[geos-commits] [SCM] GEOS branch main updated. d48d7fc02968b6a12f93afb9cd1ae74b3cd24fdf
Mon Dec 1 18:44:58 PST 2025
the project "GEOS".
The branch, main has been updated
       via  d48d7fc02968b6a12f93afb9cd1ae74b3cd24fdf (commit)
      from  c2a1d40c2d86f0b6f8028d4965ffa2aef79473d7 (commit)
revisions in full, below.
commit d48d7fc02968b6a12f93afb9cd1ae74b3cd24fdf
Author: Mike Taves <mwtoews at gmail.com>
Date:   Tue Dec 2 15:39:54 2025 +1300
    Cleanup old scripts used for Travis CI (RIP)
diff --git a/tools/ci/common.sh b/tools/ci/common.sh
deleted file mode 100755
index 08c065162..000000000
--- a/tools/ci/common.sh
+++ /dev/null
@@ -1,35 +0,0 @@
-#!/bin/sh
-# Common utilities for Travis CI setup for GEOS
-# Copyright (c) 2013 Mateusz Loskot <mateusz at loskot.net>
-# This is free software; you can redistribute and/or modify it under
-# the terms of the GNU Lesser General Public Licence as published
-# by the Free Software Foundation.
-# See the COPYING file for more information.
-if [ "$TRAVIS" != "true" ] ; then
-	echo "Running this script makes no sense outside of travis-ci.org"
-	exit 1
-fi
-# Environment
-TCI_NUMTHREADS=2
-if [ -f /sys/devices/system/cpu/online ]; then
-	# Calculates 1.5 times physical threads
-	TCI_NUMTHREADS=$(( ( $(cut -f 2 -d '-' /sys/devices/system/cpu/online) + 1 ) * 15 / 10  ))
-fi
-# Functions
-tmstamp()
-    echo -n "[$(date '+%H:%M:%S')]" ;
-run_make()
-    [ $TCI_NUMTHREADS -gt 0 ] && make -j $TCI_NUMTHREADS || make
diff --git a/tools/ci/script.sh b/tools/ci/script.sh
index 5b9e75d35..000000000
--- a/tools/ci/script.sh
+++ /dev/null
@@ -1,27 +0,0 @@
-#!/bin/sh
-# Travis CI script runner for GEOS
-if [ -z "${TRAVIS_BUILD_DIR+x}" ]; then
-  echo TRAVIS_BUILD_DIR not defined
-  exit 1
-fi
-# source common functions
-. ${TRAVIS_BUILD_DIR}/tools/ci/common.sh
-# prepare build directory
-builddir=${TRAVIS_BUILD_DIR}/_build
-mkdir -p ${builddir}
-cd ${builddir}
-# build and run tests
-${TRAVIS_BUILD_DIR}/tools/ci/script_cmake.sh
diff --git a/tools/ci/script_cmake.sh b/tools/ci/script_cmake.sh
index b5a173ee9..000000000
--- a/tools/ci/script_cmake.sh
+++ /dev/null
@@ -1,34 +0,0 @@
-#!/bin/sh
-# Travis CI script for GEOS build with CMake
-# Copyright (C) 2013 Mateusz Loskot <mateusz at loskot.net>
-  exit 1
-fi
-# return on first failure
-set -e
-cmake --version
-cmake -DCMAKE_BUILD_TYPE=${BUILD_TYPE} -DBUILD_DOCUMENTATION=YES ${TRAVIS_BUILD_DIR}
-run_make
-cmake --build . --target docs
-ctest --output-on-failure .
-if [ "${BUILD_TYPE}" = "Coverage" ]; then
-    curl -o codecov.sh https://codecov.io/bash
-    bash codecov.sh
-fi
Summary of changes:
 tools/ci/common.sh       | 35 -----------------------------------
 tools/ci/script.sh       | 27 ---------------------------
 tools/ci/script_cmake.sh | 34 ----------------------------------
 3 files changed, 96 deletions(-)
 delete mode 100755 tools/ci/common.sh
 delete mode 100755 tools/ci/script.sh
 delete mode 100755 tools/ci/script_cmake.sh
hooks/post-receive
More information about the geos-commits mailing list
