[geos-commits] [SCM] GEOS branch main updated. cad26ad980e9c7e15e7286122abcf091c37aa398
Fri Dec 5 10:47:08 PST 2025
the project "GEOS".
The branch, main has been updated
       via  cad26ad980e9c7e15e7286122abcf091c37aa398 (commit)
      from  bf3be9ebb55f2912a19acc54adeaae68c7fd01dd (commit)
revisions in full, below.
commit cad26ad980e9c7e15e7286122abcf091c37aa398
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Dec 5 10:46:04 2025 -0800
    Return EMPTY components when repeated point removal renders the underlying parts (rings, lines, etc) invalid (0 dimensional), closes #1326 and #1293
diff --git a/include/geos/io/WKTReader.h b/include/geos/io/WKTReader.h
index 7294d64f5..9fc86c978 100644
--- a/include/geos/io/WKTReader.h
+++ b/include/geos/io/WKTReader.h
@@ -115,6 +115,7 @@ public:
     std::unique_ptr<geom::Geometry> read(const std::string& wellKnownText) const;
+    std::unique_ptr<geom::CoordinateSequence> readCoordinates(const std::string& wellKnownText) const;
 protected:
     std::unique_ptr<geom::CoordinateSequence> getCoordinates(io::StringTokenizer* tokenizer, OrdinateSet& ordinates) const;
diff --git a/include/geos/operation/valid/RepeatedPointRemover.h b/include/geos/operation/valid/RepeatedPointRemover.h
index e6e91c24c..d70e71802 100644
--- a/include/geos/operation/valid/RepeatedPointRemover.h
+++ b/include/geos/operation/valid/RepeatedPointRemover.h
@@ -48,6 +48,13 @@ namespace valid {
                 const geom::CoordinateSequence* seq,
                 double tolerance = 0.0);
+        static std::unique_ptr<geom::CoordinateSequence>
+            removeRepeatedOrInvalidPoints(
+                const geom::CoordinateSequence* seq,
+                double tolerance = 0.0) {
+                return removeRepeatedAndInvalidPoints(seq, tolerance);
         static std::unique_ptr<geom::Geometry>
             removeRepeatedPoints(
                 const geom::Geometry* geom,
diff --git a/src/coverage/CoverageRingEdges.cpp b/src/coverage/CoverageRingEdges.cpp
index 4d1495a47..a5a697cc1 100644
--- a/src/coverage/CoverageRingEdges.cpp
+++ b/src/coverage/CoverageRingEdges.cpp
@@ -140,7 +140,8 @@ CoverageRingEdges::extractRingEdges(
     std::unique_ptr<CoordinateSequence> pts
         = RepeatedPointRemover::removeRepeatedPoints( ring->getCoordinatesRO() );
     std::vector<CoverageEdge*> ringEdges;
-    //-- if compacted ring is too short, don't process it
+    // if compacted ring is too short, don't process it,
+    // just return empty vector
     if (pts->getSize() < 3)
       return ringEdges;
diff --git a/src/io/WKTReader.cpp b/src/io/WKTReader.cpp
index 2b4400a6b..3c1d6fa69 100644
--- a/src/io/WKTReader.cpp
+++ b/src/io/WKTReader.cpp
@@ -65,6 +65,23 @@ WKTReader::read(const std::string& wellKnownText) const
     return ret;
+std::unique_ptr<CoordinateSequence>
+WKTReader::readCoordinates(const std::string& wellKnownText) const
+    CLocalizer clocale;
+    StringTokenizer tokenizer(wellKnownText);
+    OrdinateSet ordinateFlags = OrdinateSet::createXY();
+    auto ret = getCoordinates(&tokenizer, ordinateFlags);
+    if (tokenizer.peekNextToken() != StringTokenizer::TT_EOF) {
+        tokenizer.nextToken();
+        throw ParseException("Unexpected text after end of geometry");
+    return ret;
 WKTReader::getCoordinates(StringTokenizer* tokenizer, OrdinateSet& ordinateFlags) const
diff --git a/src/operation/valid/RepeatedPointRemover.cpp b/src/operation/valid/RepeatedPointRemover.cpp
index 22b4a9aa2..aea5e320b 100644
--- a/src/operation/valid/RepeatedPointRemover.cpp
+++ b/src/operation/valid/RepeatedPointRemover.cpp
@@ -200,19 +200,21 @@ public:
         auto filtCoords = filter.getCoords();
         if (filtCoords->size() == 0) return nullptr;
+        if (filtCoords->size() == 1) return nullptr;
         // End points for comparison and sequence repair
         const Coordinate& origEndCoord = coordinates->back();
+        bool origEndCoordIsValid = origEndCoord.isValid();
         // Fluff up overly small filtered outputs
-        if(filtCoords->size() < minLength) {
+        if(filtCoords->size() < minLength && origEndCoordIsValid) {
             filtCoords->add(origEndCoord);
         const Coordinate& filtEndCoord = filtCoords->back();
         // We stripped the last point, let's put it back on
-        if (!origEndCoord.equals2D(filtEndCoord)) {
+        if (origEndCoordIsValid && !origEndCoord.equals2D(filtEndCoord)) {
             // If the end of the filtered coordinates is within
             // tolerance of the original end, we drop the last filtered
             // coordinate so the output still follows the tolerance rule
@@ -223,8 +225,14 @@ public:
-        return filtCoords;
+        if (filtCoords->size() <= 1) return nullptr;
+        else return filtCoords;
 }; // RepeatedPointCoordinateOperation
diff --git a/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp b/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp
index 0b78590b2..c1a53bb32 100644
--- a/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp
+++ b/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp
@@ -32,9 +32,9 @@ void object::test<1>
     geom1_ = GEOSGeomFromWKT("POLYGON((0 0, 0 1, 0 10, 10 10, 10 0, 9 0, 1 0, 0 0))");
-    geom2_ = GEOSRemoveRepeatedPoints(geom1_, 3.0);
+    result_ = GEOSRemoveRepeatedPoints(geom1_, 3.0);
     expected_ = GEOSGeomFromWKT("POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0))");
-    ensure_geometry_equals(geom2_, expected_);
+    ensure_geometry_equals(result_, expected_);
 // https://github.com/libgeos/geos/issues/759
@@ -44,9 +44,9 @@ void object::test<2>
     geom1_ = GEOSGeomFromWKT("POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0))");
+    expected_ = GEOSGeomFromWKT("POLYGON EMPTY");
     result_ = GEOSRemoveRepeatedPoints(geom1_, 2.0);
-    ensure(result_ == nullptr);
 template<>
@@ -57,7 +57,6 @@ void object::test<3>()
     ensure(input_);
     result_ = GEOSRemoveRepeatedPoints(input_, 0);
     ensure("curved geometry not supported", result_ == nullptr);
diff --git a/tests/unit/operation/valid/RepeatedPointRemoverTest.cpp b/tests/unit/operation/valid/RepeatedPointRemoverTest.cpp
index 205eefcc9..5d12c1b35 100644
--- a/tests/unit/operation/valid/RepeatedPointRemoverTest.cpp
+++ b/tests/unit/operation/valid/RepeatedPointRemoverTest.cpp
@@ -44,6 +44,19 @@ struct test_repeated_point_remover_test_data
         return writer.write(&geom);
+    void
+    checkSimpleSequence(const std::string& input, const std::string& expected, double tolerance = 0.0)
+        std::unique_ptr<CoordinateSequence> inCoords = reader.readCoordinates(input);
+        std::unique_ptr<CoordinateSequence> exCoords = reader.readCoordinates(expected);
+        auto outCoords = RepeatedPointRemover::removeRepeatedPoints(inCoords.get(), tolerance);
+        // std::cout << "output" << std::endl;
+        // std::cout << outCoords->toString() << std::endl;
+        // std::cout << "expected" << std::endl;
+        // std::cout <<  exCoords->toString() << std::endl;
+        ensure_equals(*outCoords, *exCoords);
     void
     checkSequence(const std::string& input, const std::string& expected, double tolerance = 0.0)
@@ -58,6 +71,10 @@ struct test_repeated_point_remover_test_data
         ensure_equals("hasZ", exCoords->hasZ(), outCoords->hasZ());
         ensure_equals("hasM", exCoords->hasM(), outCoords->hasM());
@@ -75,7 +92,6 @@ struct test_repeated_point_remover_test_data
         ensure_equals_geometry(outGeom.get(), exGeom.get());
 typedef test_group<test_repeated_point_remover_test_data> group;
@@ -87,9 +103,9 @@ template<>
 template<>
 void object::test<1>()
-    checkSequence(
-        "LINESTRING (3 7, 8 8, 8 8, 8 8, 10 9)",
-        "LINESTRING (3 7, 8 8, 10 9)",
+        "(3 7, 8 8, 8 8, 8 8, 10 9)",
+        "(3 7, 8 8, 10 9)",
         0.0
@@ -98,24 +114,28 @@ template<>
 template<>
 void object::test<2>()
-    checkSequence(
-        "LINESTRING (3 7, 8 8, 8 8, 8 8)",
-        "LINESTRING (3 7, 8 8)",
+        "(3 7, 8 8, 8 8, 8 8)",
+        "(3 7, 8 8)",
         0.0
+// CoordinateSequences just retain each coordinate within
+// the filter tolerance
 template<>
 template<>
-    checkSequence(
-        "LINESTRING (0 0, 1 0, 4 0, 5 0)",
-        "LINESTRING (0 0, 4 0)",
+        "(0 0, 1 0, 4 0, 5 0)",
+        "(0 0, 4 0)",
         3.0
+// Linestrings note the last point and somehow
+// retain it in preference over the internal point
 template<>
 template<>
 void object::test<4>()
@@ -123,7 +143,7 @@ void object::test<4>()
     checkGeometry(
         "LINESTRING (0 0, 5 0)",
-        3.0
+        3
@@ -140,7 +160,7 @@ void object::test<5>()
-// Dimension is preserved
+// Dimension is preserved during reduction
 template<>
 template<>
 void object::test<6>()
@@ -151,6 +171,141 @@ void object::test<6>()
+// Removing from a sequence with enough tolerance
+// results in single-entry sequence
+template<>
+template<>
+void object::test<7>()
+        "(3 7, 3 7, 3 7, 3 7)",
+        "(3 7)",
+        0.0
+template<>
+template<>
+void object::test<8>()
+        "(3 7, 3.1 7.1, 3.2 7.2, 3.3 7.3)",
+        "(3 7)",
+        1.0
+template<>
+template<>
+void object::test<9>()
+    checkGeometry(
+        "LINESTRING (0 0, 0 1, 0 2, 0 3)",
+        "LINESTRING EMPTY",
+        14.0
+// small hole should collapse away
+template<>
+template<>
+void object::test<10>()
+    checkGeometry(
+        "POLYGON ((0 0, 9 0, 10 0, 10 10, 0 10, 0 1, 0 0), (5 5, 5 6, 6 6, 6 5, 5 5))",
+        "POLYGON ((0 0, 9 0, 10 10, 0 10, 0 0))",
+        3.0
+// small exterior ring should disappear whole polygon
+template<>
+template<>
+void object::test<11>()
+    checkGeometry(
+        "POLYGON ((0 0, 9 0, 10 0, 10 10, 0 10, 0 1, 0 0))",
+        "POLYGON ((0 0, 10 10, 0 0))",
+        12.0
+template<>
+template<>
+void object::test<12>()
+    checkGeometry(
+        "POLYGON EMPTY",
+        22.0
+// Careful not to replace invalid coordinates
+template<>
+template<>
+void object::test<13>()
+    checkGeometry(
+        "LINESTRING (0 0, 0 Inf, 1 1, Inf 0)",
+        "LINESTRING (0 0, 1 1)",
+        1.0
+// If it filters down to just one point, it should be empty
+template<>
+template<>
+void object::test<14>()
+    checkGeometry(
+        "LINESTRING (0 0, 0 Inf, 1 1)",
+        2.0
+// Filter out invalid coordinate, even at start/ends
+template<>
+template<>
+void object::test<15>()
+    checkGeometry(
+        "POLYGON ((Inf Inf, 0 0, 10 0, 10 10, 0 10, 0 0, Inf Inf))",
+        "POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))",
+        2.0
+template<>
+template<>
+void object::test<16>()
+    checkGeometry(
+        "POLYGON EMPTY",
+        22.0
+// https://github.com/libgeos/geos/issues/1293
+// Hole collapses, should not error out.
+template<>
+template<>
+void object::test<17>()
+    checkGeometry(
+        "POLYGON ((139770.26822331376024522 188334.00010800323798321, 139769.5 188338.01162790699163452, 139769.5 188338.3723930635896977, 139769.5 188338.5, 139769.81343283582828008 188338.5, 139770.375 188339.375, 139772.39924806414637715 188340.26989983080420643, 139770.26822331376024522 188334.00010800323798321),(139769.75256541155977175 188338.40516005983226933, 139769.75256541153066792 188338.40516005983226933, 139769.75256541153066792 188338.4051600598031655, 139769.75256541155977175 188338.40516005983226933))",
+        "POLYGON ((139769.5 188338.011627907, 139769.5 188338.3723930636, 139769.5 188338.5, 139769.81343283583 188338.5, 139770.375 188339.375, 139772.39924806415 188340.2698998308, 139770.26822331376 188334.00010800324, 139769.5 188338.011627907))",
+        1e-8
 } // namespace tut
Summary of changes:
 include/geos/io/WKTReader.h                        |   1 +
 .../geos/operation/valid/RepeatedPointRemover.h    |   7 +
 src/coverage/CoverageRingEdges.cpp                 |   3 +-
 src/io/WKTReader.cpp                               |  17 ++
 src/operation/valid/RepeatedPointRemover.cpp       |  14 +-
 tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp   |   9 +-
 .../operation/valid/RepeatedPointRemoverTest.cpp   | 179 +++++++++++++++++++--
 7 files changed, 209 insertions(+), 21 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
