[geos-commits] [SCM] GEOS branch main updated. 7403b6fdee35ba00570b440f697b0976c6582252
Fri Dec 5 13:19:40 PST 2025
the project "GEOS".
The branch, main has been updated
       via  7403b6fdee35ba00570b440f697b0976c6582252 (commit)
      from  a7626dbb6dd7f19b5edb6846bddb1550a0d7c142 (commit)
revisions in full, below.
commit 7403b6fdee35ba00570b440f697b0976c6582252
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Dec 5 13:19:04 2025 -0800
    Add CMAKE detection for openmd simd support in compiler, closes #1334
diff --git a/CMakeLists.txt b/CMakeLists.txt
index a1e2f0c6e..79d397efb 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -230,6 +230,24 @@ target_compile_options(geos_cxx_flags INTERFACE
 # works with multi-configuration generators.
 target_compile_definitions(geos_cxx_flags INTERFACE $<$<NOT:$<CONFIG:Debug>>:NDEBUG>)
+# OpenMP SIMD
+include(CheckCXXCompilerFlag)
+if(MSVC)
+  set(SIMD_FLAGS "/openmp:experimental")
+elseif(CMAKE_CXX_COMPILER_ID STREQUAL "IntelLLVM")
+  set(SIMD_FLAGS "-qopenmp-simd")
+else()
+  set(SIMD_FLAGS "-fopenmp-simd")
+endif()
+check_cxx_compiler_flag(${SIMD_FLAGS} COMPILER_HAS_SIMD)
+if(COMPILER_HAS_SIMD)
+  target_compile_options(geos_cxx_flags INTERFACE ${SIMD_FLAGS})
+  target_compile_definitions(geos_cxx_flags INTERFACE HAVE_OPEN_SIMD)
+endif()
 # Target geos_developer_cxx_flags: developer mode compilation flags
Summary of changes:
 CMakeLists.txt | 18 ++++++++++++++++++
 1 file changed, 18 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
