[geos-commits] [SCM] GEOS branch main updated. 347b3fad55b05750e471aafa8ca3c7338ba25ee5
git at osgeo.org
git at osgeo.org
Fri Dec 5 15:12:33 PST 2025
the project "GEOS".
The branch, main has been updated
via 347b3fad55b05750e471aafa8ca3c7338ba25ee5 (commit)
via 14376eeb7a53f970fc31a574c941fd1d3a4aed5b (commit)
from 953e1c3d307d9e9a3e2c95fd7b981c39d3365317 (commit)
revisions in full, below.
commit 347b3fad55b05750e471aafa8ca3c7338ba25ee5
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Dec 5 15:05:31 2025 -0800
news
diff --git a/NEWS.md b/NEWS.md
index 716795d7a..43926615a 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -5,6 +5,9 @@
- New things:
+- Breaking Changes:
+ - BufferOp returns POLYGON EMPTY when fed Inf/Nan coords (GH-1332)
## Changes in 3.14.0
2025-08-21
commit 14376eeb7a53f970fc31a574c941fd1d3a4aed5b
Date: Fri Dec 5 14:54:19 2025 -0800
Return EMPTY when confronted with request to buffer input with NaN/Inf coordinates, references #1332
diff --git a/src/operation/buffer/BufferCurveSetBuilder.cpp b/src/operation/buffer/BufferCurveSetBuilder.cpp
index 7fc39e77c..69e5976e3 100644
--- a/src/operation/buffer/BufferCurveSetBuilder.cpp
+++ b/src/operation/buffer/BufferCurveSetBuilder.cpp
@@ -201,6 +201,10 @@ BufferCurveSetBuilder::addLineString(const LineString* line)
auto coord = operation::valid::RepeatedPointRemover::removeRepeatedAndInvalidPoints(line->getCoordinatesRO());
+ if (coord->size() == 0) {
+ return;
* Rings (closed lines) are generated with a continuous curve,
* with no end arcs. This produces better quality linework,
@@ -272,21 +276,22 @@ BufferCurveSetBuilder::addPolygon(const Polygon* p)
return;
- auto shellCoord =
+ auto shellCoords =
operation::valid::RepeatedPointRemover::removeRepeatedAndInvalidPoints(shell->getCoordinatesRO());
- if (shellCoord->isEmpty()) {
- throw util::GEOSException("Shell empty after removing invalid points");
+ if (shellCoords->isEmpty()) {
+ return;
+ //throw util::GEOSException("Shell empty after removing invalid points");
// don't attempt to buffer a polygon
// with too few distinct vertices
- if(distance <= 0.0 && shellCoord->size() < 3) {
+ if(distance <= 0.0 && shellCoords->size() < 3) {
return;
addPolygonRingSide(
- shellCoord.get(),
+ shellCoords.get(),
offsetDistance,
offsetSide,
@@ -302,13 +307,17 @@ BufferCurveSetBuilder::addPolygon(const Polygon* p)
continue;
- auto holeCoord = valid::RepeatedPointRemover::removeRepeatedAndInvalidPoints(hole->getCoordinatesRO());
+ auto holeCoords = valid::RepeatedPointRemover::removeRepeatedAndInvalidPoints(hole->getCoordinatesRO());
+ //-- skip if no valid coordinates
+ if (holeCoords->isEmpty())
+ continue;
// Holes are topologically labelled opposite to the shell,
// since the interior of the polygon lies on their opposite
// side (on the left, if the hole is oriented CCW)
addPolygonRingSide(
- holeCoord.get(),
+ holeCoords.get(),
offsetDistance,
Position::opposite(offsetSide),
diff --git a/tests/unit/capi/GEOSBufferTest.cpp b/tests/unit/capi/GEOSBufferTest.cpp
index 538dfbf75..702cc8dff 100644
--- a/tests/unit/capi/GEOSBufferTest.cpp
+++ b/tests/unit/capi/GEOSBufferTest.cpp
@@ -436,10 +436,15 @@ void object::test<24>()
std::string wkb("0106000020E61000000100000001030000000100000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F");
geom1_ = GEOSGeomFromHEX_buf(reinterpret_cast<const unsigned char*>(wkb.c_str()), wkb.size());
ensure(geom1_ != nullptr);
+ expected_ = fromWKT("POLYGON EMPTY");
+ ensure(expected_ != nullptr);
geom2_ = GEOSBuffer(geom1_, 20, 8);
- ensure(geom2_ == nullptr);
+ ensure_geometry_equals(expected_, geom2_, 0.001);
geom3_ = GEOSBuffer(geom1_, -20, 8);
- ensure(geom3_ == nullptr);
+ ensure_geometry_equals(expected_, geom3_, 0.001);
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index 7ac585ccc..3e5bc5d92 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -63,13 +63,19 @@ struct test_bufferop_data {
ensure_equals("Area", actualArea, expectedArea, tolerance);
- void checkBufferEmpty(const std::string& wkt, double dist, bool isEmpty)
+ void checkBufferPolygonEmpty(const std::string& wkt, double dist, bool isEmpty)
std::unique_ptr<Geometry> geom = wktreader.read(wkt);
std::unique_ptr<Geometry> actual = geom->buffer(dist);
ensure_equals(actual->isEmpty(), isEmpty);
+ void checkBufferPolygonEmpty(const Geometry& geom, double dist, bool isEmpty)
+ std::unique_ptr<Geometry> actual = geom.buffer(dist);
+ ensure_equals(actual->isEmpty(), isEmpty);
void checkBuffer(const std::string& wkt, double dist, double tolerance, const std::string& wktExpected)
@@ -421,10 +427,10 @@ void object::test<16>
std::string wkt0("POLYGON ((666360.09 429614.71, 666344.4 429597.12, 666358.47 429584.52, 666374.5 429602.33, 666360.09 429614.71))");
- checkBufferEmpty(wkt0, -9, false);
- checkBufferEmpty(wkt0, -10, true);
- checkBufferEmpty(wkt0, -15, true);
- checkBufferEmpty(wkt0, -18, true);
+ checkBufferPolygonEmpty(wkt0, -9, false);
+ checkBufferPolygonEmpty(wkt0, -10, true);
+ checkBufferPolygonEmpty(wkt0, -15, true);
+ checkBufferPolygonEmpty(wkt0, -18, true);
// Test for https://trac.osgeo.org/geos/ticket/1101 - Non-empty negative buffer of 5-pt convex polygon
@@ -434,10 +440,10 @@ void object::test<17>
std::string wkt0("POLYGON ((6 20, 16 20, 21 9, 9 0, 0 10, 6 20))");
- checkBufferEmpty(wkt0, -8, false);
- checkBufferEmpty(wkt0, -8.6, true);
- checkBufferEmpty(wkt0, -9.6, true);
- checkBufferEmpty(wkt0, -11, true);
+ checkBufferPolygonEmpty(wkt0, -8, false);
+ checkBufferPolygonEmpty(wkt0, -8.6, true);
+ checkBufferPolygonEmpty(wkt0, -9.6, true);
+ checkBufferPolygonEmpty(wkt0, -11, true);
// Test for https://trac.osgeo.org/geos/ticket/1101 - Buffer of Polygon with hole with hole eroded
@@ -662,4 +668,39 @@ void object::test<30>
ensure(bufGeom->getArea() > 12000);
+// testInvalidCoordPoint
+template<>
+template<>
+void object::test<31> ()
+ // works for Inf ordinates as well
+ auto geom = wktreader.read("POINT (NaN NaN)");
+ checkBufferPolygonEmpty(*geom, 1, true);
+// testInvalidCoordsLine
+template<>
+template<>
+void object::test<32> ()
+ auto geom = wktreader.read("LINESTRING (NaN NaN, NaN NaN)");
+// testInvalidCoordShell
+template<>
+template<>
+void object::test<33> ()
+ // using Inf ordinates creates a valid ring with equal endpoints
+ // this would be simpler if JTS WKT supported Inf
+ auto geom = wktreader.read("POLYGON ((Inf Inf, Inf Inf, Inf Inf, Inf Inf, Inf Inf))");
} // namespace tut
Summary of changes:
NEWS.md | 3 ++
src/operation/buffer/BufferCurveSetBuilder.cpp | 23 +++++++---
tests/unit/capi/GEOSBufferTest.cpp | 9 +++-
tests/unit/operation/buffer/BufferOpTest.cpp | 59 ++++++++++++++++++++++----
4 files changed, 76 insertions(+), 18 deletions(-)
hooks/post-receive
More information about the geos-commits
