[geos-commits] [SCM] GEOS branch 3.13 updated. cd28a08b0554dd9156856458b2f3123bbb8ba41c
git at osgeo.org
git at osgeo.org
Wed Dec 10 11:18:55 PST 2025
the project "GEOS".
The branch, 3.13 has been updated
via cd28a08b0554dd9156856458b2f3123bbb8ba41c (commit)
via 89546095ea121ac948b46b2f2795e2d0fbf8bf82 (commit)
from 28f2e42a6c40910fda9f08fddec28f43c148583b (commit)
revisions in full, below.
commit cd28a08b0554dd9156856458b2f3123bbb8ba41c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Dec 10 11:18:02 2025 -0800
Update NEWS
diff --git a/NEWS.md b/NEWS.md
index 5bcee20e8..d413c6c81 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -8,6 +8,7 @@
- Fix DepthSegment comparison logic (really this time) (GH-1266, Martin Davis)
- Change CoverageGapFinder to return polygons (Martin Davis)
- Fix incorrect envelope calculation for arcs (GH-1314, Dan Baston)
+ - Quiet FP_DIVBYZERO exception from CGAlgorithmsDD::intersection (GH-1235, Paul Ramsey)
## Changes in 3.13.1
2025-03-03
commit 89546095ea121ac948b46b2f2795e2d0fbf8bf82
Date: Wed Dec 10 11:13:59 2025 -0800
Quiet FP_DIVBYZERO exception from CGAlgorithmsDD::intersection showing in downstream libraries, closes #1235
diff --git a/include/geos/math/DD.h b/include/geos/math/DD.h
index 61e3a08a7..764801251 100644
--- a/include/geos/math/DD.h
+++ b/include/geos/math/DD.h
@@ -114,6 +114,7 @@ class GEOS_DLL DD {
int signum() const;
DD rint() const;
+ void setNaN();
public:
DD(double p_hi, double p_lo) : hi(p_hi), lo(p_lo) {};
@@ -165,6 +166,7 @@ class GEOS_DLL DD {
static DD pow(const DD &d, int exp);
static DD trunc(const DD &d);
+ bool isInf() const;
bool isNaN() const;
bool isNegative() const;
bool isPositive() const;
diff --git a/src/algorithm/CGAlgorithmsDD.cpp b/src/algorithm/CGAlgorithmsDD.cpp
index ccfef602e..1526d3754 100644
--- a/src/algorithm/CGAlgorithmsDD.cpp
+++ b/src/algorithm/CGAlgorithmsDD.cpp
@@ -139,19 +139,12 @@ CGAlgorithmsDD::intersection(const CoordinateXY& p1, const CoordinateXY& p2,
DD y = (qx * pw) - (px * qw);
DD w = (px * qy) - (qx * py);
+ if (w.isZero())
+ return CoordinateXY::getNull();
double xInt = (x / w).ToDouble();
double yInt = (y / w).ToDouble();
- Coordinate rv;
- if (!std::isfinite(xInt) || !std::isfinite(yInt)) {
- rv.setNull();
- return rv;
- rv.x = xInt;
- rv.y = yInt;
- return rv;
+ return {xInt, yInt};
/* public static */
diff --git a/src/math/DD.cpp b/src/math/DD.cpp
index c620c1b62..86d284a11 100644
--- a/src/math/DD.cpp
+++ b/src/math/DD.cpp
@@ -20,8 +20,16 @@
namespace geos {
namespace math { // geos.util
+/* private */
+void DD::setNaN()
+ hi = std::numeric_limits<double>::quiet_NaN();
+/* public */
+bool DD::isInf() const
+ return std::isinf(hi);
/* public */
bool DD::isNaN() const
@@ -346,6 +354,7 @@ DD DD::determinant(double x1, double y1, double x2, double y2)
return determinant(DD(x1), DD(y1), DD(x2), DD(y2) );
* Computes the value of this number raised to an integral power.
* Follows semantics of Java Math.pow as closely as possible.
diff --git a/tests/unit/algorithm/MinimumAreaRectangleTest.cpp b/tests/unit/algorithm/MinimumAreaRectangleTest.cpp
index dad960837..506ecea7f 100644
--- a/tests/unit/algorithm/MinimumAreaRectangleTest.cpp
+++ b/tests/unit/algorithm/MinimumAreaRectangleTest.cpp
@@ -148,35 +148,37 @@ template<>
template<>
void object::test<10>()
- // bool error = false;
- // try {
- checkMinRectangle(
- "LINESTRING(-99.48710639268086 34.79029839231914,-99.48370699999998 34.78689899963806,-99.48152167568102 34.784713675318976)",
- "POLYGON ((-99.48710639268066 34.790298392318675, -99.48710639268066 34.790298392318675, -99.48152167568082 34.78471367531866, -99.48152167568082 34.78471367531866, -99.48710639268066 34.790298392318675))");
- // } catch (std::exception& e) {
- // error = true;
- // // errorMessage = e.what();
- // ensure("caught exception", error == true);
+ checkMinRectangle(
+ "LINESTRING(-99.48710639268086 34.79029839231914,-99.48370699999998 34.78689899963806,-99.48152167568102 34.784713675318976)",
+ "POLYGON ((-99.48710639268066 34.790298392318675, -99.48710639268066 34.790298392318675, -99.48152167568082 34.78471367531866, -99.48152167568082 34.78471367531866, -99.48710639268066 34.790298392318675))");
// testBadRectl
template<>
template<>
void object::test<11>()
- // try {
checkMinRectangle(
"POLYGON ((-5.21175 49.944633, -5.77435 50.021367, -5.7997 50.0306, -5.81815 50.0513, -5.82625 50.073567, -5.83085 50.1173, -6.2741 56.758767, -5.93245 57.909, -5.1158 58.644533, -5.07915 58.661733, -3.42575 58.686633, -3.1392 58.6685, -3.12495 58.666233, -1.88745 57.6444, 1.68845 52.715133, 1.7057 52.6829, 1.70915 52.6522, 1.7034 52.585433, 1.3867 51.214033, 1.36595 51.190267, 1.30485 51.121967, 0.96365 50.928567, 0.93025 50.912433, 0.1925 50.7436, -5.21175 49.944633))",
"POLYGON ((1.8583607388069103 50.41649058582797, -5.816631979932251 49.904263313964535, -6.395241388167441 58.57389735949991, 1.2797513305717105 59.08612463136336, 1.8583607388069103 50.41649058582797))");
- // error = true;
+// https://github.com/libgeos/geos/issues/1235
+// throwing FE_DIVBYZERO
+template<>
+template<>
+void object::test<12>()
+ "POLYGON ((-100 -100, -100 100, 100 100, 100 -100, -100 -100))",
+ "POLYGON ((-100 -100, -100 100, 100 100, 100 -100, -100 -100))");
} // namespace tut
diff --git a/tests/unit/geos_unit.cpp b/tests/unit/geos_unit.cpp
index 8e008c8b2..a3a78236f 100644
--- a/tests/unit/geos_unit.cpp
+++ b/tests/unit/geos_unit.cpp
@@ -49,7 +49,7 @@ usage()
<< " " << module << " geos::geom::Envelope\n"
<< " " << module << " geos::geom::Envelope 2\n"
<< endl
- << "GEOS homepage: http://geos.osgeo.org" << endl;
+ << "GEOS homepage: https://libgeos.org" << endl;
int
Summary of changes:
NEWS.md | 1 +
include/geos/math/DD.h | 2 ++
src/algorithm/CGAlgorithmsDD.cpp | 15 +++-------
src/math/DD.cpp | 13 ++++++--
tests/unit/algorithm/MinimumAreaRectangleTest.cpp | 36 ++++++++++++-----------
tests/unit/geos_unit.cpp | 2 +-
6 files changed, 38 insertions(+), 31 deletions(-)
hooks/post-receive
More information about the geos-commits
