[geos-commits] [SCM] GEOS branch main updated. f112e8421cf3a1e9b6a62e032b03e4fa8e2733b8
git at osgeo.org
git at osgeo.org
Thu Dec 11 12:04:58 PST 2025
the project "GEOS".
The branch, main has been updated
via f112e8421cf3a1e9b6a62e032b03e4fa8e2733b8 (commit)
via 0ef7d3123bf0752b6f560886b3b25543e084f4a0 (commit)
via 5b0e56a456ca38b7448ddc653e6a712b37e6146d (commit)
via fbb3d5ce2544f3b76f9dd904ebbf06e0c99e5599 (commit)
from de22f50d319ce72004d0228fef00a3964eeb6a6a (commit)
revisions in full, below.
commit f112e8421cf3a1e9b6a62e032b03e4fa8e2733b8
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Dec 11 09:36:04 2025 -0500
OffsetCurveTest: Fix invalid join style
diff --git a/tests/unit/operation/buffer/OffsetCurveTest.cpp b/tests/unit/operation/buffer/OffsetCurveTest.cpp
index 0e817439f..e6ad8b183 100644
--- a/tests/unit/operation/buffer/OffsetCurveTest.cpp
+++ b/tests/unit/operation/buffer/OffsetCurveTest.cpp
@@ -523,7 +523,7 @@ void object::test<38> ()
checkOffsetCurve(
"LINESTRING (20 20, 50 50, 80 20)",
- 10, 2, -1, -1,
+ 10, 2, BufferParameters::JOIN_ROUND, -1,
"LINESTRING (12.928932188134524 27.071067811865476, 42.928932188134524 57.071067811865476, 44.44429766980398 58.314696123025456, 46.1731656763491 59.23879532511287, 48.04909677983872 59.80785280403231, 50 60, 51.95090322016128 59.80785280403231, 53.8268343236509 59.23879532511287, 55.55570233019602 58.314696123025456, 57.071067811865476 57.071067811865476, 87.07106781186548 27.071067811865476)"
commit 0ef7d3123bf0752b6f560886b3b25543e084f4a0
Date: Thu Dec 11 09:29:25 2025 -0500
LineDissolver: Avoid null-pointer dereference
diff --git a/src/dissolve/LineDissolver.cpp b/src/dissolve/LineDissolver.cpp
index 2c036cc0d..674c132d5 100644
--- a/src/dissolve/LineDissolver.cpp
+++ b/src/dissolve/LineDissolver.cpp
@@ -50,6 +50,10 @@ LineDissolver::dissolve(const Geometry* g)
void
LineDissolver::add(const Geometry* geom)
+ if (factory == nullptr) {
+ factory = geom->getFactory();
struct LineStringFilter : public GeometryComponentFilter {
LineDissolver *m_ld;
@@ -83,9 +87,6 @@ LineDissolver::add(std::vector<const Geometry*> geometries)
void
LineDissolver::add(const LineString* lineString)
- if (factory == nullptr) {
- factory = lineString->getFactory();
const CoordinateSequence* seq = lineString->getCoordinatesRO();
bool doneStart = false;
for (std::size_t i = 1; i < seq->size(); i++) {
@@ -129,6 +130,7 @@ LineDissolver::computeResult()
if (MarkHalfEdge::isMarked(e)) continue;
process(e);
result = factory->buildGeometry(std::move(lines));
commit 5b0e56a456ca38b7448ddc653e6a712b37e6146d
Date: Thu Dec 11 09:15:05 2025 -0500
OffsetCurve: Add guard for curved inputs
diff --git a/src/operation/buffer/OffsetCurve.cpp b/src/operation/buffer/OffsetCurve.cpp
index 09fc7d074..02ee1f94f 100644
--- a/src/operation/buffer/OffsetCurve.cpp
+++ b/src/operation/buffer/OffsetCurve.cpp
@@ -62,6 +62,8 @@ OffsetCurve::setJoined(bool pIsJoined)
std::unique_ptr<Geometry>
OffsetCurve::getCurve()
+ util::ensureNoCurvedComponents(inputGeom);
GeometryMapper::mapOp GetCurveMapOp = [this](const Geometry& geom)->std::unique_ptr<Geometry> {
if (geom.getGeometryTypeId() == GEOS_POINT) return nullptr;
commit fbb3d5ce2544f3b76f9dd904ebbf06e0c99e5599
Date: Thu Dec 11 09:13:45 2025 -0500
WKTWriter: Fix casts to incorrect type
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index 7c8f04bdc..8293b31b5 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -241,12 +241,12 @@ WKTWriter::appendGeometryTaggedText(const Geometry& geometry,
case GEOS_CIRCULARSTRING: appendSimpleCurveTaggedText(static_cast<const SimpleCurve&>(geometry), outputOrdinates, level, writer); break;
case GEOS_COMPOUNDCURVE: appendCompoundCurveTaggedText(static_cast<const CompoundCurve&>(geometry), outputOrdinates, level, writer); break;
case GEOS_CURVEPOLYGON:
- case GEOS_POLYGON: appendSurfaceTaggedText(static_cast<const Polygon&>(geometry), outputOrdinates, level, writer); break;
+ case GEOS_POLYGON: appendSurfaceTaggedText(static_cast<const Surface&>(geometry), outputOrdinates, level, writer); break;
case GEOS_MULTIPOINT: appendMultiPointTaggedText(static_cast<const MultiPoint&>(geometry), outputOrdinates, level, writer); break;
case GEOS_MULTICURVE:
- case GEOS_MULTILINESTRING: appendMultiCurveTaggedText(static_cast<const MultiLineString&>(geometry), outputOrdinates, level, writer); break;
+ case GEOS_MULTILINESTRING: appendMultiCurveTaggedText(static_cast<const GeometryCollection&>(geometry), outputOrdinates, level, writer); break;
case GEOS_MULTISURFACE:
- case GEOS_MULTIPOLYGON: appendMultiSurfaceTaggedText(static_cast<const MultiPolygon&>(geometry), outputOrdinates, level, writer); break;
+ case GEOS_MULTIPOLYGON: appendMultiSurfaceTaggedText(static_cast<const GeometryCollection&>(geometry), outputOrdinates, level, writer); break;
case GEOS_GEOMETRYCOLLECTION: appendGeometryCollectionTaggedText(static_cast<const GeometryCollection&>(geometry), outputOrdinates, level, writer); break;
Summary of changes:
src/dissolve/LineDissolver.cpp | 8 +++++---
src/io/WKTWriter.cpp | 6 +++---
src/operation/buffer/OffsetCurve.cpp | 2 ++
tests/unit/operation/buffer/OffsetCurveTest.cpp | 2 +-
4 files changed, 11 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
