[geos-commits] [SCM] GEOS branch main updated. 9e758a90052a3946a75d8dbed206789665d55944
Tue Feb 4 11:12:51 PST 2025
the project "GEOS".
The branch, main has been updated
       via  9e758a90052a3946a75d8dbed206789665d55944 (commit)
      from  fa6714ecd4fe5ec660f25114a2f2af0f4738c14a (commit)
revisions in full, below.
commit 9e758a90052a3946a75d8dbed206789665d55944
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Feb 4 11:12:28 2025 -0800
    Simplify signature of geosop operations
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index a0d176e6c..986d1856a 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -118,10 +118,10 @@ struct GeometryOpCreator {
     std::function<GeometryOp *( std::string name )> create;
-std::vector<const Geometry*> toList(const std::unique_ptr<Geometry>& geom) {
+std::vector<const Geometry*> toList(const Geometry& geom) {
     std::vector<const Geometry*> geomList;
-    for (std::size_t i = 0; i < geom->getNumGeometries(); i++) {
-        geomList.emplace_back( geom->getGeometryN(i));
+    for (std::size_t i = 0; i < geom.getNumGeometries(); i++) {
+        geomList.emplace_back( geom.getGeometryN(i));
     return geomList;
@@ -144,45 +144,45 @@ std::vector<GeometryOpCreator> opRegistry {
 { "copy", [](std::string name) { return GeometryOp::create(name,
     catGeom, "copy geometry",
-    [](const std::unique_ptr<Geometry>& geom) {
-        return new Result( geom->clone() );
+    [](const Geometry& geom) {
+        return new Result( geom.clone() );
 { "envelope", [](std::string name) { return GeometryOp::create(name,
     catGeom, "envelope of geometry",
-        return new Result( geom->getEnvelope() );
+        return new Result( geom.getEnvelope() );
 {"hasZ", [](std::string name) { return GeometryOp::create(name,
     catGeom,
     "test if geometry has Z ordinate",
     Result::typeBool,
-        return new Result( geom->hasZ() );
+        return new Result( geom.hasZ() );
 {"hasM", [](std::string name) { return GeometryOp::create(name,
     catGeom,
     "test if geometry has M ordinate",
     Result::typeBool,
-        return new Result( geom->hasM() );
+        return new Result( geom.hasM() );
 {"isEmpty", [](std::string name) { return GeometryOp::create(name,
     catGeom, "test if geometry is empty",
     Result::typeBool,
-        return new Result( geom->isEmpty() );
+        return new Result( geom.isEmpty() );
 {"lineMerge",  [](std::string name) { return GeometryOp::create(name,
     catGeom,
     "merge the lines of geometry",
             geos::operation::linemerge::LineMerger lmrgr;
-            lmrgr.add(geom.get());
+            lmrgr.add(&geom);
             std::vector<std::unique_ptr<LineString>> lines = lmrgr.getMergedLineStrings();
@@ -195,8 +195,8 @@ std::vector<GeometryOpCreator> opRegistry {
 {"normalize", [](std::string name) { return GeometryOp::create(name,
     catGeom, "normalize geometry",
-        auto res = geom->clone();
+        auto res = geom.clone();
         res->normalize();
         return new Result( std::move(res) );
@@ -204,47 +204,47 @@ std::vector<GeometryOpCreator> opRegistry {
 {"reducePrecision", [](std::string name) { return GeometryOp::create(name,
     catGeom,
     "reduce precision of geometry to a precision scale factor",
-    [](const std::unique_ptr<Geometry>& geom, double d) {
+    [](const Geometry& geom, double d) {
         PrecisionModel pm(d);
-        return new Result( geos::precision::GeometryPrecisionReducer::reduce( *geom, pm ) );
+        return new Result( geos::precision::GeometryPrecisionReducer::reduce( geom, pm ) );
 {"reducePrecisionKeepCollapsed", [](std::string name) { return GeometryOp::create(name,
     catGeom,
-        return new Result( geos::precision::GeometryPrecisionReducer::reduceKeepCollapsed( *geom, pm ) );
+        return new Result( geos::precision::GeometryPrecisionReducer::reduceKeepCollapsed( geom, pm ) );
 {"reducePrecisionPointwise", [](std::string name) { return GeometryOp::create(name,
     catGeom,
-        return new Result( geos::precision::GeometryPrecisionReducer::reducePointwise( *geom, pm ) );
+        return new Result( geos::precision::GeometryPrecisionReducer::reducePointwise( geom, pm ) );
 {"reverse", [](std::string name) { return GeometryOp::create(name,
     catGeom,
     "reverse geometry",
-        return new Result( geom->reverse() );
+        return new Result( geom.reverse() );
 //=============  category: Metric  ==================
 {"area", [](std::string name) { return GeometryOp::create(name,
     catMetric, "area of geometry",
     Result::typeDouble,
-        return new Result( geom->getArea() );
+        return new Result( geom.convexHull() );
 {"length", [](std::string name) { return GeometryOp::create(name,
     catMetric, "length or perimeter of geometry",
     Result::typeDouble,
-        return new Result( geom->getLength() );
+        return new Result( geom.getLength() );
@@ -254,30 +254,30 @@ std::vector<GeometryOpCreator> opRegistry {
     catValid,
     "test if geometry is simple",
     Result::typeBool,
-        return new Result( geom->isSimple() );
+        return new Result( geom.isSimple() );
 {"isValid", [](std::string name) { return GeometryOp::create(name,
     catValid,
     "test if geometry is valid",
     Result::typeBool,
-        return new Result( geom->isValid() );
+        return new Result( geom.isValid() );
 {"fixInvalid", [](std::string name) { return GeometryOp::create(name,
     catValid,
     "fix invalid geometry to be valid",
-        return new Result( geos::geom::util::GeometryFixer::fix( geom.get() ) );
+        return new Result( geos::geom::util::GeometryFixer::fix( &geom ) );
 {"makeValid", [](std::string name) { return GeometryOp::create(name,
     catValid,
     "make geometry valid (original algorithm)",
-        return new Result( geos::operation::valid::MakeValid().build( geom.get() ) );
+        return new Result( geos::operation::valid::MakeValid().build( &geom ) );
@@ -286,28 +286,28 @@ std::vector<GeometryOpCreator> opRegistry {
 {"boundary", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute geometry boundary",
-        return new Result( geom->getBoundary() );
 {"buffer", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute the buffer of geometry by a distance",
-        return new Result( geom->buffer( d ) );
+        return new Result( geom.buffer( d ) );
 {"bufferQuadSegs", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute the buffer of geometry by a distance with quadrant segments",
-    [](const std::unique_ptr<Geometry>& geom, double d, double quadrantSegments) {
-        return new Result( geom->buffer( d, (int) quadrantSegments ) );
+    [](const Geometry& geom, double d, double quadrantSegments) {
+        return new Result( geom.buffer( d, (int) quadrantSegments ) );
 {"bufferJoin", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute the buffer of geometry by a distance, with join >0 = QS, 0 = Bevel, <0 = Mitre limit",
-    [](const std::unique_ptr<Geometry>& geom, double d, double join) {
+    [](const Geometry& geom, double d, double join) {
         geos::operation::buffer::BufferParameters param;
         if (join > 0) {
             param.setQuadrantSegments( (int) join );
@@ -320,15 +320,15 @@ std::vector<GeometryOpCreator> opRegistry {
             param.setJoinStyle(geos::operation::buffer::BufferParameters::JOIN_MITRE);
             param.setMitreLimit( (int) -join );
-        std::unique_ptr<Geometry> g3 = geos::operation::buffer::BufferOp::bufferOp(geom.get(), d, param);
+        std::unique_ptr<Geometry> g3 = geos::operation::buffer::BufferOp::bufferOp(&geom, d, param);
         return new Result( g3.release() );
 {"offsetCurve", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute the offset curve of geometry by a distance",
-        geos::operation::buffer::OffsetCurve oc(*geom, d);
+        geos::operation::buffer::OffsetCurve oc(geom, d);
         std::unique_ptr<Geometry> g3 = oc.getCurve();
@@ -336,7 +336,7 @@ std::vector<GeometryOpCreator> opRegistry {
 {"offsetCurveJoin", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute the offset curve of geometry by a distance, with join >0 = QS, 0 = Bevel, <0 = Mitre limit",
         int quadSegs = 0;
         geos::operation::buffer::BufferParameters::JoinStyle joinStyle = geos::operation::buffer::BufferParameters::JOIN_ROUND;
         double miterLimit = 0;
@@ -350,14 +350,14 @@ std::vector<GeometryOpCreator> opRegistry {
             joinStyle = geos::operation::buffer::BufferParameters::JOIN_MITRE;
             miterLimit = (int) -join;
-        std::unique_ptr<Geometry> g3 = geos::operation::buffer::OffsetCurve::getCurve(*geom, d, quadSegs, joinStyle, miterLimit);
+        std::unique_ptr<Geometry> g3 = geos::operation::buffer::OffsetCurve::getCurve(geom, d, quadSegs, joinStyle, miterLimit);
 {"OLDoffsetCurve", [](std::string name) { return GeometryOp::create(name,
     catConst,
         geos::operation::buffer::BufferParameters bp;
         bool isLeftSide = true;
@@ -366,28 +366,28 @@ std::vector<GeometryOpCreator> opRegistry {
             d = -d;
         geos::operation::buffer::BufferBuilder bufBuilder(bp);
-        return new Result( bufBuilder.bufferLineSingleSided(geom.get(), d, isLeftSide) );
+        return new Result( bufBuilder.bufferLineSingleSided(&geom, d, isLeftSide) );
 {"centroid", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute geometry centroid",
-        return new Result( geom->getCentroid() );
+        return new Result( geom.getCentroid() );
 {"convexHull", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute geometry convex hull",
-        return new Result( geom->convexHull() );
 {"concaveHull", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute geometry concave hull for Edge Length Ratio",
-        geos::algorithm::hull::ConcaveHull hull(geom.get());
+        geos::algorithm::hull::ConcaveHull hull(&geom);
         hull.setMaximumEdgeLengthRatio( d );
         return new Result( hull.getHull() );
@@ -395,8 +395,8 @@ std::vector<GeometryOpCreator> opRegistry {
 {"concaveHullByLength", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute geometry concave hull for Edge Length",
         hull.setMaximumEdgeLength( d );
@@ -404,8 +404,8 @@ std::vector<GeometryOpCreator> opRegistry {
 {"concaveHullHoles", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute geometry concave hull allowing holes for Edge Length Ratio",
         hull.setHolesAllowed(true);
@@ -414,8 +414,8 @@ std::vector<GeometryOpCreator> opRegistry {
 {"densify", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "densify geometry to a segment length ",
-        geos::geom::util::Densifier densifier( geom.get() );
+        geos::geom::util::Densifier densifier( &geom );
         densifier.setDistanceTolerance( d );
         return new Result( densifier.getResultGeometry() );
@@ -423,15 +423,15 @@ std::vector<GeometryOpCreator> opRegistry {
 {"interiorPoint", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute interior point of geometry",
-        return new Result( geom->getInteriorPoint() );
+        return new Result( geom.getInteriorPoint() );
 {"largestEmptyCircle", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute radius line of largest empty circle between obstacles, up to a distance tolerance",
-        geos::algorithm::construct::LargestEmptyCircle lec( geom.get(), d );
+        geos::algorithm::construct::LargestEmptyCircle lec( &geom, d );
         std::unique_ptr<Geometry> res = lec.getRadiusLine();
@@ -439,8 +439,8 @@ std::vector<GeometryOpCreator> opRegistry {
 {"largestEmptyCircleBdy", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute radius line of largest empty circle between obstacles with center in a boundary, up to a distance tolerance",
-    [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geom2, double d) {
-        geos::algorithm::construct::LargestEmptyCircle lec( geom.get(), geom2.get(), d );
+    [](const Geometry& geom, const Geometry& geomB, double d) {
+        geos::algorithm::construct::LargestEmptyCircle lec( &geom, &geomB, d );
@@ -448,8 +448,8 @@ std::vector<GeometryOpCreator> opRegistry {
 {"maxInscribedCircle", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute maximum inscribed circle radius of Polygon up to a distance tolerance",
-        geos::algorithm::construct::MaximumInscribedCircle mc( geom.get(), d );
+        geos::algorithm::construct::MaximumInscribedCircle mc( &geom, d );
         std::unique_ptr<Geometry> res = mc.getRadiusLine();
@@ -457,16 +457,16 @@ std::vector<GeometryOpCreator> opRegistry {
 {"minAreaRectangle", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute minimum-area rectangle enclosing geometry",
-        std::unique_ptr<Geometry> res = geos::algorithm::MinimumAreaRectangle::getMinimumRectangle(geom.get());
+        std::unique_ptr<Geometry> res = geos::algorithm::MinimumAreaRectangle::getMinimumRectangle(&geom);
 {"minBoundingCircle", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute minimum bounding circle of geometry",
-        geos::algorithm::MinimumBoundingCircle mc( geom.get() );
+        geos::algorithm::MinimumBoundingCircle mc( &geom );
         std::unique_ptr<Geometry> res = mc.getCircle();
@@ -474,8 +474,8 @@ std::vector<GeometryOpCreator> opRegistry {
 {"maxDiameter", [](std::string name) { return GeometryOp::create(name,
    catConst,
     "compute maximum diameter line of geometry",
         std::unique_ptr<Geometry> res = mc.getMaximumDiameter();
@@ -483,8 +483,8 @@ std::vector<GeometryOpCreator> opRegistry {
 {"minDiameter", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute minimum diameter line of geometry",
-        geos::algorithm::MinimumDiameter md( geom.get() );
+        geos::algorithm::MinimumDiameter md( &geom );
         std::unique_ptr<Geometry> res = md.getDiameter();
@@ -493,12 +493,12 @@ std::vector<GeometryOpCreator> opRegistry {
 {"delaunay", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute the Delaunay Triangulation of geometry vertices",
         geos::triangulate::DelaunayTriangulationBuilder builder;
         builder.setTolerance(0);
-        builder.setSites( *geom );
+        builder.setSites( geom );
-        Geometry* out = builder.getTriangles(*(geom->getFactory())).release();
+        Geometry* out = builder.getTriangles(*(geom.getFactory())).release();
         std::vector<std::unique_ptr<const Geometry>> geoms;
         for(unsigned int i = 0; i < out->getNumGeometries(); i++) {
@@ -510,19 +510,19 @@ std::vector<GeometryOpCreator> opRegistry {
 {"constrainedDelaunay", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "constrained Delauanay triangulation of polygonal geometries",
-        return new Result( geos::triangulate::polygon::ConstrainedDelaunayTriangulator::triangulate(geom.get()) );
+        return new Result( geos::triangulate::polygon::ConstrainedDelaunayTriangulator::triangulate(&geom) );
 {"voronoi", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "Voronoi Diagram of geometry vertices",
         geos::triangulate::VoronoiDiagramBuilder builder;
-        Geometry* out = builder.getDiagram(*(geom->getFactory())).release();
+        Geometry* out = builder.getDiagram(*(geom.getFactory())).release();
@@ -534,9 +534,9 @@ std::vector<GeometryOpCreator> opRegistry {
 {"polygonize", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "polygonize lines",
         geos::operation::polygonize::Polygonizer p;
-        p.add(geom.get());
+        p.add(&geom);
         std::vector<std::unique_ptr<Polygon>> polys = p.getPolygons();
@@ -549,9 +549,9 @@ std::vector<GeometryOpCreator> opRegistry {
 {"polygonizeValid", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "polygonize lines into a valid polygonal geometry",
         geos::operation::polygonize::Polygonizer p(true);
+        p.add(&geom);
@@ -564,24 +564,24 @@ std::vector<GeometryOpCreator> opRegistry {
 {"buildArea", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "build area from lines",
         geos::operation::polygonize::BuildArea builder;
-        auto result = builder.build(geom.get());
+        auto result = builder.build(&geom);
         return new Result( std::move(result) ) ;
 {"simplifyDP", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "simplify geometry using Douglas-Peucker by a distance tolerance",
-        return new Result( geos::simplify::DouglasPeuckerSimplifier::simplify(geom.get(), d) );
+        return new Result( geos::simplify::DouglasPeuckerSimplifier::simplify(&geom, d) );
 {"simplifyTP", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "simplify geometry using Douglas-Peucker with a distance tolerance, preserving topology",
-        return new Result( geos::simplify::TopologyPreservingSimplifier::simplify(geom.get(), d) );
+        return new Result( geos::simplify::TopologyPreservingSimplifier::simplify(&geom, d) );
 //=============  category: Distance  ==================
@@ -590,16 +590,16 @@ std::vector<GeometryOpCreator> opRegistry {
     catDist,
     "compute distance between geometry A and B",
     Result::typeDouble,
-    [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB) {
-        return new Result( geom->distance( geomB.get() ) );
+    [](const Geometry& geom, const Geometry& geomB) {
+        return new Result( geom.distance( &geomB) );
 {"nearestPoints", [](std::string name) { return GeometryOp::create(name,
     catDist,
     "compute a line containing the nearest points of geometry A and B",
-        std::unique_ptr<CoordinateSequence> cs = geos::operation::distance::DistanceOp::nearestPoints(geom.get(), geomB.get());
-        auto factory = geom->getFactory();
+        std::unique_ptr<CoordinateSequence> cs = geos::operation::distance::DistanceOp::nearestPoints(&geom, &geomB);
+        auto factory = geom.getFactory();
         auto res = factory->createLineString( std::move(cs) );
@@ -608,23 +608,23 @@ std::vector<GeometryOpCreator> opRegistry {
     catDist,
     "compute discrete Frechet distance between geometry A and B",
     Result::typeDouble,
-       return new Result( geos::algorithm::distance::DiscreteFrechetDistance::distance(*geom, *geomB ) );
+       return new Result( geos::algorithm::distance::DiscreteFrechetDistance::distance(geom, geomB ) );
 {"hausdorffDistance", [](std::string name) { return GeometryOp::create(name,
     catDist,
     "compute discrete Hausdorff distance between geometry A and B",
     Result::typeDouble,
-        return new Result( geos::algorithm::distance::DiscreteHausdorffDistance::distance(*geom, *geomB ) );
+        return new Result( geos::algorithm::distance::DiscreteHausdorffDistance::distance(geom, geomB ) );
     // MD - can't get this to work for now
     add("frechetDistanceLine", 2, 0, Result::typeGeometry, catDist,
     "computes a line indicating the discrete Frechet distance between geometry A and B",
-    [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d) {
         (void)d;  // prevent unused variable warning
         DiscreteFrechetDistance dist(*geom, *geomB);
         //--- not supported for now
@@ -647,16 +647,16 @@ std::vector<GeometryOpCreator> opRegistry {
     catDist,
     "compute distance between geometry A and B using PreparedGeometry",
     Result::typeDouble,
-        return new Result( prepGeomCache.get(geom.get())->distance( geomB.get() ) );
+        return new Result( prepGeomCache.get(&geom)->distance( &geomB ) );
 {"nearestPointsPrep", [](std::string name) { return GeometryOp::create(name,
     catDist,
     "compute a line containing the nearest points of geometry A and B using PreparedGeometry",
-        auto cs = prepGeomCache.get(geom.get())->nearestPoints( geomB.get() );
+        auto cs = prepGeomCache.get(&geom)->nearestPoints( &geomB );
@@ -667,102 +667,102 @@ std::vector<GeometryOpCreator> opRegistry {
 { "contains", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A contains geometry B",
     Result::typeBool,
-        return new Result( geom->contains( geomB.get() ) );
+        return new Result( geom.contains( &geomB ) );
 { "coveredBy", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A is covered by geometry B",
     Result::typeBool,
-        return new Result( geom->coveredBy( geomB.get() ) );
+        return new Result( geom.coveredBy( &geomB ) );
 { "covers", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A covers geometry B",
     Result::typeBool,
-        return new Result( geom->covers( geomB.get() ) );
+        return new Result( geom.covers( &geomB ) );
 { "crosses", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A crosses geometry B",
     Result::typeBool,
-        return new Result( geom->crosses( geomB.get() ) );
+        return new Result( geom.crosses( &geomB ) );
 { "disjoint", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A is disjoint from geometry B",
     Result::typeBool,
-        return new Result( geom->disjoint( geomB.get() ) );
+        return new Result( geom.disjoint( &geomB ) );
 { "equals", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A equals geometry B",
     Result::typeBool,
-        return new Result( geom->equals( geomB.get() ) );
+        return new Result( geom.equals( &geomB ) );
 { "intersects", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A intersects geometry B",
     Result::typeBool,
-        return new Result( geom->intersects( geomB.get() ) );
+        return new Result( geom.intersects( &geomB ) );
 { "overlaps", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A overlaps geometry B",
     Result::typeBool,
-        return new Result( geom->overlaps( geomB.get() ) );
+        return new Result( geom.overlaps( &geomB ) );
 { "touches", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A touches geometry B",
     Result::typeBool,
-        return new Result( geom->touches( geomB.get() ) );
+        return new Result( geom.touches( &geomB ) );
 { "within", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A is within geometry B",
     Result::typeBool,
-        return new Result( geom->within( geomB.get() ) );
+        return new Result( geom.within( &geomB ) );
 { "relate", [](std::string name) { return GeometryOp::create(name,
     catRel, "compute DE-9IM matrix for geometry A and B",
     Result::typeString,
-        std::unique_ptr<geom::IntersectionMatrix> im(geom->relate( geomB.get() ));
+        std::unique_ptr<geom::IntersectionMatrix> im(geom.relate( &geomB ));
         return new Result( im->toString() );
 { "relateBNR", [](std::string name) { return GeometryOp::create(name,
     catRel, "compute DE-9IM matrix for geometry A and B with a Boundary Node Rule (1=Mod2,2=Endpt,3=Multivalent,4=Monovalent)",
     Result::typeString,
             int bnr = (int) d;
             std::unique_ptr<IntersectionMatrix> im;
             switch (bnr) {
                 case 1: /* same as OGC */
-                    im = RelateOp::relate(geom.get(), geomB.get(),
+                    im = RelateOp::relate(&geom, &geomB,
                                           BoundaryNodeRule::getBoundaryRuleMod2());
                     break;
                 case 2:
                                           BoundaryNodeRule::getBoundaryEndPoint());
                     break;
                 case 3:
                                           BoundaryNodeRule::getBoundaryMultivalentEndPoint());
                     break;
                 case 4:
                                           BoundaryNodeRule::getBoundaryMonovalentEndPoint());
                     break;
                 default:
@@ -778,39 +778,39 @@ std::vector<GeometryOpCreator> opRegistry {
 { "containsPrep", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A contains geometry B, with A prepared",
     Result::typeBool,
-        return new Result( prepGeomCache.get(geom.get())->contains( geomB.get() ) );
+        return new Result( prepGeomCache.get(&geom)->contains( &geomB ) );
 { "containsProperlyPrep", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A properly contains geometry B, with A prepared",
     Result::typeBool,
-        return new Result( prepGeomCache.get(geom.get())->containsProperly( geomB.get() ) );
+        return new Result( prepGeomCache.get(&geom)->containsProperly( &geomB ) );
 { "coversPrep", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A covers geometry B, with A prepared",
     Result::typeBool,
-        return new Result( prepGeomCache.get(geom.get())->covers( geomB.get() ) );
+        return new Result( prepGeomCache.get(&geom)->covers( &geomB ) );
 { "intersectsPrep", [](std::string name) { return GeometryOp::create(name,
     catRel, "test if geometry A intersects geometry B, with A prepared",
     Result::typeBool,
-        return new Result( prepGeomCache.get(geom.get())->intersects( geomB.get() ) );
+        return new Result( prepGeomCache.get(&geom)->intersects( &geomB ) );
 { "orientationIndex", [](std::string name) { return GeometryOp::create(name,
     catRel, "orientation index for a line segment and a point",
     Result::typeInt,
-        std::unique_ptr<CoordinateSequence> seqA = geom->getCoordinates();
+        std::unique_ptr<CoordinateSequence> seqA = geom.getCoordinates();
         Coordinate p0 = seqA->getAt(0);
         Coordinate p1 = seqA->getAt(1);
-        std::unique_ptr<CoordinateSequence> seqB = geomB->getCoordinates();
+        std::unique_ptr<CoordinateSequence> seqB = geomB.getCoordinates();
         Coordinate q = seqB->getAt(0);
         return new Result( algorithm::Orientation::index(p0, p1, q) );
@@ -821,94 +821,94 @@ std::vector<GeometryOpCreator> opRegistry {
 {"difference", [](std::string name) { return GeometryOp::create(name,
     catOverlay,
     "compute difference of geometry A from B",
-       return new Result( geom->difference( geomB.get() ) );
+       return new Result( geom.difference( &geomB ) );
 {"intersection", [](std::string name) { return GeometryOp::create(name,
     catOverlay,
     "compute intersection of geometry A and B",
-       return new Result( geom->intersection( geomB.get() ) );
+       return new Result( geom.intersection( &geomB ) );
 {"symDifference", [](std::string name) { return GeometryOp::create(name,
     catOverlay,
     "compute symmetric difference of geometry A and B",
-        return new Result( geom->symDifference( geomB.get() ) );
+        return new Result( geom.symDifference( &geomB ) );
 {"unaryUnion", [](std::string name) { return GeometryOp::createAgg(name,
     catOverlay,
     "compute aggregate union",
-        return new Result( geom->Union() );
+        return new Result( geom.Union() );
 {"union", [](std::string name) { return GeometryOp::create(name,
     catOverlay,
     "compute union of geometry A and B",
-        return new Result( geom->Union( geomB.get() ) );
+        return new Result( geom.Union( &geomB ) );
 {"differenceSR", [](std::string name) { return GeometryOp::create(name,
     catOverlay,
     "compute difference of geometry A from B, snap-rounding to a precision scale factor",
         geos::geom::PrecisionModel pm(d);
-        return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::DIFFERENCE, &pm) );
+        return new Result( OverlayNG::overlay(&geom, &geomB, OverlayNG::DIFFERENCE, &pm) );
 {"intersectionSR", [](std::string name) { return GeometryOp::create(name,
     catOverlay,
     "compute intersection of geometry A and B, snap-rounding to a precision scale factor",
-        return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::INTERSECTION, &pm) );
+        return new Result( OverlayNG::overlay(&geom, &geomB, OverlayNG::INTERSECTION, &pm) );
 {"symDifferenceSR", [](std::string name) { return GeometryOp::create(name,
     catOverlay,
     "compute symmetric difference of geometry A and B, snap-rounding to a precision scale factor",
-        return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::SYMDIFFERENCE, &pm) );
+        return new Result( OverlayNG::overlay(&geom, &geomB, OverlayNG::SYMDIFFERENCE, &pm) );
 {"unionSR", [](std::string name) { return GeometryOp::create(name,
     catOverlay,
     "compute union of geometry A and B, snap-rounding to a precision scale factor",
-        return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::UNION, &pm) );
+        return new Result( OverlayNG::overlay(&geom, &geomB, OverlayNG::UNION, &pm) );
 {"unaryUnionSR", [](std::string name) { return GeometryOp::createAgg(name,
     catOverlay,
-        return new Result( geos::operation::overlayng::UnaryUnionNG::Union(geom.get(), pm ));
+        return new Result( geos::operation::overlayng::UnaryUnionNG::Union(&geom, pm ));
 {"node", [](std::string name) { return GeometryOp::create(name,
     catOverlay,
     "compute fully noded geometry",
-        return new Result( geos::noding::GeometryNoder::node( *geom ) );
+        return new Result( geos::noding::GeometryNoder::node( geom ) );
 {"clipRect", [](std::string name) { return GeometryOp::create(name,
     catOverlay,
     "clip geometry A to envelope of B",
         using geos::operation::intersection::Rectangle;
         using geos::operation::intersection::RectangleIntersection;
-        const Envelope* env = geomB->getEnvelopeInternal();
+        const Envelope* env = geomB.getEnvelopeInternal();
         Rectangle rect(env->getMinX(), env->getMinY(), env->getMaxX(), env->getMaxY());
-        return new Result( RectangleIntersection::clip( *geom, rect) );
+        return new Result( RectangleIntersection::clip( geom, rect) );
@@ -917,8 +917,8 @@ std::vector<GeometryOpCreator> opRegistry {
 {"extractLine", [](std::string name) { return GeometryOp::create(name,
     catLinearref,
     "compute the line between two distances along linear geometry A",
-    [](const std::unique_ptr<Geometry>& geom, double d, double d2) {
-        auto lil = geos::linearref::LengthIndexedLine( geom.get() );
+    [](const Geometry& geom, double d, double d2) {
+        auto lil = geos::linearref::LengthIndexedLine( &geom );
         auto res = lil.extractLine(d, d2);
@@ -926,10 +926,10 @@ std::vector<GeometryOpCreator> opRegistry {
 {"interpolate", [](std::string name) { return GeometryOp::create(name,
     catLinearref,
     "compute a point interpolated along a distance from the start of geometry A",
         auto coord = geos::geom::Coordinate( lil.extractPoint(d) );
         auto res = factory->createPoint( std::move(coord) );
@@ -938,9 +938,9 @@ std::vector<GeometryOpCreator> opRegistry {
     catLinearref,
     "compute the distance of point B projected onto line A from the start of the line",
     Result::typeDouble,
-        auto inputPt = geos::geom::Coordinate( *geomB->getCoordinate() );
-        return new Result( geos::linearref::LengthIndexedLine( geom.get() ).project( inputPt ) );
+        auto inputPt = geos::geom::Coordinate( *geomB.getCoordinate() );
+        return new Result( geos::linearref::LengthIndexedLine( &geom ).project( inputPt ) );
@@ -948,16 +948,16 @@ std::vector<GeometryOpCreator> opRegistry {
 {"clusterIntersecting", [](std::string name) { return GeometryOp::createAgg(name,
     catCluster, "cluster geometries based on intersection",
         geos::operation::cluster::GeometryIntersectsClusterFinder f;
-        return new Result(f.clusterToCollection(*geom));
+        return new Result(f.clusterToCollection(geom));
 {"clusterWithin", [](std::string name) { return GeometryOp::createAgg(name,
     catCluster, "cluster geometries based on distance",
         geos::operation::cluster::GeometryDistanceClusterFinder f(d);
@@ -965,7 +965,7 @@ std::vector<GeometryOpCreator> opRegistry {
 {"coverageSimplify", [](std::string name) { return GeometryOp::createAgg(name,
     catCoverage, "simplify a polygonal coverage by a distance tolerance",
         std::vector<const Geometry*> coverage = toList(geom);
         std::vector<std::unique_ptr<Geometry>> result
             = geos::coverage::CoverageSimplifier::simplify(coverage, d);
@@ -979,19 +979,19 @@ std::vector<GeometryOpCreator> opRegistry {
 {"coverageUnionNG", [](std::string name) { return GeometryOp::createAgg(name,
     catCoverage, "union a polygonal coverage",
-        return new Result( geos::operation::overlayng::CoverageUnion::geomunion(geom.get()) );
+        return new Result( geos::operation::overlayng::CoverageUnion::geomunion(&geom) );
 {"coverageUnion", [](std::string name) { return GeometryOp::createAgg(name,
-        return new Result( geos::operation::geounion::CoverageUnion::Union(geom.get()) );
+        return new Result( geos::operation::geounion::CoverageUnion::Union(&geom) );
 {"coverageValidate", [](std::string name) { return GeometryOp::createAgg(name,
     catCoverage, "validate a polygonal coverage",
         std::vector<std::unique_ptr<Geometry>> invalidList
             = geos::coverage::CoverageValidator::validate(coverage);
@@ -1075,7 +1075,7 @@ std::string GeometryOp::signature() {
     return sig;
-Result * GeometryOp::execute( const std::unique_ptr<Geometry>& geomA, const std::unique_ptr<Geometry>& geomB, double d, double d2 )
+Result * GeometryOp::execute( const Geometry& geomA, const Geometry& geomB, double d, double d2 )
     if (numGeomParam == 1) {
         if (numParam == 0) return geomfun_G(geomA);
diff --git a/util/geosop/GeometryOp.h b/util/geosop/GeometryOp.h
index 9ffc7f853..628e2c821 100644
--- a/util/geosop/GeometryOp.h
+++ b/util/geosop/GeometryOp.h
@@ -59,19 +59,19 @@ public:
     } typeCode;
-typedef std::function<Result *( const std::unique_ptr<Geometry>& )>
+typedef std::function<Result *( const Geometry& )>
     geomFunSig_G;
-typedef std::function<Result *( const std::unique_ptr<Geometry>&, double d )>
+typedef std::function<Result *( const Geometry&, double d )>
     geomFunSig_GD;
-typedef std::function<Result *( const std::unique_ptr<Geometry>&, double d, double d2 )>
+typedef std::function<Result *( const Geometry&, double d, double d2 )>
     geomFunSig_GDD;
-typedef std::function<Result *( const std::unique_ptr<Geometry>&, const std::unique_ptr<Geometry>& )>
+typedef std::function<Result *( const Geometry&, const Geometry& )>
     geomFunSig_GG;
-typedef std::function<Result *( const std::unique_ptr<Geometry>&, const std::unique_ptr<Geometry>&, double d )>
+typedef std::function<Result *( const Geometry&, const Geometry&, double d )>
     geomFunSig_GGD;
 class GeometryOp {
@@ -255,8 +255,8 @@ public:
     int nParam();
     std::string signature();
-    Result * execute( const std::unique_ptr<Geometry>& geomA,
-        const std::unique_ptr<Geometry>& geomB,
+    Result * execute( const Geometry& geomA,
+        const Geometry& geomB,
         double d, double d2 );
 private:
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index 17ace47fd..2cb17f000 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -514,7 +514,7 @@ Result* GeosOp::executeOp(GeometryOp * op,
     geos::util::Profile sw( "op" );
     sw.start();
-    Result* result = op->execute( gA, gB, opArgs.arg1, opArgs.arg2  );
+    Result* result = op->execute( *gA, *gB, opArgs.arg1, opArgs.arg2  );
     sw.stop();
     double time = sw.getTot();
     totalTime += time;
Summary of changes:
 util/geosop/GeometryOp.cpp | 388 ++++++++++++++++++++++-----------------------
 util/geosop/GeometryOp.h   |  14 +-
 util/geosop/GeosOp.cpp     |   2 +-
 3 files changed, 202 insertions(+), 202 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
