[geos-commits] [SCM] GEOS branch main updated. 8d2e1bd90d17f8f9fe01fd1976087c2ad02faa80
Tue Feb 4 22:21:13 PST 2025
the project "GEOS".
The branch, main has been updated
       via  8d2e1bd90d17f8f9fe01fd1976087c2ad02faa80 (commit)
      from  b77f7fa6fb4161f3587eba1b6e7f00197ce46bc5 (commit)
revisions in full, below.
commit 8d2e1bd90d17f8f9fe01fd1976087c2ad02faa80
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Feb 4 22:20:49 2025 -0800
    Refine doc for pass-by-reference
diff --git a/DEVELOPER-NOTES.md b/DEVELOPER-NOTES.md
index 516dc2cb1..a718b815f 100644
--- a/DEVELOPER-NOTES.md
+++ b/DEVELOPER-NOTES.md
@@ -72,9 +72,12 @@ public:
 ### Function Parameter calling conventions
-* Prefer passing values by reference (`Geometry&`) instead of pointer (`Geometry*`),
-  particularly for API (public) functions
-  * Note: many GEOS API functions use pass-by-pointer, but this is just historical baggage
+* Objects which are passed as read-only with no transfer of ownership
+  should be passed as `const` references (`const Geometry&`).
+  * in particular, this applies to Geometry objects passed to API operations
+  (in static functions, class constructors, or initialization methods)
+  * NOTE: many GEOS API functions use pass-by-pointer (`Geometry*`), but this is historical baggage
+  * for the common case of passing a `std::unique_ptr<Geometry> foo` the argument will be `*foo`
 * Pass-by-pointer can be used if the argument may be NULL (this is rare for API functions)
 ### Avoid Many Small Heap Allocations
Summary of changes:
 DEVELOPER-NOTES.md | 9 ++++++---
 1 file changed, 6 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
