[geos-commits] [SCM] GEOS branch 3.11 updated. 610e2a764ae6c713a2d39e69556fb809b8c2a8ef
git at osgeo.org
git at osgeo.org
Wed Feb 5 14:46:58 PST 2025
the project "GEOS".
The branch, 3.11 has been updated
via 610e2a764ae6c713a2d39e69556fb809b8c2a8ef (commit)
from ee4d9363d03f62077363d6cfb24a257feec657d9 (commit)
revisions in full, below.
commit 610e2a764ae6c713a2d39e69556fb809b8c2a8ef
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Feb 5 14:46:37 2025 -0800
Fix BufferOp to increase length of segments removed by heuristic
diff --git a/NEWS.md b/NEWS.md
index 9ee46214e..f724ee5e8 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -10,6 +10,7 @@
- GEOSConcaveHullOfPolygons, avoid crash on zero-area input (GH-1071, Dan Baston)
- MinimumClearance, avoid crash on NaN inputs (GH-1079, Dan Baston)
- Fix TopologyPreservingSimplifier/TaggedLineString to avoid jumping components (JTS-1096, Martin Davis)
+ - Fix BufferOp to increase length of segments removed by heuristic (GH-1200, Martin Davis)
- Add ring buffer hole removal heuristic (GH-1233, Martin Davis)
## Changes in 3.11.4
diff --git a/src/operation/buffer/OffsetSegmentGenerator.cpp b/src/operation/buffer/OffsetSegmentGenerator.cpp
index 579a30248..3981c5745 100644
--- a/src/operation/buffer/OffsetSegmentGenerator.cpp
+++ b/src/operation/buffer/OffsetSegmentGenerator.cpp
@@ -49,7 +49,7 @@ namespace operation { // geos.operation
namespace buffer { // geos.operation.buffer
/*private data*/
-const double OffsetSegmentGenerator::CURVE_VERTEX_SNAP_DISTANCE_FACTOR = 1.0E-6;
+const double OffsetSegmentGenerator::CURVE_VERTEX_SNAP_DISTANCE_FACTOR = 1.0E-4;
const double OffsetSegmentGenerator::OFFSET_SEGMENT_SEPARATION_FACTOR = 1.0E-3;
const double OffsetSegmentGenerator::INSIDE_TURN_VERTEX_SNAP_DISTANCE_FACTOR = 1.0E-3;
const double OffsetSegmentGenerator::SIMPLIFY_FACTOR = 100.0;
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index d51039b94..387b91eb6 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -600,7 +600,6 @@ void object::test<23>
-/* MD - not fixed in this ver
// Test that hole is not removed
// See https://github.com/libgeos/geos/issues/1125
template<>
@@ -621,7 +620,6 @@ void object::test<24>
ensure_equals(result->getNumGeometries(), 1u);
ensure_equals( (dynamic_cast<const Polygon*>( result.get() )->getNumInteriorRing()), 3u);
// testRingHoleEroded
// See https://github.com/libgeos/geos/issues/1223
Summary of changes:
NEWS.md | 1 +
src/operation/buffer/OffsetSegmentGenerator.cpp | 2 +-
tests/unit/operation/buffer/BufferOpTest.cpp | 2 --
3 files changed, 2 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
