[geos-commits] [SCM] GEOS branch main updated. ca0b8d276f96a439eafd7127230a2e5ee5532557
    git at osgeo.org
    git at osgeo.org
    Sat Feb  8 13:37:43 PST 2025
the project "GEOS".
The branch, main has been updated
       via  ca0b8d276f96a439eafd7127230a2e5ee5532557 (commit)
      from  f9bd0e7f21fd50a1062cd3a67e738d8b1ed0f32d (commit)
revisions in full, below.
commit ca0b8d276f96a439eafd7127230a2e5ee5532557
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Sat Feb 8 13:37:20 2025 -0800
    Add Orientation Index Viewer utility (#1234)
diff --git a/util/CMakeLists.txt b/util/CMakeLists.txt
index 4d52c11d9..9242e35b5 100644
--- a/util/CMakeLists.txt
+++ b/util/CMakeLists.txt
@@ -13,5 +13,13 @@ option(BUILD_GEOSOP "Build geosop command-line interface" ON)
 message(STATUS "GEOS: Build geosop ${BUILD_GEOSOP}")
 if(BUILD_GEOSOP)
-  add_subdirectory(geosop)
+add_executable(orientview
+  OrientationIndexViewer.cpp
+target_link_libraries(orientview PRIVATE geos geos_c)
+add_subdirectory(geosop)
 endif()
diff --git a/util/OrientationIndexViewer.cpp b/util/OrientationIndexViewer.cpp
new file mode 100644
index 000000000..f2763499b
--- /dev/null
+++ b/util/OrientationIndexViewer.cpp
@@ -0,0 +1,201 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2025 Martin Davis
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Computes orientation index for a line segment and a point,
+ * in a grid of contiguous FP numbers around the point.
+ * Uses either DD (robust) or FP algorithms.
+ * Examples:
+ *    orientview  0 0   1 1   0.5 0.5
+ *    orientview  0 2   2 0   0.4 1.6
+ *    orientview -g   0 2   2 0   0.4 1.6
+ *    orientview -g -f -v 0 2   2 0   0.4 1.6
+ *    orientview -p   9 0   0 9  8.6 0.4
+#include <geos/algorithm/Orientation.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/GeometryFactory.h>
+#include <algorithm>
+#include <random>
+#include <vector>
+#include <memory>
+#include <iomanip>
+using namespace geos::geom;
+using geos::algorithm::Orientation;
+bool isVerbose = false;
+bool showGraph = false;
+bool isFP = false;
+bool isPermute = false;
+double p0x, p0y, p1x, p1y, p2x, p2y;
+void printUsage() {
+    std::cout << "GEOS Orientation Index Viewer" << std::endl;
+    std::cout << "Usage: orientview [ flags ] x0 y0 x1 y1 x2 y2" << std::endl;
+    std::cout << "  -f - use FP instead of DD orientation algorithm" << std::endl;
+    std::cout << "  -g - show grid of nearby points" << std::endl;
+    std::cout << "  -p - compute all permutations of points" << std::endl;
+    std::cout << "  -v - show verbose detail for each point" << std::endl;
+    std::cout << "Example: orientview -g -p   0 2   2 0   0.4 1.6" << std::endl;
+void parseFlag(char* arg) {
+    char flag = arg[1];
+    switch (flag) {
+    case 'f':
+        isFP = true; break;
+    case 'g':
+        showGraph = true; break;
+    case 'p':
+        isPermute = true; break;
+    case 'v':
+        isVerbose = true; break;
+void parseArgs(int argc, char** argv) {
+    int i = 1;
+    //-- parse flags
+    while (argv[i][0] == '-' && isalpha(argv[i][1])) {
+        parseFlag(argv[i]);
+        i++;
+    //-- parse points
+    if (argc - i < 6) {
+        std::cerr << "3 coordinates must be specified";
+        exit(EXIT_FAILURE);
+    // assert: there are 6 ordinates = 3 coordinates
+    p0x = std::stod(argv[i]);
+    p0y = std::stod(argv[i+1]);
+    p1x = std::stod(argv[i+2]);
+    p1y = std::stod(argv[i+3]);
+    p2x = std::stod(argv[i+4]);
+    p2y = std::stod(argv[i+5]);
+int
+orientationIndexFP(const Coordinate& p1, const Coordinate& p2,const Coordinate& q){
+	double dx1 = p2.x-p1.x;
+	double dy1 = p2.y-p1.y;
+	double dx2 = q.x-p2.x;
+	double dy2 = q.y-p2.y;
+	double det = dx1 * dy2 - dx2 * dy1;
+	if (det > 0.0) return 1;
+	if (det < 0.0) return-1;
+	return 0;
+double nextafterN(double x, double dir, size_t n) {
+    for (size_t i = 0; i < n; i++) {
+        x = nextafter(x, dir);
+    return x;
+void computePoint(size_t ix, size_t iy, double x, double y, Coordinate p0, Coordinate p1, bool useFP, bool showDetail)
+    Coordinate p(x, y);
+    int index;
+    if (useFP) {
+        index = orientationIndexFP(p0, p1, p);
+    else {
+        index = Orientation::index(p0, p1, p);
+    char c = '0';
+    if (index < 0) c = '-';
+    if (index > 0) c = '+';
+    std::cout << c;
+    (void)ix;
+    (void)iy;
+    if (showDetail) {
+        std::cout << " " << (useFP ? "FP" : "DD")
+            << " [ " << ix << ", " << iy << " ]  "
+            << std::setprecision(20)
+            << "POINT ( " << x << " " << y << " ) -> " << index << std::endl;
+void computeGrid(double x0, double y0, double x1, double y1, double xp, double yp, size_t n) {
+    Coordinate p0(x0, y0);
+    Coordinate p1(x1, y1);
+    std::cout << "LINESTRING ( " << x0 << " " << y0 << ", " << x1 << " " << y1 << " )" << std::endl;
+    computePoint(0, 0, xp, yp, p0, p1, false, true);
+    computePoint(0, 0, xp, yp, p0, p1, true, true);
+    std::cout << std::endl;
+    if (showGraph) {
+        size_t nGrid = 2 * n + 1;
+        std::cout << (isFP ? "Orientation FP" : "Orientation DD") << std::endl;
+        //-- display grid limits
+        double xmin = nextafterN(xp, xp - 1, n);
+        double ymin = nextafterN(yp, xp - 1, n);
+        double xmax = nextafterN(xp, xp + 1, n);
+        double ymax = nextafterN(yp, yp + 1, n);
+        std::cout << "Grid: "
+            << "(" << xmin << " " << ymin << " ) - "
+            << "(" << xmax << " " << ymax << " )"
+            << std::endl;
+        //-- display grid size for X and Y
+        double xdel = nextafter(xp, xp - 1) - xp;
+        double ydel = nextafter(yp, yp - 1) - yp;
+        std::cout << "Size: "
+            << "dX = " << xdel << "  dy = " << ydel
+            << std::endl;
+        double y = nextafterN(yp, yp + 1, n);
+        for (size_t iy = nGrid; iy > 0; iy--) {
+            double x = nextafterN(xp, xp - 1, n);
+            for (size_t ix = 0; ix <= nGrid; ix++) {
+                computePoint(ix, iy, x, y, p0, p1, isFP, isVerbose);
+                x = nextafter(x, x + 1);
+            y = nextafter(y, y - 1);
+int main(int argc, char** argv) {
+    if (argc <= 1) {
+        printUsage();
+        exit(EXIT_SUCCESS);
+    parseArgs(argc, argv);
+    const int gridSize = 20;
+    computeGrid(p0x, p0y, p1x, p1y, p2x, p2y,     gridSize);
+    if (isPermute) {
+        computeGrid(p1x, p1y, p2x, p2y, p0x, p0y,     gridSize);
+        computeGrid(p2x, p2y, p0x, p0y, p1x, p1y,     gridSize);
Summary of changes:
 util/CMakeLists.txt             |  10 +-
 util/OrientationIndexViewer.cpp | 201 ++++++++++++++++++++++++++++++++++++++++
 2 files changed, 210 insertions(+), 1 deletion(-)
 create mode 100644 util/OrientationIndexViewer.cpp
hooks/post-receive
More information about the geos-commits
