[geos-commits] [SCM] GEOS branch 3.12 updated. d40251f2647d76f1870adf5bfeb19d48ff1fad5a
git at osgeo.org
git at osgeo.org
Tue Feb 11 17:54:16 PST 2025
the project "GEOS".
The branch, 3.12 has been updated
via d40251f2647d76f1870adf5bfeb19d48ff1fad5a (commit)
from bcd4c34855e2d0183cd59a703488b92a8c52a031 (commit)
revisions in full, below.
commit d40251f2647d76f1870adf5bfeb19d48ff1fad5a
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Feb 11 17:36:12 2025 -0800
Backport geosop updates
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index c6d988df3..0cbb25645 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -24,6 +24,7 @@
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/prep/PreparedGeometry.h>
#include <geos/geom/prep/PreparedGeometryFactory.h>
+#include <geos/algorithm/Orientation.h>
#include <geos/algorithm/construct/LargestEmptyCircle.h>
#include <geos/algorithm/construct/MaximumInscribedCircle.h>
#include <geos/algorithm/BoundaryNodeRule.h>
@@ -110,10 +111,10 @@ struct GeometryOpCreator {
std::function<GeometryOp *( std::string name )> create;
-std::vector<const Geometry*> toList(const std::unique_ptr<Geometry>& geom) {
+std::vector<const Geometry*> toList(const Geometry& geom) {
std::vector<const Geometry*> geomList;
- for (std::size_t i = 0; i < geom->getNumGeometries(); i++) {
- geomList.emplace_back( geom->getGeometryN(i));
+ for (std::size_t i = 0; i < geom.getNumGeometries(); i++) {
+ geomList.emplace_back( geom.getGeometryN(i));
return geomList;
@@ -136,45 +137,45 @@ std::vector<GeometryOpCreator> opRegistry {
{ "copy", [](std::string name) { return GeometryOp::create(name,
catGeom, "copy geometry",
- [](const std::unique_ptr<Geometry>& geom) {
- return new Result( geom->clone() );
+ [](const Geometry& geom) {
+ return new Result( geom.clone() );
{ "envelope", [](std::string name) { return GeometryOp::create(name,
catGeom, "envelope of geometry",
- return new Result( geom->getEnvelope() );
+ return new Result( geom.getEnvelope() );
{"hasZ", [](std::string name) { return GeometryOp::create(name,
catGeom,
"test if geometry has Z ordinate",
Result::typeBool,
- return new Result( geom->hasZ() );
+ return new Result( geom.hasZ() );
{"hasM", [](std::string name) { return GeometryOp::create(name,
catGeom,
"test if geometry has M ordinate",
Result::typeBool,
- return new Result( geom->hasM() );
+ return new Result( geom.hasM() );
{"isEmpty", [](std::string name) { return GeometryOp::create(name,
catGeom, "test if geometry is empty",
Result::typeBool,
- return new Result( geom->isEmpty() );
+ return new Result( geom.isEmpty() );
{"lineMerge", [](std::string name) { return GeometryOp::create(name,
catGeom,
"merge the lines of geometry",
geos::operation::linemerge::LineMerger lmrgr;
- lmrgr.add(geom.get());
+ lmrgr.add(&geom);
std::vector<std::unique_ptr<LineString>> lines = lmrgr.getMergedLineStrings();
@@ -187,8 +188,8 @@ std::vector<GeometryOpCreator> opRegistry {
{"normalize", [](std::string name) { return GeometryOp::create(name,
catGeom, "normalize geometry",
- auto res = geom->clone();
+ auto res = geom.clone();
res->normalize();
return new Result( std::move(res) );
@@ -196,47 +197,47 @@ std::vector<GeometryOpCreator> opRegistry {
{"reducePrecision", [](std::string name) { return GeometryOp::create(name,
catGeom,
"reduce precision of geometry to a precision scale factor",
- [](const std::unique_ptr<Geometry>& geom, double d) {
+ [](const Geometry& geom, double d) {
PrecisionModel pm(d);
- return new Result( geos::precision::GeometryPrecisionReducer::reduce( *geom, pm ) );
+ return new Result( geos::precision::GeometryPrecisionReducer::reduce( geom, pm ) );
{"reducePrecisionKeepCollapsed", [](std::string name) { return GeometryOp::create(name,
catGeom,
- return new Result( geos::precision::GeometryPrecisionReducer::reduceKeepCollapsed( *geom, pm ) );
+ return new Result( geos::precision::GeometryPrecisionReducer::reduceKeepCollapsed( geom, pm ) );
{"reducePrecisionPointwise", [](std::string name) { return GeometryOp::create(name,
catGeom,
- return new Result( geos::precision::GeometryPrecisionReducer::reducePointwise( *geom, pm ) );
+ return new Result( geos::precision::GeometryPrecisionReducer::reducePointwise( geom, pm ) );
{"reverse", [](std::string name) { return GeometryOp::create(name,
catGeom,
"reverse geometry",
- return new Result( geom->reverse() );
+ return new Result( geom.reverse() );
//============= category: Metric ==================
{"area", [](std::string name) { return GeometryOp::create(name,
catMetric, "area of geometry",
Result::typeDouble,
- return new Result( geom->getArea() );
+ return new Result( geom.convexHull() );
{"length", [](std::string name) { return GeometryOp::create(name,
catMetric, "length or perimeter of geometry",
Result::typeDouble,
- return new Result( geom->getLength() );
+ return new Result( geom.getLength() );
@@ -246,30 +247,30 @@ std::vector<GeometryOpCreator> opRegistry {
catValid,
"test if geometry is simple",
Result::typeBool,
- return new Result( geom->isSimple() );
+ return new Result( geom.isSimple() );
{"isValid", [](std::string name) { return GeometryOp::create(name,
catValid,
"test if geometry is valid",
Result::typeBool,
- return new Result( geom->isValid() );
+ return new Result( geom.isValid() );
{"fixInvalid", [](std::string name) { return GeometryOp::create(name,
catValid,
"fix invalid geometry to be valid",
- return new Result( geos::geom::util::GeometryFixer::fix( geom.get() ) );
+ return new Result( geos::geom::util::GeometryFixer::fix( &geom ) );
{"makeValid", [](std::string name) { return GeometryOp::create(name,
catValid,
"make geometry valid (original algorithm)",
- return new Result( geos::operation::valid::MakeValid().build( geom.get() ) );
+ return new Result( geos::operation::valid::MakeValid().build( &geom ) );
@@ -278,30 +279,78 @@ std::vector<GeometryOpCreator> opRegistry {
{"boundary", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute geometry boundary",
- return new Result( geom->getBoundary() );
{"buffer", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute the buffer of geometry by a distance",
- return new Result( geom->buffer( d ) );
+ return new Result( geom.buffer( d ) );
+{"bufferQuadSegs", [](std::string name) { return GeometryOp::create(name,
+ catConst,
+ "compute the buffer of geometry by a distance with quadrant segments",
+ [](const Geometry& geom, double d, double quadrantSegments) {
+ return new Result( geom.buffer( d, (int) quadrantSegments ) );
+{"bufferJoin", [](std::string name) { return GeometryOp::create(name,
+ catConst,
+ "compute the buffer of geometry by a distance, with join >0 = QS, 0 = Bevel, <0 = Mitre limit",
+ [](const Geometry& geom, double d, double join) {
+ geos::operation::buffer::BufferParameters param;
+ if (join > 0) {
+ param.setQuadrantSegments( (int) join );
+ param.setJoinStyle(geos::operation::buffer::BufferParameters::JOIN_ROUND);
+ else if (join == 0) {
+ param.setJoinStyle(geos::operation::buffer::BufferParameters::JOIN_BEVEL);
+ else if (join < 0) {
+ param.setJoinStyle(geos::operation::buffer::BufferParameters::JOIN_MITRE);
+ param.setMitreLimit( (int) -join );
+ std::unique_ptr<Geometry> g3 = geos::operation::buffer::BufferOp::bufferOp(&geom, d, param);
+ return new Result( g3.release() );
{"offsetCurve", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute the offset curve of geometry by a distance",
- geos::operation::buffer::OffsetCurve oc(*geom, d);
+ geos::operation::buffer::OffsetCurve oc(geom, d);
std::unique_ptr<Geometry> g3 = oc.getCurve();
+{"offsetCurveJoin", [](std::string name) { return GeometryOp::create(name,
+ catConst,
+ "compute the offset curve of geometry by a distance, with join >0 = QS, 0 = Bevel, <0 = Mitre limit",
+ int quadSegs = 0;
+ geos::operation::buffer::BufferParameters::JoinStyle joinStyle = geos::operation::buffer::BufferParameters::JOIN_ROUND;
+ double miterLimit = 0;
+ if (join > 0) {
+ quadSegs = (int) join;
+ joinStyle = geos::operation::buffer::BufferParameters::JOIN_BEVEL;
+ joinStyle = geos::operation::buffer::BufferParameters::JOIN_MITRE;
+ miterLimit = (int) -join;
+ std::unique_ptr<Geometry> g3 = geos::operation::buffer::OffsetCurve::getCurve(geom, d, quadSegs, joinStyle, miterLimit);
{"OLDoffsetCurve", [](std::string name) { return GeometryOp::create(name,
catConst,
geos::operation::buffer::BufferParameters bp;
bool isLeftSide = true;
@@ -310,28 +359,28 @@ std::vector<GeometryOpCreator> opRegistry {
d = -d;
geos::operation::buffer::BufferBuilder bufBuilder(bp);
- return new Result( bufBuilder.bufferLineSingleSided(geom.get(), d, isLeftSide) );
+ return new Result( bufBuilder.bufferLineSingleSided(&geom, d, isLeftSide) );
{"centroid", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute geometry centroid",
- return new Result( geom->getCentroid() );
+ return new Result( geom.getCentroid() );
{"convexHull", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute geometry convex hull",
- return new Result( geom->convexHull() );
{"concaveHull", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute geometry concave hull for Edge Length Ratio",
- geos::algorithm::hull::ConcaveHull hull(geom.get());
+ geos::algorithm::hull::ConcaveHull hull(&geom);
hull.setMaximumEdgeLengthRatio( d );
return new Result( hull.getHull() );
@@ -339,8 +388,8 @@ std::vector<GeometryOpCreator> opRegistry {
{"concaveHullByLength", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute geometry concave hull for Edge Length",
hull.setMaximumEdgeLength( d );
@@ -348,8 +397,8 @@ std::vector<GeometryOpCreator> opRegistry {
{"concaveHullHoles", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute geometry concave hull allowing holes for Edge Length Ratio",
hull.setHolesAllowed(true);
@@ -358,8 +407,8 @@ std::vector<GeometryOpCreator> opRegistry {
{"densify", [](std::string name) { return GeometryOp::create(name,
catConst,
"densify geometry to a segment length ",
- geos::geom::util::Densifier densifier( geom.get() );
+ geos::geom::util::Densifier densifier( &geom );
densifier.setDistanceTolerance( d );
return new Result( densifier.getResultGeometry() );
@@ -367,15 +416,15 @@ std::vector<GeometryOpCreator> opRegistry {
{"interiorPoint", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute interior point of geometry",
- return new Result( geom->getInteriorPoint() );
+ return new Result( geom.getInteriorPoint() );
{"largestEmptyCircle", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute radius line of largest empty circle between obstacles up to a distance tolerance",
- geos::algorithm::construct::LargestEmptyCircle lec( geom.get(), d );
+ geos::algorithm::construct::LargestEmptyCircle lec( &geom, d );
std::unique_ptr<Geometry> res = lec.getRadiusLine();
@@ -383,8 +432,8 @@ std::vector<GeometryOpCreator> opRegistry {
{"largestEmptyCircleBdy", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute radius line of largest empty circle between obstacles with center in a boundary, up to a distance tolerance",
- [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geom2, double d) {
- geos::algorithm::construct::LargestEmptyCircle lec( geom.get(), geom2.get(), d );
+ [](const Geometry& geom, const Geometry& geomB, double d) {
+ geos::algorithm::construct::LargestEmptyCircle lec( &geom, &geomB, d );
@@ -392,8 +441,8 @@ std::vector<GeometryOpCreator> opRegistry {
{"maxInscribedCircle", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute maximum inscribed circle radius of Polygon up to a distance tolerance",
- geos::algorithm::construct::MaximumInscribedCircle mc( geom.get(), d );
+ geos::algorithm::construct::MaximumInscribedCircle mc( &geom, d );
std::unique_ptr<Geometry> res = mc.getRadiusLine();
@@ -401,16 +450,16 @@ std::vector<GeometryOpCreator> opRegistry {
{"minAreaRectangle", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute minimum-area rectangle enclosing geometry",
- std::unique_ptr<Geometry> res = geos::algorithm::MinimumAreaRectangle::getMinimumRectangle(geom.get());
+ std::unique_ptr<Geometry> res = geos::algorithm::MinimumAreaRectangle::getMinimumRectangle(&geom);
{"minBoundingCircle", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute minimum bounding circle of geometry",
- geos::algorithm::MinimumBoundingCircle mc( geom.get() );
+ geos::algorithm::MinimumBoundingCircle mc( &geom );
std::unique_ptr<Geometry> res = mc.getCircle();
@@ -418,8 +467,8 @@ std::vector<GeometryOpCreator> opRegistry {
{"maxDiameter", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute maximum diameter line of geometry",
std::unique_ptr<Geometry> res = mc.getMaximumDiameter();
@@ -427,8 +476,8 @@ std::vector<GeometryOpCreator> opRegistry {
{"minDiameter", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute minimum diameter line of geometry",
- geos::algorithm::MinimumDiameter md( geom.get() );
+ geos::algorithm::MinimumDiameter md( &geom );
std::unique_ptr<Geometry> res = md.getDiameter();
@@ -437,12 +486,12 @@ std::vector<GeometryOpCreator> opRegistry {
{"delaunay", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute the Delaunay Triangulation of geometry vertices",
geos::triangulate::DelaunayTriangulationBuilder builder;
builder.setTolerance(0);
- builder.setSites( *geom );
+ builder.setSites( geom );
- Geometry* out = builder.getTriangles(*(geom->getFactory())).release();
+ Geometry* out = builder.getTriangles(*(geom.getFactory())).release();
std::vector<std::unique_ptr<const Geometry>> geoms;
for(unsigned int i = 0; i < out->getNumGeometries(); i++) {
@@ -454,19 +503,19 @@ std::vector<GeometryOpCreator> opRegistry {
{"constrainedDelaunay", [](std::string name) { return GeometryOp::create(name,
catConst,
"constrained Delauanay triangulation of polygonal geometries",
- return new Result( geos::triangulate::polygon::ConstrainedDelaunayTriangulator::triangulate(geom.get()) );
+ return new Result( geos::triangulate::polygon::ConstrainedDelaunayTriangulator::triangulate(&geom) );
{"voronoi", [](std::string name) { return GeometryOp::create(name,
catConst,
"Voronoi Diagram of geometry vertices",
geos::triangulate::VoronoiDiagramBuilder builder;
- Geometry* out = builder.getDiagram(*(geom->getFactory())).release();
+ Geometry* out = builder.getDiagram(*(geom.getFactory())).release();
@@ -478,9 +527,9 @@ std::vector<GeometryOpCreator> opRegistry {
{"polygonize", [](std::string name) { return GeometryOp::create(name,
catConst,
"polygonize lines",
geos::operation::polygonize::Polygonizer p;
- p.add(geom.get());
+ p.add(&geom);
std::vector<std::unique_ptr<Polygon>> polys = p.getPolygons();
@@ -493,9 +542,9 @@ std::vector<GeometryOpCreator> opRegistry {
{"polygonizeValid", [](std::string name) { return GeometryOp::create(name,
catConst,
"polygonize lines into a valid polygonal geometry",
geos::operation::polygonize::Polygonizer p(true);
+ p.add(&geom);
@@ -508,24 +557,24 @@ std::vector<GeometryOpCreator> opRegistry {
{"buildArea", [](std::string name) { return GeometryOp::create(name,
catConst,
"build area from lines",
geos::operation::polygonize::BuildArea builder;
- auto result = builder.build(geom.get());
+ auto result = builder.build(&geom);
return new Result( std::move(result) ) ;
{"simplifyDP", [](std::string name) { return GeometryOp::create(name,
catConst,
"simplify geometry using Douglas-Peucker by a distance tolerance",
- return new Result( geos::simplify::DouglasPeuckerSimplifier::simplify(geom.get(), d) );
+ return new Result( geos::simplify::DouglasPeuckerSimplifier::simplify(&geom, d) );
{"simplifyTP", [](std::string name) { return GeometryOp::create(name,
catConst,
"simplify geometry using Douglas-Peucker with a distance tolerance, preserving topology",
- return new Result( geos::simplify::TopologyPreservingSimplifier::simplify(geom.get(), d) );
+ return new Result( geos::simplify::TopologyPreservingSimplifier::simplify(&geom, d) );
//============= category: Distance ==================
@@ -534,16 +583,16 @@ std::vector<GeometryOpCreator> opRegistry {
catDist,
"compute distance between geometry A and B",
Result::typeDouble,
- [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB) {
- return new Result( geom->distance( geomB.get() ) );
+ [](const Geometry& geom, const Geometry& geomB) {
+ return new Result( geom.distance( &geomB) );
{"nearestPoints", [](std::string name) { return GeometryOp::create(name,
catDist,
"compute a line containing the nearest points of geometry A and B",
- std::unique_ptr<CoordinateSequence> cs = geos::operation::distance::DistanceOp::nearestPoints(geom.get(), geomB.get());
- auto factory = geom->getFactory();
+ std::unique_ptr<CoordinateSequence> cs = geos::operation::distance::DistanceOp::nearestPoints(&geom, &geomB);
+ auto factory = geom.getFactory();
auto res = factory->createLineString( std::move(cs) );
@@ -552,23 +601,23 @@ std::vector<GeometryOpCreator> opRegistry {
catDist,
"compute discrete Frechet distance between geometry A and B",
Result::typeDouble,
- return new Result( geos::algorithm::distance::DiscreteFrechetDistance::distance(*geom, *geomB ) );
+ return new Result( geos::algorithm::distance::DiscreteFrechetDistance::distance(geom, geomB ) );
{"hausdorffDistance", [](std::string name) { return GeometryOp::create(name,
catDist,
"compute discrete Hausdorff distance between geometry A and B",
Result::typeDouble,
- return new Result( geos::algorithm::distance::DiscreteHausdorffDistance::distance(*geom, *geomB ) );
+ return new Result( geos::algorithm::distance::DiscreteHausdorffDistance::distance(geom, geomB ) );
// MD - can't get this to work for now
add("frechetDistanceLine", 2, 0, Result::typeGeometry, catDist,
"computes a line indicating the discrete Frechet distance between geometry A and B",
- [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d) {
(void)d; // prevent unused variable warning
DiscreteFrechetDistance dist(*geom, *geomB);
//--- not supported for now
@@ -591,16 +640,16 @@ std::vector<GeometryOpCreator> opRegistry {
catDist,
"compute distance between geometry A and B using PreparedGeometry",
Result::typeDouble,
- return new Result( prepGeomCache.get(geom.get())->distance( geomB.get() ) );
+ return new Result( prepGeomCache.get(&geom)->distance( &geomB ) );
{"nearestPointsPrep", [](std::string name) { return GeometryOp::create(name,
catDist,
"compute a line containing the nearest points of geometry A and B using PreparedGeometry",
- auto cs = prepGeomCache.get(geom.get())->nearestPoints( geomB.get() );
+ auto cs = prepGeomCache.get(&geom)->nearestPoints( &geomB );
@@ -611,102 +660,102 @@ std::vector<GeometryOpCreator> opRegistry {
{ "contains", [](std::string name) { return GeometryOp::create(name,
catRel, "test if geometry A contains geometry B",
Result::typeBool,
- return new Result( geom->contains( geomB.get() ) );
+ return new Result( geom.contains( &geomB ) );
{ "coveredBy", [](std::string name) { return GeometryOp::create(name,
catRel, "test if geometry A is covered by geometry B",
Result::typeBool,
- return new Result( geom->coveredBy( geomB.get() ) );
+ return new Result( geom.coveredBy( &geomB ) );
{ "covers", [](std::string name) { return GeometryOp::create(name,
catRel, "test if geometry A covers geometry B",
Result::typeBool,
+ return new Result( geom.covers( &geomB ) );
{ "crosses", [](std::string name) { return GeometryOp::create(name,
catRel, "test if geometry A crosses geometry B",
Result::typeBool,
- return new Result( geom->crosses( geomB.get() ) );
+ return new Result( geom.crosses( &geomB ) );
{ "disjoint", [](std::string name) { return GeometryOp::create(name,
catRel, "test if geometry A is disjoint from geometry B",
Result::typeBool,
- return new Result( geom->disjoint( geomB.get() ) );
+ return new Result( geom.disjoint( &geomB ) );
{ "equals", [](std::string name) { return GeometryOp::create(name,
catRel, "test if geometry A equals geometry B",
Result::typeBool,
- return new Result( geom->equals( geomB.get() ) );
+ return new Result( geom.equals( &geomB ) );
{ "intersects", [](std::string name) { return GeometryOp::create(name,
catRel, "test if geometry A intersects geometry B",
Result::typeBool,
- return new Result( geom->intersects( geomB.get() ) );
+ return new Result( geom.intersects( &geomB ) );
{ "overlaps", [](std::string name) { return GeometryOp::create(name,
catRel, "test if geometry A overlaps geometry B",
Result::typeBool,
- return new Result( geom->overlaps( geomB.get() ) );
+ return new Result( geom.overlaps( &geomB ) );
{ "touches", [](std::string name) { return GeometryOp::create(name,
catRel, "test if geometry A touches geometry B",
Result::typeBool,
- return new Result( geom->touches( geomB.get() ) );
+ return new Result( geom.touches( &geomB ) );
{ "within", [](std::string name) { return GeometryOp::create(name,
catRel, "test if geometry A is within geometry B",
Result::typeBool,
- return new Result( geom->within( geomB.get() ) );
+ return new Result( geom.within( &geomB ) );
{ "relate", [](std::string name) { return GeometryOp::create(name,
catRel, "compute DE-9IM matrix for geometry A and B",
Result::typeString,
- std::unique_ptr<geom::IntersectionMatrix> im(geom->relate( geomB.get() ));
+ std::unique_ptr<geom::IntersectionMatrix> im(geom.relate( &geomB ));
return new Result( im->toString() );
{ "relateBNR", [](std::string name) { return GeometryOp::create(name,
catRel, "compute DE-9IM matrix for geometry A and B with a Boundary Node Rule (1=Mod2,2=Endpt,3=Multivalent,4=Monovalent)",
Result::typeString,
int bnr = (int) d;
std::unique_ptr<IntersectionMatrix> im;
switch (bnr) {
case 1: /* same as OGC */
- im = RelateOp::relate(geom.get(), geomB.get(),
+ im = RelateOp::relate(&geom, &geomB,
BoundaryNodeRule::getBoundaryRuleMod2());
break;
case 2:
BoundaryNodeRule::getBoundaryEndPoint());
break;
case 3:
BoundaryNodeRule::getBoundaryMultivalentEndPoint());
break;
case 4:
BoundaryNodeRule::getBoundaryMonovalentEndPoint());
break;
default:
@@ -720,31 +769,43 @@ std::vector<GeometryOpCreator> opRegistry {
{ "containsPrep", [](std::string name) { return GeometryOp::create(name,
- catRel, "test if geometry A contains geometry B, using PreparedGeometry",
+ catRel, "test if geometry A contains geometry B, with A prepared",
Result::typeBool,
- return new Result( prepGeomCache.get(geom.get())->contains( geomB.get() ) );
+ return new Result( prepGeomCache.get(&geom)->contains( &geomB ) );
{ "containsProperlyPrep", [](std::string name) { return GeometryOp::create(name,
- catRel, "test if geometry A properly contains geometry B, using PreparedGeometry",
+ catRel, "test if geometry A properly contains geometry B, with A prepared",
Result::typeBool,
- return new Result( prepGeomCache.get(geom.get())->containsProperly( geomB.get() ) );
+ return new Result( prepGeomCache.get(&geom)->containsProperly( &geomB ) );
{ "coversPrep", [](std::string name) { return GeometryOp::create(name,
- catRel, "test if geometry A covers geometry B, using PreparedGeometry",
+ catRel, "test if geometry A covers geometry B, with A prepared",
Result::typeBool,
- return new Result( prepGeomCache.get(geom.get())->covers( geomB.get() ) );
+ return new Result( prepGeomCache.get(&geom)->covers( &geomB ) );
{ "intersectsPrep", [](std::string name) { return GeometryOp::create(name,
- catRel, "test if geometry A intersects geometry B, using PreparedGeometry",
+ catRel, "test if geometry A intersects geometry B, with A prepared",
Result::typeBool,
- return new Result( prepGeomCache.get(geom.get())->intersects( geomB.get() ) );
+ return new Result( prepGeomCache.get(&geom)->intersects( &geomB ) );
+{ "orientationIndex", [](std::string name) { return GeometryOp::create(name,
+ catRel, "orientation index for a line segment and a point",
+ Result::typeInt,
+ std::unique_ptr<CoordinateSequence> seqA = geom.getCoordinates();
+ Coordinate p0 = seqA->getAt(0);
+ Coordinate p1 = seqA->getAt(1);
+ std::unique_ptr<CoordinateSequence> seqB = geomB.getCoordinates();
+ Coordinate q = seqB->getAt(0);
+ return new Result( algorithm::Orientation::index(p0, p1, q) );
@@ -753,94 +814,94 @@ std::vector<GeometryOpCreator> opRegistry {
{"difference", [](std::string name) { return GeometryOp::create(name,
catOverlay,
"compute difference of geometry A from B",
- return new Result( geom->difference( geomB.get() ) );
+ return new Result( geom.difference( &geomB ) );
{"intersection", [](std::string name) { return GeometryOp::create(name,
catOverlay,
"compute intersection of geometry A and B",
- return new Result( geom->intersection( geomB.get() ) );
+ return new Result( geom.intersection( &geomB ) );
{"symDifference", [](std::string name) { return GeometryOp::create(name,
catOverlay,
"compute symmetric difference of geometry A and B",
- return new Result( geom->symDifference( geomB.get() ) );
+ return new Result( geom.symDifference( &geomB ) );
{"unaryUnion", [](std::string name) { return GeometryOp::createAgg(name,
catOverlay,
"compute aggregate union",
- return new Result( geom->Union() );
+ return new Result( geom.Union() );
{"union", [](std::string name) { return GeometryOp::create(name,
catOverlay,
"compute union of geometry A and B",
- return new Result( geom->Union( geomB.get() ) );
+ return new Result( geom.Union( &geomB ) );
{"differenceSR", [](std::string name) { return GeometryOp::create(name,
catOverlay,
"compute difference of geometry A from B, snap-rounding to a precision scale factor",
geos::geom::PrecisionModel pm(d);
- return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::DIFFERENCE, &pm) );
+ return new Result( OverlayNG::overlay(&geom, &geomB, OverlayNG::DIFFERENCE, &pm) );
{"intersectionSR", [](std::string name) { return GeometryOp::create(name,
catOverlay,
"compute intersection of geometry A and B, snap-rounding to a precision scale factor",
- return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::INTERSECTION, &pm) );
+ return new Result( OverlayNG::overlay(&geom, &geomB, OverlayNG::INTERSECTION, &pm) );
{"symDifferenceSR", [](std::string name) { return GeometryOp::create(name,
catOverlay,
"compute symmetric difference of geometry A and B, snap-rounding to a precision scale factor",
- return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::SYMDIFFERENCE, &pm) );
+ return new Result( OverlayNG::overlay(&geom, &geomB, OverlayNG::SYMDIFFERENCE, &pm) );
{"unionSR", [](std::string name) { return GeometryOp::create(name,
catOverlay,
"compute union of geometry A and B, snap-rounding to a precision scale factor",
- return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::UNION, &pm) );
+ return new Result( OverlayNG::overlay(&geom, &geomB, OverlayNG::UNION, &pm) );
{"unaryUnionSR", [](std::string name) { return GeometryOp::createAgg(name,
catOverlay,
- return new Result( geos::operation::overlayng::UnaryUnionNG::Union(geom.get(), pm ));
+ return new Result( geos::operation::overlayng::UnaryUnionNG::Union(&geom, pm ));
{"node", [](std::string name) { return GeometryOp::create(name,
catOverlay,
"compute fully noded geometry",
- return new Result( geos::noding::GeometryNoder::node( *geom ) );
+ return new Result( geos::noding::GeometryNoder::node( geom ) );
{"clipRect", [](std::string name) { return GeometryOp::create(name,
catOverlay,
"clip geometry A to envelope of B",
using geos::operation::intersection::Rectangle;
using geos::operation::intersection::RectangleIntersection;
- const Envelope* env = geomB->getEnvelopeInternal();
+ const Envelope* env = geomB.getEnvelopeInternal();
Rectangle rect(env->getMinX(), env->getMinY(), env->getMaxX(), env->getMaxY());
- return new Result( RectangleIntersection::clip( *geom, rect) );
+ return new Result( RectangleIntersection::clip( geom, rect) );
@@ -849,8 +910,8 @@ std::vector<GeometryOpCreator> opRegistry {
{"extractLine", [](std::string name) { return GeometryOp::create(name,
catLinearref,
"compute the line between two distances along linear geometry A",
- [](const std::unique_ptr<Geometry>& geom, double d, double d2) {
- auto lil = geos::linearref::LengthIndexedLine( geom.get() );
+ [](const Geometry& geom, double d, double d2) {
+ auto lil = geos::linearref::LengthIndexedLine( &geom );
auto res = lil.extractLine(d, d2);
@@ -858,10 +919,10 @@ std::vector<GeometryOpCreator> opRegistry {
{"interpolate", [](std::string name) { return GeometryOp::create(name,
catLinearref,
"compute a point interpolated along a distance from the start of geometry A",
auto coord = geos::geom::Coordinate( lil.extractPoint(d) );
auto res = factory->createPoint( std::move(coord) );
@@ -870,9 +931,9 @@ std::vector<GeometryOpCreator> opRegistry {
catLinearref,
"compute the distance of point B projected onto line A from the start of the line",
Result::typeDouble,
- auto inputPt = geos::geom::Coordinate( *geomB->getCoordinate() );
- return new Result( geos::linearref::LengthIndexedLine( geom.get() ).project( inputPt ) );
+ auto inputPt = geos::geom::Coordinate( *geomB.getCoordinate() );
+ return new Result( geos::linearref::LengthIndexedLine( &geom ).project( inputPt ) );
@@ -880,16 +941,16 @@ std::vector<GeometryOpCreator> opRegistry {
{"clusterIntersecting", [](std::string name) { return GeometryOp::createAgg(name,
catCluster, "cluster geometries based on intersection",
geos::operation::cluster::GeometryIntersectsClusterFinder f;
- return new Result(f.clusterToCollection(*geom));
+ return new Result(f.clusterToCollection(geom));
{"clusterWithin", [](std::string name) { return GeometryOp::createAgg(name,
catCluster, "cluster geometries based on distance",
geos::operation::cluster::GeometryDistanceClusterFinder f(d);
@@ -897,7 +958,7 @@ std::vector<GeometryOpCreator> opRegistry {
{"coverageSimplify", [](std::string name) { return GeometryOp::createAgg(name,
catCoverage, "simplify a polygonal coverage by a distance tolerance",
std::vector<const Geometry*> coverage = toList(geom);
std::vector<std::unique_ptr<Geometry>> result
= geos::coverage::CoverageSimplifier::simplify(coverage, d);
@@ -911,19 +972,19 @@ std::vector<GeometryOpCreator> opRegistry {
{"coverageUnionNG", [](std::string name) { return GeometryOp::createAgg(name,
catCoverage, "union a polygonal coverage",
- return new Result( geos::operation::overlayng::CoverageUnion::geomunion(geom.get()) );
+ return new Result( geos::operation::overlayng::CoverageUnion::geomunion(&geom) );
{"coverageUnion", [](std::string name) { return GeometryOp::createAgg(name,
- return new Result( geos::operation::geounion::CoverageUnion::Union(geom.get()) );
+ return new Result( geos::operation::geounion::CoverageUnion::Union(&geom) );
{"coverageValidate", [](std::string name) { return GeometryOp::createAgg(name,
catCoverage, "validate a polygonal coverage",
std::vector<std::unique_ptr<Geometry>> invalidList
= geos::coverage::CoverageValidator::validate(coverage);
@@ -1007,7 +1068,7 @@ std::string GeometryOp::signature() {
return sig;
-Result * GeometryOp::execute( const std::unique_ptr<Geometry>& geomA, const std::unique_ptr<Geometry>& geomB, double d, double d2 )
+Result * GeometryOp::execute( const Geometry& geomA, const Geometry& geomB, double d, double d2 )
if (numGeomParam == 1) {
if (numParam == 0) return geomfun_G(geomA);
diff --git a/util/geosop/GeometryOp.h b/util/geosop/GeometryOp.h
index 1dad1016a..92c57ce7a 100644
--- a/util/geosop/GeometryOp.h
+++ b/util/geosop/GeometryOp.h
@@ -56,19 +56,19 @@ public:
} typeCode;
-typedef std::function<Result *( const std::unique_ptr<Geometry>& )>
+typedef std::function<Result *( const Geometry& )>
geomFunSig_G;
-typedef std::function<Result *( const std::unique_ptr<Geometry>&, double d )>
+typedef std::function<Result *( const Geometry&, double d )>
geomFunSig_GD;
-typedef std::function<Result *( const std::unique_ptr<Geometry>&, double d, double d2 )>
+typedef std::function<Result *( const Geometry&, double d, double d2 )>
geomFunSig_GDD;
-typedef std::function<Result *( const std::unique_ptr<Geometry>&, const std::unique_ptr<Geometry>& )>
+typedef std::function<Result *( const Geometry&, const Geometry& )>
geomFunSig_GG;
-typedef std::function<Result *( const std::unique_ptr<Geometry>&, const std::unique_ptr<Geometry>&, double d )>
+typedef std::function<Result *( const Geometry&, const Geometry&, double d )>
geomFunSig_GGD;
class GeometryOp {
@@ -252,8 +252,8 @@ public:
int nParam();
std::string signature();
- Result * execute( const std::unique_ptr<Geometry>& geomA,
- const std::unique_ptr<Geometry>& geomB,
+ Result * execute( const Geometry& geomA,
+ const Geometry& geomB,
double d, double d2 );
private:
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index 45aefbc66..deb70b7d1 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -488,7 +488,7 @@ Result* GeosOp::executeOp(GeometryOp * op,
geos::util::Profile sw( "op" );
sw.start();
- Result* result = op->execute( gA, gB, opArgs.arg1, opArgs.arg2 );
+ Result* result = op->execute( *gA, *gB, opArgs.arg1, opArgs.arg2 );
sw.stop();
double time = sw.getTot();
totalTime += time;
Summary of changes:
util/geosop/GeometryOp.cpp | 439 ++++++++++++++++++++++++++-------------------
util/geosop/GeometryOp.h | 14 +-
util/geosop/GeosOp.cpp | 2 +-
3 files changed, 258 insertions(+), 197 deletions(-)
hooks/post-receive
More information about the geos-commits
