[geos-commits] [SCM] GEOS branch 3.13 updated. b99325742a76f16586c1bd180f9df6311585c56d
git at osgeo.org
git at osgeo.org
Wed Feb 12 15:45:43 PST 2025
the project "GEOS".
The branch, 3.13 has been updated
via b99325742a76f16586c1bd180f9df6311585c56d (commit)
from 518749e941a089dcd8fe6140a1469069a891f61c (commit)
revisions in full, below.
commit b99325742a76f16586c1bd180f9df6311585c56d
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Feb 12 15:41:24 2025 -0800
Fix buffer element erosion for negative distance and remove overlay deps (#1239)
diff --git a/include/geos/operation/buffer/BufferBuilder.h b/include/geos/operation/buffer/BufferBuilder.h
index 259f469ae..b3c6cc928 100644
--- a/include/geos/operation/buffer/BufferBuilder.h
+++ b/include/geos/operation/buffer/BufferBuilder.h
@@ -56,10 +56,9 @@ class PlanarGraph;
namespace operation {
namespace buffer {
class BufferSubgraph;
-namespace overlay {
class PolygonBuilder;
@@ -233,7 +232,7 @@ private:
* the final polygons
void buildSubgraphs(const std::vector<BufferSubgraph*>& subgraphList,
- overlay::PolygonBuilder& polyBuilder);
+ PolygonBuilder& polyBuilder);
/// \brief
/// Return the externally-set noding::Noder OR a newly created
diff --git a/include/geos/operation/buffer/BufferNodeFactory.h b/include/geos/operation/buffer/BufferNodeFactory.h
new file mode 100644
index 000000000..e2e7ab83c
--- /dev/null
+++ b/include/geos/operation/buffer/BufferNodeFactory.h
@@ -0,0 +1,52 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2006 Refractions Research Inc.
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <geos/export.h>
+#include <vector>
+#include <geos/geomgraph/NodeFactory.h> // for inheritance
+// Forward declarations
+namespace geos {
+namespace geom {
+class Coordinate;
+namespace geomgraph {
+class Node;
+namespace geos {
+namespace operation { // geos::operation
+namespace buffer { // geos::operation::buffer
+/** \brief
+ * Creates nodes for use in the geomgraph::PlanarGraph constructed during
+ * buffer operations. NOTE: also used by operation::valid
+class GEOS_DLL BufferNodeFactory: public geomgraph::NodeFactory {
+public:
+ BufferNodeFactory(): geomgraph::NodeFactory() {}
+ geomgraph::Node* createNode(const geom::Coordinate& coord) const override;
+ static const geomgraph::NodeFactory& instance();
+} // namespace geos::operation::buffer
diff --git a/include/geos/operation/buffer/MaximalEdgeRing.h b/include/geos/operation/buffer/MaximalEdgeRing.h
index 000000000..4ecd6a0f0
--- /dev/null
+++ b/include/geos/operation/buffer/MaximalEdgeRing.h
@@ -0,0 +1,104 @@
+ * Last port: operation/overlay/MaximalEdgeRing.java rev. 1.15 (JTS-1.10)
+#pragma once
+#include <vector>
+#include <geos/geomgraph/EdgeRing.h> // for inheritance
+namespace geos {
+namespace geom {
+class GeometryFactory;
+class DirectedEdge;
+namespace buffer {
+class MinimalEdgeRing;
+namespace geos {
+/** \brief
+ * A ring of [DirectedEdges](@ref geomgraph::DirectedEdge) which may contain nodes of degree > 2.
+ * A MaximalEdgeRing may represent two different spatial entities:
+ * - a single polygon possibly containing inversions (if the ring is oriented CW)
+ * - a single hole possibly containing exversions (if the ring is oriented CCW)
+ * If the MaximalEdgeRing represents a polygon,
+ * the interior of the polygon is strongly connected.
+ * These are the form of rings used to define polygons under some spatial data models.
+ * However, under the OGC SFS model, [MinimalEdgeRings](@ref MinimalEdgeRing) are required.
+ * A MaximalEdgeRing can be converted to a list of MinimalEdgeRings using the
+ * {@link #buildMinimalRings() } method.
+ * @see com.vividsolutions.jts.operation.overlay.MinimalEdgeRing
+class GEOS_DLL MaximalEdgeRing: public geomgraph::EdgeRing {
+public:
+ MaximalEdgeRing(geomgraph::DirectedEdge* start,
+ const geom::GeometryFactory* geometryFactory);
+ // throw(const TopologyException &)
+ ~MaximalEdgeRing() override = default;
+ geomgraph::DirectedEdge* getNext(geomgraph::DirectedEdge* de) override;
+ void setEdgeRing(geomgraph::DirectedEdge* de, geomgraph::EdgeRing* er) override;
+ /// \brief
+ /// This function returns a newly allocated vector of
+ /// pointers to newly allocated MinimalEdgeRing objects.
+ /// @deprecated pass the vector yourself instead
+ std::vector<MinimalEdgeRing*>* buildMinimalRings();
+ /// \brief
+ /// This function pushes pointers to newly allocated MinimalEdgeRing
+ /// objects to the provided vector.
+ void buildMinimalRings(std::vector<MinimalEdgeRing*>& minEdgeRings);
+ void buildMinimalRings(std::vector<EdgeRing*>& minEdgeRings);
+ /// \brief
+ /// For all nodes in this EdgeRing,
+ /// link the DirectedEdges at the node to form minimalEdgeRings
+ void linkDirectedEdgesForMinimalEdgeRings();
diff --git a/include/geos/operation/buffer/MinimalEdgeRing.h b/include/geos/operation/buffer/MinimalEdgeRing.h
index 000000000..0b4b5c099
--- /dev/null
+++ b/include/geos/operation/buffer/MinimalEdgeRing.h
@@ -0,0 +1,80 @@
+ * Last port: operation/overlay/MinimalEdgeRing.java rev. 1.13 (JTS-1.10)
+#pragma once
+#include <geos/geomgraph/DirectedEdge.h> // for inlines
+#include <vector>
+namespace geos {
+namespace geom {
+class EdgeRing;
+namespace geos {
+/** \brief
+ * A ring of [Edges](@ref geomgraph::Edge) with the property that no node
+ * has degree greater than 2.
+ * These are the form of rings required to represent polygons
+ * under the OGC SFS spatial data model.
+ * @see operation::buffer::MaximalEdgeRing
+class GEOS_DLL MinimalEdgeRing: public geomgraph::EdgeRing {
+public:
+ MinimalEdgeRing(geomgraph::DirectedEdge* start,
+ ~MinimalEdgeRing() override {};
+ return de->getNextMin();
+ geomgraph::EdgeRing* er) override
+ de->setMinEdgeRing(er);
diff --git a/include/geos/operation/buffer/PolygonBuilder.h b/include/geos/operation/buffer/PolygonBuilder.h
index 000000000..914a341a7
--- /dev/null
+++ b/include/geos/operation/buffer/PolygonBuilder.h
@@ -0,0 +1,202 @@
+ * Last port: operation/overlay/PolygonBuilder.java rev. 1.20 (JTS-1.10)
+#pragma once
+#include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
+#include <vector>
+#ifdef _MSC_VER
+#pragma warning(push)
+#pragma warning(disable: 4251) // warning C4251: needs to have dll-interface to be used by clients of class
+#endif
+namespace geos {
+namespace geom {
+class Geometry;
+class Coordinate;
+class EdgeRing;
+class Node;
+class PlanarGraph;
+namespace buffer {
+class MaximalEdgeRing;
+namespace geos {
+/** \brief
+ * Forms Polygon out of a graph of geomgraph::DirectedEdge.
+ * The edges to use are marked as being in the result Area.
+class GEOS_DLL PolygonBuilder {
+public:
+ PolygonBuilder(const geom::GeometryFactory* newGeometryFactory);
+ ~PolygonBuilder();
+ * Add a complete graph.
+ * The graph is assumed to contain one or more polygons,
+ * possibly with holes.
+ void add(geomgraph::PlanarGraph* graph);
+ * Add a set of edges and nodes, which form a graph.
+ void add(const std::vector<geomgraph::DirectedEdge*>* dirEdges,
+ const std::vector<geomgraph::Node*>* nodes);
+ std::vector<std::unique_ptr<geom::Geometry>> getPolygons();
+private:
+ const geom::GeometryFactory* geometryFactory;
+ std::vector<geomgraph::EdgeRing*> shellList;
+ * For all DirectedEdges in result, form them into MaximalEdgeRings
+ * @param maxEdgeRings
+ * Formed MaximalEdgeRings will be pushed to this vector.
+ * Ownership of the elements is transferred to caller.
+ void buildMaximalEdgeRings(
+ const std::vector<geomgraph::DirectedEdge*>* dirEdges,
+ std::vector<MaximalEdgeRing*>& maxEdgeRings);
+ void buildMinimalEdgeRings(
+ std::vector<MaximalEdgeRing*>& maxEdgeRings,
+ std::vector<geomgraph::EdgeRing*>& newShellList,
+ std::vector<geomgraph::EdgeRing*>& freeHoleList,
+ std::vector<MaximalEdgeRing*>& edgeRings);
+ * This method takes a list of MinimalEdgeRings derived from a
+ * MaximalEdgeRing, and tests whether they form a Polygon.
+ * This is the case if there is a single shell
+ * in the list. In this case the shell is returned.
+ * The other possibility is that they are a series of connected
+ * holes, in which case no shell is returned.
+ * @return the shell geomgraph::EdgeRing, if there is one
+ * @return NULL, if all the rings are holes
+ geomgraph::EdgeRing* findShell(std::vector<MinimalEdgeRing*>* minEdgeRings);
+ * This method assigns the holes for a Polygon (formed from a list of
+ * MinimalEdgeRings) to its shell.
+ * Determining the holes for a MinimalEdgeRing polygon serves two
+ * purposes:
+ * - it is faster than using a point-in-polygon check later on.
+ * - it ensures correctness, since if the PIP test was used the point
+ * chosen might lie on the shell, which might return an incorrect
+ * result from the PIP test
+ void placePolygonHoles(geomgraph::EdgeRing* shell,
+ std::vector<MinimalEdgeRing*>* minEdgeRings);
+ * For all rings in the input list,
+ * determine whether the ring is a shell or a hole
+ * and add it to the appropriate list.
+ * Due to the way the DirectedEdges were linked,
+ * a ring is a shell if it is oriented CW, a hole otherwise.
+ void sortShellsAndHoles(std::vector<MaximalEdgeRing*>& edgeRings,
+ std::vector<geomgraph::EdgeRing*>& freeHoleList);
+ struct FastPIPRing {
+ geomgraph::EdgeRing* edgeRing;
+ algorithm::locate::IndexedPointInAreaLocator* pipLocator;
+ /** \brief
+ * This method determines finds a containing shell for all holes
+ * which have not yet been assigned to a shell.
+ * Holes which do not lie in any shell are (probably) an eroded element,
+ * so are simply discarded.
+ void placeFreeHoles(std::vector<FastPIPRing>& newShellList,
+ /** \brief
+ * Find the innermost enclosing shell geomgraph::EdgeRing containing the
+ * argument geomgraph::EdgeRing, if any.
+ * The innermost enclosing ring is the <i>smallest</i> enclosing ring.
+ * The algorithm used depends on the fact that:
+ * ring A contains ring B iff envelope(ring A)
+ * contains envelope(ring B)
+ * This routine is only safe to use if the chosen point of the hole
+ * is known to be properly contained in a shell
+ * (which is guaranteed to be the case if the hole does not touch
+ * its shell)
+ * @return containing geomgraph::EdgeRing, if there is one
+ * @return NULL if no containing geomgraph::EdgeRing is found
+ geomgraph::EdgeRing* findEdgeRingContaining(geomgraph::EdgeRing* testEr,
+ std::vector<FastPIPRing>& newShellList);
+ std::vector<std::unique_ptr<geom::Geometry>> computePolygons(
+ std::vector<geomgraph::EdgeRing*>& newShellList);
+ * Checks the current set of shells (with their associated holes) to
+ * see if any of them contain the point.
+#ifdef _MSC_VER
+#pragma warning(pop)
+#endif
diff --git a/src/operation/buffer/BufferBuilder.cpp b/src/operation/buffer/BufferBuilder.cpp
index 1fa923ccb..a5d423e9e 100644
--- a/src/operation/buffer/BufferBuilder.cpp
+++ b/src/operation/buffer/BufferBuilder.cpp
@@ -33,8 +33,8 @@
#include <geos/operation/buffer/SubgraphDepthLocater.h>
#include <geos/operation/overlayng/OverlayNG.h>
#include <geos/operation/overlay/snap/SnapOverlayOp.h>
-#include <geos/operation/overlay/PolygonBuilder.h>
-#include <geos/operation/overlay/OverlayNodeFactory.h>
+#include <geos/operation/buffer/PolygonBuilder.h>
+#include <geos/operation/buffer/BufferNodeFactory.h>
#include <geos/operation/polygonize/Polygonizer.h>
#include <geos/operation/union/UnaryUnionOp.h>
#include <geos/operation/valid/RepeatedPointRemover.h>
@@ -77,7 +77,6 @@ using namespace geos::geom;
using namespace geos::geomgraph;
using namespace geos::noding;
using namespace geos::algorithm;
-using namespace geos::operation::overlay;
using namespace geos::operation::linemerge;
namespace {
@@ -439,7 +438,7 @@ BufferBuilder::buffer(const Geometry* g, double distance)
std::vector<BufferSubgraph*> subgraphList;
try {
- PlanarGraph graph(OverlayNodeFactory::instance());
+ PlanarGraph graph(BufferNodeFactory::instance());
graph.addEdges(edgeList.getEdges());
GEOS_CHECK_FOR_INTERRUPTS();
diff --git a/src/operation/buffer/BufferNodeFactory.cpp b/src/operation/buffer/BufferNodeFactory.cpp
index 000000000..934caae6c
--- /dev/null
+++ b/src/operation/buffer/BufferNodeFactory.cpp
@@ -0,0 +1,42 @@
+ * Copyright (C) 2001-2002 Vivid Solutions Inc.
+ * Copyright (C) 2005 Refractions Research Inc.
+#include <geos/geomgraph/Node.h>
+#include <geos/geomgraph/DirectedEdgeStar.h>
+using namespace geos::geomgraph;
+namespace geos {
+namespace operation { // geos.operation
+namespace buffer { // geos.operation.buffer
+Node*
+BufferNodeFactory::createNode(const geom::Coordinate& coord) const
+ return new Node(coord, new DirectedEdgeStar());
+const NodeFactory&
+BufferNodeFactory::instance()
+ static BufferNodeFactory onf;
+ return onf;
+} // namespace geos.operation.buffer
diff --git a/src/operation/buffer/MaximalEdgeRing.cpp b/src/operation/buffer/MaximalEdgeRing.cpp
index 000000000..35a56f958
--- /dev/null
+++ b/src/operation/buffer/MaximalEdgeRing.cpp
@@ -0,0 +1,136 @@
+ * Copyright (C) 2005-2006 Refractions Research Inc.
+#include <geos/operation/buffer/MaximalEdgeRing.h>
+#include <geos/operation/buffer/MinimalEdgeRing.h>
+#include <geos/geomgraph/EdgeEndStar.h>
+#include <geos/util.h>
+#include <cassert>
+#include <vector>
+#ifndef GEOS_DEBUG
+#define GEOS_DEBUG 0
+#endif
+#if GEOS_DEBUG
+#include <iostream>
+#endif
+using namespace geos::geom;
+namespace geos {
+/*public*/
+MaximalEdgeRing::MaximalEdgeRing(DirectedEdge* start,
+ const GeometryFactory* p_geometryFactory)
+// throw(const TopologyException &)
+ EdgeRing(start, p_geometryFactory)
+ computePoints(start);
+ computeRing();
+#if GEOS_DEBUG
+ std::cerr << "MaximalEdgeRing[" << this << "] ctor" << std::endl;
+#endif
+/*public*/
+DirectedEdge*
+MaximalEdgeRing::getNext(DirectedEdge* de)
+ return de->getNext();
+/*public*/
+void
+MaximalEdgeRing::setEdgeRing(DirectedEdge* de, EdgeRing* er)
+ de->setEdgeRing(er);
+/*public*/
+void
+MaximalEdgeRing::linkDirectedEdgesForMinimalEdgeRings()
+ DirectedEdge* de = startDe;
+ do {
+ Node* node = de->getNode();
+ EdgeEndStar* ees = node->getEdges();
+ DirectedEdgeStar* des = detail::down_cast<DirectedEdgeStar*>(ees);
+ des->linkMinimalDirectedEdges(this);
+ de = de->getNext();
+ while(de != startDe);
+/*public*/
+std::vector<MinimalEdgeRing*>*
+MaximalEdgeRing::buildMinimalRings()
+ std::vector<MinimalEdgeRing*>* minEdgeRings = new std::vector<MinimalEdgeRing*>;
+ buildMinimalRings(*minEdgeRings);
+ return minEdgeRings;
+/*public*/
+void
+MaximalEdgeRing::buildMinimalRings(std::vector<MinimalEdgeRing*>& minEdgeRings)
+ do {
+ if(de->getMinEdgeRing() == nullptr) {
+ MinimalEdgeRing* minEr = new MinimalEdgeRing(de, geometryFactory);
+ minEdgeRings.push_back(minEr);
+/*public*/
+void
+MaximalEdgeRing::buildMinimalRings(std::vector<EdgeRing*>& minEdgeRings)
+ do {
+} // namespace geos.operation.overlay
diff --git a/src/operation/buffer/MinimalEdgeRing.cpp b/src/operation/buffer/MinimalEdgeRing.cpp
index 000000000..a0aeb9174
--- /dev/null
+++ b/src/operation/buffer/MinimalEdgeRing.cpp
@@ -0,0 +1,39 @@
+namespace geos {
+MinimalEdgeRing::MinimalEdgeRing(geomgraph::DirectedEdge* start,
+ const geom::GeometryFactory* p_geometryFactory)
+ geomgraph::EdgeRing(start, p_geometryFactory)
+ computeRing();
diff --git a/src/operation/buffer/PolygonBuilder.cpp b/src/operation/buffer/PolygonBuilder.cpp
index 000000000..893847f91
--- /dev/null
+++ b/src/operation/buffer/PolygonBuilder.cpp
@@ -0,0 +1,372 @@
+#include <geos/operation/polygonize/EdgeRing.h>
+#include <geos/geomgraph/NodeMap.h>
+#include <geos/geomgraph/PlanarGraph.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/LinearRing.h>
+#include <geos/geom/Polygon.h>
+#include <geos/algorithm/PointLocation.h>
+#include <geos/util/TopologyException.h>
+#include <geos/util/GEOSException.h>
+#include <vector>
+#include <cassert>
+#ifndef GEOS_DEBUG
+#endif
+#if GEOS_DEBUG
+#endif
+using namespace geos::algorithm;
+namespace geos {
+PolygonBuilder::PolygonBuilder(const GeometryFactory* newGeometryFactory)
+ geometryFactory(newGeometryFactory)
+PolygonBuilder::~PolygonBuilder()
+ for(std::size_t i = 0, n = shellList.size(); i < n; ++i) {
+ delete shellList[i];
+/*public*/
+void
+PolygonBuilder::add(PlanarGraph* graph)
+//throw(TopologyException *)
+ const std::vector<EdgeEnd*>* eeptr = graph->getEdgeEnds();
+ assert(eeptr);
+ const std::vector<EdgeEnd*>& ee = *eeptr;
+ std::size_t eeSize = ee.size();
+#if GEOS_DEBUG
+ std::cerr << __FUNCTION__ << ": PlanarGraph has " << eeSize << " EdgeEnds" << std::endl;
+#endif
+ std::vector<DirectedEdge*> dirEdges(eeSize);
+ for(std::size_t i = 0; i < eeSize; ++i) {
+ DirectedEdge* de = detail::down_cast<DirectedEdge*>(ee[i]);
+ dirEdges[i] = de;
+ const auto& nodeMap = graph->getNodeMap()->nodeMap;
+ std::vector<Node*> nodes;
+ nodes.reserve(nodeMap.size());
+ for(const auto& nodeIt: nodeMap) {
+ Node* node = nodeIt.second.get();
+ nodes.push_back(node);
+ add(&dirEdges, &nodes); // might throw a TopologyException *
+/*public*/
+void
+PolygonBuilder::add(const std::vector<DirectedEdge*>* dirEdges,
+ const std::vector<Node*>* nodes)
+ PlanarGraph::linkResultDirectedEdges(nodes->begin(), nodes->end());
+ std::vector<MaximalEdgeRing*> maxEdgeRings;
+ buildMaximalEdgeRings(dirEdges, maxEdgeRings);
+ std::vector<EdgeRing*> freeHoleList;
+ std::vector<MaximalEdgeRing*> edgeRings;
+ buildMinimalEdgeRings(maxEdgeRings, shellList, freeHoleList, edgeRings);
+ sortShellsAndHoles(edgeRings, shellList, freeHoleList);
+ std::vector<FastPIPRing> indexedshellist;
+ for(auto const& shell : shellList) {
+ FastPIPRing pipRing { shell, new geos::algorithm::locate::IndexedPointInAreaLocator(*shell->getLinearRing()) };
+ indexedshellist.push_back(pipRing);
+ placeFreeHoles(indexedshellist, freeHoleList);
+ //Assert: every hole on freeHoleList has a shell assigned to it
+ for(auto const& shell : indexedshellist) {
+ delete shell.pipLocator;
+/*public*/
+std::vector<std::unique_ptr<Geometry>>
+PolygonBuilder::getPolygons()
+ std::vector<std::unique_ptr<Geometry>> resultPolyList = computePolygons(shellList);
+ return resultPolyList;
+/*private*/
+void
+PolygonBuilder::buildMaximalEdgeRings(const std::vector<DirectedEdge*>* dirEdges,
+#if GEOS_DEBUG
+ std::cerr << "PolygonBuilder::buildMaximalEdgeRings got " << dirEdges->size() << " dirEdges" << std::endl;
+#endif
+ std::vector<MaximalEdgeRing*>::size_type oldSize = maxEdgeRings.size();
+ for(std::size_t i = 0, n = dirEdges->size(); i < n; i++) {
+ DirectedEdge* de = (*dirEdges)[i];
+#if GEOS_DEBUG
+ std::cerr << " dirEdge " << i << std::endl
+ << de->printEdge() << std::endl
+ << " inResult:" << de->isInResult() << std::endl
+ << " isArea:" << de->getLabel().isArea() << std::endl;
+#endif
+ if(de->isInResult() && de->getLabel().isArea()) {
+ // if this edge has not yet been processed
+ if(de->getEdgeRing() == nullptr) {
+ MaximalEdgeRing* er;
+ try {
+ // MaximalEdgeRing constructor may throw
+ er = new MaximalEdgeRing(de, geometryFactory);
+ catch(util::GEOSException&) {
+ // cleanup if that happens (see stmlf-cases-20061020.xml)
+ for(std::size_t p_i = oldSize, p_n = maxEdgeRings.size(); p_i < p_n; p_i++) {
+ delete maxEdgeRings[p_i];
+ //cerr << "Exception! " << e.what() << std::endl;
+ throw;
+ maxEdgeRings.push_back(er);
+ er->setInResult();
+ //System.out.println("max node degree=" + er.getMaxDegree());
+#if GEOS_DEBUG
+ std::cerr << " pushed " << maxEdgeRings.size() - oldSize << " maxEdgeRings" << std::endl;
+#endif
+/*private*/
+void
+PolygonBuilder::buildMinimalEdgeRings(
+ std::vector<EdgeRing*>& newShellList, std::vector<EdgeRing*>& freeHoleList,
+ for(std::size_t i = 0, n = maxEdgeRings.size(); i < n; ++i) {
+ MaximalEdgeRing* er = maxEdgeRings[i];
+#if GEOS_DEBUG
+ std::cerr << "buildMinimalEdgeRings: maxEdgeRing " << i << " has " << er->getMaxNodeDegree() << " maxNodeDegree" << std::endl;
+#endif
+ if(er->getMaxNodeDegree() > 2) {
+ er->linkDirectedEdgesForMinimalEdgeRings();
+ std::vector<MinimalEdgeRing*> minEdgeRings;
+ er->buildMinimalRings(minEdgeRings);
+ // at this point we can go ahead and attempt to place
+ // holes, if this EdgeRing is a polygon
+ EdgeRing* shell = findShell(&minEdgeRings);
+ if(shell != nullptr) {
+ placePolygonHoles(shell, &minEdgeRings);
+ newShellList.push_back(shell);
+ else {
+ freeHoleList.insert(freeHoleList.end(),
+ minEdgeRings.begin(),
+ minEdgeRings.end());
+ delete er;
+ else {
+ edgeRings.push_back(er);
+/*private*/
+EdgeRing*
+PolygonBuilder::findShell(std::vector<MinimalEdgeRing*>* minEdgeRings)
+ int shellCount = 0;
+ EdgeRing* shell = nullptr;
+#if GEOS_DEBUG
+ std::cerr << "PolygonBuilder::findShell got " << minEdgeRings->size() << " minEdgeRings" << std::endl;
+#endif
+ for(std::size_t i = 0, n = minEdgeRings->size(); i < n; ++i) {
+ EdgeRing* er = (*minEdgeRings)[i];
+ if(! er->isHole()) {
+ shell = er;
+ ++shellCount;
+ if(shellCount > 1) {
+ throw util::TopologyException("found two shells in MinimalEdgeRing list");
+ return shell;
+/*private*/
+void
+PolygonBuilder::placePolygonHoles(EdgeRing* shell,
+ MinimalEdgeRing* er = (*minEdgeRings)[i];
+ if(er->isHole()) {
+ er->setShell(shell);
+/*private*/
+void
+PolygonBuilder::sortShellsAndHoles(std::vector<MaximalEdgeRing*>& edgeRings,
+ std::vector<EdgeRing*>& newShellList, std::vector<EdgeRing*>& freeHoleList)
+ for(std::size_t i = 0, n = edgeRings.size(); i < n; i++) {
+ EdgeRing* er = edgeRings[i];
+ //er->setInResult();
+ freeHoleList.push_back(er);
+ else {
+ newShellList.push_back(er);
+/*private*/
+void
+PolygonBuilder::placeFreeHoles(std::vector<FastPIPRing>& newShellList,
+ std::vector<EdgeRing*>& freeHoleList)
+ for(std::vector<EdgeRing*>::iterator
+ it = freeHoleList.begin(), itEnd = freeHoleList.end();
+ it != itEnd;
+ ++it) {
+ EdgeRing* hole = *it;
+ // only place this hole if it doesn't yet have a shell
+ if(hole->getShell() == nullptr) {
+ EdgeRing* shell = findEdgeRingContaining(hole, newShellList);
+ * If hole lies outside shell, discard it.
+ hole->setShell(shell);
+ else {
+ delete hole;
+/*private*/
+EdgeRing*
+PolygonBuilder::findEdgeRingContaining(EdgeRing* testEr,
+ LinearRing* testRing = testEr->getLinearRing();
+ const Envelope* testEnv = testRing->getEnvelopeInternal();
+ EdgeRing* minShell = nullptr;
+ const Envelope* minShellEnv = nullptr;
+ for(auto const& tryShell : newShellList) {
+ LinearRing* tryShellRing = tryShell.edgeRing->getLinearRing();
+ const Envelope* tryShellEnv = tryShellRing->getEnvelopeInternal();
+ // the hole envelope cannot equal the shell envelope
+ // (also guards against testing rings against themselves)
+ if(tryShellEnv->equals(testEnv)) {
+ continue;
+ // hole must be contained in shell
+ if(!tryShellEnv->contains(testEnv)) {
+ continue;
+ const CoordinateSequence* tsrcs = tryShellRing->getCoordinatesRO();
+ const Coordinate& testPt = operation::polygonize::EdgeRing::ptNotInList(testRing->getCoordinatesRO(), tsrcs);
+ bool isContained = false;
+ if(tryShell.pipLocator->locate(&testPt) != Location::EXTERIOR) {
+ isContained = true;
+ // check if this new containing ring is smaller than
+ // the current minimum ring
+ if(isContained) {
+ if(minShell == nullptr
+ || minShellEnv->contains(tryShellEnv)) {
+ minShell = tryShell.edgeRing;
+ minShellEnv = minShell->getLinearRing()->getEnvelopeInternal();
+ return minShell;
+/*private*/
+PolygonBuilder::computePolygons(std::vector<EdgeRing*>& newShellList)
+#if GEOS_DEBUG
+ std::cerr << "PolygonBuilder::computePolygons: got " << newShellList.size() << " shells" << std::endl;
+#endif
+ std::vector<std::unique_ptr<Geometry>> resultPolyList;
+ // add Polygons for all shells
+ for(std::size_t i = 0, n = newShellList.size(); i < n; i++) {
+ EdgeRing* er = newShellList[i];
+ auto poly = er->toPolygon(geometryFactory);
+ resultPolyList.push_back(std::move(poly));
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index 63d8fb4bc..342f95db2 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -598,4 +598,17 @@ void object::test<26>
"POLYGON ((0.73 0.05, 0.67 -0.13, 0.58 -0.31, 0.46 -0.46, 0.31 -0.58, 0.13 -0.67, -0.05 -0.73, -0.25 -0.75, -0.75 -0.75, -0.95 -0.73, -1.13 -0.67, -1.31 -0.58, -1.46 -0.46, -1.58 -0.31, -1.67 -0.13, -1.73 0.05, -1.75 0.25, -1.75 0.75, -1.73 0.95, -1.67 1.13, -1.58 1.31, -1.46 1.46, -1.31 1.58, -1.13 1.67, -0.95 1.73, -0.75 1.75, -0.25 1.75, -0.05 1.73, 0.13 1.67, 0.31 1.58, 0.46 1.46, 0.58 1.31, 0.67 1.13, 0.73 0.95, 0.75 0.75, 0.75 0.25, 0.73 0.05))");
+// testElementErodedEx
+// Checks that a skinny element polygon is eroded with no internal predicision reduction due to topo exes
+// see https://github.com/libgeos/geos/issues/1182
+template<>
+template<>
+void object::test<27>
+ std::string wkt = "MULTIPOLYGON (((48268.99938 -49048.29324, 44429.1 -55700.232847, 44429.1 -55107.317582, 44506.1 -54974, 44429.1 -54840, 44429.1 -51569.2, 42170.10515 -49316.27944, 48268.99938 -49048.29324)), ((43433.08324 -51823.15037, 42480.09977 -55494.96132, 42477.638798 -55504.400121, 42480.20715 -55494.547587, 42482.247919 -55485.931009, 42482.431666 -55485.976608, 43433.08324 -51823.15037)))";
+ checkBuffer(wkt, -1, 0.01,
+"POLYGON ((48267.2218198241 -49049.37231112561, 44430.1 -55696.500291383236, 44430.1 -55107.58561879013, 44506.96594366424 -54974.50014155032, 44507.05088958367 -54974.309530288774, 44507.09442572395 -54974.10543945913, 44507.09465615313 -54973.896756903174, 44507.05157083636 -54973.69257042533, 44506.96704607295 -54973.50177203271, 44430.1 -54839.73314639927, 44430.1 -51569.2, 44430.08071956347 -51569.00457958696, 44430.02362172434 -51568.81669475566, 44429.93090822513 -51568.64359050924, 44429.80615417933 -51568.49194189856, 42172.42282165639 -49317.178566110095, 48267.2218198241 -49049.37231112561))");
} // namespace tut
Summary of changes:
include/geos/operation/buffer/BufferBuilder.h | 5 ++-
.../BufferNodeFactory.h} | 14 +++-----
.../{overlay => buffer}/MaximalEdgeRing.h | 7 ++--
.../{overlay => buffer}/MinimalEdgeRing.h | 6 ++--
.../operation/{overlay => buffer}/PolygonBuilder.h | 18 +++--------
src/operation/buffer/BufferBuilder.cpp | 7 ++--
.../BufferNodeFactory.cpp} | 16 ++++------
.../{overlay => buffer}/MaximalEdgeRing.cpp | 6 ++--
.../{overlay => buffer}/MinimalEdgeRing.cpp | 9 ++----
.../{overlay => buffer}/PolygonBuilder.cpp | 37 ++++++++--------------
tests/unit/operation/buffer/BufferOpTest.cpp | 13 ++++++++
11 files changed, 59 insertions(+), 79 deletions(-)
copy include/geos/operation/{overlay/OverlayNodeFactory.h => buffer/BufferNodeFactory.h} (71%)
copy include/geos/operation/{overlay => buffer}/MaximalEdgeRing.h (96%)
copy include/geos/operation/{overlay => buffer}/MinimalEdgeRing.h (93%)
copy include/geos/operation/{overlay => buffer}/PolygonBuilder.h (90%)
copy src/operation/{overlay/OverlayNodeFactory.cpp => buffer/BufferNodeFactory.cpp} (66%)
copy src/operation/{overlay => buffer}/MaximalEdgeRing.cpp (95%)
copy src/operation/{overlay => buffer}/MinimalEdgeRing.cpp (76%)
copy src/operation/{overlay => buffer}/PolygonBuilder.cpp (89%)
hooks/post-receive
More information about the geos-commits
