[geos-commits] [SCM] GEOS branch main updated. 8aadb147d12b181cd470659eb6d91d595dd21395
git at osgeo.org
git at osgeo.org
Fri Feb 21 09:28:17 PST 2025
the project "GEOS".
The branch, main has been updated
via 8aadb147d12b181cd470659eb6d91d595dd21395 (commit)
from 642e32daecee5154befff14efd6b5da873627fb3 (commit)
revisions in full, below.
commit 8aadb147d12b181cd470659eb6d91d595dd21395
Author: freemine <freemine at yeah.net>
Date: Sat Feb 22 01:27:38 2025 +0800
Enforce stricter rules when parsing WKT
Closes #1241
WKT input previously accepted odd mis-spellings of the geometry type names (eg `POIN EMPTY`) which is far more liberal than most WKT parsers. Now out of spec WKT throws `ParseException`.
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 19b9e115b..06a5dec49 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1978,6 +1978,7 @@ extern void GEOS_DLL GEOSWKTReader_setFixStructure_r(
GEOSWKTReader *reader,
char doFix);
/* ========== WKT Writer ========== */
/** \see GEOSWKTReader_create */
diff --git a/src/io/WKTReader.cpp b/src/io/WKTReader.cpp
index fc850d220..2b4400a6b 100644
--- a/src/io/WKTReader.cpp
+++ b/src/io/WKTReader.cpp
@@ -157,7 +157,15 @@ WKTReader::getNextNumber(StringTokenizer* tokenizer)
bool
WKTReader::isTypeName(const std::string & type, const std::string & typeName) {
- return util::startsWith(type, typeName);
+ auto l = type.size();
+ auto r = typeName.size();
+ if (l == r && type == typeName) return true;
+ if (l == r + 1 && (type == typeName + 'Z' || type == typeName + 'M')) return true;
+ if (l == r + 2 && type == typeName + "ZM") return true;
+ // take `POINT` as example:
+ // POI, POINTa, POINTZMx are all invalid
+ return false;
void
@@ -178,24 +186,34 @@ WKTReader::readOrdinateFlags(const std::string & s, OrdinateSet& ordinateFlags)
std::string
WKTReader::getNextEmptyOrOpener(StringTokenizer* tokenizer, OrdinateSet& ordinateFlags)
+ const bool changesAllowed = ordinateFlags.changesAllowed();
std::string nextWord = getNextWord(tokenizer);
bool flagsModified = false;
// Skip the Z, M or ZM of an SF1.2 3/4 dim coordinate.
if (nextWord == "ZM") {
+ if (!changesAllowed) {
+ throw ParseException("'ZM' found but 'ZM' or 'Z' or 'M' has been specified in previous type");
ordinateFlags.setZ(true);
ordinateFlags.setM(true);
flagsModified = true;
} else {
if (nextWord == "Z") {
+ throw ParseException("'Z' found but 'ZM' or 'Z' or 'M' has been specified in previous type");
if (nextWord == "M") {
+ if (!changesAllowed || flagsModified) {
+ throw ParseException("'M' found but 'ZM' or 'Z' or 'M' has been specified previously");
diff --git a/tests/unit/io/WKTReaderTest.cpp b/tests/unit/io/WKTReaderTest.cpp
index 59e5f1b25..af9621916 100644
--- a/tests/unit/io/WKTReaderTest.cpp
+++ b/tests/unit/io/WKTReaderTest.cpp
@@ -244,7 +244,6 @@ void object::test<9>
ensure_dimension("POINT Z EMPTY", 3);
ensure_dimension("POINTZM EMPTY", 4);
ensure_dimension("POINT ZM EMPTY", 4);
- ensure_dimension("POINT Z M EMPTY", 4);
ensure_dimension("LINESTRING EMPTY", 2);
ensure_dimension("LINESTRINGM EMPTY", 3);
@@ -253,7 +252,6 @@ void object::test<9>
ensure_dimension("LINESTRING Z EMPTY", 3);
ensure_dimension("LINESTRINGZM EMPTY", 4);
ensure_dimension("LINESTRING ZM EMPTY", 4);
- ensure_dimension("LINESTRING Z M EMPTY", 4);
ensure_dimension("POLYGON EMPTY", 2);
ensure_dimension("POLYGONM EMPTY", 3);
@@ -262,7 +260,6 @@ void object::test<9>
ensure_dimension("POLYGON Z EMPTY", 3);
ensure_dimension("POLYGONZM EMPTY", 4);
ensure_dimension("POLYGON ZM EMPTY", 4);
- ensure_dimension("POLYGON Z M EMPTY", 4);
@@ -473,4 +470,33 @@ void object::test<24>
ensure_equals(geom->getNumGeometries(), 3u);
+// Raise exception strictly on invalid WKT
+template<>
+template<>
+void object::test<25>
+ ensure_parseexception("POI(1 1)");
+ ensure_parseexception("POINTx(1 1)");
+ ensure_parseexception("POINTxy(1 1)");
+ ensure_parseexception("POINTabc(1 1)");
+ ensure_parseexception("POINTZMc(1 1)");
+ ensure_parseexception("POINTaZM(1 1)");
+ ensure_parseexception("POINT Z M EMPTY");
+ ensure_parseexception("POINTZ Z EMPTY");
+ ensure_parseexception("POINTZ ZM EMPTY");
+ ensure_parseexception("POINT ZZ EMPTY");
+ ensure_parseexception("POINT ZZM EMPTY");
+ ensure_parseexception("POINT XY EMPTY");
+ ensure_parseexception("POINT MZ EMPTY");
+ ensure_parseexception("POINT ZMc EMPTY");
+ ensure_parseexception("POINT XY EMPT");
+ ensure_parseexception("POINT XY EMPT Y");
+ ensure_parseexception("POINT EMPTYY");
+ ensure_parseexception("LINESTRING Z M EMPTY");
+ ensure_parseexception("POLYGON Z M EMPTY");
} // namespace tut
diff --git a/tools/codespell.ignore b/tools/codespell.ignore
index 896a43d83..f29596743 100644
--- a/tools/codespell.ignore
+++ b/tools/codespell.ignore
@@ -15,3 +15,4 @@ seh
bLoc
aLo
Wel
+EMPTYY
Summary of changes:
capi/geos_c.h.in | 1 +
src/io/WKTReader.cpp | 20 +++++++++++++++++++-
tests/unit/io/WKTReaderTest.cpp | 32 +++++++++++++++++++++++++++++---
tools/codespell.ignore | 1 +
4 files changed, 50 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
