[geos-commits] [SCM] GEOS branch main updated. 472f417778a139c5ba0ff37782ed2bba07050ea7
git at osgeo.org
git at osgeo.org
Wed Feb 26 13:48:06 PST 2025
the project "GEOS".
The branch, main has been updated
via 472f417778a139c5ba0ff37782ed2bba07050ea7 (commit)
from 91e8010ae2e2881184382c5dd0e9c48880543e7b (commit)
revisions in full, below.
commit 472f417778a139c5ba0ff37782ed2bba07050ea7
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed Feb 26 16:47:36 2025 -0500
CoordinateSequence: Raise error on invalid ordinateIndex (#1245)
Co-authored-by: Mike Taves <mwtoews at gmail.com>
diff --git a/NEWS.md b/NEWS.md
index db168b22f..40c536f09 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -6,6 +6,7 @@
- Breaking Changes:
- Stricter WKT parsing (GH-1241, @freemine)
+ - GEOSCoordSeq_setOrdinate returns an error if the sequence does not have the specified ordinate (GH-1245, Dan Baston)
- Fixes/Improvements:
- Fix ConcaveHullOfPolygons nested shell handling (GH-1169, Martin Davis)
diff --git a/src/geom/CoordinateSequence.cpp b/src/geom/CoordinateSequence.cpp
index 599ca6ffb..014c3188b 100644
--- a/src/geom/CoordinateSequence.cpp
+++ b/src/geom/CoordinateSequence.cpp
@@ -547,10 +547,18 @@ CoordinateSequence::setOrdinate(std::size_t index, std::size_t ordinateIndex, do
getAt<CoordinateXY>(index).y = value;
break;
case CoordinateSequence::Z:
- getAt<Coordinate>(index).z = value;
+ if (!hasZ()) {
+ throw util::IllegalArgumentException("Coordinate type is not XYZ or XYZM");
+ getAt<Coordinate>(index).z = value;
break;
case CoordinateSequence::M:
+ if (!hasM()) {
+ throw util::IllegalArgumentException("Coordinate type is not XYM or XYZM.");
if (getCoordinateType() == CoordinateType::XYZM) {
getAt<CoordinateXYZM>(index).m = value;
} else {
diff --git a/tests/unit/capi/GEOSCoordSeqTest.cpp b/tests/unit/capi/GEOSCoordSeqTest.cpp
index 03feb3efa..176b3d523 100644
--- a/tests/unit/capi/GEOSCoordSeqTest.cpp
+++ b/tests/unit/capi/GEOSCoordSeqTest.cpp
@@ -766,4 +766,90 @@ void object::test<21>()
GEOS_finish_r(handle);
+template<>
+template<>
+void object::test<22>()
+ set_test_name("setOrdinate on XYZM coordinate");
+ cs_ = GEOSCoordSeq_create(1, 4);
+ ensure("setX", GEOSCoordSeq_setOrdinate(cs_, 0, 0, 1));
+ ensure("setY", GEOSCoordSeq_setOrdinate(cs_, 0, 1, 2));
+ ensure("setZ", GEOSCoordSeq_setOrdinate(cs_, 0, 2, 3));
+ ensure("setM", GEOSCoordSeq_setOrdinate(cs_, 0, 3, 4));
+ double x, y, z, m;
+ ensure(GEOSCoordSeq_copyToArrays(cs_, &x, &y, &z, &m));
+ ensure_equals("X", x, 1);
+ ensure_equals("Y", y, 2);
+ ensure_equals("Z", z, 3);
+ ensure_equals("M", m, 4);
+template<>
+template<>
+void object::test<23>()
+ set_test_name("setOrdinate on XYZ coordinate");
+ cs_ = GEOSCoordSeq_create(1, 3);
+ ensure("setM", !GEOSCoordSeq_setOrdinate(cs_, 0, 3, 4));
+ double x, y, z;
+ ensure(GEOSCoordSeq_copyToArrays(cs_, &x, &y, &z, nullptr));
+template<>
+template<>
+void object::test<24>()
+ set_test_name("setOrdinate on XY coordinate");
+ cs_ = GEOSCoordSeq_create(1, 2);
+ ensure("setZ", !GEOSCoordSeq_setOrdinate(cs_, 0, 2, 3));
+ double x, y;
+ ensure(GEOSCoordSeq_copyToArrays(cs_, &x, &y, nullptr, nullptr));
+template<>
+template<>
+void object::test<25>()
+ set_test_name("setOrdinate on XYM coordinate");
+ /* TODO: use GEOSCoordSeq_createWithDimensions() instead */
+ double buffer[3];
+ cs_ = GEOSCoordSeq_copyFromBuffer(buffer, 1, 0, 1);
+ double x, y, m;
+ ensure(GEOSCoordSeq_copyToArrays(cs_, &x, &y, nullptr, &m));
} // namespace tut
Summary of changes:
NEWS.md | 1 +
src/geom/CoordinateSequence.cpp | 10 ++++-
tests/unit/capi/GEOSCoordSeqTest.cpp | 86 ++++++++++++++++++++++++++++++++++++
3 files changed, 96 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
