[geos-commits] [SCM] GEOS branch 3.13 updated. 5af0c221ed9b61a2e21a7d121716c9e3aa6acd39
git at osgeo.org
git at osgeo.org
Tue Jan 7 17:01:51 PST 2025
the project "GEOS".
The branch, 3.13 has been updated
via 5af0c221ed9b61a2e21a7d121716c9e3aa6acd39 (commit)
via 87a824c022ab7644313a7a9b704ab808696a192b (commit)
from 4f293e17469fe4abf6a5dcf398713c9d914377f2 (commit)
revisions in full, below.
commit 5af0c221ed9b61a2e21a7d121716c9e3aa6acd39
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Jan 7 17:01:28 2025 -0800
Update NEWS
diff --git a/NEWS.md b/NEWS.md
index ee8ab3733..ae2ecbb85 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -9,7 +9,8 @@
- Fix WKTWriter for small precisions and with trim enabled (GH-1199, Mike Taves)
- Fix BufferOp to increase length of segments removed by heuristic (GH-1200, Martin Davis)
- Improve RelateNG performance for A/L cases in prepared predicates (GH-1201, Martin Davis)
+ - Improve OffsetCurve to handle mitre joins for polygons (Martin Davis)
## Changes in 3.13.0
2024-09-06
commit 87a824c022ab7644313a7a9b704ab808696a192b
Date: Tue Jan 7 15:03:43 2025 -0800
diff --git a/include/geos/operation/buffer/OffsetCurve.h b/include/geos/operation/buffer/OffsetCurve.h
index 403ca98b7..cff62f76b 100644
--- a/include/geos/operation/buffer/OffsetCurve.h
+++ b/include/geos/operation/buffer/OffsetCurve.h
@@ -103,6 +103,9 @@ private:
// Methods
+ std::unique_ptr<Geometry> computePolygonCurve(
+ const Polygon& polyGeom, double distance);
std::unique_ptr<Geometry> computeCurve(
const LineString& lineGeom, double distance);
diff --git a/src/operation/buffer/OffsetCurve.cpp b/src/operation/buffer/OffsetCurve.cpp
index f524ccdc1..09fc7d074 100644
--- a/src/operation/buffer/OffsetCurve.cpp
+++ b/src/operation/buffer/OffsetCurve.cpp
@@ -66,15 +66,7 @@ OffsetCurve::getCurve()
if (geom.getGeometryTypeId() == GEOS_POINT) return nullptr;
if (geom.getGeometryTypeId() == GEOS_POLYGON) {
- auto boundary = geom.buffer(distance)->getBoundary();
- if (boundary->getGeometryTypeId() == GEOS_LINEARRING) {
- const LinearRing& ring = static_cast<const LinearRing&>(geom);
- auto ringCs = ring.getCoordinatesRO();
- std::unique_ptr<Geometry> ls(geom.getFactory()->createLineString(*ringCs));
- return ls;
- return boundary;
+ return computePolygonCurve(static_cast<const Polygon&>(geom), distance);
return computeCurve(static_cast<const LineString&>(geom), distance);
@@ -141,6 +133,22 @@ OffsetCurve::rawOffset(const LineString& line, double dist)
return rawOffsetCurve(line, dist, bufParams);
+/* private */
+std::unique_ptr<Geometry>
+OffsetCurve::computePolygonCurve(const Polygon& polyGeom, double dist)
+ auto buffer = BufferOp::bufferOp(&polyGeom, dist, bufferParams);
+ std::unique_ptr<Geometry> boundary = buffer->getBoundary();
+ //-- convert LinearRing to LineString if needed
+ if (boundary->getGeometryTypeId() == GEOS_LINEARRING) {
+ const LinearRing& ring = static_cast<LinearRing&>(*boundary);
+ auto ringCs = ring.getCoordinatesRO();
+ std::unique_ptr<Geometry> ls(polyGeom.getFactory()->createLineString(*ringCs));
+ return ls;
+ return boundary;
/* private */
OffsetCurve::computeCurve(const LineString& lineGeom, double dist)
diff --git a/tests/unit/operation/buffer/OffsetCurveTest.cpp b/tests/unit/operation/buffer/OffsetCurveTest.cpp
index 76b01c4df..e845a51f4 100644
--- a/tests/unit/operation/buffer/OffsetCurveTest.cpp
+++ b/tests/unit/operation/buffer/OffsetCurveTest.cpp
@@ -588,6 +588,23 @@ void object::test<43> ()
+// testPolygonJoinMitre
+template<>
+template<>
+void object::test<44> ()
+ checkOffsetCurve(
+ "POLYGON ((1 1, 1 7, 5 4, 8 8, 8 1, 1 1))",
+ 1, 0, BufferParameters::JOIN_MITRE, 5,
+ "LINESTRING (0 0, 0 9, 4.8 5.4, 9 11, 9 0, 0 0)",
+ 0.0001
+ checkOffsetCurve(
+ -1, 0, BufferParameters::JOIN_MITRE, 5,
+ "LINESTRING (2 2, 2 5, 5.2 2.6, 7 5, 7 2, 2 2)",
+ 0.0001
} // namespace tut2
Summary of changes:
NEWS.md | 3 ++-
include/geos/operation/buffer/OffsetCurve.h | 3 +++
src/operation/buffer/OffsetCurve.cpp | 26 ++++++++++++++++---------
tests/unit/operation/buffer/OffsetCurveTest.cpp | 19 +++++++++++++++++-
4 files changed, 40 insertions(+), 11 deletions(-)
hooks/post-receive
More information about the geos-commits
