[geos-commits] [SCM] GEOS branch main updated. 145b8d1f1517736e150a0828e5bd9078cb8a58e2
git at osgeo.org
git at osgeo.org
Sun Jan 12 10:09:18 PST 2025
the project "GEOS".
The branch, main has been updated
via 145b8d1f1517736e150a0828e5bd9078cb8a58e2 (commit)
from a1e35c13b207c239ba34e13909a8f26d6adb47e2 (commit)
revisions in full, below.
commit 145b8d1f1517736e150a0828e5bd9078cb8a58e2
Author: Kunlin Yu <yukunlin at syriusrobotics.com>
Date: Mon Jan 13 02:08:53 2025 +0800
Fix bug of GeoJSONWriter when there are sub-objects or sub-array in an array (#1216)
* Add a unit test to trigger the bug "cannot use operator[] with a string argument with array"
Signed-off-by: Kunlin Yu <yukunlin at syriusrobotics.com>
* Add another unit test to trigger the bug "cannot use operator[] with a string argument with array"
* Fix bug of GeoJSONWriter related array in properties
diff --git a/src/io/GeoJSONWriter.cpp b/src/io/GeoJSONWriter.cpp
index bf3826d49..8c9db9d7b 100644
--- a/src/io/GeoJSONWriter.cpp
+++ b/src/io/GeoJSONWriter.cpp
@@ -109,15 +109,33 @@ void GeoJSONWriter::encodeGeoJSONValue(const std::string& key, const GeoJSONValu
else if (value.isArray()) {
- j[key] = json::array();
- for (const GeoJSONValue& v : value.getArray()) {
- encodeGeoJSONValue("", v, j[key]);
+ if (j.is_object()) {
+ j[key] = json::array();
+ for (const GeoJSONValue& v : value.getArray()) {
+ encodeGeoJSONValue("", v, j[key]);
+ else {
+ json sub_array = json::array();
+ encodeGeoJSONValue("", v, sub_array);
+ j.push_back(sub_array);
else if (value.isObject()) {
- j[key] = json::object();
- for (const auto& entry : value.getObject()) {
- encodeGeoJSONValue(entry.first, entry.second, j[key]);
+ j[key] = json::object();
+ for (const auto& entry : value.getObject()) {
+ encodeGeoJSONValue(entry.first, entry.second, j[key]);
+ else {
+ json sub_obj = json::object();
+ encodeGeoJSONValue(entry.first, entry.second, sub_obj);
+ j.push_back(sub_obj);
diff --git a/tests/unit/io/GeoJSONWriterTest.cpp b/tests/unit/io/GeoJSONWriterTest.cpp
index 53d6e609a..7db14f5cf 100644
--- a/tests/unit/io/GeoJSONWriterTest.cpp
+++ b/tests/unit/io/GeoJSONWriterTest.cpp
@@ -372,7 +372,6 @@ void object::test<25>
std::string result = geojsonwriter.write(geom.get());
ensure_equals(result, "{\"type\":\"LineString\",\"coordinates\":[[102.0,0.0,2.0],[103.0,1.0,4.0],[104.0,0.0,8.0],[105.0,1.0,16.0]]}");
// Write a LineString Z with some NaN Z to GeoJSON
template<>
template<>
@@ -420,4 +419,38 @@ void object::test<28>
ensure_equals(result, "{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}");
+// GeoJSONWriter Write a feature with properties "matrix": [ [1, 2, 3], [4, 5, 6] ]
+template<>
+template<>
+void object::test<29>
+ geos::io::GeoJSONValue row1(std::vector<geos::io::GeoJSONValue>({1.0, 2.0, 3.0}));
+ geos::io::GeoJSONValue row2(std::vector<geos::io::GeoJSONValue>({4.0, 5.0, 6.0}));
+ std::vector<geos::io::GeoJSONValue> obj_array = {row1, row2};
+ geos::io::GeoJSONFeature feature = {
+ wktreader.read("POINT(0 0)"),
+ std::map<std::string, geos::io::GeoJSONValue> {{"matrix", geos::io::GeoJSONValue(obj_array)}}
+ std::string result = geojsonwriter.write(feature);
+ ensure_equals(result, "{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[0.0,0.0]},\"properties\":{\"matrix\":[[1.0,2.0,3.0],[4.0,5.0,6.0]]}}");
+// GeoJSONWriter Write a feature with properties "array": [{"key": "value_1"}, {"key": "value_2"}]
+template<>
+template<>
+void object::test<30>
+ geos::io::GeoJSONValue obj1(std::map<std::string, geos::io::GeoJSONValue>({{"key", std::string("value_1")}}));
+ geos::io::GeoJSONValue obj2(std::map<std::string, geos::io::GeoJSONValue>({{"key", std::string("value_2")}}));
+ std::vector<geos::io::GeoJSONValue> obj_array = {obj1, obj2};
+ std::map<std::string, geos::io::GeoJSONValue> {{"array", geos::io::GeoJSONValue(obj_array)}}
+ ensure_equals(result, "{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[0.0,0.0]},\"properties\":{\"array\":[{\"key\":\"value_1\"},{\"key\":\"value_2\"}]}}");
Summary of changes:
src/io/GeoJSONWriter.cpp | 30 ++++++++++++++++++++++++------
tests/unit/io/GeoJSONWriterTest.cpp | 35 ++++++++++++++++++++++++++++++++++-
2 files changed, 58 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
