[geos-commits] [SCM] GEOS branch main updated. 3c42d2d52d5df22268dfe58c13f66bc6ef86c423
Mon Jan 13 12:11:30 PST 2025
the project "GEOS".
The branch, main has been updated
       via  3c42d2d52d5df22268dfe58c13f66bc6ef86c423 (commit)
       via  63fb272cffe8dcf28864925e12f0e8eb981faa9d (commit)
       via  00c98da08487ca93a1951f50dd41f344402046d2 (commit)
      from  1660b7931aa7c19461bd896206a3679e7961a922 (commit)
revisions in full, below.
commit 3c42d2d52d5df22268dfe58c13f66bc6ef86c423
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Jan 13 12:10:46 2025 -0800
    Add test case for GH-1225
diff --git a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
index 9818b8b92..dcab53cc8 100644
--- a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
+++ b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
@@ -249,5 +249,17 @@ void object::test<10>
        0.01 );
+// https://github.com/libgeos/geos/pull/1225
+template<>
+template<>
+void object::test<11>
+    checkCircle("POLYGON((0 -10,-7.07107 -7.07107,-10 0,-7.07107 7.07107,0 10,7.07107 7.07107,10 0,7.07107 -7.07107,0 -10))",
+        0.1, 0, 0, 9.2387);
 } // namespace tut
commit 63fb272cffe8dcf28864925e12f0e8eb981faa9d
Author: Benoit Maurin <maurinbe at gmail.com>
Date:   Mon Jan 13 19:20:44 2025 +0100
    Fix tests
index be67b9a2e..9818b8b92 100644
@@ -173,7 +173,7 @@ void object::test<5>
     checkCircle("POLYGON ((100 100, 200 200, 100 100, 100 100))",
-       0.01, 150, 150, 0 );
+       0.01, 100, 100, 0 );
@@ -198,7 +198,7 @@ void object::test<7>
      checkCircle("POLYGON((1 2, 1 2, 1 2, 1 2, 3 2, 1 2))",
-       0.01, 2, 2, 0 );
+       0.01, 1, 2, 0 );
 // Exception thrown to avoid infinite loop with infinite envelope
commit 00c98da08487ca93a1951f50dd41f344402046d2
Date:   Mon Jan 13 17:59:31 2025 +0100
    Fix inscribed circle initialization
diff --git a/src/algorithm/construct/MaximumInscribedCircle.cpp b/src/algorithm/construct/MaximumInscribedCircle.cpp
index c3a471078..89c910d3b 100644
--- a/src/algorithm/construct/MaximumInscribedCircle.cpp
+++ b/src/algorithm/construct/MaximumInscribedCircle.cpp
@@ -164,8 +164,8 @@ MaximumInscribedCircle::distanceToBoundary(double x, double y)
 MaximumInscribedCircle::Cell
 MaximumInscribedCircle::createInteriorPointCell(const Geometry* geom)
-    Coordinate c;
     std::unique_ptr<Point> p = geom->getInteriorPoint();
+    Coordinate c(p->getX(), p->getY());
     Cell cell(p->getX(), p->getY(), 0, distanceToBoundary(c));
     return cell;
Summary of changes:
 src/algorithm/construct/MaximumInscribedCircle.cpp       |  2 +-
 .../algorithm/construct/MaximumInscribedCircleTest.cpp   | 16 ++++++++++++++--
 2 files changed, 15 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
