[geos-commits] [SCM] GEOS branch 3.12 updated. 8f7a7df145b8fe47373c861927bbc6a0ad6be0d4
git at osgeo.org
git at osgeo.org
Tue Jan 14 16:27:10 PST 2025
the project "GEOS".
The branch, 3.12 has been updated
via 8f7a7df145b8fe47373c861927bbc6a0ad6be0d4 (commit)
from db50ec0b856bba55bd4ea1aa3631cfff1235eddb (commit)
revisions in full, below.
commit 8f7a7df145b8fe47373c861927bbc6a0ad6be0d4
Author: Mike Taves <mwtoews at gmail.com>
Date: Wed Jan 15 13:17:31 2025 +1300
Fix invalid values from CoverageUnionNG (#1226)
diff --git a/src/operation/overlayng/CoverageUnion.cpp b/src/operation/overlayng/CoverageUnion.cpp
index c0c8a1458..3d860c92a 100644
--- a/src/operation/overlayng/CoverageUnion.cpp
+++ b/src/operation/overlayng/CoverageUnion.cpp
@@ -33,7 +33,6 @@ namespace overlayng { // geos.operation.overlayng
std::unique_ptr<Geometry>
CoverageUnion::geomunion(const Geometry* coverage)
- double area_in = coverage->getArea();
std::unique_ptr<Geometry> result;
// a precision model is not needed since no noding is done
@@ -47,9 +46,10 @@ CoverageUnion::geomunion(const Geometry* coverage)
result = OverlayNG::geomunion(coverage, nullptr, &bcn);
- double area_out = result->getArea();
+ double area_in = coverage->getArea();
- if (std::abs((area_out - area_in)/area_in) > AREA_PCT_DIFF_TOL) {
+ if ( (area_in != 0.0) &&
+ (std::abs((result->getArea() - area_in)/area_in) > AREA_PCT_DIFF_TOL)) {
throw geos::util::TopologyException("CoverageUnion cannot process overlapping inputs.");
diff --git a/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp b/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp
index aec919b20..86d8ac948 100644
--- a/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp
+++ b/tests/unit/operation/overlayng/CoverageUnionNGTest.cpp
@@ -8,6 +8,7 @@
#include <geos/operation/overlayng/CoverageUnion.h>
// std
+#include <cfenv>
#include <memory>
using namespace geos::geom;
@@ -31,7 +32,9 @@ struct test_coverageunionng_data {
std::unique_ptr<Geometry> geom = r.read(wkt);
std::unique_ptr<Geometry> expected = r.read(wktExpected);
+ std::feclearexcept(FE_ALL_EXCEPT);
std::unique_ptr<Geometry> result = CoverageUnion::geomunion(geom.get());
+ ensure("FE_INVALID raised", !std::fetestexcept(FE_INVALID));
try {
ensure_equals_geometry_xyzm(result.get(), expected.get());
@@ -220,4 +223,31 @@ void object::test<17>()
"POLYGON M ((0 0 0, 1 0 1, 1 1 2, 0 1 3, 0 0 0))");
+// Check empty polygon
+template<>
+template<>
+void object::test<18>()
+ checkUnion("POLYGON EMPTY",
+ "POLYGON EMPTY");
+// Check empty GeometryCollection, with M dimension
+template<>
+template<>
+void object::test<19>()
+ checkUnion("GEOMETRYCOLLECTION M EMPTY",
+ "GEOMETRYCOLLECTION M EMPTY");
+// Check GeometryCollection of empty polygon
+template<>
+template<>
+void object::test<20>()
+ checkUnion("GEOMETRYCOLLECTION( POLYGON EMPTY )",
+ "POLYGON EMPTY");
} // namespace tut
Summary of changes:
src/operation/overlayng/CoverageUnion.cpp | 6 ++---
.../operation/overlayng/CoverageUnionNGTest.cpp | 30 ++++++++++++++++++++++
2 files changed, 33 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
