[geos-commits] [SCM] GEOS branch 3.13 updated. b3844c03ee8761a0713c15931d72f2e242f0b44e
Fri Jan 17 15:07:23 PST 2025
the project "GEOS".
The branch, 3.13 has been updated
       via  b3844c03ee8761a0713c15931d72f2e242f0b44e (commit)
      from  52c30fd0387e35148b7b5baaf67841d9643c0ee3 (commit)
revisions in full, below.
commit b3844c03ee8761a0713c15931d72f2e242f0b44e
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Jan 17 14:37:47 2025 -0800
    Fix overlay heuristic for GeometryCollections with empty elements (#1229)
diff --git a/include/geos/geom/HeuristicOverlay.h b/include/geos/geom/HeuristicOverlay.h
index bc1217a78..e4eb8b74a 100644
--- a/include/geos/geom/HeuristicOverlay.h
+++ b/include/geos/geom/HeuristicOverlay.h
@@ -46,37 +46,7 @@ class StructuredCollection {
 public:
-    StructuredCollection(const Geometry* g)
-        : factory(g->getFactory())
-        , pt_union(nullptr)
-        , line_union(nullptr)
-        , poly_union(nullptr)
-        readCollection(g);
-        unionByDimension();
-    StructuredCollection()
-        : factory(nullptr)
-    void readCollection(const Geometry* g);
-    const Geometry* getPolyUnion()  const { return poly_union.get(); }
-    const Geometry* getLineUnion()  const { return line_union.get(); }
-    const Geometry* getPointUnion() const { return pt_union.get(); }
-    std::unique_ptr<Geometry> doUnion(const StructuredCollection& a) const;
-    std::unique_ptr<Geometry> doIntersection(const StructuredCollection& a) const;
-    std::unique_ptr<Geometry> doSymDifference(const StructuredCollection& a) const;
-    std::unique_ptr<Geometry> doDifference(const StructuredCollection& a) const;
-    std::unique_ptr<Geometry> doUnaryUnion() const;
-    static void toVector(const Geometry* g, std::vector<const Geometry*>& v);
-    void unionByDimension(void);
+    static std::unique_ptr<Geometry> overlay(const Geometry* g0, const Geometry* g1, int opCode);
 private:
@@ -87,7 +57,49 @@ private:
     std::unique_ptr<Geometry> pt_union;
     std::unique_ptr<Geometry> line_union;
     std::unique_ptr<Geometry> poly_union;
+    Dimension::DimensionType dimension;
+    StructuredCollection(const Geometry* g)
+        : factory(g->getFactory())
+        , pt_union(nullptr)
+        , line_union(nullptr)
+        , poly_union(nullptr)
+        , dimension(Dimension::DONTCARE)
+        readCollection(g);
+        unionByDimension();
+    StructuredCollection()
+        : factory(nullptr)
+    Dimension::DimensionType getDimension() const
+        return dimension;
+    void addDimension(Dimension::DimensionType dim);
+    std::unique_ptr<Geometry> doUnaryUnion(int resultDim) const;
+    std::unique_ptr<Geometry> computeResult(StructuredCollection& coll, int opCode,
+                Dimension::DimensionType dimA, Dimension::DimensionType dimB) const;
+    void readCollection(const Geometry* g);
+    const Geometry* getPolyUnion()  const { return poly_union.get(); }
+    const Geometry* getLineUnion()  const { return line_union.get(); }
+    const Geometry* getPointUnion() const { return pt_union.get(); }
+    std::unique_ptr<Geometry> doUnion(const StructuredCollection& a) const;
+    std::unique_ptr<Geometry> doIntersection(const StructuredCollection& a) const;
+    std::unique_ptr<Geometry> doSymDifference(const StructuredCollection& a) const;
+    std::unique_ptr<Geometry> doDifference(const StructuredCollection& a) const;
+    static void toVector(const Geometry* g, std::vector<const Geometry*>& v);
+    void unionByDimension(void);
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index 433933587..a34c7bf35 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -619,43 +619,6 @@ Geometry::intersection(const Geometry* other) const
 Geometry::Union(const Geometry* other) const
-#ifdef SHORTCIRCUIT_PREDICATES
-    // if envelopes are disjoint return a MULTI geom or
-    // a geometrycollection
-    if(! getEnvelopeInternal()->intersects(other->getEnvelopeInternal())) {
-//cerr<<"SHORTCIRCUITED-UNION engaged"<<endl;
-        const GeometryCollection* coll;
-        std::size_t ngeomsThis = getNumGeometries();
-        std::size_t ngeomsOther = other->getNumGeometries();
-        // Allocated for ownership transfer
-        std::vector<std::unique_ptr<Geometry>> v;
-        v.reserve(ngeomsThis + ngeomsOther);
-        if(nullptr != (coll = dynamic_cast<const GeometryCollection*>(this))) {
-            for(std::size_t i = 0; i < ngeomsThis; ++i) {
-                v.push_back(coll->getGeometryN(i)->clone());
-        else {
-            v.push_back(this->clone());
-        if(nullptr != (coll = dynamic_cast<const GeometryCollection*>(other))) {
-            for(std::size_t i = 0; i < ngeomsOther; ++i) {
-        else {
-            v.push_back(other->clone());
-        return _factory->buildGeometry(std::move(v));
-#endif
     return HeuristicOverlay(this, other, OverlayNG::UNION);
@@ -676,40 +639,6 @@ Geometry::difference(const Geometry* other) const
 Geometry::symDifference(const Geometry* other) const
-    if(! getEnvelopeInternal()->intersects(other->getEnvelopeInternal()) && !(isEmpty() && other->isEmpty())) {
-        else {
-        else {
     return HeuristicOverlay(this, other, OverlayNG::SYMDIFFERENCE);
diff --git a/src/geom/HeuristicOverlay.cpp b/src/geom/HeuristicOverlay.cpp
index 2d3d51304..c164e00fb 100644
--- a/src/geom/HeuristicOverlay.cpp
+++ b/src/geom/HeuristicOverlay.cpp
@@ -20,11 +20,19 @@
  * This file provides a single function, taking two
  * const Geometry pointers, applying a binary operator to them
  * and returning a result Geometry in an unique_ptr<>.
+ * It implements a "combine-disjoint" heuristic for optimizing some overlay cases.
+ * It also implements overlay for GeometryCollections, which is not (yet)
+ * provided by OverlayNG.
+ * Internal overlay usage should call OverlayNG directly
+ * if this behaviour is not needed (i.e. when the inputs are known to be simple
+ * or when full overlay is desired to be computed.)
 #include <geos/geom/HeuristicOverlay.h>
 #include <geos/operation/overlayng/OverlayNGRobust.h>
+#include <geos/operation/overlayng/OverlayUtil.h>
 #include <geos/util/IllegalArgumentException.h>
 #include <geos/geom/Dimension.h>
 #include <geos/geom/MultiPoint.h>
@@ -39,32 +47,109 @@ namespace geom { // geos::geom
 using operation::overlayng::OverlayNG;
 using operation::overlayng::OverlayNGRobust;
+using operation::overlayng::OverlayUtil;
+bool
+hasSingleNonEmptyElement(const Geometry* geom) {
+    if (geom->getGeometryTypeId() != GEOS_GEOMETRYCOLLECTION) {
+        //-- is a non-empty element
+        return ! geom->isEmpty();
+    //-- iterate over GC elements and determine if a single non-empty is present
+    //-- buffer num geoms, since can be expensive for nested collections
+    bool foundNonEmptyElement = false;
+    std::size_t numGeoms = geom->getNumGeometries();
+    for(std::size_t i = 0; i < numGeoms; ++i) {
+        if (hasSingleNonEmptyElement(geom->getGeometryN(i))) {
+            //-- already found an element, so more than one present
+            if (foundNonEmptyElement) {
+                return false;
+            foundNonEmptyElement = true;
+    return foundNonEmptyElement;
+bool isCombinable(const Geometry* g0, const Geometry* g1)
+    //-- if both empty use OverlayNG return-type logic
+    if (g0->isEmpty() && g1->isEmpty())
+        return false;
+    //-- not disjoint
+    if (g0->getEnvelopeInternal()->intersects(g1->getEnvelopeInternal()))
+        return false;
+    return hasSingleNonEmptyElement(g0)
+        && hasSingleNonEmptyElement(g1);
+void
+extractElements(const Geometry* g, std::vector<std::unique_ptr<Geometry>>& v)
+    if (const auto* coll = dynamic_cast<const GeometryCollection*>(g)) {
+        std::size_t numGeoms = g->getNumGeometries();
+            //-- recurse to handle nested GCs
+            extractElements(coll->getGeometryN(i), v);
+    else if (g->isEmpty()) {
+        return;
+    else {
+        v.push_back(g->clone());
+std::unique_ptr<Geometry>
+combineReduced(const Geometry* g0, const Geometry* g1)
+    // Allocated for ownership transfer
+    std::vector<std::unique_ptr<Geometry>> v;
+    v.reserve(g0->getNumGeometries() + g1->getNumGeometries());
+    extractElements(g0, v);
+    extractElements(g1, v);
+    return g0->getFactory()->buildGeometry(std::move(v));
+bool isHandledByOverlayNG(const Geometry* geom) {
+    if (geom->isMixedDimension() && ! geom->isEmpty())
+        return false;
+    //-- GCs with polygonals must be unioned
+    if (geom->getGeometryTypeId() == GEOS_GEOMETRYCOLLECTION
+        && geom->getDimension() == 2)
+        return false;
+    return true;
 HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
-    std::unique_ptr<Geometry> ret;
+     * If feasible, do fast combine instead of full overlay
+     * NOTE: does not node LineStrings, or merge elements of arg geoms.
+     * This is different behaviour to full overlay.
+    //TODO: could also handle difference and intersection?
+    if ( ( opCode == OverlayNG::UNION
+        || opCode == OverlayNG::SYMDIFFERENCE)
+            && isCombinable(g0, g1)) {
+        return combineReduced(g0, g1);
     * overlayng::OverlayNGRobust does not currently handle
-    * GeometryCollection (collections of mixed dimension)
+    * non-empty GeometryCollections
     * so we handle that case here.
-    if ((g0->isMixedDimension() && !g0->isEmpty()) ||
-        (g1->isMixedDimension() && !g1->isEmpty()))
+    if (! isHandledByOverlayNG(g0) ||
+        ! isHandledByOverlayNG(g1))
-        StructuredCollection s0(g0);
-        StructuredCollection s1(g1);
-        switch (opCode) {
-        case OverlayNG::UNION:
-            return s0.doUnion(s1);
-        case OverlayNG::DIFFERENCE:
-            return s0.doDifference(s1);
-        case OverlayNG::SYMDIFFERENCE:
-            return s0.doSymDifference(s1);
-        case OverlayNG::INTERSECTION:
-            return s0.doIntersection(s1);
+        return StructuredCollection::overlay(g0, g1, opCode);
@@ -86,6 +171,7 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
     * Running overlayng::OverlayNGRobust at this stage should guarantee
     * that none of the other heuristics are ever needed.
+    std::unique_ptr<Geometry> ret;
     if (g0 == nullptr && g1 == nullptr) {
         return std::unique_ptr<Geometry>(nullptr);
@@ -108,6 +194,34 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
     return ret;
+/* public static */
+StructuredCollection::overlay(const Geometry* g0, const Geometry* g1, int opCode)
+    StructuredCollection s0(g0);
+    StructuredCollection s1(g1);
+    switch (opCode) {
+    case OverlayNG::UNION:
+        return s0.doUnion(s1);
+    case OverlayNG::DIFFERENCE:
+        return s0.doDifference(s1);
+    case OverlayNG::SYMDIFFERENCE:
+        return s0.doSymDifference(s1);
+    case OverlayNG::INTERSECTION:
+        return s0.doIntersection(s1);
+    default:
+        throw util::IllegalArgumentException("Invalid overlay opcode");
+/* private */
+void
+StructuredCollection::addDimension(Dimension::DimensionType dim)
+    if (dimension < dim)
+        dimension = dim;
 /* public */
 void
 StructuredCollection::readCollection(const Geometry* g)
@@ -123,12 +237,15 @@ StructuredCollection::readCollection(const Geometry* g)
         switch (g->getGeometryTypeId()) {
             case GEOS_POINT:
                 pts.push_back(g);
+                addDimension(Dimension::P);
                 break;
             case GEOS_LINESTRING:
                 lines.push_back(g);
+                addDimension(Dimension::L);
                 break;
             case GEOS_POLYGON:
                 polys.push_back(g);
+                addDimension(Dimension::A);
                 break;
             default:
                 throw util::IllegalArgumentException("cannot process unexpected collection");
@@ -181,7 +298,9 @@ StructuredCollection::unionByDimension(void)
     // io::WKTWriter w;
     // std::cout << "line_col " << w.write(*line_col) << std::endl;
-    // std::cout << "line_union " << w.write(*line_union) << std::endl;
+    // std::cout << "pt_union: " << w.write(*pt_union) << std::endl;
+    // std::cout << "line_union: " << w.write(*line_union) << std::endl;
+    // std::cout << "poly_union: " << w.write(*poly_union) << std::endl;
     if (! pt_union->isPuntal())
         throw util::IllegalArgumentException("union of points not puntal");
@@ -193,7 +312,7 @@ StructuredCollection::unionByDimension(void)
 /* public */
-StructuredCollection::doUnaryUnion() const
+StructuredCollection::doUnaryUnion(int resultDim) const
     * Before output, we clean up the components to remove spatial
@@ -221,15 +340,27 @@ StructuredCollection::doUnaryUnion() const
     toVector(lines_less_polys.get(), geoms);
     toVector(poly_union.get(), geoms);
+    if (geoms.size() == 0) {
+        return OverlayUtil::createEmptyResult(
+            resultDim, factory);
     return factory->buildGeometry(geoms.begin(), geoms.end());
+/* public */
+StructuredCollection::computeResult(StructuredCollection& coll, int opCode,
+    coll.unionByDimension();
+    int resultDim = OverlayUtil::resultDimension(opCode, dimA, dimB);
+    return coll.doUnaryUnion(resultDim);
 /* public */
 StructuredCollection::doUnion(const StructuredCollection& a) const
     auto poly_union_poly = OverlayNGRobust::Overlay(
         a.getPolyUnion(),
         poly_union.get(),
@@ -249,8 +380,7 @@ StructuredCollection::doUnion(const StructuredCollection& a) const
     c.readCollection(poly_union_poly.get());
     c.readCollection(line_union_line.get());
     c.readCollection(pt_union_pt.get());
-    c.unionByDimension();
-    return c.doUnaryUnion();
+    return computeResult(c, OverlayNG::UNION, getDimension(), a.getDimension());
@@ -322,8 +452,7 @@ StructuredCollection::doIntersection(const StructuredCollection& a) const
     c.readCollection(pt_inter_poly.get());
     c.readCollection(pt_inter_line.get());
     c.readCollection(pt_inter_pt.get());
+    return computeResult(c, OverlayNG::INTERSECTION, getDimension(), a.getDimension());
@@ -364,8 +493,7 @@ StructuredCollection::doDifference(const StructuredCollection& a) const
     c.readCollection(poly_diff_poly.get());
     c.readCollection(line_diff_poly_line.get());
     c.readCollection(pt_diff_poly_line_pt.get());
+    return computeResult(c, OverlayNG::DIFFERENCE, getDimension(), a.getDimension());
@@ -390,8 +518,7 @@ StructuredCollection::doSymDifference(const StructuredCollection& a) const
     c.readCollection(poly_symdiff_poly.get());
     c.readCollection(line_symdiff_line.get());
     c.readCollection(pt_symdiff_pt.get());
+    return computeResult(c, OverlayNG::SYMDIFFERENCE, getDimension(), a.getDimension());
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 2a4e736f4..82cd91bcc 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -20,11 +20,11 @@
 #include <geos/geom/Geometry.h>
 #include <geos/geom/GeometryFactory.h>
-#include <geos/geom/HeuristicOverlay.h>
 #include <geos/geom/MultiPolygon.h>
 #include <geos/geom/Polygon.h>
 #include <geos/index/strtree/TemplateSTRtree.h>
 #include <geos/operation/overlayng/OverlayNG.h>
+#include <geos/operation/overlayng/OverlayNGRobust.h>
 #include <geos/operation/union/CascadedPolygonUnion.h>
 #include <geos/operation/valid/IsValidOp.h>
 #include <geos/operation/valid/IsSimpleOp.h>
@@ -201,10 +201,8 @@ CascadedPolygonUnion::restrictToPolygons(std::unique_ptr<geom::Geometry> g)
 ClassicUnionStrategy::Union(const geom::Geometry* g0, const geom::Geometry* g1)
-    // TODO make an rvalue overload for this that can consume its inputs.
-    // At a minimum, a copy in the buffer fallback can be eliminated.
     try {
-        return geom::HeuristicOverlay(g0, g1, operation::overlayng::OverlayNG::UNION);
+        return operation::overlayng::OverlayNGRobust::Overlay(g0, g1, operation::overlayng::OverlayNG::UNION);
     catch (const util::TopologyException &ex) {
         ::geos::ignore_unused_variable_warning(ex);
diff --git a/src/operation/valid/MakeValid.cpp b/src/operation/valid/MakeValid.cpp
index f54428390..4d00027c7 100644
--- a/src/operation/valid/MakeValid.cpp
+++ b/src/operation/valid/MakeValid.cpp
@@ -23,9 +23,9 @@
 #include <geos/operation/polygonize/BuildArea.h>
 #include <geos/operation/union/UnaryUnionOp.h>
 #include <geos/geom/GeometryCollection.h>
@@ -51,6 +51,7 @@
 using namespace geos::geom;
 using geos::operation::overlayng::OverlayNG;
+using geos::operation::overlayng::OverlayNGRobust;
 namespace geos {
 namespace operation { // geos.operation
@@ -60,19 +61,19 @@ namespace valid { // geos.operation.valid
 static std::unique_ptr<geom::Geometry>
 makeValidSymDifference(const geom::Geometry* g0, const geom::Geometry* g1)
-    return HeuristicOverlay(g0, g1, OverlayNG::SYMDIFFERENCE);
+    return OverlayNGRobust::Overlay(g0, g1, OverlayNG::SYMDIFFERENCE);
 makeValidDifference(const geom::Geometry* g0, const geom::Geometry* g1)
-    return HeuristicOverlay(g0, g1, OverlayNG::DIFFERENCE);
+    return OverlayNGRobust::Overlay(g0, g1, OverlayNG::DIFFERENCE);
 makeValidUnion(const geom::Geometry* g0, const geom::Geometry* g1)
-    return HeuristicOverlay(g0, g1, OverlayNG::UNION);
+    return OverlayNGRobust::Overlay(g0, g1, OverlayNG::UNION);
diff --git a/tests/unit/geom/HeuristicOverlayTest.cpp b/tests/unit/geom/HeuristicOverlayTest.cpp
index c687e8a69..0f9a19717 100644
--- a/tests/unit/geom/HeuristicOverlayTest.cpp
+++ b/tests/unit/geom/HeuristicOverlayTest.cpp
@@ -163,7 +163,7 @@ void object::test<8> ()
         "GEOMETRYCOLLECTION(POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)))",
         "GEOMETRYCOLLECTION(POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)), POINT(20 20))",
-        "GEOMETRYCOLLECTION EMPTY"
+        "POLYGON EMPTY"
@@ -204,4 +204,16 @@ void object::test<11> ()
+template<>
+template<>
+void object::test<12> ()
+    checkOverlay(
+        "GEOMETRYCOLLECTION (POLYGON ((1 5, 5 5, 5 1, 1 1, 1 5)), POLYGON ((9 5, 9 1, 5 1, 5 5, 9 5)))",
+        "POLYGON ((1 5, 9 5, 9 1, 1 1, 1 5))",
+        OverlayNG::DIFFERENCE,
+        "POLYGON EMPTY"
 } // namespace tut
diff --git a/tests/xmltester/BufferResultMatcher.cpp b/tests/xmltester/BufferResultMatcher.cpp
index dd260ca7c..7100673d1 100644
--- a/tests/xmltester/BufferResultMatcher.cpp
+++ b/tests/xmltester/BufferResultMatcher.cpp
@@ -19,7 +19,6 @@
 #include "BufferResultMatcher.h"
 #include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
@@ -65,15 +64,8 @@ BufferResultMatcher::isSymDiffAreaInTolerance(
     const geom::Geometry& actualBuffer,
     const geom::Geometry& expectedBuffer)
-    typedef std::unique_ptr<geom::Geometry> GeomPtr;
-    using geos::geom::HeuristicOverlay;
     double area = expectedBuffer.getArea();
-    GeomPtr diff = HeuristicOverlay(&actualBuffer, &expectedBuffer,
-                            operation::overlayng::OverlayNG::SYMDIFFERENCE);
-    double areaDiff = diff->getArea();
+    double areaDiff = actualBuffer.symDifference(&expectedBuffer)->getArea();
     // can't get closer than difference area = 0 !
     // This also handles case when symDiff is empty
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 165fa199b..aa01c88da 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -178,6 +178,13 @@ tolower(std::string& str)
+void toupper(std::string& s)
+    std::transform(s.begin(), s.end(), s.begin(),
+        [](char c){ return (char)std::toupper(c); }
 std::string
 normalize_filename(const std::string& str)
@@ -875,11 +882,13 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
     tmp = opel->Attribute("arg1");
     if(tmp) {
         opArg1 = tmp;
+        toupper(opArg1);
     tmp = opel->Attribute("arg2");
     if(tmp) {
         opArg2 = tmp;
+        toupper(opArg2);
     tmp = opel->Attribute("arg3");
@@ -988,13 +997,15 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
         else if(opName == "intersection") {
+            geom::Geometry* g1 = opArg1 == "B" ? gB : gA;
+            geom::Geometry* g2 = opArg2 == "B" ? gB : gA;
             GeomPtr gRes(parseGeometry(opRes, "expected"));
             gRes->normalize();
             profile.start();
-            GeomPtr gRealRes(gA->intersection(gB));
+            GeomPtr gRealRes(g1->intersection(g2));
             profile.stop();
@@ -1312,6 +1323,9 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
         else if(opName == "union") {
             gRes->normalize();
@@ -1319,10 +1333,10 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
             GeomPtr gRealRes;
             if(gB) {
-                gRealRes = gA->Union(gB);
+                gRealRes = g1->Union(g2);
             else {
-                gRealRes = gA->Union();
+                gRealRes = g1->Union();
             profile.stop();
@@ -1339,11 +1353,13 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
         else if(opName == "difference") {
             gRes->normalize();
-            GeomPtr gRealRes(gA->difference(gB));
+            GeomPtr gRealRes(g1->difference(g2));
             gRealRes->normalize();
@@ -1360,10 +1376,13 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
         else if(opName == "symdifference") {
             gRes->normalize();
-            GeomPtr gRealRes(gA->symDifference(gB));
+            GeomPtr gRealRes(g1->symDifference(g2));
diff --git a/tests/xmltester/tests/general/TestOverlayEmpty.xml b/tests/xmltester/tests/general/TestOverlayEmpty.xml
index 9dd989672..2c17375c5 100644
--- a/tests/xmltester/tests/general/TestOverlayEmpty.xml
+++ b/tests/xmltester/tests/general/TestOverlayEmpty.xml
@@ -1016,6 +1016,55 @@
 <test> <op name='symDifference' arg1='A' arg2='B'>  POLYGON EMPTY   </op> </test>
 </case>
+<case>
+  <desc>PC - point and disjoint GC with empty elements</desc>
+  <a>
+POINT (1 1)
+  </a>
+  <b>
+GEOMETRYCOLLECTION (POLYGON EMPTY, POINT EMPTY, LINESTRING (2 2, 3 3))
+  </b>
+<test>  <op name="intersection" arg1="A" arg2="B">
+POINT EMPTY
+  </op></test>
+<test>  <op name="union" arg1="A" arg2="B">
+GEOMETRYCOLLECTION (LINESTRING (2 2, 3 3), POINT (1 1))
+  </op></test>
+<test>  <op name="difference" arg1="A" arg2="B">
+POINT (1 1)
+  </op></test>
+<test>  <op name="difference" arg1="B" arg2="A">
+LINESTRING (2 2, 3 3)
+  </op></test>
+<test>  <op name="symdifference" arg1="A" arg2="B">
+  </op></test>
+</case>
+<case>
+  <desc>PC - point and disjoint GC with nested empty elements</desc>
+  <a>
+POINT (1 1)
+  </a>
+  <b>
+GEOMETRYCOLLECTION (GEOMETRYCOLLECTION (POLYGON EMPTY, POINT EMPTY), GEOMETRYCOLLECTION(POLYGON EMPTY, LINESTRING (2 2, 3 3)))
+  </b>
+POINT EMPTY
+  </op></test>
+  </op></test>
+POINT (1 1)
+  </op></test>
+  </op></test>
+  </op></test>
+</case>
 </run>
Summary of changes:
 include/geos/geom/HeuristicOverlay.h               |  38 +++--
 src/geom/Geometry.cpp                              |  71 --------
 src/geom/HeuristicOverlay.cpp                      | 181 ++++++++++++++++++---
 src/operation/union/CascadedPolygonUnion.cpp       |   6 +-
 src/operation/valid/MakeValid.cpp                  |   9 +-
 tests/unit/geom/HeuristicOverlayTest.cpp           |  14 +-
 tests/xmltester/BufferResultMatcher.cpp            |  10 +-
 tests/xmltester/XMLTester.cpp                      |  29 +++-
 tests/xmltester/tests/general/TestOverlayEmpty.xml |  49 ++++++
 9 files changed, 273 insertions(+), 134 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
