[geos-commits] [SCM] GEOS branch 3.12 updated. 6f1b29bf1c09c865e32b4037a693714e8e380f96
git at osgeo.org
git at osgeo.org
Fri Jan 17 15:11:43 PST 2025
the project "GEOS".
The branch, 3.12 has been updated
via 6f1b29bf1c09c865e32b4037a693714e8e380f96 (commit)
via 364ece733cf456d1f91de3811d81a7ac0465164e (commit)
from 8f7a7df145b8fe47373c861927bbc6a0ad6be0d4 (commit)
revisions in full, below.
commit 6f1b29bf1c09c865e32b4037a693714e8e380f96
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Jan 17 15:11:18 2025 -0800
Update NEWS
diff --git a/NEWS.md b/NEWS.md
index 4829fbd6f..fdc8b9fff 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -17,6 +17,7 @@
- Fix BufferOp to increase length of segments removed by heuristic (GH-1200, Martin Davis)
- Improve OffsetCurve to handle mitre joins for polygons (Martin Davis)
- Fix inscribed circle initialization (GH-1225, Benoit Maurin)
+ - Fix overlay heuristic for GeometryCollections with empty elements (GH-1229, Martin Davis)
## Changes in 3.12.2
2024-06-05
commit 364ece733cf456d1f91de3811d81a7ac0465164e
Date: Fri Jan 17 14:37:47 2025 -0800
Fix overlay heuristic for GeometryCollections with empty elements (#1229)
diff --git a/include/geos/geom/HeuristicOverlay.h b/include/geos/geom/HeuristicOverlay.h
index bc1217a78..e4eb8b74a 100644
--- a/include/geos/geom/HeuristicOverlay.h
+++ b/include/geos/geom/HeuristicOverlay.h
@@ -46,37 +46,7 @@ class StructuredCollection {
public:
- StructuredCollection(const Geometry* g)
- : factory(g->getFactory())
- , pt_union(nullptr)
- , line_union(nullptr)
- , poly_union(nullptr)
- readCollection(g);
- unionByDimension();
- StructuredCollection()
- : factory(nullptr)
- void readCollection(const Geometry* g);
- const Geometry* getPolyUnion() const { return poly_union.get(); }
- const Geometry* getLineUnion() const { return line_union.get(); }
- const Geometry* getPointUnion() const { return pt_union.get(); }
- std::unique_ptr<Geometry> doUnion(const StructuredCollection& a) const;
- std::unique_ptr<Geometry> doIntersection(const StructuredCollection& a) const;
- std::unique_ptr<Geometry> doSymDifference(const StructuredCollection& a) const;
- std::unique_ptr<Geometry> doDifference(const StructuredCollection& a) const;
- std::unique_ptr<Geometry> doUnaryUnion() const;
- static void toVector(const Geometry* g, std::vector<const Geometry*>& v);
- void unionByDimension(void);
+ static std::unique_ptr<Geometry> overlay(const Geometry* g0, const Geometry* g1, int opCode);
private:
@@ -87,7 +57,49 @@ private:
std::unique_ptr<Geometry> pt_union;
std::unique_ptr<Geometry> line_union;
std::unique_ptr<Geometry> poly_union;
+ Dimension::DimensionType dimension;
+ StructuredCollection(const Geometry* g)
+ : factory(g->getFactory())
+ , pt_union(nullptr)
+ , line_union(nullptr)
+ , poly_union(nullptr)
+ , dimension(Dimension::DONTCARE)
+ readCollection(g);
+ unionByDimension();
+ StructuredCollection()
+ : factory(nullptr)
+ Dimension::DimensionType getDimension() const
+ return dimension;
+ void addDimension(Dimension::DimensionType dim);
+ std::unique_ptr<Geometry> doUnaryUnion(int resultDim) const;
+ std::unique_ptr<Geometry> computeResult(StructuredCollection& coll, int opCode,
+ Dimension::DimensionType dimA, Dimension::DimensionType dimB) const;
+ void readCollection(const Geometry* g);
+ const Geometry* getPolyUnion() const { return poly_union.get(); }
+ const Geometry* getLineUnion() const { return line_union.get(); }
+ const Geometry* getPointUnion() const { return pt_union.get(); }
+ std::unique_ptr<Geometry> doUnion(const StructuredCollection& a) const;
+ std::unique_ptr<Geometry> doIntersection(const StructuredCollection& a) const;
+ std::unique_ptr<Geometry> doSymDifference(const StructuredCollection& a) const;
+ std::unique_ptr<Geometry> doDifference(const StructuredCollection& a) const;
+ static void toVector(const Geometry* g, std::vector<const Geometry*>& v);
+ void unionByDimension(void);
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index dfd37113e..ff5c0e324 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -543,43 +543,6 @@ Geometry::intersection(const Geometry* other) const
Geometry::Union(const Geometry* other) const
-#ifdef SHORTCIRCUIT_PREDICATES
- // if envelopes are disjoint return a MULTI geom or
- // a geometrycollection
- if(! getEnvelopeInternal()->intersects(other->getEnvelopeInternal())) {
-//cerr<<"SHORTCIRCUITED-UNION engaged"<<endl;
- const GeometryCollection* coll;
- std::size_t ngeomsThis = getNumGeometries();
- std::size_t ngeomsOther = other->getNumGeometries();
- // Allocated for ownership transfer
- std::vector<std::unique_ptr<Geometry>> v;
- v.reserve(ngeomsThis + ngeomsOther);
- if(nullptr != (coll = dynamic_cast<const GeometryCollection*>(this))) {
- for(std::size_t i = 0; i < ngeomsThis; ++i) {
- v.push_back(coll->getGeometryN(i)->clone());
- else {
- v.push_back(this->clone());
- if(nullptr != (coll = dynamic_cast<const GeometryCollection*>(other))) {
- for(std::size_t i = 0; i < ngeomsOther; ++i) {
- else {
- v.push_back(other->clone());
- return _factory->buildGeometry(std::move(v));
-#endif
return HeuristicOverlay(this, other, OverlayNG::UNION);
@@ -600,40 +563,6 @@ Geometry::difference(const Geometry* other) const
Geometry::symDifference(const Geometry* other) const
- if(! getEnvelopeInternal()->intersects(other->getEnvelopeInternal()) && !(isEmpty() && other->isEmpty())) {
- else {
- else {
return HeuristicOverlay(this, other, OverlayNG::SYMDIFFERENCE);
diff --git a/src/geom/HeuristicOverlay.cpp b/src/geom/HeuristicOverlay.cpp
index 2d3d51304..c164e00fb 100644
--- a/src/geom/HeuristicOverlay.cpp
+++ b/src/geom/HeuristicOverlay.cpp
@@ -20,11 +20,19 @@
* This file provides a single function, taking two
* const Geometry pointers, applying a binary operator to them
* and returning a result Geometry in an unique_ptr<>.
+ * It implements a "combine-disjoint" heuristic for optimizing some overlay cases.
+ * It also implements overlay for GeometryCollections, which is not (yet)
+ * provided by OverlayNG.
+ * Internal overlay usage should call OverlayNG directly
+ * if this behaviour is not needed (i.e. when the inputs are known to be simple
+ * or when full overlay is desired to be computed.)
#include <geos/geom/HeuristicOverlay.h>
#include <geos/operation/overlayng/OverlayNGRobust.h>
+#include <geos/operation/overlayng/OverlayUtil.h>
#include <geos/util/IllegalArgumentException.h>
#include <geos/geom/Dimension.h>
#include <geos/geom/MultiPoint.h>
@@ -39,32 +47,109 @@ namespace geom { // geos::geom
using operation::overlayng::OverlayNG;
using operation::overlayng::OverlayNGRobust;
+using operation::overlayng::OverlayUtil;
+bool
+hasSingleNonEmptyElement(const Geometry* geom) {
+ if (geom->getGeometryTypeId() != GEOS_GEOMETRYCOLLECTION) {
+ //-- is a non-empty element
+ return ! geom->isEmpty();
+ //-- iterate over GC elements and determine if a single non-empty is present
+ //-- buffer num geoms, since can be expensive for nested collections
+ bool foundNonEmptyElement = false;
+ std::size_t numGeoms = geom->getNumGeometries();
+ for(std::size_t i = 0; i < numGeoms; ++i) {
+ if (hasSingleNonEmptyElement(geom->getGeometryN(i))) {
+ //-- already found an element, so more than one present
+ if (foundNonEmptyElement) {
+ return false;
+ foundNonEmptyElement = true;
+ return foundNonEmptyElement;
+bool isCombinable(const Geometry* g0, const Geometry* g1)
+ //-- if both empty use OverlayNG return-type logic
+ if (g0->isEmpty() && g1->isEmpty())
+ return false;
+ //-- not disjoint
+ if (g0->getEnvelopeInternal()->intersects(g1->getEnvelopeInternal()))
+ return false;
+ return hasSingleNonEmptyElement(g0)
+ && hasSingleNonEmptyElement(g1);
+void
+extractElements(const Geometry* g, std::vector<std::unique_ptr<Geometry>>& v)
+ if (const auto* coll = dynamic_cast<const GeometryCollection*>(g)) {
+ std::size_t numGeoms = g->getNumGeometries();
+ //-- recurse to handle nested GCs
+ extractElements(coll->getGeometryN(i), v);
+ else if (g->isEmpty()) {
+ return;
+ else {
+ v.push_back(g->clone());
+std::unique_ptr<Geometry>
+combineReduced(const Geometry* g0, const Geometry* g1)
+ // Allocated for ownership transfer
+ std::vector<std::unique_ptr<Geometry>> v;
+ v.reserve(g0->getNumGeometries() + g1->getNumGeometries());
+ extractElements(g0, v);
+ extractElements(g1, v);
+ return g0->getFactory()->buildGeometry(std::move(v));
+bool isHandledByOverlayNG(const Geometry* geom) {
+ if (geom->isMixedDimension() && ! geom->isEmpty())
+ return false;
+ //-- GCs with polygonals must be unioned
+ if (geom->getGeometryTypeId() == GEOS_GEOMETRYCOLLECTION
+ && geom->getDimension() == 2)
+ return false;
+ return true;
HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
- std::unique_ptr<Geometry> ret;
+ * If feasible, do fast combine instead of full overlay
+ * NOTE: does not node LineStrings, or merge elements of arg geoms.
+ * This is different behaviour to full overlay.
+ //TODO: could also handle difference and intersection?
+ if ( ( opCode == OverlayNG::UNION
+ || opCode == OverlayNG::SYMDIFFERENCE)
+ && isCombinable(g0, g1)) {
+ return combineReduced(g0, g1);
* overlayng::OverlayNGRobust does not currently handle
- * GeometryCollection (collections of mixed dimension)
+ * non-empty GeometryCollections
* so we handle that case here.
- if ((g0->isMixedDimension() && !g0->isEmpty()) ||
- (g1->isMixedDimension() && !g1->isEmpty()))
+ if (! isHandledByOverlayNG(g0) ||
+ ! isHandledByOverlayNG(g1))
- StructuredCollection s0(g0);
- StructuredCollection s1(g1);
- switch (opCode) {
- case OverlayNG::UNION:
- return s0.doUnion(s1);
- case OverlayNG::DIFFERENCE:
- return s0.doDifference(s1);
- case OverlayNG::SYMDIFFERENCE:
- return s0.doSymDifference(s1);
- case OverlayNG::INTERSECTION:
- return s0.doIntersection(s1);
+ return StructuredCollection::overlay(g0, g1, opCode);
@@ -86,6 +171,7 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
* Running overlayng::OverlayNGRobust at this stage should guarantee
* that none of the other heuristics are ever needed.
+ std::unique_ptr<Geometry> ret;
if (g0 == nullptr && g1 == nullptr) {
return std::unique_ptr<Geometry>(nullptr);
@@ -108,6 +194,34 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
return ret;
+/* public static */
+StructuredCollection::overlay(const Geometry* g0, const Geometry* g1, int opCode)
+ StructuredCollection s0(g0);
+ StructuredCollection s1(g1);
+ switch (opCode) {
+ case OverlayNG::UNION:
+ return s0.doUnion(s1);
+ case OverlayNG::DIFFERENCE:
+ return s0.doDifference(s1);
+ case OverlayNG::SYMDIFFERENCE:
+ return s0.doSymDifference(s1);
+ case OverlayNG::INTERSECTION:
+ return s0.doIntersection(s1);
+ default:
+ throw util::IllegalArgumentException("Invalid overlay opcode");
+/* private */
+void
+StructuredCollection::addDimension(Dimension::DimensionType dim)
+ if (dimension < dim)
+ dimension = dim;
/* public */
void
StructuredCollection::readCollection(const Geometry* g)
@@ -123,12 +237,15 @@ StructuredCollection::readCollection(const Geometry* g)
switch (g->getGeometryTypeId()) {
case GEOS_POINT:
pts.push_back(g);
+ addDimension(Dimension::P);
break;
case GEOS_LINESTRING:
lines.push_back(g);
+ addDimension(Dimension::L);
break;
case GEOS_POLYGON:
polys.push_back(g);
+ addDimension(Dimension::A);
break;
default:
throw util::IllegalArgumentException("cannot process unexpected collection");
@@ -181,7 +298,9 @@ StructuredCollection::unionByDimension(void)
// io::WKTWriter w;
// std::cout << "line_col " << w.write(*line_col) << std::endl;
- // std::cout << "line_union " << w.write(*line_union) << std::endl;
+ // std::cout << "pt_union: " << w.write(*pt_union) << std::endl;
+ // std::cout << "line_union: " << w.write(*line_union) << std::endl;
+ // std::cout << "poly_union: " << w.write(*poly_union) << std::endl;
if (! pt_union->isPuntal())
throw util::IllegalArgumentException("union of points not puntal");
@@ -193,7 +312,7 @@ StructuredCollection::unionByDimension(void)
/* public */
-StructuredCollection::doUnaryUnion() const
+StructuredCollection::doUnaryUnion(int resultDim) const
* Before output, we clean up the components to remove spatial
@@ -221,15 +340,27 @@ StructuredCollection::doUnaryUnion() const
toVector(lines_less_polys.get(), geoms);
toVector(poly_union.get(), geoms);
+ if (geoms.size() == 0) {
+ return OverlayUtil::createEmptyResult(
+ resultDim, factory);
return factory->buildGeometry(geoms.begin(), geoms.end());
+/* public */
+StructuredCollection::computeResult(StructuredCollection& coll, int opCode,
+ coll.unionByDimension();
+ int resultDim = OverlayUtil::resultDimension(opCode, dimA, dimB);
+ return coll.doUnaryUnion(resultDim);
/* public */
StructuredCollection::doUnion(const StructuredCollection& a) const
auto poly_union_poly = OverlayNGRobust::Overlay(
a.getPolyUnion(),
poly_union.get(),
@@ -249,8 +380,7 @@ StructuredCollection::doUnion(const StructuredCollection& a) const
c.readCollection(poly_union_poly.get());
c.readCollection(line_union_line.get());
c.readCollection(pt_union_pt.get());
- c.unionByDimension();
- return c.doUnaryUnion();
+ return computeResult(c, OverlayNG::UNION, getDimension(), a.getDimension());
@@ -322,8 +452,7 @@ StructuredCollection::doIntersection(const StructuredCollection& a) const
c.readCollection(pt_inter_poly.get());
c.readCollection(pt_inter_line.get());
c.readCollection(pt_inter_pt.get());
+ return computeResult(c, OverlayNG::INTERSECTION, getDimension(), a.getDimension());
@@ -364,8 +493,7 @@ StructuredCollection::doDifference(const StructuredCollection& a) const
c.readCollection(poly_diff_poly.get());
c.readCollection(line_diff_poly_line.get());
c.readCollection(pt_diff_poly_line_pt.get());
+ return computeResult(c, OverlayNG::DIFFERENCE, getDimension(), a.getDimension());
@@ -390,8 +518,7 @@ StructuredCollection::doSymDifference(const StructuredCollection& a) const
c.readCollection(poly_symdiff_poly.get());
c.readCollection(line_symdiff_line.get());
c.readCollection(pt_symdiff_pt.get());
+ return computeResult(c, OverlayNG::SYMDIFFERENCE, getDimension(), a.getDimension());
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 2a4e736f4..82cd91bcc 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -20,11 +20,11 @@
#include <geos/geom/Geometry.h>
#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/HeuristicOverlay.h>
#include <geos/geom/MultiPolygon.h>
#include <geos/geom/Polygon.h>
#include <geos/index/strtree/TemplateSTRtree.h>
#include <geos/operation/overlayng/OverlayNG.h>
+#include <geos/operation/overlayng/OverlayNGRobust.h>
#include <geos/operation/union/CascadedPolygonUnion.h>
#include <geos/operation/valid/IsValidOp.h>
#include <geos/operation/valid/IsSimpleOp.h>
@@ -201,10 +201,8 @@ CascadedPolygonUnion::restrictToPolygons(std::unique_ptr<geom::Geometry> g)
ClassicUnionStrategy::Union(const geom::Geometry* g0, const geom::Geometry* g1)
- // TODO make an rvalue overload for this that can consume its inputs.
- // At a minimum, a copy in the buffer fallback can be eliminated.
try {
- return geom::HeuristicOverlay(g0, g1, operation::overlayng::OverlayNG::UNION);
+ return operation::overlayng::OverlayNGRobust::Overlay(g0, g1, operation::overlayng::OverlayNG::UNION);
catch (const util::TopologyException &ex) {
::geos::ignore_unused_variable_warning(ex);
diff --git a/src/operation/valid/MakeValid.cpp b/src/operation/valid/MakeValid.cpp
index f54428390..4d00027c7 100644
--- a/src/operation/valid/MakeValid.cpp
+++ b/src/operation/valid/MakeValid.cpp
@@ -23,9 +23,9 @@
#include <geos/operation/polygonize/BuildArea.h>
#include <geos/operation/union/UnaryUnionOp.h>
#include <geos/geom/GeometryCollection.h>
@@ -51,6 +51,7 @@
using namespace geos::geom;
using geos::operation::overlayng::OverlayNG;
+using geos::operation::overlayng::OverlayNGRobust;
namespace geos {
namespace operation { // geos.operation
@@ -60,19 +61,19 @@ namespace valid { // geos.operation.valid
static std::unique_ptr<geom::Geometry>
makeValidSymDifference(const geom::Geometry* g0, const geom::Geometry* g1)
- return HeuristicOverlay(g0, g1, OverlayNG::SYMDIFFERENCE);
+ return OverlayNGRobust::Overlay(g0, g1, OverlayNG::SYMDIFFERENCE);
makeValidDifference(const geom::Geometry* g0, const geom::Geometry* g1)
- return HeuristicOverlay(g0, g1, OverlayNG::DIFFERENCE);
+ return OverlayNGRobust::Overlay(g0, g1, OverlayNG::DIFFERENCE);
makeValidUnion(const geom::Geometry* g0, const geom::Geometry* g1)
- return HeuristicOverlay(g0, g1, OverlayNG::UNION);
+ return OverlayNGRobust::Overlay(g0, g1, OverlayNG::UNION);
diff --git a/tests/unit/geom/HeuristicOverlayTest.cpp b/tests/unit/geom/HeuristicOverlayTest.cpp
index c687e8a69..0f9a19717 100644
--- a/tests/unit/geom/HeuristicOverlayTest.cpp
+++ b/tests/unit/geom/HeuristicOverlayTest.cpp
@@ -163,7 +163,7 @@ void object::test<8> ()
"GEOMETRYCOLLECTION(POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)))",
"GEOMETRYCOLLECTION(POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)), POINT(20 20))",
- "GEOMETRYCOLLECTION EMPTY"
+ "POLYGON EMPTY"
@@ -204,4 +204,16 @@ void object::test<11> ()
+template<>
+template<>
+void object::test<12> ()
+ checkOverlay(
+ "GEOMETRYCOLLECTION (POLYGON ((1 5, 5 5, 5 1, 1 1, 1 5)), POLYGON ((9 5, 9 1, 5 1, 5 5, 9 5)))",
+ "POLYGON ((1 5, 9 5, 9 1, 1 1, 1 5))",
+ OverlayNG::DIFFERENCE,
+ "POLYGON EMPTY"
} // namespace tut
diff --git a/tests/xmltester/BufferResultMatcher.cpp b/tests/xmltester/BufferResultMatcher.cpp
index dd260ca7c..7100673d1 100644
--- a/tests/xmltester/BufferResultMatcher.cpp
+++ b/tests/xmltester/BufferResultMatcher.cpp
@@ -19,7 +19,6 @@
#include "BufferResultMatcher.h"
#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
@@ -65,15 +64,8 @@ BufferResultMatcher::isSymDiffAreaInTolerance(
const geom::Geometry& actualBuffer,
const geom::Geometry& expectedBuffer)
- typedef std::unique_ptr<geom::Geometry> GeomPtr;
- using geos::geom::HeuristicOverlay;
double area = expectedBuffer.getArea();
- GeomPtr diff = HeuristicOverlay(&actualBuffer, &expectedBuffer,
- operation::overlayng::OverlayNG::SYMDIFFERENCE);
- double areaDiff = diff->getArea();
+ double areaDiff = actualBuffer.symDifference(&expectedBuffer)->getArea();
// can't get closer than difference area = 0 !
// This also handles case when symDiff is empty
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 4bd67edef..c364524ee 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -176,6 +176,13 @@ tolower(std::string& str)
+void toupper(std::string& s)
+ std::transform(s.begin(), s.end(), s.begin(),
+ [](char c){ return (char)std::toupper(c); }
std::string
normalize_filename(const std::string& str)
@@ -873,11 +880,13 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
tmp = opel->Attribute("arg1");
if(tmp) {
opArg1 = tmp;
+ toupper(opArg1);
tmp = opel->Attribute("arg2");
if(tmp) {
opArg2 = tmp;
+ toupper(opArg2);
tmp = opel->Attribute("arg3");
@@ -986,13 +995,15 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
else if(opName == "intersection") {
+ geom::Geometry* g1 = opArg1 == "B" ? gB : gA;
+ geom::Geometry* g2 = opArg2 == "B" ? gB : gA;
GeomPtr gRes(parseGeometry(opRes, "expected"));
gRes->normalize();
profile.start();
- GeomPtr gRealRes(gA->intersection(gB));
+ GeomPtr gRealRes(g1->intersection(g2));
profile.stop();
@@ -1310,6 +1321,9 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
else if(opName == "union") {
gRes->normalize();
@@ -1317,10 +1331,10 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
GeomPtr gRealRes;
if(gB) {
- gRealRes = gA->Union(gB);
+ gRealRes = g1->Union(g2);
else {
- gRealRes = gA->Union();
+ gRealRes = g1->Union();
profile.stop();
@@ -1337,11 +1351,13 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
else if(opName == "difference") {
gRes->normalize();
- GeomPtr gRealRes(gA->difference(gB));
+ GeomPtr gRealRes(g1->difference(g2));
gRealRes->normalize();
@@ -1358,10 +1374,13 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
else if(opName == "symdifference") {
gRes->normalize();
- GeomPtr gRealRes(gA->symDifference(gB));
+ GeomPtr gRealRes(g1->symDifference(g2));
diff --git a/tests/xmltester/tests/general/TestOverlayEmpty.xml b/tests/xmltester/tests/general/TestOverlayEmpty.xml
index 9dd989672..2c17375c5 100644
--- a/tests/xmltester/tests/general/TestOverlayEmpty.xml
+++ b/tests/xmltester/tests/general/TestOverlayEmpty.xml
@@ -1016,6 +1016,55 @@
<test> <op name='symDifference' arg1='A' arg2='B'> POLYGON EMPTY </op> </test>
</case>
+<case>
+ <desc>PC - point and disjoint GC with empty elements</desc>
+ <a>
+POINT (1 1)
+ </a>
+ <b>
+GEOMETRYCOLLECTION (POLYGON EMPTY, POINT EMPTY, LINESTRING (2 2, 3 3))
+ </b>
+<test> <op name="intersection" arg1="A" arg2="B">
+POINT EMPTY
+ </op></test>
+<test> <op name="union" arg1="A" arg2="B">
+GEOMETRYCOLLECTION (LINESTRING (2 2, 3 3), POINT (1 1))
+ </op></test>
+<test> <op name="difference" arg1="A" arg2="B">
+POINT (1 1)
+ </op></test>
+<test> <op name="difference" arg1="B" arg2="A">
+LINESTRING (2 2, 3 3)
+ </op></test>
+<test> <op name="symdifference" arg1="A" arg2="B">
+ </op></test>
+</case>
+<case>
+ <desc>PC - point and disjoint GC with nested empty elements</desc>
+ <a>
+POINT (1 1)
+ </a>
+ <b>
+GEOMETRYCOLLECTION (GEOMETRYCOLLECTION (POLYGON EMPTY, POINT EMPTY), GEOMETRYCOLLECTION(POLYGON EMPTY, LINESTRING (2 2, 3 3)))
+ </b>
+POINT EMPTY
+ </op></test>
+ </op></test>
+POINT (1 1)
+ </op></test>
+ </op></test>
+ </op></test>
+</case>
</run>
Summary of changes:
NEWS.md | 1 +
include/geos/geom/HeuristicOverlay.h | 38 +++--
src/geom/Geometry.cpp | 71 --------
src/geom/HeuristicOverlay.cpp | 181 ++++++++++++++++++---
src/operation/union/CascadedPolygonUnion.cpp | 6 +-
src/operation/valid/MakeValid.cpp | 9 +-
tests/unit/geom/HeuristicOverlayTest.cpp | 14 +-
tests/xmltester/BufferResultMatcher.cpp | 10 +-
tests/xmltester/XMLTester.cpp | 29 +++-
tests/xmltester/tests/general/TestOverlayEmpty.xml | 49 ++++++
10 files changed, 274 insertions(+), 134 deletions(-)
hooks/post-receive
More information about the geos-commits
