[geos-commits] [SCM] GEOS branch main updated. b2af4472de4195a8e1cde955addf8693c3e05c04
git at osgeo.org
git at osgeo.org
Wed Jan 22 16:54:58 PST 2025
the project "GEOS".
The branch, main has been updated
via b2af4472de4195a8e1cde955addf8693c3e05c04 (commit)
from af08e9d5318ad823072d17908058c6b1aa9125b9 (commit)
revisions in full, below.
commit b2af4472de4195a8e1cde955addf8693c3e05c04
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed Jan 22 19:54:31 2025 -0500
Add clustering functions to C API (#1154)
* Add clustering functions to C API
* C API cluster functions: Return ids instead of GEOSGeometry*
* C API cluster functions: Return GEOSClusterInfo object
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 39d34ff5e..633c6b07c 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -24,6 +24,7 @@
#include <geos/io/GeoJSONReader.h>
#include <geos/io/GeoJSONWriter.h>
#include <geos/operation/buffer/BufferParameters.h>
+#include <geos/operation/cluster/Clusters.h>
#include <geos/util/Interrupt.h>
#include <stdexcept>
@@ -40,6 +41,7 @@
// violations.
#define GEOSGeometry geos::geom::Geometry
#define GEOSPreparedGeometry geos::geom::prep::PreparedGeometry
+#define GEOSClusterInfo geos::operation::cluster::Clusters
#define GEOSCoordSequence geos::geom::CoordinateSequence
#define GEOSBufferParams geos::operation::buffer::BufferParameters
#define GEOSSTRtree geos::index::strtree::TemplateSTRtree<void*>
@@ -343,6 +345,61 @@ extern "C" {
return GEOSNearestPoints_r(handle, g1, g2);
+ GEOSClusterInfo*
+ GEOSClusterDBSCAN(const GEOSGeometry* g, double eps, unsigned minPoints)
+ return GEOSClusterDBSCAN_r(handle, g, eps, minPoints);
+ GEOSClusterInfo*
+ GEOSClusterGeometryDistance(const GEOSGeometry* g, double d)
+ return GEOSClusterGeometryDistance_r(handle, g, d);
+ GEOSClusterInfo*
+ GEOSClusterGeometryIntersects(const GEOSGeometry* g)
+ return GEOSClusterGeometryIntersects_r(handle, g);
+ GEOSClusterInfo*
+ GEOSClusterEnvelopeDistance(const GEOSGeometry* g, double d)
+ return GEOSClusterEnvelopeDistance_r(handle, g, d);
+ GEOSClusterInfo*
+ GEOSClusterEnvelopeIntersects(const GEOSGeometry* g)
+ return GEOSClusterEnvelopeIntersects_r(handle, g);
+ std::size_t GEOSClusterInfo_getNumClusters(const GEOSClusterInfo* clusters)
+ return GEOSClusterInfo_getNumClusters_r(handle, clusters);
+ std::size_t GEOSClusterInfo_getClusterSize(const GEOSClusterInfo* clusters, size_t i)
+ return GEOSClusterInfo_getClusterSize_r(handle, clusters, i);
+ const std::size_t* GEOSClusterInfo_getInputsForClusterN(const GEOSClusterInfo* clusters, size_t i)
+ return GEOSClusterInfo_getInputsForClusterN_r(handle, clusters, i);
+ std::size_t* GEOSClusterInfo_getClustersForInputs(const GEOSClusterInfo* clusters)
+ return GEOSClusterInfo_getClustersForInputs_r(handle, clusters);
+ void GEOSClusterInfo_destroy(GEOSClusterInfo* info)
+ GEOSClusterInfo_destroy_r(handle, info);
Geometry*
GEOSGeomFromWKT(const char* wkt)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index bd3b3e36c..761f69889 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -175,6 +175,12 @@ typedef struct GEOSBufParams_t GEOSBufferParams;
typedef struct GEOSMakeValidParams_t GEOSMakeValidParams;
+* Object containing information about cluster of geometries.
+* \see GEOSClusterInfo_destroy()
+typedef struct GEOSClusterInfo_t GEOSClusterInfo;
#endif
/** \cond */
@@ -1848,6 +1854,50 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_transformXYZ_r(
GEOSTransformXYZCallback callback,
void* userdata);
+/** \see GEOSClusterDBSCAN */
+extern GEOSClusterInfo GEOS_DLL* GEOSClusterDBSCAN_r(
+ GEOSContextHandle_t handle,
+ const GEOSGeometry* g,
+ double eps,
+ unsigned minPoints);
+/** \see GEOSClusterGeometryDistance */
+extern GEOSClusterInfo GEOS_DLL* GEOSClusterGeometryDistance_r(
+ double d);
+/** \see GEOSClusterGeometryIntersects */
+extern GEOSClusterInfo GEOS_DLL* GEOSClusterGeometryIntersects_r(
+ const GEOSGeometry* g);
+/** \see GEOSClusterEnvelopeDistance */
+extern GEOSClusterInfo GEOS_DLL* GEOSClusterEnvelopeDistance_r(
+ double d);
+/** \see GEOSClusterEnvelopeIntersects */
+extern GEOSClusterInfo GEOS_DLL* GEOSClusterEnvelopeIntersects_r(
+/** \see GEOSClusterInfo_getNumClusters */
+extern size_t GEOS_DLL GEOSClusterInfo_getNumClusters_r(GEOSContextHandle_t, const GEOSClusterInfo* clusters);
+/** \see GEOSClusterInfo_getClusterSize */
+extern size_t GEOS_DLL GEOSClusterInfo_getClusterSize_r(GEOSContextHandle_t, const GEOSClusterInfo* clusters, size_t i);
+/** \see GEOSClusterInfo_getClustersForInputs */
+extern size_t GEOS_DLL* GEOSClusterInfo_getClustersForInputs_r(GEOSContextHandle_t, const GEOSClusterInfo* clusters);
+/** \see GEOSClusterInfo_getInputsForClusterN */
+extern const size_t GEOS_DLL* GEOSClusterInfo_getInputsForClusterN_r(GEOSContextHandle_t, const GEOSClusterInfo* clusters, size_t i);
+/** \see GEOSClusterInfo_destroy */
+extern void GEOS_DLL GEOSClusterInfo_destroy_r(GEOSContextHandle_t, GEOSClusterInfo* info);
/* ========= Algorithms ========= */
/** \see GEOSOrientationIndex */
@@ -3759,6 +3809,123 @@ extern GEOSGeometry GEOS_DLL *GEOSClipByRect(
extern GEOSGeometry GEOS_DLL *GEOSSharedPaths(
const GEOSGeometry* g1,
const GEOSGeometry* g2);
+/* ========== Clustering functions ========== */
+/** @name Clustering
+* Functions for clustering geometries
+static const size_t GEOS_CLUSTER_NONE = (size_t) -1;
+ * @brief GEOSClusterDBSCAN
+ * Cluster geometries using the DBSCAN algorithm
+ * @param g a collection of geometries to be clustered
+ * @param eps distance parameter for clustering
+ * @param minPoints density parameter for clustering
+ * @return cluster information object
+extern GEOSClusterInfo GEOS_DLL* GEOSClusterDBSCAN(const GEOSGeometry* g, double eps, unsigned minPoints);
+ * @brief GEOSClusterGeometryDistance
+ * Cluster geometries according to a distance threshold
+ * @param d minimum distance between geometries in the same cluster
+extern GEOSClusterInfo GEOS_DLL* GEOSClusterGeometryDistance(const GEOSGeometry* g, double d);
+ * @brief GEOSClusterGeometryIntersects
+ * Cluster geometries that intersect
+extern GEOSClusterInfo GEOS_DLL* GEOSClusterGeometryIntersects(const GEOSGeometry* g);
+ * @brief GEOSClusterEnvelopeDistance
+ * Cluster geometries according to an envelope distance threshold
+ * @param d minimum envelope distance between geometries in the same cluster
+extern GEOSClusterInfo GEOS_DLL* GEOSClusterEnvelopeDistance(const GEOSGeometry* g, double d);
+ * @brief GEOSClusterEnvelopeIntersects
+ * Cluster geometries whose envelopes intersect
+ * @param g
+extern GEOSClusterInfo GEOS_DLL* GEOSClusterEnvelopeIntersects(const GEOSGeometry* g);
+ * @brief GEOSClusterInfo_getNumClusters
+ * Get the number of clusters identifed by a clustering operation
+ * @param clusters cluster information object
+ * @return number of clusters identifed
+extern size_t GEOS_DLL GEOSClusterInfo_getNumClusters(const GEOSClusterInfo* clusters);
+ * @brief GEOSClusterInfo_getSize
+ * Get the number of elements in the ith cluster (0-indexed)
+ * @param i cluster for which a size will be returned
+ * @return number of elements in the cluster
+extern size_t GEOS_DLL GEOSClusterInfo_getClusterSize(const GEOSClusterInfo* clusters, size_t i );
+ * @brief GEOSClusterInfo_getClustersForInputs
+ * Get the cluster index associated with each input to the clustering operation.
+ * Inputs that do are not associated with any cluster will have an index of GEOS_CLUSTER_NONE.
+ * @return an array of cluster indices, to be freed by the caller.
+extern size_t GEOS_DLL* GEOSClusterInfo_getClustersForInputs(const GEOSClusterInfo* clusters);
+ * @brief GEOSClusterInfo_getInputsForClusterN
+ * @param i index of the cluster for which indices should be retrieved
+ * @return a pointer to an array of cluster indices. Size of the array is indicated by
+ * GEOSClusterInfo_getNumElements. The array is owner by the cluster information
+ * object and should not be modified or freed by the caller.
+extern const size_t GEOS_DLL* GEOSClusterInfo_getInputsForClusterN(const GEOSClusterInfo* clusters, size_t i);
+ * @brief GEOSClusterInfo_destroy
+ * Destroy a cluster information object.
+extern void GEOS_DLL GEOSClusterInfo_destroy(GEOSClusterInfo* clusters);
@@ -4975,9 +5142,9 @@ extern char GEOS_DLL GEOSEqualsIdentical(
* Calculate the [DE9IM](https://en.wikipedia.org/wiki/DE-9IM) string for a geometry pair
-* and compare against a DE9IM pattern.
+* and compare against a DE9IM pattern.
* Returns true if the computed matrix matches the pattern.
-* The pattern is a 9-character string
+* The pattern is a 9-character string
* containing symbols in the set "012TF*".
* "012F" match the corresponding dimension symbol;
* "T" matches any non-empty dimension; "*" matches any dimension.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index b77d872ba..ace450b49 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -73,6 +73,11 @@
#include <geos/operation/buffer/BufferOp.h>
#include <geos/operation/buffer/OffsetCurve.h>
+#include <geos/operation/cluster/DBSCANClusterFinder.h>
+#include <geos/operation/cluster/EnvelopeDistanceClusterFinder.h>
+#include <geos/operation/cluster/EnvelopeIntersectsClusterFinder.h>
+#include <geos/operation/cluster/GeometryDistanceClusterFinder.h>
+#include <geos/operation/cluster/GeometryIntersectsClusterFinder.h>
#include <geos/operation/distance/DistanceOp.h>
#include <geos/operation/distance/IndexedFacetDistance.h>
#include <geos/operation/linemerge/LineMerger.h>
@@ -135,6 +140,7 @@
#define GEOSWKTReader geos::io::WKTReader
@@ -203,6 +209,7 @@ using geos::algorithm::hull::ConcaveHullOfPolygons;
using geos::operation::buffer::BufferBuilder;
using geos::operation::buffer::BufferParameters;
using geos::operation::buffer::OffsetCurve;
+using geos::operation::cluster::Clusters;
using geos::operation::distance::IndexedFacetDistance;
using geos::operation::geounion::CascadedPolygonUnion;
using geos::operation::overlayng::OverlayNG;
@@ -948,6 +955,98 @@ extern "C" {
+ static Clusters* capi_clusters(const Geometry* g,
+ geos::operation::cluster::AbstractClusterFinder& finder)
+ std::vector<const Geometry*> input{g->getNumGeometries()};
+ for (std::size_t i = 0; i < input.size(); i++) {
+ input[i] = g->getGeometryN(i);
+ return new Clusters(finder.cluster(input));
+ Clusters*
+ GEOSClusterDBSCAN_r(GEOSContextHandle_t extHandle, const Geometry* g, double eps, unsigned minPoints)
+ return execute(extHandle, [&]() {
+ geos::operation::cluster::DBSCANClusterFinder finder(eps, minPoints);
+ return capi_clusters(g, finder);
+ Clusters*
+ GEOSClusterGeometryIntersects_r(GEOSContextHandle_t extHandle, const Geometry* g)
+ geos::operation::cluster::GeometryIntersectsClusterFinder finder;
+ Clusters*
+ GEOSClusterEnvelopeIntersects_r(GEOSContextHandle_t extHandle, const Geometry* g)
+ geos::operation::cluster::EnvelopeIntersectsClusterFinder finder;
+ Clusters*
+ GEOSClusterEnvelopeDistance_r(GEOSContextHandle_t extHandle, const Geometry* g, double d)
+ geos::operation::cluster::EnvelopeDistanceClusterFinder finder(d);
+ Clusters*
+ GEOSClusterGeometryDistance_r(GEOSContextHandle_t extHandle, const Geometry* g, double d)
+ geos::operation::cluster::GeometryDistanceClusterFinder finder(d);
+ std::size_t GEOSClusterInfo_getNumClusters_r(GEOSContextHandle_t extHandle, const Clusters* clusters)
+ return execute(extHandle, 0, [&]() -> std::size_t {
+ return static_cast<unsigned>(clusters->getNumClusters());
+ std::size_t GEOSClusterInfo_getClusterSize_r(GEOSContextHandle_t extHandle, const Clusters* clusters, std::size_t i)
+ return execute(extHandle, 0, [&]() {
+ return static_cast<unsigned>(clusters->getSize(i));
+ const std::size_t* GEOSClusterInfo_getInputsForClusterN_r(GEOSContextHandle_t extHandle, const Clusters* clusters, std::size_t i)
+ return &*clusters->begin(i);
+ std::size_t* GEOSClusterInfo_getClustersForInputs_r(GEOSContextHandle_t extHandle, const Clusters* clusters)
+ auto ids = clusters->getClusterIds(GEOS_CLUSTER_NONE);
+ std::size_t* ids_buf = (size_t*) malloc(ids.size() * sizeof(std::size_t));
+ std::copy(ids.begin(), ids.end(), ids_buf);
+ return ids_buf;
+ void GEOSClusterInfo_destroy_r(GEOSContextHandle_t, Clusters* clusters)
+ delete clusters;
Geometry*
GEOSGeomFromWKT_r(GEOSContextHandle_t extHandle, const char* wkt)
diff --git a/tests/unit/capi/GEOSClusterTest.cpp b/tests/unit/capi/GEOSClusterTest.cpp
new file mode 100644
index 000000000..f96d91ce5
--- /dev/null
+++ b/tests/unit/capi/GEOSClusterTest.cpp
@@ -0,0 +1,148 @@
+// Test Suite for C-API GEOSCluster*
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capicluster_data : public capitest::utility {
+ static GEOSGeometry* construct_clusters(const GEOSGeometry* input,
+ const GEOSClusterInfo* clusters)
+ auto ngeoms = static_cast<std::size_t>(GEOSGetNumGeometries(input));
+ auto numClusters = GEOSClusterInfo_getNumClusters(clusters);
+ std::vector<GEOSGeometry*> cluster_components(ngeoms);
+ std::vector<GEOSGeometry*> cluster_geoms(numClusters);
+ for (std::size_t cluster_id = 0; cluster_id < numClusters; cluster_id++) {
+ auto sz = GEOSClusterInfo_getClusterSize(clusters, cluster_id);
+ const std::size_t* indices = GEOSClusterInfo_getInputsForClusterN(clusters, cluster_id);
+ for (std::size_t i = 0; i < sz; i++) {
+ cluster_components[i] = GEOSGeom_clone(GEOSGetGeometryN(input, static_cast<int>(indices[i])));
+ cluster_geoms[cluster_id] = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION,
+ cluster_components.data(),
+ static_cast<unsigned>(sz));
+ // combine the clusters into a single nested GeometryCollection
+ return GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION,
+ cluster_geoms.data(),
+ static_cast<unsigned>(cluster_geoms.size()));
+typedef test_group<test_capicluster_data> group;
+typedef group::object object;
+group test_capicluster_group("capi::GEOSCluster");
+// Test Cases
+template<>
+template<> void object::test<1>
+ input_ = fromWKT(
+ "GEOMETRYCOLLECTION ("
+ "POINT (0 1),"
+ "LINESTRING (0 0, 0 0.1),"
+ "LINESTRING (0 0, 1.0 1.0),"
+ "POINT (0.9 1.0),"
+ "POINT (0 7))");
+ GEOSClusterInfo* clusters = GEOSClusterEnvelopeIntersects(input_);
+ ensure_equals("two clusters by envelope intersection", GEOSClusterInfo_getNumClusters(clusters), 2u);
+ GEOSGeometry* geom_result = construct_clusters(input_, clusters);
+ GEOSGeometry* geom_expected = fromWKT("GEOMETRYCOLLECTION ("
+ " GEOMETRYCOLLECTION ("
+ " POINT (0 1),"
+ " LINESTRING (0 0, 0 0.1),"
+ " LINESTRING (0 0, 1.0 1.0),"
+ " POINT (0.9 1.0)),"
+ " POINT (0 7)))");
+ ensure_geometry_equals_identical(geom_expected, geom_result);
+ GEOSGeom_destroy(geom_result);
+ GEOSGeom_destroy(geom_expected);
+ GEOSClusterInfo_destroy(clusters);
+ GEOSClusterInfo* clusters = GEOSClusterEnvelopeDistance(input_, 6);
+ ensure_equals("one cluster by envelope distance", GEOSClusterInfo_getNumClusters(clusters), 1u);
+ GEOSClusterInfo* clusters = GEOSClusterGeometryIntersects(input_);
+ ensure_equals("four clusters by geometry intersection", GEOSClusterInfo_getNumClusters(clusters), 4u);
+ GEOSClusterInfo* clusters = GEOSClusterGeometryDistance(input_, 0.2);
+ ensure_equals("three clusters by distance", GEOSClusterInfo_getNumClusters(clusters), 3u);
+template<>
+template<>
+void object::test<2>()
+ input_ = fromWKT(
+ "POINT (0 0),"
+ "POINT (-1 0),"
+ "POINT (-1 -0.1),"
+ "POINT (-1 0.1),"
+ "POINT (1 0),"
+ "POINT (2 0),"
+ "POINT (3 0),"
+ "POINT ( 3 -0.1),"
+ "POINT ( 3 0.1)"
+ GEOSClusterInfo* clusters = GEOSClusterDBSCAN(input_, 1.01, 5);
+ ensure_equals("two clusters with minPoints = 5", GEOSClusterInfo_getNumClusters(clusters), 2u);
+ GEOSClusterInfo* clusters = GEOSClusterDBSCAN(input_, 1.01, 2);
+ ensure_equals("one cluster with minPoints = 2", GEOSClusterInfo_getNumClusters(clusters), 1u);
+ GEOSClusterInfo* clusters = GEOSClusterDBSCAN(input_, 1.01, 20);
+ ensure_equals("no clusters with minPoints = 20", GEOSClusterInfo_getNumClusters(clusters), 0u);
+ auto* cluster_ids = GEOSClusterInfo_getClustersForInputs(clusters);
+ for (int i = 0; i < GEOSGetNumGeometries(input_); i++) {
+ ensure_equals(cluster_ids[i], GEOS_CLUSTER_NONE);
+ GEOSFree(cluster_ids);
+} // namespace tut
Summary of changes:
capi/geos_c.cpp | 57 ++++++++++++
capi/geos_c.h.in | 171 +++++++++++++++++++++++++++++++++++-
capi/geos_ts_c.cpp | 99 +++++++++++++++++++++
tests/unit/capi/GEOSClusterTest.cpp | 148 +++++++++++++++++++++++++++++++
4 files changed, 473 insertions(+), 2 deletions(-)
create mode 100644 tests/unit/capi/GEOSClusterTest.cpp
hooks/post-receive
More information about the geos-commits
