[geos-commits] [SCM] GEOS branch main updated. ae1f72600b5939169d57c1ae76cd9dec7fba847e
git at osgeo.org
git at osgeo.org
Fri Jul 4 12:13:36 PDT 2025
the project "GEOS".
The branch, main has been updated
via ae1f72600b5939169d57c1ae76cd9dec7fba847e (commit)
from 3e5548c497271eda29d5e992b0f22da8702c7b4d (commit)
revisions in full, below.
commit ae1f72600b5939169d57c1ae76cd9dec7fba847e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Jul 4 12:13:15 2025 -0700
Port DiscreteFrechetDistance from JTS (#1274)
Updates the DiscreteFrechetDistance along the lines of the [JTS improvement](https://github.com/locationtech/jts/pull/764). Removes stack overflow failure identified in #516, by removing the recursion. Replacement algorithm slows down with large objects, but no longer crashes. Interrupt points added hopefully in enough places to guard against overly large objects.
diff --git a/NEWS.md b/NEWS.md
index 0fb4f8e34..8232eaf6f 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -27,6 +27,7 @@
- Fix OverlayNG coordinate dimension handling for EMPTY geometries (GH-1258, Martin Davis)
- Fix DepthSegment comparison logic (really this time) (GH-1266, Martin Davis)
- Change CoverageGapFinder to return polygons (Martin Davis)
+ - Update DiscreteFrechetDistance to new algorithm (GH-1274, Paul Ramsey)
## Changes in 3.13.0
2024-09-06
diff --git a/include/geos/algorithm/distance/DiscreteFrechetDistance.h b/include/geos/algorithm/distance/DiscreteFrechetDistance.h
index da72b382c..a82952afb 100644
--- a/include/geos/algorithm/distance/DiscreteFrechetDistance.h
+++ b/include/geos/algorithm/distance/DiscreteFrechetDistance.h
@@ -3,173 +3,531 @@
* GEOS - Geometry Engine Open Source
* http://geos.osgeo.org
- * Copyright (C) 2016 Shinichi SUGIYAMA (shin.sugi at gmail.com)
+ * Copyright (c) 2021 Felix Obermaier
+ * Copyright (c) 2025 Paul Ramsey
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
* by the Free Software Foundation.
* See the COPYING file for more information.
- * Last port: original work
- * Developed by Shinichi SUGIYAMA (shin.sugi at gmail.com)
- * based on http://www.kr.tuwien.ac.at/staff/eiter/et-archive/cdtr9464.pdf
#pragma once
#include <geos/export.h>
-#include <geos/algorithm/distance/PointPairDistance.h> // for composition
-#include <geos/algorithm/distance/DistanceToPoint.h> // for composition
-#include <geos/util/IllegalArgumentException.h> // for inlines
-#include <geos/geom/Geometry.h> // for inlines
-#include <geos/util/math.h> // for inlines
-#include <geos/geom/CoordinateFilter.h> // for inheritance
-#include <geos/geom/CoordinateSequence.h> // for inheritance
+#include <geos/algorithm/distance/PointPairDistance.h>
+#include <geos/geom/CoordinateSequenceFilter.h>
+#include <geos/util/math.h>
-#include <cstddef>
+#include <cstdint>
+#include <unordered_map>
+#include <array>
#include <vector>
+#include <memory>
-#ifdef _MSC_VER
-#pragma warning(push)
-#pragma warning(disable: 4251) // warning C4251: needs to have dll-interface to be used by clients of class
-#endif
+// Forward declarations
namespace geos {
-namespace algorithm {
-//class RayCrossingCounter;
namespace geom {
class Geometry;
class Coordinate;
-//class CoordinateSequence;
-namespace index {
-namespace intervalrtree {
-//class SortedPackedIntervalRTree;
+class CoordinateSequence;
namespace geos {
namespace algorithm { // geos::algorithm
-namespace distance { // geos::algorithm::distance
+namespace distance { // geos::algorithm::distance
/** \brief
- * An algorithm for computing a distance metric
- * which is an approximation to the Frechet Distance
- * based on a discretization of the input {@link geom::Geometry}.
+ * The Fréchet distance is a measure of similarity between curves. Thus, it can
+ * be used like the Hausdorff distance.
- * The algorithm computes the Frechet distance restricted to discrete points
- * for one of the geometries.
- * The points can be either the vertices of the geometries (the default),
- * or the geometries with line segments densified by a given fraction.
- * Also determines two points of the Geometries which are separated by the
- * computed distance.
+ * An analogy for the Fréchet distance taken from
+ * <a href="http://www.kr.tuwien.ac.at/staff/eiter/et-archive/cdtr9464.pdf">
+ * Computing Discrete Fréchet Distance</a>
- * This algorithm is an approximation to the standard Frechet distance.
- * Specifically,
- * <pre>
- * for all geometries a, b: DFD(a, b) >= FD(a, b)
- * </pre>
- * The approximation can be made as close as needed by densifying the
- * input geometries.
- * In the limit, this value will approach the true Frechet distance:
- * <pre>
- * DFD(A, B, densifyFactor) -> FD(A, B) as densifyFactor -> 0.0
- * </pre>
- * The default approximation is exact or close enough for a large subset of
- * useful cases.
+ * <blockquote>A man is walking a dog on a leash: the man can move
+ * on one curve, the dog on the other; both may vary their
+ * speed, but backtracking is not allowed. </blockquote>
- * The difference between DFD and FD is bounded
- * by the length of the longest edge of the polygonal curves.
+ * Its metric is better than the Hausdorff distance
+ * because it takes the directions of the curves into account.
+ * It is possible that two curves have a small Hausdorff but a large
+ * Fréchet distance.
- * Fréchet distance sweep continuously along their respective curves
- * and the direction of curves is significant.
- * This makes a better measure of similarity than Hausdorff distance.
+ * This implementation is base on the following optimized Fréchet distance algorithm:
+ * Thomas Devogele, Maxence Esnault, Laurent Etienne. Distance discrète de Fréchet optimisée. Spatial
+ * Analysis and Geomatics (SAGEO), Nov 2016, Nice, France. hal-02110055
- * An example showing how different DHD and DFD are:
- * <pre>
- * A = LINESTRING (0 0, 50 200, 100 0, 150 200, 200 0)
- * B = LINESTRING (0 200, 200 150, 0 100, 200 50, 0 0)
- * B' = LINESTRING (0 0, 200 50, 0 100, 200 150, 0 200)
+ * Several matrix storage implementations are provided
- * DHD(A, B) = DHD(A, B') = 48.5071250072666
- * DFD(A, B) = 200
- * DFD(A, B') = 282.842712474619
- * </pre>
+ * * <a href="https://en.wikipedia.org/wiki/Fr%C3%A9chet_distance">Fréchet distance</a>
+ * * <a href="http://www.kr.tuwien.ac.at/staff/eiter/et-archive/cdtr9464.pdf">
+ * * <a href="https://hal.archives-ouvertes.fr/hal-02110055/document">Distance discrète de Fréchet optimisée</a>
+ * * <a href="https://towardsdatascience.com/fast-discrete-fr%C3%A9chet-distance-d6b422a8fb77">
+ * Fast Discrete Fréchet Distance</a>
+ * @see DiscreteHausdorffDistance
class GEOS_DLL DiscreteFrechetDistance {
+ using DistanceToPairMap = std::unordered_map<double, std::array<std::size_t, 2>>;
public:
- static double distance(const geom::Geometry& g0,
- const geom::Geometry& g1);
+ * Creates an instance of this class using the provided geometries.
+ * @param geom0 a geometry
+ * @param geom1 a geometry
+ DiscreteFrechetDistance(const geom::Geometry& geom0, const geom::Geometry& geom1)
+ : g0(geom0)
+ , g1(geom1) {};
- const geom::Geometry& g1, double densifyFrac);
- DiscreteFrechetDistance(const geom::Geometry& p_g0,
- const geom::Geometry& p_g1)
- g0(p_g0),
- g1(p_g1),
- ptDist(),
- densifyFrac(0.0)
- * Sets the fraction by which to densify each segment.
- * Each segment will be (virtually) split into a number of equal-length
- * subsegments, whose fraction of the total length is closest
- * to the given fraction.
- * @param dFrac
+ * Abstract base class for storing 2d matrix data
+ class GEOS_DLL MatrixStorage {
+ public:
+ std::size_t m_numRows;
+ std::size_t m_numCols;
+ double m_defaultValue;
+ * @param numRows the number of rows
+ * @param numCols the number of columns
+ * @param defaultValue A default value
+ MatrixStorage(std::size_t numRows, std::size_t numCols, double defaultValue)
+ : m_numRows(numRows)
+ , m_numCols(numCols)
+ , m_defaultValue(defaultValue) {};
+ virtual ~MatrixStorage() = 0;
+ * Gets the matrix value at i, j
+ * @param i the row index
+ * @param j the column index
+ * @return The matrix value at i, j
+ virtual double get(std::size_t i, std::size_t j) const = 0;
+ * Sets the matrix value at i, j
+ * @param value The matrix value to set at i, j
+ virtual void set(std::size_t i, std::size_t j, double value) = 0;
+ * Gets a flag indicating if the matrix has a set value, e.g. one that is different
+ * than MatrixStorage defaultValue.
+ * @return a flag indicating if the matrix has a set value
+ virtual bool isValueSet(std::size_t i, std::size_t j) const = 0;
+ * Straight forward implementation of a rectangular matrix
+ class RectMatrix : public MatrixStorage {
+ private:
+ std::vector<double> m_matrix;
+ public:
+ * Creates an instance of this matrix using the given number of rows and columns.
+ * A default value can be specified
+ RectMatrix(std::size_t numRows, std::size_t numCols, double defaultValue)
+ : MatrixStorage(numRows, numCols, defaultValue)
+ m_matrix.resize(numRows * numCols, defaultValue);
+ double get(std::size_t i, std::size_t j) const override {
+ return m_matrix[i * m_numCols + j];
+ void set(std::size_t i, std::size_t j, double value) override {
+ m_matrix[i * m_numCols + j] = value;
+ bool isValueSet(std::size_t i, std::size_t j) const override {
+ return get(i, j) != m_defaultValue;
+ * A matrix implementation that adheres to the
+ * <a href="https://en.wikipedia.org/wiki/Sparse_matrix#Compressed_sparse_row_(CSR,_CRS_or_Yale_format)">
+ * Compressed sparse row format</a>.
+ * Note: Unfortunately not as fast as hoped.
+ class CsrMatrix : public MatrixStorage {
+ private:
+ std::vector<double> m_v;
+ std::vector<std::size_t> m_ri;
+ std::vector<std::size_t> m_ci;
+ public:
+ CsrMatrix(std::size_t numRows, std::size_t numCols, double defaultValue, std::size_t expectedValues)
+ m_v.resize(expectedValues);
+ m_ci.resize(expectedValues);
+ m_ri.resize(numRows + 1);
+ CsrMatrix(std::size_t numRows, std::size_t numCols, double defaultValue)
+ : CsrMatrix(numRows, numCols, defaultValue, expectedValuesHeuristic(numRows, numCols))
+ * Computes an initial value for the number of expected values
+ * @return the expected number of values in the sparse matrix
+ static std::size_t expectedValuesHeuristic(std::size_t numRows, std::size_t numCols) {
+ std::size_t max = std::max(numRows, numCols);
+ return max * max / 10;
+ * A work-alike for Java Arrays.binarySearch(), used
+ * for searching ordered arrays. This variant searches
+ * for the key value within a bounded subset of the array.
+ * @param vec the vector to search
+ * @param fromIndex the lower bound index for the search
+ * @param toIndex the upper bound index for the search
+ * @param key the value to hunt for
+ * @return a pair with the first item being true if the key
+ * was found and false otherwise, and the second being the
+ * index of the key found, or the insertion point of the
+ * key if not found
+ std::pair<bool, std::size_t>
+ cppBinarySearch(const std::vector<std::size_t>& vec, std::size_t fromIndex, std::size_t toIndex, std::size_t key) const {
+ // Return not found on invalid input
+ if (fromIndex > toIndex || toIndex > vec.size())
+ return {false, 0};
+ // Define the iterators for the sub-range
+ auto first_it = vec.begin() + static_cast<std::ptrdiff_t>(fromIndex);
+ auto last_it = vec.begin() + static_cast<std::ptrdiff_t>(toIndex);
+ // Perform the binary search using std::lower_bound
+ auto it = std::lower_bound(first_it, last_it, key);
+ // Calculate the index relative to the *beginning of the original vector*
+ auto result_index = std::distance(vec.begin(), it);
+ // Determine if the element was found and return the appropriate value
+ if (it != last_it && *it == key) {
+ // Element found, return its index
+ return {true, result_index};
+ } else {
+ // Element not found, return the insertion point
+ return {false, result_index};
+ std::pair<bool, std::size_t> indexOf(std::size_t i, std::size_t j) const {
+ std::size_t cLow = m_ri[i];
+ std::size_t cHigh = m_ri[i+1];
+ if (cHigh <= cLow) return {false, cLow};
+ return cppBinarySearch(m_ci, cLow, cHigh, j);
+ // get the index in the vector
+ std::pair<bool, std::size_t> vi = indexOf(i, j);
+ // if the vector index is negative, return default value
+ if (!vi.first)
+ return m_defaultValue;
+ return m_v[vi.second];
+ // do we already have a value?
+ if (!vi.first)
+ // no, we don't, we need to ensure space!
+ ensureCapacity(m_ri[m_numRows] + 1);
+ // update row indices
+ for (std::size_t ii = i + 1; ii <= m_numRows; ii++)
+ m_ri[ii] += 1;
+ // move and update column indices, move values
+ std::size_t viv = vi.second;
+ for (std::size_t ii = m_ri[m_numRows]; ii > viv; ii--) {
+ m_ci[ii] = m_ci[ii - 1];
+ m_v[ii] = m_v[ii - 1];
+ // insert column index
+ m_ci[viv] = j;
+ // set the new value
+ m_v[vi.second] = value;
+ auto r = indexOf(i, j);
+ return r.first;
+ * Ensures that the column index vector (m_ci) and value vector (m_v) are sufficiently large.
+ * @param required the number of items to store in the matrix
+ void ensureCapacity(std::size_t required) {
+ if (required < m_v.size())
+ return;
+ std::size_t increment = std::max(m_numRows, m_numCols);
+ m_v.resize(m_v.size() + increment);
+ m_ci.resize(m_v.size() + increment);
+ * A sparse matrix based on java's HashMap.
+ class HashMapMatrix : public MatrixStorage {
+ private:
+ std::unordered_map<std::size_t, double> m_matrix;
+ public:
+ * @param defaultValue a default value
+ HashMapMatrix(std::size_t numRows, std::size_t numCols, double defaultValue)
+ std::size_t key = i << 32 | j;
+ auto it_found = m_matrix.find(key);
+ if (it_found != m_matrix.end()) {
+ return (*it_found).second;
+ else {
+ m_matrix[key] = value;
+ return it_found != m_matrix.end();
+ * Computes the Discrete Fréchet Distance between two Geometrys
+ * using a Cartesian distance computation function.
+ * @param geom0 the 1st geometry
+ * @param geom1 the 2nd geometry
+ * @return the cartesian distance between geom0 and geom1
+ static double distance(const geom::Geometry& geom0, const geom::Geometry& geom1);
+ * @param densityFrac the fraction of edge length to target
+ * when densifying edges
+ static double distance(const geom::Geometry& geom0, const geom::Geometry& geom1, double densityFrac);
+ * Gets the pair of {@link geom::Coordinate}s at which the distance is obtained.
+ * @return the pair of Coordinates at which the distance is obtained
+ std::array<geom::CoordinateXY, 2> getCoordinates();
void setDensifyFraction(double dFrac);
- double
- distance()
- compute(g0, g1);
- return ptDist.getDistance();
- const std::array<geom::CoordinateXY, 2>
- getCoordinates() const
- return ptDist.getCoordinates();
private:
- geom::Coordinate getSegmentAt(const geom::CoordinateSequence& seq, std::size_t index);
- PointPairDistance& getFrechetDistance(std::vector< std::vector<PointPairDistance> >& ca, std::size_t i, std::size_t j,
- const geom::CoordinateSequence& p, const geom::CoordinateSequence& q);
- void compute(const geom::Geometry& discreteGeom, const geom::Geometry& geom);
+ // Members
const geom::Geometry& g0;
const geom::Geometry& g1;
+ std::unique_ptr<PointPairDistance> ptDist;
+ double densifyFraction = -1.0;
- PointPairDistance ptDist;
+ * Computes the {@code Discrete Fréchet Distance} between the input geometries
+ * @return the Discrete Fréchet Distance
+ /* private */
+ double distance();
- /// Value of 0.0 indicates that no densification should take place
- double densifyFrac; // = 0.0;
+ * Utility method to ape Java behaviour
+ void putIfAbsent(
+ DistanceToPairMap& distanceToPair,
+ double key, std::array<std::size_t, 2> val);
- // Declare type as noncopyable
- DiscreteFrechetDistance(const DiscreteFrechetDistance& other) = delete;
- DiscreteFrechetDistance& operator=(const DiscreteFrechetDistance& rhs) = delete;
+ * Creates a matrix to store the computed distances.
+ * @param rows the number of rows
+ * @param cols the number of columns
+ * @return a matrix storage
+ static std::unique_ptr<MatrixStorage> createMatrixStorage(
+ std::size_t rows, std::size_t cols);
+ * Computes the Fréchet Distance for the given distance matrix.
+ * @param coords0 an array of {@code Coordinate}s.
+ * @param coords1 an array of {@code Coordinate}s.
+ * @param diagonal an array of alternating col/row index values for the diagonal of the distance matrix
+ * @param distances the distance matrix
+ * @param distanceToPair a lookup for coordinate pairs based on a distance
+ static std::unique_ptr<PointPairDistance> computeFrechet(
+ const geom::CoordinateSequence& coords0,
+ const geom::CoordinateSequence& coords1,
+ std::vector<std::size_t>& diagonal,
+ MatrixStorage& distances,
+ DistanceToPairMap& distanceToPair);
+ * Returns the minimum distance at the corner ({@code i, j}).
+ * @param matrix A sparse matrix
+ * @param i the column index
+ * @param j the row index
+ * @return the minimum distance
+ /* private */
+ static double getMinDistanceAtCorner(
+ MatrixStorage& matrix, std::size_t i, std::size_t j);
+ * Computes relevant distances between pairs of {@link Coordinate}s for the
+ * computation of the {@code Discrete Fréchet Distance}.
+ void computeCoordinateDistances(
+ const geom::CoordinateSequence& coords0, const geom::CoordinateSequence& coords1,
+ MatrixStorage& distances, DistanceToPairMap& distanceToPair);
+ * Computes the indices for the diagonal of a {@code numCols x numRows} grid
+ * using the <a href=https://en.wikipedia.org/wiki/Bresenham%27s_line_algorithm>
+ * Bresenham line algorithm</a>.
+ * @return a packed array of column and row indices
+ static std::vector<std::size_t> bresenhamDiagonal(
+ std::size_t numCols, std::size_t numRows);
+ * @param geom the geometry to densify
+ * @param densifyFrac the amount to split up edges
+ * @return a coordinate sequence of every vertex and all introduced
+ * densified vertices for the geometry
+ static std::unique_ptr<geom::CoordinateSequence> getDensifiedCoordinates(
+ const geom::Geometry& geom, double densifyFrac);
+ class DensifiedCoordinatesFilter : public geom::CoordinateSequenceFilter {
+ public:
+ DensifiedCoordinatesFilter(double fraction, geom::CoordinateSequence& coords)
+ : m_numSubSegs(static_cast<uint32_t>(util::round(1.0 / fraction)))
+ , m_coords(coords)
+ void filter_ro(
+ const geom::CoordinateSequence& seq,
+ std::size_t index) override;
+ bool isGeometryChanged() const override {
+ return false;
+ bool isDone() const override {
+ return false;
+ private:
+ uint32_t m_numSubSegs;
+ geom::CoordinateSequence& m_coords;
+}; // DiscreteFrechetDistance
} // geos::algorithm::distance
} // geos
-#ifdef _MSC_VER
-#pragma warning(pop)
-#endif
diff --git a/include/geos/algorithm/distance/PointPairDistance.h b/include/geos/algorithm/distance/PointPairDistance.h
index 7589abbef..35aa135d0 100644
--- a/include/geos/algorithm/distance/PointPairDistance.h
+++ b/include/geos/algorithm/distance/PointPairDistance.h
@@ -120,13 +120,11 @@ public:
return isNull;
-private:
* Initializes the points, avoiding recomputing the distance.
* @param p0
* @param p1
- * @param dist the distance between p0 and p1
+ * @param distSquared the squared distance between p0 and p1
void
initialize(const geom::CoordinateXY& p0, const geom::CoordinateXY& p1,
@@ -138,14 +136,14 @@ private:
isNull = false;
+private:
std::array<geom::CoordinateXY, 2> pt;
double distanceSquared;
bool isNull;
} // geos
diff --git a/src/algorithm/distance/DiscreteFrechetDistance.cpp b/src/algorithm/distance/DiscreteFrechetDistance.cpp
index 99a650f19..4fa6d0f50 100644
--- a/src/algorithm/distance/DiscreteFrechetDistance.cpp
+++ b/src/algorithm/distance/DiscreteFrechetDistance.cpp
@@ -3,171 +3,369 @@
- * Copyright (C) 2016 Shinichi SUGIYAMA <shin.sugi at gmail.com>
#include <geos/algorithm/distance/DiscreteFrechetDistance.h>
+#include <geos/geom/Coordinate.h>
-#include <geos/geom/LineString.h>
+#include <geos/util/IllegalStateException.h>
+#include <geos/util/IllegalArgumentException.h>
+#include <geos/util.h>
+#include <geos/util/Interrupt.h>
-#include <typeinfo>
-#include <cassert>
-#include <vector>
-#include <algorithm>
-#include <limits>
-#include <iostream>
-#include "geos/util.h"
-using namespace geos::geom;
+using geos::geom::Geometry;
+using geos::geom::CoordinateSequence;
+using geos::geom::CoordinateXY;
namespace geos {
namespace algorithm { // geos.algorithm
-namespace distance { // geos.algorithm.distance
+namespace distance { // geos.algorithm.distance
-/* static public */
+/* public static */
double
-DiscreteFrechetDistance::distance(const geom::Geometry& g0,
+DiscreteFrechetDistance::distance(const Geometry& geom0, const Geometry& geom1)
- DiscreteFrechetDistance dist(g0, g1);
+ DiscreteFrechetDistance dist(geom0, geom1);
return dist.distance();
double
- double densifyFrac)
+DiscreteFrechetDistance::distance(const Geometry& geom0, const Geometry& geom1, double densityFrac)
- dist.setDensifyFraction(densifyFrac);
+ dist.setDensifyFraction(densityFrac);
+/* private */
+double
+DiscreteFrechetDistance::distance()
+ if (g0.isEmpty() || g1.isEmpty()) {
+ throw util::IllegalArgumentException(
+ "DiscreteFrechetDistance called with empty inputs.");
+ util::ensureNoCurvedComponents(g0);
+ util::ensureNoCurvedComponents(g1);
+ std::unique_ptr<CoordinateSequence> coords0;
+ std::unique_ptr<CoordinateSequence> coords1;
+ if (densifyFraction < 0) {
+ coords0 = g0.getCoordinates();
+ coords1 = g1.getCoordinates();
+ else {
+ coords0 = getDensifiedCoordinates(g0, densifyFraction);
+ coords1 = getDensifiedCoordinates(g1, densifyFraction);
+ std::unique_ptr<MatrixStorage> distances = createMatrixStorage(coords0->size(), coords1->size());
+ std::vector<std::size_t> diagonal = bresenhamDiagonal(coords0->size(), coords1->size());
+ DistanceToPairMap distanceToPair;
+ computeCoordinateDistances(*coords0, *coords1, diagonal, *distances, distanceToPair);
+ ptDist = computeFrechet(*coords0, *coords1, diagonal, *distances, distanceToPair);
+ return ptDist->getDistance();
/* public */
-void DiscreteFrechetDistance::setDensifyFraction(double dFrac)
+void
+DiscreteFrechetDistance::setDensifyFraction(double dFrac)
- // !(dFrac > 0) written that way to catch NaN
- // and test on 1.0/dFrac to avoid a potential later undefined behaviour
- // when casting to std::size_t
- if(dFrac > 1.0 || !(dFrac > 0.0) ||
- util::round(1.0 / dFrac) >
- static_cast<double>(std::numeric_limits<std::size_t>::max())) {
+ // Densifying too far is too CPU intensive, and
+ // we also want to catching NaN and other out-of-range
+ // values here.
+ if (std::isnan(dFrac) || dFrac > 1.0 || dFrac <= 0.001) {
- "Fraction is not in range (0.0 - 1.0]");
+ "Fraction is not in range (0.001 - 1.0]");
- densifyFrac = dFrac;
-/* private */
-geom::Coordinate
-DiscreteFrechetDistance::getSegmentAt(const CoordinateSequence& seq, std::size_t index)
- if(densifyFrac > 0.0) {
- // Validity of the cast to size_t has been verified in setDensifyFraction()
- std::size_t numSubSegs = std::size_t(util::round(1.0 / densifyFrac));
- std::size_t i = index / numSubSegs;
- std::size_t j = index % numSubSegs;
- if(i >= seq.size() - 1) {
- return seq.getAt(seq.size() - 1);
- const geom::Coordinate& p0 = seq.getAt(i);
- const geom::Coordinate& p1 = seq.getAt(i + 1);
- double delx = (p1.x - p0.x) / static_cast<double>(numSubSegs);
- double dely = (p1.y - p0.y) / static_cast<double>(numSubSegs);
- double x = p0.x + static_cast<double>(j) * delx;
- double y = p0.y + static_cast<double>(j) * dely;
- Coordinate pt(x, y);
- return pt;
- else {
- return seq.getAt(index);
-PointPairDistance&
-DiscreteFrechetDistance::getFrechetDistance(std::vector< std::vector<PointPairDistance> >& ca, std::size_t i, std::size_t j,
- const CoordinateSequence& p, const CoordinateSequence& q)
- PointPairDistance p_ptDist;
- if(! ca[i][j].getIsNull()) {
- return ca[i][j];
- p_ptDist.initialize(getSegmentAt(p, i), getSegmentAt(q, j));
- if(i == 0 && j == 0) {
- ca[i][j] = p_ptDist;
- else if(i > 0 && j == 0) {
- PointPairDistance nextDist = getFrechetDistance(ca, i - 1, 0, p, q);
- ca[i][j] = (nextDist.getDistance() > p_ptDist.getDistance()) ? nextDist : p_ptDist;
- else if(i == 0 && j > 0) {
- PointPairDistance nextDist = getFrechetDistance(ca, 0, j - 1, p, q);
- else {
- PointPairDistance d1 = getFrechetDistance(ca, i - 1, j, p, q),
- d2 = getFrechetDistance(ca, i - 1, j - 1, p, q),
- d3 = getFrechetDistance(ca, i, j - 1, p, q);
- PointPairDistance& minDist = (d1.getDistance() < d2.getDistance()) ? d1 : d2;
- if(d3.getDistance() < minDist.getDistance()) {
- minDist = d3;
- ca[i][j] = (minDist.getDistance() > p_ptDist.getDistance()) ? minDist : p_ptDist;
- return ca[i][j];
+ densifyFraction = dFrac;
void
-DiscreteFrechetDistance::compute(
- const geom::Geometry& discreteGeom,
- const geom::Geometry& geom)
+DiscreteFrechetDistance::putIfAbsent(
- if (discreteGeom.isEmpty() || geom.isEmpty()) {
- throw util::IllegalArgumentException("DiscreteFrechetDistance called with empty inputs.");
- util::ensureNoCurvedComponents(discreteGeom);
- util::ensureNoCurvedComponents(geom);
- auto lp = discreteGeom.getCoordinates();
- auto lq = geom.getCoordinates();
- std::size_t pSize, qSize;
- if(densifyFrac > 0) {
- pSize = numSubSegs * (lp->size() - 1) + 1;
- qSize = numSubSegs * (lq->size() - 1) + 1;
- else {
- pSize = lp->size();
- qSize = lq->size();
- std::vector< std::vector<PointPairDistance> > ca(pSize, std::vector<PointPairDistance>(qSize));
- for(std::size_t i = 0; i < pSize; i++) {
- for(std::size_t j = 0; j < qSize; j++) {
- ca[i][j].initialize();
- ptDist = getFrechetDistance(ca, pSize - 1, qSize - 1, *lp, *lq);
+ auto it = distanceToPair.find(key);
+ if (it == distanceToPair.end())
+ distanceToPair[key] = val;
-} // namespace geos.algorithm.distance
+/* private static */
+std::unique_ptr<DiscreteFrechetDistance::MatrixStorage>
+DiscreteFrechetDistance::createMatrixStorage(std::size_t rows, std::size_t cols)
+ std::size_t max = std::max(rows, cols);
+ double inf = std::numeric_limits<double>::infinity();
+ // NOTE: these constraints need to be verified
+ if (max < 1024)
+ return std::make_unique<RectMatrix>(rows, cols, inf);
+ return std::make_unique<CsrMatrix>(rows, cols, inf);
+/* public */
+std::array<CoordinateXY, 2>
+DiscreteFrechetDistance::getCoordinates()
+ if (ptDist == nullptr)
+ distance();
+ return ptDist->getCoordinates();
+std::unique_ptr<PointPairDistance>
+DiscreteFrechetDistance::computeFrechet(
+ const CoordinateSequence& coords0, const CoordinateSequence& coords1,
+ for (std::size_t d = 0; d < diagonal.size(); d += 2) {
+ std::size_t i0 = diagonal[d];
+ std::size_t j0 = diagonal[d + 1];
+ GEOS_CHECK_FOR_INTERRUPTS();
+ for (std::size_t i = i0; i < coords0.size(); i++) {
+ if (distances.isValueSet(i, j0)) {
+ double dist = getMinDistanceAtCorner(distances, i, j0);
+ if (dist > distances.get(i, j0))
+ distances.set(i, j0, dist);
+ else {
+ break;
+ for (std::size_t j = j0 + 1; j < coords1.size(); j++) {
+ if (distances.isValueSet(i0, j)) {
+ double dist = getMinDistanceAtCorner(distances, i0, j);
+ if (dist > distances.get(i0, j))
+ distances.set(i0, j, dist);
+ else {
+ break;
+ double distance = distances.get(coords0.size()-1, coords1.size()-1);
+ auto it = distanceToPair.find(distance);
+ if (it == distanceToPair.end()) {
+ throw geos::util::IllegalStateException("Pair of points not recorded for computed distance");
+ std::array<std::size_t, 2> index = (*it).second;
+ const CoordinateXY& c0 = coords0.getAt(index[0]);
+ const CoordinateXY& c1 = coords1.getAt(index[1]);
+ auto result = std::make_unique<PointPairDistance>();
+ result->initialize(c0, c1, distance * distance);
+ return result;
+double
+DiscreteFrechetDistance::getMinDistanceAtCorner(MatrixStorage& matrix, std::size_t i, std::size_t j)
+ if (i > 0 && j > 0) {
+ double d0 = matrix.get(i - 1, j - 1);
+ double d1 = matrix.get(i - 1, j);
+ double d2 = matrix.get(i, j - 1);
+ return std::min(std::min(d0, d1), d2);
+ if (i == 0 && j == 0)
+ return matrix.get(0, 0);
+ if (i == 0)
+ return matrix.get(0, j - 1);
+ // j == 0
+ return matrix.get(i - 1, 0);
+/* private */
+void
+DiscreteFrechetDistance::computeCoordinateDistances(
+ std::size_t numDiag = diagonal.size();
+ double maxDistOnDiag = 0.0;
+ std::size_t imin = 0, jmin = 0;
+ std::size_t numCoords0 = coords0.size();
+ std::size_t numCoords1 = coords1.size();
+ // First compute all the distances along the diagonal.
+ // Record the maximum distance.
+ for (std::size_t k = 0; k < numDiag; k += 2) {
+ std::size_t i0 = diagonal[k];
+ std::size_t j0 = diagonal[k + 1];
+ double diagDist = coords0[i0].distance(coords1[j0]);
+ if (diagDist > maxDistOnDiag) maxDistOnDiag = diagDist;
+ distances.set(i0, j0, diagDist);
+ // TBD convert to std::map
+ putIfAbsent(distanceToPair, diagDist, {i0, j0});
+ // Check for distances shorter than maxDistOnDiag along the diagonal
+ for (std::size_t k = 0; k < numDiag - 2; k += 2) {
+ // Decode index
+ // Get reference coordinates for col and row
+ const CoordinateXY& coord0 = coords0.getAt(i0);
+ const CoordinateXY& coord1 = coords1.getAt(j0);
+ // Check for shorter distances in this row
+ std::size_t i = i0 + 1;
+ for (; i < numCoords0; i++) {
+ if (!distances.isValueSet(i, j0)) {
+ double dist = coords0[i].distance(coord1);
+ if (dist < maxDistOnDiag || i < imin) {
+ putIfAbsent(distanceToPair, dist, {i, j0});
+ else {
+ break;
+ else {
+ break;
+ imin = i;
+ // Check for shorter distances in this column
+ std::size_t j = j0 + 1;
+ for (; j < numCoords1; j++) {
+ if (!distances.isValueSet(i0, j)) {
+ double dist = coord0.distance(coords1[j]);
+ if (dist < maxDistOnDiag || j < jmin)
+ putIfAbsent(distanceToPair, dist, {i0, j});
+ else
+ break;
+ else {
+ break;
+ jmin = j;
+/* static */
+std::vector<std::size_t>
+DiscreteFrechetDistance::bresenhamDiagonal(std::size_t numCols, std::size_t numRows)
+ std::size_t dim = std::max(numCols, numRows);
+ std::vector<std::size_t> diagXY;
+ diagXY.reserve(2 * dim);
+ int64_t dx = static_cast<int64_t>(numCols) - 1;
+ int64_t dy = static_cast<int64_t>(numRows) - 1;
+ int64_t err;
+ if (numCols > numRows) {
+ std::size_t y = 0;
+ err = 2 * dy - dx;
+ for (std::size_t x = 0; x < numCols; x++) {
+ diagXY.push_back(x);
+ diagXY.push_back(y);
+ if (err > 0) {
+ y += 1;
+ err -= 2 * dx;
+ err += 2 * dy;
+ else {
+ std::size_t x = 0;
+ err = 2 * dx - dy;
+ for (std::size_t y = 0; y < numRows; y++) {
+ if (err > 0) {
+ x += 1;
+ err -= 2 * dy;
+ err += 2 * dx;
+ return diagXY;
+std::unique_ptr<CoordinateSequence>
+DiscreteFrechetDistance::getDensifiedCoordinates(const Geometry& geom, double densifyFrac)
+ auto coords = std::make_unique<CoordinateSequence>();
+ DensifiedCoordinatesFilter dcf(densifyFrac, *coords);
+ geom.apply_ro(dcf);
+ return coords;
+void
+DiscreteFrechetDistance::DensifiedCoordinatesFilter::filter_ro(
+ const geom::CoordinateSequence& seq, std::size_t index)
+ // Skip the first coordinate so we can operate an edge
+ // at a time
+ if (index == 0)
+ return;
+ const geom::Coordinate& p0 = seq.getAt(index - 1);
+ const geom::Coordinate& p1 = seq.getAt(index);
+ double dx = (p1.x - p0.x) / m_numSubSegs;
+ double dy = (p1.y - p0.y) / m_numSubSegs;
+ for(uint32_t i = 0; i < m_numSubSegs; i++) {
+ geom::CoordinateXY pt(p0.x + i * dx, p0.y + i * dy);
+ m_coords.add(pt, true); // allowRepeated
+ // Include the final point in the sequence
+ if (index == seq.size() - 1)
+ m_coords.add(p1, true); // allowRepeated
+/* Implementation of pure virtual destructor for C++ */
+DiscreteFrechetDistance::MatrixStorage::~MatrixStorage() {}
diff --git a/tests/unit/algorithm/distance/DiscreteFrechetDistanceData.h b/tests/unit/algorithm/distance/DiscreteFrechetDistanceData.h
new file mode 100644
index 000000000..db82ddab7
--- /dev/null
+++ b/tests/unit/algorithm/distance/DiscreteFrechetDistanceData.h
@@ -0,0 +1,5559 @@
+#define LS1 "LINESTRING (" \
+ "7.619528 47.506634," \
+ "7.619552 47.50662," \
+ "7.61957 47.50661," \
+ "7.619595 47.50659," \
+ "7.61962 47.506588," \
+ "7.619643 47.506584," \
+ "7.619667 47.506573," \
+ "7.6197 47.506573," \
+ "7.619728 47.50657," \
+ "7.619772 47.50658," \
+ "7.619795 47.50658," \
+ "7.619822 47.506577," \
+ "7.619845 47.506577," \
+ "7.619875 47.50658," \
+ "7.619908 47.506577," \
+ "7.619948 47.50658," \
+ "7.619985 47.50658," \
+ "7.620023 47.50658," \
+ "7.620057 47.506577," \
+ "7.620085 47.506577," \
+ "7.620115 47.506573," \
+ "7.620145 47.50657," \
+ "7.62017 47.506565," \
+ "7.620195 47.50656," \
+ "7.620223 47.506557," \
+ "7.620248 47.506554," \
+ "7.620275 47.50655," \
+ "7.620305 47.506546," \
+ "7.620338 47.506542," \
+ "7.620365 47.506535," \
+ "7.620382 47.50654," \
+ "7.620407 47.506542," \
+ "7.620433 47.50655," \
+ "7.620463 47.506542," \
+ "7.620485 47.50653," \
+ "7.620517 47.506527," \
+ "7.620547 47.50652," \
+ "7.620573 47.5065," \
+ "7.6206 47.506493," \
+ "7.620625 47.506477," \
+ "7.620643 47.506462," \
+ "7.620665 47.50645," \
+ "7.62069 47.50643," \
+ "7.620708 47.506405," \
+ "7.62072 47.506382," \
+ "7.620728 47.506363," \
+ "7.620738 47.506336," \
+ "7.620745 47.506313," \
+ "7.620752 47.506294," \
+ "7.620757 47.50627," \
+ "7.620765 47.50625," \
+ "7.62076 47.506214," \
+ "7.620755 47.506184," \
+ "7.62075 47.50614," \
+ "7.620737 47.506104," \
+ "7.620742 47.506073," \
+ "7.620755 47.50604," \
+ "7.62076 47.50601," \
+ "7.620752 47.505978," \
+ "7.620742 47.505947," \
+ "7.620737 47.505913," \
+ "7.620732 47.505882," \
+ "7.620733 47.50585," \
+ "7.620743 47.50583," \
+ "7.620743 47.5058," \
+ "7.620745 47.505768," \
+ "7.620752 47.505733," \
+ "7.620758 47.5057," \
+ "7.620778 47.505672," \
+ "7.620795 47.50565," \
+ "7.620805 47.505615," \
+ "7.620812 47.50559," \
+ "7.620812 47.50556," \
+ "7.620818 47.50553," \
+ "7.620822 47.5055," \
+ "7.620838 47.50547," \
+ "7.62085 47.50544," \
+ "7.620847 47.505398," \
+ "7.620855 47.505375," \
+ "7.62086 47.50535," \
+ "7.620858 47.50532," \
+ "7.62086 47.505295," \
+ "7.62086 47.505264," \
+ "7.620862 47.505238," \
+ "7.620867 47.505215," \
+ "7.620872 47.50519," \
+ "7.62088 47.505165," \
+ "7.620897 47.50514," \
+ "7.620905 47.50512," \
+ "7.620922 47.505096," \
+ "7.62095 47.505074," \
+ "7.620973 47.505054," \
+ "7.621002 47.50503," \
+ "7.621022 47.50501," \
+ "7.621042 47.50498," \
+ "7.62106 47.504955," \
+ "7.621077 47.50493," \
+ "7.621093 47.5049," \
+ "7.621117 47.50488," \
+ "7.621138 47.50486," \
+ "7.621165 47.504845," \
+ "7.62119 47.504826," \
+ "7.621218 47.504807," \
+ "7.62124 47.504784," \
+ "7.621267 47.50476," \
+ "7.621297 47.504734," \
+ "7.62133 47.50471," \
+ "7.621368 47.50469," \
+ "7.621392 47.504673," \
+ "7.621413 47.50466," \
+ "7.62144 47.504646," \
+ "7.621468 47.50463," \
+ "7.621502 47.504612," \
+ "7.621525 47.504585," \
+ "7.621545 47.50456," \
+ "7.62156 47.50453," \
+ "7.621575 47.50451," \
+ "7.62159 47.504486," \
+ "7.62161 47.504467," \
+ "7.621637 47.50445," \
+ "7.621657 47.504433," \
+ "7.621683 47.504414," \
+ "7.621702 47.5044," \
+ "7.62172 47.50438," \
+ "7.621742 47.504364," \
+ "7.621767 47.50435," \
+ "7.621798 47.504333," \
+ "7.62183 47.50432," \
+ "7.621858 47.504295," \
+ "7.621887 47.50428," \
+ "7.621918 47.504265," \
+ "7.621943 47.504246," \
+ "7.621963 47.50423," \
+ "7.621982 47.50421," \
+ "7.622 47.50419," \
+ "7.622023 47.504173," \
+ "7.622057 47.50416," \
+ "7.622087 47.504147," \
+ "7.62212 47.50413," \
+ "7.622143 47.504116," \
+ "7.622173 47.5041," \
+ "7.62221 47.50409," \
+ "7.62224 47.50407," \
+ "7.62227 47.50405," \
+ "7.622302 47.50404," \
+ "7.622332 47.504025," \
+ "7.62236 47.504013," \
+ "7.622388 47.503994," \
+ "7.622418 47.50398," \
+ "7.622447 47.503963," \
+ "7.62247 47.50394," \
+ "7.622497 47.50392," \
+ "7.622525 47.5039," \
+ "7.622553 47.50388," \
+ "7.622578 47.503857," \
+ "7.622602 47.503838," \
+ "7.622622 47.503815," \
+ "7.622645 47.50379," \
+ "7.622668 47.503773," \
+ "7.622695 47.503754," \
+ "7.622723 47.503735," \
+ "7.622752 47.503716," \
+ "7.622787 47.503696," \
+ "7.622822 47.50368," \
+ "7.622858 47.503666," \
+ "7.622892 47.503647," \
+ "7.622923 47.503624," \
+ "7.622962 47.503605," \
+ "7.623003 47.503593," \
+ "7.62303 47.503574," \
+ "7.623058 47.503563," \
+ "7.623098 47.50355," \
+ "7.62314 47.503548," \
+ "7.623173 47.503536," \
+ "7.623203 47.503525," \
+ "7.623225 47.50351," \
+ "7.62325 47.503494," \
+ "7.623277 47.50348," \
+ "7.623307 47.503464," \
+ "7.623332 47.50345," \
+ "7.623357 47.50343," \
+ "7.623377 47.50341," \
+ "7.623403 47.50339," \
+ "7.623427 47.503376," \
+ "7.623455 47.50336," \
+ "7.623485 47.503345," \
+ "7.62351 47.503338," \
+ "7.623532 47.503323," \
+ "7.623557 47.503307," \
+ "7.623582 47.503292," \
+ "7.62361 47.50328," \
+ "7.623645 47.503273," \
+ "7.623682 47.50326," \
+ "7.623713 47.503246," \
+ "7.623752 47.50324," \
+ "7.623785 47.50323," \
+ "7.62382 47.50323," \
+ "7.623858 47.503242," \
+ "7.623882 47.503242," \
+ "7.623893 47.503242," \
+ "7.623907 47.503246," \
+ "7.623918 47.503258," \
+ "7.62392 47.503273," \
+ "7.623925 47.503292," \
+ "7.623937 47.503307," \
+ "7.623938 47.503326," \
+ "7.623937 47.50334," \
+ "7.623928 47.50336," \
+ "7.623923 47.503384," \
+ "7.623922 47.503407," \
+ "7.62391 47.503426," \
+ "7.623893 47.50345," \
+ "7.623863 47.503464," \
+ "7.623835 47.503487," \
+ "7.623803 47.50351," \
+ "7.623772 47.50353," \
+ "7.623747 47.50355," \
+ "7.623725 47.50357," \
+ "7.623702 47.503593," \
+ "7.623677 47.503616," \
+ "7.623657 47.503643," \
+ "7.623632 47.503666," \
+ "7.623605 47.503685," \
+ "7.623572 47.5037," \
+ "7.623533 47.50371," \
+ "7.623497 47.503727," \
+ "7.62347 47.503735," \
+ "7.623448 47.503742," \
+ "7.623427 47.50376," \
+ "7.623407 47.503784," \
+ "7.623383 47.503803," \
+ "7.623363 47.503822," \
+ "7.623342 47.50384," \
+ "7.623322 47.50386," \
+ "7.6233 47.503876," \
+ "7.623282 47.50389," \
+ "7.623263 47.503914," \
+ "7.623242 47.503937," \
+ "7.623217 47.50396," \
+ "7.623192 47.50398," \
+ "7.623168 47.503998," \
+ "7.62315 47.504013," \
+ "7.62313 47.504032," \
+ "7.623103 47.50405," \
+ "7.623078 47.504074," \
+ "7.623058 47.504097," \
+ "7.62304 47.504124," \
+ "7.623018 47.504147," \
+ "7.623005 47.504173," \
+ "7.622997 47.504196," \
+ "7.62299 47.504223," \
+ "7.62298 47.50425," \
+ "7.622973 47.504276," \
+ "7.622967 47.504314," \
+ "7.622957 47.50435," \
+ "7.622942 47.50438," \
+ "7.622927 47.504414," \
+ "7.62292 47.504448," \
+ "7.622915 47.50448," \
+ "7.622907 47.50451," \
+ "7.622893 47.50454," \
+ "7.622888 47.50457," \
+ "7.622888 47.504604," \
+ "7.622872 47.50463," \
+ "7.622848 47.504654," \
+ "7.62283 47.50468," \
+ "7.622817 47.504707," \
+ "7.62281 47.50473," \
+ "7.6228 47.504757," \
+ "7.622785 47.504784," \
+ "7.622768 47.50481," \
+ "7.62275 47.504837," \
+ "7.62274 47.504868," \
+ "7.622723 47.504887," \
+ "7.622718 47.504917," \
+ "7.622707 47.504948," \
+ "7.622695 47.50498," \
+ "7.62269 47.505," \
+ "7.622683 47.505028," \
+ "7.622678 47.50505," \
+ "7.622677 47.505077," \
+ "7.622675 47.5051," \
+ "7.622673 47.505123," \
+ "7.622673 47.505154," \
+ "7.622672 47.50519," \
+ "7.62267 47.505226," \
+ "7.622668 47.505257," \
+ "7.622675 47.505283," \
+ "7.622677 47.505302," \
+ "7.62268 47.50533," \
+ "7.622677 47.50535," \
+ "7.622668 47.505367," \
+ "7.622663 47.505394," \
+ "7.62266 47.505424," \
+ "7.622658 47.505447," \
+ "7.622653 47.505486," \
+ "7.62266 47.50552," \
+ "7.622677 47.505566," \
+ "7.622678 47.505596," \
+ "7.622678 47.505627," \
+ "7.622682 47.505653," \
+ "7.622695 47.505672," \
+ "7.622717 47.50569," \
+ "7.622758 47.505722," \
+ "7.622795 47.505733," \
+ "7.622827 47.505737," \
+ "7.622862 47.505753," \
+ "7.622903 47.505768," \
+ "7.622942 47.50578," \
+ "7.622968 47.505783," \
+ "7.623 47.505787," \
+ "7.623028 47.50578," \
+ "7.623058 47.50577," \
+ "7.62309 47.50576," \
+ "7.623127 47.505753," \
+ "7.62316 47.50574," \
+ "7.623192 47.505733," \
+ "7.623227 47.50573," \
+ "7.623258 47.50572," \
+ "7.623285 47.505703," \
+ "7.62331 47.50569," \
+ "7.623337 47.505684," \
+ "7.623363 47.505672," \
+ "7.623392 47.505657," \
+ "7.62342 47.505642," \
+ "7.623452 47.50563," \
+ "7.623482 47.505623," \
+ "7.623505 47.50561," \
+ "7.623523 47.505596," \
+ "7.623545 47.50559," \
+ "7.62357 47.505577," \
+ "7.623598 47.50556," \
+ "7.623637 47.505547," \
+ "7.623672 47.50553," \
+ "7.623697 47.505512," \
+ "7.623717 47.5055," \
+ "7.623748 47.505493," \
+ "7.623783 47.50549," \
+ "7.623828 47.50549," \
+ "7.623873 47.505486," \
+ "7.623908 47.505478," \
+ "7.623942 47.505466," \
+ "7.623968 47.505455," \
+ "7.623993 47.505444," \
+ "7.624015 47.505432," \
+ "7.62404 47.50542," \
+ "7.62407 47.50541," \
+ "7.624097 47.505398," \
+ "7.624125 47.505383," \
+ "7.624155 47.50537," \
+ "7.62418 47.50536," \
+ "7.62421 47.50535," \
+ "7.624243 47.505337," \
+ "7.624278 47.505318," \
+ "7.624312 47.505302," \
+ "7.624338 47.505287," \
+ "7.624372 47.505272," \
+ "7.62441 47.50526," \
+ "7.62446 47.50525," \
+ "7.624505 47.505238," \
+ "7.624532 47.505222," \
+ "7.624567 47.505215," \
+ "7.624593 47.5052," \
+ "7.624625 47.50519," \
+ "7.624653 47.505177," \
+ "7.62468 47.505165," \
+ "7.624702 47.505146," \
+ "7.624715 47.505123," \
+ "7.624738 47.5051," \
+ "7.624758 47.50508," \
+ "7.624777 47.505062," \
+ "7.62479 47.505047," \
+ "7.624807 47.505028," \
+ "7.624838 47.50501," \
+ "7.624862 47.504986," \
+ "7.62489 47.504963," \
+ "7.624907 47.504944," \
+ "7.624922 47.50492," \
+ "7.624933 47.504898," \
+ "7.624947 47.50487," \
+ "7.624957 47.504852," \
+ "7.624967 47.50483," \
+ "7.624975 47.50481," \
+ "7.62498 47.50479," \
+ "7.62499 47.504776," \
+ "7.625028 47.504753," \
+ "7.625058 47.504745," \
+ "7.625085 47.50473," \
+ "7.625108 47.50472," \
+ "7.625127 47.504704," \
+ "7.625148 47.504684," \
+ "7.625165 47.50467," \
+ "7.625185 47.504654," \
+ "7.62521 47.504642," \
+ "7.625233 47.504627," \
+ "7.625255 47.504616," \
+ "7.625282 47.504604," \
+ "7.625308 47.50459," \
+ "7.625337 47.504574," \
+ "7.625362 47.50456," \
+ "7.62539 47.504547," \
+ "7.625423 47.504536," \
+ "7.625452 47.504517," \
+ "7.625463 47.504486," \
+ "7.625502 47.50448," \
+ "7.625525 47.504467," \
+ "7.625552 47.504456," \
+ "7.625582 47.50445," \
+ "7.625612 47.504444," \
+ "7.625652 47.504444," \
+ "7.625683 47.504444," \
+ "7.625708 47.504444," \
+ "7.625725 47.50444," \
+ "7.625737 47.504448," \
+ "7.625752 47.50446," \
+ "7.625757 47.504475," \
+ "7.625763 47.50449," \
+ "7.625772 47.5045," \
+ "7.625782 47.50452," \
+ "7.625787 47.504536," \
+ "7.625783 47.50455," \
+ "7.62578 47.504574," \
+ "7.625772 47.504597," \
+ "7.625757 47.504616," \
+ "7.625743 47.50464," \
+ "7.625727 47.50466," \
+ "7.62571 47.504684," \
+ "7.625692 47.50471," \
+ "7.62569 47.504738," \
+ "7.625692 47.504765," \
+ "7.625697 47.504787," \
+ "7.625703 47.504807," \
+ "7.625702 47.504833," \
+ "7.625707 47.504856," \
+ "7.625715 47.50488," \
+ "7.625715 47.504906," \
+ "7.625722 47.50493," \
+ "7.625728 47.504948," \
+ "7.62573 47.50497," \
+ "7.625742 47.505," \
+ "7.625747 47.50503," \
+ "7.625758 47.50506," \
+ "7.625778 47.505093," \
+ "7.625793 47.505116," \
+ "7.625805 47.50514," \
+ "7.625808 47.50516," \
+ "7.625818 47.505188," \
+ "7.625837 47.505215," \
+ "7.625847 47.505238," \
+ "7.625857 47.505272," \
+ "7.62587 47.505306," \
+ "7.62588 47.50533," \
+ "7.625887 47.505352," \
+ "7.62589 47.50538," \
+ "7.625893 47.505398," \
+ "7.625902 47.505417," \
+ "7.625912 47.505436," \
+ "7.625923 47.505455," \
+ "7.62594 47.50548," \
+ "7.625955 47.50551," \
+ "7.625967 47.50554," \
+ "7.625982 47.505573," \
+ "7.626 47.505604," \
+ "7.62601 47.505627," \
+ "7.626022 47.505657," \
+ "7.626033 47.505684," \
+ "7.626048 47.50571," \
+ "7.626072 47.50574," \
+ "7.626092 47.50578," \
+ "7.626105 47.50581," \
+ "7.626118 47.505844," \
+ "7.626133 47.50588," \
+ "7.62615 47.505913," \
+ "7.626173 47.505943," \
+ "7.6262 47.505974," \
+ "7.626233 47.50601," \
+ "7.626257 47.50603," \
+ "7.626282 47.50605," \
+ "7.626308 47.50607," \
+ "7.626335 47.50609," \
+ "7.626363 47.506104," \
+ "7.626393 47.506123," \
+ "7.62642 47.506138," \
+ "7.626453 47.506153," \
+ "7.626492 47.50617," \
+ "7.626533 47.50618," \
+ "7.626578 47.50619," \
+ "7.626623 47.506195," \
+ "7.626658 47.50619," \
+ "7.626693 47.50618," \
+ "7.626725 47.50617," \
+ "7.626758 47.506157," \
+ "7.626788 47.50615," \
+ "7.626817 47.506134," \
+ "7.62684 47.50612," \
+ "7.62686 47.506104," \
+ "7.62687 47.506077," \
+ "7.62689 47.50606," \
+ "7.626918 47.50605," \
+ "7.626957 47.50605," \
+ "7.626995 47.506046," \
+ "7.627022 47.506035," \
+ "7.627047 47.506016," \
+ "7.627077 47.506004," \
+ "7.627102 47.505993," \
+ "7.627128 47.50598," \
+ "7.627152 47.505974," \
+ "7.62718 47.505974," \
+ "7.627207 47.505962," \
+ "7.627233 47.505947," \
+ "7.627257 47.50593," \
+ "7.627278 47.505917," \
+ "7.627298 47.5059," \
+ "7.627308 47.505882," \
+ "7.627328 47.505867," \
+ "7.62735 47.50585," \
+ "7.627375 47.50584," \
+ "7.627398 47.50583," \
+ "7.627417 47.505814," \
+ "7.627437 47.505795," \
+ "7.627458 47.505775," \
+ "7.627482 47.505756," \
+ "7.6275 47.505737," \
+ "7.62751 47.50572," \
+ "7.627523 47.5057," \
+ "7.62755 47.505684," \
+ "7.627572 47.505672," \
+ "7.627588 47.505653," \
+ "7.627622 47.505642," \
+ "7.627638 47.505627," \
+ "7.62765 47.505608," \
+ "7.627672 47.50559," \
+ "7.627695 47.505573," \
+ "7.627712 47.505558," \
+ "7.627732 47.50554," \
+ "7.627755 47.505524," \
+ "7.627778 47.50551," \
+ "7.627798 47.50549," \
+ "7.627822 47.50547," \
+ "7.627845 47.50546," \
+ "7.627872 47.505444," \
+ "7.627885 47.50542," \
+ "7.6279 47.505398," \
+ "7.627923 47.50538," \
+ "7.627948 47.505367," \
+ "7.627978 47.50535," \
+ "7.62801 47.50533," \
+ "7.628028 47.505306," \
+ "7.628038 47.50529," \
+ "7.628072 47.505283," \
+ "7.628092 47.505276," \
+ "7.628108 47.50526," \
+ "7.62813 47.50525," \
+ "7.628155 47.505234," \
+ "7.628178 47.505215," \
+ "7.628198 47.505203," \
+ "7.628212 47.50519," \
+ "7.628243 47.505177," \
+ "7.628283 47.50515," \
+ "7.628305 47.505127," \
+ "7.628327 47.505108," \
+ "7.628348 47.505096," \
+ "7.628372 47.50509," \
+ "7.628392 47.505077," \
+ "7.628407 47.505062," \
+ "7.62842 47.505047," \
+ "7.628433 47.50503," \
+ "7.628445 47.505016," \
+ "7.628458 47.505," \
+ "7.62847 47.504982," \
+ "7.628483 47.504967," \
+ "7.628495 47.504948," \
+ "7.628495 47.504917," \
+ "7.628505 47.5049," \
+ "7.628518 47.50489," \
+ "7.62852 47.504875," \
+ "7.628525 47.504864," \
+ "7.628532 47.50485," \
+ "7.62854 47.504833," \
+ "7.628545 47.50482," \
+ "7.628555 47.504807," \
+ "7.628565 47.50479," \
+ "7.628572 47.504776," \
+ "7.628582 47.50476," \
+ "7.628598 47.50475," \
+ "7.628608 47.504738," \
+ "7.628615 47.504723," \
+ "7.628628 47.504707," \
+ "7.62864 47.504692," \
+ "7.62865 47.504673," \
+ "7.62866 47.504654," \
+ "7.628667 47.50464," \
+ "7.628675 47.50462," \
+ "7.628678 47.504597," \
+ "7.628662 47.504566," \
+ "7.628665 47.504543," \
+ "7.62866 47.50452," \
+ "7.628667 47.504498," \
+ "7.628672 47.50447," \
+ "7.628673 47.504448," \
+ "7.628668 47.504417," \
+ "7.62867 47.50439," \
+ "7.628663 47.504364," \
+ "7.628653 47.504337," \
+ "7.628645 47.50431," \
+ "7.628645 47.504288," \
+ "7.628655 47.504265," \
+ "7.628662 47.50424," \
+ "7.628657 47.50421," \
+ "7.628652 47.504185," \
+ "7.62865 47.504154," \
+ "7.628642 47.504128," \
+ "7.628653 47.504112," \
+ "7.628675 47.5041," \
+ "7.628697 47.504086," \
+ "7.628722 47.50408," \
+ "7.62873 47.504066," \
+ "7.628732 47.50405," \
+ "7.62874 47.504044," \
+ "7.628752 47.504032," \
+ "7.62876 47.50402," \
+ "7.628762 47.504005," \
+ "7.628763 47.50399," \
+ "7.628765 47.50398," \
+ "7.628767 47.503967," \
+ "7.628775 47.503956," \
+ "7.628778 47.50394," \
+ "7.628783 47.503918," \
+ "7.628785 47.5039," \
+ "7.628787 47.50388," \
+ "7.62879 47.50386," \
+ "7.628802 47.503838," \
+ "7.628818 47.503815," \
+ "7.628832 47.503788," \
+ "7.628845 47.50376," \
+ "7.62886 47.50374," \
+ "7.62886 47.50371," \
+ "7.628857 47.50368," \
+ "7.628852 47.50366," \
+ "7.628855 47.503643," \
+ "7.628863 47.503624," \
+ "7.628878 47.50361," \
+ "7.628885 47.503586," \
+ "7.628887 47.50357," \
+ "7.628895 47.50355," \
+ "7.628903 47.50353," \
+ "7.62891 47.5035," \
+ "7.628923 47.503483," \
+ "7.628937 47.503468," \
+ "7.628947 47.503445," \
+ "7.628952 47.50342," \
+ "7.628958 47.5034," \
+ "7.628973 47.50338," \
+ "7.628995 47.50337," \
+ "7.629018 47.503353," \
+ "7.629035 47.50334," \
+ "7.62905 47.50333," \
+ "7.629057 47.50331," \
+ "7.62906 47.503284," \
+ "7.629063 47.503258," \
+ "7.629075 47.503227," \
+ "7.62909 47.503204," \
+ "7.629098 47.503174," \
+ "7.6291 47.503143," \
+ "7.629122 47.503124," \
+ "7.62913 47.503094," \
+ "7.629152 47.503082," \
+ "7.629168 47.503067," \
+ "7.629183 47.50305," \
+ "7.6292 47.503036," \
+ "7.629222 47.50302," \
+ "7.629243 47.50301," \
+ "7.62926 47.502995," \
+ "7.629267 47.50297," \
+ "7.629272 47.502953," \
+ "7.629288 47.502937," \
+ "7.629308 47.502926," \
+ "7.629318 47.50291," \
+ "7.62933 47.502876," \
+ "7.629352 47.50285," \
+ "7.629368 47.502827," \
+ "7.62938 47.502808," \
+ "7.629393 47.50279," \
+ "7.629402 47.50276," \
+ "7.629418 47.502743," \
+ "7.62944 47.502728," \
+ "7.629465 47.502712," \
+ "7.629483 47.502693," \
+ "7.629508 47.50268," \
+ "7.629537 47.502674," \
+ "7.629563 47.502663," \
+ "7.629578 47.502647," \
+ "7.629592 47.502632," \
+ "7.629602 47.502617," \
+ "7.629618 47.502605," \
+ "7.629635 47.502594," \
+ "7.629662 47.50258," \
+ "7.629683 47.502563," \
+ "7.629697 47.502552," \
+ "7.629703 47.502537," \
+ "7.629713 47.502518," \
+ "7.62973 47.502495," \
+ "7.62975 47.50247," \
+ "7.629763 47.50245," \
+ "7.629778 47.502434," \
+ "7.629788 47.50241," \
+ "7.629788 47.502388," \
+ "7.629793 47.502365," \
+ "7.629802 47.50235," \
+ "7.629807 47.502335," \
+ "7.629817 47.50232," \
+ "7.629833 47.502316," \
+ "7.629853 47.502316," \
+ "7.629868 47.502308," \
+ "7.62989 47.502308," \
+ "7.629912 47.50231," \
+ "7.629927 47.50231," \
+ "7.62994 47.502316," \
+ "7.629945 47.50232," \
+ "7.629952 47.502327," \
+ "7.629952 47.502335," \
+ "7.629948 47.502346," \
+ "7.629947 47.502357," \
+ "7.629945 47.502373," \
+ "7.629937 47.502388," \
+ "7.629933 47.502403," \
+ "7.629935 47.50242," \
+ "7.629933 47.502434," \
+ "7.629925 47.50245," \
+ "7.629927 47.502464," \
+ "7.629928 47.502483," \
+ "7.629928 47.502506," \
+ "7.629933 47.502525," \
+ "7.629927 47.502544," \
+ "7.62993 47.502563," \
+ "7.62994 47.502583," \
+ "7.629942 47.502605," \
+ "7.629937 47.502625," \
+ "7.629923 47.502636," \
+ "7.629912 47.502644," \
+ "7.62992 47.502666," \
+ "7.62993 47.502697," \
+ "7.629935 47.50273," \
+ "7.629942 47.50276," \
+ "7.629942 47.502785," \
+ "7.629947 47.502804," \
+ "7.629952 47.502827," \
+ "7.629957 47.502846," \
+ "7.62996 47.502865," \
+ "7.629967 47.50288," \
+ "7.629973 47.5029," \
+ "7.629978 47.50292," \
+ "7.629987 47.502945," \
+ "7.629987 47.502964," \
+ "7.629995 47.502995," \
+ "7.629998 47.503025," \
+ "7.63 47.50305," \
+ "7.629995 47.503075," \
+ "7.629992 47.503098," \
+ "7.629995 47.50313," \
+ "7.629997 47.503155," \
+ "7.630008 47.50318," \
+ "7.63002 47.503204," \
+ "7.630033 47.50323," \
+ "7.630042 47.503254," \
+ "7.63005 47.50328," \
+ "7.63006 47.503304," \
+ "7.630065 47.50333," \
+ "7.630072 47.503357," \
+ "7.630077 47.50338," \
+ "7.630083 47.503403," \
+ "7.630085 47.50342," \
+ "7.630087 47.50344," \
+ "7.630093 47.503464," \
+ "7.630097 47.503487," \
+ "7.6301 47.50351," \
+ "7.630112 47.503532," \
+ "7.630123 47.503567," \
+ "7.630128 47.5036," \
+ "7.630132 47.503628," \
+ "7.630133 47.50365," \
+ "7.630142 47.503677," \
+ "7.630143 47.503696," \
+ "7.630145 47.503723," \
+ "7.63014 47.503746," \
+ "7.630133 47.503773," \
+ "7.630127 47.5038," \
+ "7.630128 47.503826," \
+ "7.630132 47.503853," \
+ "7.630132 47.503876," \
+ "7.630133 47.5039," \
+ "7.63014 47.50392," \
+ "7.630135 47.503944," \
+ "7.630143 47.503975," \
+ "7.630143 47.504005," \
+ "7.63016 47.504044," \
+ "7.630183 47.50408," \
+ "7.630202 47.50411," \
+ "7.63022 47.504128," \
+ "7.63025 47.504158," \
+ "7.630268 47.50418," \
+ "7.630315 47.504215," \
+ "7.630343 47.50424," \
+ "7.630372 47.504253," \
+ "7.630398 47.504265," \
+ "7.630425 47.50427," \
+ "7.630455 47.504265," \
+ "7.630483 47.504257," \
+ "7.63051 47.504246," \
+ "7.630538 47.504227," \
+ "7.630557 47.504204," \
+ "7.630575 47.50419," \
+ "7.630593 47.504173," \
+ "7.630607 47.50416," \
+ "7.630615 47.504147," \
+ "7.630627 47.50413," \
+ "7.63064 47.504124," \
+ "7.630655 47.50411," \
+ "7.630668 47.504093," \
+ "7.630683 47.50408," \
+ "7.6307 47.50406," \
+ "7.630712 47.504032," \
+ "7.630732 47.504013," \
+ "7.630752 47.503986," \
+ "7.63077 47.503963," \
+ "7.630793 47.503933," \
+ "7.630803 47.503902," \
+ "7.630815 47.503872," \
+ "7.630833 47.50384," \
+ "7.630855 47.50381," \
+ "7.630877 47.503788," \
+ "7.630898 47.50377," \
+ "7.630918 47.50375," \
+ "7.630937 47.503727," \
+ "7.630952 47.503708," \
+ "7.630968 47.50369," \
+ "7.630985 47.503662," \
+ "7.631007 47.503647," \
+ "7.631025 47.503624," \
+ "7.631047 47.5036," \
+ "7.631073 47.50357," \
+ "7.631095 47.503548," \
+ "7.631113 47.50353," \
+ "7.631128 47.503506," \
+ "7.631143 47.503487," \
+ "7.631157 47.50347," \
+ "7.631168 47.503452," \
+ "7.631183 47.503437," \
+ "7.631202 47.503418," \
+ "7.631213 47.50339," \
+ "7.63124 47.503372," \
+ "7.631263 47.503353," \
+ "7.631292 47.503338," \
+ "7.631312 47.503323," \
+ "7.631328 47.503304," \
+ "7.631353 47.50329," \
+ "7.631375 47.503277," \
+ "7.631402 47.50326," \
+ "7.631427 47.50324," \
+ "7.631452 47.503216," \
+ "7.631485 47.503197," \
+ "7.631513 47.503178," \
+ "7.631543 47.503166," \
+ "7.631572 47.503143," \
+ "7.631602 47.503124," \
+ "7.631623 47.5031," \
+ "7.631645 47.50308," \
+ "7.631665 47.50306," \
+ "7.631695 47.50304," \
+ "7.631717 47.50303," \
+ "7.631735 47.503002," \
+ "7.631753 47.502983," \
+ "7.631777 47.502968," \
+ "7.631803 47.502956," \
+ "7.631832 47.502953," \
+ "7.631863 47.50294," \
+ "7.631897 47.50293," \
+ "7.63194 47.50292," \
+ "7.631972 47.502895," \
+ "7.632 47.502888," \
+ "7.63203 47.50288," \
+ "7.632058 47.50287," \
+ "7.632103 47.502853," \
+ "7.632145 47.50283," \
+ "7.632183 47.502815," \
+ "7.632215 47.502796," \
+ "7.632245 47.50278," \
+ "7.632273 47.502766," \
+ "7.6323 47.502747," \
+ "7.632333 47.502728," \
+ "7.632372 47.50271," \
+ "7.632413 47.502697," \
+ "7.632445 47.502686," \
+ "7.632482 47.50267," \
+ "7.63252 47.502663," \
+ "7.632545 47.50265," \
+ "7.63258 47.50265," \
+ "7.632617 47.50265," \
+ "7.63266 47.50266," \
+ "7.632695 47.502666," \
+ "7.632727 47.50267," \
+ "7.632748 47.50267," \
+ "7.63277 47.502678," \
+ "7.632798 47.50268," \
+ "7.632823 47.502693," \
+ "7.632848 47.502705," \
+ "7.63288 47.502716," \
+ "7.632912 47.50273," \
+ "7.632943 47.502747," \
+ "7.632972 47.502758," \
+ "7.633002 47.502766," \
+ "7.633033 47.502777," \
+ "7.633068 47.502785," \
+ "7.633113 47.502792," \
+ "7.633143 47.502796," \
+ "7.633168 47.502792," \
+ "7.633207 47.502804," \
+ "7.63324 47.502815," \
+ "7.63327 47.502823," \
+ "7.633313 47.50284," \
+ "7.633353 47.502857," \
+ "7.633395 47.50287," \
+ "7.633438 47.502876," \
+ "7.633475 47.50288," \
+ "7.633505 47.502884," \
+ "7.63354 47.50289," \
+ "7.633578 47.502903," \
+ "7.633613 47.502907," \
+ "7.633648 47.50291," \
+ "7.633672 47.502914," \
+ "7.633702 47.502922," \
+ "7.633738 47.502934," \
+ "7.633773 47.502934," \
+ "7.63381 47.50294," \
+ "7.633842 47.50295," \
+ "7.633877 47.502956," \
+ "7.633918 47.50297," \
+ "7.633957 47.502987," \
+ "7.633993 47.503," \
+ "7.63403 47.503006," \
+ "7.634067 47.503014," \
+ "7.634107 47.50303," \
+ "7.634152 47.503044," \
+ "7.634192 47.503056," \
+ "7.634233 47.503067," \
+ "7.634267 47.50308," \
+ "7.634308 47.50309," \
+ "7.634343 47.503105," \
+ "7.634387 47.503124," \
+ "7.634423 47.503136," \
+ "7.634457 47.503143," \
+ "7.634488 47.503147," \
+ "7.634522 47.50315," \
+ "7.634562 47.503162," \
+ "7.634603 47.503174," \
+ "7.63465 47.503185," \
+ "7.63469 47.50319," \
+ "7.634727 47.50319," \
+ "7.634762 47.503185," \
+ "7.634802 47.50318," \
+ "7.634832 47.50317," \
+ "7.634872 47.503166," \
+ "7.634907 47.503162," \
+ "7.634937 47.503155," \
+ "7.634977 47.503155," \
+ "7.635012 47.503147," \
+ "7.635043 47.503136," \
+ "7.635092 47.503136," \
+ "7.635128 47.50313," \
+ "7.635155 47.503117," \
+ "7.635188 47.503113," \
+ "7.635222 47.5031," \
+ "7.635253 47.50309," \
+ "7.635292 47.503086," \
+ "7.635332 47.50308," \
+ "7.635368 47.50307," \
+ "7.635407 47.503063," \
+ "7.635448 47.50306," \
+ "7.635483 47.50305," \
+ "7.63551 47.503036," \
+ "7.635552 47.50303," \
+ "7.635598 47.50302," \
+ "7.63564 47.503014," \
+ "7.635687 47.503014," \
+ "7.635732 47.503006," \
+ "7.635765 47.50299," \
+ "7.6358 47.502975," \
+ "7.635833 47.502964," \
+ "7.635868 47.50295," \
+ "7.635898 47.502934," \
+ "7.63592 47.502907," \
+ "7.63595 47.50289," \
+ "7.635978 47.502872," \
+ "7.636005 47.502857," \
+ "7.636028 47.502846," \
+ "7.636063 47.50284," \
+ "7.63609 47.50282," \
+ "7.636108 47.502796," \
+ "7.636127 47.502773," \
+ "7.636145 47.50275," \
+ "7.636168 47.502735," \
+ "7.636198 47.50272," \
+ "7.636233 47.502705," \
+ "7.636257 47.502686," \
+ "7.636285 47.50267," \
+ "7.636305 47.50265," \
+ "7.636327 47.502644," \
+ "7.63635 47.502636," \
+ "7.636372 47.50262," \
+ "7.636392 47.5026," \
+ "7.636422 47.502583," \
+ "7.636448 47.502556," \
+ "7.636462 47.50253," \
+ "7.636483 47.502506," \
+ "7.636507 47.502483," \
+ "7.636528 47.50246," \
+ "7.636555 47.502445," \
+ "7.63659 47.50243," \
+ "7.636615 47.50241," \
+ "7.636637 47.50239," \
+ "7.63666 47.502377," \
+ "7.636692 47.502365," \
+ "7.636718 47.502346," \
+ "7.636747 47.502327," \
+ "7.636768 47.5023," \
+ "7.636783 47.502277," \
+ "7.636805 47.50225," \
+ "7.63683 47.50223," \
+ "7.636852 47.50221," \
+ "7.636873 47.50219," \
+ "7.636898 47.502167," \
+ "7.636928 47.50215," \
+ "7.636958 47.502136," \
+ "7.636995 47.50213," \
+ "7.63703 47.502117," \
+ "7.637065 47.50211," \
+ "7.637107 47.502106," \
+ "7.637145 47.5021," \
+ "7.6372 47.50211," \
+ "7.637233 47.502117," \
+ "7.637268 47.502125," \
+ "7.6373 47.50213," \
+ "7.637352 47.502148," \
+ "7.637393 47.50216," \
+ "7.637433 47.502163," \
+ "7.637473 47.50217," \
+ "7.637507 47.50218," \
+ "7.637537 47.502186," \
+ "7.637575 47.502193," \
+ "7.637613 47.502197," \
+ "7.637658 47.50221," \
+ "7.637702 47.502216," \
+ "7.637747 47.50222," \
+ "7.637788 47.502228," \
+ "7.637833 47.502235," \
+ "7.63788 47.502243," \
+ "7.637928 47.502247," \
+ "7.637978 47.502247," \
+ "7.638028 47.502247," \
+ "7.638077 47.50224," \
+ "7.638118 47.502228," \
+ "7.638165 47.502216," \
+ "7.638218 47.502216," \
+ "7.638275 47.50221," \
+ "7.63833 47.502197," \
+ "7.63837 47.50218," \
+ "7.638423 47.502167," \
+ "7.638468 47.50215," \
+ "7.638508 47.502136," \
+ "7.638553 47.502125," \
+ "7.638593 47.502113," \
+ "7.638638 47.5021," \
+ "7.638678 47.502087," \
+ "7.638725 47.502083," \
+ "7.638772 47.502075," \
+ "7.638818 47.502064," \
+ "7.638863 47.502056," \
+ "7.638905 47.502045," \
+ "7.638952 47.50203," \
+ "7.638993 47.502014," \
+ "7.639037 47.502003," \
+ "7.639083 47.501995," \
+ "7.639132 47.50199," \
+ "7.639172 47.50198," \
+ "7.639217 47.501972," \
+ "7.63926 47.501965," \
+ "7.639308 47.50196," \
+ "7.639357 47.501953," \
+ "7.639403 47.501945," \
+ "7.63945 47.501934," \
+ "7.639492 47.501923," \
+ "7.639537 47.501907," \
+ "7.63958 47.50189," \
+ "7.639623 47.501877," \
+ "7.639662 47.501858," \
+ "7.639697 47.501835," \
+ "7.639728 47.50181," \
+ "7.63976 47.50178," \
+ "7.639778 47.501755," \
+ "7.6398 47.50173," \
+ "7.639825 47.501713," \
+ "7.63985 47.501686," \
+ "7.639865 47.501656," \
+ "7.639877 47.50162," \
+ "7.639892 47.501587," \
+ "7.639903 47.501556," \
+ "7.639907 47.501522," \
+ "7.63991 47.501495," \
+ "7.639912 47.50147," \
+ "7.639908 47.50145," \
+ "7.639902 47.501427," \
+ "7.639897 47.501408," \
+ "7.639893 47.501385," \
+ "7.639888 47.50136," \
+ "7.639882 47.50133," \
+ "7.639872 47.501305," \
+ "7.639857 47.501278," \
+ "7.639838 47.50125," \
+ "7.63982 47.501225," \
+ "7.639795 47.501198," \
+ "7.639772 47.50116," \
+ "7.639762 47.50113," \
+ "7.639745 47.5011," \
+ "7.639727 47.501072," \
+ "7.639712 47.501045," \
+ "7.639693 47.50102," \
+ "7.639673 47.500988," \
+ "7.639657 47.500954," \
+ "7.639635 47.500927," \
+ "7.639615 47.500896," \
+ "7.639597 47.500866," \
+ "7.63957 47.500824," \
+ "7.639548 47.50078," \
+ "7.63952 47.50075," \
+ "7.6395 47.500725," \
+ "7.639473 47.5007," \
+ "7.639447 47.50067," \
+ "7.639415 47.50064," \
+ "7.639392 47.500618," \
+ "7.639368 47.500595," \
+ "7.639348 47.500576," \
+ "7.639323 47.50052," \
+ "7.639293 47.500477," \
+ "7.639267 47.500446," \
+ "7.639227 47.500412," \
+ "7.639197 47.50038," \
+ "7.639175 47.500347," \
+ "7.639155 47.500317," \
+ "7.639128 47.500294," \
+ "7.639093 47.50027," \
+ "7.63906 47.50025," \
+ "7.639035 47.50023," \
+ "7.639 47.500202," \
+ "7.63897 47.500175," \
+ "7.638935 47.50015," \
+ "7.63891 47.50012," \
+ "7.638885 47.5001," \
+ "7.638857 47.500076," \
+ "7.638827 47.50006," \
+ "7.638788 47.500046," \
+ "7.638755 47.500027," \
+ "7.638715 47.500004," \
+ "7.638682 47.49999," \
+ "7.638648 47.49996," \
+ "7.638613 47.499943," \
+ "7.638578 47.49992," \
+ "7.63854 47.499893," \
+ "7.6385 47.499874," \
+ "7.63846 47.49985," \
+ "7.638422 47.499832," \
+ "7.638393 47.499817," \
+ "7.638357 47.49979," \
+ "7.638312 47.499763," \
+ "7.638273 47.499744," \
+ "7.63823 47.49972," \
+ "7.638188 47.4997," \
+ "7.63816 47.499683," \
+ "7.638137 47.49966," \
+ "7.63811 47.49964," \
+ "7.6381 47.499615," \
+ "7.638078 47.49959," \
+ "7.638052 47.49956," \
+ "7.638025 47.499535," \
+ "7.638002 47.499516," \
+ "7.637965 47.499496," \
+ "7.637933 47.49947," \
+ "7.637905 47.499447," \
+ "7.637883 47.499413," \
+ "7.63787 47.49939," \
+ "7.637858 47.49936," \
+ "7.637852 47.49933," \
+ "7.637853 47.499302," \
+ "7.637862 47.499275," \
+ "7.637887 47.49926," \
+ "7.637913 47.499245," \
+ "7.637948 47.49923," \
+ "7.637983 47.49922," \
+ "7.63803 47.499218," \
+ "7.638082 47.499218," \
+ "7.63813 47.499214," \
+ "7.638175 47.49921," \
+ "7.638217 47.499207," \
+ "7.638258 47.499195," \
+ "7.638302 47.49919," \
+ "7.638348 47.499187," \
+ "7.638395 47.499187," \
+ "7.638447 47.499187," \
+ "7.63849 47.49918," \
+ "7.63854 47.499176," \
+ "7.63859 47.49917," \
+ "7.638647 47.49917," \
+ "7.638697 47.499165," \
+ "7.638738 47.499153," \
+ "7.63878 47.49914," \
+ "7.63883 47.499126," \
+ "7.63888 47.49912," \
+ "7.638928 47.49911," \
+ "7.638975 47.499092," \
+ "7.639025 47.499077," \
+ "7.63907 47.49906," \
+ "7.639118 47.499046," \
+ "7.639162 47.49903," \
+ "7.639203 47.49901," \
+ "7.639257 47.499," \
+ "7.639308 47.49899," \
+ "7.63935 47.498974," \
+ "7.639397 47.498962," \
+ "7.639447 47.498955," \
+ "7.639493 47.49894," \
+ "7.639547 47.49893," \
+ "7.6396 47.49892," \
+ "7.639652 47.49891," \
+ "7.639695 47.498898," \
+ "7.639735 47.49888," \
+ "7.639783 47.49887," \
+ "7.63983 47.498856," \
+ "7.639877 47.498837," \
+ "7.639915 47.498802," \
+ "7.639947 47.498764," \
+ "7.63997 47.49872," \
+ "7.639978 47.498684," \
+ "7.63998 47.49865," \
+ "7.639968 47.498615," \
+ "7.639952 47.498585," \
+ "7.639932 47.498547," \
+ "7.639917 47.498512," \
+ "7.639907 47.498486," \
+ "7.639897 47.49846," \
+ "7.63988 47.498432," \
+ "7.639865 47.498405," \
+ "7.639853 47.498383," \
+ "7.639835 47.498356," \
+ "7.63981 47.49832," \
+ "7.639777 47.498283," \
+ "7.639753 47.498253," \
+ "7.63973 47.498226," \
+ "7.639703 47.4982," \
+ "7.639675 47.498173," \
+ "7.639632 47.49814," \
+ "7.639588 47.4981," \
+ "7.639543 47.498062," \
+ "7.639498 47.498028," \
+ "7.639452 47.497993," \
+ "7.639412 47.497955," \
+ "7.639372 47.497925," \
+ "7.639335 47.497894," \
+ "7.639303 47.497868," \
+ "7.639272 47.49784," \
+ "7.639238 47.497818," \
+ "7.639208 47.4978," \
+ "7.639182 47.497784," \
+ "7.639157 47.497757," \
+ "7.639133 47.497734," \
+ "7.639097 47.497707," \
+ "7.639058 47.49768," \
+ "7.639008 47.497646," \
+ "7.638942 47.497597," \
+ "7.638897 47.49756," \
+ "7.638872 47.497536," \
+ "7.638843 47.497517," \
+ "7.638808 47.49749," \
+ "7.638765 47.497467," \
+ "7.638723 47.497448," \
+ "7.638648 47.497417," \
+ "7.638588 47.4974," \
+ "7.638533 47.497375," \
+ "7.638482 47.49735," \
+ "7.63843 47.497314," \
+ "7.638392 47.49729," \
+ "7.638352 47.497265," \
+ "7.638307 47.497227," \
+ "7.63829 47.497196," \
+ "7.638247 47.49716," \
+ "7.638198 47.497124," \
+ "7.638163 47.4971," \
+ "7.638132 47.497078," \
+ "7.638102 47.497047," \
+ "7.63808 47.497032," \
+ "7.638048 47.497013," \
+ "7.638018 47.49699," \
+ "7.637988 47.49697," \
+ "7.63796 47.49695," \
+ "7.637935 47.496918," \
+ "7.637913 47.496883," \
+ "7.637872 47.49685," \
+ "7.637828 47.49682," \
+ "7.637792 47.496788," \
+ "7.637762 47.49675," \
+ "7.637737 47.496716," \
+ "7.637703 47.49668," \
+ "7.637673 47.496655," \
+ "7.63764 47.49662," \
+ "7.637608 47.496593," \
+ "7.63758 47.49656," \
+ "7.637558 47.496525," \
+ "7.637543 47.496487," \
+ "7.63754 47.496452," \
+ "7.637552 47.49642," \
+ "7.637578 47.49639," \
+ "7.63761 47.49637," \
+ "7.637643 47.49635," \
+ "7.637692 47.49634," \
+ "7.63775 47.49635," \
+ "7.63781 47.496357," \
+ "7.637872 47.49637," \
+ "7.637927 47.496372," \
+ "7.63798 47.496372," \
+ "7.638032 47.496376," \
+ "7.638098 47.496384," \
+ "7.638167 47.49639," \
+ "7.638223 47.4964," \
+ "7.638278 47.496407," \
+ "7.638337 47.49642," \
+ "7.638388 47.496426," \
+ "7.63844 47.496437," \
+ "7.638493 47.496445," \
+ "7.638543 47.49645," \
+ "7.6386 47.49645," \
+ "7.638658 47.496452," \
+ "7.638715 47.496456," \
+ "7.63877 47.496464," \
+ "7.63882 47.496464," \
+ "7.638867 47.496468," \
+ "7.638915 47.496468," \
+ "7.63897 47.496468," \
+ "7.639025 47.496464," \
+ "7.639087 47.49647," \
+ "7.639152 47.496483," \
+ "7.639218 47.496487," \
+ "7.639265 47.496494," \
+ "7.639315 47.4965," \
+ "7.639368 47.49651," \
+ "7.639403 47.496513," \
+ "7.639458 47.49653," \
+ "7.639493 47.496536," \
+ "7.639542 47.496555," \
+ "7.639587 47.496567," \
+ "7.639635 47.49658," \
+ "7.639687 47.496593," \
+ "7.639718 47.49661," \
+ "7.639762 47.496624," \
+ "7.639815 47.496643," \
+ "7.63987 47.496662," \
+ "7.639918 47.49668," \
+ "7.63996 47.496696," \
+ "7.64 47.49671," \
+ "7.64004 47.496723," \
+ "7.640088 47.496735," \
+ "7.640142 47.496742," \
+ "7.640187 47.496742," \
+ "7.640232 47.496742," \
+ "7.640295 47.496742," \
+ "7.640345 47.496742," \
+ "7.640395 47.496746," \
+ "7.64045 47.49675," \
+ "7.6405 47.49676," \
+ "7.640557 47.496773," \
+ "7.640612 47.496784," \
+ "7.64067 47.496803," \
+ "7.64072 47.49682," \
+ "7.640765 47.496834," \
+ "7.64081 47.496857," \
+ "7.640853 47.49688," \
+ "7.64089 47.496902," \
+ "7.640918 47.496914," \
+ "7.64095 47.49693," \
+ "7.640987 47.49695," \
+ "7.64102 47.496964," \
+ "7.64105 47.49698," \
+ "7.641077 47.496998," \
+ "7.641108 47.497017," \
+ "7.641158 47.497036," \
+ "7.641203 47.49705," \
+ "7.641253 47.497074," \
+ "7.6413 47.4971," \
+ "7.641347 47.497128," \
+ "7.641398 47.497154," \
+ "7.641458 47.49718," \
+ "7.641498 47.4972," \
+ "7.641538 47.497223," \
+ "7.641568 47.49725," \
+ "7.641607 47.497272," \
+ "7.641642 47.497288," \
+ "7.641685 47.497307," \
+ "7.641732 47.49733," \
+ "7.64178 47.49735," \
+ "7.641835 47.49737," \
+ "7.641892 47.497406," \
+ "7.641952 47.49744," \
+ "7.642008 47.497463," \
+ "7.642058 47.49748," \
+ "7.642115 47.4975," \
+ "7.642197 47.497528," \
+ "7.642265 47.49755," \
+ "7.64233 47.49758," \
+ "7.642392 47.497604," \
+ "7.642463 47.49763," \
+ "7.642517 47.497646," \
+ "7.642567 47.497654," \
+ "7.642625 47.49769," \
+ "7.642673 47.49769," \
+ "7.642718 47.49769," \
+ "7.642778 47.49771," \
+ "7.64284 47.497723," \
+ "7.642897 47.497738," \
+ "7.642955 47.49776," \
+ "7.64301 47.497784," \
+ "7.643073 47.497795," \
+ "7.643128 47.497818," \
+ "7.643173 47.497818," \
+ "7.643228 47.497837," \
+ "7.643277 47.49785," \
+ "7.643323 47.497852," \
+ "7.643365 47.497864," \
+ "7.643408 47.49788," \
+ "7.643458 47.497917," \
+ "7.643492 47.497932," \
+ "7.643533 47.49795," \
+ "7.64358 47.497993," \
+ "7.64361 47.498013," \
+ "7.643633 47.498024," \
+ "7.643657 47.49804," \
+ "7.643698 47.498077," \
+ "7.643732 47.49811," \
+ "7.64376 47.498154," \
+ "7.643785 47.498177," \
+ "7.64381 47.498203," \
+ "7.64383 47.498226," \
+ "7.643848 47.498253," \
+ "7.643872 47.498283," \
+ "7.643893 47.498314," \
+ "7.64391 47.498337," \
+ "7.643928 47.498363," \
+ "7.643947 47.498394," \
+ "7.643962 47.498417," \
+ "7.643978 47.498444," \
+ "7.644003 47.498478," \
+ "7.644027 47.498516," \
+ "7.64406 47.498558," \
+ "7.644082 47.498596," \
+ "7.644107 47.498634," \
+ "7.644133 47.49867," \
+ "7.644167 47.49871," \
+ "7.644198 47.498745," \
+ "7.64423 47.49878," \
+ "7.64426 47.498814," \
+ "7.644298 47.49885," \
+ "7.644333 47.498875," \
+ "7.64436 47.498894," \
+ "7.64441 47.498913," \
+ "7.644447 47.498936," \
+ "7.644483 47.498962," \
+ "7.644522 47.49899," \
+ "7.64456 47.499012," \
+ "7.644597 47.49903," \
+ "7.644635 47.499054," \
+ "7.644662 47.49907," \
+ "7.644687 47.49909," \
+ "7.644717 47.49911," \
+ "7.64474 47.49912," \
+ "7.644773 47.499138," \
+ "7.64481 47.499157," \
+ "7.644848 47.499172," \
+ "7.644882 47.49919," \
+ "7.644923 47.49922," \
+ "7.644955 47.49925," \
+ "7.644997 47.499283," \
+ "7.64503 47.499306," \
+ "7.645067 47.499332," \
+ "7.645092 47.499363," \
+ "7.645123 47.499386," \
+ "7.64516 47.499413," \
+ "7.645187 47.499435," \
+ "7.645223 47.49946," \
+ "7.645258 47.49949," \
+ "7.645307 47.49951," \
+ "7.645363 47.499535," \
+ "7.64542 47.49955," \
+ "7.645475 47.499554," \
+ "7.645537 47.49955," \
+ "7.645602 47.49955," \
+ "7.645657 47.499546," \
+ "7.645715 47.499554," \
+ "7.645782 47.49957," \
+ "7.645828 47.49958," \
+ "7.645853 47.4996," \
+ "7.645873 47.499622," \
+ "7.645902 47.499638," \
+ "7.645943 47.49964," \
+ "7.645978 47.499626," \
+ "7.645998 47.4996," \
+ "7.646022 47.49957," \
+ "7.64605 47.499535," \
+ "7.646073 47.4995," \
+ "7.646092 47.499462," \
+ "7.646112 47.49943," \
+ "7.646128 47.499405," \
+ "7.646143 47.499374," \
+ "7.646167 47.49934," \
+ "7.646193 47.499302," \
+ "7.64622 47.49927," \
+ "7.646242 47.49924," \
+ "7.646265 47.499214," \
+ "7.646307 47.49919," \
+ "7.646352 47.499165," \
+ "7.646387 47.49914," \
+ "7.646412 47.499107," \
+ "7.646455 47.49908," \
+ "7.646507 47.499054," \
+ "7.646552 47.499027," \
+ "7.646598 47.499012," \
+ "7.646643 47.49899," \
+ "7.646693 47.498966," \
+ "7.646752 47.498955," \
+ "7.646812 47.498943," \
+ "7.646878 47.49893," \
+ "7.64694 47.49892," \
+ "7.647008 47.498917," \
+ "7.647062 47.4989," \
+ "7.647108 47.498886," \
+ "7.647158 47.498875," \
+ "7.647195 47.498848," \
+ "7.647243 47.49882," \
+ "7.647295 47.498795," \
+ "7.64734 47.49877," \
+ "7.64738 47.49875," \
+ "7.64743 47.498722," \
+ "7.647475 47.4987," \
+ "7.647508 47.49867," \
+ "7.647547 47.498642," \
+ "7.64759 47.498615," \
+ "7.647617 47.49859," \
+ "7.647633 47.49855," \
+ "7.647647 47.498524," \
+ "7.647685 47.4985," \
+ "7.647723 47.49848," \
+ "7.64774 47.498455," \
+ "7.64775 47.49843," \
+ "7.647762 47.498398," \
+ "7.647783 47.49837," \
+ "7.647808 47.49835," \
+ "7.647835 47.49833," \
+ "7.647868 47.49829," \
+ "7.647902 47.49827," \
+ "7.64794 47.49825," \
+ "7.647973 47.498226," \
+ "7.648005 47.49821," \
+ "7.648042 47.498184," \
+ "7.648078 47.49816," \
+ "7.648107 47.49814," \
+ "7.648125 47.49812," \
+ "7.648148 47.498093," \
+ "7.648158 47.49806," \
+ "7.648163 47.49803," \
+ "7.64816 47.498," \
+ "7.648153 47.49797," \
+ "7.648138 47.49794," \
+ "7.648122 47.49791," \
+ "7.648117 47.497887," \
+ "7.648102 47.497864," \
+ "7.64809 47.49784," \
+ "7.648077 47.497814," \
+ "7.648058 47.49778," \
+ "7.648047 47.49775," \
+ "7.648042 47.49772," \
+ "7.648043 47.497696," \
+ "7.648047 47.497677," \
+ "7.64804 47.497654," \
+ "7.648032 47.497627," \
+ "7.648017 47.4976," \
+ "7.648005 47.49757," \
+ "7.647973 47.497528," \
+ "7.647962 47.497494," \
+ "7.647948 47.49746," \
+ "7.647943 47.49743," \
+ "7.647933 47.497406," \
+ "7.647928 47.497375," \
+ "7.647923 47.497353," \
+ "7.647908 47.497322," \
+ "7.647878 47.497295," \
+ "7.647853 47.49727," \
+ "7.647828 47.49724," \
+ "7.647818 47.497208," \
+ "7.647805 47.49718," \
+ "7.647793 47.497158," \
+ "7.647773 47.49713," \
+ "7.64776 47.4971," \
+ "7.647742 47.497078," \
+ "7.647745 47.49706," \
+ "7.647767 47.497047," \
+ "7.6478 47.497044," \
+ "7.647827 47.49704," \
+ "7.647855 47.49703," \
+ "7.64788 47.49702," \
+ "7.647907 47.497005," \
+ "7.647928 47.496986," \
+ "7.647943 47.496967," \
+ "7.64796 47.496952," \
+ "7.647968 47.49693," \
+ "7.64798 47.496902," \
+ "7.647988 47.496883," \
+ "7.648 47.49686," \
+ "7.64801 47.496838," \
+ "7.648018 47.496815," \
+ "7.648025 47.49679," \
+ "7.648033 47.49677," \
+ "7.64804 47.49675," \
+ "7.64805 47.496727," \
+ "7.648063 47.49671," \
+ "7.648073 47.496693," \
+ "7.648083 47.496674," \
+ "7.648097 47.49665," \
+ "7.648113 47.496628," \
+ "7.648133 47.49661," \
+ "7.64815 47.496586," \
+ "7.648162 47.496563," \
+ "7.648168 47.496536," \
+ "7.648172 47.49651," \
+ "7.648188 47.49648," \
+ "7.648192 47.496456," \
+ "7.648208 47.496433," \
+ "7.648225 47.496414," \
+ "7.648248 47.496395," \
+ "7.64826 47.496376," \
+ "7.64827 47.496353," \
+ "7.648277 47.496334," \
+ "7.648287 47.496307," \
+ "7.648302 47.496277," \
+ "7.648318 47.496246," \
+ "7.648337 47.496216," \
+ "7.648348 47.49619," \
+ "7.648358 47.496166," \
+ "7.648363 47.496143," \
+ "7.648375 47.496117," \
+ "7.648387 47.49609," \
+ "7.648402 47.496063," \
+ "7.648412 47.496037," \
+ "7.64842 47.496017," \
+ "7.648433 47.495995," \
+ "7.648445 47.495968," \
+ "7.648457 47.49594," \
+ "7.648463 47.495914," \
+ "7.64846 47.495888," \
+ "7.648457 47.495865," \
+ "7.648453 47.495842," \
+ "7.648453 47.49581," \
+ "7.648452 47.49579," \
+ "7.64846 47.495766," \
+ "7.648472 47.49574," \
+ "7.648467 47.495705," \
+ "7.648467 47.495663," \
+ "7.648458 47.49562," \
+ "7.648448 47.495583," \
+ "7.648445 47.495556," \
+ "7.64844 47.49554," \
+ "7.648435 47.49553," \
+ "7.648437 47.49552," \
+ "7.648435 47.495514," \
+ "7.648433 47.495506," \
+ "7.648433 47.495483," \
+ "7.648438 47.49546," \
+ "7.648445 47.49544," \
+ "7.648447 47.49542," \
+ "7.64845 47.495396," \
+ "7.648457 47.495373," \
+ "7.648467 47.495354," \
+ "7.648468 47.495335," \
+ "7.648475 47.495308," \
+ "7.648475 47.495277," \
+ "7.64848 47.495247," \
+ "7.648497 47.495213," \
+ "7.648505 47.49518," \
+ "7.648508 47.49514," \
+ "7.648513 47.495106," \
+ "7.648527 47.495075," \
+ "7.648537 47.495052," \
+ "7.648538 47.49502," \
+ "7.648535 47.49499," \
+ "7.64855 47.49496," \
+ "7.648568 47.494934," \
+ "7.648577 47.494904," \
+ "7.64859 47.49487," \
+ "7.648585 47.494843," \
+ "7.648595 47.494816," \
+ "7.648603 47.494793," \
+ "7.648618 47.494766," \
+ "7.648628 47.494743," \
+ "7.64864 47.494717," \
+ "7.648655 47.494698," \
+ "7.648675 47.49468," \
+ "7.648692 47.49466," \
+ "7.648713 47.49464," \
+ "7.648747 47.494633," \
+ "7.648763 47.494625," \
+ "7.648787 47.49462," \
+ "7.64881 47.49462," \
+ "7.648852 47.49462," \
+ "7.648883 47.494617," \
+ "7.648918 47.49463," \
+ "7.648943 47.494633," \
+ "7.648963 47.49464," \
+ "7.648993 47.49465," \
+ "7.649023 47.494663," \
+ "7.649058 47.49468," \
+ "7.649097 47.494682," \
+ "7.649133 47.494686," \
+ "7.649173 47.4947," \
+ "7.649208 47.494717," \
+ "7.649245 47.49473," \
+ "7.649278 47.49474," \
+ "7.649312 47.494736," \
+ "7.649342 47.49473," \
+ "7.649368 47.49472," \
+ "7.649402 47.494717," \
+ "7.649433 47.494713," \
+ "7.649473 47.494717," \
+ "7.64951 47.494724," \
+ "7.649542 47.494728," \
+ "7.649577 47.49473," \
+ "7.64961 47.494736," \
+ "7.649647 47.494743," \
+ "7.649688 47.49475," \
+ "7.649735 47.49476," \
+ "7.649777 47.494766," \
+ "7.649833 47.494778," \
+ "7.649873 47.49478," \
+ "7.649905 47.494778," \
+ "7.649937 47.494766," \
+ "7.649967 47.49476," \
+ "7.650007 47.49474," \
+ "7.65004 47.494724," \
+ "7.65008 47.494717," \
+ "7.650123 47.494713," \
+ "7.650167 47.494713," \
+ "7.650217 47.494717," \
+ "7.650255 47.494717," \
+ "7.650293 47.494713," \
+ "7.650335 47.494705," \
+ "7.650375 47.494705," \
+ "7.65042 47.49471," \
+ "7.650465 47.494713," \
+ "7.65051 47.49471," \
+ "7.650562 47.4947," \
+ "7.65061 47.494686," \
+ "7.650662 47.494682," \
+ "7.6507 47.494675," \
+ "7.650742 47.494663," \
+ "7.650783 47.494656," \
+ "7.650827 47.494648," \
+ "7.650865 47.494633," \
+ "7.650917 47.49461," \
+ "7.650963 47.49459," \
+ "7.65101 47.494583," \
+ "7.651067 47.494576," \
+ "7.651102 47.494564," \
+ "7.65113 47.494545," \
+ "7.65116 47.494526," \
+ "7.651195 47.494507," \
+ "7.651223 47.49448," \
+ "7.651247 47.49446," \
+ "7.651275 47.494442," \
+ "7.651298 47.494423," \
+ "7.65133 47.494404," \
+ "7.651357 47.49439," \
+ "7.651383 47.494373," \
+ "7.651408 47.49436," \
+ "7.651438 47.494347," \
+ "7.651462 47.494335," \
+ "7.651483 47.494324," \
+ "7.651508 47.494316," \
+ "7.65153 47.494305," \
+ "7.651553 47.494293," \
+ "7.651575 47.494286," \
+ "7.651597 47.494274," \
+ "7.651622 47.494267," \
+ "7.651647 47.49426," \
+ "7.65167 47.494244," \
+ "7.6517 47.494236," \
+ "7.651728 47.494225," \
+ "7.651755 47.494217," \
+ "7.65178 47.49421," \
+ "7.651805 47.4942," \
+ "7.651825 47.49419," \
+ "7.651853 47.494186," \
+ "7.65188 47.49418," \
+ "7.651905 47.494167," \
+ "7.651933 47.494164," \
+ "7.651965 47.494164," \
+ "7.651997 47.494156," \
+ "7.652028 47.49415," \
+ "7.652057 47.49414," \
+ "7.652087 47.494133," \
+ "7.652125 47.49412," \
+ "7.65216 47.494118," \
+ "7.652193 47.49411," \
+ "7.652227 47.494102," \
+ "7.652253 47.49409," \
+ "7.652283 47.494083," \
+ "7.652312 47.494072," \
+ "7.652342 47.494064," \
+ "7.652372 47.49406," \
+ "7.652398 47.494053," \
+ "7.652422 47.494045," \
+ "7.652452 47.494038," \
+ "7.652482 47.494034," \
+ "7.652508 47.494026," \
+ "7.652532 47.494022," \
+ "7.652557 47.49401," \
+ "7.652585 47.494003," \
+ "7.652615 47.493996," \
+ "7.652638 47.493984," \
+ "7.652667 47.493973," \
+ "7.652693 47.49396," \
+ "7.652722 47.493954," \
+ "7.65275 47.493942," \
+ "7.652775 47.493927," \
+ "7.652805 47.493916," \
+ "7.652835 47.493904," \
+ "7.65286 47.493893," \
+ "7.652867 47.49387," \
+ "7.65288 47.493847," \
+ "7.652897 47.49383," \
+ "7.652935 47.493835," \
+ "7.65297 47.49383," \
+ "7.65301 47.49382," \
+ "7.653052 47.49381," \
+ "7.653092 47.493793," \
+ "7.653133 47.49378," \
+ "7.65318 47.493767," \
+ "7.653222 47.49375," \
+ "7.65326 47.493736," \
+ "7.653303 47.493713," \
+ "7.653345 47.493694," \
+ "7.653388 47.49367," \
+ "7.653435 47.493652," \
+ "7.653482 47.493633," \
+ "7.653527 47.493614," \
+ "7.653573 47.4936," \
+ "7.653617 47.493584," \
+ "7.653663 47.49357," \
+ "7.653708 47.49355," \
+ "7.653753 47.493534," \
+ "7.653802 47.49352," \
+ "7.653847 47.4935," \
+ "7.653892 47.49349," \
+ "7.65394 47.493473," \
+ "7.653983 47.493458," \
+ "7.654028 47.493443," \
+ "7.654078 47.49343," \
+ "7.654125 47.49342," \
+ "7.654173 47.49341," \
+ "7.65422 47.493397," \
+ "7.654262 47.49338," \
+ "7.654305 47.49337," \
+ "7.654347 47.49336," \
+ "7.654388 47.493343," \
+ "7.654428 47.49333," \
+ "7.65447 47.493317," \
+ "7.65451 47.493305," \
+ "7.65455 47.493294," \
+ "7.654587 47.493282," \
+ "7.654622 47.49327," \
+ "7.654662 47.493263," \
+ "7.6547 47.49325," \
+ "7.654737 47.493237," \
+ "7.654777 47.49323," \
+ "7.654818 47.493217," \
+ "7.654858 47.49321," \
+ "7.654893 47.4932," \
+ "7.654935 47.493195," \
+ "7.654975 47.493183," \
+ "7.655013 47.49317," \
+ "7.655053 47.493156," \
+ "7.655097 47.49315," \
+ "7.655137 47.49314," \
+ "7.655177 47.493134," \
+ "7.655203 47.49312," \
+ "7.655238 47.49311," \
+ "7.655282 47.493107," \
+ "7.65532 47.4931," \
+ "7.65536 47.493088," \
+ "7.655398 47.493076," \
+ "7.65544 47.493065," \
+ "7.65548 47.493057," \
+ "7.655517 47.493046," \
+ "7.655555 47.49304," \
+ "7.655597 47.49303," \
+ "7.655638 47.493027," \
+ "7.65568 47.49302," \
+ "7.655723 47.49301," \
+ "7.655767 47.493004," \
+ "7.655812 47.492996," \
+ "7.655853 47.49299," \
+ "7.65589 47.492977," \
+ "7.655928 47.49296," \
+ "7.65597 47.49295," \
+ "7.656008 47.492935," \
+ "7.656043 47.49292," \
+ "7.656082 47.492905," \
+ "7.656115 47.49289," \
+ "7.656145 47.492874," \
+ "7.656173 47.49285," \
+ "7.6562 47.49283," \
+ "7.656227 47.49281," \
+ "7.656258 47.492794," \
+ "7.65628 47.49278," \
+ "7.656305 47.492764," \
+ "7.656325 47.492744," \
+ "7.656335 47.49272," \
+ "7.656342 47.492695," \
+ "7.656353 47.492672," \
+ "7.656362 47.49265," \
+ "7.656368 47.492626," \
+ "7.656373 47.492603," \
+ "7.656382 47.49258," \
+ "7.656395 47.492554," \
+ "7.65641 47.49253," \
+ "7.656425 47.492504," \
+ "7.656433 47.49249," \
+ "7.656457 47.49246," \
+ "7.656475 47.492428," \
+ "7.656495 47.492405," \
+ "7.656508 47.492382," \
+ "7.656523 47.492355," \
+ "7.656528 47.49233," \
+ "7.656545 47.49229," \
+ "7.656568 47.492264," \
+ "7.65658 47.492233," \
+ "7.656595 47.49221," \
+ "7.65662 47.49218," \
+ "7.656637 47.49215," \
+ "7.656665 47.492123," \
+ "7.656692 47.492104," \
+ "7.656725 47.49207," \
+ "7.656745 47.49204," \
+ "7.656767 47.492016," \
+ "7.656783 47.491997," \
+ "7.656812 47.49197," \
+ "7.65685 47.49195," \
+ "7.656882 47.491932," \
+ "7.6569 47.4919," \
+ "7.656927 47.491882," \
+ "7.656955 47.49186," \
+ "7.656975 47.491844," \
+ "7.656997 47.49182," \
+ "7.657017 47.4918," \
+ "7.657035 47.49177," \
+ "7.657057 47.49174," \
+ "7.657078 47.491726," \
+ "7.657093 47.491707," \
+ "7.657112 47.491688," \
+ "7.65713 47.491657," \
+ "7.657137 47.491627," \
+ "7.657148 47.491596," \
+ "7.657168 47.491566," \
+ "7.657183 47.491524," \
+ "7.6572 47.491486," \
+ "7.6572 47.49146," \
+ "7.65721 47.49143," \
+ "7.65722 47.491394," \
+ "7.657225 47.491367," \
+ "7.657235 47.491337," \
+ "7.657245 47.491318," \
+ "7.657248 47.491283," \
+ "7.65724 47.491257," \
+ "7.657243 47.491234," \
+ "7.657253 47.491207," \
+ "7.65727 47.491184," \
+ "7.657288 47.491158," \
+ "7.657303 47.491127," \
+ "7.657325 47.491096," \
+ "7.657325 47.49106," \
+ "7.657338 47.491028," \
+ "7.657348 47.49099," \
+ "7.657358 47.49095," \
+ "7.65737 47.490913," \
+ "7.657377 47.49088," \
+ "7.657392 47.49085," \
+ "7.657407 47.490818," \
+ "7.657405 47.490788," \
+ "7.657405 47.490753," \
+ "7.657413 47.490726," \
+ "7.657427 47.490704," \
+ "7.657428 47.490677," \
+ "7.657428 47.490646," \
+ "7.657418 47.490612," \
+ "7.657417 47.490578," \
+ "7.657423 47.490543," \
+ "7.657427 47.49051," \
+ "7.657435 47.490475," \
+ "7.65744 47.49044," \
+ "7.657438 47.490406," \
+ "7.65743 47.490356," \
+ "7.657425 47.490322," \
+ "7.657428 47.49029," \
+ "7.657432 47.490253," \
+ "7.657433 47.490215," \
+ "7.657437 47.490185," \
+ "7.657437 47.49015," \
+ "7.657437 47.490116," \
+ "7.65744 47.490074," \
+ "7.657455 47.490044," \
+ "7.657472 47.490017," \
+ "7.657493 47.489983," \
+ "7.657515 47.489952," \
+ "7.657533 47.489914," \
+ "7.657552 47.48989," \
+ "7.657573 47.489864," \
+ "7.657595 47.489838," \
+ "7.657613 47.48981," \
+ "7.657632 47.489784," \
+ "7.657653 47.489758," \
+ "7.657677 47.48973," \
+ "7.657695 47.4897," \
+ "7.657718 47.489674," \
+ "7.65774 47.489647," \
+ "7.657763 47.489624," \
+ "7.65778 47.489597," \
+ "7.657795 47.48957," \
+ "7.65782 47.489536," \
+ "7.657842 47.489517," \
+ "7.657862 47.48949," \
+ "7.657878 47.489464," \
+ "7.657893 47.489433," \
+ "7.657908 47.489407," \
+ "7.657923 47.48938," \
+ "7.657947 47.489346," \
+ "7.657963 47.489323," \
+ "7.657978 47.489292," \
+ "7.65799 47.489254," \
+ "7.657995 47.48923," \
+ "7.658008 47.489204," \
+ "7.658027 47.489166," \
+ "7.65804 47.489147," \
+ "7.658055 47.48912," \
+ "7.658075 47.489098," \
+ "7.658097 47.48907," \
+ "7.658108 47.489048," \
+ "7.658123 47.48902," \
+ "7.658133 47.48899," \
+ "7.658143 47.488964," \
+ "7.658152 47.488934," \
+ "7.658158 47.488907," \
+ "7.65817 47.488876," \
+ "7.658187 47.48885," \
+ "7.6582 47.488823," \
+ "7.658212 47.48879," \
+ "7.658222 47.48877," \
+ "7.658237 47.488743," \
+ "7.658252 47.488716," \
+ "7.658268 47.48869," \
+ "7.658285 47.488667," \
+ "7.658298 47.488636," \
+ "7.658315 47.48861," \
+ "7.658337 47.48858," \
+ "7.658347 47.48855," \
+ "7.658358 47.488525," \
+ "7.658377 47.4885," \
+ "7.658393 47.48848," \
+ "7.658412 47.488453," \
+ "7.658432 47.488426," \
+ "7.658443 47.4884," \
+ "7.658462 47.488373," \
+ "7.658482 47.488346," \
+ "7.658498 47.48832," \
+ "7.658517 47.488293," \
+ "7.658535 47.48827," \
+ "7.658552 47.488243," \
+ "7.658568 47.488216," \
+ "7.658587 47.488194," \
+ "7.658605 47.48817," \
+ "7.658625 47.488148," \
+ "7.658632 47.488125," \
+ "7.658652 47.48811," \
+ "7.658662 47.488087," \
+ "7.658675 47.488056," \
+ "7.658692 47.48803," \
+ "7.658715 47.488007," \
+ "7.658742 47.487988," \
+ "7.658762 47.487965," \
+ "7.658783 47.48794," \
+ "7.658815 47.487926," \
+ "7.658843 47.487907," \
+ "7.658867 47.48789," \
+ "7.658892 47.48786," \
+ "7.65893 47.48784," \
+ "7.658957 47.487823," \
+ "7.658987 47.487804," \
+ "7.659015 47.487793," \
+ "7.659038 47.487774," \
+ "7.659063 47.487755," \
+ "7.659093 47.487736," \
+ "7.659123 47.487717," \
+ "7.659158 47.4877," \
+ "7.659193 47.48768," \
+ "7.659222 47.48767," \
+ "7.65926 47.48765," \
+ "7.659292 47.487637," \
+ "7.659318 47.48762," \
+ "7.659348 47.487606," \
+ "7.659378 47.48759," \
+ "7.659405 47.487576," \
+ "7.659433 47.487556," \
+ "7.659463 47.487537," \
+ "7.659498 47.48752," \
+ "7.659523 47.4875," \
+ "7.659552 47.487484," \
+ "7.659573 47.487473," \
+ "7.659602 47.48746," \
+ "7.659633 47.487446," \
+ "7.659663 47.487434," \
+ "7.659692 47.487423," \
+ "7.659717 47.487404," \
+ "7.659747 47.48739," \
+ "7.659778 47.48737," \
+ "7.65981 47.487354," \
+ "7.659843 47.487343," \
+ "7.659875 47.487324," \
+ "7.659902 47.48731," \
+ "7.659928 47.48729," \
+ "7.659948 47.487267," \
+ "7.659968 47.487244," \
+ "7.659988 47.48722," \
+ "7.660018 47.48721," \
+ "7.660047 47.487186," \
+ "7.66007 47.487167," \
+ "7.660097 47.48715," \
+ "7.660122 47.487133," \
+ "7.66015 47.487118," \
+ "7.660177 47.487103," \
+ "7.660203 47.487087," \
+ "7.660228 47.48707," \
+ "7.660253 47.487057," \
+ "7.66028 47.487034," \
+ "7.660302 47.487015," \
+ "7.660323 47.48699," \
+ "7.660348 47.486977," \
+ "7.660373 47.486954," \
+ "7.660395 47.486935," \
+ "7.660417 47.486916," \
+ "7.660435 47.486893," \
+ "7.660452 47.48687," \
+ "7.660468 47.486847," \
+ "7.660478 47.486816," \
+ "7.66049 47.4868," \
+ "7.660498 47.486774," \
+ "7.660507 47.486744," \
+ "7.660512 47.48672," \
+ "7.660513 47.48669," \
+ "7.660513 47.48666," \
+ "7.660522 47.486633," \
+ "7.660527 47.486607," \
+ "7.660528 47.48658," \
+ "7.660528 47.486557," \
+ "7.660528 47.48653," \
+ "7.660528 47.4865," \
+ "7.660528 47.48647," \
+ "7.660542 47.486446," \
+ "7.660538 47.48642," \
+ "7.660527 47.486393," \
+ "7.66052 47.486374," \
+ "7.660505 47.48635," \
+ "7.660478 47.48632," \
+ "7.660457 47.486298," \
+ "7.66044 47.48628," \
+ "7.660423 47.48626," \
+ "7.660408 47.486237," \
+ "7.660392 47.486214," \
+ "7.660375 47.486187," \
+ "7.660365 47.48617," \
+ "7.660353 47.48615," \
+ "7.660335 47.486126," \
+ "7.660323 47.48611," \
+ "7.660313 47.48609," \
+ "7.660303 47.486057," \
+ "7.660293 47.48603," \
+ "7.660285 47.48601," \
+ "7.660275 47.485996," \
+ "7.660265 47.485977," \
+ "7.660253 47.48595," \
+ "7.660238 47.485924," \
+ "7.660235 47.485905," \
+ "7.66023 47.485886," \
+ "7.660232 47.485863," \
+ "7.66023 47.485844," \
+ "7.660223 47.48582," \
+ "7.660215 47.485794," \
+ "7.66021 47.48577," \
+ "7.660205 47.48575," \
+ "7.660205 47.48573," \
+ "7.660213 47.485714," \
+ "7.660222 47.485706," \
+ "7.660225 47.485687," \
+ "7.66023 47.485672," \
+ "7.660232 47.485657," \
+ "7.66024 47.48564," \
+ "7.660247 47.485638," \
+ "7.66025 47.485626," \
+ "7.660253 47.485615," \
+ "7.660257 47.485596," \
+ "7.660262 47.48558," \
+ "7.660255 47.485554," \
+ "7.660247 47.48553," \
+ "7.660242 47.48551," \
+ "7.660242 47.485493," \
+ "7.660245 47.48548," \
+ "7.66026 47.485474," \
+ "7.660268 47.48546," \
+ "7.660277 47.485443," \
+ "7.660282 47.485428," \
+ "7.660292 47.485413," \
+ "7.660303 47.485397," \
+ "7.660322 47.48538," \
+ "7.660332 47.48536," \
+ "7.660343 47.485336," \
+ "7.66036 47.485313," \
+ "7.660377 47.48528," \
+ "7.660387 47.485245," \
+ "7.660392 47.48522," \
+ "7.66039 47.48519," \
+ "7.66038 47.485153," \
+ "7.660358 47.48512," \
+ "7.660358 47.485104," \
+ "7.660358 47.485077," \
+ "7.660355 47.48506," \
+ "7.660347 47.48504," \
+ "7.660332 47.485016," \
+ "7.660325 47.484997," \
+ "7.660317 47.484978," \
+ "7.660312 47.48496," \
+ "7.660305 47.484943," \
+ "7.660303 47.48493," \
+ "7.660298 47.484917," \
+ "7.660287 47.484898," \
+ "7.660273 47.484886," \
+ "7.660263 47.48487," \
+ "7.660255 47.484856," \
+ "7.660247 47.484833," \
+ "7.660252 47.48482," \
+ "7.660255 47.484802," \
+ "7.66025 47.48479," \
+ "7.660233 47.484768," \
+ "7.660225 47.484753," \
+ "7.660218 47.484737," \
+ "7.660207 47.484722," \
+ "7.660185 47.484707," \
+ "7.66016 47.484688," \
+ "7.660135 47.48467," \
+ "7.660105 47.484642," \
+ "7.660078 47.48462," \
+ "7.660063 47.484604," \
+ "7.660048 47.484592," \
+ "7.660038 47.48458," \
+ "7.660023 47.484573," \
+ "7.660003 47.484554," \
+ "7.659992 47.48454," \
+ "7.659978 47.484524," \
+ "7.659967 47.48451," \
+ "7.65996 47.48449," \
+ "7.659957 47.48447," \
+ "7.659948 47.484455," \
+ "7.659942 47.484444," \
+ "7.659925 47.484425," \
+ "7.659903 47.48441," \
+ "7.659892 47.484394," \
+ "7.65988 47.48438," \
+ "7.659863 47.484356," \
+ "7.659847 47.48433," \
+ "7.65983 47.484314," \
+ "7.659813 47.48429," \
+ "7.65979 47.484253," \
+ "7.659787 47.484234," \
+ "7.659778 47.48422," \
+ "7.659768 47.4842," \
+ "7.659755 47.48418," \
+ "7.65974 47.484165," \
+ "7.659725 47.484154," \
+ "7.659707 47.48414," \
+ "7.659693 47.48412," \
+ "7.659683 47.484108," \
+ "7.659672 47.484097," \
+ "7.659657 47.48408," \
+ "7.659643 47.484066," \
+ "7.659623 47.48405," \
+ "7.659595 47.48403," \
+ "7.65957 47.484016," \
+ "7.659482 47.483986," \
+ "7.659418 47.48398," \
+ "7.65937 47.48398," \
+ "7.659318 47.483974," \
+ "7.659267 47.483967," \
+ "7.659235 47.483963," \
+ "7.659213 47.483955," \
+ "7.659197 47.483948," \
+ "7.65917 47.483936," \
+ "7.659133 47.483925," \
+ "7.659105 47.48391," \
+ "7.659073 47.4839," \
+ "7.659043 47.483883," \
+ "7.659003 47.483864," \
+ "7.658967 47.48385," \
+ "7.658932 47.483833," \
+ "7.658893 47.483814," \
+ "7.658853 47.4838," \
+ "7.658818 47.483784," \
+ "7.658795 47.48377," \
+ "7.658765 47.48375," \
+ "7.658735 47.483727," \
+ "7.658698 47.483707," \
+ "7.658663 47.48369," \
+ "7.658625 47.48367," \
+ "7.658588 47.483646," \
+ "7.658552 47.48363," \
+ "7.658525 47.48362," \
+ "7.658497 47.483604," \
+ "7.658472 47.48359," \
+ "7.65844 47.483574," \
+ "7.658405 47.48356," \
+ "7.65837 47.48354," \
+ "7.658335 47.483517," \
+ "7.658307 47.4835," \
+ "7.658273 47.483486," \
+ "7.658253 47.483475," \
+ "7.658227 47.48346," \
+ "7.658207 47.483444," \
+ "7.658185 47.483437," \
+ "7.658145 47.483414," \
+ "7.658108 47.483387," \
+ "7.658075 47.483368," \
+ "7.658045 47.483345," \
+ "7.658013 47.483322," \
+ "7.657985 47.483303," \
+ "7.657955 47.483284," \
+ "7.657932 47.48327," \
+ "7.657908 47.483253," \
+ "7.657878 47.483234," \
+ "7.657857 47.48322," \
+ "7.657837 47.483204," \
+ "7.65782 47.483185," \
+ "7.6578 47.48316," \
+ "7.65778 47.483135," \
+ "7.65775 47.48311," \
+ "7.657753 47.4831," \
+ "7.657747 47.483086," \
+ "7.657732 47.48306," \
+ "7.657722 47.483036," \
+ "7.657703 47.483013," \
+ "7.657697 47.48299," \
+ "7.657692 47.482967," \
+ "7.657688 47.48295," \
+ "7.657682 47.48292," \
+ "7.657668 47.482903," \
+ "7.657638 47.48287," \
+ "7.657613 47.48285," \
+ "7.657587 47.48282," \
+ "7.657562 47.48279," \
+ "7.657545 47.482777," \
+ "7.657517 47.48275," \
+ "7.65749 47.482727," \
+ "7.657462 47.482708," \
+ "7.657438 47.48269," \
+ "7.657402 47.48266," \
+ "7.65737 47.48264," \
+ "7.657345 47.48262," \
+ "7.657313 47.482597," \
+ "7.657282 47.48258," \
+ "7.65725 47.48255," \
+ "7.65723 47.482525," \
+ "7.657223 47.4825," \
+ "7.657225 47.482475," \
+ "7.657223 47.482445," \
+ "7.657225 47.482414," \
+ "7.657228 47.482388," \
+ "7.657233 47.482365," \
+ "7.65724 47.48235," \
+ "7.657235 47.48232," \
+ "7.657222 47.48229," \
+ "7.657212 47.482265," \
+ "7.657187 47.48224," \
+ "7.657162 47.482212," \
+ "7.657138 47.48218," \
+ "7.65712 47.48215," \
+ "7.657105 47.482113," \
+ "7.657093 47.482082," \
+ "7.657082 47.48206," \
+ "7.657073 47.482037," \
+ "7.657062 47.482002," \
+ "7.657062 47.481968," \
+ "7.657062 47.481937," \
+ "7.657065 47.481907," \
+ "7.657073 47.481873," \
+ "7.657083 47.481842," \
+ "7.657092 47.481815," \
+ "7.657103 47.481773," \
+ "7.65711 47.481747," \
+ "7.657113 47.48172," \
+ "7.657118 47.481693," \
+ "7.657123 47.481663," \
+ "7.657133 47.48163," \
+ "7.657147 47.4816," \
+ "7.657162 47.48158," \
+ "7.657183 47.48155," \
+ "7.657202 47.48153," \
+ "7.657232 47.4815," \
+ "7.657255 47.48148," \
+ "7.65728 47.481453," \
+ "7.657298 47.481422," \
+ "7.657317 47.481396," \
+ "7.657335 47.481365," \
+ "7.657355 47.481342," \
+ "7.657387 47.48133," \
+ "7.657422 47.48131," \
+ "7.657452 47.481293," \
+ "7.657477 47.481266," \
+ "7.657497 47.481243," \
+ "7.657522 47.48121," \
+ "7.657532 47.481182," \
+ "7.657538 47.481155," \
+ "7.657552 47.48112," \
+ "7.657565 47.48108," \
+ "7.657575 47.481045," \
+ "7.65758 47.481007," \
+ "7.657588 47.480984," \
+ "7.65759 47.480938," \
+ "7.657603 47.48091," \
+ "7.657618 47.480873," \
+ "7.657638 47.48084," \
+ "7.657648 47.480797," \
+ "7.657663 47.480755," \
+ "7.657668 47.480717," \
+ "7.65767 47.480682," \
+ "7.657675 47.480648," \
+ "7.657682 47.480614," \
+ "7.657685 47.48058," \
+ "7.657693 47.480553," \
+ "7.657702 47.48052," \
+ "7.657715 47.480488," \
+ "7.657742 47.480446," \
+ "7.657753 47.480423," \
+ "7.657763 47.48039," \
+ "7.657778 47.48036," \
+ "7.657783 47.480324," \
+ "7.657785 47.480293," \
+ "7.65779 47.480263," \
+ "7.657788 47.48023," \
+ "7.657792 47.480194," \
+ "7.657785 47.480164," \
+ "7.657782 47.48013," \
+ "7.657788 47.4801," \
+ "7.657785 47.48007," \
+ "7.657783 47.48004," \
+ "7.657783 47.480003," \
+ "7.657785 47.47997," \
+ "7.657792 47.47994," \
+ "7.657798 47.479908," \
+ "7.657808 47.479874," \
+ "7.657827 47.47984," \
+ "7.657833 47.47981," \
+ "7.657845 47.479774," \
+ "7.657865 47.47974," \
+ "7.657885 47.479706," \
+ "7.657908 47.47967," \
+ "7.65793 47.47964," \
+ "7.657947 47.479614," \
+ "7.657953 47.479576," \
+ "7.657967 47.479538," \
+ "7.657985 47.47949," \
+ "7.657993 47.479458," \
+ "7.658007 47.479412," \
+ "7.65801 47.47938," \
+ "7.658013 47.47934," \
+ "7.65802 47.4793," \
+ "7.658027 47.479275," \
+ "7.658038 47.479233," \
+ "7.658048 47.4792," \
+ "7.658055 47.47916," \
+ "7.658078 47.479126," \
+ "7.658102 47.47909," \
+ "7.658103 47.479046," \
+ "7.658108 47.479004," \
+ "7.658127 47.478973," \
+ "7.658133 47.478935," \
+ "7.658142 47.47891," \
+ "7.658162 47.47887," \
+ "7.658178 47.478844," \
+ "7.658165 47.478806," \
+ "7.658135 47.47877," \
+ "7.658115 47.47874," \
+ "7.658107 47.478718," \
+ "7.658103 47.4787," \
+ "7.658087 47.478676," \
+ "7.658058 47.478664," \
+ "7.658023 47.47865," \
+ "7.657982 47.478638," \
+ "7.657933 47.478626," \
+ "7.657897 47.47861," \
+ "7.657853 47.478596," \
+ "7.657808 47.47859," \
+ "7.657765 47.478577," \
+ "7.657722 47.47856," \
+ "7.657688 47.478554," \
+ "7.657655 47.478554," \
+ "7.657623 47.47856," \
+ "7.657602 47.478577," \
+ "7.657587 47.478607," \
+ "7.657573 47.47863," \
+ "7.65755 47.47865," \
+ "7.657532 47.47867," \
+ "7.65752 47.478683," \
+ "7.657503 47.478687," \
+ "7.657488 47.478683," \
+ "7.657482 47.478672," \
+ "7.657477 47.47866," \
+ "7.65747 47.47865," \
+ "7.657457 47.47864," \
+ "7.657442 47.478626," \
+ "7.65743 47.478615," \
+ "7.657423 47.478603," \
+ "7.657407 47.478592," \
+ "7.657393 47.478577," \
+ "7.657375 47.47856," \
+ "7.657355 47.47855," \
+ "7.657342 47.47854," \
+ "7.657333 47.478527," \
+ "7.657317 47.47852," \
+ "7.6573 47.478504," \
+ "7.657283 47.478504," \
+ "7.657248 47.478493," \
+ "7.657215 47.478485," \
+ "7.657193 47.478493," \
+ "7.657172 47.478508," \
+ "7.65716 47.478523," \
+ "7.657157 47.47854," \
+ "7.657158 47.47856," \
+ "7.65716 47.478584," \
+ "7.657153 47.4786," \
+ "7.65715 47.478615," \
+ "7.657147 47.478622," \
+ "7.657142 47.478626," \
+ "7.657137 47.47862," \
+ "7.657123 47.478607," \
+ "7.657117 47.478603," \
+ "7.657105 47.478584," \
+ "7.657087 47.47856," \
+ "7.657062 47.478542," \
+ "7.657042 47.478527," \
+ "7.657025 47.47852," \
+ "7.657007 47.47851," \
+ "7.656985 47.478497," \
+ "7.656963 47.478477," \
+ "7.656938 47.47846," \
+ "7.656912 47.47844," \
+ "7.656888 47.478416," \
+ "7.656865 47.478397," \
+ "7.656842 47.478386," \
+ "7.656812 47.47837," \
+ "7.656772 47.47835," \
+ "7.65673 47.478336," \
+ "7.656688 47.478325," \
+ "7.656647 47.478313," \
+ "7.656607 47.478302," \
+ "7.656563 47.478294," \
+ "7.656515 47.47828," \
+ "7.656467 47.478264," \
+ "7.656417 47.47825," \
+ "7.656368 47.478233," \
+ "7.65633 47.478226," \
+ "7.65629 47.478214," \
+ "7.656248 47.478207," \
+ "7.65621 47.4782," \
+ "7.65617 47.478195," \
+ "7.656127 47.47819," \
+ "7.656077 47.478184," \
+ "7.656038 47.478176," \
+ "7.656003 47.47817," \
+ "7.655972 47.478157," \
+ "7.655938 47.47815," \
+ "7.655907 47.47815," \
+ "7.655867 47.47815," \
+ "7.655827 47.478153," \
+ "7.655787 47.478153," \
+ "7.655743 47.478153," \
+ "7.6557 47.478153," \
+ "7.65566 47.478153," \
+ "7.655623 47.478146," \
+ "7.655575 47.478138," \
+ "7.65554 47.47813," \
+ "7.655498 47.47812," \
+ "7.655458 47.47811," \
+ "7.655413 47.478096," \
+ "7.655373 47.47809," \
+ "7.655345 47.47809," \
+ "7.655312 47.478077," \
+ "7.65528 47.47807," \
+ "7.655243 47.478058," \
+ "7.655198 47.478046," \
+ "7.655148 47.47803," \
+ "7.6551 47.47802," \
+ "7.655052 47.47801," \
+ "7.65498 47.477985," \
+ "7.654918 47.477966," \
+ "7.654868 47.47795," \
+ "7.654815 47.477932," \
+ "7.654757 47.477905," \
+ "7.654708 47.477886," \
+ "7.654668 47.47787," \
+ "7.654612 47.47785," \
+ "7.654568 47.477837," \
+ "7.654527 47.477825," \
+ "7.654493 47.477818," \
+ "7.65446 47.477806," \
+ "7.654422 47.477787," \
+ "7.654383 47.477776," \
+ "7.654338 47.47776," \
+ "7.654293 47.47775," \
+ "7.654252 47.477737," \
+ "7.654207 47.477726," \
+ "7.65417 47.47772," \
+ "7.65413 47.477715," \
+ "7.65409 47.477703," \
+ "7.654047 47.47769," \
+ "7.654003 47.477684," \
+ "7.65396 47.477676," \
+ "7.653913 47.477673," \
+ "7.653875 47.47766," \
+ "7.653838 47.477657," \
+ "7.653797 47.477654," \
+ "7.653755 47.477646," \
+ "7.653713 47.477642," \
+ "7.653673 47.47764," \
+ "7.653628 47.477627," \
+ "7.653578 47.47762," \
+ "7.653528 47.47761," \
+ "7.653473 47.477596," \
+ "7.653423 47.47758," \
+ "7.653375 47.477573," \
+ "7.653328 47.477562," \
+ "7.653282 47.47756," \
+ "7.653245 47.47755," \
+ "7.6532 47.477547," \
+ "7.65315 47.477547," \
+ "7.6531 47.477543," \
+ "7.653058 47.47754," \
+ "7.652995 47.477528," \
+ "7.652937 47.47752," \
+ "7.652877 47.477505," \
+ "7.652815 47.477486," \
+ "7.652757 47.47748," \
+ "7.652692 47.477463," \
+ "7.652635 47.477455," \
+ "7.652573 47.477448," \
+ "7.652513 47.477448," \
+ "7.652462 47.477448," \
+ "7.652408 47.47745," \
+ "7.652353 47.47745," \
+ "7.6523 47.477455," \
+ "7.652248 47.477467," \
+ "7.652192 47.477474," \
+ "7.652137 47.47748," \
+ "7.65208 47.477497," \
+ "7.65201 47.477524," \
+ "7.65197 47.477543," \
+ "7.651922 47.477566," \
+ "7.651863 47.47759," \
+ "7.651822 47.477596," \
+ "7.651772 47.477608," \
+ "7.651722 47.47761," \
+ "7.651668 47.477615," \
+ "7.651612 47.477615," \
+ "7.651562 47.477615," \
+ "7.651513 47.47762," \
+ "7.651475 47.477615," \
+ "7.651447 47.47762," \
+ "7.651423 47.477623," \
+ "7.651388 47.477623," \
+ "7.651358 47.477627," \
+ "7.65133 47.47763," \
+ "7.651278 47.477623," \
+ "7.651237 47.47761," \
+ "7.651192 47.47761," \
+ "7.651142 47.477604," \
+ "7.651107 47.4776," \
+ "7.651075 47.4776," \
+ "7.651028 47.477596," \
+ "7.650978 47.47759," \
+ "7.650935 47.477585," \
+ "7.650895 47.47758," \
+ "7.650853 47.477577," \
+ "7.65081 47.47757," \
+ "7.650765 47.477566," \
+ "7.650718 47.47756," \
+ "7.650677 47.47755," \
+ "7.650635 47.47754," \
+ "7.650595 47.477524," \
+ "7.650552 47.477512," \
+ "7.650513 47.47751," \
+ "7.65047 47.477505," \
+ "7.65042 47.4775," \
+ "7.650367 47.4775," \
+ "7.650288 47.477512," \
+ "7.650227 47.477524," \
+ "7.650172 47.47753," \
+ "7.65011 47.477543," \
+ "7.650047 47.477543," \
+ "7.649998 47.477547," \
+ "7.649947 47.477554," \
+ "7.649913 47.477566," \
+ "7.649878 47.47757," \
+ "7.649835 47.477573," \
+ "7.649782 47.477573," \
+ "7.649725 47.477573," \
+ "7.649672 47.47758," \
+ "7.649622 47.477585," \
+ "7.64958 47.477585," \
+ "7.64953 47.47759," \
+ "7.649475 47.477585," \
+ "7.649433 47.47759," \
+ "7.649378 47.47759," \
+ "7.649333 47.47759," \
+ "7.649297 47.477596," \
+ "7.649263 47.477608," \
+ "7.649225 47.477623," \
+ "7.649198 47.47764," \
+ "7.649158 47.477654," \
+ "7.649128 47.477657," \
+ "7.649088 47.477665," \
+ "7.649045 47.477673," \
+ "7.64901 47.477676," \
+ "7.648982 47.477688," \
+ "7.648942 47.477695," \
+ "7.648905 47.477703," \
+ "7.64886 47.477707," \
+ "7.648817 47.477707," \
+ "7.648782 47.477707," \
+ "7.648732 47.477703," \
+ "7.648695 47.4777," \
+ "7.64866 47.47769," \
+ "7.648628 47.477684," \
+ "7.648582 47.477673," \
+ "7.64854 47.47766," \
+ "7.648508 47.477657," \
+ "7.648468 47.477654," \
+ "7.648428 47.47765," \
+ "7.64838 47.477646," \
+ "7.64833 47.47764," \
+ "7.648287 47.47764," \
+ "7.648247 47.477642," \
+ "7.648205 47.477646," \
+ "7.648158 47.477654," \
+ "7.648118 47.47766," \
+ "7.648072 47.47767," \
+ "7.648033 47.477676," \
+ "7.647978 47.47769," \
+ "7.647935 47.477703," \
+ "7.647892 47.477722," \
+ "7.647857 47.47774," \
+ "7.64782 47.477764," \
+ "7.64778 47.47779," \
+ "7.64775 47.477818," \
+ "7.647727 47.477844," \
+ "7.647705 47.477867," \
+ "7.64767 47.47789," \
+ "7.647633 47.477917," \
+ "7.647597 47.47794)"
+#define LS2 "LINESTRING (" \
+ "7.619772 47.50658," \
+ "7.619795 47.50658," \
+ "7.619822 47.506577," \
+ "7.619845 47.506577," \
+ "7.619875 47.50658," \
+ "7.619908 47.506577," \
+ "7.619948 47.50658," \
+ "7.619985 47.50658," \
+ "7.620023 47.50658," \
+ "7.620057 47.506577," \
+ "7.620085 47.506577," \
+ "7.620115 47.506573," \
+ "7.620145 47.50657," \
+ "7.62017 47.506565," \
+ "7.620195 47.50656," \
+ "7.620223 47.506557," \
+ "7.620248 47.506554," \
+ "7.620275 47.50655," \
+ "7.620305 47.506546," \
+ "7.620338 47.506542," \
+ "7.620365 47.506535," \
+ "7.620382 47.50654," \
+ "7.620407 47.506542," \
+ "7.620433 47.50655," \
+ "7.620463 47.506542," \
+ "7.620485 47.50653," \
+ "7.620517 47.506527," \
+ "7.620547 47.50652," \
+ "7.620573 47.5065," \
+ "7.6206 47.506493," \
+ "7.620625 47.506477," \
+ "7.620643 47.506462," \
+ "7.620665 47.50645," \
+ "7.62069 47.50643," \
+ "7.620708 47.506405," \
+ "7.62072 47.506382," \
+ "7.620728 47.506363," \
+ "7.620738 47.506336," \
+ "7.620745 47.506313," \
+ "7.620752 47.506294," \
+ "7.620757 47.50627," \
+ "7.620765 47.50625," \
+ "7.62076 47.506214," \
+ "7.620755 47.506184," \
+ "7.62075 47.50614," \
+ "7.620737 47.506104," \
+ "7.620742 47.506073," \
+ "7.620755 47.50604," \
+ "7.62076 47.50601," \
+ "7.620752 47.505978," \
+ "7.620742 47.505947," \
+ "7.620737 47.505913," \
+ "7.620732 47.505882," \
+ "7.620733 47.50585," \
+ "7.620743 47.50583," \
+ "7.620743 47.5058," \
+ "7.620745 47.505768," \
+ "7.620752 47.505733," \
+ "7.620758 47.5057," \
+ "7.620778 47.505672," \
+ "7.620795 47.50565," \
+ "7.620805 47.505615," \
+ "7.620812 47.50559," \
+ "7.620812 47.50556," \
+ "7.620818 47.50553," \
+ "7.620822 47.5055," \
+ "7.620838 47.50547," \
+ "7.62085 47.50544," \
+ "7.620847 47.505398," \
+ "7.620855 47.505375," \
+ "7.62086 47.50535," \
+ "7.620858 47.50532," \
+ "7.62086 47.505295," \
+ "7.62086 47.505264," \
+ "7.620862 47.505238," \
+ "7.620867 47.505215," \
+ "7.620872 47.50519," \
+ "7.62088 47.505165," \
+ "7.620897 47.50514," \
+ "7.620905 47.50512," \
+ "7.620922 47.505096," \
+ "7.62095 47.505074," \
+ "7.620973 47.505054," \
+ "7.621002 47.50503," \
+ "7.621022 47.50501," \
+ "7.621042 47.50498," \
+ "7.62106 47.504955," \
+ "7.621077 47.50493," \
+ "7.621093 47.5049," \
+ "7.621117 47.50488," \
+ "7.621138 47.50486," \
+ "7.621165 47.504845," \
+ "7.62119 47.504826," \
+ "7.621218 47.504807," \
+ "7.62124 47.504784," \
+ "7.621267 47.50476," \
+ "7.621297 47.504734," \
+ "7.62133 47.50471," \
+ "7.621368 47.50469," \
+ "7.621392 47.504673," \
+ "7.621413 47.50466," \
+ "7.62144 47.504646," \
+ "7.621468 47.50463," \
+ "7.621502 47.504612," \
+ "7.621525 47.504585," \
+ "7.621545 47.50456," \
+ "7.62156 47.50453," \
+ "7.621575 47.50451," \
+ "7.62159 47.504486," \
+ "7.62161 47.504467," \
+ "7.621637 47.50445," \
+ "7.621657 47.504433," \
+ "7.621683 47.504414," \
+ "7.621702 47.5044," \
+ "7.62172 47.50438," \
+ "7.621742 47.504364," \
+ "7.621767 47.50435," \
+ "7.621798 47.504333," \
+ "7.62183 47.50432," \
+ "7.621858 47.504295," \
+ "7.621887 47.50428," \
+ "7.621918 47.504265," \
+ "7.621943 47.504246," \
+ "7.621963 47.50423," \
+ "7.621982 47.50421," \
+ "7.622 47.50419," \
+ "7.622023 47.504173," \
+ "7.622057 47.50416," \
+ "7.622087 47.504147," \
+ "7.62212 47.50413," \
+ "7.622143 47.504116," \
+ "7.622173 47.5041," \
+ "7.62221 47.50409," \
+ "7.62224 47.50407," \
+ "7.62227 47.50405," \
+ "7.622302 47.50404," \
+ "7.622332 47.504025," \
+ "7.62236 47.504013," \
+ "7.622388 47.503994," \
+ "7.622418 47.50398," \
+ "7.622447 47.503963," \
+ "7.62247 47.50394," \
+ "7.622497 47.50392," \
+ "7.622525 47.5039," \
+ "7.622553 47.50388," \
+ "7.622578 47.503857," \
+ "7.622602 47.503838," \
+ "7.622622 47.503815," \
+ "7.622645 47.50379," \
+ "7.622668 47.503773," \
+ "7.622695 47.503754," \
+ "7.622723 47.503735," \
+ "7.622752 47.503716," \
+ "7.622787 47.503696," \
+ "7.622822 47.50368," \
+ "7.622858 47.503666," \
+ "7.622892 47.503647," \
+ "7.622923 47.503624," \
+ "7.622962 47.503605," \
+ "7.623003 47.503593," \
+ "7.62303 47.503574," \
+ "7.623058 47.503563," \
+ "7.623098 47.50355," \
+ "7.62314 47.503548," \
+ "7.623173 47.503536," \
+ "7.623203 47.503525," \
+ "7.623225 47.50351," \
+ "7.62325 47.503494," \
+ "7.623277 47.50348," \
+ "7.623307 47.503464," \
+ "7.623332 47.50345," \
+ "7.623357 47.50343," \
+ "7.623377 47.50341," \
+ "7.623403 47.50339," \
+ "7.623427 47.503376," \
+ "7.623455 47.50336," \
+ "7.623485 47.503345," \
+ "7.62351 47.503338," \
+ "7.623532 47.503323," \
+ "7.623557 47.503307," \
+ "7.623582 47.503292," \
+ "7.62361 47.50328," \
+ "7.623645 47.503273," \
+ "7.623682 47.50326," \
+ "7.623713 47.503246," \
+ "7.623752 47.50324," \
+ "7.623785 47.50323," \
+ "7.62382 47.50323," \
+ "7.623858 47.503242," \
+ "7.623882 47.503242," \
+ "7.623893 47.503242," \
+ "7.623907 47.503246," \
+ "7.623918 47.503258," \
+ "7.62392 47.503273," \
+ "7.623925 47.503292," \
+ "7.623937 47.503307," \
+ "7.623938 47.503326," \
+ "7.623937 47.50334," \
+ "7.623928 47.50336," \
+ "7.623923 47.503384," \
+ "7.623922 47.503407," \
+ "7.62391 47.503426," \
+ "7.623893 47.50345," \
+ "7.623863 47.503464," \
+ "7.623835 47.503487," \
+ "7.623803 47.50351," \
+ "7.623772 47.50353," \
+ "7.623747 47.50355," \
+ "7.623725 47.50357," \
+ "7.623702 47.503593," \
+ "7.623677 47.503616," \
+ "7.623657 47.503643," \
+ "7.623632 47.503666," \
+ "7.623605 47.503685," \
+ "7.623572 47.5037," \
+ "7.623533 47.50371," \
+ "7.623497 47.503727," \
+ "7.62347 47.503735," \
+ "7.623448 47.503742," \
+ "7.623427 47.50376," \
+ "7.623407 47.503784," \
+ "7.623383 47.503803," \
+ "7.623363 47.503822," \
+ "7.623342 47.50384," \
+ "7.623322 47.50386," \
+ "7.6233 47.503876," \
+ "7.623282 47.50389," \
+ "7.623263 47.503914," \
+ "7.623242 47.503937," \
+ "7.623217 47.50396," \
+ "7.623192 47.50398," \
+ "7.623168 47.503998," \
+ "7.62315 47.504013," \
+ "7.62313 47.504032," \
+ "7.623103 47.50405," \
+ "7.623078 47.504074," \
+ "7.623058 47.504097," \
+ "7.62304 47.504124," \
+ "7.623018 47.504147," \
+ "7.623005 47.504173," \
+ "7.622997 47.504196," \
+ "7.62299 47.504223," \
+ "7.62298 47.50425," \
+ "7.622973 47.504276," \
+ "7.622967 47.504314," \
+ "7.622957 47.50435," \
+ "7.622942 47.50438," \
+ "7.622927 47.504414," \
+ "7.62292 47.504448," \
+ "7.622915 47.50448," \
+ "7.622907 47.50451," \
+ "7.622893 47.50454," \
+ "7.622888 47.50457," \
+ "7.622888 47.504604," \
+ "7.622872 47.50463," \
+ "7.622848 47.504654," \
+ "7.62283 47.50468," \
+ "7.622817 47.504707," \
+ "7.62281 47.50473," \
+ "7.6228 47.504757," \
+ "7.622785 47.504784," \
+ "7.622768 47.50481," \
+ "7.62275 47.504837," \
+ "7.62274 47.504868," \
+ "7.622723 47.504887," \
+ "7.622718 47.504917," \
+ "7.622707 47.504948," \
+ "7.622695 47.50498," \
+ "7.62269 47.505," \
+ "7.622683 47.505028," \
+ "7.622678 47.50505," \
+ "7.622677 47.505077," \
+ "7.622675 47.5051," \
+ "7.622673 47.505123," \
+ "7.622673 47.505154," \
+ "7.622672 47.50519," \
+ "7.62267 47.505226," \
+ "7.622668 47.505257," \
+ "7.622675 47.505283," \
+ "7.622677 47.505302," \
+ "7.62268 47.50533," \
+ "7.622677 47.50535," \
+ "7.622668 47.505367," \
+ "7.622663 47.505394," \
+ "7.62266 47.505424," \
+ "7.622658 47.505447," \
+ "7.622653 47.505486," \
+ "7.62266 47.50552," \
+ "7.622677 47.505566," \
+ "7.622678 47.505596," \
+ "7.622678 47.505627," \
+ "7.622682 47.505653," \
+ "7.622695 47.505672," \
+ "7.622717 47.50569," \
+ "7.622758 47.505722," \
+ "7.622795 47.505733," \
+ "7.622827 47.505737," \
+ "7.622862 47.505753," \
+ "7.622903 47.505768," \
+ "7.622942 47.50578," \
+ "7.622968 47.505783," \
+ "7.623 47.505787," \
+ "7.623028 47.50578," \
+ "7.623058 47.50577," \
+ "7.62309 47.50576," \
+ "7.623127 47.505753," \
+ "7.62316 47.50574," \
+ "7.623192 47.505733," \
+ "7.623227 47.50573," \
+ "7.623258 47.50572," \
+ "7.623285 47.505703," \
+ "7.62331 47.50569," \
+ "7.623337 47.505684," \
+ "7.623363 47.505672," \
+ "7.623392 47.505657," \
+ "7.62342 47.505642," \
+ "7.623452 47.50563," \
+ "7.623482 47.505623," \
+ "7.623505 47.50561," \
+ "7.623523 47.505596," \
+ "7.623545 47.50559," \
+ "7.62357 47.505577," \
+ "7.623598 47.50556," \
+ "7.623637 47.505547," \
+ "7.623672 47.50553," \
+ "7.623697 47.505512," \
+ "7.623717 47.5055," \
+ "7.623748 47.505493," \
+ "7.623783 47.50549," \
+ "7.623828 47.50549," \
+ "7.623873 47.505486," \
+ "7.623908 47.505478," \
+ "7.623942 47.505466," \
+ "7.623968 47.505455," \
+ "7.623993 47.505444," \
+ "7.624015 47.505432," \
+ "7.62404 47.50542," \
+ "7.62407 47.50541," \
+ "7.624097 47.505398," \
+ "7.624125 47.505383," \
+ "7.624155 47.50537," \
+ "7.62418 47.50536," \
+ "7.62421 47.50535," \
+ "7.624243 47.505337," \
+ "7.624278 47.505318," \
+ "7.624312 47.505302," \
+ "7.624338 47.505287," \
+ "7.624372 47.505272," \
+ "7.62441 47.50526," \
+ "7.62446 47.50525," \
+ "7.624505 47.505238," \
+ "7.624532 47.505222," \
+ "7.624567 47.505215," \
+ "7.624593 47.5052," \
+ "7.624625 47.50519," \
+ "7.624653 47.505177," \
+ "7.62468 47.505165," \
+ "7.624702 47.505146," \
+ "7.624715 47.505123," \
+ "7.624738 47.5051," \
+ "7.624758 47.50508," \
+ "7.624777 47.505062," \
+ "7.62479 47.505047," \
+ "7.624807 47.505028," \
+ "7.624838 47.50501," \
+ "7.624862 47.504986," \
+ "7.62489 47.504963," \
+ "7.624907 47.504944," \
+ "7.624922 47.50492," \
+ "7.624933 47.504898," \
+ "7.624947 47.50487," \
+ "7.624957 47.504852," \
+ "7.624967 47.50483," \
+ "7.624975 47.50481," \
+ "7.62498 47.50479," \
+ "7.62499 47.504776," \
+ "7.625028 47.504753," \
+ "7.625058 47.504745," \
+ "7.625085 47.50473," \
+ "7.625108 47.50472," \
+ "7.625127 47.504704," \
+ "7.625148 47.504684," \
+ "7.625165 47.50467," \
+ "7.625185 47.504654," \
+ "7.62521 47.504642," \
+ "7.625233 47.504627," \
+ "7.625255 47.504616," \
+ "7.625282 47.504604," \
+ "7.625308 47.50459," \
+ "7.625337 47.504574," \
+ "7.625362 47.50456," \
+ "7.62539 47.504547," \
+ "7.625423 47.504536," \
+ "7.625452 47.504517," \
+ "7.625463 47.504486," \
+ "7.625502 47.50448," \
+ "7.625525 47.504467," \
+ "7.625552 47.504456," \
+ "7.625582 47.50445," \
+ "7.625612 47.504444," \
+ "7.625652 47.504444," \
+ "7.625683 47.504444," \
+ "7.625708 47.504444," \
+ "7.625725 47.50444," \
+ "7.625737 47.504448," \
+ "7.625752 47.50446," \
+ "7.625757 47.504475," \
+ "7.625763 47.50449," \
+ "7.625772 47.5045," \
+ "7.625782 47.50452," \
+ "7.625787 47.504536," \
+ "7.625783 47.50455," \
+ "7.62578 47.504574," \
+ "7.625772 47.504597," \
+ "7.625757 47.504616," \
+ "7.625743 47.50464," \
+ "7.625727 47.50466," \
+ "7.62571 47.504684," \
+ "7.625692 47.50471," \
+ "7.62569 47.504738," \
+ "7.625692 47.504765," \
+ "7.625697 47.504787," \
+ "7.625703 47.504807," \
+ "7.625702 47.504833," \
+ "7.625707 47.504856," \
+ "7.625715 47.50488," \
+ "7.625715 47.504906," \
+ "7.625722 47.50493," \
+ "7.625728 47.504948," \
+ "7.62573 47.50497," \
+ "7.625742 47.505," \
+ "7.625747 47.50503," \
+ "7.625758 47.50506," \
+ "7.625778 47.505093," \
+ "7.625793 47.505116," \
+ "7.625805 47.50514," \
+ "7.625808 47.50516," \
+ "7.625818 47.505188," \
+ "7.625837 47.505215," \
+ "7.625847 47.505238," \
+ "7.625857 47.505272," \
+ "7.62587 47.505306," \
+ "7.62588 47.50533," \
+ "7.625887 47.505352," \
+ "7.62589 47.50538," \
+ "7.625893 47.505398," \
+ "7.625902 47.505417," \
+ "7.625912 47.505436," \
+ "7.625923 47.505455," \
+ "7.62594 47.50548," \
+ "7.625955 47.50551," \
+ "7.625967 47.50554," \
+ "7.625982 47.505573," \
+ "7.626 47.505604," \
+ "7.62601 47.505627," \
+ "7.626022 47.505657," \
+ "7.626033 47.505684," \
+ "7.626048 47.50571," \
+ "7.626072 47.50574," \
+ "7.626092 47.50578," \
+ "7.626105 47.50581," \
+ "7.626118 47.505844," \
+ "7.626133 47.50588," \
+ "7.62615 47.505913," \
+ "7.626173 47.505943," \
+ "7.6262 47.505974," \
+ "7.626233 47.50601," \
+ "7.626257 47.50603," \
+ "7.626282 47.50605," \
+ "7.626308 47.50607," \
+ "7.626335 47.50609," \
+ "7.626363 47.506104," \
+ "7.626393 47.506123," \
+ "7.62642 47.506138," \
+ "7.626453 47.506153," \
+ "7.626492 47.50617," \
+ "7.626533 47.50618," \
+ "7.626578 47.50619," \
+ "7.626623 47.506195," \
+ "7.626658 47.50619," \
+ "7.626693 47.50618," \
+ "7.626725 47.50617," \
+ "7.626758 47.506157," \
+ "7.626788 47.50615," \
+ "7.626817 47.506134," \
+ "7.62684 47.50612," \
+ "7.62686 47.506104," \
+ "7.62687 47.506077," \
+ "7.62689 47.50606," \
+ "7.626918 47.50605," \
+ "7.626957 47.50605," \
+ "7.626995 47.506046," \
+ "7.627022 47.506035," \
+ "7.627047 47.506016," \
+ "7.627077 47.506004," \
+ "7.627102 47.505993," \
+ "7.627128 47.50598," \
+ "7.627152 47.505974," \
+ "7.62718 47.505974," \
+ "7.627207 47.505962," \
+ "7.627233 47.505947," \
+ "7.627257 47.50593," \
+ "7.627278 47.505917," \
+ "7.627298 47.5059," \
+ "7.627308 47.505882," \
+ "7.627328 47.505867," \
+ "7.62735 47.50585," \
+ "7.627375 47.50584," \
+ "7.627398 47.50583," \
+ "7.627417 47.505814," \
+ "7.627437 47.505795," \
+ "7.627458 47.505775," \
+ "7.627482 47.505756," \
+ "7.6275 47.505737," \
+ "7.62751 47.50572," \
+ "7.627523 47.5057," \
+ "7.62755 47.505684," \
+ "7.627572 47.505672," \
+ "7.627588 47.505653," \
+ "7.627622 47.505642," \
+ "7.627638 47.505627," \
+ "7.62765 47.505608," \
+ "7.627672 47.50559," \
+ "7.627695 47.505573," \
+ "7.627712 47.505558," \
+ "7.627732 47.50554," \
+ "7.627755 47.505524," \
+ "7.627778 47.50551," \
+ "7.627798 47.50549," \
+ "7.627822 47.50547," \
+ "7.627845 47.50546," \
+ "7.627872 47.505444," \
+ "7.627885 47.50542," \
+ "7.6279 47.505398," \
+ "7.627923 47.50538," \
+ "7.627948 47.505367," \
+ "7.627978 47.50535," \
+ "7.62801 47.50533," \
+ "7.628028 47.505306," \
+ "7.628038 47.50529," \
+ "7.628072 47.505283," \
+ "7.628092 47.505276," \
+ "7.628108 47.50526," \
+ "7.62813 47.50525," \
+ "7.628155 47.505234," \
+ "7.628178 47.505215," \
+ "7.628198 47.505203," \
+ "7.628212 47.50519," \
+ "7.628243 47.505177," \
+ "7.628283 47.50515," \
+ "7.628305 47.505127," \
+ "7.628327 47.505108," \
+ "7.628348 47.505096," \
+ "7.628372 47.50509," \
+ "7.628392 47.505077," \
+ "7.628407 47.505062," \
+ "7.62842 47.505047," \
+ "7.628433 47.50503," \
+ "7.628445 47.505016," \
+ "7.628458 47.505," \
+ "7.62847 47.504982," \
+ "7.628483 47.504967," \
+ "7.628495 47.504948," \
+ "7.628495 47.504917," \
+ "7.628505 47.5049," \
+ "7.628518 47.50489," \
+ "7.62852 47.504875," \
+ "7.628525 47.504864," \
+ "7.628532 47.50485," \
+ "7.62854 47.504833," \
+ "7.628545 47.50482," \
+ "7.628555 47.504807," \
+ "7.628565 47.50479," \
+ "7.628572 47.504776," \
+ "7.628582 47.50476," \
+ "7.628598 47.50475," \
+ "7.628608 47.504738," \
+ "7.628615 47.504723," \
+ "7.628628 47.504707," \
+ "7.62864 47.504692," \
+ "7.62865 47.504673," \
+ "7.62866 47.504654," \
+ "7.628667 47.50464," \
+ "7.628675 47.50462," \
+ "7.628678 47.504597," \
+ "7.628662 47.504566," \
+ "7.628665 47.504543," \
+ "7.62866 47.50452," \
+ "7.628667 47.504498," \
+ "7.628672 47.50447," \
+ "7.628673 47.504448," \
+ "7.628668 47.504417," \
+ "7.62867 47.50439," \
+ "7.628663 47.504364," \
+ "7.628653 47.504337," \
+ "7.628645 47.50431," \
+ "7.628645 47.504288," \
+ "7.628655 47.504265," \
+ "7.628662 47.50424," \
+ "7.628657 47.50421," \
+ "7.628652 47.504185," \
+ "7.62865 47.504154," \
+ "7.628642 47.504128," \
+ "7.628653 47.504112," \
+ "7.628675 47.5041," \
+ "7.628697 47.504086," \
+ "7.628722 47.50408," \
+ "7.62873 47.504066," \
+ "7.628732 47.50405," \
+ "7.62874 47.504044," \
+ "7.628752 47.504032," \
+ "7.62876 47.50402," \
+ "7.628762 47.504005," \
+ "7.628763 47.50399," \
+ "7.628765 47.50398," \
+ "7.628767 47.503967," \
+ "7.628775 47.503956," \
+ "7.628778 47.50394," \
+ "7.628783 47.503918," \
+ "7.628785 47.5039," \
+ "7.628787 47.50388," \
+ "7.62879 47.50386," \
+ "7.628802 47.503838," \
+ "7.628818 47.503815," \
+ "7.628832 47.503788," \
+ "7.628845 47.50376," \
+ "7.62886 47.50374," \
+ "7.62886 47.50371," \
+ "7.628857 47.50368," \
+ "7.628852 47.50366," \
+ "7.628855 47.503643," \
+ "7.628863 47.503624," \
+ "7.628878 47.50361," \
+ "7.628885 47.503586," \
+ "7.628887 47.50357," \
+ "7.628895 47.50355," \
+ "7.628903 47.50353," \
+ "7.62891 47.5035," \
+ "7.628923 47.503483," \
+ "7.628937 47.503468," \
+ "7.628947 47.503445," \
+ "7.628952 47.50342," \
+ "7.628958 47.5034," \
+ "7.628973 47.50338," \
+ "7.628995 47.50337," \
+ "7.629018 47.503353," \
+ "7.629035 47.50334," \
+ "7.62905 47.50333," \
+ "7.629057 47.50331," \
+ "7.62906 47.503284," \
+ "7.629063 47.503258," \
+ "7.629075 47.503227," \
+ "7.62909 47.503204," \
+ "7.629098 47.503174," \
+ "7.6291 47.503143," \
+ "7.629122 47.503124," \
+ "7.62913 47.503094," \
+ "7.629152 47.503082," \
+ "7.629168 47.503067," \
+ "7.629183 47.50305," \
+ "7.6292 47.503036," \
+ "7.629222 47.50302," \
+ "7.629243 47.50301," \
+ "7.62926 47.502995," \
+ "7.629267 47.50297," \
+ "7.629272 47.502953," \
+ "7.629288 47.502937," \
+ "7.629308 47.502926," \
+ "7.629318 47.50291," \
+ "7.62933 47.502876," \
+ "7.629352 47.50285," \
+ "7.629368 47.502827," \
+ "7.62938 47.502808," \
+ "7.629393 47.50279," \
+ "7.629402 47.50276," \
+ "7.629418 47.502743," \
+ "7.62944 47.502728," \
+ "7.629465 47.502712," \
+ "7.629483 47.502693," \
+ "7.629508 47.50268," \
+ "7.629537 47.502674," \
+ "7.629563 47.502663," \
+ "7.629578 47.502647," \
+ "7.629592 47.502632," \
+ "7.629602 47.502617," \
+ "7.629618 47.502605," \
+ "7.629635 47.502594," \
+ "7.629662 47.50258," \
+ "7.629683 47.502563," \
+ "7.629697 47.502552," \
+ "7.629703 47.502537," \
+ "7.629713 47.502518," \
+ "7.62973 47.502495," \
+ "7.62975 47.50247," \
+ "7.629763 47.50245," \
+ "7.629778 47.502434," \
+ "7.629788 47.50241," \
+ "7.629788 47.502388," \
+ "7.629793 47.502365," \
+ "7.629802 47.50235," \
+ "7.629807 47.502335," \
+ "7.629817 47.50232," \
+ "7.629833 47.502316," \
+ "7.629853 47.502316," \
+ "7.629868 47.502308," \
+ "7.62989 47.502308," \
+ "7.629912 47.50231," \
+ "7.629927 47.50231," \
+ "7.62994 47.502316," \
+ "7.629945 47.50232," \
+ "7.629952 47.502327," \
+ "7.629952 47.502335," \
+ "7.629948 47.502346," \
+ "7.629947 47.502357," \
+ "7.629945 47.502373," \
+ "7.629937 47.502388," \
+ "7.629933 47.502403," \
+ "7.629935 47.50242," \
+ "7.629933 47.502434," \
+ "7.629925 47.50245," \
+ "7.629927 47.502464," \
+ "7.629928 47.502483," \
+ "7.629928 47.502506," \
+ "7.629933 47.502525," \
+ "7.629927 47.502544," \
+ "7.62993 47.502563," \
+ "7.62994 47.502583," \
+ "7.629942 47.502605," \
+ "7.629937 47.502625," \
+ "7.629923 47.502636," \
+ "7.629912 47.502644," \
+ "7.62992 47.502666," \
+ "7.62993 47.502697," \
+ "7.629935 47.50273," \
+ "7.629942 47.50276," \
+ "7.629942 47.502785," \
+ "7.629947 47.502804," \
+ "7.629952 47.502827," \
+ "7.629957 47.502846," \
+ "7.62996 47.502865," \
+ "7.629967 47.50288," \
+ "7.629973 47.5029," \
+ "7.629978 47.50292," \
+ "7.629987 47.502945," \
+ "7.629987 47.502964," \
+ "7.629995 47.502995," \
+ "7.629998 47.503025," \
+ "7.63 47.50305," \
+ "7.629995 47.503075," \
+ "7.629992 47.503098," \
+ "7.629995 47.50313," \
+ "7.629997 47.503155," \
+ "7.630008 47.50318," \
+ "7.63002 47.503204," \
+ "7.630033 47.50323," \
+ "7.630042 47.503254," \
+ "7.63005 47.50328," \
+ "7.63006 47.503304," \
+ "7.630065 47.50333," \
+ "7.630072 47.503357," \
+ "7.630077 47.50338," \
+ "7.630083 47.503403," \
+ "7.630085 47.50342," \
+ "7.630087 47.50344," \
+ "7.630093 47.503464," \
+ "7.630097 47.503487," \
+ "7.6301 47.50351," \
+ "7.630112 47.503532," \
+ "7.630123 47.503567," \
+ "7.630128 47.5036," \
+ "7.630132 47.503628," \
+ "7.630133 47.50365," \
+ "7.630142 47.503677," \
+ "7.630143 47.503696," \
+ "7.630145 47.503723," \
+ "7.63014 47.503746," \
+ "7.630133 47.503773," \
+ "7.630127 47.5038," \
+ "7.630128 47.503826," \
+ "7.630132 47.503853," \
+ "7.630132 47.503876," \
+ "7.630133 47.5039," \
+ "7.63014 47.50392," \
+ "7.630135 47.503944," \
+ "7.630143 47.503975," \
+ "7.630143 47.504005," \
+ "7.63016 47.504044," \
+ "7.630183 47.50408," \
+ "7.630202 47.50411," \
+ "7.63022 47.504128," \
+ "7.63025 47.504158," \
+ "7.630268 47.50418," \
+ "7.630315 47.504215," \
+ "7.630343 47.50424," \
+ "7.630372 47.504253," \
+ "7.630398 47.504265," \
+ "7.630425 47.50427," \
+ "7.630455 47.504265," \
+ "7.630483 47.504257," \
+ "7.63051 47.504246," \
+ "7.630538 47.504227," \
+ "7.630557 47.504204," \
+ "7.630575 47.50419," \
+ "7.630593 47.504173," \
+ "7.630607 47.50416," \
+ "7.630615 47.504147," \
+ "7.630627 47.50413," \
+ "7.63064 47.504124," \
+ "7.630655 47.50411," \
+ "7.630668 47.504093," \
+ "7.630683 47.50408," \
+ "7.6307 47.50406," \
+ "7.630712 47.504032," \
+ "7.630732 47.504013," \
+ "7.630752 47.503986," \
+ "7.63077 47.503963," \
+ "7.630793 47.503933," \
+ "7.630803 47.503902," \
+ "7.630815 47.503872," \
+ "7.630833 47.50384," \
+ "7.630855 47.50381," \
+ "7.630877 47.503788," \
+ "7.630898 47.50377," \
+ "7.630918 47.50375," \
+ "7.630937 47.503727," \
+ "7.630952 47.503708," \
+ "7.630968 47.50369," \
+ "7.630985 47.503662," \
+ "7.631007 47.503647," \
+ "7.631025 47.503624," \
+ "7.631047 47.5036," \
+ "7.631073 47.50357," \
+ "7.631095 47.503548," \
+ "7.631113 47.50353," \
+ "7.631128 47.503506," \
+ "7.631143 47.503487," \
+ "7.631157 47.50347," \
+ "7.631168 47.503452," \
+ "7.631183 47.503437," \
+ "7.631202 47.503418," \
+ "7.631213 47.50339," \
+ "7.63124 47.503372," \
+ "7.631263 47.503353," \
+ "7.631292 47.503338," \
+ "7.631312 47.503323," \
+ "7.631328 47.503304," \
+ "7.631353 47.50329," \
+ "7.631375 47.503277," \
+ "7.631402 47.50326," \
+ "7.631427 47.50324," \
+ "7.631452 47.503216," \
+ "7.631485 47.503197," \
+ "7.631513 47.503178," \
+ "7.631543 47.503166," \
+ "7.631572 47.503143," \
+ "7.631602 47.503124," \
+ "7.631623 47.5031," \
+ "7.631645 47.50308," \
+ "7.631665 47.50306," \
+ "7.631695 47.50304," \
+ "7.631717 47.50303," \
+ "7.631735 47.503002," \
+ "7.631753 47.502983," \
+ "7.631777 47.502968," \
+ "7.631803 47.502956," \
+ "7.631832 47.502953," \
+ "7.631863 47.50294," \
+ "7.631897 47.50293," \
+ "7.63194 47.50292," \
+ "7.631972 47.502895," \
+ "7.632 47.502888," \
+ "7.63203 47.50288," \
+ "7.632058 47.50287," \
+ "7.632103 47.502853," \
+ "7.632145 47.50283," \
+ "7.632183 47.502815," \
+ "7.632215 47.502796," \
+ "7.632245 47.50278," \
+ "7.632273 47.502766," \
+ "7.6323 47.502747," \
+ "7.632333 47.502728," \
+ "7.632372 47.50271," \
+ "7.632413 47.502697," \
+ "7.632445 47.502686," \
+ "7.632482 47.50267," \
+ "7.63252 47.502663," \
+ "7.632545 47.50265," \
+ "7.63258 47.50265," \
+ "7.632617 47.50265," \
+ "7.63266 47.50266," \
+ "7.632695 47.502666," \
+ "7.632727 47.50267," \
+ "7.632748 47.50267," \
+ "7.63277 47.502678," \
+ "7.632798 47.50268," \
+ "7.632823 47.502693," \
+ "7.632848 47.502705," \
+ "7.63288 47.502716," \
+ "7.632912 47.50273," \
+ "7.632943 47.502747," \
+ "7.632972 47.502758," \
+ "7.633002 47.502766," \
+ "7.633033 47.502777," \
+ "7.633068 47.502785," \
+ "7.633113 47.502792," \
+ "7.633143 47.502796," \
+ "7.633168 47.502792," \
+ "7.633207 47.502804," \
+ "7.63324 47.502815," \
+ "7.63327 47.502823," \
+ "7.633313 47.50284," \
+ "7.633353 47.502857," \
+ "7.633395 47.50287," \
+ "7.633438 47.502876," \
+ "7.633475 47.50288," \
+ "7.633505 47.502884," \
+ "7.63354 47.50289," \
+ "7.633578 47.502903," \
+ "7.633613 47.502907," \
+ "7.633648 47.50291," \
+ "7.633672 47.502914," \
+ "7.633702 47.502922," \
+ "7.633738 47.502934," \
+ "7.633773 47.502934," \
+ "7.63381 47.50294," \
+ "7.633842 47.50295," \
+ "7.633877 47.502956," \
+ "7.633918 47.50297," \
+ "7.633957 47.502987," \
+ "7.633993 47.503," \
+ "7.63403 47.503006," \
+ "7.634067 47.503014," \
+ "7.634107 47.50303," \
+ "7.634152 47.503044," \
+ "7.634192 47.503056," \
+ "7.634233 47.503067," \
+ "7.634267 47.50308," \
+ "7.634308 47.50309," \
+ "7.634343 47.503105," \
+ "7.634387 47.503124," \
+ "7.634423 47.503136," \
+ "7.634457 47.503143," \
+ "7.634488 47.503147," \
+ "7.634522 47.50315," \
+ "7.634562 47.503162," \
+ "7.634603 47.503174," \
+ "7.63465 47.503185," \
+ "7.63469 47.50319," \
+ "7.634727 47.50319," \
+ "7.634762 47.503185," \
+ "7.634802 47.50318," \
+ "7.634832 47.50317," \
+ "7.634872 47.503166," \
+ "7.634907 47.503162," \
+ "7.634937 47.503155," \
+ "7.634977 47.503155," \
+ "7.635012 47.503147," \
+ "7.635043 47.503136," \
+ "7.635092 47.503136," \
+ "7.635128 47.50313," \
+ "7.635155 47.503117," \
+ "7.635188 47.503113," \
+ "7.635222 47.5031," \
+ "7.635253 47.50309," \
+ "7.635292 47.503086," \
+ "7.635332 47.50308," \
+ "7.635368 47.50307," \
+ "7.635407 47.503063," \
+ "7.635448 47.50306," \
+ "7.635483 47.50305," \
+ "7.63551 47.503036," \
+ "7.635552 47.50303," \
+ "7.635598 47.50302," \
+ "7.63564 47.503014," \
+ "7.635687 47.503014," \
+ "7.635732 47.503006," \
+ "7.635765 47.50299," \
+ "7.6358 47.502975," \
+ "7.635833 47.502964," \
+ "7.635868 47.50295," \
+ "7.635898 47.502934," \
+ "7.63592 47.502907," \
+ "7.63595 47.50289," \
+ "7.635978 47.502872," \
+ "7.636005 47.502857," \
+ "7.636028 47.502846," \
+ "7.636063 47.50284," \
+ "7.63609 47.50282," \
+ "7.636108 47.502796," \
+ "7.636127 47.502773," \
+ "7.636145 47.50275," \
+ "7.636168 47.502735," \
+ "7.636198 47.50272," \
+ "7.636233 47.502705," \
+ "7.636257 47.502686," \
+ "7.636285 47.50267," \
+ "7.636305 47.50265," \
+ "7.636327 47.502644," \
+ "7.63635 47.502636," \
+ "7.636372 47.50262," \
+ "7.636392 47.5026," \
+ "7.636422 47.502583," \
+ "7.636448 47.502556," \
+ "7.636462 47.50253," \
+ "7.636483 47.502506," \
+ "7.636507 47.502483," \
+ "7.636528 47.50246," \
+ "7.636555 47.502445," \
+ "7.63659 47.50243," \
+ "7.636615 47.50241," \
+ "7.636637 47.50239," \
+ "7.63666 47.502377," \
+ "7.636692 47.502365," \
+ "7.636718 47.502346," \
+ "7.636747 47.502327," \
+ "7.636768 47.5023," \
+ "7.636783 47.502277," \
+ "7.636805 47.50225," \
+ "7.63683 47.50223," \
+ "7.636852 47.50221," \
+ "7.636873 47.50219," \
+ "7.636898 47.502167," \
+ "7.636928 47.50215," \
+ "7.636958 47.502136," \
+ "7.636995 47.50213," \
+ "7.63703 47.502117," \
+ "7.637065 47.50211," \
+ "7.637107 47.502106," \
+ "7.637145 47.5021," \
+ "7.6372 47.50211," \
+ "7.637233 47.502117," \
+ "7.637268 47.502125," \
+ "7.6373 47.50213," \
+ "7.637352 47.502148," \
+ "7.637393 47.50216," \
+ "7.637433 47.502163," \
+ "7.637473 47.50217," \
+ "7.637507 47.50218," \
+ "7.637537 47.502186," \
+ "7.637575 47.502193," \
+ "7.637613 47.502197," \
+ "7.637658 47.50221," \
+ "7.637702 47.502216," \
+ "7.637747 47.50222," \
+ "7.637788 47.502228," \
+ "7.637833 47.502235," \
+ "7.63788 47.502243," \
+ "7.637928 47.502247," \
+ "7.637978 47.502247," \
+ "7.638028 47.502247," \
+ "7.638077 47.50224," \
+ "7.638118 47.502228," \
+ "7.638165 47.502216," \
+ "7.638218 47.502216," \
+ "7.638275 47.50221," \
+ "7.63833 47.502197," \
+ "7.63837 47.50218," \
+ "7.638423 47.502167," \
+ "7.638468 47.50215," \
+ "7.638508 47.502136," \
+ "7.638553 47.502125," \
+ "7.638593 47.502113," \
+ "7.638638 47.5021," \
+ "7.638678 47.502087," \
+ "7.638725 47.502083," \
+ "7.638772 47.502075," \
+ "7.638818 47.502064," \
+ "7.638863 47.502056," \
+ "7.638905 47.502045," \
+ "7.638952 47.50203," \
+ "7.638993 47.502014," \
+ "7.639037 47.502003," \
+ "7.639083 47.501995," \
+ "7.639132 47.50199," \
+ "7.639172 47.50198," \
+ "7.639217 47.501972," \
+ "7.63926 47.501965," \
+ "7.639308 47.50196," \
+ "7.639357 47.501953," \
+ "7.639403 47.501945," \
+ "7.63945 47.501934," \
+ "7.639492 47.501923," \
+ "7.639537 47.501907," \
+ "7.63958 47.50189," \
+ "7.639623 47.501877," \
+ "7.639662 47.501858," \
+ "7.639697 47.501835," \
+ "7.639728 47.50181," \
+ "7.63976 47.50178," \
+ "7.639778 47.501755," \
+ "7.6398 47.50173," \
+ "7.639825 47.501713," \
+ "7.63985 47.501686," \
+ "7.639865 47.501656," \
+ "7.639877 47.50162," \
+ "7.639892 47.501587," \
+ "7.639903 47.501556," \
+ "7.639907 47.501522," \
+ "7.63991 47.501495," \
+ "7.639912 47.50147," \
+ "7.639908 47.50145," \
+ "7.639902 47.501427," \
+ "7.639897 47.501408," \
+ "7.639893 47.501385," \
+ "7.639888 47.50136," \
+ "7.639882 47.50133," \
+ "7.639872 47.501305," \
+ "7.639857 47.501278," \
+ "7.639838 47.50125," \
+ "7.63982 47.501225," \
+ "7.639795 47.501198," \
+ "7.639772 47.50116," \
+ "7.639762 47.50113," \
+ "7.639745 47.5011," \
+ "7.639727 47.501072," \
+ "7.639712 47.501045," \
+ "7.639693 47.50102," \
+ "7.639673 47.500988," \
+ "7.639657 47.500954," \
+ "7.639635 47.500927," \
+ "7.639615 47.500896," \
+ "7.639597 47.500866," \
+ "7.63957 47.500824," \
+ "7.639548 47.50078," \
+ "7.63952 47.50075," \
+ "7.6395 47.500725," \
+ "7.639473 47.5007," \
+ "7.639447 47.50067," \
+ "7.639415 47.50064," \
+ "7.639392 47.500618," \
+ "7.639368 47.500595," \
+ "7.639348 47.500576," \
+ "7.639323 47.50052," \
+ "7.639293 47.500477," \
+ "7.639267 47.500446," \
+ "7.639227 47.500412," \
+ "7.639197 47.50038," \
+ "7.639175 47.500347," \
+ "7.639155 47.500317," \
+ "7.639128 47.500294," \
+ "7.639093 47.50027," \
+ "7.63906 47.50025," \
+ "7.639035 47.50023," \
+ "7.639 47.500202," \
+ "7.63897 47.500175," \
+ "7.638935 47.50015," \
+ "7.63891 47.50012," \
+ "7.638885 47.5001," \
+ "7.638857 47.500076," \
+ "7.638827 47.50006," \
+ "7.638788 47.500046," \
+ "7.638755 47.500027," \
+ "7.638715 47.500004," \
+ "7.638682 47.49999," \
+ "7.638648 47.49996," \
+ "7.638613 47.499943," \
+ "7.638578 47.49992," \
+ "7.63854 47.499893," \
+ "7.6385 47.499874," \
+ "7.63846 47.49985," \
+ "7.638422 47.499832," \
+ "7.638393 47.499817," \
+ "7.638357 47.49979," \
+ "7.638312 47.499763," \
+ "7.638273 47.499744," \
+ "7.63823 47.49972," \
+ "7.638188 47.4997," \
+ "7.63816 47.499683," \
+ "7.638137 47.49966," \
+ "7.63811 47.49964," \
+ "7.6381 47.499615," \
+ "7.638078 47.49959," \
+ "7.638052 47.49956," \
+ "7.638025 47.499535," \
+ "7.638002 47.499516," \
+ "7.637965 47.499496," \
+ "7.637933 47.49947," \
+ "7.637905 47.499447," \
+ "7.637883 47.499413," \
+ "7.63787 47.49939," \
+ "7.637858 47.49936," \
+ "7.637852 47.49933," \
+ "7.637853 47.499302," \
+ "7.637862 47.499275," \
+ "7.637887 47.49926," \
+ "7.637913 47.499245," \
+ "7.637948 47.49923," \
+ "7.637983 47.49922," \
+ "7.63803 47.499218," \
+ "7.638082 47.499218," \
+ "7.63813 47.499214," \
+ "7.638175 47.49921," \
+ "7.638217 47.499207," \
+ "7.638258 47.499195," \
+ "7.638302 47.49919," \
+ "7.638348 47.499187," \
+ "7.638395 47.499187," \
+ "7.638447 47.499187," \
+ "7.63849 47.49918," \
+ "7.63854 47.499176," \
+ "7.63859 47.49917," \
+ "7.638647 47.49917," \
+ "7.638697 47.499165," \
+ "7.638738 47.499153," \
+ "7.63878 47.49914," \
+ "7.63883 47.499126," \
+ "7.63888 47.49912," \
+ "7.638928 47.49911," \
+ "7.638975 47.499092," \
+ "7.639025 47.499077," \
+ "7.63907 47.49906," \
+ "7.639118 47.499046," \
+ "7.639162 47.49903," \
+ "7.639203 47.49901," \
+ "7.639257 47.499," \
+ "7.639308 47.49899," \
+ "7.63935 47.498974," \
+ "7.639397 47.498962," \
+ "7.639447 47.498955," \
+ "7.639493 47.49894," \
+ "7.639547 47.49893," \
+ "7.6396 47.49892," \
+ "7.639652 47.49891," \
+ "7.639695 47.498898," \
+ "7.639735 47.49888," \
+ "7.639783 47.49887," \
+ "7.63983 47.498856," \
+ "7.639877 47.498837," \
+ "7.639915 47.498802," \
+ "7.639947 47.498764," \
+ "7.63997 47.49872," \
+ "7.639978 47.498684," \
+ "7.63998 47.49865," \
+ "7.639968 47.498615," \
+ "7.639952 47.498585," \
+ "7.639932 47.498547," \
+ "7.639917 47.498512," \
+ "7.639907 47.498486," \
+ "7.639897 47.49846," \
+ "7.63988 47.498432," \
+ "7.639865 47.498405," \
+ "7.639853 47.498383," \
+ "7.639835 47.498356," \
+ "7.63981 47.49832," \
+ "7.639777 47.498283," \
+ "7.639753 47.498253," \
+ "7.63973 47.498226," \
+ "7.639703 47.4982," \
+ "7.639675 47.498173," \
+ "7.639632 47.49814," \
+ "7.639588 47.4981," \
+ "7.639543 47.498062," \
+ "7.639498 47.498028," \
+ "7.639452 47.497993," \
+ "7.639412 47.497955," \
+ "7.639372 47.497925," \
+ "7.639335 47.497894," \
+ "7.639303 47.497868," \
+ "7.639272 47.49784," \
+ "7.639238 47.497818," \
+ "7.639208 47.4978," \
+ "7.639182 47.497784," \
+ "7.639157 47.497757," \
+ "7.639133 47.497734," \
+ "7.639097 47.497707," \
+ "7.639058 47.49768," \
+ "7.639008 47.497646," \
+ "7.638942 47.497597," \
+ "7.638897 47.49756," \
+ "7.638872 47.497536," \
+ "7.638843 47.497517," \
+ "7.638808 47.49749," \
+ "7.638765 47.497467," \
+ "7.638723 47.497448," \
+ "7.638648 47.497417," \
+ "7.638588 47.4974," \
+ "7.638533 47.497375," \
+ "7.638482 47.49735," \
+ "7.63843 47.497314," \
+ "7.638392 47.49729," \
+ "7.638352 47.497265," \
+ "7.638307 47.497227," \
+ "7.63829 47.497196," \
+ "7.638247 47.49716," \
+ "7.638198 47.497124," \
+ "7.638163 47.4971," \
+ "7.638132 47.497078," \
+ "7.638102 47.497047," \
+ "7.63808 47.497032," \
+ "7.638048 47.497013," \
+ "7.638018 47.49699," \
+ "7.637988 47.49697," \
+ "7.63796 47.49695," \
+ "7.637935 47.496918," \
+ "7.637913 47.496883," \
+ "7.637872 47.49685," \
+ "7.637828 47.49682," \
+ "7.637792 47.496788," \
+ "7.637762 47.49675," \
+ "7.637737 47.496716," \
+ "7.637703 47.49668," \
+ "7.637673 47.496655," \
+ "7.63764 47.49662," \
+ "7.637608 47.496593," \
+ "7.63758 47.49656," \
+ "7.637558 47.496525," \
+ "7.637543 47.496487," \
+ "7.63754 47.496452," \
+ "7.637552 47.49642," \
+ "7.637578 47.49639," \
+ "7.63761 47.49637," \
+ "7.637643 47.49635," \
+ "7.637692 47.49634," \
+ "7.63775 47.49635," \
+ "7.63781 47.496357," \
+ "7.637872 47.49637," \
+ "7.637927 47.496372," \
+ "7.63798 47.496372," \
+ "7.638032 47.496376," \
+ "7.638098 47.496384," \
+ "7.638167 47.49639," \
+ "7.638223 47.4964," \
+ "7.638278 47.496407," \
+ "7.638337 47.49642," \
+ "7.638388 47.496426," \
+ "7.63844 47.496437," \
+ "7.638493 47.496445," \
+ "7.638543 47.49645," \
+ "7.6386 47.49645," \
+ "7.638658 47.496452," \
+ "7.638715 47.496456," \
+ "7.63877 47.496464," \
+ "7.63882 47.496464," \
+ "7.638867 47.496468," \
+ "7.638915 47.496468," \
+ "7.63897 47.496468," \
+ "7.639025 47.496464," \
+ "7.639087 47.49647," \
+ "7.639152 47.496483," \
+ "7.639218 47.496487," \
+ "7.639265 47.496494," \
+ "7.639315 47.4965," \
+ "7.639368 47.49651," \
+ "7.639403 47.496513," \
+ "7.639458 47.49653," \
+ "7.639493 47.496536," \
+ "7.639542 47.496555," \
+ "7.639587 47.496567," \
+ "7.639635 47.49658," \
+ "7.639687 47.496593," \
+ "7.639718 47.49661," \
+ "7.639762 47.496624," \
+ "7.639815 47.496643," \
+ "7.63987 47.496662," \
+ "7.639918 47.49668," \
+ "7.63996 47.496696," \
+ "7.64 47.49671," \
+ "7.64004 47.496723," \
+ "7.640088 47.496735," \
+ "7.640142 47.496742," \
+ "7.640187 47.496742," \
+ "7.640232 47.496742," \
+ "7.640295 47.496742," \
+ "7.640345 47.496742," \
+ "7.640395 47.496746," \
+ "7.64045 47.49675," \
+ "7.6405 47.49676," \
+ "7.640557 47.496773," \
+ "7.640612 47.496784," \
+ "7.64067 47.496803," \
+ "7.64072 47.49682," \
+ "7.640765 47.496834," \
+ "7.64081 47.496857," \
+ "7.640853 47.49688," \
+ "7.64089 47.496902," \
+ "7.640918 47.496914," \
+ "7.64095 47.49693," \
+ "7.640987 47.49695," \
+ "7.64102 47.496964," \
+ "7.64105 47.49698," \
+ "7.641077 47.496998," \
+ "7.641108 47.497017," \
+ "7.641158 47.497036," \
+ "7.641203 47.49705," \
+ "7.641253 47.497074," \
+ "7.6413 47.4971," \
+ "7.641347 47.497128," \
+ "7.641398 47.497154," \
+ "7.641458 47.49718," \
+ "7.641498 47.4972," \
+ "7.641538 47.497223," \
+ "7.641568 47.49725," \
+ "7.641607 47.497272," \
+ "7.641642 47.497288," \
+ "7.641685 47.497307," \
+ "7.641732 47.49733," \
+ "7.64178 47.49735," \
+ "7.641835 47.49737," \
+ "7.641892 47.497406," \
+ "7.641952 47.49744," \
+ "7.642008 47.497463," \
+ "7.642058 47.49748," \
+ "7.642115 47.4975," \
+ "7.642197 47.497528," \
+ "7.642265 47.49755," \
+ "7.64233 47.49758," \
+ "7.642392 47.497604," \
+ "7.642463 47.49763," \
+ "7.642517 47.497646," \
+ "7.642567 47.497654," \
+ "7.642625 47.49769," \
+ "7.642673 47.49769," \
+ "7.642718 47.49769," \
+ "7.642778 47.49771," \
+ "7.64284 47.497723," \
+ "7.642897 47.497738," \
+ "7.642955 47.49776," \
+ "7.64301 47.497784," \
+ "7.643073 47.497795," \
+ "7.643128 47.497818," \
+ "7.643173 47.497818," \
+ "7.643228 47.497837," \
+ "7.643277 47.49785," \
+ "7.643323 47.497852," \
+ "7.643365 47.497864," \
+ "7.643408 47.49788," \
+ "7.643458 47.497917," \
+ "7.643492 47.497932," \
+ "7.643533 47.49795," \
+ "7.64358 47.497993," \
+ "7.64361 47.498013," \
+ "7.643633 47.498024," \
+ "7.643657 47.49804," \
+ "7.643698 47.498077," \
+ "7.643732 47.49811," \
+ "7.64376 47.498154," \
+ "7.643785 47.498177," \
+ "7.64381 47.498203," \
+ "7.64383 47.498226," \
+ "7.643848 47.498253," \
+ "7.643872 47.498283," \
+ "7.643893 47.498314," \
+ "7.64391 47.498337," \
+ "7.643928 47.498363," \
+ "7.643947 47.498394," \
+ "7.643962 47.498417," \
+ "7.643978 47.498444," \
+ "7.644003 47.498478," \
+ "7.644027 47.498516," \
+ "7.64406 47.498558," \
+ "7.644082 47.498596," \
+ "7.644107 47.498634," \
+ "7.644133 47.49867," \
+ "7.644167 47.49871," \
+ "7.644198 47.498745," \
+ "7.64423 47.49878," \
+ "7.64426 47.498814," \
+ "7.644298 47.49885," \
+ "7.644333 47.498875," \
+ "7.64436 47.498894," \
+ "7.64441 47.498913," \
+ "7.644447 47.498936," \
+ "7.644483 47.498962," \
+ "7.644522 47.49899," \
+ "7.64456 47.499012," \
+ "7.644597 47.49903," \
+ "7.644635 47.499054," \
+ "7.644662 47.49907," \
+ "7.644687 47.49909," \
+ "7.644717 47.49911," \
+ "7.64474 47.49912," \
+ "7.644773 47.499138," \
+ "7.64481 47.499157," \
+ "7.644848 47.499172," \
+ "7.644882 47.49919," \
+ "7.644923 47.49922," \
+ "7.644955 47.49925," \
+ "7.644997 47.499283," \
+ "7.64503 47.499306," \
+ "7.645067 47.499332," \
+ "7.645092 47.499363," \
+ "7.645123 47.499386," \
+ "7.64516 47.499413," \
+ "7.645187 47.499435," \
+ "7.645223 47.49946," \
+ "7.645258 47.49949," \
+ "7.645307 47.49951," \
+ "7.645363 47.499535," \
+ "7.64542 47.49955," \
+ "7.645475 47.499554," \
+ "7.645537 47.49955," \
+ "7.645602 47.49955," \
+ "7.645657 47.499546," \
+ "7.645715 47.499554," \
+ "7.645782 47.49957," \
+ "7.645828 47.49958," \
+ "7.645853 47.4996," \
+ "7.645873 47.499622," \
+ "7.645902 47.499638," \
+ "7.645943 47.49964," \
+ "7.645978 47.499626," \
+ "7.645998 47.4996," \
+ "7.646022 47.49957," \
+ "7.64605 47.499535," \
+ "7.646073 47.4995," \
+ "7.646092 47.499462," \
+ "7.646112 47.49943," \
+ "7.646128 47.499405," \
+ "7.646143 47.499374," \
+ "7.646167 47.49934," \
+ "7.646193 47.499302," \
+ "7.64622 47.49927," \
+ "7.646242 47.49924," \
+ "7.646265 47.499214," \
+ "7.646307 47.49919," \
+ "7.646352 47.499165," \
+ "7.646387 47.49914," \
+ "7.646412 47.499107," \
+ "7.646455 47.49908," \
+ "7.646507 47.499054," \
+ "7.646552 47.499027," \
+ "7.646598 47.499012," \
+ "7.646643 47.49899," \
+ "7.646693 47.498966," \
+ "7.646752 47.498955," \
+ "7.646812 47.498943," \
+ "7.646878 47.49893," \
+ "7.64694 47.49892," \
+ "7.647008 47.498917," \
+ "7.647062 47.4989," \
+ "7.647108 47.498886," \
+ "7.647158 47.498875," \
+ "7.647195 47.498848," \
+ "7.647243 47.49882," \
+ "7.647295 47.498795," \
+ "7.64734 47.49877," \
+ "7.64738 47.49875," \
+ "7.64743 47.498722," \
+ "7.647475 47.4987," \
+ "7.647508 47.49867," \
+ "7.647547 47.498642," \
+ "7.64759 47.498615," \
+ "7.647617 47.49859," \
+ "7.647633 47.49855," \
+ "7.647647 47.498524," \
+ "7.647685 47.4985," \
+ "7.647723 47.49848," \
+ "7.64774 47.498455," \
+ "7.64775 47.49843," \
+ "7.647762 47.498398," \
+ "7.647783 47.49837," \
+ "7.647808 47.49835," \
+ "7.647835 47.49833," \
+ "7.647868 47.49829," \
+ "7.647902 47.49827," \
+ "7.64794 47.49825," \
+ "7.647973 47.498226," \
+ "7.648005 47.49821," \
+ "7.648042 47.498184," \
+ "7.648078 47.49816," \
+ "7.648107 47.49814," \
+ "7.648125 47.49812," \
+ "7.648148 47.498093," \
+ "7.648158 47.49806," \
+ "7.648163 47.49803," \
+ "7.64816 47.498," \
+ "7.648153 47.49797," \
+ "7.648138 47.49794," \
+ "7.648122 47.49791," \
+ "7.648117 47.497887," \
+ "7.648102 47.497864," \
+ "7.64809 47.49784," \
+ "7.648077 47.497814," \
+ "7.648058 47.49778," \
+ "7.648047 47.49775," \
+ "7.648042 47.49772," \
+ "7.648043 47.497696," \
+ "7.648047 47.497677," \
+ "7.64804 47.497654," \
+ "7.648032 47.497627," \
+ "7.648017 47.4976," \
+ "7.648005 47.49757," \
+ "7.647973 47.497528," \
+ "7.647962 47.497494," \
+ "7.647948 47.49746," \
+ "7.647943 47.49743," \
+ "7.647933 47.497406," \
+ "7.647928 47.497375," \
+ "7.647923 47.497353," \
+ "7.647908 47.497322," \
+ "7.647878 47.497295," \
+ "7.647853 47.49727," \
+ "7.647828 47.49724," \
+ "7.647818 47.497208," \
+ "7.647805 47.49718," \
+ "7.647793 47.497158," \
+ "7.647773 47.49713," \
+ "7.64776 47.4971," \
+ "7.647742 47.497078," \
+ "7.647745 47.49706," \
+ "7.647767 47.497047," \
+ "7.6478 47.497044," \
+ "7.647827 47.49704," \
+ "7.647855 47.49703," \
+ "7.64788 47.49702," \
+ "7.647907 47.497005," \
+ "7.647928 47.496986," \
+ "7.647943 47.496967," \
+ "7.64796 47.496952," \
+ "7.647968 47.49693," \
+ "7.64798 47.496902," \
+ "7.647988 47.496883," \
+ "7.648 47.49686," \
+ "7.64801 47.496838," \
+ "7.648018 47.496815," \
+ "7.648025 47.49679," \
+ "7.648033 47.49677," \
+ "7.64804 47.49675," \
+ "7.64805 47.496727," \
+ "7.648063 47.49671," \
+ "7.648073 47.496693," \
+ "7.648083 47.496674," \
+ "7.648097 47.49665," \
+ "7.648113 47.496628," \
+ "7.648133 47.49661," \
+ "7.64815 47.496586," \
+ "7.648162 47.496563," \
+ "7.648168 47.496536," \
+ "7.648172 47.49651," \
+ "7.648188 47.49648," \
+ "7.648192 47.496456," \
+ "7.648208 47.496433," \
+ "7.648225 47.496414," \
+ "7.648248 47.496395," \
+ "7.64826 47.496376," \
+ "7.64827 47.496353," \
+ "7.648277 47.496334," \
+ "7.648287 47.496307," \
+ "7.648302 47.496277," \
+ "7.648318 47.496246," \
+ "7.648337 47.496216," \
+ "7.648348 47.49619," \
+ "7.648358 47.496166," \
+ "7.648363 47.496143," \
+ "7.648375 47.496117," \
+ "7.648387 47.49609," \
+ "7.648402 47.496063," \
+ "7.648412 47.496037," \
+ "7.64842 47.496017," \
+ "7.648433 47.495995," \
+ "7.648445 47.495968," \
+ "7.648457 47.49594," \
+ "7.648463 47.495914," \
+ "7.64846 47.495888," \
+ "7.648457 47.495865," \
+ "7.648453 47.495842," \
+ "7.648453 47.49581," \
+ "7.648452 47.49579," \
+ "7.64846 47.495766," \
+ "7.648472 47.49574," \
+ "7.648467 47.495705," \
+ "7.648467 47.495663," \
+ "7.648458 47.49562," \
+ "7.648448 47.495583," \
+ "7.648445 47.495556," \
+ "7.64844 47.49554," \
+ "7.648435 47.49553," \
+ "7.648437 47.49552," \
+ "7.648435 47.495514," \
+ "7.648433 47.495506," \
+ "7.648433 47.495483," \
+ "7.648438 47.49546," \
+ "7.648445 47.49544," \
+ "7.648447 47.49542," \
+ "7.64845 47.495396," \
+ "7.648457 47.495373," \
+ "7.648467 47.495354," \
+ "7.648468 47.495335," \
+ "7.648475 47.495308," \
+ "7.648475 47.495277," \
+ "7.64848 47.495247," \
+ "7.648497 47.495213," \
+ "7.648505 47.49518," \
+ "7.648508 47.49514," \
+ "7.648513 47.495106," \
+ "7.648527 47.495075," \
+ "7.648537 47.495052," \
+ "7.648538 47.49502," \
+ "7.648535 47.49499," \
+ "7.64855 47.49496," \
+ "7.648568 47.494934," \
+ "7.648577 47.494904," \
+ "7.64859 47.49487," \
+ "7.648585 47.494843," \
+ "7.648595 47.494816," \
+ "7.648603 47.494793," \
+ "7.648618 47.494766," \
+ "7.648628 47.494743," \
+ "7.64864 47.494717," \
+ "7.648655 47.494698," \
+ "7.648675 47.49468," \
+ "7.648692 47.49466," \
+ "7.648713 47.49464," \
+ "7.648747 47.494633," \
+ "7.648763 47.494625," \
+ "7.648787 47.49462," \
+ "7.64881 47.49462," \
+ "7.648852 47.49462," \
+ "7.648883 47.494617," \
+ "7.648918 47.49463," \
+ "7.648943 47.494633," \
+ "7.648963 47.49464," \
+ "7.648993 47.49465," \
+ "7.649023 47.494663," \
+ "7.649058 47.49468," \
+ "7.649097 47.494682," \
+ "7.649133 47.494686," \
+ "7.649173 47.4947," \
+ "7.649208 47.494717," \
+ "7.649245 47.49473," \
+ "7.649278 47.49474," \
+ "7.649312 47.494736," \
+ "7.649342 47.49473," \
+ "7.649368 47.49472," \
+ "7.649402 47.494717," \
+ "7.649433 47.494713," \
+ "7.649473 47.494717," \
+ "7.64951 47.494724," \
+ "7.649542 47.494728," \
+ "7.649577 47.49473," \
+ "7.64961 47.494736," \
+ "7.649647 47.494743," \
+ "7.649688 47.49475," \
+ "7.649735 47.49476," \
+ "7.649777 47.494766," \
+ "7.649833 47.494778," \
+ "7.649873 47.49478," \
+ "7.649905 47.494778," \
+ "7.649937 47.494766," \
+ "7.649967 47.49476," \
+ "7.650007 47.49474," \
+ "7.65004 47.494724," \
+ "7.65008 47.494717," \
+ "7.650123 47.494713," \
+ "7.650167 47.494713," \
+ "7.650217 47.494717," \
+ "7.650255 47.494717," \
+ "7.650293 47.494713," \
+ "7.650335 47.494705," \
+ "7.650375 47.494705," \
+ "7.65042 47.49471," \
+ "7.650465 47.494713," \
+ "7.65051 47.49471," \
+ "7.650562 47.4947," \
+ "7.65061 47.494686," \
+ "7.650662 47.494682," \
+ "7.6507 47.494675," \
+ "7.650742 47.494663," \
+ "7.650783 47.494656," \
+ "7.650827 47.494648," \
+ "7.650865 47.494633," \
+ "7.650917 47.49461," \
+ "7.650963 47.49459," \
+ "7.65101 47.494583," \
+ "7.651067 47.494576," \
+ "7.651102 47.494564," \
+ "7.65113 47.494545," \
+ "7.65116 47.494526," \
+ "7.651195 47.494507," \
+ "7.651223 47.49448," \
+ "7.651247 47.49446," \
+ "7.651275 47.494442," \
+ "7.651298 47.494423," \
+ "7.65133 47.494404," \
+ "7.651357 47.49439," \
+ "7.651383 47.494373," \
+ "7.651408 47.49436," \
+ "7.651438 47.494347," \
+ "7.651462 47.494335," \
+ "7.651483 47.494324," \
+ "7.651508 47.494316," \
+ "7.65153 47.494305," \
+ "7.651553 47.494293," \
+ "7.651575 47.494286," \
+ "7.651597 47.494274," \
+ "7.651622 47.494267," \
+ "7.651647 47.49426," \
+ "7.65167 47.494244," \
+ "7.6517 47.494236," \
+ "7.651728 47.494225," \
+ "7.651755 47.494217," \
+ "7.65178 47.49421," \
+ "7.651805 47.4942," \
+ "7.651825 47.49419," \
+ "7.651853 47.494186," \
+ "7.65188 47.49418," \
+ "7.651905 47.494167," \
+ "7.651933 47.494164," \
+ "7.651965 47.494164," \
+ "7.651997 47.494156," \
+ "7.652028 47.49415," \
+ "7.652057 47.49414," \
+ "7.652087 47.494133," \
+ "7.652125 47.49412," \
+ "7.65216 47.494118," \
+ "7.652193 47.49411," \
+ "7.652227 47.494102," \
+ "7.652253 47.49409," \
+ "7.652283 47.494083," \
+ "7.652312 47.494072," \
+ "7.652342 47.494064," \
+ "7.652372 47.49406," \
+ "7.652398 47.494053," \
+ "7.652422 47.494045," \
+ "7.652452 47.494038," \
+ "7.652482 47.494034," \
+ "7.652508 47.494026," \
+ "7.652532 47.494022," \
+ "7.652557 47.49401," \
+ "7.652585 47.494003," \
+ "7.652615 47.493996," \
+ "7.652638 47.493984," \
+ "7.652667 47.493973," \
+ "7.652693 47.49396," \
+ "7.652722 47.493954," \
+ "7.65275 47.493942," \
+ "7.652775 47.493927," \
+ "7.652805 47.493916," \
+ "7.652835 47.493904," \
+ "7.65286 47.493893," \
+ "7.652867 47.49387," \
+ "7.65288 47.493847," \
+ "7.652897 47.49383," \
+ "7.652935 47.493835," \
+ "7.65297 47.49383," \
+ "7.65301 47.49382," \
+ "7.653052 47.49381," \
+ "7.653092 47.493793," \
+ "7.653133 47.49378," \
+ "7.65318 47.493767," \
+ "7.653222 47.49375," \
+ "7.65326 47.493736," \
+ "7.653303 47.493713," \
+ "7.653345 47.493694," \
+ "7.653388 47.49367," \
+ "7.653435 47.493652," \
+ "7.653482 47.493633," \
+ "7.653527 47.493614," \
+ "7.653573 47.4936," \
+ "7.653617 47.493584," \
+ "7.653663 47.49357," \
+ "7.653708 47.49355," \
+ "7.653753 47.493534," \
+ "7.653802 47.49352," \
+ "7.653847 47.4935," \
+ "7.653892 47.49349," \
+ "7.65394 47.493473," \
+ "7.653983 47.493458," \
+ "7.654028 47.493443," \
+ "7.654078 47.49343," \
+ "7.654125 47.49342," \
+ "7.654173 47.49341," \
+ "7.65422 47.493397," \
+ "7.654262 47.49338," \
+ "7.654305 47.49337," \
+ "7.654347 47.49336," \
+ "7.654388 47.493343," \
+ "7.654428 47.49333," \
+ "7.65447 47.493317," \
+ "7.65451 47.493305," \
+ "7.65455 47.493294," \
+ "7.654587 47.493282," \
+ "7.654622 47.49327," \
+ "7.654662 47.493263," \
+ "7.6547 47.49325," \
+ "7.654737 47.493237," \
+ "7.654777 47.49323," \
+ "7.654818 47.493217," \
+ "7.654858 47.49321," \
+ "7.654893 47.4932," \
+ "7.654935 47.493195," \
+ "7.654975 47.493183," \
+ "7.655013 47.49317," \
+ "7.655053 47.493156," \
+ "7.655097 47.49315," \
+ "7.655137 47.49314," \
+ "7.655177 47.493134," \
+ "7.655203 47.49312," \
+ "7.655238 47.49311," \
+ "7.655282 47.493107," \
+ "7.65532 47.4931," \
+ "7.65536 47.493088," \
+ "7.655398 47.493076," \
+ "7.65544 47.493065," \
+ "7.65548 47.493057," \
+ "7.655517 47.493046," \
+ "7.655555 47.49304," \
+ "7.655597 47.49303," \
+ "7.655638 47.493027," \
+ "7.65568 47.49302," \
+ "7.655723 47.49301," \
+ "7.655767 47.493004," \
+ "7.655812 47.492996," \
+ "7.655853 47.49299," \
+ "7.65589 47.492977," \
+ "7.655928 47.49296," \
+ "7.65597 47.49295," \
+ "7.656008 47.492935," \
+ "7.656043 47.49292," \
+ "7.656082 47.492905," \
+ "7.656115 47.49289," \
+ "7.656145 47.492874," \
+ "7.656173 47.49285," \
+ "7.6562 47.49283," \
+ "7.656227 47.49281," \
+ "7.656258 47.492794," \
+ "7.65628 47.49278," \
+ "7.656305 47.492764," \
+ "7.656325 47.492744," \
+ "7.656335 47.49272," \
+ "7.656342 47.492695," \
+ "7.656353 47.492672," \
+ "7.656362 47.49265," \
+ "7.656368 47.492626," \
+ "7.656373 47.492603," \
+ "7.656382 47.49258," \
+ "7.656395 47.492554," \
+ "7.65641 47.49253," \
+ "7.656425 47.492504," \
+ "7.656433 47.49249," \
+ "7.656457 47.49246," \
+ "7.656475 47.492428," \
+ "7.656495 47.492405," \
+ "7.656508 47.492382," \
+ "7.656523 47.492355," \
+ "7.656528 47.49233," \
+ "7.656545 47.49229," \
+ "7.656568 47.492264," \
+ "7.65658 47.492233," \
+ "7.656595 47.49221," \
+ "7.65662 47.49218," \
+ "7.656637 47.49215," \
+ "7.656665 47.492123," \
+ "7.656692 47.492104," \
+ "7.656725 47.49207," \
+ "7.656745 47.49204," \
+ "7.656767 47.492016," \
+ "7.656783 47.491997," \
+ "7.656812 47.49197," \
+ "7.65685 47.49195," \
+ "7.656882 47.491932," \
+ "7.6569 47.4919," \
+ "7.656927 47.491882," \
+ "7.656955 47.49186," \
+ "7.656975 47.491844," \
+ "7.656997 47.49182," \
+ "7.657017 47.4918," \
+ "7.657035 47.49177," \
+ "7.657057 47.49174," \
+ "7.657078 47.491726," \
+ "7.657093 47.491707," \
+ "7.657112 47.491688," \
+ "7.65713 47.491657," \
+ "7.657137 47.491627," \
+ "7.657148 47.491596," \
+ "7.657168 47.491566," \
+ "7.657183 47.491524," \
+ "7.6572 47.491486," \
+ "7.6572 47.49146," \
+ "7.65721 47.49143," \
+ "7.65722 47.491394," \
+ "7.657225 47.491367," \
+ "7.657235 47.491337," \
+ "7.657245 47.491318," \
+ "7.657248 47.491283," \
+ "7.65724 47.491257," \
+ "7.657243 47.491234," \
+ "7.657253 47.491207," \
+ "7.65727 47.491184," \
+ "7.657288 47.491158," \
+ "7.657303 47.491127," \
+ "7.657325 47.491096," \
+ "7.657325 47.49106," \
+ "7.657338 47.491028," \
+ "7.657348 47.49099," \
+ "7.657358 47.49095," \
+ "7.65737 47.490913," \
+ "7.657377 47.49088," \
+ "7.657392 47.49085," \
+ "7.657407 47.490818," \
+ "7.657405 47.490788," \
+ "7.657405 47.490753," \
+ "7.657413 47.490726," \
+ "7.657427 47.490704," \
+ "7.657428 47.490677," \
+ "7.657428 47.490646," \
+ "7.657418 47.490612," \
+ "7.657417 47.490578," \
+ "7.657423 47.490543," \
+ "7.657427 47.49051," \
+ "7.657435 47.490475," \
+ "7.65744 47.49044," \
+ "7.657438 47.490406," \
+ "7.65743 47.490356," \
+ "7.657425 47.490322," \
+ "7.657428 47.49029," \
+ "7.657432 47.490253," \
+ "7.657433 47.490215," \
+ "7.657437 47.490185," \
+ "7.657437 47.49015," \
+ "7.657437 47.490116," \
+ "7.65744 47.490074," \
+ "7.657455 47.490044," \
+ "7.657472 47.490017," \
+ "7.657493 47.489983," \
+ "7.657515 47.489952," \
+ "7.657533 47.489914," \
+ "7.657552 47.48989," \
+ "7.657573 47.489864," \
+ "7.657595 47.489838," \
+ "7.657613 47.48981," \
+ "7.657632 47.489784," \
+ "7.657653 47.489758," \
+ "7.657677 47.48973," \
+ "7.657695 47.4897," \
+ "7.657718 47.489674," \
+ "7.65774 47.489647," \
+ "7.657763 47.489624," \
+ "7.65778 47.489597," \
+ "7.657795 47.48957," \
+ "7.65782 47.489536," \
+ "7.657842 47.489517," \
+ "7.657862 47.48949," \
+ "7.657878 47.489464," \
+ "7.657893 47.489433," \
+ "7.657908 47.489407," \
+ "7.657923 47.48938," \
+ "7.657947 47.489346," \
+ "7.657963 47.489323," \
+ "7.657978 47.489292," \
+ "7.65799 47.489254," \
+ "7.657995 47.48923," \
+ "7.658008 47.489204," \
+ "7.658027 47.489166," \
+ "7.65804 47.489147," \
+ "7.658055 47.48912," \
+ "7.658075 47.489098," \
+ "7.658097 47.48907," \
+ "7.658108 47.489048," \
+ "7.658123 47.48902," \
+ "7.658133 47.48899," \
+ "7.658143 47.488964," \
+ "7.658152 47.488934," \
+ "7.658158 47.488907," \
+ "7.65817 47.488876," \
+ "7.658187 47.48885," \
+ "7.6582 47.488823," \
+ "7.658212 47.48879," \
+ "7.658222 47.48877," \
+ "7.658237 47.488743," \
+ "7.658252 47.488716," \
+ "7.658268 47.48869," \
+ "7.658285 47.488667," \
+ "7.658298 47.488636," \
+ "7.658315 47.48861," \
+ "7.658337 47.48858," \
+ "7.658347 47.48855," \
+ "7.658358 47.488525," \
+ "7.658377 47.4885," \
+ "7.658393 47.48848," \
+ "7.658412 47.488453," \
+ "7.658432 47.488426," \
+ "7.658443 47.4884," \
+ "7.658462 47.488373," \
+ "7.658482 47.488346," \
+ "7.658498 47.48832," \
+ "7.658517 47.488293," \
+ "7.658535 47.48827," \
+ "7.658552 47.488243," \
+ "7.658568 47.488216," \
+ "7.658587 47.488194," \
+ "7.658605 47.48817," \
+ "7.658625 47.488148," \
+ "7.658632 47.488125," \
+ "7.658652 47.48811," \
+ "7.658662 47.488087," \
+ "7.658675 47.488056," \
+ "7.658692 47.48803," \
+ "7.658715 47.488007," \
+ "7.658742 47.487988," \
+ "7.658762 47.487965," \
+ "7.658783 47.48794," \
+ "7.658815 47.487926," \
+ "7.658843 47.487907," \
+ "7.658867 47.48789," \
+ "7.658892 47.48786," \
+ "7.65893 47.48784," \
+ "7.658957 47.487823," \
+ "7.658987 47.487804," \
+ "7.659015 47.487793," \
+ "7.659038 47.487774," \
+ "7.659063 47.487755," \
+ "7.659093 47.487736," \
+ "7.659123 47.487717," \
+ "7.659158 47.4877," \
+ "7.659193 47.48768," \
+ "7.659222 47.48767," \
+ "7.65926 47.48765," \
+ "7.659292 47.487637," \
+ "7.659318 47.48762," \
+ "7.659348 47.487606," \
+ "7.659378 47.48759," \
+ "7.659405 47.487576," \
+ "7.659433 47.487556," \
+ "7.659463 47.487537," \
+ "7.659498 47.48752," \
+ "7.659523 47.4875," \
+ "7.659552 47.487484," \
+ "7.659573 47.487473," \
+ "7.659602 47.48746," \
+ "7.659633 47.487446," \
+ "7.659663 47.487434," \
+ "7.659692 47.487423," \
+ "7.659717 47.487404," \
+ "7.659747 47.48739," \
+ "7.659778 47.48737," \
+ "7.65981 47.487354," \
+ "7.659843 47.487343," \
+ "7.659875 47.487324," \
+ "7.659902 47.48731," \
+ "7.659928 47.48729," \
+ "7.659948 47.487267," \
+ "7.659968 47.487244," \
+ "7.659988 47.48722," \
+ "7.660018 47.48721," \
+ "7.660047 47.487186," \
+ "7.66007 47.487167," \
+ "7.660097 47.48715," \
+ "7.660122 47.487133," \
+ "7.66015 47.487118," \
+ "7.660177 47.487103," \
+ "7.660203 47.487087," \
+ "7.660228 47.48707," \
+ "7.660253 47.487057," \
+ "7.66028 47.487034," \
+ "7.660302 47.487015," \
+ "7.660323 47.48699," \
+ "7.660348 47.486977," \
+ "7.660373 47.486954," \
+ "7.660395 47.486935," \
+ "7.660417 47.486916," \
+ "7.660435 47.486893," \
+ "7.660452 47.48687," \
+ "7.660468 47.486847," \
+ "7.660478 47.486816," \
+ "7.66049 47.4868," \
+ "7.660498 47.486774," \
+ "7.660507 47.486744," \
+ "7.660512 47.48672," \
+ "7.660513 47.48669," \
+ "7.660513 47.48666," \
+ "7.660522 47.486633," \
+ "7.660527 47.486607," \
+ "7.660528 47.48658," \
+ "7.660528 47.486557," \
+ "7.660528 47.48653," \
+ "7.660528 47.4865," \
+ "7.660528 47.48647," \
+ "7.660542 47.486446," \
+ "7.660538 47.48642," \
+ "7.660527 47.486393," \
+ "7.66052 47.486374," \
+ "7.660505 47.48635," \
+ "7.660478 47.48632," \
+ "7.660457 47.486298," \
+ "7.66044 47.48628," \
+ "7.660423 47.48626," \
+ "7.660408 47.486237," \
+ "7.660392 47.486214," \
+ "7.660375 47.486187," \
+ "7.660365 47.48617," \
+ "7.660353 47.48615," \
+ "7.660335 47.486126," \
+ "7.660323 47.48611," \
+ "7.660313 47.48609," \
+ "7.660303 47.486057," \
+ "7.660293 47.48603," \
+ "7.660285 47.48601," \
+ "7.660275 47.485996," \
+ "7.660265 47.485977," \
+ "7.660253 47.48595," \
+ "7.660238 47.485924," \
+ "7.660235 47.485905," \
+ "7.66023 47.485886," \
+ "7.660232 47.485863," \
+ "7.66023 47.485844," \
+ "7.660223 47.48582," \
+ "7.660215 47.485794," \
+ "7.66021 47.48577," \
+ "7.660205 47.48575," \
+ "7.660205 47.48573," \
+ "7.660213 47.485714," \
+ "7.660222 47.485706," \
+ "7.660225 47.485687," \
+ "7.66023 47.485672," \
+ "7.660232 47.485657," \
+ "7.66024 47.48564," \
+ "7.660247 47.485638," \
+ "7.66025 47.485626," \
+ "7.660253 47.485615," \
+ "7.660257 47.485596," \
+ "7.660262 47.48558," \
+ "7.660255 47.485554," \
+ "7.660247 47.48553," \
+ "7.660242 47.48551," \
+ "7.660242 47.485493," \
+ "7.660245 47.48548," \
+ "7.66026 47.485474," \
+ "7.660268 47.48546," \
+ "7.660277 47.485443," \
+ "7.660282 47.485428," \
+ "7.660292 47.485413," \
+ "7.660303 47.485397," \
+ "7.660322 47.48538," \
+ "7.660332 47.48536," \
+ "7.660343 47.485336," \
+ "7.66036 47.485313," \
+ "7.660377 47.48528," \
+ "7.660387 47.485245," \
+ "7.660392 47.48522," \
+ "7.66039 47.48519," \
+ "7.66038 47.485153," \
+ "7.660358 47.48512," \
+ "7.660358 47.485104," \
+ "7.660358 47.485077," \
+ "7.660355 47.48506," \
+ "7.660347 47.48504," \
+ "7.660332 47.485016," \
+ "7.660325 47.484997," \
+ "7.660317 47.484978," \
+ "7.660312 47.48496," \
+ "7.660305 47.484943," \
+ "7.660303 47.48493," \
+ "7.660298 47.484917," \
+ "7.660287 47.484898," \
+ "7.660273 47.484886," \
+ "7.660263 47.48487," \
+ "7.660255 47.484856," \
+ "7.660247 47.484833," \
+ "7.660252 47.48482," \
+ "7.660255 47.484802," \
+ "7.66025 47.48479," \
+ "7.660233 47.484768," \
+ "7.660225 47.484753," \
+ "7.660218 47.484737," \
+ "7.660207 47.484722," \
+ "7.660185 47.484707," \
+ "7.66016 47.484688," \
+ "7.660135 47.48467," \
+ "7.660105 47.484642," \
+ "7.660078 47.48462," \
+ "7.660063 47.484604," \
+ "7.660048 47.484592," \
+ "7.660038 47.48458," \
+ "7.660023 47.484573," \
+ "7.660003 47.484554," \
+ "7.659992 47.48454," \
+ "7.659978 47.484524," \
+ "7.659967 47.48451," \
+ "7.65996 47.48449," \
+ "7.659957 47.48447," \
+ "7.659948 47.484455," \
+ "7.659942 47.484444," \
+ "7.659925 47.484425," \
+ "7.659903 47.48441," \
+ "7.659892 47.484394," \
+ "7.65988 47.48438," \
+ "7.659863 47.484356," \
+ "7.659847 47.48433," \
+ "7.65983 47.484314," \
+ "7.659813 47.48429," \
+ "7.65979 47.484253," \
+ "7.659787 47.484234," \
+ "7.659778 47.48422," \
+ "7.659768 47.4842," \
+ "7.659755 47.48418," \
+ "7.65974 47.484165," \
+ "7.659725 47.484154," \
+ "7.659707 47.48414," \
+ "7.659693 47.48412," \
+ "7.659683 47.484108," \
+ "7.659672 47.484097," \
+ "7.659657 47.48408," \
+ "7.659643 47.484066," \
+ "7.659623 47.48405," \
+ "7.659595 47.48403," \
+ "7.65957 47.484016," \
+ "7.659482 47.483986," \
+ "7.659418 47.48398," \
+ "7.65937 47.48398," \
+ "7.659318 47.483974," \
+ "7.659267 47.483967," \
+ "7.659235 47.483963," \
+ "7.659213 47.483955," \
+ "7.659197 47.483948," \
+ "7.65917 47.483936," \
+ "7.659133 47.483925," \
+ "7.659105 47.48391," \
+ "7.659073 47.4839," \
+ "7.659043 47.483883," \
+ "7.659003 47.483864," \
+ "7.658967 47.48385," \
+ "7.658932 47.483833," \
+ "7.658893 47.483814," \
+ "7.658853 47.4838," \
+ "7.658818 47.483784," \
+ "7.658795 47.48377," \
+ "7.658765 47.48375," \
+ "7.658735 47.483727," \
+ "7.658698 47.483707," \
+ "7.658663 47.48369," \
+ "7.658625 47.48367," \
+ "7.658588 47.483646," \
+ "7.658552 47.48363," \
+ "7.658525 47.48362," \
+ "7.658497 47.483604," \
+ "7.658472 47.48359," \
+ "7.65844 47.483574," \
+ "7.658405 47.48356," \
+ "7.65837 47.48354," \
+ "7.658335 47.483517," \
+ "7.658307 47.4835," \
+ "7.658273 47.483486," \
+ "7.658253 47.483475," \
+ "7.658227 47.48346," \
+ "7.658207 47.483444," \
+ "7.658185 47.483437," \
+ "7.658145 47.483414," \
+ "7.658108 47.483387," \
+ "7.658075 47.483368," \
+ "7.658045 47.483345," \
+ "7.658013 47.483322," \
+ "7.657985 47.483303," \
+ "7.657955 47.483284," \
+ "7.657932 47.48327," \
+ "7.657908 47.483253," \
+ "7.657878 47.483234," \
+ "7.657857 47.48322," \
+ "7.657837 47.483204," \
+ "7.65782 47.483185," \
+ "7.6578 47.48316," \
+ "7.65778 47.483135," \
+ "7.65775 47.48311," \
+ "7.657753 47.4831," \
+ "7.657747 47.483086," \
+ "7.657732 47.48306," \
+ "7.657722 47.483036," \
+ "7.657703 47.483013," \
+ "7.657697 47.48299," \
+ "7.657692 47.482967," \
+ "7.657688 47.48295," \
+ "7.657682 47.48292," \
+ "7.657668 47.482903," \
+ "7.657638 47.48287," \
+ "7.657613 47.48285," \
+ "7.657587 47.48282," \
+ "7.657562 47.48279," \
+ "7.657545 47.482777," \
+ "7.657517 47.48275," \
+ "7.65749 47.482727," \
+ "7.657462 47.482708," \
+ "7.657438 47.48269," \
+ "7.657402 47.48266," \
+ "7.65737 47.48264," \
+ "7.657345 47.48262," \
+ "7.657313 47.482597," \
+ "7.657282 47.48258," \
+ "7.65725 47.48255," \
+ "7.65723 47.482525," \
+ "7.657223 47.4825," \
+ "7.657225 47.482475," \
+ "7.657223 47.482445," \
+ "7.657225 47.482414," \
+ "7.657228 47.482388," \
+ "7.657233 47.482365," \
+ "7.65724 47.48235," \
+ "7.657235 47.48232," \
+ "7.657222 47.48229," \
+ "7.657212 47.482265," \
+ "7.657187 47.48224," \
+ "7.657162 47.482212," \
+ "7.657138 47.48218," \
+ "7.65712 47.48215," \
+ "7.657105 47.482113," \
+ "7.657093 47.482082," \
+ "7.657082 47.48206," \
+ "7.657073 47.482037," \
+ "7.657062 47.482002," \
+ "7.657062 47.481968," \
+ "7.657062 47.481937," \
+ "7.657065 47.481907," \
+ "7.657073 47.481873," \
+ "7.657083 47.481842," \
+ "7.657092 47.481815," \
+ "7.657103 47.481773," \
+ "7.65711 47.481747," \
+ "7.657113 47.48172," \
+ "7.657118 47.481693," \
+ "7.657123 47.481663," \
+ "7.657133 47.48163," \
+ "7.657147 47.4816," \
+ "7.657162 47.48158," \
+ "7.657183 47.48155," \
+ "7.657202 47.48153," \
+ "7.657232 47.4815," \
+ "7.657255 47.48148," \
+ "7.65728 47.481453," \
+ "7.657298 47.481422," \
+ "7.657317 47.481396," \
+ "7.657335 47.481365," \
+ "7.657355 47.481342," \
+ "7.657387 47.48133," \
+ "7.657422 47.48131," \
+ "7.657452 47.481293," \
+ "7.657477 47.481266," \
+ "7.657497 47.481243," \
+ "7.657522 47.48121," \
+ "7.657532 47.481182," \
+ "7.657538 47.481155," \
+ "7.657552 47.48112," \
+ "7.657565 47.48108," \
+ "7.657575 47.481045," \
+ "7.65758 47.481007," \
+ "7.657588 47.480984," \
+ "7.65759 47.480938," \
+ "7.657603 47.48091," \
+ "7.657618 47.480873," \
+ "7.657638 47.48084," \
+ "7.657648 47.480797," \
+ "7.657663 47.480755," \
+ "7.657668 47.480717," \
+ "7.65767 47.480682," \
+ "7.657675 47.480648," \
+ "7.657682 47.480614," \
+ "7.657685 47.48058," \
+ "7.657693 47.480553," \
+ "7.657702 47.48052," \
+ "7.657715 47.480488," \
+ "7.657742 47.480446," \
+ "7.657753 47.480423," \
+ "7.657763 47.48039," \
+ "7.657778 47.48036," \
+ "7.657783 47.480324," \
+ "7.657785 47.480293," \
+ "7.65779 47.480263," \
+ "7.657788 47.48023," \
+ "7.657792 47.480194," \
+ "7.657785 47.480164," \
+ "7.657782 47.48013," \
+ "7.657788 47.4801," \
+ "7.657785 47.48007," \
+ "7.657783 47.48004," \
+ "7.657783 47.480003," \
+ "7.657785 47.47997," \
+ "7.657792 47.47994," \
+ "7.657798 47.479908," \
+ "7.657808 47.479874," \
+ "7.657827 47.47984," \
+ "7.657833 47.47981," \
+ "7.657845 47.479774," \
+ "7.657865 47.47974," \
+ "7.657885 47.479706," \
+ "7.657908 47.47967," \
+ "7.65793 47.47964," \
+ "7.657947 47.479614," \
+ "7.657953 47.479576," \
+ "7.657967 47.479538," \
+ "7.657985 47.47949," \
+ "7.657993 47.479458," \
+ "7.658007 47.479412," \
+ "7.65801 47.47938," \
+ "7.658013 47.47934," \
+ "7.65802 47.4793," \
+ "7.658027 47.479275," \
+ "7.658038 47.479233," \
+ "7.658048 47.4792," \
+ "7.658055 47.47916," \
+ "7.658078 47.479126," \
+ "7.658102 47.47909," \
+ "7.658103 47.479046," \
+ "7.658108 47.479004," \
+ "7.658127 47.478973," \
+ "7.658133 47.478935," \
+ "7.658142 47.47891," \
+ "7.658162 47.47887," \
+ "7.658178 47.478844," \
+ "7.658165 47.478806," \
+ "7.658135 47.47877," \
+ "7.658115 47.47874," \
+ "7.658107 47.478718," \
+ "7.658103 47.4787," \
+ "7.658087 47.478676," \
+ "7.658058 47.478664," \
+ "7.658023 47.47865," \
+ "7.657982 47.478638," \
+ "7.657933 47.478626," \
+ "7.657897 47.47861," \
+ "7.657853 47.478596," \
+ "7.657808 47.47859," \
+ "7.657765 47.478577," \
+ "7.657722 47.47856," \
+ "7.657688 47.478554," \
+ "7.657655 47.478554," \
+ "7.657623 47.47856," \
+ "7.657602 47.478577," \
+ "7.657587 47.478607," \
+ "7.657573 47.47863," \
+ "7.65755 47.47865," \
+ "7.657532 47.47867," \
+ "7.65752 47.478683," \
+ "7.657503 47.478687," \
+ "7.657488 47.478683," \
+ "7.657482 47.478672," \
+ "7.657477 47.47866," \
+ "7.65747 47.47865," \
+ "7.657457 47.47864," \
+ "7.657442 47.478626," \
+ "7.65743 47.478615," \
+ "7.657423 47.478603," \
+ "7.657407 47.478592," \
+ "7.657393 47.478577," \
+ "7.657375 47.47856," \
+ "7.657355 47.47855," \
+ "7.657342 47.47854," \
+ "7.657333 47.478527," \
+ "7.657317 47.47852," \
+ "7.6573 47.478504," \
+ "7.657283 47.478504," \
+ "7.657248 47.478493," \
+ "7.657215 47.478485," \
+ "7.657193 47.478493," \
+ "7.657172 47.478508," \
+ "7.65716 47.478523," \
+ "7.657157 47.47854," \
+ "7.657158 47.47856," \
+ "7.65716 47.478584," \
+ "7.657153 47.4786," \
+ "7.65715 47.478615," \
+ "7.657147 47.478622," \
+ "7.657142 47.478626," \
+ "7.657137 47.47862," \
+ "7.657123 47.478607," \
+ "7.657117 47.478603," \
+ "7.657105 47.478584," \
+ "7.657087 47.47856," \
+ "7.657062 47.478542," \
+ "7.657042 47.478527," \
+ "7.657025 47.47852," \
+ "7.657007 47.47851," \
+ "7.656985 47.478497," \
+ "7.656963 47.478477," \
+ "7.656938 47.47846," \
+ "7.656912 47.47844," \
+ "7.656888 47.478416," \
+ "7.656865 47.478397," \
+ "7.656842 47.478386," \
+ "7.656812 47.47837," \
+ "7.656772 47.47835," \
+ "7.65673 47.478336," \
+ "7.656688 47.478325," \
+ "7.656647 47.478313," \
+ "7.656607 47.478302," \
+ "7.656563 47.478294," \
+ "7.656515 47.47828," \
+ "7.656467 47.478264," \
+ "7.656417 47.47825," \
+ "7.656368 47.478233," \
+ "7.65633 47.478226," \
+ "7.65629 47.478214," \
+ "7.656248 47.478207," \
+ "7.65621 47.4782," \
+ "7.65617 47.478195," \
+ "7.656127 47.47819," \
+ "7.656077 47.478184," \
+ "7.656038 47.478176," \
+ "7.656003 47.47817," \
+ "7.655972 47.478157," \
+ "7.655938 47.47815," \
+ "7.655907 47.47815," \
+ "7.655867 47.47815," \
+ "7.655827 47.478153," \
+ "7.655787 47.478153," \
+ "7.655743 47.478153," \
+ "7.6557 47.478153," \
+ "7.65566 47.478153," \
+ "7.655623 47.478146," \
+ "7.655575 47.478138," \
+ "7.65554 47.47813," \
+ "7.655498 47.47812," \
+ "7.655458 47.47811," \
+ "7.655413 47.478096," \
+ "7.655373 47.47809," \
+ "7.655345 47.47809," \
+ "7.655312 47.478077," \
+ "7.65528 47.47807," \
+ "7.655243 47.478058," \
+ "7.655198 47.478046," \
+ "7.655148 47.47803," \
+ "7.6551 47.47802," \
+ "7.655052 47.47801," \
+ "7.65498 47.477985," \
+ "7.654918 47.477966," \
+ "7.654868 47.47795," \
+ "7.654815 47.477932," \
+ "7.654757 47.477905," \
+ "7.654708 47.477886," \
+ "7.654668 47.47787," \
+ "7.654612 47.47785," \
+ "7.654568 47.477837," \
+ "7.654527 47.477825," \
+ "7.654493 47.477818," \
+ "7.65446 47.477806," \
+ "7.654422 47.477787," \
+ "7.654383 47.477776," \
+ "7.654338 47.47776," \
+ "7.654293 47.47775," \
+ "7.654252 47.477737," \
+ "7.654207 47.477726," \
+ "7.65417 47.47772," \
+ "7.65413 47.477715," \
+ "7.65409 47.477703," \
+ "7.654047 47.47769," \
+ "7.654003 47.477684," \
+ "7.65396 47.477676," \
+ "7.653913 47.477673," \
+ "7.653875 47.47766," \
+ "7.653838 47.477657," \
+ "7.653797 47.477654," \
+ "7.653755 47.477646," \
+ "7.653713 47.477642," \
+ "7.653673 47.47764," \
+ "7.653628 47.477627," \
+ "7.653578 47.47762," \
+ "7.653528 47.47761," \
+ "7.653473 47.477596," \
+ "7.653423 47.47758," \
+ "7.653375 47.477573," \
+ "7.653328 47.477562," \
+ "7.653282 47.47756," \
+ "7.653245 47.47755," \
+ "7.6532 47.477547," \
+ "7.65315 47.477547," \
+ "7.6531 47.477543," \
+ "7.653058 47.47754," \
+ "7.652995 47.477528," \
+ "7.652937 47.47752," \
+ "7.652877 47.477505," \
+ "7.652815 47.477486," \
+ "7.652757 47.47748," \
+ "7.652692 47.477463," \
+ "7.652635 47.477455," \
+ "7.652573 47.477448," \
+ "7.652513 47.477448," \
+ "7.652462 47.477448," \
+ "7.652408 47.47745," \
+ "7.652353 47.47745," \
+ "7.6523 47.477455," \
+ "7.652248 47.477467," \
+ "7.652192 47.477474," \
+ "7.652137 47.47748," \
+ "7.65208 47.477497," \
+ "7.65201 47.477524," \
+ "7.65197 47.477543," \
+ "7.651922 47.477566," \
+ "7.651863 47.47759," \
+ "7.651822 47.477596," \
+ "7.651772 47.477608," \
+ "7.651722 47.47761," \
+ "7.651668 47.477615," \
+ "7.651612 47.477615," \
+ "7.651562 47.477615," \
+ "7.651513 47.47762," \
+ "7.651475 47.477615," \
+ "7.651447 47.47762," \
+ "7.651423 47.477623," \
+ "7.651388 47.477623," \
+ "7.651358 47.477627," \
+ "7.65133 47.47763," \
+ "7.651278 47.477623," \
+ "7.651237 47.47761," \
+ "7.651192 47.47761," \
+ "7.651142 47.477604," \
+ "7.651107 47.4776," \
+ "7.651075 47.4776," \
+ "7.651028 47.477596," \
+ "7.650978 47.47759," \
+ "7.650935 47.477585," \
+ "7.650895 47.47758," \
+ "7.650853 47.477577," \
+ "7.65081 47.47757," \
+ "7.650765 47.477566," \
+ "7.650718 47.47756," \
+ "7.650677 47.47755," \
+ "7.650635 47.47754," \
+ "7.650595 47.477524," \
+ "7.650552 47.477512," \
+ "7.650513 47.47751," \
+ "7.65047 47.477505," \
+ "7.65042 47.4775," \
+ "7.650367 47.4775," \
+ "7.650288 47.477512," \
+ "7.650227 47.477524," \
+ "7.650172 47.47753," \
+ "7.65011 47.477543," \
+ "7.650047 47.477543," \
+ "7.649998 47.477547," \
+ "7.649947 47.477554," \
+ "7.649913 47.477566," \
+ "7.649878 47.47757," \
+ "7.649835 47.477573," \
+ "7.649782 47.477573," \
+ "7.649725 47.477573," \
+ "7.649672 47.47758," \
+ "7.649622 47.477585," \
+ "7.64958 47.477585," \
+ "7.64953 47.47759," \
+ "7.649475 47.477585," \
+ "7.649433 47.47759," \
+ "7.649378 47.47759," \
+ "7.649333 47.47759," \
+ "7.649297 47.477596," \
+ "7.649263 47.477608," \
+ "7.649225 47.477623," \
+ "7.649198 47.47764," \
+ "7.649158 47.477654," \
+ "7.649128 47.477657," \
+ "7.649088 47.477665," \
+ "7.649045 47.477673," \
+ "7.64901 47.477676," \
+ "7.648982 47.477688," \
+ "7.648942 47.477695," \
+ "7.648905 47.477703," \
+ "7.64886 47.477707," \
+ "7.648817 47.477707," \
+ "7.648782 47.477707," \
+ "7.648732 47.477703," \
+ "7.648695 47.4777," \
+ "7.64866 47.47769," \
+ "7.648628 47.477684," \
+ "7.648582 47.477673," \
+ "7.64854 47.47766," \
+ "7.648508 47.477657," \
+ "7.648468 47.477654," \
+ "7.648428 47.47765," \
+ "7.64838 47.477646," \
+ "7.64833 47.47764," \
+ "7.648287 47.47764," \
+ "7.648247 47.477642," \
+ "7.648205 47.477646," \
+ "7.648158 47.477654," \
+ "7.648118 47.47766," \
+ "7.648072 47.47767," \
+ "7.648033 47.477676," \
+ "7.647978 47.47769," \
+ "7.647935 47.477703," \
+ "7.647892 47.477722," \
+ "7.647857 47.47774," \
+ "7.64782 47.477764," \
+ "7.64778 47.47779," \
+ "7.64775 47.477818)"
diff --git a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
index ae5c344c7..d118b494f 100644
--- a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
@@ -31,76 +31,50 @@ namespace tut {
// Test Group
-// Test data, not used
-struct test_DiscreteFrechetDistance_data {
+struct test_frechetdistance_data {
- typedef std::unique_ptr<Geometry> GeomPtr;
- test_DiscreteFrechetDistance_data()
- pm(),
- gf(GeometryFactory::create(&pm)),
- reader(gf.get())
- static const double TOLERANCE;
+ geos::io::WKTReader reader;
+ static constexpr double TOLERANCE = 0.00001;
void
- runTest(const std::string& wkt1, const std::string& wkt2,
+ checkDiscreteFrechet(const std::string& wkt1, const std::string& wkt2,
double expectedDistance)
- GeomPtr g1(reader.read(wkt1));
- GeomPtr g2(reader.read(wkt2));
+ std::unique_ptr<Geometry> g1(reader.read(wkt1));
+ std::unique_ptr<Geometry> g2(reader.read(wkt2));
double distance = DiscreteFrechetDistance::distance(*g1, *g2);
- double diff = std::fabs(distance - expectedDistance);
- //std::cerr << "expectedDistance:" << expectedDistance << " actual distance:" << distance << std::endl;
- ensure(diff <= TOLERANCE);
+ ensure_equals("checkDiscreteFrechet", distance, expectedDistance, TOLERANCE);
void
+ checkDensifiedFrechet(const std::string& wkt1, const std::string& wkt2,
double densifyFactor, double expectedDistance)
- double distance = DiscreteFrechetDistance::distance(*g1,
- *g2, densifyFactor);
+ double distance = DiscreteFrechetDistance::distance(*g1, *g2, densifyFactor);
+ ensure_equals("checkDensifiedFrechet", distance, expectedDistance, TOLERANCE);
- PrecisionModel pm;
- GeometryFactory::Ptr gf;
- geos::io::WKTReader reader;
-const double test_DiscreteFrechetDistance_data::TOLERANCE = 0.00001;
-typedef test_group<test_DiscreteFrechetDistance_data> group;
+typedef test_group<test_frechetdistance_data> group;
typedef group::object object;
-group test_DiscreteFrechetDistance_group("geos::algorithm::distance::DiscreteFrechetDistance");
-// Test Cases
+group test_frechetdistance_group("geos::algorithm::distance::DiscreteFrechetDistance");
// 1 - testLineSegments
template<>
template<>
-void object::test<1>
+void object::test<1> ()
- runTest("LINESTRING (0 0, 2 1)", "LINESTRING (0 0, 2 0)", 1.0);
+ checkDiscreteFrechet("LINESTRING (0 0, 2 1)", "LINESTRING (0 0, 2 0)", 1.0);
// zero densify factor
try {
- runTest("LINESTRING (0 0, 2 1)", "LINESTRING EMPTY", 0.0, 0);
+ checkDensifiedFrechet("LINESTRING (0 0, 2 1)", "LINESTRING EMPTY", 0.0, 0);
catch(const geos::util::IllegalArgumentException& e) {
// We do expect an exception
@@ -109,7 +83,7 @@ void object::test<1>
// too big densify factor
try {
- runTest("LINESTRING (0 0, 2 1)", "LINESTRING EMPTY", 1 + 1e-10, 0);
+ checkDensifiedFrechet("LINESTRING (0 0, 2 1)", "LINESTRING EMPTY", 1 + 1e-10, 0);
@@ -118,7 +92,7 @@ void object::test<1>
// too small positive densify factor
try {
- runTest("LINESTRING (0 0, 2 1)", "LINESTRING EMPTY", 1e-30, 0);
+ checkDensifiedFrechet("LINESTRING (0 0, 2 1)", "LINESTRING EMPTY", 1e-30, 0);
@@ -129,19 +103,17 @@ void object::test<1>
// 2 - testLineSegments2
template<>
template<>
-void object::test<2>
+void object::test<2> ()
- runTest("LINESTRING (0 0, 2 0)", "LINESTRING (0 1, 1 2, 2 1)", 2.23606797749979);
+ checkDiscreteFrechet("LINESTRING (0 0, 2 0)", "LINESTRING (0 1, 1 2, 2 1)", 2.23606797749979);
// 3 - testLinePoints
template<>
template<>
-void object::test<3>
+void object::test<3> ()
- runTest("LINESTRING (0 0, 2 0)", "MULTIPOINT ((0 1), (1 0), (2 1))", 1.0);
+ checkDiscreteFrechet("LINESTRING (0 0, 2 0)", "MULTIPOINT ((0 1), (1 0), (2 1))", 1.0);
// 4 - testLinesShowingDiscretenessEffect
@@ -151,27 +123,25 @@ void object::test<3>
template<>
template<>
-void object::test<4>
+void object::test<4> ()
- runTest("LINESTRING (0 0, 100 0)", "LINESTRING (0 0, 50 50, 100 0)", 70.7106781186548);
-// densifying provides accurate HD
- runTest("LINESTRING (0 0, 100 0)", "LINESTRING (0 0, 50 50, 100 0)", 0.5, 50.0);
+ checkDiscreteFrechet("LINESTRING (0 0, 100 0)", "LINESTRING (0 0, 50 50, 100 0)", 70.7106781186548);
+ // densifying provides accurate HD
+ checkDensifiedFrechet("LINESTRING (0 0, 100 0)", "LINESTRING (0 0, 50 50, 100 0)", 0.5, 50.0);
// 5 - test Line Segments revealing distance initialization bug
template<>
template<>
-void object::test<5>
+void object::test<5> ()
- runTest("LINESTRING (1 1, 2 2)", "LINESTRING (1 4, 2 3)", 3);
+ checkDiscreteFrechet("LINESTRING (1 1, 2 2)", "LINESTRING (1 4, 2 3)", 3);
+// Empty arguments should throw error
template<>
template<>
-void object::test<6>
+void object::test<6> ()
auto g1 = reader.read("LINESTRING EMPTY");
auto g2 = reader.read("POLYGON EMPTY");
@@ -183,4 +153,25 @@ void object::test<6>
+// Large test data set caused stack overflow in old
+// recursive version of the algorithm
+// https://github.com/libgeos/geos/issues/516
+#include "DiscreteFrechetDistanceData.h"
+template<>
+template<>
+void object::test<7> ()
+ checkDiscreteFrechet(LS1, LS2, 2.49903e-04);
+template<>
+template<>
+void object::test<8> ()
+ checkDensifiedFrechet("LINESTRING(1 0, 2 0)", "LINESTRING(-1 0, 0 0, 7 8)", 0.002, 9.43398);
} // namespace tut
diff --git a/tests/unit/algorithm/distance/MatrixStorageTest.cpp b/tests/unit/algorithm/distance/MatrixStorageTest.cpp
new file mode 100644
index 000000000..cea043cf4
--- /dev/null
+++ b/tests/unit/algorithm/distance/MatrixStorageTest.cpp
@@ -0,0 +1,110 @@
+// Test Suite for geos::algorithm::distance::DiscreteFrechetDistance::MatrixStorage
+#include <tut/tut.hpp>
+// geos
+#include <geos/algorithm/distance/DiscreteFrechetDistance.h>
+#include <geos/util.h>
+using geos::algorithm::distance::DiscreteFrechetDistance;
+namespace tut {
+struct test_matrixstorage_data {
+ test_matrixstorage_data() {};
+ void
+ runOrderedTest(DiscreteFrechetDistance::MatrixStorage& mat)
+ mat.set(0, 0, 10);
+ mat.set(0, 1, 20);
+ mat.set(1, 1, 30);
+ mat.set(1, 3, 40);
+ mat.set(2, 2, 50);
+ mat.set(2, 3, 60);
+ mat.set(2, 4, 70);
+ mat.set(3, 5, 80);
+ ensure_equals("ordered 10", mat.get(0, 0), 10);
+ ensure_equals("ordered 20", mat.get(0, 1), 20);
+ ensure_equals("ordered 30", mat.get(1, 1), 30);
+ ensure_equals("ordered 40", mat.get(1, 3), 40);
+ ensure_equals("ordered 50", mat.get(2, 2), 50);
+ ensure_equals("ordered 60", mat.get(2, 3), 60);
+ ensure_equals("ordered 70", mat.get(2, 4), 70);
+ ensure_equals("ordered 80", mat.get(3, 5), 80);
+ void
+ runUnorderedTest(DiscreteFrechetDistance::MatrixStorage& mat)
+ ensure_equals("unordered 10", mat.get(0, 0), 10);
+ ensure_equals("unordered 20", mat.get(0, 1), 20);
+ ensure_equals("unordered 30", mat.get(1, 1), 30);
+ ensure_equals("unordered 40", mat.get(1, 3), 40);
+ ensure_equals("unordered 50", mat.get(2, 2), 50);
+ ensure_equals("unordered 60", mat.get(2, 3), 60);
+ ensure_equals("unordered 70", mat.get(2, 4), 70);
+ ensure_equals("unordered 80", mat.get(3, 5), 80);
+typedef test_group<test_matrixstorage_data> group;
+typedef group::object object;
+group test_matrixstorage_group("geos::algorithm::distance::MatrixStorage");
+// Test Cases
+// testCsrMatrix
+template<>
+template<>
+void object::test<1>()
+ std::unique_ptr<DiscreteFrechetDistance::MatrixStorage> mat;
+ mat = std::make_unique<DiscreteFrechetDistance::CsrMatrix>(4, 6, 0.0, 8);
+ runOrderedTest(*mat);
+ runUnorderedTest(*mat);
+// testHashMapMatrix
+template<>
+template<>
+void object::test<2>()
+ mat = std::make_unique<DiscreteFrechetDistance::HashMapMatrix>(4, 6, 0.0);
+// testRectMatrix
+template<>
+template<>
+void object::test<3>()
+ mat = std::make_unique<DiscreteFrechetDistance::RectMatrix>(4, 6, 0.0);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSFrechetDistanceTest.cpp b/tests/unit/capi/GEOSFrechetDistanceTest.cpp
index dc7d69929..68d8dddd5 100644
--- a/tests/unit/capi/GEOSFrechetDistanceTest.cpp
+++ b/tests/unit/capi/GEOSFrechetDistanceTest.cpp
@@ -26,8 +26,7 @@ group test_capigeosfrechetdistance_group("capi::GEOSFrechetDistance");
template<>
template<>
geom1_ = fromWKT("LINESTRING (0 0, 100 0)");
geom2_ = fromWKT("LINESTRING (0 0, 50 50, 100 0)");
@@ -41,8 +40,7 @@ void object::test<1>
template<>
template<>
@@ -58,33 +56,15 @@ void object::test<2>
// https://trac.osgeo.org/geos/ticket/1086
template<>
template<>
+ double dist = 0;
geom1_ = fromWKT("LINESTRING (0 0, 3 7, 5 5)");
geom2_ = fromWKT("LINESTRING (0 0, 9 1, 2 2)");
- double dist = 0;
- GEOSFrechetDistanceDensify(geom1_, geom2_, 1e-40, &dist);
- ensure(dist >= 0); // no crash
+ int ret = GEOSFrechetDistanceDensify(geom1_, geom2_, 1e-40, &dist);
+ ensure_equals(ret, 0);
-// No crash with tiny densify fraction
-// https://trac.osgeo.org/geos/ticket/1086
-template<>
-template<>
- geom1_ = fromWKT("LINESTRING (0 0, 3 7, 5 5)");
- geom2_ = fromWKT("LINESTRING (0 0, 9 1, 2 2)");
- double dist = 0;
- GEOSFrechetDistanceDensify(geom1_, geom2_, 1e-19, &dist);
template<>
template<>
Summary of changes:
NEWS.md | 1 +
.../algorithm/distance/DiscreteFrechetDistance.h | 588 ++-
.../geos/algorithm/distance/PointPairDistance.h | 10 +-
src/algorithm/distance/DiscreteFrechetDistance.cpp | 414 +-
.../distance/DiscreteFrechetDistanceData.h | 5559 ++++++++++++++++++++
.../distance/DiscreteFrechetDistanceTest.cpp | 115 +-
.../unit/algorithm/distance/MatrixStorageTest.cpp | 110 +
tests/unit/capi/GEOSFrechetDistanceTest.cpp | 32 +-
8 files changed, 6512 insertions(+), 317 deletions(-)
create mode 100644 tests/unit/algorithm/distance/DiscreteFrechetDistanceData.h
create mode 100644 tests/unit/algorithm/distance/MatrixStorageTest.cpp
hooks/post-receive
More information about the geos-commits
