[geos-commits] [SCM] GEOS branch main updated. 29d4f5d030293a9b8254022266e0789a2badc726
    git at osgeo.org
    git at osgeo.org
    Tue Jul  8 09:31:24 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  29d4f5d030293a9b8254022266e0789a2badc726 (commit)
      from  cee8cc2aae43a84f0d1d146604f7bd42066d379b (commit)
revisions in full, below.
commit 29d4f5d030293a9b8254022266e0789a2badc726
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jul 8 09:31:05 2025 -0700
    DiscreteFrechet Crash on Point arguments (#1280)
    Do not drop point geometries in densification step!
diff --git a/src/algorithm/distance/DiscreteFrechetDistance.cpp b/src/algorithm/distance/DiscreteFrechetDistance.cpp
index 4fa6d0f50..29f4a364f 100644
--- a/src/algorithm/distance/DiscreteFrechetDistance.cpp
+++ b/src/algorithm/distance/DiscreteFrechetDistance.cpp
@@ -343,8 +343,12 @@ DiscreteFrechetDistance::DensifiedCoordinatesFilter::filter_ro(
     // Skip the first coordinate so we can operate an edge
     // at a time
-    if (index == 0)
+    if (index == 0) {
+        // Preserve one coordinate for points
+        if (seq.size() == 1)
+            m_coords.add(seq.getAt(index), true);
         return;
     const geom::Coordinate& p0 = seq.getAt(index - 1);
     const geom::Coordinate& p1 = seq.getAt(index);
diff --git a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
index d118b494f..86472ac06 100644
--- a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
@@ -153,7 +153,7 @@ void object::test<6> ()
-// Large test data set caused stack overflow in old
+// Large test data set caused stack overflow in old
 // recursive version of the algorithm
 // https://github.com/libgeos/geos/issues/516
@@ -173,5 +173,11 @@ void object::test<8> ()
     checkDensifiedFrechet("LINESTRING(1 0, 2 0)", "LINESTRING(-1 0, 0 0, 7 8)", 0.002, 9.43398);
+template<>
+template<>
+void object::test<9> ()
+    checkDensifiedFrechet("POINT(-11.1111111 40)", "POINT(-11.1111111 40)", 0.8, 0);
 } // namespace tut
Summary of changes:
 src/algorithm/distance/DiscreteFrechetDistance.cpp            | 6 +++++-
 tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp | 8 +++++++-
 2 files changed, 12 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
