[geos-commits] [SCM] GEOS branch main updated. a7b98f56014ede6ecbeae43d2abef78b2a527871
    git at osgeo.org
    git at osgeo.org
    Tue Jul  8 13:13:50 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  a7b98f56014ede6ecbeae43d2abef78b2a527871 (commit)
      from  34a1e547d4a016e482539c936bfe0a8ba49a9d54 (commit)
revisions in full, below.
commit a7b98f56014ede6ecbeae43d2abef78b2a527871
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jul 8 13:13:31 2025 -0700
    Catch empty components of CompoundCurve in validation
    closes #1167
diff --git a/src/geom/CompoundCurve.cpp b/src/geom/CompoundCurve.cpp
index 740e7c5bc..9c01111b6 100644
--- a/src/geom/CompoundCurve.cpp
+++ b/src/geom/CompoundCurve.cpp
@@ -314,13 +314,19 @@ CompoundCurve::reverseImpl() const
 void
 CompoundCurve::validateConstruction() const
+    for (std::size_t i = 0; i < curves.size(); i++) {
+        if (curves[i]->isEmpty()) {
+            std::ostringstream ss;
+            ss << "Section " << i << " of CompoundCurve is empty";
+            throw util::IllegalArgumentException(ss.str());
     for (std::size_t i = 1; i < curves.size(); i++) {
         const CoordinateXY& end = curves[i-1]->getCoordinatesRO()->back<CoordinateXY>();
         const CoordinateXY& start = curves[i]->getCoordinatesRO()->front<CoordinateXY>();
         if (start != end) {
             ss << "Sections of CompoundCurve are not contiguous: " <<
                    "curve " << (i-1) << " ends at " << end <<
                    " ; curve " << i << " begins at " << start;
diff --git a/tests/unit/geom/CompoundCurveTest.cpp b/tests/unit/geom/CompoundCurveTest.cpp
index 958cf109e..165c67338 100644
--- a/tests/unit/geom/CompoundCurveTest.cpp
+++ b/tests/unit/geom/CompoundCurveTest.cpp
@@ -322,11 +322,12 @@ void object::test<9>()
     curves.push_back(wktreader_.read<SimpleCurve>("LINESTRING (0 0, 1 2)"));
     curves.push_back(wktreader_.read<SimpleCurve>("CIRCULARSTRING (2 1, 3 3, 4 1)"));
+    ensure_THROW(factory_->createCompoundCurve(std::move(curves)), geos::util::IllegalArgumentException);
+    curves.clear();
+    curves.push_back(wktreader_.read<SimpleCurve>("LINESTRING (0 0, 1 2)"));
+    curves.push_back(wktreader_.read<SimpleCurve>("CIRCULARSTRING EMPTY"));
Summary of changes:
 src/geom/CompoundCurve.cpp            | 8 +++++++-
 tests/unit/geom/CompoundCurveTest.cpp | 7 ++++---
 2 files changed, 11 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
