[geos-commits] [SCM] GEOS branch main updated. 20c5648b2774de312f0a5d03fb6c9354a42dd0af
git at osgeo.org
git at osgeo.org
Tue Jul 8 14:41:43 PDT 2025
the project "GEOS".
The branch, main has been updated
via 20c5648b2774de312f0a5d03fb6c9354a42dd0af (commit)
from 76d6074e6565d863e157076664cc89e6944f0a0c (commit)
revisions in full, below.
commit 20c5648b2774de312f0a5d03fb6c9354a42dd0af
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jul 8 14:41:19 2025 -0700
Remove unused implementation of GeometryPrecisionReducer
diff --git a/src/precision/PrecisionReducerCoordinateOperation.cpp b/src/precision/PrecisionReducerCoordinateOperation.cpp
deleted file mode 100644
index 4f0338821..000000000
--- a/src/precision/PrecisionReducerCoordinateOperation.cpp
+++ /dev/null
@@ -1,92 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2012 Sandro Santilli <strk at kbt.io>
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: precision/PrecisionreducerCoordinateOperation.java r591 (JTS-1.12)
-#include <geos/precision/PrecisionReducerCoordinateOperation.h>
-#include <geos/geom/PrecisionModel.h>
-#include <geos/geom/CoordinateSequence.h>
-#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/Geometry.h>
-#include <geos/geom/LineString.h>
-#include <geos/geom/LinearRing.h>
-#include <geos/operation/valid/RepeatedPointRemover.h>
-#include <geos/util.h>
-#include <vector>
-using namespace geos::geom;
-namespace geos {
-namespace precision { // geos.precision
-std::unique_ptr<CoordinateSequence>
-PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
- const Geometry* geom)
- auto csSize = cs->size();
- if(csSize == 0) {
- return nullptr;
- auto reducedCoords = detail::make_unique<CoordinateSequence>(csSize);
- // copy coordinates and reduce
- for(std::size_t i = 0; i < csSize; ++i) {
- (*reducedCoords)[i] = cs->getAt(i);
- targetPM.makePrecise((*reducedCoords)[i]);
- // remove repeated points, to simplify returned geometry as
- // much as possible.
- std::unique_ptr<CoordinateSequence> noRepeatedCoords = operation::valid::RepeatedPointRemover::removeRepeatedPoints(reducedCoords.get());
- * Check to see if the removal of repeated points
- * collapsed the coordinate List to an invalid length
- * for the type of the parent geometry.
- * It is not necessary to check for Point collapses,
- * since the coordinate list can
- * never collapse to less than one point.
- * If the length is invalid, return the full-length coordinate array
- * first computed, or null if collapses are being removed.
- * (This may create an invalid geometry - the client must handle this.)
- unsigned int minLength = 0;
- if(dynamic_cast<const LineString*>(geom)) {
- minLength = 2;
- if(dynamic_cast<const LinearRing*>(geom)) {
- minLength = 4;
- if(removeCollapsed) {
- reducedCoords = nullptr;
- // return null or original length coordinate array
- if(noRepeatedCoords->getSize() < minLength) {
- return reducedCoords;
- // ok to return shorter coordinate array
- return noRepeatedCoords;
-} // namespace geos.precision
Summary of changes:
.../PrecisionReducerCoordinateOperation.cpp | 92 ----------------------
1 file changed, 92 deletions(-)
delete mode 100644 src/precision/PrecisionReducerCoordinateOperation.cpp
hooks/post-receive
More information about the geos-commits
