[geos-commits] [SCM] GEOS branch main updated. 7e3fd04eda8706c227b73ddd09e4d104c7c8fb5a
    git at osgeo.org
    git at osgeo.org
    Wed Jul 16 14:52:21 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  7e3fd04eda8706c227b73ddd09e4d104c7c8fb5a (commit)
      from  ded33834934a547ecfd3a885f096bfcb2e2b8e3f (commit)
revisions in full, below.
commit 7e3fd04eda8706c227b73ddd09e4d104c7c8fb5a
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Jul 16 17:51:58 2025 -0400
    TemplateSTRTree: throw exception on invalid node capacity (#1288)
    Resolves https://github.com/libgeos/geos/issues/1287
diff --git a/include/geos/index/strtree/TemplateSTRtree.h b/include/geos/index/strtree/TemplateSTRtree.h
index baae429d0..381aeeea1 100644
--- a/include/geos/index/strtree/TemplateSTRtree.h
+++ b/include/geos/index/strtree/TemplateSTRtree.h
@@ -131,7 +131,9 @@ public:
         root(nullptr),
         nodeCapacity(p_nodeCapacity),
         numItems(0)
+        validateConstruction();
      * Constructs a tree with the given maximum number of child nodes that
@@ -141,9 +143,11 @@ public:
     TemplateSTRtreeImpl(size_t p_nodeCapacity, size_t itemCapacity) :
         root(nullptr),
-        numItems(0) {
+        numItems(0)
         auto finalSize = treeSize(itemCapacity);
         nodes.reserve(finalSize);
@@ -678,6 +682,12 @@ protected:
     static size_t sliceCapacity(size_t numNodes, size_t numSlices) {
         return static_cast<size_t>(std::ceil(static_cast<double>(numNodes) / static_cast<double>(numSlices)));
+    void validateConstruction() const {
+        if (nodeCapacity < 2) {
+            throw util::IllegalArgumentException("STRTree node capacity must be >= 2");
 struct EnvelopeTraits {
diff --git a/tests/unit/capi/GEOSSTRtreeTest.cpp b/tests/unit/capi/GEOSSTRtreeTest.cpp
index ab3697fab..ad210d464 100644
--- a/tests/unit/capi/GEOSSTRtreeTest.cpp
+++ b/tests/unit/capi/GEOSSTRtreeTest.cpp
@@ -505,6 +505,17 @@ void object::test<14>()
     GEOSSTRtree_destroy(tree);
+template<>
+template<>
+void object::test<15>()
+    set_test_name("node capacity too small");
+    GEOSSTRtree* tree = GEOSSTRtree_create(1);
+    ensure(tree == nullptr);
 } // namespace tut
Summary of changes:
 include/geos/index/strtree/TemplateSTRtree.h | 14 ++++++++++++--
 tests/unit/capi/GEOSSTRtreeTest.cpp          | 11 +++++++++++
 2 files changed, 23 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
