[geos-commits] [SCM] GEOS branch 3.9 updated. 60c95bdfe22f7776e1ea9a65c6e7159c08a257af
Tue Jun 17 09:42:56 PDT 2025
the project "GEOS".
The branch, 3.9 has been updated
       via  60c95bdfe22f7776e1ea9a65c6e7159c08a257af (commit)
      from  a295f69e6ba2740d2d596633610189e699f590ad (commit)
revisions in full, below.
commit 60c95bdfe22f7776e1ea9a65c6e7159c08a257af
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jun 17 09:42:26 2025 -0700
    remove azure pipelines
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml
deleted file mode 100644
index 26d8a06b6..000000000
--- a/.azure-pipelines.yml
+++ /dev/null
@@ -1,256 +0,0 @@
-# Azure Pipelines for GEOS
-# All builds are based on the CMake configuration.
-# Author: Mateusz Loskot <mateusz at loskot dot net>
-# trigger:
-#   branches:
-#     include:
-#     - master
-#     - bugfix/*
-#     - feature/*
-#     - fix/*
-#     - pr/*
-pr:
-  branches:
-    include:
-    - master
-variables:
-  - name: BUILD_TYPE
-    value: Release
-stages:
-- stage: Test
-  jobs:
-  - job: 'Linux'
-    strategy:
-      matrix:
-        GCC 8:
-          CXXSTD: 11, 14, 17, 20
-          CXX: g++-8
-          PACKAGES: g++-8
-          VM_IMAGE: ubuntu-20.04
-          VM_NAME: focal
-        GCC 7:
-          CXX: g++-7
-          PACKAGES: g++-7
-          VM_NAME: focal
-        # GCC 6:
-        #   CXXSTD: 11, 14
-        #   CXX: g++-6
-        #   PACKAGES: g++-6
-        # GCC 5:
-        #   CXXSTD: 11
-        #   CXX: g++-5
-        #   PACKAGES: g++-5
-        # Clang 8:
-        #   CXXSTD: 11, 14, 17
-        #   CXX: clang++-8
-        #   PACKAGES: clang-8
-        #   LLVM_REPO: llvm-toolchain-xenial-8
-        # Clang 7:
-        #   CXXSTD: 14, 17
-        #   CXX: clang++-7
-        #   PACKAGES: clang-7
-        #   LLVM_REPO: llvm-toolchain-xenial-7
-        # Clang 6:
-        #   CXXSTD: 14, 17
-        #   CXX: clang++-6.0
-        #   PACKAGES: clang-6.0
-        #   LLVM_REPO: llvm-toolchain-xenial-6.0
-        # Clang 5:
-        #   PACKAGES: clang-5.0
-        #   CXX: clang++-5.0
-        #   LLVM_REPO: llvm-toolchain-xenial-5.0
-        # Clang 4:
-        #   CXXSTD: 11, 14
-        #   CXX: clang++-4.0
-        #   PACKAGES: clang-4.0
-        #   LLVM_REPO: llvm-toolchain-xenial-4.0
-        # Clang 3.9:
-        #   CXXSTD: 11, 14
-        #   CXX: clang++-3.9
-        #   PACKAGES: clang-3.9
-    pool:
-      vmImage: $(VM_IMAGE)
-    steps:
-    - script: |
-        set -e
-        uname -a
-        sudo -E apt-add-repository -y "ppa:ubuntu-toolchain-r/test"
-        if test -n "${LLVM_REPO}" ; then
-          wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | sudo apt-key add -
-          sudo -E apt-add-repository "deb http://apt.llvm.org/${VM_NAME}/ ${LLVM_REPO} main"
-        fi
-        sudo -E apt-get update
-        sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cmake ${PACKAGES}
-      displayName: 'Install'
-    - script: |
-        set -e
-        mkdir build.cxx11
-        cd build.cxx11
-        cmake --version
-        cmake -DCMAKE_CXX_STANDARD=11 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
-        cmake --build . --config $BUILD_TYPE
-        ctest -V --output-on-failure -C $BUILD_TYPE
-      displayName: 'Build C++11'
-      condition: contains(variables['CXXSTD'], '11')
-    - script: |
-        set -e
-        mkdir build.cxx14
-        cd build.cxx14
-        cmake --version
-        cmake -DCMAKE_CXX_STANDARD=14 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
-      displayName: 'Build C++14'
-      condition: contains(variables['CXXSTD'], '14')
-    - script: |
-        set -e
-        mkdir build.cxx17
-        cd build.cxx17
-        cmake --version
-        cmake -DCMAKE_CXX_STANDARD=17 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
-      displayName: 'Build C++17'
-      condition: contains(variables['CXXSTD'], '17')
-    - script: |
-        set -e
-        mkdir build.cxx20
-        cd build.cxx20
-        cmake --version
-        cmake -DCMAKE_CXX_STANDARD=20 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
-      displayName: 'Build C++20'
-      condition: contains(variables['CXXSTD'], '20')
-  - job: 'Windows'
-    strategy:
-      matrix:
-        #Disabled until MSVC 16.4 is released
-        #(see https://developercommunity.visualstudio.com/content/problem/726778/this-snippet-compiles-totally-fine-on-godbolt-msvc.html?childToView=744771#comment-744771)
-        VS 2019 C++20 Strict:
-          TOOLSET: msvc-14.2
-          CXXSTD: 20
-          VM_IMAGE: 'windows-2019'
-        # VS 2017 C++17:
-        #   TOOLSET: msvc-14.1
-        #   CXXSTD: 17
-        #   VM_IMAGE: 'vs2017-win2016'
-        # VS 2017 C++14:
-        #   CXXSTD: 14 # default
-    pool:
-    steps:
-    - powershell: |
-        Write-Host "Installing CMake 3.14.4"
-        Invoke-WebRequest https://cmake.org/files/v3.14/cmake-3.14.4-win64-x64.zip -OutFile C:\cmake-3.14.4-win64-x64.zip
-        Expand-Archive C:\cmake-3.14.4-win64-x64.zip -DestinationPath C:\
-        Rename-Item -Path C:\cmake-3.14.4-win64-x64 -NewName C:\cmake
-        Write-Host "##vso[task.prependpath]C:\cmake\bin"
-    - script: |
-        mkdir build.cxx%CXXSTD%
-        cd build.cxx%CXXSTD%
-        cmake --version
-        cmake -DCMAKE_CXX_STANDARD=%CXXSTD% -DBUILD_SHARED_LIBS=ON ..
-      displayName: 'CMake'
-    - script: |
-        cmake --build . --config %BUILD_TYPE%
-      displayName: 'Build'
-    - script: |
-        ctest -V --output-on-failure -C %BUILD_TYPE%
-      displayName: 'Test'
-  - job: 'macOS'
-    pool:
-      vmImage: 'macOS-11'
-    strategy:
-      matrix:
-        # https://github.com/actions/runner-images/blob/main/images/macos/macos-11-Readme.md#xcode
-        Xcode 11.7:
-          TOOLSET: clang
-          CXXSTD: 11, 17
-          XCODE_APP: /Applications/Xcode_11.7.app
-        # Xcode 10.1:
-        #   TOOLSET: clang
-        #   CXXSTD: 14, 17
-        #   XCODE_APP: /Applications/Xcode_10.1.app
-        # Xcode 10.0:
-        #   CXXSTD: 14, 17
-        #   XCODE_APP: /Applications/Xcode_10.app
-        # Xcode 9.4.1:
-        #   XCODE_APP: /Applications/Xcode_9.4.1.app
-    steps:
-    - script: |
-        set -e
-        uname -a
-        sudo xcode-select -switch ${XCODE_APP}
-        which clang++
-        clang++ --version
-      displayName: Install
-    - script: |
-        set -e
-        mkdir build.cxx11
-        cd build.cxx11
-        cmake --version
-    - script: |
-        set -e
-        mkdir build.cxx14
-        cd build.cxx14
-        cmake --version
-    - script: |
-        set -e
-        mkdir build.cxx17
-        cd build.cxx17
-        cmake --version
-    - script: |
-        set -e
-        mkdir build.cxx20
-        cd build.cxx20
-        cmake --version
-  - job: Code_quality_checks
-    pool:
-      vmImage: 'ubuntu-latest'
-    steps:
-    - script: |
-        set -e
-        sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
-        ./tools/cppcheck.sh
-      displayName: 'cppcheck'
Summary of changes:
 .azure-pipelines.yml | 256 ---------------------------------------------------
 1 file changed, 256 deletions(-)
 delete mode 100644 .azure-pipelines.yml
hooks/post-receive
More information about the geos-commits mailing list
