[geos-commits] [SCM] GEOS branch 3.9 updated. 082161ef5c34a47178742167fa7025b6ff31ad47
Mon Mar 3 09:26:21 PST 2025
the project "GEOS".
The branch, 3.9 has been updated
       via  082161ef5c34a47178742167fa7025b6ff31ad47 (commit)
      from  835d1360220955ca0928f9d8ff9472bbede4ae27 (commit)
revisions in full, below.
commit 082161ef5c34a47178742167fa7025b6ff31ad47
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Mar 3 09:25:47 2025 -0800
    Fix some build issues prior to relesae
diff --git a/NEWS b/NEWS
index 889f00328..cc884c558 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 ## Changes in 3.9.6
-xxxx-xx-xx
+2025-03-03
 - Bug fixes / improvements:
   - Intersection: change to using DoubleDouble computation to improve robustness (GH-937, Martin Davis)
diff --git a/Version.txt b/Version.txt
index b0c752dcc..f8bdd47ac 100644
--- a/Version.txt
+++ b/Version.txt
@@ -5,7 +5,7 @@ GEOS_VERSION_MINOR=9
 GEOS_VERSION_PATCH=6
 # OPTIONS: "", "dev", "rc1" etc.
-GEOS_PATCH_WORD=dev
+GEOS_PATCH_WORD=
 # GEOS CAPI Versions
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index df6269675..6efc698ee 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -133,8 +133,7 @@ public:
      * the circumcentre of an obtuse isosceles triangle lies outside the triangle.
      * This method uses @ref geos::math::DD extended-precision arithmetic to provide more accurate
-     * results than [circumcentre(Coordinate, Coordinate, Coordinate)]
-     * (@ref geos::geom::Triangle::circumcentre(const Coordinate& p0, const Coordinate& p1, const Coordinate& p2)).
+     * results than Triangle::circumcentre(Coordinate, Coordinate, Coordinate)
      * @param a
      *          a vertex of the triangle
diff --git a/include/geos/io/WKBWriter.h b/include/geos/io/WKBWriter.h
index 48f6beade..fd15f49c9 100644
--- a/include/geos/io/WKBWriter.h
+++ b/include/geos/io/WKBWriter.h
@@ -25,6 +25,7 @@
 #include <geos/util/Machine.h> // for getMachineByteOrder
 #include <iosfwd>
 #include <cstdint>
+#include <cstddef>
 // Forward declarations
 namespace geos {
@@ -200,7 +201,7 @@ private:
     void writeCoordinateSequence(const geom::CoordinateSequence& cs, bool sized);
     // throws IOException
-    void writeCoordinate(const geom::CoordinateSequence& cs, size_t idx, bool is3d);
+    void writeCoordinate(const geom::CoordinateSequence& cs, std::size_t idx, bool is3d);
     void writeGeometryType(int geometryType, int SRID);
diff --git a/include/geos/operation/distance/IndexedFacetDistance.h b/include/geos/operation/distance/IndexedFacetDistance.h
index 19d7e5ba6..6dd7d65fa 100644
--- a/include/geos/operation/distance/IndexedFacetDistance.h
+++ b/include/geos/operation/distance/IndexedFacetDistance.h
@@ -39,7 +39,7 @@ namespace distance {
 ///   an repeated query situation.
 /// Using this technique is usually much more performant than using the
-/// brute-force \ref geom::Geometry::distance(const Geometry* g) const when one
+/// brute-force Geometry::distance(const Geometry* g) const when one
 /// or both input geometries are large, or when evaluating many distance
 /// computations against a single geometry.
diff --git a/include/geos/operation/overlayng/OverlayNG.h b/include/geos/operation/overlayng/OverlayNG.h
index 7fed36bba..c412320f2 100644
--- a/include/geos/operation/overlayng/OverlayNG.h
+++ b/include/geos/operation/overlayng/OverlayNG.h
@@ -271,7 +271,7 @@ public:
     * the result of overlaying the geometries using
     * a given overlay operation.
-    * The method handles arguments of {@link Location#NONE} correctly
+    * The method handles arguments of Location::NONE correctly
     static bool isResultOfOpPoint(const OverlayLabel* label, int opCode);
@@ -284,7 +284,7 @@ public:
     * computed during the overlay process should be
     * included in the result geometry.
-    * The method handles arguments of {@link Location#NONE} correctly.
+    * The method handles arguments of Location::NONE correctly.
     static bool isResultOfOp(int overlayOpCode, Location loc0, Location loc1);
diff --git a/include/geos/operation/union/UnaryUnionOp.h b/include/geos/operation/union/UnaryUnionOp.h
index 0ba3de933..e3a3e6fba 100644
--- a/include/geos/operation/union/UnaryUnionOp.h
+++ b/include/geos/operation/union/UnaryUnionOp.h
@@ -73,7 +73,7 @@ namespace geounion {  // geos::operation::geounion
  *   or portions of line segments will be reduced to a single line segment
  *   in the output.
  *   This is consistent with the semantics of the
- *   [Geometry::Union(Geometry* )](@ref geom::Geometry::Union(const Geometry* other) const)
+ *   Geometry::Union(const Geometry* other)
  *   operation. If **merged** linework is required, the
  *   [LineMerger](@ref operation::linemerge::LineMerger) class
  *   can be used.
diff --git a/src/io/WKBWriter.cpp b/src/io/WKBWriter.cpp
index d6bbb7e63..411f98f58 100644
--- a/src/io/WKBWriter.cpp
+++ b/src/io/WKBWriter.cpp
@@ -301,7 +301,7 @@ WKBWriter::writeCoordinateSequence(const CoordinateSequence& cs,
 void
-WKBWriter::writeCoordinate(const CoordinateSequence& cs, size_t idx,
+WKBWriter::writeCoordinate(const CoordinateSequence& cs, std::size_t idx,
                            bool is3d)
 #if DEBUG_WKB_WRITER
Summary of changes:
 NEWS                                                   | 2 +-
 Version.txt                                            | 2 +-
 include/geos/algorithm/CGAlgorithmsDD.h                | 3 +--
 include/geos/io/WKBWriter.h                            | 3 ++-
 include/geos/operation/distance/IndexedFacetDistance.h | 2 +-
 include/geos/operation/overlayng/OverlayNG.h           | 4 ++--
 include/geos/operation/union/UnaryUnionOp.h            | 2 +-
 src/io/WKBWriter.cpp                                   | 2 +-
 8 files changed, 10 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
