[geos-commits] [SCM] GEOS branch main-json created. b88ee32d9568c2cedc6c6c8d651a3558bc9e512c
Mon Mar 3 16:35:24 PST 2025
the project "GEOS".
The branch, main-json has been created
        at  b88ee32d9568c2cedc6c6c8d651a3558bc9e512c (commit)
commit b88ee32d9568c2cedc6c6c8d651a3558bc9e512c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Mar 3 16:34:51 2025 -0800
    codespell
diff --git a/include/geos/vend/json.hpp b/include/geos/vend/json.hpp
index 8b72ea653..9a2fc4e50 100644
--- a/include/geos/vend/json.hpp
+++ b/include/geos/vend/json.hpp
@@ -11082,8 +11082,8 @@ class binary_reader
-    @param[out] dim  an integer vector storing the ND array dimensions
-    @return whether reading ND array size vector is successful
+    @param[out] dim  an integer vector storing the array dimensions
+    @return whether reading array size vector is successful
     bool get_ubjson_ndarray_size(std::vector<size_t>& dim)
@@ -11369,7 +11369,7 @@ class binary_reader
     for a more compact representation.
     @param[out] result  pair of the size and the type
-    @param[in] inside_ndarray  whether the parser is parsing an ND array dimensional vector
+    @param[in] inside_ndarray  whether the parser is parsing an array dimensional vector
     @return whether pair creation completed
commit c0769a601ea9000bf884952a7ad371009e0b76e7
Date:   Mon Mar 3 16:09:02 2025 -0800
    Update the nlohmann/json header to version 3.11.3
    References #1247
index 315e0a35b..8b72ea653 100644
@@ -1,57 +1,160 @@
-    __ _____ _____ _____
- __|  |   __|     |   | |  JSON for Modern C++
-|  |  |__   |  |  | | | |  version 3.9.1
-|_____|_____|_____|_|___|  https://github.com/nlohmann/json
+//     __ _____ _____ _____
+//  __|  |   __|     |   | |  JSON for Modern C++
+// |  |  |__   |  |  | | | |  version 3.11.3
+// |_____|_____|_____|_|___|  https://github.com/nlohmann/json
+// SPDX-FileCopyrightText: 2013-2023 Niels Lohmann <https://nlohmann.me>
+// SPDX-License-Identifier: MIT
-Licensed under the MIT License <http://opensource.org/licenses/MIT>.
-SPDX-License-Identifier: MIT
-Copyright (c) 2013-2019 Niels Lohmann <http://nlohmann.me>.
-Permission is hereby  granted, free of charge, to any  person obtaining a copy
-of this software and associated  documentation files (the "Software"), to deal
-in the Software  without restriction, including without  limitation the rights
-to  use, copy,  modify, merge,  publish, distribute,  sublicense, and/or  sell
-copies  of  the Software,  and  to  permit persons  to  whom  the Software  is
-furnished to do so, subject to the following conditions:
-The above copyright notice and this permission notice shall be included in all
-copies or substantial portions of the Software.
-THE SOFTWARE  IS PROVIDED "AS  IS", WITHOUT WARRANTY  OF ANY KIND,  EXPRESS OR
-IMPLIED,  INCLUDING BUT  NOT  LIMITED TO  THE  WARRANTIES OF  MERCHANTABILITY,
-FITNESS FOR  A PARTICULAR PURPOSE AND  NONINFRINGEMENT. IN NO EVENT  SHALL THE
-AUTHORS  OR COPYRIGHT  HOLDERS  BE  LIABLE FOR  ANY  CLAIM,  DAMAGES OR  OTHER
-LIABILITY, WHETHER IN AN ACTION OF  CONTRACT, TORT OR OTHERWISE, ARISING FROM,
-OUT OF OR IN CONNECTION WITH THE SOFTWARE  OR THE USE OR OTHER DEALINGS IN THE
-SOFTWARE.
+ * Note on documentation: The source files contain links to the online      *
+ * documentation of the public API at https://json.nlohmann.me. This URL    *
+ * contains the most recent documentation and should also be applicable to  *
+ * previous versions; documentation for deprecated functions is not         *
+ * removed, but marked deprecated. See "Generate documentation" section in  *
+ * file docs/README.md.                                                     *
 #ifndef INCLUDE_NLOHMANN_JSON_HPP_
 #define INCLUDE_NLOHMANN_JSON_HPP_
-#define NLOHMANN_JSON_VERSION_MAJOR 3
-#define NLOHMANN_JSON_VERSION_MINOR 9
-#define NLOHMANN_JSON_VERSION_PATCH 1
 #include <algorithm> // all_of, find, for_each
 #include <cstddef> // nullptr_t, ptrdiff_t, size_t
 #include <functional> // hash, less
 #include <initializer_list> // initializer_list
-#include <iosfwd> // istream, ostream
+#ifndef JSON_NO_IO
+    #include <iosfwd> // istream, ostream
+#endif  // JSON_NO_IO
 #include <iterator> // random_access_iterator_tag
 #include <memory> // unique_ptr
-#include <numeric> // accumulate
 #include <string> // string, stoi, to_string
 #include <utility> // declval, forward, move, pair, swap
 #include <vector> // vector
 // #include <nlohmann/adl_serializer.hpp>
 #include <utility>
+// #include <nlohmann/detail/abi_macros.hpp>
+// This file contains all macro definitions affecting or depending on the ABI
+#ifndef JSON_SKIP_LIBRARY_VERSION_CHECK
+    #if defined(NLOHMANN_JSON_VERSION_MAJOR) && defined(NLOHMANN_JSON_VERSION_MINOR) && defined(NLOHMANN_JSON_VERSION_PATCH)
+        #if NLOHMANN_JSON_VERSION_MAJOR != 3 || NLOHMANN_JSON_VERSION_MINOR != 11 || NLOHMANN_JSON_VERSION_PATCH != 3
+            #warning "Already included a different version of the library!"
+        #endif
+    #endif
+#endif
+#define NLOHMANN_JSON_VERSION_MAJOR 3   // NOLINT(modernize-macro-to-enum)
+#define NLOHMANN_JSON_VERSION_MINOR 11  // NOLINT(modernize-macro-to-enum)
+#define NLOHMANN_JSON_VERSION_PATCH 3   // NOLINT(modernize-macro-to-enum)
+#ifndef JSON_DIAGNOSTICS
+    #define JSON_DIAGNOSTICS 0
+#endif
+#ifndef JSON_USE_LEGACY_DISCARDED_VALUE_COMPARISON
+    #define JSON_USE_LEGACY_DISCARDED_VALUE_COMPARISON 0
+#endif
+#if JSON_DIAGNOSTICS
+    #define NLOHMANN_JSON_ABI_TAG_DIAGNOSTICS _diag
+#else
+#endif
+#if JSON_USE_LEGACY_DISCARDED_VALUE_COMPARISON
+    #define NLOHMANN_JSON_ABI_TAG_LEGACY_DISCARDED_VALUE_COMPARISON _ldvcmp
+#else
+#endif
+#ifndef NLOHMANN_JSON_NAMESPACE_NO_VERSION
+    #define NLOHMANN_JSON_NAMESPACE_NO_VERSION 0
+#endif
+// Construct the namespace ABI tags component
+#define NLOHMANN_JSON_ABI_TAGS_CONCAT_EX(a, b) json_abi ## a ## b
+#define NLOHMANN_JSON_ABI_TAGS_CONCAT(a, b) \
+    NLOHMANN_JSON_ABI_TAGS_CONCAT_EX(a, b)
+#define NLOHMANN_JSON_ABI_TAGS                                       \
+    NLOHMANN_JSON_ABI_TAGS_CONCAT(                                   \
+            NLOHMANN_JSON_ABI_TAG_DIAGNOSTICS,                       \
+            NLOHMANN_JSON_ABI_TAG_LEGACY_DISCARDED_VALUE_COMPARISON)
+// Construct the namespace version component
+#define NLOHMANN_JSON_NAMESPACE_VERSION_CONCAT_EX(major, minor, patch) \
+    _v ## major ## _ ## minor ## _ ## patch
+#define NLOHMANN_JSON_NAMESPACE_VERSION_CONCAT(major, minor, patch) \
+    NLOHMANN_JSON_NAMESPACE_VERSION_CONCAT_EX(major, minor, patch)
+#if NLOHMANN_JSON_NAMESPACE_NO_VERSION
+#else
+#define NLOHMANN_JSON_NAMESPACE_VERSION                                 \
+    NLOHMANN_JSON_NAMESPACE_VERSION_CONCAT(NLOHMANN_JSON_VERSION_MAJOR, \
+                                           NLOHMANN_JSON_VERSION_MINOR, \
+                                           NLOHMANN_JSON_VERSION_PATCH)
+#endif
+// Combine namespace components
+#define NLOHMANN_JSON_NAMESPACE_CONCAT_EX(a, b) a ## b
+#define NLOHMANN_JSON_NAMESPACE_CONCAT(a, b) \
+    NLOHMANN_JSON_NAMESPACE_CONCAT_EX(a, b)
+#define NLOHMANN_JSON_NAMESPACE               \
+    nlohmann::NLOHMANN_JSON_NAMESPACE_CONCAT( \
+            NLOHMANN_JSON_ABI_TAGS,           \
+            NLOHMANN_JSON_NAMESPACE_VERSION)
+#endif
+#ifndef NLOHMANN_JSON_NAMESPACE_BEGIN
+#define NLOHMANN_JSON_NAMESPACE_BEGIN                \
+    namespace nlohmann                               \
+    inline namespace NLOHMANN_JSON_NAMESPACE_CONCAT( \
+                NLOHMANN_JSON_NAMESPACE_VERSION)     \
+#endif
+#ifndef NLOHMANN_JSON_NAMESPACE_END
+#define NLOHMANN_JSON_NAMESPACE_END                                     \
+    }  /* namespace (inline namespace) NOLINT(readability/namespace) */ \
+    }  // namespace nlohmann
+#endif
 // #include <nlohmann/detail/conversions/from_json.hpp>
 #include <algorithm> // transform
@@ -67,63 +170,172 @@ SOFTWARE.
 #include <valarray> // valarray
 // #include <nlohmann/detail/exceptions.hpp>
+#include <cstddef> // nullptr_t
 #include <exception> // exception
+    #include <numeric> // accumulate
+#endif
 #include <stdexcept> // runtime_error
 #include <string> // to_string
+#include <vector> // vector
-// #include <nlohmann/detail/input/position_t.hpp>
+// #include <nlohmann/detail/value_t.hpp>
+#include <array> // array
 #include <cstddef> // size_t
-namespace nlohmann
-namespace detail
-/// struct to capture the start position of the current token
-struct position_t
-    /// the total number of characters read
-    std::size_t chars_read_total = 0;
-    /// the number of characters read in the current line
-    std::size_t chars_read_current_line = 0;
-    /// the number of lines read
-    std::size_t lines_read = 0;
-    /// conversion to size_t to preserve SAX interface
-    constexpr operator size_t() const
-        return chars_read_total;
-} // namespace detail
-} // namespace nlohmann
+#include <cstdint> // uint8_t
+#include <string> // string
 // #include <nlohmann/detail/macro_scope.hpp>
-#include <utility> // pair
+#include <utility> // declval, pair
+// #include <nlohmann/detail/meta/detected.hpp>
+#include <type_traits>
+// #include <nlohmann/detail/meta/void_t.hpp>
+NLOHMANN_JSON_NAMESPACE_BEGIN
+namespace detail
+template<typename ...Ts> struct make_void
+    using type = void;
+template<typename ...Ts> using void_t = typename make_void<Ts...>::type;
+}  // namespace detail
+NLOHMANN_JSON_NAMESPACE_END
+namespace detail
+// https://en.cppreference.com/w/cpp/experimental/is_detected
+struct nonesuch
+    nonesuch() = delete;
+    ~nonesuch() = delete;
+    nonesuch(nonesuch const&) = delete;
+    nonesuch(nonesuch const&&) = delete;
+    void operator=(nonesuch const&) = delete;
+    void operator=(nonesuch&&) = delete;
+template<class Default,
+         class AlwaysVoid,
+         template<class...> class Op,
+         class... Args>
+struct detector
+    using value_t = std::false_type;
+    using type = Default;
+template<class Default, template<class...> class Op, class... Args>
+struct detector<Default, void_t<Op<Args...>>, Op, Args...>
+    using value_t = std::true_type;
+    using type = Op<Args...>;
+template<template<class...> class Op, class... Args>
+using is_detected = typename detector<nonesuch, void, Op, Args...>::value_t;
+struct is_detected_lazy : is_detected<Op, Args...> { };
+using detected_t = typename detector<nonesuch, void, Op, Args...>::type;
+using detected_or = detector<Default, void, Op, Args...>;
+using detected_or_t = typename detected_or<Default, Op, Args...>::type;
+template<class Expected, template<class...> class Op, class... Args>
+using is_detected_exact = std::is_same<Expected, detected_t<Op, Args...>>;
+template<class To, template<class...> class Op, class... Args>
+using is_detected_convertible =
+    std::is_convertible<detected_t<Op, Args...>, To>;
 // #include <nlohmann/thirdparty/hedley/hedley.hpp>
+// SPDX-FileCopyrightText: 2016-2021 Evan Nemerson <evan at nemerson.com>
 /* Hedley - https://nemequ.github.io/hedley
  * Created by Evan Nemerson <evan at nemerson.com>
- * To the extent possible under law, the author(s) have dedicated all
- * copyright and related and neighboring rights to this software to
- * the public domain worldwide. This software is distributed without
- * any warranty.
- * For details, see <http://creativecommons.org/publicdomain/zero/1.0/>.
- * SPDX-License-Identifier: CC0-1.0
-#if !defined(JSON_HEDLEY_VERSION) || (JSON_HEDLEY_VERSION < 14)
+#if !defined(JSON_HEDLEY_VERSION) || (JSON_HEDLEY_VERSION < 15)
 #if defined(JSON_HEDLEY_VERSION)
     #undef JSON_HEDLEY_VERSION
 #endif
-#define JSON_HEDLEY_VERSION 14
+#define JSON_HEDLEY_VERSION 15
 #if defined(JSON_HEDLEY_STRINGIFY_EX)
     #undef JSON_HEDLEY_STRINGIFY_EX
@@ -490,7 +702,7 @@ struct position_t
     #if __VER__ > 1000
         #define JSON_HEDLEY_IAR_VERSION JSON_HEDLEY_VERSION_ENCODE((__VER__ / 1000000), ((__VER__ / 1000) % 1000), (__VER__ % 1000))
     #else
-        #define JSON_HEDLEY_IAR_VERSION JSON_HEDLEY_VERSION_ENCODE(VER / 100, __VER__ % 100, 0)
+        #define JSON_HEDLEY_IAR_VERSION JSON_HEDLEY_VERSION_ENCODE(__VER__ / 100, __VER__ % 100, 0)
     #endif
 #endif
@@ -567,6 +779,22 @@ struct position_t
     #define JSON_HEDLEY_PELLES_VERSION_CHECK(major,minor,patch) (0)
 #endif
+#if defined(JSON_HEDLEY_MCST_LCC_VERSION)
+    #undef JSON_HEDLEY_MCST_LCC_VERSION
+#endif
+#if defined(__LCC__) && defined(__LCC_MINOR__)
+    #define JSON_HEDLEY_MCST_LCC_VERSION JSON_HEDLEY_VERSION_ENCODE(__LCC__ / 100, __LCC__ % 100, __LCC_MINOR__)
+#endif
+#if defined(JSON_HEDLEY_MCST_LCC_VERSION_CHECK)
+    #undef JSON_HEDLEY_MCST_LCC_VERSION_CHECK
+#endif
+    #define JSON_HEDLEY_MCST_LCC_VERSION_CHECK(major,minor,patch) (JSON_HEDLEY_MCST_LCC_VERSION >= JSON_HEDLEY_VERSION_ENCODE(major, minor, patch))
+#else
+    #define JSON_HEDLEY_MCST_LCC_VERSION_CHECK(major,minor,patch) (0)
+#endif
 #if defined(JSON_HEDLEY_GCC_VERSION)
     #undef JSON_HEDLEY_GCC_VERSION
 #endif
@@ -576,6 +804,7 @@ struct position_t
     !defined(JSON_HEDLEY_INTEL_VERSION) && \
     !defined(JSON_HEDLEY_PGI_VERSION) && \
     !defined(JSON_HEDLEY_ARM_VERSION) && \
+    !defined(JSON_HEDLEY_CRAY_VERSION) && \
     !defined(JSON_HEDLEY_TI_VERSION) && \
     !defined(JSON_HEDLEY_TI_ARMCL_VERSION) && \
     !defined(JSON_HEDLEY_TI_CL430_VERSION) && \
@@ -583,7 +812,8 @@ struct position_t
     !defined(JSON_HEDLEY_TI_CL6X_VERSION) && \
     !defined(JSON_HEDLEY_TI_CL7X_VERSION) && \
     !defined(JSON_HEDLEY_TI_CLPRU_VERSION) && \
-    !defined(__COMPCERT__)
+    !defined(__COMPCERT__) && \
+    !defined(JSON_HEDLEY_MCST_LCC_VERSION)
     #define JSON_HEDLEY_GCC_VERSION JSON_HEDLEY_GNUC_VERSION
 #endif
@@ -599,17 +829,21 @@ struct position_t
 #if defined(JSON_HEDLEY_HAS_ATTRIBUTE)
     #undef JSON_HEDLEY_HAS_ATTRIBUTE
 #endif
-#if defined(__has_attribute)
-    #define JSON_HEDLEY_HAS_ATTRIBUTE(attribute) __has_attribute(attribute)
+#if \
+  defined(__has_attribute) && \
+    (!defined(JSON_HEDLEY_IAR_VERSION) || JSON_HEDLEY_IAR_VERSION_CHECK(8,5,9)) \
+#  define JSON_HEDLEY_HAS_ATTRIBUTE(attribute) __has_attribute(attribute)
 #else
-    #define JSON_HEDLEY_HAS_ATTRIBUTE(attribute) (0)
+#  define JSON_HEDLEY_HAS_ATTRIBUTE(attribute) (0)
 #endif
 #if defined(JSON_HEDLEY_GNUC_HAS_ATTRIBUTE)
     #undef JSON_HEDLEY_GNUC_HAS_ATTRIBUTE
 #endif
-    #define JSON_HEDLEY_GNUC_HAS_ATTRIBUTE(attribute,major,minor,patch) __has_attribute(attribute)
+    #define JSON_HEDLEY_GNUC_HAS_ATTRIBUTE(attribute,major,minor,patch) JSON_HEDLEY_HAS_ATTRIBUTE(attribute)
 #else
     #define JSON_HEDLEY_GNUC_HAS_ATTRIBUTE(attribute,major,minor,patch) JSON_HEDLEY_GNUC_VERSION_CHECK(major,minor,patch)
 #endif
@@ -618,7 +852,7 @@ struct position_t
     #undef JSON_HEDLEY_GCC_HAS_ATTRIBUTE
 #endif
-    #define JSON_HEDLEY_GCC_HAS_ATTRIBUTE(attribute,major,minor,patch) __has_attribute(attribute)
+    #define JSON_HEDLEY_GCC_HAS_ATTRIBUTE(attribute,major,minor,patch) JSON_HEDLEY_HAS_ATTRIBUTE(attribute)
 #else
     #define JSON_HEDLEY_GCC_HAS_ATTRIBUTE(attribute,major,minor,patch) JSON_HEDLEY_GCC_VERSION_CHECK(major,minor,patch)
 #endif
@@ -982,6 +1216,8 @@ struct position_t
     #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_DEPRECATED _Pragma("GCC diagnostic ignored \"-Wdeprecated-declarations\"")
 #elif JSON_HEDLEY_MSVC_VERSION_CHECK(15,0,0)
     #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_DEPRECATED __pragma(warning(disable:4996))
+#elif JSON_HEDLEY_MCST_LCC_VERSION_CHECK(1,25,10)
+    #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_DEPRECATED _Pragma("diag_suppress 1215,1444")
 #elif \
     JSON_HEDLEY_TI_VERSION_CHECK(15,12,0) || \
     (JSON_HEDLEY_TI_ARMCL_VERSION_CHECK(4,8,0) && defined(__TI_GNU_ATTRIBUTE_SUPPORT__)) || \
@@ -1032,6 +1268,8 @@ struct position_t
     #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNKNOWN_PRAGMAS _Pragma("diag_suppress 163")
 #elif JSON_HEDLEY_IAR_VERSION_CHECK(8,0,0)
     #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNKNOWN_PRAGMAS _Pragma("diag_suppress=Pe161")
+    #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNKNOWN_PRAGMAS _Pragma("diag_suppress 161")
 #else
 #endif
@@ -1062,6 +1300,8 @@ struct position_t
     #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNKNOWN_CPP_ATTRIBUTES _Pragma("diag_suppress 1173")
     #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNKNOWN_CPP_ATTRIBUTES _Pragma("diag_suppress=Pe1097")
+    #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNKNOWN_CPP_ATTRIBUTES _Pragma("diag_suppress 1097")
 #else
 #endif
@@ -1079,6 +1319,21 @@ struct position_t
     #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_CAST_QUAL
 #endif
+#if defined(JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNUSED_FUNCTION)
+    #undef JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNUSED_FUNCTION
+#endif
+#if JSON_HEDLEY_HAS_WARNING("-Wunused-function")
+    #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNUSED_FUNCTION _Pragma("clang diagnostic ignored \"-Wunused-function\"")
+#elif JSON_HEDLEY_GCC_VERSION_CHECK(3,4,0)
+    #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNUSED_FUNCTION _Pragma("GCC diagnostic ignored \"-Wunused-function\"")
+#elif JSON_HEDLEY_MSVC_VERSION_CHECK(1,0,0)
+    #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNUSED_FUNCTION __pragma(warning(disable:4505))
+    #define JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNUSED_FUNCTION _Pragma("diag_suppress 3142")
+#else
+#endif
 #if defined(JSON_HEDLEY_DEPRECATED)
     #undef JSON_HEDLEY_DEPRECATED
 #endif
@@ -1091,7 +1346,7 @@ struct position_t
     #define JSON_HEDLEY_DEPRECATED(since) __declspec(deprecated("Since " # since))
     #define JSON_HEDLEY_DEPRECATED_FOR(since, replacement) __declspec(deprecated("Since " #since "; use " #replacement))
 #elif \
-    JSON_HEDLEY_HAS_EXTENSION(attribute_deprecated_with_message) || \
+    (JSON_HEDLEY_HAS_EXTENSION(attribute_deprecated_with_message) && !defined(JSON_HEDLEY_IAR_VERSION)) || \
     JSON_HEDLEY_GCC_VERSION_CHECK(4,5,0) || \
     JSON_HEDLEY_INTEL_VERSION_CHECK(13,0,0) || \
     JSON_HEDLEY_ARM_VERSION_CHECK(5,6,0) || \
@@ -1101,7 +1356,8 @@ struct position_t
     JSON_HEDLEY_TI_ARMCL_VERSION_CHECK(18,1,0) || \
     JSON_HEDLEY_TI_CL6X_VERSION_CHECK(8,3,0) || \
     JSON_HEDLEY_TI_CL7X_VERSION_CHECK(1,2,0) || \
-    JSON_HEDLEY_TI_CLPRU_VERSION_CHECK(2,3,0)
+    JSON_HEDLEY_TI_CLPRU_VERSION_CHECK(2,3,0) || \
+    JSON_HEDLEY_MCST_LCC_VERSION_CHECK(1,25,10)
     #define JSON_HEDLEY_DEPRECATED(since) __attribute__((__deprecated__("Since " #since)))
     #define JSON_HEDLEY_DEPRECATED_FOR(since, replacement) __attribute__((__deprecated__("Since " #since "; use " #replacement)))
 #elif defined(__cplusplus) && (__cplusplus >= 201402L)
@@ -1121,7 +1377,9 @@ struct position_t
     (JSON_HEDLEY_TI_CL6X_VERSION_CHECK(7,2,0) && defined(__TI_GNU_ATTRIBUTE_SUPPORT__)) || \
     JSON_HEDLEY_TI_CL6X_VERSION_CHECK(7,5,0) || \
-    JSON_HEDLEY_TI_CLPRU_VERSION_CHECK(2,1,0)
+    JSON_HEDLEY_TI_CLPRU_VERSION_CHECK(2,1,0) || \
+    JSON_HEDLEY_MCST_LCC_VERSION_CHECK(1,25,10) || \
+    JSON_HEDLEY_IAR_VERSION_CHECK(8,10,0)
     #define JSON_HEDLEY_DEPRECATED(since) __attribute__((__deprecated__))
     #define JSON_HEDLEY_DEPRECATED_FOR(since, replacement) __attribute__((__deprecated__))
 #elif \
@@ -1144,7 +1402,8 @@ struct position_t
 #if \
     JSON_HEDLEY_HAS_ATTRIBUTE(warning) || \
     JSON_HEDLEY_GCC_VERSION_CHECK(4,3,0) || \
-    JSON_HEDLEY_INTEL_VERSION_CHECK(13,0,0)
+    JSON_HEDLEY_INTEL_VERSION_CHECK(13,0,0) || \
     #define JSON_HEDLEY_UNAVAILABLE(available_since) __attribute__((__warning__("Not available until " #available_since)))
 #else
@@ -1172,7 +1431,8 @@ struct position_t
     (JSON_HEDLEY_SUNPRO_VERSION_CHECK(5,15,0) && defined(__cplusplus)) || \
-    JSON_HEDLEY_PGI_VERSION_CHECK(17,10,0)
+    JSON_HEDLEY_PGI_VERSION_CHECK(17,10,0) || \
     #define JSON_HEDLEY_WARN_UNUSED_RESULT __attribute__((__warn_unused_result__))
     #define JSON_HEDLEY_WARN_UNUSED_RESULT_MSG(msg) __attribute__((__warn_unused_result__))
 #elif (JSON_HEDLEY_HAS_CPP_ATTRIBUTE(nodiscard) >= 201907L)
@@ -1196,7 +1456,8 @@ struct position_t
     JSON_HEDLEY_HAS_ATTRIBUTE(sentinel) || \
     JSON_HEDLEY_GCC_VERSION_CHECK(4,0,0) || \
-    JSON_HEDLEY_ARM_VERSION_CHECK(5,4,0)
+    JSON_HEDLEY_ARM_VERSION_CHECK(5,4,0) || \
     #define JSON_HEDLEY_SENTINEL(position) __attribute__((__sentinel__(position)))
 #else
@@ -1207,7 +1468,9 @@ struct position_t
 #endif
 #if JSON_HEDLEY_IAR_VERSION_CHECK(8,0,0)
     #define JSON_HEDLEY_NO_RETURN __noreturn
-#elif JSON_HEDLEY_INTEL_VERSION_CHECK(13,0,0)
+#elif \
     #define JSON_HEDLEY_NO_RETURN __attribute__((__noreturn__))
 #elif defined(__STDC_VERSION__) && __STDC_VERSION__ >= 201112L
     #define JSON_HEDLEY_NO_RETURN _Noreturn
@@ -1229,7 +1492,8 @@ struct position_t
 #elif JSON_HEDLEY_SUNPRO_VERSION_CHECK(5,10,0)
     #define JSON_HEDLEY_NO_RETURN _Pragma("does_not_return")
@@ -1286,7 +1550,9 @@ struct position_t
     JSON_HEDLEY_PGI_VERSION_CHECK(18,10,0) || \
-    JSON_HEDLEY_IBM_VERSION_CHECK(13,1,5)
+    JSON_HEDLEY_IBM_VERSION_CHECK(13,1,5) || \
+    JSON_HEDLEY_CRAY_VERSION_CHECK(10,0,0) || \
     #define JSON_HEDLEY_UNREACHABLE() __builtin_unreachable()
 #elif defined(JSON_HEDLEY_ASSUME)
     #define JSON_HEDLEY_UNREACHABLE() JSON_HEDLEY_ASSUME(0)
@@ -1364,7 +1630,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
     #define JSON_HEDLEY_PRINTF_FORMAT(string_idx,first_to_check) __attribute__((__format__(__printf__, string_idx, first_to_check)))
 #elif JSON_HEDLEY_PELLES_VERSION_CHECK(6,0,0)
     #define JSON_HEDLEY_PRINTF_FORMAT(string_idx,first_to_check) __declspec(vaformat(printf,string_idx,first_to_check))
@@ -1401,7 +1668,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
 #endif
 #if \
   (JSON_HEDLEY_HAS_BUILTIN(__builtin_expect_with_probability) && !defined(JSON_HEDLEY_PGI_VERSION)) || \
-  JSON_HEDLEY_GCC_VERSION_CHECK(9,0,0)
+  JSON_HEDLEY_GCC_VERSION_CHECK(9,0,0) || \
 #  define JSON_HEDLEY_PREDICT(expr, value, probability) __builtin_expect_with_probability(  (expr), (value), (probability))
 #  define JSON_HEDLEY_PREDICT_TRUE(expr, probability)   __builtin_expect_with_probability(!!(expr),    1   , (probability))
 #  define JSON_HEDLEY_PREDICT_FALSE(expr, probability)  __builtin_expect_with_probability(!!(expr),    0   , (probability))
@@ -1422,7 +1690,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
   JSON_HEDLEY_TINYC_VERSION_CHECK(0,9,27) || \
-  JSON_HEDLEY_CRAY_VERSION_CHECK(8,1,0)
+  JSON_HEDLEY_CRAY_VERSION_CHECK(8,1,0) || \
 #  define JSON_HEDLEY_PREDICT(expr, expected, probability) \
     (((probability) >= 0.9) ? __builtin_expect((expr), (expected)) : (JSON_HEDLEY_STATIC_CAST(void, expected), (expr)))
 #  define JSON_HEDLEY_PREDICT_TRUE(expr, probability) \
@@ -1468,7 +1737,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
     #define JSON_HEDLEY_MALLOC __attribute__((__malloc__))
     #define JSON_HEDLEY_MALLOC _Pragma("returns_new_memory")
@@ -1501,7 +1771,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
 #  define JSON_HEDLEY_PURE __attribute__((__pure__))
 #  define JSON_HEDLEY_PURE _Pragma("does_not_write_global_data")
@@ -1537,7 +1808,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
     #define JSON_HEDLEY_CONST __attribute__((__const__))
 #elif \
@@ -1565,7 +1837,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
     (JSON_HEDLEY_SUNPRO_VERSION_CHECK(5,14,0) && defined(__cplusplus)) || \
     JSON_HEDLEY_IAR_VERSION_CHECK(8,0,0) || \
-    defined(__clang__)
+    defined(__clang__) || \
     #define JSON_HEDLEY_RESTRICT __restrict
 #elif JSON_HEDLEY_SUNPRO_VERSION_CHECK(5,3,0) && !defined(__cplusplus)
     #define JSON_HEDLEY_RESTRICT _Restrict
@@ -1593,7 +1866,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
     JSON_HEDLEY_TI_CL2000_VERSION_CHECK(6,2,0) || \
     JSON_HEDLEY_TI_CL6X_VERSION_CHECK(8,0,0) || \
     #define JSON_HEDLEY_INLINE __inline
 #else
@@ -1619,7 +1893,9 @@ JSON_HEDLEY_DIAGNOSTIC_POP
 #  define JSON_HEDLEY_ALWAYS_INLINE __attribute__((__always_inline__)) JSON_HEDLEY_INLINE
 #elif \
   JSON_HEDLEY_MSVC_VERSION_CHECK(12,0,0) || \
@@ -1661,7 +1937,9 @@ JSON_HEDLEY_DIAGNOSTIC_POP
     #define JSON_HEDLEY_NEVER_INLINE __attribute__((__noinline__))
 #elif \
     JSON_HEDLEY_MSVC_VERSION_CHECK(13,10,0) || \
@@ -1708,7 +1986,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
         JSON_HEDLEY_TI_CL6X_VERSION_CHECK(7,5,0) \
 #    define JSON_HEDLEY_PRIVATE __attribute__((__visibility__("hidden")))
 #    define JSON_HEDLEY_PUBLIC  __attribute__((__visibility__("default")))
 #  else
@@ -1724,7 +2003,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
 #if \
     JSON_HEDLEY_HAS_ATTRIBUTE(nothrow) || \
     JSON_HEDLEY_GCC_VERSION_CHECK(3,3,0) || \
     #define JSON_HEDLEY_NO_THROW __attribute__((__nothrow__))
 #elif \
     JSON_HEDLEY_MSVC_VERSION_CHECK(13,1,0) || \
@@ -1740,7 +2020,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
 #endif
 #if \
     JSON_HEDLEY_HAS_ATTRIBUTE(fallthrough) || \
-    JSON_HEDLEY_GCC_VERSION_CHECK(7,0,0)
+    JSON_HEDLEY_GCC_VERSION_CHECK(7,0,0) || \
     #define JSON_HEDLEY_FALL_THROUGH __attribute__((__fallthrough__))
 #elif JSON_HEDLEY_HAS_CPP_ATTRIBUTE_NS(clang,fallthrough)
     #define JSON_HEDLEY_FALL_THROUGH JSON_HEDLEY_DIAGNOSTIC_DISABLE_CPP98_COMPAT_WRAP_([[clang::fallthrough]])
@@ -1757,7 +2038,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
 #endif
 #if \
     JSON_HEDLEY_HAS_ATTRIBUTE(returns_nonnull) || \
-    JSON_HEDLEY_GCC_VERSION_CHECK(4,9,0)
+    JSON_HEDLEY_GCC_VERSION_CHECK(4,9,0) || \
     #define JSON_HEDLEY_RETURNS_NON_NULL __attribute__((__returns_nonnull__))
 #elif defined(_Ret_notnull_) /* SAL */
     #define JSON_HEDLEY_RETURNS_NON_NULL _Ret_notnull_
@@ -1799,7 +2081,8 @@ JSON_HEDLEY_DIAGNOSTIC_POP
     JSON_HEDLEY_IBM_VERSION_CHECK(13,1,0) || \
     JSON_HEDLEY_TI_CL6X_VERSION_CHECK(6,1,0) || \
     (JSON_HEDLEY_SUNPRO_VERSION_CHECK(5,10,0) && !defined(__cplusplus)) || \
     #define JSON_HEDLEY_IS_CONSTANT(expr) __builtin_constant_p(expr)
 #endif
 #if !defined(__cplusplus)
@@ -1823,7 +2106,7 @@ JSON_HEDLEY_DIAGNOSTIC_POP
           !defined(JSON_HEDLEY_SUNPRO_VERSION) && \
-       JSON_HEDLEY_HAS_EXTENSION(c_generic_selections) || \
+       (JSON_HEDLEY_HAS_EXTENSION(c_generic_selections) && !defined(JSON_HEDLEY_IAR_VERSION)) || \
        JSON_HEDLEY_INTEL_VERSION_CHECK(17,0,0) || \
        JSON_HEDLEY_IBM_VERSION_CHECK(12,1,0) || \
@@ -2000,7 +2283,7 @@ JSON_HEDLEY_DIAGNOSTIC_POP
 #if defined(JSON_HEDLEY_FLAGS)
     #undef JSON_HEDLEY_FLAGS
 #endif
-#if JSON_HEDLEY_HAS_ATTRIBUTE(flag_enum)
+#if JSON_HEDLEY_HAS_ATTRIBUTE(flag_enum) && (!defined(__cplusplus) || JSON_HEDLEY_HAS_WARNING("-Wbitfield-enum-conversion"))
     #define JSON_HEDLEY_FLAGS __attribute__((__flag_enum__))
 #else
@@ -2080,9 +2363,12 @@ JSON_HEDLEY_DIAGNOSTIC_POP
 #endif /* !defined(JSON_HEDLEY_VERSION) || (JSON_HEDLEY_VERSION < X) */
-// This file contains all internal macro definitions
+// This file contains all internal macro definitions (except those affecting ABI)
 // You MUST include macro_unscope.hpp at the end of json.hpp to undef all of them
 // exclude unsupported compilers
 #if !defined(JSON_SKIP_UNSUPPORTED_COMPILER_CHECK)
     #if defined(__clang__)
@@ -2097,30 +2383,136 @@ JSON_HEDLEY_DIAGNOSTIC_POP
 #endif
 // C++ language standard detection
-#if (defined(__cplusplus) && __cplusplus >= 202002L) || (defined(_MSVC_LANG) && _MSVC_LANG >= 202002L)
-    #define JSON_HAS_CPP_20
-    #define JSON_HAS_CPP_17
-    #define JSON_HAS_CPP_14
-#elif (defined(__cplusplus) && __cplusplus >= 201703L) || (defined(_HAS_CXX17) && _HAS_CXX17 == 1) // fix for issue #464
-#elif (defined(__cplusplus) && __cplusplus >= 201402L) || (defined(_HAS_CXX14) && _HAS_CXX14 == 1)
+// if the user manually specified the used c++ version this is skipped
+#if !defined(JSON_HAS_CPP_20) && !defined(JSON_HAS_CPP_17) && !defined(JSON_HAS_CPP_14) && !defined(JSON_HAS_CPP_11)
+    #if (defined(__cplusplus) && __cplusplus >= 202002L) || (defined(_MSVC_LANG) && _MSVC_LANG >= 202002L)
+        #define JSON_HAS_CPP_20
+        #define JSON_HAS_CPP_17
+        #define JSON_HAS_CPP_14
+    #elif (defined(__cplusplus) && __cplusplus >= 201703L) || (defined(_HAS_CXX17) && _HAS_CXX17 == 1) // fix for issue #464
+    #elif (defined(__cplusplus) && __cplusplus >= 201402L) || (defined(_HAS_CXX14) && _HAS_CXX14 == 1)
+    #endif
+    // the cpp 11 flag is always specified because it is the minimal required version
+    #define JSON_HAS_CPP_11
 #endif
-// disable float-equal warnings on GCC/clang
-#if defined(__clang__) || defined(__GNUC__) || defined(__GNUG__)
-    #pragma GCC diagnostic push
-    #pragma GCC diagnostic ignored "-Wfloat-equal"
+#ifdef __has_include
+    #if __has_include(<version>)
+        #include <version>
+    #endif
+#endif
+#if !defined(JSON_HAS_FILESYSTEM) && !defined(JSON_HAS_EXPERIMENTAL_FILESYSTEM)
+    #ifdef JSON_HAS_CPP_17
+        #if defined(__cpp_lib_filesystem)
+            #define JSON_HAS_FILESYSTEM 1
+        #elif defined(__cpp_lib_experimental_filesystem)
+            #define JSON_HAS_EXPERIMENTAL_FILESYSTEM 1
+        #elif !defined(__has_include)
+        #elif __has_include(<filesystem>)
+        #elif __has_include(<experimental/filesystem>)
+        #endif
+        // std::filesystem does not work on MinGW GCC 8: https://sourceforge.net/p/mingw-w64/bugs/737/
+        #if defined(__MINGW32__) && defined(__GNUC__) && __GNUC__ == 8
+            #undef JSON_HAS_FILESYSTEM
+            #undef JSON_HAS_EXPERIMENTAL_FILESYSTEM
+        #endif
+        // no filesystem support before GCC 8: https://en.cppreference.com/w/cpp/compiler_support
+        #if defined(__GNUC__) && !defined(__clang__) && __GNUC__ < 8
+        #endif
+        // no filesystem support before Clang 7: https://en.cppreference.com/w/cpp/compiler_support
+        #if defined(__clang_major__) && __clang_major__ < 7
+        #endif
+        // no filesystem support before MSVC 19.14: https://en.cppreference.com/w/cpp/compiler_support
+        #if defined(_MSC_VER) && _MSC_VER < 1914
+        #endif
+        // no filesystem support before iOS 13
+        #if defined(__IPHONE_OS_VERSION_MIN_REQUIRED) && __IPHONE_OS_VERSION_MIN_REQUIRED < 130000
+        #endif
+        // no filesystem support before macOS Catalina
+        #if defined(__MAC_OS_X_VERSION_MIN_REQUIRED) && __MAC_OS_X_VERSION_MIN_REQUIRED < 101500
+        #endif
+    #endif
+#endif
+#ifndef JSON_HAS_EXPERIMENTAL_FILESYSTEM
+    #define JSON_HAS_EXPERIMENTAL_FILESYSTEM 0
+#endif
+#ifndef JSON_HAS_FILESYSTEM
+    #define JSON_HAS_FILESYSTEM 0
+#endif
+#ifndef JSON_HAS_THREE_WAY_COMPARISON
+    #if defined(__cpp_impl_three_way_comparison) && __cpp_impl_three_way_comparison >= 201907L \
+        && defined(__cpp_lib_three_way_comparison) && __cpp_lib_three_way_comparison >= 201907L
+        #define JSON_HAS_THREE_WAY_COMPARISON 1
+    #else
+        #define JSON_HAS_THREE_WAY_COMPARISON 0
+    #endif
+#endif
+#ifndef JSON_HAS_RANGES
+    // ranges header shipping in GCC 11.1.0 (released 2021-04-27) has syntax error
+    #if defined(__GLIBCXX__) && __GLIBCXX__ == 20210427
+        #define JSON_HAS_RANGES 0
+    #elif defined(__cpp_lib_ranges)
+        #define JSON_HAS_RANGES 1
+    #else
+    #endif
+#endif
+#ifndef JSON_HAS_STATIC_RTTI
+    #if !defined(_HAS_STATIC_RTTI) || _HAS_STATIC_RTTI != 0
+        #define JSON_HAS_STATIC_RTTI 1
+    #else
+        #define JSON_HAS_STATIC_RTTI 0
+    #endif
+#endif
+#ifdef JSON_HAS_CPP_17
+    #define JSON_INLINE_VARIABLE inline
+#else
+#endif
+#if JSON_HEDLEY_HAS_ATTRIBUTE(no_unique_address)
+    #define JSON_NO_UNIQUE_ADDRESS [[no_unique_address]]
+#else
 #endif
 // disable documentation warnings on clang
-    #pragma GCC diagnostic ignored "-Wdocumentation"
+    #pragma clang diagnostic push
+    #pragma clang diagnostic ignored "-Wdocumentation"
+    #pragma clang diagnostic ignored "-Wdocumentation-unknown-command"
 #endif
-// allow to disable exceptions
+// allow disabling exceptions
 #if (defined(__cpp_exceptions) || defined(__EXCEPTIONS) || defined(_CPPUNWIND)) && !defined(JSON_NOEXCEPTION)
     #define JSON_THROW(exception) throw exception
     #define JSON_TRY try
@@ -2154,7 +2546,7 @@ JSON_HEDLEY_DIAGNOSTIC_POP
     #define JSON_INTERNAL_CATCH JSON_INTERNAL_CATCH_USER
 #endif
-// allow to override assert
+// allow overriding assert
 #if !defined(JSON_ASSERT)
     #include <cassert> // assert
     #define JSON_ASSERT(x) assert(x)
@@ -2208,12 +2600,13 @@ JSON_HEDLEY_DIAGNOSTIC_POP
              class NumberUnsignedType, class NumberFloatType,              \
              template<typename> class AllocatorType,                       \
              template<typename, typename = void> class JSONSerializer,     \
-             class BinaryType>
+             class BinaryType,                                             \
+             class CustomBaseClass>
 #define NLOHMANN_BASIC_JSON_TPL                                            \
     basic_json<ObjectType, ArrayType, StringType, BooleanType,             \
     NumberIntegerType, NumberUnsignedType, NumberFloatType,                \
-    AllocatorType, JSONSerializer, BinaryType>
+    AllocatorType, JSONSerializer, BinaryType, CustomBaseClass>
 // Macros to simplify conversion from/to types
@@ -2350,6 +2743,7 @@ JSON_HEDLEY_DIAGNOSTIC_POP
 #define NLOHMANN_JSON_TO(v1) nlohmann_json_j[#v1] = nlohmann_json_t.v1;
 #define NLOHMANN_JSON_FROM(v1) nlohmann_json_j.at(#v1).get_to(nlohmann_json_t.v1);
+#define NLOHMANN_JSON_FROM_WITH_DEFAULT(v1) nlohmann_json_t.v1 = nlohmann_json_j.value(#v1, nlohmann_json_default_obj.v1);
 @brief macro
@@ -2360,6 +2754,13 @@ JSON_HEDLEY_DIAGNOSTIC_POP
     friend void to_json(nlohmann::json& nlohmann_json_j, const Type& nlohmann_json_t) { NLOHMANN_JSON_EXPAND(NLOHMANN_JSON_PASTE(NLOHMANN_JSON_TO, __VA_ARGS__)) } \
     friend void from_json(const nlohmann::json& nlohmann_json_j, Type& nlohmann_json_t) { NLOHMANN_JSON_EXPAND(NLOHMANN_JSON_PASTE(NLOHMANN_JSON_FROM, __VA_ARGS__)) }
+#define NLOHMANN_DEFINE_TYPE_INTRUSIVE_WITH_DEFAULT(Type, ...)  \
+    friend void to_json(nlohmann::json& nlohmann_json_j, const Type& nlohmann_json_t) { NLOHMANN_JSON_EXPAND(NLOHMANN_JSON_PASTE(NLOHMANN_JSON_TO, __VA_ARGS__)) } \
+    friend void from_json(const nlohmann::json& nlohmann_json_j, Type& nlohmann_json_t) { const Type nlohmann_json_default_obj{}; NLOHMANN_JSON_EXPAND(NLOHMANN_JSON_PASTE(NLOHMANN_JSON_FROM_WITH_DEFAULT, __VA_ARGS__)) }
+#define NLOHMANN_DEFINE_TYPE_INTRUSIVE_ONLY_SERIALIZE(Type, ...)  \
 @brief macro
 @def NLOHMANN_DEFINE_TYPE_NON_INTRUSIVE
@@ -2369,6 +2770,51 @@ JSON_HEDLEY_DIAGNOSTIC_POP
     inline void to_json(nlohmann::json& nlohmann_json_j, const Type& nlohmann_json_t) { NLOHMANN_JSON_EXPAND(NLOHMANN_JSON_PASTE(NLOHMANN_JSON_TO, __VA_ARGS__)) } \
     inline void from_json(const nlohmann::json& nlohmann_json_j, Type& nlohmann_json_t) { NLOHMANN_JSON_EXPAND(NLOHMANN_JSON_PASTE(NLOHMANN_JSON_FROM, __VA_ARGS__)) }
+#define NLOHMANN_DEFINE_TYPE_NON_INTRUSIVE_ONLY_SERIALIZE(Type, ...)  \
+    inline void to_json(nlohmann::json& nlohmann_json_j, const Type& nlohmann_json_t) { NLOHMANN_JSON_EXPAND(NLOHMANN_JSON_PASTE(NLOHMANN_JSON_TO, __VA_ARGS__)) }
+#define NLOHMANN_DEFINE_TYPE_NON_INTRUSIVE_WITH_DEFAULT(Type, ...)  \
+    inline void to_json(nlohmann::json& nlohmann_json_j, const Type& nlohmann_json_t) { NLOHMANN_JSON_EXPAND(NLOHMANN_JSON_PASTE(NLOHMANN_JSON_TO, __VA_ARGS__)) } \
+    inline void from_json(const nlohmann::json& nlohmann_json_j, Type& nlohmann_json_t) { const Type nlohmann_json_default_obj{}; NLOHMANN_JSON_EXPAND(NLOHMANN_JSON_PASTE(NLOHMANN_JSON_FROM_WITH_DEFAULT, __VA_ARGS__)) }
+// inspired from https://stackoverflow.com/a/26745591
+// allows to call any std function as if (e.g. with begin):
+// using std::begin; begin(x);
+// it allows using the detected idiom to retrieve the return type
+// of such an expression
+#define NLOHMANN_CAN_CALL_STD_FUNC_IMPL(std_name)                                 \
+    namespace detail {                                                            \
+    using std::std_name;                                                          \
+    template<typename... T>                                                       \
+    using result_of_##std_name = decltype(std_name(std::declval<T>()...));        \
+    namespace detail2 {                                                           \
+    struct std_name##_tag                                                         \
+    std_name##_tag std_name(T&&...);                                              \
+    struct would_call_std_##std_name                                              \
+        static constexpr auto const value = ::nlohmann::detail::                  \
+                                            is_detected_exact<std_name##_tag, result_of_##std_name, T...>::value; \
+    } /* namespace detail2 */ \
+    struct would_call_std_##std_name : detail2::would_call_std_##std_name<T...>   \
 #ifndef JSON_USE_IMPLICIT_CONVERSIONS
     #define JSON_USE_IMPLICIT_CONVERSIONS 1
 #endif
@@ -2379,361 +2825,247 @@ JSON_HEDLEY_DIAGNOSTIC_POP
     #define JSON_EXPLICIT explicit
 #endif
+#ifndef JSON_DISABLE_ENUM_SERIALIZATION
+    #define JSON_DISABLE_ENUM_SERIALIZATION 0
+#endif
-namespace nlohmann
+#ifndef JSON_USE_GLOBAL_UDLS
+    #define JSON_USE_GLOBAL_UDLS 1
+#endif
+#if JSON_HAS_THREE_WAY_COMPARISON
+    #include <compare> // partial_ordering
+#endif
 namespace detail
-// exceptions //
+// JSON type enumeration //
- at brief general exception of the @ref basic_json class
+ at brief the JSON type enumeration
-This class is an extension of `std::exception` objects with a member @a id for
-exception ids. It is used as the base class for all exceptions thrown by the
- at ref basic_json class. This class can hence be used as "wildcard" to catch
-exceptions.
+This enumeration collects the different JSON types. It is internally used to
+distinguish the stored values, and the functions @ref basic_json::is_null(),
+ at ref basic_json::is_object(), @ref basic_json::is_array(),
+ at ref basic_json::is_string(), @ref basic_json::is_boolean(),
+ at ref basic_json::is_number() (with @ref basic_json::is_number_integer(),
+ at ref basic_json::is_number_unsigned(), and @ref basic_json::is_number_float()),
+ at ref basic_json::is_discarded(), @ref basic_json::is_primitive(), and
+ at ref basic_json::is_structured() rely on it.
-Subclasses:
-- @ref parse_error for exceptions indicating a parse error
-- @ref invalid_iterator for exceptions indicating errors with iterators
-- @ref type_error for exceptions indicating executing a member function with
-                  a wrong type
-- @ref out_of_range for exceptions indicating access out of the defined range
-- @ref other_error for exceptions indicating other library errors
+ at note There are three enumeration entries (number_integer, number_unsigned, and
+number_float), because the library distinguishes these three types for numbers:
+ at ref basic_json::number_unsigned_t is used for unsigned integers,
+ at ref basic_json::number_integer_t is used for signed integers, and
+ at ref basic_json::number_float_t is used for floating-point numbers or to
+approximate integers which do not fit in the limits of their respective type.
- at internal
- at note To have nothrow-copy-constructible exceptions, we internally use
-      `std::runtime_error` which can cope with arbitrary-length error messages.
-      Intermediate strings are built with static functions and then passed to
-      the actual constructor.
- at endinternal
+ at sa see @ref basic_json::basic_json(const value_t value_type) -- create a JSON
+value with the default value for a given type
- at liveexample{The following code shows how arbitrary library exceptions can be
-caught.,exception}
- at since version 3.0.0
+ at since version 1.0.0
-class exception : public std::exception
+enum class value_t : std::uint8_t
-  public:
-    /// returns the explanatory string
-    JSON_HEDLEY_RETURNS_NON_NULL
-    const char* what() const noexcept override
-        return m.what();
-    /// the id of the exception
-    const int id;
-  protected:
-    JSON_HEDLEY_NON_NULL(3)
-    exception(int id_, const char* what_arg) : id(id_), m(what_arg) {}
-    static std::string name(const std::string& ename, int id_)
-        return "[json.exception." + ename + "." + std::to_string(id_) + "] ";
-  private:
-    /// an exception object as storage for error messages
-    std::runtime_error m;
+    null,             ///< null value
+    object,           ///< object (unordered set of name/value pairs)
+    array,            ///< array (ordered collection of values)
+    string,           ///< string value
+    boolean,          ///< boolean value
+    number_integer,   ///< number value (signed integer)
+    number_unsigned,  ///< number value (unsigned integer)
+    number_float,     ///< number value (floating-point)
+    binary,           ///< binary array (ordered collection of bytes)
+    discarded         ///< discarded by the parser callback function
- at brief exception indicating a parse error
+ at brief comparison operator for JSON types
-This exception is thrown by the library when a parse error occurs. Parse errors
-can occur during the deserialization of JSON text, CBOR, MessagePack, as well
-as when using JSON Patch.
+Returns an ordering that is similar to Python:
+- order: null < boolean < number < object < array < string < binary
+- furthermore, each type is not smaller than itself
+- discarded values are not comparable
+- binary is represented as a b"" string in python and directly comparable to a
+  string; however, making a binary array directly comparable with a string would
+  be surprising behavior in a JSON file.
-Member @a byte holds the byte index of the last read character in the input
-file.
-Exceptions have ids 1xx.
-name / id                      | example message | description
-json.exception.parse_error.101 | parse error at 2: unexpected end of input; expected string literal | This error indicates a syntax error while deserializing a JSON text. The error message describes that an unexpected token (character) was encountered, and the member @a byte indicates the error position.
-json.exception.parse_error.102 | parse error at 14: missing or wrong low surrogate | JSON uses the `\uxxxx` format to describe Unicode characters. Code points above above 0xFFFF are split into two `\uxxxx` entries ("surrogate pairs"). This error indicates that the surrogate pair is incomplete or contains an invalid code point.
-json.exception.parse_error.103 | parse error: code points above 0x10FFFF are invalid | Unicode supports code points up to 0x10FFFF. Code points above 0x10FFFF are invalid.
-json.exception.parse_error.104 | parse error: JSON patch must be an array of objects | [RFC 6902](https://tools.ietf.org/html/rfc6902) requires a JSON Patch document to be a JSON document that represents an array of objects.
-json.exception.parse_error.105 | parse error: operation must have string member 'op' | An operation of a JSON Patch document must contain exactly one "op" member, whose value indicates the operation to perform. Its value must be one of "add", "remove", "replace", "move", "copy", or "test"; other values are errors.
-json.exception.parse_error.106 | parse error: array index '01' must not begin with '0' | An array index in a JSON Pointer ([RFC 6901](https://tools.ietf.org/html/rfc6901)) may be `0` or any number without a leading `0`.
-json.exception.parse_error.107 | parse error: JSON pointer must be empty or begin with '/' - was: 'foo' | A JSON Pointer must be a Unicode string containing a sequence of zero or more reference tokens, each prefixed by a `/` character.
-json.exception.parse_error.108 | parse error: escape character '~' must be followed with '0' or '1' | In a JSON Pointer, only `~0` and `~1` are valid escape sequences.
-json.exception.parse_error.109 | parse error: array index 'one' is not a number | A JSON Pointer array index must be a number.
-json.exception.parse_error.110 | parse error at 1: cannot read 2 bytes from vector | When parsing CBOR or MessagePack, the byte vector ends before the complete value has been read.
-json.exception.parse_error.112 | parse error at 1: error reading CBOR; last byte: 0xF8 | Not all types of CBOR or MessagePack are supported. This exception occurs if an unsupported byte was read.
-json.exception.parse_error.113 | parse error at 2: expected a CBOR string; last byte: 0x98 | While parsing a map key, a value that is not a string has been read.
-json.exception.parse_error.114 | parse error: Unsupported BSON record type 0x0F | The parsing of the corresponding BSON record type is not implemented (yet).
-json.exception.parse_error.115 | parse error at byte 5: syntax error while parsing UBJSON high-precision number: invalid number text: 1A | A UBJSON high-precision number could not be parsed.
- at note For an input with n bytes, 1 is the index of the first character and n+1
-      is the index of the terminating null byte or the end of file. This also
-      holds true when reading a byte vector (CBOR or MessagePack).
- at liveexample{The following code shows how a `parse_error` exception can be
-caught.,parse_error}
- at sa - @ref exception for the base class of the library exceptions
- at sa - @ref invalid_iterator for exceptions indicating errors with iterators
- at sa - @ref type_error for exceptions indicating executing a member function with
-                    a wrong type
- at sa - @ref out_of_range for exceptions indicating access out of the defined range
- at sa - @ref other_error for exceptions indicating other library errors
-class parse_error : public exception
+    inline std::partial_ordering operator<=>(const value_t lhs, const value_t rhs) noexcept // *NOPAD*
+#else
+    inline bool operator<(const value_t lhs, const value_t rhs) noexcept
+#endif
-  public:
-    @brief create a parse error exception
-    @param[in] id_       the id of the exception
-    @param[in] pos       the position where the error occurred (or with
-                         chars_read_total=0 if the position cannot be
-                         determined)
-    @param[in] what_arg  the explanatory string
-    @return parse_error object
-    static parse_error create(int id_, const position_t& pos, const std::string& what_arg)
+    static constexpr std::array<std::uint8_t, 9> order = {{
+            0 /* null */, 3 /* object */, 4 /* array */, 5 /* string */,
+            1 /* boolean */, 2 /* integer */, 2 /* unsigned */, 2 /* float */,
+            6 /* binary */
+    const auto l_index = static_cast<std::size_t>(lhs);
+    const auto r_index = static_cast<std::size_t>(rhs);
+    if (l_index < order.size() && r_index < order.size())
-        std::string w = exception::name("parse_error", id_) + "parse error" +
-                        position_string(pos) + ": " + what_arg;
-        return parse_error(id_, pos.chars_read_total, w.c_str());
+        return order[l_index] <=> order[r_index]; // *NOPAD*
+    return std::partial_ordering::unordered;
+#else
+    return l_index < order.size() && r_index < order.size() && order[l_index] < order[r_index];
+#endif
-    static parse_error create(int id_, std::size_t byte_, const std::string& what_arg)
-                        (byte_ != 0 ? (" at byte " + std::to_string(byte_)) : "") +
-                        ": " + what_arg;
-        return parse_error(id_, byte_, w.c_str());
-    @brief byte index of the parse error
-    The byte index of the last read character in the input file.
-    @note For an input with n bytes, 1 is the index of the first character and
-          n+1 is the index of the terminating null byte or the end of file.
-          This also holds true when reading a byte vector (CBOR or MessagePack).
-    const std::size_t byte;
-  private:
-    parse_error(int id_, std::size_t byte_, const char* what_arg)
-        : exception(id_, what_arg), byte(byte_) {}
-    static std::string position_string(const position_t& pos)
-        return " at line " + std::to_string(pos.lines_read + 1) +
-               ", column " + std::to_string(pos.chars_read_current_line);
- at brief exception indicating errors with iterators
-This exception is thrown if iterators passed to a library function do not match
-the expected semantics.
-Exceptions have ids 2xx.
-json.exception.invalid_iterator.201 | iterators are not compatible | The iterators passed to constructor @ref basic_json(InputIT first, InputIT last) are not compatible, meaning they do not belong to the same container. Therefore, the range (@a first, @a last) is invalid.
-json.exception.invalid_iterator.202 | iterator does not fit current value | In an erase or insert function, the passed iterator @a pos does not belong to the JSON value for which the function was called. It hence does not define a valid position for the deletion/insertion.
-json.exception.invalid_iterator.203 | iterators do not fit current value | Either iterator passed to function @ref erase(IteratorType first, IteratorType last) does not belong to the JSON value from which values shall be erased. It hence does not define a valid range to delete values from.
-json.exception.invalid_iterator.204 | iterators out of range | When an iterator range for a primitive type (number, boolean, or string) is passed to a constructor or an erase function, this range has to be exactly (@ref begin(), @ref end()), because this is the only way the single stored value is expressed. All other ranges are invalid.
-json.exception.invalid_iterator.205 | iterator out of range | When an iterator for a primitive type (number, boolean, or string) is passed to an erase function, the iterator has to be the @ref begin() iterator, because it is the only way to address the stored value. All other iterators are invalid.
-json.exception.invalid_iterator.206 | cannot construct with iterators from null | The iterators passed to constructor @ref basic_json(InputIT first, InputIT last) belong to a JSON null value and hence to not define a valid range.
-json.exception.invalid_iterator.207 | cannot use key() for non-object iterators | The key() member function can only be used on iterators belonging to a JSON object, because other types do not have a concept of a key.
-json.exception.invalid_iterator.208 | cannot use operator[] for object iterators | The operator[] to specify a concrete offset cannot be used on iterators belonging to a JSON object, because JSON objects are unordered.
-json.exception.invalid_iterator.209 | cannot use offsets with object iterators | The offset operators (+, -, +=, -=) cannot be used on iterators belonging to a JSON object, because JSON objects are unordered.
-json.exception.invalid_iterator.210 | iterators do not fit | The iterator range passed to the insert function are not compatible, meaning they do not belong to the same container. Therefore, the range (@a first, @a last) is invalid.
-json.exception.invalid_iterator.211 | passed iterators may not belong to container | The iterator range passed to the insert function must not be a subrange of the container to insert to.
-json.exception.invalid_iterator.212 | cannot compare iterators of different containers | When two iterators are compared, they must belong to the same container.
-json.exception.invalid_iterator.213 | cannot compare order of object iterators | The order of object iterators cannot be compared, because JSON objects are unordered.
-json.exception.invalid_iterator.214 | cannot get value | Cannot get value for iterator: Either the iterator belongs to a null value or it is an iterator to a primitive type (number, boolean, or string), but the iterator is different to @ref begin().
- at liveexample{The following code shows how an `invalid_iterator` exception can be
-caught.,invalid_iterator}
- at sa - @ref parse_error for exceptions indicating a parse error
-                    a wrong type
-class invalid_iterator : public exception
+// GCC selects the built-in operator< over an operator rewritten from
+// a user-defined spaceship operator
+// Clang, MSVC, and ICC select the rewritten candidate
+// (see GCC bug https://gcc.gnu.org/bugzilla/show_bug.cgi?id=105200)
+#if JSON_HAS_THREE_WAY_COMPARISON && defined(__GNUC__)
+inline bool operator<(const value_t lhs, const value_t rhs) noexcept
-  public:
-    static invalid_iterator create(int id_, const std::string& what_arg)
-        std::string w = exception::name("invalid_iterator", id_) + what_arg;
-        return invalid_iterator(id_, w.c_str());
+    return std::is_lt(lhs <=> rhs); // *NOPAD*
+#endif
-  private:
-    invalid_iterator(int id_, const char* what_arg)
-        : exception(id_, what_arg) {}
- at brief exception indicating executing a member function with a wrong type
-This exception is thrown in case of a type error; that is, a library function is
-executed on a JSON value whose type does not match the expected semantics.
-Exceptions have ids 3xx.
-json.exception.type_error.301 | cannot create object from initializer list | To create an object from an initializer list, the initializer list must consist only of a list of pairs whose first element is a string. When this constraint is violated, an array is created instead.
-json.exception.type_error.302 | type must be object, but is array | During implicit or explicit value conversion, the JSON type must be compatible to the target type. For instance, a JSON string can only be converted into string types, but not into numbers or boolean types.
-json.exception.type_error.303 | incompatible ReferenceType for get_ref, actual type is object | To retrieve a reference to a value stored in a @ref basic_json object with @ref get_ref, the type of the reference must match the value type. For instance, for a JSON array, the @a ReferenceType must be @ref array_t &.
-json.exception.type_error.304 | cannot use at() with string | The @ref at() member functions can only be executed for certain JSON types.
-json.exception.type_error.305 | cannot use operator[] with string | The @ref operator[] member functions can only be executed for certain JSON types.
-json.exception.type_error.306 | cannot use value() with string | The @ref value() member functions can only be executed for certain JSON types.
-json.exception.type_error.307 | cannot use erase() with string | The @ref erase() member functions can only be executed for certain JSON types.
-json.exception.type_error.308 | cannot use push_back() with string | The @ref push_back() and @ref operator+= member functions can only be executed for certain JSON types.
-json.exception.type_error.309 | cannot use insert() with | The @ref insert() member functions can only be executed for certain JSON types.
-json.exception.type_error.310 | cannot use swap() with number | The @ref swap() member functions can only be executed for certain JSON types.
-json.exception.type_error.311 | cannot use emplace_back() with string | The @ref emplace_back() member function can only be executed for certain JSON types.
-json.exception.type_error.312 | cannot use update() with string | The @ref update() member functions can only be executed for certain JSON types.
-json.exception.type_error.313 | invalid value to unflatten | The @ref unflatten function converts an object whose keys are JSON Pointers back into an arbitrary nested JSON value. The JSON Pointers must not overlap, because then the resulting value would not be well defined.
-json.exception.type_error.314 | only objects can be unflattened | The @ref unflatten function only works for an object whose keys are JSON Pointers.
-json.exception.type_error.315 | values in object must be primitive | The @ref unflatten function only works for an object whose keys are JSON Pointers and whose values are primitive.
-json.exception.type_error.316 | invalid UTF-8 byte at index 10: 0x7E | The @ref dump function only works with UTF-8 encoded strings; that is, if you assign a `std::string` to a JSON value, make sure it is UTF-8 encoded. |
-json.exception.type_error.317 | JSON value cannot be serialized to requested format | The dynamic type of the object cannot be represented in the requested serialization format (e.g. a raw `true` or `null` JSON object cannot be serialized to BSON) |
- at liveexample{The following code shows how a `type_error` exception can be
-caught.,type_error}
-class type_error : public exception
-  public:
-    static type_error create(int id_, const std::string& what_arg)
-        std::string w = exception::name("type_error", id_) + what_arg;
-        return type_error(id_, w.c_str());
-  private:
-    type_error(int id_, const char* what_arg) : exception(id_, what_arg) {}
- at brief exception indicating access out of the defined range
-This exception is thrown in case a library function is called on an input
-parameter that exceeds the expected range, for instance in case of array
-indices or nonexisting object keys.
-Exceptions have ids 4xx.
-json.exception.out_of_range.401 | array index 3 is out of range | The provided array index @a i is larger than @a size-1.
-json.exception.out_of_range.402 | array index '-' (3) is out of range | The special array index `-` in a JSON Pointer never describes a valid element of the array, but the index past the end. That is, it can only be used to add elements at this position, but not to read it.
-json.exception.out_of_range.403 | key 'foo' not found | The provided key was not found in the JSON object.
-json.exception.out_of_range.404 | unresolved reference token 'foo' | A reference token in a JSON Pointer could not be resolved.
-json.exception.out_of_range.405 | JSON pointer has no parent | The JSON Patch operations 'remove' and 'add' can not be applied to the root element of the JSON value.
-json.exception.out_of_range.406 | number overflow parsing '10E1000' | A parsed number could not be stored as without changing it to NaN or INF.
-json.exception.out_of_range.407 | number overflow serializing '9223372036854775808' | UBJSON and BSON only support integer numbers up to 9223372036854775807. (until version 3.8.0) |
-json.exception.out_of_range.408 | excessive array size: 8658170730974374167 | The size (following `#`) of an UBJSON array or object exceeds the maximal capacity. |
-json.exception.out_of_range.409 | BSON key cannot contain code point U+0000 (at byte 2) | Key identifiers to be serialized to BSON cannot contain code point U+0000, since the key is stored as zero-terminated c-string |
- at liveexample{The following code shows how an `out_of_range` exception can be
-caught.,out_of_range}
-                    a wrong type
-class out_of_range : public exception
-  public:
-    static out_of_range create(int id_, const std::string& what_arg)
-        std::string w = exception::name("out_of_range", id_) + what_arg;
-        return out_of_range(id_, w.c_str());
-  private:
-    out_of_range(int id_, const char* what_arg) : exception(id_, what_arg) {}
- at brief exception indicating other library errors
-This exception is thrown in case of errors that cannot be classified with the
-other exception types.
-Exceptions have ids 5xx.
-json.exception.other_error.501 | unsuccessful: {"op":"test","path":"/baz", "value":"bar"} | A JSON Patch operation 'test' failed. The unsuccessful operation is also printed.
-                    a wrong type
- at liveexample{The following code shows how an `other_error` exception can be
-caught.,other_error}
-class other_error : public exception
-  public:
-    static other_error create(int id_, const std::string& what_arg)
-        std::string w = exception::name("other_error", id_) + what_arg;
-        return other_error(id_, w.c_str());
-  private:
-    other_error(int id_, const char* what_arg) : exception(id_, what_arg) {}
+// #include <nlohmann/detail/string_escape.hpp>
+namespace detail
+ at brief replace all occurrences of a substring by another string
+ at param[in,out] s  the string to manipulate; changed so that all
+               occurrences of @a f are replaced with @a t
+ at param[in]     f  the substring to replace with @a t
+ at param[in]     t  the string to replace @a f
+ at pre The search string @a f must not be empty. **This precondition is
+enforced with an assertion.**
+ at since version 2.0.0
+template<typename StringType>
+inline void replace_substring(StringType& s, const StringType& f,
+                              const StringType& t)
+    JSON_ASSERT(!f.empty());
+    for (auto pos = s.find(f);                // find first occurrence of f
+            pos != StringType::npos;          // make sure f was found
+            s.replace(pos, f.size(), t),      // replace with t, and
+            pos = s.find(f, pos + t.size()))  // find next occurrence of f
+ * @brief string escaping as described in RFC 6901 (Sect. 4)
+ * @param[in] s string to escape
+ * @return    escaped string
+ * Note the order of escaping "~" to "~0" and "/" to "~1" is important.
+inline StringType escape(StringType s)
+    replace_substring(s, StringType{"~"}, StringType{"~0"});
+    replace_substring(s, StringType{"/"}, StringType{"~1"});
+    return s;
+ * @brief string unescaping as described in RFC 6901 (Sect. 4)
+ * @param[in] s string to unescape
+ * @return    unescaped string
+ * Note the order of escaping "~1" to "/" and "~0" to "~" is important.
+static void unescape(StringType& s)
+    replace_substring(s, StringType{"~1"}, StringType{"/"});
+    replace_substring(s, StringType{"~0"}, StringType{"~"});
+// #include <nlohmann/detail/input/position_t.hpp>
+#include <cstddef> // size_t
+namespace detail
+/// struct to capture the start position of the current token
+struct position_t
+    /// the total number of characters read
+    std::size_t chars_read_total = 0;
+    /// the number of characters read in the current line
+    std::size_t chars_read_current_line = 0;
+    /// the number of lines read
+    std::size_t lines_read = 0;
+    /// conversion to size_t to preserve SAX interface
+    constexpr operator size_t() const
+        return chars_read_total;
 // #include <nlohmann/detail/meta/cpp_future.hpp>
+// SPDX-FileCopyrightText: 2018 The Abseil Authors
 #include <type_traits> // conditional, enable_if, false_type, integral_constant, is_constructible, is_integral, is_same, remove_cv, remove_reference, true_type
 #include <utility> // index_sequence, make_index_sequence, index_sequence_for
@@ -2741,8 +3073,7 @@ class other_error : public exception
-namespace nlohmann
 namespace detail
@@ -2763,36 +3094,112 @@ using std::index_sequence_for;
 template<bool B, typename T = void>
 using enable_if_t = typename std::enable_if<B, T>::type;
-// source: https://stackoverflow.com/a/32223343
-template<std::size_t... Ints>
-struct index_sequence
+// The following code is taken from https://github.com/abseil/abseil-cpp/blob/10cb35e459f5ecca5b2ff107635da0bfa41011b4/absl/utility/utility.h
+// which is part of Google Abseil (https://github.com/abseil/abseil-cpp), licensed under the Apache License 2.0.
+//// START OF CODE FROM GOOGLE ABSEIL
+// integer_sequence
+// Class template representing a compile-time integer sequence. An instantiation
+// of `integer_sequence<T, Ints...>` has a sequence of integers encoded in its
+// type through its template arguments (which is a common need when
+// working with C++11 variadic templates). `absl::integer_sequence` is designed
+// to be a drop-in replacement for C++14's `std::integer_sequence`.
+// Example:
+//   template< class T, T... Ints >
+//   void user_function(integer_sequence<T, Ints...>);
+//   int main()
+//     // user_function's `T` will be deduced to `int` and `Ints...`
+//     // will be deduced to `0, 1, 2, 3, 4`.
+//     user_function(make_integer_sequence<int, 5>());
+template <typename T, T... Ints>
+struct integer_sequence
-    using type = index_sequence;
-    using value_type = std::size_t;
+    using value_type = T;
     static constexpr std::size_t size() noexcept
         return sizeof...(Ints);
-template<class Sequence1, class Sequence2>
-struct merge_and_renumber;
+// index_sequence
+// A helper template for an `integer_sequence` of `size_t`,
+// `absl::index_sequence` is designed to be a drop-in replacement for C++14's
+// `std::index_sequence`.
+template <size_t... Ints>
+using index_sequence = integer_sequence<size_t, Ints...>;
-template<std::size_t... I1, std::size_t... I2>
-struct merge_and_renumber<index_sequence<I1...>, index_sequence<I2...>>
-        : index_sequence < I1..., (sizeof...(I1) + I2)... > {};
+namespace utility_internal
-template<std::size_t N>
-struct make_index_sequence
-    : merge_and_renumber < typename make_index_sequence < N / 2 >::type,
-      typename make_index_sequence < N - N / 2 >::type > {};
+template <typename Seq, size_t SeqSize, size_t Rem>
+struct Extend;
-template<> struct make_index_sequence<0> : index_sequence<> {};
-template<> struct make_index_sequence<1> : index_sequence<0> {};
+// Note that SeqSize == sizeof...(Ints). It's passed explicitly for efficiency.
+template <typename T, T... Ints, size_t SeqSize>
+struct Extend<integer_sequence<T, Ints...>, SeqSize, 0>
+    using type = integer_sequence < T, Ints..., (Ints + SeqSize)... >;
-template<typename... Ts>
+struct Extend<integer_sequence<T, Ints...>, SeqSize, 1>
+    using type = integer_sequence < T, Ints..., (Ints + SeqSize)..., 2 * SeqSize >;
+// Recursion helper for 'make_integer_sequence<T, N>'.
+// 'Gen<T, N>::type' is an alias for 'integer_sequence<T, 0, 1, ... N-1>'.
+template <typename T, size_t N>
+struct Gen
+    using type =
+        typename Extend < typename Gen < T, N / 2 >::type, N / 2, N % 2 >::type;
+template <typename T>
+struct Gen<T, 0>
+    using type = integer_sequence<T>;
+}  // namespace utility_internal
+// Compile-time sequences of integers
+// make_integer_sequence
+// This template alias is equivalent to
+// `integer_sequence<int, 0, 1, ..., N-1>`, and is designed to be a drop-in
+// replacement for C++14's `std::make_integer_sequence`.
+template <typename T, T N>
+using make_integer_sequence = typename utility_internal::Gen<T, N>::type;
+// make_index_sequence
+// This template alias is equivalent to `index_sequence<0, 1, ..., N-1>`,
+// and is designed to be a drop-in replacement for C++14's
+// `std::make_index_sequence`.
+template <size_t N>
+using make_index_sequence = make_integer_sequence<size_t, N>;
+// index_sequence_for
+// Converts a typename pack into an index sequence of the same length, and
+// is designed to be a drop-in replacement for C++14's
+// `std::index_sequence_for()`
+template <typename... Ts>
 using index_sequence_for = make_index_sequence<sizeof...(Ts)>;
+//// END OF CODE FROM GOOGLE ABSEIL
 #endif
 // dispatch utility (taken from ranges-v3)
@@ -2803,50 +3210,64 @@ template<> struct priority_tag<0> {};
 template<typename T>
 struct static_const
-    static constexpr T value{};
+    static JSON_INLINE_VARIABLE constexpr T value{};
-template<typename T>
-constexpr T static_const<T>::value;
+#ifndef JSON_HAS_CPP_17
+    template<typename T>
+    constexpr T static_const<T>::value;
+#endif
+template<typename T, typename... Args>
+inline constexpr std::array<T, sizeof...(Args)> make_array(Args&& ... args)
+    return std::array<T, sizeof...(Args)> {{static_cast<T>(std::forward<Args>(args))...}};
 // #include <nlohmann/detail/meta/type_traits.hpp>
+//     __ _____ _____ _____
+//  __|  |   __|     |   | |  JSON for Modern C++
+// |  |  |__   |  |  | | | |  version 3.11.3
+// |_____|_____|_____|_|___|  https://github.com/nlohmann/json
+// SPDX-FileCopyrightText: 2013-2023 Niels Lohmann <https://nlohmann.me>
+// SPDX-License-Identifier: MIT
 #include <limits> // numeric_limits
 #include <type_traits> // false_type, is_constructible, is_integral, is_same, true_type
 #include <tuple> // tuple
+#include <string> // char_traits
 // #include <nlohmann/detail/iterators/iterator_traits.hpp>
-namespace nlohmann
-namespace detail
-template<typename ...Ts> struct make_void
-    using type = void;
-template<typename ...Ts> using void_t = typename make_void<Ts...>::type;
-namespace nlohmann
 namespace detail
 template<typename It, typename = void>
 struct iterator_types {};
@@ -2885,157 +3306,136 @@ struct iterator_traits<T*, enable_if_t<std::is_object<T>::value>>
     using pointer = T*;
     using reference = T&;
+// #include <nlohmann/detail/meta/call_std/begin.hpp>
+// #include <nlohmann/detail/macro_scope.hpp>
+NLOHMANN_CAN_CALL_STD_FUNC_IMPL(begin);
+// #include <nlohmann/detail/meta/call_std/end.hpp>
+NLOHMANN_CAN_CALL_STD_FUNC_IMPL(end);
-#include <type_traits>
-// #include <nlohmann/detail/meta/void_t.hpp>
-// https://en.cppreference.com/w/cpp/experimental/is_detected
-namespace nlohmann
-namespace detail
-struct nonesuch
-    nonesuch() = delete;
-    ~nonesuch() = delete;
-    nonesuch(nonesuch const&) = delete;
-    nonesuch(nonesuch const&&) = delete;
-    void operator=(nonesuch const&) = delete;
-    void operator=(nonesuch&&) = delete;
-template<class Default,
-         class AlwaysVoid,
-         template<class...> class Op,
-         class... Args>
-struct detector
-    using value_t = std::false_type;
-    using type = Default;
-template<class Default, template<class...> class Op, class... Args>
-struct detector<Default, void_t<Op<Args...>>, Op, Args...>
-    using value_t = std::true_type;
-    using type = Op<Args...>;
-template<template<class...> class Op, class... Args>
-using is_detected = typename detector<nonesuch, void, Op, Args...>::value_t;
-using detected_t = typename detector<nonesuch, void, Op, Args...>::type;
-using detected_or = detector<Default, void, Op, Args...>;
-using detected_or_t = typename detected_or<Default, Op, Args...>::type;
-template<class Expected, template<class...> class Op, class... Args>
-using is_detected_exact = std::is_same<Expected, detected_t<Op, Args...>>;
-template<class To, template<class...> class Op, class... Args>
-using is_detected_convertible =
-    std::is_convertible<detected_t<Op, Args...>, To>;
 // #include <nlohmann/json_fwd.hpp>
 #ifndef INCLUDE_NLOHMANN_JSON_FWD_HPP_
-#define INCLUDE_NLOHMANN_JSON_FWD_HPP_
+    #define INCLUDE_NLOHMANN_JSON_FWD_HPP_
-#include <cstdint> // int64_t, uint64_t
-#include <map> // map
-#include <memory> // allocator
-#include <string> // string
-#include <vector> // vector
+    #include <cstdint> // int64_t, uint64_t
+    #include <map> // map
+    #include <memory> // allocator
+    #include <string> // string
+    #include <vector> // vector
- at brief namespace for Niels Lohmann
- at see https://github.com/nlohmann
- at since version 1.0.0
-namespace nlohmann
- at brief default JSONSerializer template argument
+    // #include <nlohmann/detail/abi_macros.hpp>
-This serializer ignores the template arguments and uses ADL
-([argument-dependent lookup](https://en.cppreference.com/w/cpp/language/adl))
-for serialization.
-template<typename T = void, typename SFINAE = void>
-struct adl_serializer;
-template<template<typename U, typename V, typename... Args> class ObjectType =
-         std::map,
-         template<typename U, typename... Args> class ArrayType = std::vector,
-         class StringType = std::string, class BooleanType = bool,
-         class NumberIntegerType = std::int64_t,
-         class NumberUnsignedType = std::uint64_t,
-         class NumberFloatType = double,
-         template<typename U> class AllocatorType = std::allocator,
-         template<typename T, typename SFINAE = void> class JSONSerializer =
-         adl_serializer,
-         class BinaryType = std::vector<std::uint8_t>>
-class basic_json;
+    @brief namespace for Niels Lohmann
+    @see https://github.com/nlohmann
+    @since version 1.0.0
+    NLOHMANN_JSON_NAMESPACE_BEGIN
- at brief JSON Pointer
+    @brief default JSONSerializer template argument
-A JSON pointer defines a string syntax for identifying a specific value
-within a JSON document. It can be used with functions `at` and
-`operator[]`. Furthermore, JSON pointers are the base for JSON patches.
+    This serializer ignores the template arguments and uses ADL
+    ([argument-dependent lookup](https://en.cppreference.com/w/cpp/language/adl))
+    for serialization.
+    template<typename T = void, typename SFINAE = void>
+    struct adl_serializer;
- at sa [RFC 6901](https://tools.ietf.org/html/rfc6901)
+    /// a class to store JSON values
+    /// @sa https://json.nlohmann.me/api/basic_json/
+    template<template<typename U, typename V, typename... Args> class ObjectType =
+    std::map,
+    template<typename U, typename... Args> class ArrayType = std::vector,
+    class StringType = std::string, class BooleanType = bool,
+    class NumberIntegerType = std::int64_t,
+    class NumberUnsignedType = std::uint64_t,
+    class NumberFloatType = double,
+    template<typename U> class AllocatorType = std::allocator,
+    template<typename T, typename SFINAE = void> class JSONSerializer =
+    adl_serializer,
+    class BinaryType = std::vector<std::uint8_t>, // cppcheck-suppress syntaxError
+    class CustomBaseClass = void>
+    class basic_json;
- at since version 2.0.0
-template<typename BasicJsonType>
-class json_pointer;
+    /// @brief JSON Pointer defines a string syntax for identifying a specific value within a JSON document
+    /// @sa https://json.nlohmann.me/api/json_pointer/
+    template<typename RefStringType>
+    class json_pointer;
- at brief default JSON class
+    @brief default specialization
+    @sa https://json.nlohmann.me/api/json/
+    using json = basic_json<>;
-This type is the default specialization of the @ref basic_json class which
-uses the standard template types.
+    /// @brief a minimal map-like container that preserves insertion order
+    /// @sa https://json.nlohmann.me/api/ordered_map/
+    template<class Key, class T, class IgnoredLess, class Allocator>
+    struct ordered_map;
-using json = basic_json<>;
+    /// @brief specialization that maintains the insertion order of object keys
+    /// @sa https://json.nlohmann.me/api/ordered_json/
+    using ordered_json = basic_json<nlohmann::ordered_map>;
-template<class Key, class T, class IgnoredLess, class Allocator>
-struct ordered_map;
- at brief ordered JSON class
-This type preserves the insertion order of object keys.
- at since version 3.9.0
-using ordered_json = basic_json<nlohmann::ordered_map>;
-}  // namespace nlohmann
+    NLOHMANN_JSON_NAMESPACE_END
 #endif  // INCLUDE_NLOHMANN_JSON_FWD_HPP_
-namespace nlohmann
+NLOHMANN_JSON_NAMESPACE_BEGIN
 @brief detail namespace with internal helper functions
@@ -3046,6 +3446,7 @@ implementations of some @ref basic_json methods, and meta-programming helpers.
 namespace detail
 // helpers //
@@ -3064,6 +3465,16 @@ template<typename> struct is_basic_json : std::false_type {};
 NLOHMANN_BASIC_JSON_TPL_DECLARATION
 struct is_basic_json<NLOHMANN_BASIC_JSON_TPL> : std::true_type {};
+// used by exceptions create() member functions
+// true_type for pointer to possibly cv-qualified basic_json or std::nullptr_t
+// false_type otherwise
+template<typename BasicJsonContext>
+struct is_basic_json_context :
+    std::integral_constant < bool,
+    is_basic_json<typename std::remove_cv<typename std::remove_pointer<BasicJsonContext>::type>::type>::value
+    || std::is_same<BasicJsonContext, std::nullptr_t>::value >
 // json_ref helpers //
@@ -3102,9 +3513,6 @@ using reference_t = typename T::reference;
 using iterator_category_t = typename T::iterator_category;
-using iterator_t = typename T::iterator;
 using to_json_function = decltype(T::to_json(std::declval<Args>()...));
@@ -3129,8 +3537,7 @@ struct is_getable
 template<typename BasicJsonType, typename T>
-struct has_from_json < BasicJsonType, T,
-           enable_if_t < !is_basic_json<T>::value >>
+struct has_from_json < BasicJsonType, T, enable_if_t < !is_basic_json<T>::value >>
     using serializer = typename BasicJsonType::template json_serializer<T, void>;
@@ -3169,11 +3576,133 @@ struct has_to_json < BasicJsonType, T, enable_if_t < !is_basic_json<T>::value >>
         T>::value;
+template<typename T>
+using detect_key_compare = typename T::key_compare;
+struct has_key_compare : std::integral_constant<bool, is_detected<detect_key_compare, T>::value> {};
+// obtains the actual object key comparator
+template<typename BasicJsonType>
+struct actual_object_comparator
+    using object_t = typename BasicJsonType::object_t;
+    using object_comparator_t = typename BasicJsonType::default_object_comparator_t;
+    using type = typename std::conditional < has_key_compare<object_t>::value,
+          typename object_t::key_compare, object_comparator_t>::type;
+using actual_object_comparator_t = typename actual_object_comparator<BasicJsonType>::type;
+// char_traits //
+// Primary template of char_traits calls std char_traits
+struct char_traits : std::char_traits<T>
+// Explicitly define char traits for unsigned char since it is not standard
+template<>
+struct char_traits<unsigned char> : std::char_traits<char>
+    using char_type = unsigned char;
+    using int_type = uint64_t;
+    // Redefine to_int_type function
+    static int_type to_int_type(char_type c) noexcept
+        return static_cast<int_type>(c);
+    static char_type to_char_type(int_type i) noexcept
+        return static_cast<char_type>(i);
+    static constexpr int_type eof() noexcept
+        return static_cast<int_type>(EOF);
+// Explicitly define char traits for signed char since it is not standard
+template<>
+struct char_traits<signed char> : std::char_traits<char>
+    using char_type = signed char;
 // is_ functions //
+// https://en.cppreference.com/w/cpp/types/conjunction
+template<class...> struct conjunction : std::true_type { };
+template<class B> struct conjunction<B> : B { };
+template<class B, class... Bn>
+struct conjunction<B, Bn...>
+: std::conditional<static_cast<bool>(B::value), conjunction<Bn...>, B>::type {};
+// https://en.cppreference.com/w/cpp/types/negation
+template<class B> struct negation : std::integral_constant < bool, !B::value > { };
+// Reimplementation of is_constructible and is_default_constructible, due to them being broken for
+// std::pair and std::tuple until LWG 2367 fix (see https://cplusplus.github.io/LWG/lwg-defects.html#2367).
+// This causes compile errors in e.g. clang 3.5 or gcc 4.9.
+struct is_default_constructible : std::is_default_constructible<T> {};
+template <typename T1, typename T2>
+struct is_default_constructible<std::pair<T1, T2>>
+            : conjunction<is_default_constructible<T1>, is_default_constructible<T2>> {};
+struct is_default_constructible<const std::pair<T1, T2>>
+struct is_default_constructible<std::tuple<Ts...>>
+            : conjunction<is_default_constructible<Ts>...> {};
+struct is_default_constructible<const std::tuple<Ts...>>
+template <typename T, typename... Args>
+struct is_constructible : std::is_constructible<T, Args...> {};
+struct is_constructible<std::pair<T1, T2>> : is_default_constructible<std::pair<T1, T2>> {};
+struct is_constructible<const std::pair<T1, T2>> : is_default_constructible<const std::pair<T1, T2>> {};
+struct is_constructible<std::tuple<Ts...>> : is_default_constructible<std::tuple<Ts...>> {};
+struct is_constructible<const std::tuple<Ts...>> : is_default_constructible<const std::tuple<Ts...>> {};
 template<typename T, typename = void>
 struct is_iterator_traits : std::false_type {};
@@ -3192,6 +3721,31 @@ struct is_iterator_traits<iterator_traits<T>>
         is_detected<reference_t, traits>::value;
+struct is_range
+  private:
+    using t_ref = typename std::add_lvalue_reference<T>::type;
+    using iterator = detected_t<result_of_begin, t_ref>;
+    using sentinel = detected_t<result_of_end, t_ref>;
+    // to be 100% correct, it should use https://en.cppreference.com/w/cpp/iterator/input_or_output_iterator
+    // and https://en.cppreference.com/w/cpp/iterator/sentinel_for
+    // but reimplementing these would be too much work, as a lot of other concepts are used underneath
+    static constexpr auto is_iterator_begin =
+        is_iterator_traits<iterator_traits<iterator>>::value;
+  public:
+    static constexpr bool value = !std::is_same<iterator, nonesuch>::value && !std::is_same<sentinel, nonesuch>::value && is_iterator_begin;
+template<typename R>
+using iterator_t = enable_if_t<is_range<R>::value, result_of_begin<decltype(std::declval<R&>())>>;
+using range_value_t = value_type_t<iterator_traits<iterator_t<T>>>;
 // The following implementation of is_complete_type is taken from
 // https://blogs.msdn.microsoft.com/vcblog/2015/12/02/partial-support-for-expression-sfinae-in-vs-2015-update-1/
 // and is written by Xiang Fan who agreed to using it in this library.
@@ -3216,9 +3770,9 @@ struct is_compatible_object_type_impl <
     // macOS's is_constructible does not play well with nonesuch...
-        std::is_constructible<typename object_t::key_type,
+        is_constructible<typename object_t::key_type,
         typename CompatibleObjectType::key_type>::value &&
-        std::is_constructible<typename object_t::mapped_type,
+        is_constructible<typename object_t::mapped_type,
         typename CompatibleObjectType::mapped_type>::value;
@@ -3239,10 +3793,10 @@ struct is_constructible_object_type_impl <
-        (std::is_default_constructible<ConstructibleObjectType>::value &&
+        (is_default_constructible<ConstructibleObjectType>::value &&
          (std::is_move_assignable<ConstructibleObjectType>::value ||
           std::is_copy_assignable<ConstructibleObjectType>::value) &&
-         (std::is_constructible<typename ConstructibleObjectType::key_type,
+         (is_constructible<typename ConstructibleObjectType::key_type,
           typename object_t::key_type>::value &&
           std::is_same <
@@ -3259,42 +3813,29 @@ struct is_constructible_object_type
     : is_constructible_object_type_impl<BasicJsonType,
       ConstructibleObjectType> {};
-template<typename BasicJsonType, typename CompatibleStringType,
-         typename = void>
-struct is_compatible_string_type_impl : std::false_type {};
 template<typename BasicJsonType, typename CompatibleStringType>
-struct is_compatible_string_type_impl <
-    BasicJsonType, CompatibleStringType,
-    enable_if_t<is_detected_exact<typename BasicJsonType::string_t::value_type,
-    value_type_t, CompatibleStringType>::value >>
-    static constexpr auto value =
-        std::is_constructible<typename BasicJsonType::string_t, CompatibleStringType>::value;
-template<typename BasicJsonType, typename ConstructibleStringType>
-    : is_compatible_string_type_impl<BasicJsonType, ConstructibleStringType> {};
-template<typename BasicJsonType, typename ConstructibleStringType,
-         typename = void>
-struct is_constructible_string_type_impl : std::false_type {};
-struct is_constructible_string_type_impl <
-    BasicJsonType, ConstructibleStringType,
-    value_type_t, ConstructibleStringType>::value >>
-        std::is_constructible<ConstructibleStringType,
-        typename BasicJsonType::string_t>::value;
+        is_constructible<typename BasicJsonType::string_t, CompatibleStringType>::value;
-    : is_constructible_string_type_impl<BasicJsonType, ConstructibleStringType> {};
+    // launder type through decltype() to fix compilation failure on ICPC
+#ifdef __INTEL_COMPILER
+    using laundered_type = decltype(std::declval<ConstructibleStringType>());
+#else
+    using laundered_type = ConstructibleStringType;
+#endif
+    static constexpr auto value =
+        conjunction <
+        is_constructible<laundered_type, typename BasicJsonType::string_t>,
+        is_detected_exact<typename BasicJsonType::string_t::value_type,
+        value_type_t, laundered_type >>::value;
 template<typename BasicJsonType, typename CompatibleArrayType, typename = void>
 struct is_compatible_array_type_impl : std::false_type {};
@@ -3302,17 +3843,16 @@ struct is_compatible_array_type_impl : std::false_type {};
 template<typename BasicJsonType, typename CompatibleArrayType>
 struct is_compatible_array_type_impl <
     BasicJsonType, CompatibleArrayType,
-    enable_if_t < is_detected<value_type_t, CompatibleArrayType>::value&&
+    enable_if_t <
     is_detected<iterator_t, CompatibleArrayType>::value&&
-// This is needed because json_reverse_iterator has a ::iterator type...
-// Therefore it is detected as a CompatibleArrayType.
-// The real fix would be to have an Iterable concept.
-    !is_iterator_traits <
-    iterator_traits<CompatibleArrayType >>::value >>
+    is_iterator_traits<iterator_traits<detected_t<iterator_t, CompatibleArrayType>>>::value&&
+// special case for types like std::filesystem::path whose iterator's value_type are themselves
+// c.f. https://github.com/nlohmann/json/pull/3073
+    !std::is_same<CompatibleArrayType, detected_t<range_value_t, CompatibleArrayType>>::value >>
-        std::is_constructible<BasicJsonType,
-        typename CompatibleArrayType::value_type>::value;
+        is_constructible<BasicJsonType,
+        range_value_t<CompatibleArrayType>>::value;
@@ -3334,28 +3874,29 @@ struct is_constructible_array_type_impl <
     BasicJsonType, ConstructibleArrayType,
     enable_if_t < !std::is_same<ConstructibleArrayType,
     typename BasicJsonType::value_type>::value&&
-    std::is_default_constructible<ConstructibleArrayType>::value&&
+    !is_compatible_string_type<BasicJsonType, ConstructibleArrayType>::value&&
+    is_default_constructible<ConstructibleArrayType>::value&&
 (std::is_move_assignable<ConstructibleArrayType>::value ||
  std::is_copy_assignable<ConstructibleArrayType>::value)&&
-is_detected<value_type_t, ConstructibleArrayType>::value&&
 is_detected<iterator_t, ConstructibleArrayType>::value&&
-is_complete_type <
-detected_t<value_type_t, ConstructibleArrayType >>::value >>
+is_iterator_traits<iterator_traits<detected_t<iterator_t, ConstructibleArrayType>>>::value&&
+is_detected<range_value_t, ConstructibleArrayType>::value&&
+!std::is_same<ConstructibleArrayType, detected_t<range_value_t, ConstructibleArrayType>>::value&&
+        is_complete_type <
+        detected_t<range_value_t, ConstructibleArrayType >>::value >>
-    static constexpr bool value =
-        // This is needed because json_reverse_iterator has a ::iterator type,
-        // furthermore, std::back_insert_iterator (and other iterators) have a
-        // base class `iterator`... Therefore it is detected as a
-        // ConstructibleArrayType. The real fix would be to have an Iterable
-        // concept.
-        !is_iterator_traits<iterator_traits<ConstructibleArrayType>>::value &&
+    using value_type = range_value_t<ConstructibleArrayType>;
-        (std::is_same<typename ConstructibleArrayType::value_type,
-         typename BasicJsonType::array_t::value_type>::value ||
-         has_from_json<BasicJsonType,
-         typename ConstructibleArrayType::value_type>::value ||
-         has_non_default_from_json <
-         BasicJsonType, typename ConstructibleArrayType::value_type >::value);
+        std::is_same<value_type,
+        typename BasicJsonType::array_t::value_type>::value ||
+        has_from_json<BasicJsonType,
+        value_type>::value ||
+        has_non_default_from_json <
+        BasicJsonType,
+        value_type >::value;
 template<typename BasicJsonType, typename ConstructibleArrayType>
@@ -3378,7 +3919,7 @@ struct is_compatible_integer_type_impl <
     using CompatibleLimits = std::numeric_limits<CompatibleNumberIntegerType>;
-        std::is_constructible<RealIntegerType,
+        is_constructible<RealIntegerType,
         CompatibleNumberIntegerType>::value &&
         CompatibleLimits::is_integer &&
         RealLimits::is_signed == CompatibleLimits::is_signed;
@@ -3405,115 +3946,726 @@ template<typename BasicJsonType, typename CompatibleType>
 struct is_compatible_type
     : is_compatible_type_impl<BasicJsonType, CompatibleType> {};
-// https://en.cppreference.com/w/cpp/types/conjunction
-template<class...> struct conjunction : std::true_type { };
-template<class B1> struct conjunction<B1> : B1 { };
-template<class B1, class... Bn>
-struct conjunction<B1, Bn...>
-: std::conditional<bool(B1::value), conjunction<Bn...>, B1>::type {};
 template<typename T1, typename T2>
 struct is_constructible_tuple : std::false_type {};
 template<typename T1, typename... Args>
-struct is_constructible_tuple<T1, std::tuple<Args...>> : conjunction<std::is_constructible<T1, Args>...> {};
+struct is_constructible_tuple<T1, std::tuple<Args...>> : conjunction<is_constructible<T1, Args>...> {};
+template<typename BasicJsonType, typename T>
+struct is_json_iterator_of : std::false_type {};
+struct is_json_iterator_of<BasicJsonType, typename BasicJsonType::iterator> : std::true_type {};
+struct is_json_iterator_of<BasicJsonType, typename BasicJsonType::const_iterator> : std::true_type
+// checks if a given type T is a template specialization of Primary
+template<template <typename...> class Primary, typename T>
+struct is_specialization_of : std::false_type {};
+template<template <typename...> class Primary, typename... Args>
+struct is_specialization_of<Primary, Primary<Args...>> : std::true_type {};
+using is_json_pointer = is_specialization_of<::nlohmann::json_pointer, uncvref_t<T>>;
+// checks if A and B are comparable using Compare functor
+template<typename Compare, typename A, typename B, typename = void>
+struct is_comparable : std::false_type {};
+template<typename Compare, typename A, typename B>
+struct is_comparable<Compare, A, B, void_t<
+decltype(std::declval<Compare>()(std::declval<A>(), std::declval<B>())),
+decltype(std::declval<Compare>()(std::declval<B>(), std::declval<A>()))
+>> : std::true_type {};
+using detect_is_transparent = typename T::is_transparent;
+// type trait to check if KeyType can be used as object key (without a BasicJsonType)
+// see is_usable_as_basic_json_key_type below
+template<typename Comparator, typename ObjectKeyType, typename KeyTypeCVRef, bool RequireTransparentComparator = true,
+         bool ExcludeObjectKeyType = RequireTransparentComparator, typename KeyType = uncvref_t<KeyTypeCVRef>>
+using is_usable_as_key_type = typename std::conditional <
+                              is_comparable<Comparator, ObjectKeyType, KeyTypeCVRef>::value
+                              && !(ExcludeObjectKeyType && std::is_same<KeyType,
+                                   ObjectKeyType>::value)
+                              && (!RequireTransparentComparator
+                                  || is_detected <detect_is_transparent, Comparator>::value)
+                              && !is_json_pointer<KeyType>::value,
+                              std::true_type,
+                              std::false_type >::type;
+// true if:
+//   - KeyType is comparable with BasicJsonType::object_t::key_type
+//   - if ExcludeObjectKeyType is true, KeyType is not BasicJsonType::object_t::key_type
+//   - the comparator is transparent or RequireTransparentComparator is false
+//   - KeyType is not a JSON iterator or json_pointer
+template<typename BasicJsonType, typename KeyTypeCVRef, bool RequireTransparentComparator = true,
+using is_usable_as_basic_json_key_type = typename std::conditional <
+        is_usable_as_key_type<typename BasicJsonType::object_comparator_t,
+        typename BasicJsonType::object_t::key_type, KeyTypeCVRef,
+        RequireTransparentComparator, ExcludeObjectKeyType>::value
+        && !is_json_iterator_of<BasicJsonType, KeyType>::value,
+        std::true_type,
+template<typename ObjectType, typename KeyType>
+using detect_erase_with_key_type = decltype(std::declval<ObjectType&>().erase(std::declval<KeyType>()));
+// type trait to check if object_t has an erase() member functions accepting KeyType
+template<typename BasicJsonType, typename KeyType>
+using has_erase_with_key_type = typename std::conditional <
+                                is_detected <
+                                detect_erase_with_key_type,
+                                typename BasicJsonType::object_t, KeyType >::value,
+                                std::true_type,
+// a naive helper to check if a type is an ordered_map (exploits the fact that
+// ordered_map inherits capacity() from std::vector)
+struct is_ordered_map
+    using one = char;
+    struct two
+        char x[2]; // NOLINT(cppcoreguidelines-avoid-c-arrays,hicpp-avoid-c-arrays,modernize-avoid-c-arrays)
+    template <typename C> static one test( decltype(&C::capacity) ) ;
+    template <typename C> static two test(...);
+    enum { value = sizeof(test<T>(nullptr)) == sizeof(char) }; // NOLINT(cppcoreguidelines-pro-type-vararg,hicpp-vararg)
+// to avoid useless casts (see https://github.com/nlohmann/json/issues/2893#issuecomment-889152324)
+template < typename T, typename U, enable_if_t < !std::is_same<T, U>::value, int > = 0 >
+T conditional_static_cast(U value)
+    return static_cast<T>(value);
+template<typename T, typename U, enable_if_t<std::is_same<T, U>::value, int> = 0>
+    return value;
+template<typename... Types>
+using all_integral = conjunction<std::is_integral<Types>...>;
+using all_signed = conjunction<std::is_signed<Types>...>;
+using all_unsigned = conjunction<std::is_unsigned<Types>...>;
+// there's a disjunction trait in another PR; replace when merged
+using same_sign = std::integral_constant < bool,
+      all_signed<Types...>::value || all_unsigned<Types...>::value >;
+template<typename OfType, typename T>
+using never_out_of_range = std::integral_constant < bool,
+      (std::is_signed<OfType>::value && (sizeof(T) < sizeof(OfType)))
+      || (same_sign<OfType, T>::value && sizeof(OfType) == sizeof(T)) >;
+template<typename OfType, typename T,
+         bool OfTypeSigned = std::is_signed<OfType>::value,
+         bool TSigned = std::is_signed<T>::value>
+struct value_in_range_of_impl2;
+struct value_in_range_of_impl2<OfType, T, false, false>
+    static constexpr bool test(T val)
+        using CommonType = typename std::common_type<OfType, T>::type;
+        return static_cast<CommonType>(val) <= static_cast<CommonType>((std::numeric_limits<OfType>::max)());
+struct value_in_range_of_impl2<OfType, T, true, false>
+struct value_in_range_of_impl2<OfType, T, false, true>
+        return val >= 0 && static_cast<CommonType>(val) <= static_cast<CommonType>((std::numeric_limits<OfType>::max)());
+struct value_in_range_of_impl2<OfType, T, true, true>
+        return static_cast<CommonType>(val) >= static_cast<CommonType>((std::numeric_limits<OfType>::min)())
+               && static_cast<CommonType>(val) <= static_cast<CommonType>((std::numeric_limits<OfType>::max)());
+         bool NeverOutOfRange = never_out_of_range<OfType, T>::value,
+         typename = detail::enable_if_t<all_integral<OfType, T>::value>>
+struct value_in_range_of_impl1;
+struct value_in_range_of_impl1<OfType, T, false>
+        return value_in_range_of_impl2<OfType, T>::test(val);
+struct value_in_range_of_impl1<OfType, T, true>
+    static constexpr bool test(T /*val*/)
+        return true;
+inline constexpr bool value_in_range_of(T val)
+    return value_in_range_of_impl1<OfType, T>::test(val);
+template<bool Value>
+using bool_constant = std::integral_constant<bool, Value>;
+// is_c_string
+namespace impl
+inline constexpr bool is_c_string()
+    using TUnExt = typename std::remove_extent<T>::type;
+    using TUnCVExt = typename std::remove_cv<TUnExt>::type;
+    using TUnPtr = typename std::remove_pointer<T>::type;
+    using TUnCVPtr = typename std::remove_cv<TUnPtr>::type;
+    return
+        (std::is_array<T>::value && std::is_same<TUnCVExt, char>::value)
+        || (std::is_pointer<T>::value && std::is_same<TUnCVPtr, char>::value);
+}  // namespace impl
+// checks whether T is a [cv] char */[cv] char[] C string
+struct is_c_string : bool_constant<impl::is_c_string<T>()> {};
+using is_c_string_uncvref = is_c_string<uncvref_t<T>>;
+// is_transparent
+namespace impl
+inline constexpr bool is_transparent()
+    return is_detected<detect_is_transparent, T>::value;
+// checks whether T has a member named is_transparent
+struct is_transparent : bool_constant<impl::is_transparent<T>()> {};
 }  // namespace detail
+NLOHMANN_JSON_NAMESPACE_END
+// #include <nlohmann/detail/string_concat.hpp>
+#include <cstring> // strlen
+#include <string> // string
+#include <utility> // forward
+// #include <nlohmann/detail/meta/cpp_future.hpp>
+// #include <nlohmann/detail/meta/detected.hpp>
+namespace detail
+inline std::size_t concat_length()
+    return 0;
+template<typename... Args>
+inline std::size_t concat_length(const char* cstr, const Args& ... rest);
+template<typename StringType, typename... Args>
+inline std::size_t concat_length(const StringType& str, const Args& ... rest);
+inline std::size_t concat_length(const char /*c*/, const Args& ... rest)
+    return 1 + concat_length(rest...);
+    // cppcheck-suppress ignoredReturnValue
+    return ::strlen(cstr) + concat_length(rest...);
+    return str.size() + concat_length(rest...);
+template<typename OutStringType>
+inline void concat_into(OutStringType& /*out*/)
+template<typename StringType, typename Arg>
+using string_can_append = decltype(std::declval<StringType&>().append(std::declval < Arg && > ()));
+using detect_string_can_append = is_detected<string_can_append, StringType, Arg>;
+using string_can_append_op = decltype(std::declval<StringType&>() += std::declval < Arg && > ());
+using detect_string_can_append_op = is_detected<string_can_append_op, StringType, Arg>;
+using string_can_append_iter = decltype(std::declval<StringType&>().append(std::declval<const Arg&>().begin(), std::declval<const Arg&>().end()));
+using detect_string_can_append_iter = is_detected<string_can_append_iter, StringType, Arg>;
+using string_can_append_data = decltype(std::declval<StringType&>().append(std::declval<const Arg&>().data(), std::declval<const Arg&>().size()));
+using detect_string_can_append_data = is_detected<string_can_append_data, StringType, Arg>;
+template < typename OutStringType, typename Arg, typename... Args,
+           enable_if_t < !detect_string_can_append<OutStringType, Arg>::value
+                         && detect_string_can_append_op<OutStringType, Arg>::value, int > = 0 >
+inline void concat_into(OutStringType& out, Arg && arg, Args && ... rest);
+                         && !detect_string_can_append_op<OutStringType, Arg>::value
+                         && detect_string_can_append_iter<OutStringType, Arg>::value, int > = 0 >
+inline void concat_into(OutStringType& out, const Arg& arg, Args && ... rest);
+                         && !detect_string_can_append_iter<OutStringType, Arg>::value
+                         && detect_string_can_append_data<OutStringType, Arg>::value, int > = 0 >
+template<typename OutStringType, typename Arg, typename... Args,
+         enable_if_t<detect_string_can_append<OutStringType, Arg>::value, int> = 0>
+    out.append(std::forward<Arg>(arg));
+    concat_into(out, std::forward<Args>(rest)...);
+                         && detect_string_can_append_op<OutStringType, Arg>::value, int > >
+inline void concat_into(OutStringType& out, Arg&& arg, Args&& ... rest)
+    out += std::forward<Arg>(arg);
+                         && detect_string_can_append_iter<OutStringType, Arg>::value, int > >
+inline void concat_into(OutStringType& out, const Arg& arg, Args&& ... rest)
+    out.append(arg.begin(), arg.end());
+                         && detect_string_can_append_data<OutStringType, Arg>::value, int > >
+    out.append(arg.data(), arg.size());
+template<typename OutStringType = std::string, typename... Args>
+inline OutStringType concat(Args && ... args)
+    OutStringType str;
+    str.reserve(concat_length(args...));
+    concat_into(str, std::forward<Args>(args)...);
+    return str;
+}  // namespace detail
+namespace detail
+// exceptions //
+/// @brief general exception of the @ref basic_json class
+/// @sa https://json.nlohmann.me/api/basic_json/exception/
+class exception : public std::exception
+  public:
+    /// returns the explanatory string
+    const char* what() const noexcept override
+        return m.what();
+    /// the id of the exception
+    const int id; // NOLINT(cppcoreguidelines-non-private-member-variables-in-classes)
+  protected:
+    JSON_HEDLEY_NON_NULL(3)
+    exception(int id_, const char* what_arg) : id(id_), m(what_arg) {} // NOLINT(bugprone-throw-keyword-missing)
+    static std::string name(const std::string& ename, int id_)
+        return concat("[json.exception.", ename, '.', std::to_string(id_), "] ");
+    static std::string diagnostics(std::nullptr_t /*leaf_element*/)
+        return "";
+    template<typename BasicJsonType>
+    static std::string diagnostics(const BasicJsonType* leaf_element)
+#if JSON_DIAGNOSTICS
+        std::vector<std::string> tokens;
+        for (const auto* current = leaf_element; current != nullptr && current->m_parent != nullptr; current = current->m_parent)
+            switch (current->m_parent->type())
+                case value_t::array:
+                    for (std::size_t i = 0; i < current->m_parent->m_data.m_value.array->size(); ++i)
+                        if (&current->m_parent->m_data.m_value.array->operator[](i) == current)
+                            tokens.emplace_back(std::to_string(i));
+                            break;
+                    break;
+                case value_t::object:
+                    for (const auto& element : *current->m_parent->m_data.m_value.object)
+                        if (&element.second == current)
+                            tokens.emplace_back(element.first.c_str());
+                            break;
+                    break;
+                case value_t::null: // LCOV_EXCL_LINE
+                case value_t::string: // LCOV_EXCL_LINE
+                case value_t::boolean: // LCOV_EXCL_LINE
+                case value_t::number_integer: // LCOV_EXCL_LINE
+                case value_t::number_unsigned: // LCOV_EXCL_LINE
+                case value_t::number_float: // LCOV_EXCL_LINE
+                case value_t::binary: // LCOV_EXCL_LINE
+                case value_t::discarded: // LCOV_EXCL_LINE
+                default:   // LCOV_EXCL_LINE
+                    break; // LCOV_EXCL_LINE
+        if (tokens.empty())
+            return "";
+        auto str = std::accumulate(tokens.rbegin(), tokens.rend(), std::string{},
+                                   [](const std::string & a, const std::string & b)
+            return concat(a, '/', detail::escape(b));
+        return concat('(', str, ") ");
+#else
+        static_cast<void>(leaf_element);
+        return "";
+#endif
+  private:
+    /// an exception object as storage for error messages
+    std::runtime_error m;
+/// @brief exception indicating a parse error
+/// @sa https://json.nlohmann.me/api/basic_json/parse_error/
+class parse_error : public exception
+  public:
+    @brief create a parse error exception
+    @param[in] id_       the id of the exception
+    @param[in] pos       the position where the error occurred (or with
+                         chars_read_total=0 if the position cannot be
+                         determined)
+    @param[in] what_arg  the explanatory string
+    @return parse_error object
+    template<typename BasicJsonContext, enable_if_t<is_basic_json_context<BasicJsonContext>::value, int> = 0>
+    static parse_error create(int id_, const position_t& pos, const std::string& what_arg, BasicJsonContext context)
+        const std::string w = concat(exception::name("parse_error", id_), "parse error",
+                                     position_string(pos), ": ", exception::diagnostics(context), what_arg);
+        return {id_, pos.chars_read_total, w.c_str()};
+    static parse_error create(int id_, std::size_t byte_, const std::string& what_arg, BasicJsonContext context)
+                                     (byte_ != 0 ? (concat(" at byte ", std::to_string(byte_))) : ""),
+                                     ": ", exception::diagnostics(context), what_arg);
+        return {id_, byte_, w.c_str()};
+    @brief byte index of the parse error
+    The byte index of the last read character in the input file.
+    @note For an input with n bytes, 1 is the index of the first character and
+          n+1 is the index of the terminating null byte or the end of file.
+          This also holds true when reading a byte vector (CBOR or MessagePack).
+    const std::size_t byte;
+  private:
+    parse_error(int id_, std::size_t byte_, const char* what_arg)
+        : exception(id_, what_arg), byte(byte_) {}
+    static std::string position_string(const position_t& pos)
+        return concat(" at line ", std::to_string(pos.lines_read + 1),
+                      ", column ", std::to_string(pos.chars_read_current_line));
+/// @brief exception indicating errors with iterators
+/// @sa https://json.nlohmann.me/api/basic_json/invalid_iterator/
+class invalid_iterator : public exception
+  public:
+    static invalid_iterator create(int id_, const std::string& what_arg, BasicJsonContext context)
+        const std::string w = concat(exception::name("invalid_iterator", id_), exception::diagnostics(context), what_arg);
+        return {id_, w.c_str()};
+  private:
+    invalid_iterator(int id_, const char* what_arg)
+        : exception(id_, what_arg) {}
+/// @brief exception indicating executing a member function with a wrong type
+/// @sa https://json.nlohmann.me/api/basic_json/type_error/
+class type_error : public exception
+  public:
+    static type_error create(int id_, const std::string& what_arg, BasicJsonContext context)
+        const std::string w = concat(exception::name("type_error", id_), exception::diagnostics(context), what_arg);
+  private:
+    type_error(int id_, const char* what_arg) : exception(id_, what_arg) {}
+/// @brief exception indicating access out of the defined range
+/// @sa https://json.nlohmann.me/api/basic_json/out_of_range/
+class out_of_range : public exception
+  public:
+    static out_of_range create(int id_, const std::string& what_arg, BasicJsonContext context)
+        const std::string w = concat(exception::name("out_of_range", id_), exception::diagnostics(context), what_arg);
+  private:
+    out_of_range(int id_, const char* what_arg) : exception(id_, what_arg) {}
+/// @brief exception indicating other library errors
+/// @sa https://json.nlohmann.me/api/basic_json/other_error/
+class other_error : public exception
+  public:
+    static other_error create(int id_, const std::string& what_arg, BasicJsonContext context)
+        const std::string w = concat(exception::name("other_error", id_), exception::diagnostics(context), what_arg);
+  private:
+    other_error(int id_, const char* what_arg) : exception(id_, what_arg) {}
+// #include <nlohmann/detail/meta/identity_tag.hpp>
+// #include <nlohmann/detail/abi_macros.hpp>
+namespace detail
+// dispatching helper struct
+template <class T> struct identity_tag {};
+// #include <nlohmann/detail/meta/std_fs.hpp>
+#if JSON_HAS_EXPERIMENTAL_FILESYSTEM
+#include <experimental/filesystem>
+namespace detail
+namespace std_fs = std::experimental::filesystem;
+#elif JSON_HAS_FILESYSTEM
+#include <filesystem>
+namespace detail
+namespace std_fs = std::filesystem;
+#endif
+// #include <nlohmann/detail/meta/type_traits.hpp>
 // #include <nlohmann/detail/value_t.hpp>
-#include <array> // array
-#include <cstddef> // size_t
-#include <cstdint> // uint8_t
-namespace nlohmann
 namespace detail
-// JSON type enumeration //
- at brief the JSON type enumeration
-This enumeration collects the different JSON types. It is internally used to
-distinguish the stored values, and the functions @ref basic_json::is_null(),
- at ref basic_json::is_object(), @ref basic_json::is_array(),
- at ref basic_json::is_string(), @ref basic_json::is_boolean(),
- at ref basic_json::is_number() (with @ref basic_json::is_number_integer(),
- at ref basic_json::is_number_unsigned(), and @ref basic_json::is_number_float()),
- at ref basic_json::is_discarded(), @ref basic_json::is_primitive(), and
- at ref basic_json::is_structured() rely on it.
- at note There are three enumeration entries (number_integer, number_unsigned, and
-number_float), because the library distinguishes these three types for numbers:
- at ref basic_json::number_unsigned_t is used for unsigned integers,
- at ref basic_json::number_integer_t is used for signed integers, and
- at ref basic_json::number_float_t is used for floating-point numbers or to
-approximate integers which do not fit in the limits of their respective type.
- at sa @ref basic_json::basic_json(const value_t value_type) -- create a JSON
-value with the default value for a given type
-enum class value_t : std::uint8_t
-    null,             ///< null value
-    object,           ///< object (unordered set of name/value pairs)
-    array,            ///< array (ordered collection of values)
-    string,           ///< string value
-    boolean,          ///< boolean value
-    number_integer,   ///< number value (signed integer)
-    number_unsigned,  ///< number value (unsigned integer)
-    number_float,     ///< number value (floating-point)
-    binary,           ///< binary array (ordered collection of bytes)
-    discarded         ///< discarded by the parser callback function
- at brief comparison operator for JSON types
-Returns an ordering that is similar to Python:
-- order: null < boolean < number < object < array < string < binary
-- furthermore, each type is not smaller than itself
-- discarded values are not comparable
-- binary is represented as a b"" string in python and directly comparable to a
-  string; however, making a binary array directly comparable with a string would
-  be surprising behavior in a JSON file.
-inline bool operator<(const value_t lhs, const value_t rhs) noexcept
-    static constexpr std::array<std::uint8_t, 9> order = {{
-            0 /* null */, 3 /* object */, 4 /* array */, 5 /* string */,
-            1 /* boolean */, 2 /* integer */, 2 /* unsigned */, 2 /* float */,
-            6 /* binary */
-    const auto l_index = static_cast<std::size_t>(lhs);
-    const auto r_index = static_cast<std::size_t>(rhs);
-    return l_index < order.size() && r_index < order.size() && order[l_index] < order[r_index];
-}  // namespace detail
-namespace nlohmann
-namespace detail
-void from_json(const BasicJsonType& j, typename std::nullptr_t& n)
+inline void from_json(const BasicJsonType& j, typename std::nullptr_t& n)
     if (JSON_HEDLEY_UNLIKELY(!j.is_null()))
-        JSON_THROW(type_error::create(302, "type must be null, but is " + std::string(j.type_name())));
+        JSON_THROW(type_error::create(302, concat("type must be null, but is ", j.type_name()), &j));
     n = nullptr;
@@ -3543,83 +4695,92 @@ void get_arithmetic_value(const BasicJsonType& j, ArithmeticType& val)
             break;
         default:
-            JSON_THROW(type_error::create(302, "type must be number, but is " + std::string(j.type_name())));
+            JSON_THROW(type_error::create(302, concat("type must be number, but is ", j.type_name()), &j));
-void from_json(const BasicJsonType& j, typename BasicJsonType::boolean_t& b)
+inline void from_json(const BasicJsonType& j, typename BasicJsonType::boolean_t& b)
     if (JSON_HEDLEY_UNLIKELY(!j.is_boolean()))
-        JSON_THROW(type_error::create(302, "type must be boolean, but is " + std::string(j.type_name())));
+        JSON_THROW(type_error::create(302, concat("type must be boolean, but is ", j.type_name()), &j));
     b = *j.template get_ptr<const typename BasicJsonType::boolean_t*>();
-void from_json(const BasicJsonType& j, typename BasicJsonType::string_t& s)
+inline void from_json(const BasicJsonType& j, typename BasicJsonType::string_t& s)
     if (JSON_HEDLEY_UNLIKELY(!j.is_string()))
-        JSON_THROW(type_error::create(302, "type must be string, but is " + std::string(j.type_name())));
+        JSON_THROW(type_error::create(302, concat("type must be string, but is ", j.type_name()), &j));
     s = *j.template get_ptr<const typename BasicJsonType::string_t*>();
 template <
-    typename BasicJsonType, typename ConstructibleStringType,
+    typename BasicJsonType, typename StringType,
     enable_if_t <
-        is_constructible_string_type<BasicJsonType, ConstructibleStringType>::value&&
-        !std::is_same<typename BasicJsonType::string_t,
-                      ConstructibleStringType>::value,
-        int > = 0 >
-void from_json(const BasicJsonType& j, ConstructibleStringType& s)
+        std::is_assignable<StringType&, const typename BasicJsonType::string_t>::value
+        && is_detected_exact<typename BasicJsonType::string_t::value_type, value_type_t, StringType>::value
+        && !std::is_same<typename BasicJsonType::string_t, StringType>::value
+        && !is_json_ref<StringType>::value, int > = 0 >
+inline void from_json(const BasicJsonType& j, StringType& s)
-void from_json(const BasicJsonType& j, typename BasicJsonType::number_float_t& val)
+inline void from_json(const BasicJsonType& j, typename BasicJsonType::number_float_t& val)
     get_arithmetic_value(j, val);
-void from_json(const BasicJsonType& j, typename BasicJsonType::number_unsigned_t& val)
+inline void from_json(const BasicJsonType& j, typename BasicJsonType::number_unsigned_t& val)
-void from_json(const BasicJsonType& j, typename BasicJsonType::number_integer_t& val)
+inline void from_json(const BasicJsonType& j, typename BasicJsonType::number_integer_t& val)
+#if !JSON_DISABLE_ENUM_SERIALIZATION
 template<typename BasicJsonType, typename EnumType,
          enable_if_t<std::is_enum<EnumType>::value, int> = 0>
-void from_json(const BasicJsonType& j, EnumType& e)
+inline void from_json(const BasicJsonType& j, EnumType& e)
     typename std::underlying_type<EnumType>::type val;
     e = static_cast<EnumType>(val);
+#endif  // JSON_DISABLE_ENUM_SERIALIZATION
 // forward_list doesn't have an insert method
 template<typename BasicJsonType, typename T, typename Allocator,
          enable_if_t<is_getable<BasicJsonType, T>::value, int> = 0>
-void from_json(const BasicJsonType& j, std::forward_list<T, Allocator>& l)
+inline void from_json(const BasicJsonType& j, std::forward_list<T, Allocator>& l)
     if (JSON_HEDLEY_UNLIKELY(!j.is_array()))
-        JSON_THROW(type_error::create(302, "type must be array, but is " + std::string(j.type_name())));
+        JSON_THROW(type_error::create(302, concat("type must be array, but is ", j.type_name()), &j));
     l.clear();
     std::transform(j.rbegin(), j.rend(),
@@ -3632,11 +4793,11 @@ void from_json(const BasicJsonType& j, std::forward_list<T, Allocator>& l)
 // valarray doesn't have an insert method
-void from_json(const BasicJsonType& j, std::valarray<T>& l)
+inline void from_json(const BasicJsonType& j, std::valarray<T>& l)
     l.resize(j.size());
     std::transform(j.begin(), j.end(), std::begin(l),
@@ -3647,7 +4808,7 @@ void from_json(const BasicJsonType& j, std::valarray<T>& l)
 template<typename BasicJsonType, typename T, std::size_t N>
-auto from_json(const BasicJsonType& j, T (&arr)[N])
+auto from_json(const BasicJsonType& j, T (&arr)[N])  // NOLINT(cppcoreguidelines-avoid-c-arrays,hicpp-avoid-c-arrays,modernize-avoid-c-arrays)
 -> decltype(j.template get<T>(), void())
     for (std::size_t i = 0; i < N; ++i)
@@ -3657,7 +4818,7 @@ auto from_json(const BasicJsonType& j, T (&arr)[N])
-void from_json_array_impl(const BasicJsonType& j, typename BasicJsonType::array_t& arr, priority_tag<3> /*unused*/)
+inline void from_json_array_impl(const BasicJsonType& j, typename BasicJsonType::array_t& arr, priority_tag<3> /*unused*/)
     arr = *j.template get_ptr<const typename BasicJsonType::array_t*>();
@@ -3673,7 +4834,10 @@ auto from_json_array_impl(const BasicJsonType& j, std::array<T, N>& arr,
-template<typename BasicJsonType, typename ConstructibleArrayType>
+template<typename BasicJsonType, typename ConstructibleArrayType,
+         enable_if_t<
+             std::is_assignable<ConstructibleArrayType&, ConstructibleArrayType>::value,
+             int> = 0>
 auto from_json_array_impl(const BasicJsonType& j, ConstructibleArrayType& arr, priority_tag<1> /*unused*/)
 -> decltype(
     arr.reserve(std::declval<typename ConstructibleArrayType::size_type>()),
@@ -3694,9 +4858,12 @@ auto from_json_array_impl(const BasicJsonType& j, ConstructibleArrayType& arr, p
     arr = std::move(ret);
-void from_json_array_impl(const BasicJsonType& j, ConstructibleArrayType& arr,
-                          priority_tag<0> /*unused*/)
+         enable_if_t<
+             int> = 0>
+inline void from_json_array_impl(const BasicJsonType& j, ConstructibleArrayType& arr,
+                                 priority_tag<0> /*unused*/)
     using std::end;
@@ -3727,19 +4894,37 @@ void())
-                                      std::string(j.type_name())));
     from_json_array_impl(j, arr, priority_tag<3> {});
+template < typename BasicJsonType, typename T, std::size_t... Idx >
+std::array<T, sizeof...(Idx)> from_json_inplace_array_impl(BasicJsonType&& j,
+        identity_tag<std::array<T, sizeof...(Idx)>> /*unused*/, index_sequence<Idx...> /*unused*/)
+    return { { std::forward<BasicJsonType>(j).at(Idx).template get<T>()... } };
+template < typename BasicJsonType, typename T, std::size_t N >
+auto from_json(BasicJsonType&& j, identity_tag<std::array<T, N>> tag)
+-> decltype(from_json_inplace_array_impl(std::forward<BasicJsonType>(j), tag, make_index_sequence<N> {}))
+    if (JSON_HEDLEY_UNLIKELY(!j.is_array()))
+    return from_json_inplace_array_impl(std::forward<BasicJsonType>(j), tag, make_index_sequence<N> {});
-void from_json(const BasicJsonType& j, typename BasicJsonType::binary_t& bin)
+inline void from_json(const BasicJsonType& j, typename BasicJsonType::binary_t& bin)
     if (JSON_HEDLEY_UNLIKELY(!j.is_binary()))
-        JSON_THROW(type_error::create(302, "type must be binary, but is " + std::string(j.type_name())));
+        JSON_THROW(type_error::create(302, concat("type must be binary, but is ", j.type_name()), &j));
     bin = *j.template get_ptr<const typename BasicJsonType::binary_t*>();
@@ -3747,15 +4932,15 @@ void from_json(const BasicJsonType& j, typename BasicJsonType::binary_t& bin)
 template<typename BasicJsonType, typename ConstructibleObjectType,
          enable_if_t<is_constructible_object_type<BasicJsonType, ConstructibleObjectType>::value, int> = 0>
-void from_json(const BasicJsonType& j, ConstructibleObjectType& obj)
+inline void from_json(const BasicJsonType& j, ConstructibleObjectType& obj)
     if (JSON_HEDLEY_UNLIKELY(!j.is_object()))
-        JSON_THROW(type_error::create(302, "type must be object, but is " + std::string(j.type_name())));
+        JSON_THROW(type_error::create(302, concat("type must be object, but is ", j.type_name()), &j));
     ConstructibleObjectType ret;
-    auto inner_object = j.template get_ptr<const typename BasicJsonType::object_t*>();
+    const auto* inner_object = j.template get_ptr<const typename BasicJsonType::object_t*>();
     using value_type = typename ConstructibleObjectType::value_type;
     std::transform(
         inner_object->begin(), inner_object->end(),
@@ -3779,7 +4964,7 @@ template < typename BasicJsonType, typename ArithmeticType,
                !std::is_same<ArithmeticType, typename BasicJsonType::number_float_t>::value&&
                !std::is_same<ArithmeticType, typename BasicJsonType::boolean_t>::value,
                int > = 0 >
-void from_json(const BasicJsonType& j, ArithmeticType& val)
+inline void from_json(const BasicJsonType& j, ArithmeticType& val)
     switch (static_cast<value_t>(j))
@@ -3804,44 +4989,75 @@ void from_json(const BasicJsonType& j, ArithmeticType& val)
             break;
         default:
-template<typename BasicJsonType, typename A1, typename A2>
-void from_json(const BasicJsonType& j, std::pair<A1, A2>& p)
+template<typename BasicJsonType, typename... Args, std::size_t... Idx>
+std::tuple<Args...> from_json_tuple_impl_base(BasicJsonType&& j, index_sequence<Idx...> /*unused*/)
-    p = {j.at(0).template get<A1>(), j.at(1).template get<A2>()};
+    return std::make_tuple(std::forward<BasicJsonType>(j).at(Idx).template get<Args>()...);
-template<typename BasicJsonType, typename Tuple, std::size_t... Idx>
-void from_json_tuple_impl(const BasicJsonType& j, Tuple& t, index_sequence<Idx...> /*unused*/)
+template < typename BasicJsonType, class A1, class A2 >
+std::pair<A1, A2> from_json_tuple_impl(BasicJsonType&& j, identity_tag<std::pair<A1, A2>> /*unused*/, priority_tag<0> /*unused*/)
-    t = std::make_tuple(j.at(Idx).template get<typename std::tuple_element<Idx, Tuple>::type>()...);
+    return {std::forward<BasicJsonType>(j).at(0).template get<A1>(),
+            std::forward<BasicJsonType>(j).at(1).template get<A2>()};
+template<typename BasicJsonType, typename A1, typename A2>
+inline void from_json_tuple_impl(BasicJsonType&& j, std::pair<A1, A2>& p, priority_tag<1> /*unused*/)
+    p = from_json_tuple_impl(std::forward<BasicJsonType>(j), identity_tag<std::pair<A1, A2>> {}, priority_tag<0> {});
 template<typename BasicJsonType, typename... Args>
-void from_json(const BasicJsonType& j, std::tuple<Args...>& t)
+std::tuple<Args...> from_json_tuple_impl(BasicJsonType&& j, identity_tag<std::tuple<Args...>> /*unused*/, priority_tag<2> /*unused*/)
-    from_json_tuple_impl(j, t, index_sequence_for<Args...> {});
+    return from_json_tuple_impl_base<BasicJsonType, Args...>(std::forward<BasicJsonType>(j), index_sequence_for<Args...> {});
+template<typename BasicJsonType, typename... Args>
+inline void from_json_tuple_impl(BasicJsonType&& j, std::tuple<Args...>& t, priority_tag<3> /*unused*/)
+    t = from_json_tuple_impl_base<BasicJsonType, Args...>(std::forward<BasicJsonType>(j), index_sequence_for<Args...> {});
+template<typename BasicJsonType, typename TupleRelated>
+auto from_json(BasicJsonType&& j, TupleRelated&& t)
+-> decltype(from_json_tuple_impl(std::forward<BasicJsonType>(j), std::forward<TupleRelated>(t), priority_tag<3> {}))
+    return from_json_tuple_impl(std::forward<BasicJsonType>(j), std::forward<TupleRelated>(t), priority_tag<3> {});
 template < typename BasicJsonType, typename Key, typename Value, typename Compare, typename Allocator,
            typename = enable_if_t < !std::is_constructible <
                                         typename BasicJsonType::string_t, Key >::value >>
-void from_json(const BasicJsonType& j, std::map<Key, Value, Compare, Allocator>& m)
+inline void from_json(const BasicJsonType& j, std::map<Key, Value, Compare, Allocator>& m)
     m.clear();
     for (const auto& p : j)
         if (JSON_HEDLEY_UNLIKELY(!p.is_array()))
-            JSON_THROW(type_error::create(302, "type must be array, but is " + std::string(p.type_name())));
+            JSON_THROW(type_error::create(302, concat("type must be array, but is ", p.type_name()), &j));
         m.emplace(p.at(0).template get<Key>(), p.at(1).template get<Value>());
@@ -3850,45 +5066,72 @@ void from_json(const BasicJsonType& j, std::map<Key, Value, Compare, Allocator>&
 template < typename BasicJsonType, typename Key, typename Value, typename Hash, typename KeyEqual, typename Allocator,
-void from_json(const BasicJsonType& j, std::unordered_map<Key, Value, Hash, KeyEqual, Allocator>& m)
+inline void from_json(const BasicJsonType& j, std::unordered_map<Key, Value, Hash, KeyEqual, Allocator>& m)
     m.clear();
+#if JSON_HAS_FILESYSTEM || JSON_HAS_EXPERIMENTAL_FILESYSTEM
+inline void from_json(const BasicJsonType& j, std_fs::path& p)
+    if (JSON_HEDLEY_UNLIKELY(!j.is_string()))
+    p = *j.template get_ptr<const typename BasicJsonType::string_t*>();
+#endif
 struct from_json_fn
-    auto operator()(const BasicJsonType& j, T& val) const
-    noexcept(noexcept(from_json(j, val)))
-    -> decltype(from_json(j, val), void())
+    auto operator()(const BasicJsonType& j, T&& val) const
+    noexcept(noexcept(from_json(j, std::forward<T>(val))))
+    -> decltype(from_json(j, std::forward<T>(val)))
-        return from_json(j, val);
+        return from_json(j, std::forward<T>(val));
 /// namespace to hold default `from_json` function
 /// to see why this is required:
 /// http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2015/n4381.html
-namespace
+namespace // NOLINT(cert-dcl59-cpp,fuchsia-header-anon-namespaces,google-build-namespaces)
-constexpr const auto& from_json = detail::static_const<detail::from_json_fn>::value;
-} // namespace
+#endif
+JSON_INLINE_VARIABLE constexpr const auto& from_json = // NOLINT(misc-definitions-in-headers)
+    detail::static_const<detail::from_json_fn>::value;
+}  // namespace
+#endif
 // #include <nlohmann/detail/conversions/to_json.hpp>
 #include <algorithm> // copy
@@ -3901,22 +5144,37 @@ constexpr const auto& from_json = detail::static_const<detail::from_json_fn>::va
 // #include <nlohmann/detail/iterators/iteration_proxy.hpp>
 #include <iterator> // input_iterator_tag
 #include <string> // string, to_string
 #include <tuple> // tuple_size, get, tuple_element
+#include <utility> // move
+#if JSON_HAS_RANGES
+    #include <ranges> // enable_borrowed_range
+#endif
-namespace nlohmann
 namespace detail
 template<typename string_type>
 void int_to_string( string_type& target, std::size_t value )
@@ -3929,14 +5187,14 @@ template<typename IteratorType> class iteration_proxy_value
   public:
     using difference_type = std::ptrdiff_t;
     using value_type = iteration_proxy_value;
-    using pointer = value_type * ;
-    using reference = value_type & ;
+    using pointer = value_type *;
+    using reference = value_type &;
     using iterator_category = std::input_iterator_tag;
     using string_type = typename std::remove_cv< typename std::remove_reference<decltype( std::declval<IteratorType>().key() ) >::type >::type;
   private:
     /// the iterator
-    IteratorType anchor;
+    IteratorType anchor{};
     /// an index for arrays (used to create key names)
     std::size_t array_index = 0;
     /// last stringified array index
@@ -3944,13 +5202,30 @@ template<typename IteratorType> class iteration_proxy_value
     /// a string representation of the array index
     mutable string_type array_index_str = "0";
     /// an empty string (to return a reference for primitive values)
-    const string_type empty_str = "";
+    string_type empty_str{};
   public:
-    explicit iteration_proxy_value(IteratorType it) noexcept : anchor(it) {}
+    explicit iteration_proxy_value() = default;
+    explicit iteration_proxy_value(IteratorType it, std::size_t array_index_ = 0)
+    noexcept(std::is_nothrow_move_constructible<IteratorType>::value
+             && std::is_nothrow_default_constructible<string_type>::value)
+        : anchor(std::move(it))
+        , array_index(array_index_)
+    iteration_proxy_value(iteration_proxy_value const&) = default;
+    iteration_proxy_value& operator=(iteration_proxy_value const&) = default;
+    // older GCCs are a bit fussy and require explicit noexcept specifiers on defaulted functions
+    iteration_proxy_value(iteration_proxy_value&&)
+             && std::is_nothrow_move_constructible<string_type>::value) = default; // NOLINT(hicpp-noexcept-move,performance-noexcept-move-constructor,cppcoreguidelines-noexcept-move-operations)
+    iteration_proxy_value& operator=(iteration_proxy_value&&)
+    noexcept(std::is_nothrow_move_assignable<IteratorType>::value
+             && std::is_nothrow_move_assignable<string_type>::value) = default; // NOLINT(hicpp-noexcept-move,performance-noexcept-move-constructor,cppcoreguidelines-noexcept-move-operations)
+    ~iteration_proxy_value() = default;
     /// dereference operator (needed for range-based for)
-    iteration_proxy_value& operator*()
+    const iteration_proxy_value& operator*() const
         return *this;
@@ -3964,6 +5239,14 @@ template<typename IteratorType> class iteration_proxy_value
         return *this;
+    iteration_proxy_value operator++(int)& // NOLINT(cert-dcl21-cpp)
+        auto tmp = iteration_proxy_value(anchor, array_index);
+        ++anchor;
+        ++array_index;
+        return tmp;
     /// equality operator (needed for InputIterator)
     bool operator==(const iteration_proxy_value& o) const
@@ -3999,6 +5282,14 @@ template<typename IteratorType> class iteration_proxy_value
                 return anchor.key();
             // use an empty key for all primitive types
             default:
                 return empty_str;
@@ -4016,25 +5307,34 @@ template<typename IteratorType> class iteration_proxy
   private:
     /// the container to iterate
-    typename IteratorType::reference container;
+    typename IteratorType::pointer container = nullptr;
   public:
+    explicit iteration_proxy() = default;
     /// construct iteration proxy from a container
     explicit iteration_proxy(typename IteratorType::reference cont) noexcept
-        : container(cont) {}
+        : container(&cont) {}
+    iteration_proxy(iteration_proxy const&) = default;
+    iteration_proxy& operator=(iteration_proxy const&) = default;
+    iteration_proxy(iteration_proxy&&) noexcept = default;
+    iteration_proxy& operator=(iteration_proxy&&) noexcept = default;
+    ~iteration_proxy() = default;
     /// return iterator begin (needed for range-based for)
-    iteration_proxy_value<IteratorType> begin() noexcept
+    iteration_proxy_value<IteratorType> begin() const noexcept
-        return iteration_proxy_value<IteratorType>(container.begin());
+        return iteration_proxy_value<IteratorType>(container->begin());
     /// return iterator end (needed for range-based for)
-    iteration_proxy_value<IteratorType> end() noexcept
+    iteration_proxy_value<IteratorType> end() const noexcept
-        return iteration_proxy_value<IteratorType>(container.end());
+        return iteration_proxy_value<IteratorType>(container->end());
 // Structured Bindings Support
 // For further reference see https://blog.tartanllama.xyz/structured-bindings/
 // And see https://github.com/nlohmann/json/pull/1391
@@ -4051,8 +5351,9 @@ auto get(const nlohmann::detail::iteration_proxy_value<IteratorType>& i) -> decl
     return i.value();
 // The Addition to the STD Namespace is required to add
 // Structured Bindings Support to the iteration_proxy_value class
@@ -4060,17 +5361,18 @@ auto get(const nlohmann::detail::iteration_proxy_value<IteratorType>& i) -> decl
 namespace std
 #if defined(__clang__)
     // Fix: https://github.com/nlohmann/json/issues/1401
     #pragma clang diagnostic push
     #pragma clang diagnostic ignored "-Wmismatched-tags"
 #endif
-class tuple_size<::nlohmann::detail::iteration_proxy_value<IteratorType>>
+class tuple_size<::nlohmann::detail::iteration_proxy_value<IteratorType>> // NOLINT(cert-dcl58-cpp)
             : public std::integral_constant<std::size_t, 2> {};
 template<std::size_t N, typename IteratorType>
-class tuple_element<N, ::nlohmann::detail::iteration_proxy_value<IteratorType >>
+class tuple_element<N, ::nlohmann::detail::iteration_proxy_value<IteratorType >> // NOLINT(cert-dcl58-cpp)
   public:
     using type = decltype(
@@ -4080,23 +5382,40 @@ class tuple_element<N, ::nlohmann::detail::iteration_proxy_value<IteratorType >>
     #pragma clang diagnostic pop
 #endif
-} // namespace std
+}  // namespace std
+    template <typename IteratorType>
+    inline constexpr bool ::std::ranges::enable_borrowed_range<::nlohmann::detail::iteration_proxy<IteratorType>> = true;
+#endif
-namespace nlohmann
 namespace detail
 // constructors //
+ * Note all external_constructor<>::construct functions need to call
+ * j.m_data.m_value.destroy(j.m_data.m_type) to avoid a memory leak in case j contains an
+ * allocated value (e.g., a string). See bug issue
+ * https://github.com/nlohmann/json/issues/2865 for more information.
 template<value_t> struct external_constructor;
 template<>
@@ -4105,8 +5424,9 @@ struct external_constructor<value_t::boolean>
     static void construct(BasicJsonType& j, typename BasicJsonType::boolean_t b) noexcept
-        j.m_type = value_t::boolean;
-        j.m_value = b;
+        j.m_data.m_value.destroy(j.m_data.m_type);
+        j.m_data.m_type = value_t::boolean;
+        j.m_data.m_value = b;
         j.assert_invariant();
@@ -4117,16 +5437,18 @@ struct external_constructor<value_t::string>
     static void construct(BasicJsonType& j, const typename BasicJsonType::string_t& s)
-        j.m_type = value_t::string;
-        j.m_value = s;
+        j.m_data.m_type = value_t::string;
+        j.m_data.m_value = s;
     static void construct(BasicJsonType& j, typename BasicJsonType::string_t&& s)
-        j.m_value = std::move(s);
+        j.m_data.m_value = std::move(s);
@@ -4135,8 +5457,9 @@ struct external_constructor<value_t::string>
                              int > = 0 >
     static void construct(BasicJsonType& j, const CompatibleStringType& str)
-        j.m_value.string = j.template create<typename BasicJsonType::string_t>(str);
+        j.m_data.m_value.string = j.template create<typename BasicJsonType::string_t>(str);
@@ -4147,18 +5470,18 @@ struct external_constructor<value_t::binary>
     static void construct(BasicJsonType& j, const typename BasicJsonType::binary_t& b)
-        j.m_type = value_t::binary;
-        typename BasicJsonType::binary_t value{b};
-        j.m_value = value;
+        j.m_data.m_type = value_t::binary;
+        j.m_data.m_value = typename BasicJsonType::binary_t(b);
     static void construct(BasicJsonType& j, typename BasicJsonType::binary_t&& b)
-        typename BasicJsonType::binary_t value{std::move(b)};
+        j.m_data.m_value = typename BasicJsonType::binary_t(std::move(b));
@@ -4169,8 +5492,9 @@ struct external_constructor<value_t::number_float>
     static void construct(BasicJsonType& j, typename BasicJsonType::number_float_t val) noexcept
-        j.m_type = value_t::number_float;
-        j.m_value = val;
+        j.m_data.m_type = value_t::number_float;
+        j.m_data.m_value = val;
@@ -4181,8 +5505,9 @@ struct external_constructor<value_t::number_unsigned>
     static void construct(BasicJsonType& j, typename BasicJsonType::number_unsigned_t val) noexcept
-        j.m_type = value_t::number_unsigned;
-        j.m_value = val;
+        j.m_data.m_type = value_t::number_unsigned;
@@ -4193,8 +5518,9 @@ struct external_constructor<value_t::number_integer>
     static void construct(BasicJsonType& j, typename BasicJsonType::number_integer_t val) noexcept
-        j.m_type = value_t::number_integer;
-        j.m_value = val;
+        j.m_data.m_type = value_t::number_integer;
@@ -4205,16 +5531,20 @@ struct external_constructor<value_t::array>
     static void construct(BasicJsonType& j, const typename BasicJsonType::array_t& arr)
-        j.m_type = value_t::array;
-        j.m_value = arr;
+        j.m_data.m_type = value_t::array;
+        j.m_data.m_value = arr;
+        j.set_parents();
     static void construct(BasicJsonType& j, typename BasicJsonType::array_t&& arr)
-        j.m_value = std::move(arr);
+        j.m_data.m_value = std::move(arr);
+        j.set_parents();
@@ -4225,20 +5555,25 @@ struct external_constructor<value_t::array>
         using std::begin;
         using std::end;
-        j.m_value.array = j.template create<typename BasicJsonType::array_t>(begin(arr), end(arr));
+        j.m_data.m_value.array = j.template create<typename BasicJsonType::array_t>(begin(arr), end(arr));
+        j.set_parents();
     static void construct(BasicJsonType& j, const std::vector<bool>& arr)
-        j.m_value = value_t::array;
-        j.m_value.array->reserve(arr.size());
+        j.m_data.m_value = value_t::array;
+        j.m_data.m_value.array->reserve(arr.size());
         for (const bool x : arr)
-            j.m_value.array->push_back(x);
+            j.m_data.m_value.array->push_back(x);
+            j.set_parent(j.m_data.m_value.array->back());
@@ -4247,13 +5582,15 @@ struct external_constructor<value_t::array>
              enable_if_t<std::is_convertible<T, BasicJsonType>::value, int> = 0>
     static void construct(BasicJsonType& j, const std::valarray<T>& arr)
-        j.m_value.array->resize(arr.size());
+        j.m_data.m_value.array->resize(arr.size());
         if (arr.size() > 0)
-            std::copy(std::begin(arr), std::end(arr), j.m_value.array->begin());
+            std::copy(std::begin(arr), std::end(arr), j.m_data.m_value.array->begin());
+        j.set_parents();
@@ -4264,16 +5601,20 @@ struct external_constructor<value_t::object>
     static void construct(BasicJsonType& j, const typename BasicJsonType::object_t& obj)
-        j.m_type = value_t::object;
-        j.m_value = obj;
+        j.m_data.m_type = value_t::object;
+        j.m_data.m_value = obj;
+        j.set_parents();
     static void construct(BasicJsonType& j, typename BasicJsonType::object_t&& obj)
-        j.m_value = std::move(obj);
+        j.m_data.m_value = std::move(obj);
+        j.set_parents();
@@ -4284,8 +5625,10 @@ struct external_constructor<value_t::object>
         using std::begin;
         using std::end;
-        j.m_value.object = j.template create<typename BasicJsonType::object_t>(begin(obj), end(obj));
+        j.m_data.m_value.object = j.template create<typename BasicJsonType::object_t>(begin(obj), end(obj));
+        j.set_parents();
@@ -4296,55 +5639,70 @@ struct external_constructor<value_t::object>
          enable_if_t<std::is_same<T, typename BasicJsonType::boolean_t>::value, int> = 0>
-void to_json(BasicJsonType& j, T b) noexcept
+inline void to_json(BasicJsonType& j, T b) noexcept
     external_constructor<value_t::boolean>::construct(j, b);
+template < typename BasicJsonType, typename BoolRef,
+           enable_if_t <
+               ((std::is_same<std::vector<bool>::reference, BoolRef>::value
+                 && !std::is_same <std::vector<bool>::reference, typename BasicJsonType::boolean_t&>::value)
+                || (std::is_same<std::vector<bool>::const_reference, BoolRef>::value
+                    && !std::is_same <detail::uncvref_t<std::vector<bool>::const_reference>,
+                                      typename BasicJsonType::boolean_t >::value))
+               && std::is_convertible<const BoolRef&, typename BasicJsonType::boolean_t>::value, int > = 0 >
+inline void to_json(BasicJsonType& j, const BoolRef& b) noexcept
+    external_constructor<value_t::boolean>::construct(j, static_cast<typename BasicJsonType::boolean_t>(b));
 template<typename BasicJsonType, typename CompatibleString,
          enable_if_t<std::is_constructible<typename BasicJsonType::string_t, CompatibleString>::value, int> = 0>
-void to_json(BasicJsonType& j, const CompatibleString& s)
+inline void to_json(BasicJsonType& j, const CompatibleString& s)
     external_constructor<value_t::string>::construct(j, s);
-void to_json(BasicJsonType& j, typename BasicJsonType::string_t&& s)
+inline void to_json(BasicJsonType& j, typename BasicJsonType::string_t&& s)
     external_constructor<value_t::string>::construct(j, std::move(s));
 template<typename BasicJsonType, typename FloatType,
          enable_if_t<std::is_floating_point<FloatType>::value, int> = 0>
-void to_json(BasicJsonType& j, FloatType val) noexcept
+inline void to_json(BasicJsonType& j, FloatType val) noexcept
     external_constructor<value_t::number_float>::construct(j, static_cast<typename BasicJsonType::number_float_t>(val));
 template<typename BasicJsonType, typename CompatibleNumberUnsignedType,
          enable_if_t<is_compatible_integer_type<typename BasicJsonType::number_unsigned_t, CompatibleNumberUnsignedType>::value, int> = 0>
-void to_json(BasicJsonType& j, CompatibleNumberUnsignedType val) noexcept
+inline void to_json(BasicJsonType& j, CompatibleNumberUnsignedType val) noexcept
     external_constructor<value_t::number_unsigned>::construct(j, static_cast<typename BasicJsonType::number_unsigned_t>(val));
 template<typename BasicJsonType, typename CompatibleNumberIntegerType,
          enable_if_t<is_compatible_integer_type<typename BasicJsonType::number_integer_t, CompatibleNumberIntegerType>::value, int> = 0>
-void to_json(BasicJsonType& j, CompatibleNumberIntegerType val) noexcept
+inline void to_json(BasicJsonType& j, CompatibleNumberIntegerType val) noexcept
     external_constructor<value_t::number_integer>::construct(j, static_cast<typename BasicJsonType::number_integer_t>(val));
-void to_json(BasicJsonType& j, EnumType e) noexcept
+inline void to_json(BasicJsonType& j, EnumType e) noexcept
     using underlying_type = typename std::underlying_type<EnumType>::type;
     external_constructor<value_t::number_integer>::construct(j, static_cast<underlying_type>(e));
-void to_json(BasicJsonType& j, const std::vector<bool>& e)
+inline void to_json(BasicJsonType& j, const std::vector<bool>& e)
     external_constructor<value_t::array>::construct(j, e);
@@ -4357,39 +5715,39 @@ template < typename BasicJsonType, typename CompatibleArrayType,
                          !std::is_same<typename BasicJsonType::binary_t, CompatibleArrayType>::value&&
                          !is_basic_json<CompatibleArrayType>::value,
                          int > = 0 >
-void to_json(BasicJsonType& j, const CompatibleArrayType& arr)
+inline void to_json(BasicJsonType& j, const CompatibleArrayType& arr)
     external_constructor<value_t::array>::construct(j, arr);
-void to_json(BasicJsonType& j, const typename BasicJsonType::binary_t& bin)
+inline void to_json(BasicJsonType& j, const typename BasicJsonType::binary_t& bin)
     external_constructor<value_t::binary>::construct(j, bin);
-void to_json(BasicJsonType& j, const std::valarray<T>& arr)
+inline void to_json(BasicJsonType& j, const std::valarray<T>& arr)
     external_constructor<value_t::array>::construct(j, std::move(arr));
-void to_json(BasicJsonType& j, typename BasicJsonType::array_t&& arr)
+inline void to_json(BasicJsonType& j, typename BasicJsonType::array_t&& arr)
 template < typename BasicJsonType, typename CompatibleObjectType,
            enable_if_t < is_compatible_object_type<BasicJsonType, CompatibleObjectType>::value&& !is_basic_json<CompatibleObjectType>::value, int > = 0 >
-void to_json(BasicJsonType& j, const CompatibleObjectType& obj)
+inline void to_json(BasicJsonType& j, const CompatibleObjectType& obj)
     external_constructor<value_t::object>::construct(j, obj);
-void to_json(BasicJsonType& j, typename BasicJsonType::object_t&& obj)
+inline void to_json(BasicJsonType& j, typename BasicJsonType::object_t&& obj)
     external_constructor<value_t::object>::construct(j, std::move(obj));
@@ -4397,15 +5755,15 @@ void to_json(BasicJsonType& j, typename BasicJsonType::object_t&& obj)
 template <
     typename BasicJsonType, typename T, std::size_t N,
     enable_if_t < !std::is_constructible<typename BasicJsonType::string_t,
-                  const T(&)[N]>::value,
+                  const T(&)[N]>::value, // NOLINT(cppcoreguidelines-avoid-c-arrays,hicpp-avoid-c-arrays,modernize-avoid-c-arrays)
                   int > = 0 >
-void to_json(BasicJsonType& j, const T(&arr)[N])
+inline void to_json(BasicJsonType& j, const T(&arr)[N]) // NOLINT(cppcoreguidelines-avoid-c-arrays,hicpp-avoid-c-arrays,modernize-avoid-c-arrays)
 template < typename BasicJsonType, typename T1, typename T2, enable_if_t < std::is_constructible<BasicJsonType, T1>::value&& std::is_constructible<BasicJsonType, T2>::value, int > = 0 >
-void to_json(BasicJsonType& j, const std::pair<T1, T2>& p)
+inline void to_json(BasicJsonType& j, const std::pair<T1, T2>& p)
     j = { p.first, p.second };
@@ -4413,23 +5771,31 @@ void to_json(BasicJsonType& j, const std::pair<T1, T2>& p)
 // for https://github.com/nlohmann/json/pull/1134
          enable_if_t<std::is_same<T, iteration_proxy_value<typename BasicJsonType::iterator>>::value, int> = 0>
-void to_json(BasicJsonType& j, const T& b)
+inline void to_json(BasicJsonType& j, const T& b)
     j = { {b.key(), b.value()} };
-void to_json_tuple_impl(BasicJsonType& j, const Tuple& t, index_sequence<Idx...> /*unused*/)
+inline void to_json_tuple_impl(BasicJsonType& j, const Tuple& t, index_sequence<Idx...> /*unused*/)
     j = { std::get<Idx>(t)... };
 template<typename BasicJsonType, typename T, enable_if_t<is_constructible_tuple<BasicJsonType, T>::value, int > = 0>
-void to_json(BasicJsonType& j, const T& t)
+inline void to_json(BasicJsonType& j, const T& t)
     to_json_tuple_impl(j, t, make_index_sequence<std::tuple_size<T>::value> {});
+template<typename BasicJsonType>
+inline void to_json(BasicJsonType& j, const std_fs::path& p)
+    j = p.string();
+#endif
 struct to_json_fn
@@ -4441,106 +5807,116 @@ struct to_json_fn
+#ifndef JSON_HAS_CPP_17
 /// namespace to hold default `to_json` function
-namespace
+/// to see why this is required:
+/// http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2015/n4381.html
-constexpr const auto& to_json = detail::static_const<detail::to_json_fn>::value;
-} // namespace
-} // namespace nlohmann
+#endif
+JSON_INLINE_VARIABLE constexpr const auto& to_json = // NOLINT(misc-definitions-in-headers)
+    detail::static_const<detail::to_json_fn>::value;
+}  // namespace
+#endif
-namespace nlohmann
+NLOHMANN_JSON_NAMESPACE_BEGIN
-template<typename, typename>
+/// @sa https://json.nlohmann.me/api/adl_serializer/
+template<typename ValueType, typename>
 struct adl_serializer
-    @brief convert a JSON value to any value type
-    This function is usually called by the `get()` function of the
-    @ref basic_json class (either explicit or via conversion operators).
-    @param[in] j        JSON value to read from
-    @param[in,out] val  value to write to
-    template<typename BasicJsonType, typename ValueType>
-    static auto from_json(BasicJsonType&& j, ValueType& val) noexcept(
+    /// @brief convert a JSON value to any value type
+    /// @sa https://json.nlohmann.me/api/adl_serializer/from_json/
+    template<typename BasicJsonType, typename TargetType = ValueType>
+    static auto from_json(BasicJsonType && j, TargetType& val) noexcept(
         noexcept(::nlohmann::from_json(std::forward<BasicJsonType>(j), val)))
     -> decltype(::nlohmann::from_json(std::forward<BasicJsonType>(j), val), void())
         ::nlohmann::from_json(std::forward<BasicJsonType>(j), val);
-    @brief convert any value type to a JSON value
-    This function is usually called by the constructors of the @ref basic_json
-    class.
-    @param[in,out] j  JSON value to write to
-    @param[in] val    value to read from
-    static auto to_json(BasicJsonType& j, ValueType&& val) noexcept(
-        noexcept(::nlohmann::to_json(j, std::forward<ValueType>(val))))
-    -> decltype(::nlohmann::to_json(j, std::forward<ValueType>(val)), void())
+    static auto from_json(BasicJsonType && j) noexcept(
+    noexcept(::nlohmann::from_json(std::forward<BasicJsonType>(j), detail::identity_tag<TargetType> {})))
+    -> decltype(::nlohmann::from_json(std::forward<BasicJsonType>(j), detail::identity_tag<TargetType> {}))
-        ::nlohmann::to_json(j, std::forward<ValueType>(val));
+        return ::nlohmann::from_json(std::forward<BasicJsonType>(j), detail::identity_tag<TargetType> {});
+    /// @brief convert any value type to a JSON value
+    /// @sa https://json.nlohmann.me/api/adl_serializer/to_json/
+    static auto to_json(BasicJsonType& j, TargetType && val) noexcept(
+        noexcept(::nlohmann::to_json(j, std::forward<TargetType>(val))))
+    -> decltype(::nlohmann::to_json(j, std::forward<TargetType>(val)), void())
+        ::nlohmann::to_json(j, std::forward<TargetType>(val));
 // #include <nlohmann/byte_container_with_subtype.hpp>
+//     __ _____ _____ _____
+//  __|  |   __|     |   | |  JSON for Modern C++
+// |  |  |__   |  |  | | | |  version 3.11.3
+// |_____|_____|_____|_|___|  https://github.com/nlohmann/json
+// SPDX-FileCopyrightText: 2013-2023 Niels Lohmann <https://nlohmann.me>
+// SPDX-License-Identifier: MIT
+#include <cstdint> // uint8_t, uint64_t
 #include <tuple> // tie
-namespace nlohmann
- at brief an internal type for a backed binary type
-This type extends the template parameter @a BinaryType provided to `basic_json`
-with a subtype used by BSON and MessagePack. This type exists so that the user
-does not have to specify a type themselves with a specific naming scheme in
-order to override the binary type.
- at tparam BinaryType container to store bytes (`std::vector<std::uint8_t>` by
-                   default)
- at since version 3.8.0
+/// @brief an internal type for a backed binary type
+/// @sa https://json.nlohmann.me/api/byte_container_with_subtype/
 template<typename BinaryType>
 class byte_container_with_subtype : public BinaryType
   public:
-    /// the type of the underlying container
     using container_type = BinaryType;
+    using subtype_type = std::uint64_t;
+    /// @sa https://json.nlohmann.me/api/byte_container_with_subtype/byte_container_with_subtype/
     byte_container_with_subtype() noexcept(noexcept(container_type()))
         : container_type()
     byte_container_with_subtype(const container_type& b) noexcept(noexcept(container_type(b)))
         : container_type(b)
     byte_container_with_subtype(container_type&& b) noexcept(noexcept(container_type(std::move(b))))
         : container_type(std::move(b))
-    byte_container_with_subtype(const container_type& b, std::uint8_t subtype_) noexcept(noexcept(container_type(b)))
+    byte_container_with_subtype(const container_type& b, subtype_type subtype_) noexcept(noexcept(container_type(b)))
         : container_type(b)
         , m_subtype(subtype_)
         , m_has_subtype(true)
-    byte_container_with_subtype(container_type&& b, std::uint8_t subtype_) noexcept(noexcept(container_type(std::move(b))))
+    byte_container_with_subtype(container_type&& b, subtype_type subtype_) noexcept(noexcept(container_type(std::move(b))))
@@ -4557,96 +5933,30 @@ class byte_container_with_subtype : public BinaryType
         return !(rhs == *this);
-    @brief sets the binary subtype
-    Sets the binary subtype of the value, also flags a binary JSON value as
-    having a subtype, which has implications for serialization.
-    @complexity Constant.
-    @exceptionsafety No-throw guarantee: this member function never throws
-    exceptions.
-    @sa @ref subtype() -- return the binary subtype
-    @sa @ref clear_subtype() -- clears the binary subtype
-    @sa @ref has_subtype() -- returns whether or not the binary value has a
-    subtype
-    @since version 3.8.0
-    void set_subtype(std::uint8_t subtype_) noexcept
+    /// @brief sets the binary subtype
+    /// @sa https://json.nlohmann.me/api/byte_container_with_subtype/set_subtype/
+    void set_subtype(subtype_type subtype_) noexcept
         m_subtype = subtype_;
         m_has_subtype = true;
-    @brief return the binary subtype
-    Returns the numerical subtype of the value if it has a subtype. If it does
-    not have a subtype, this function will return size_t(-1) as a sentinel
-    value.
-    @return the numerical subtype of the binary value
-    exceptions.
-    @sa @ref set_subtype() -- sets the binary subtype
-    subtype
-    constexpr std::uint8_t subtype() const noexcept
+    /// @brief return the binary subtype
+    /// @sa https://json.nlohmann.me/api/byte_container_with_subtype/subtype/
+    constexpr subtype_type subtype() const noexcept
-        return m_subtype;
+        return m_has_subtype ? m_subtype : static_cast<subtype_type>(-1);
-    @brief return whether the value has a subtype
-    @return whether the value has a subtype
-    exceptions.
+    /// @brief return whether the value has a subtype
+    /// @sa https://json.nlohmann.me/api/byte_container_with_subtype/has_subtype/
     constexpr bool has_subtype() const noexcept
         return m_has_subtype;
-    @brief clears the binary subtype
-    Clears the binary subtype and flags the value as not having a subtype, which
-    has implications for serialization; for instance MessagePack will prefer the
-    bin family over the ext family.
-    exceptions.
-    subtype
+    /// @brief clears the binary subtype
+    /// @sa https://json.nlohmann.me/api/byte_container_with_subtype/clear_subtype/
     void clear_subtype() noexcept
         m_subtype = 0;
@@ -4654,11 +5964,11 @@ class byte_container_with_subtype : public BinaryType
   private:
-    std::uint8_t m_subtype = 0;
+    subtype_type m_subtype = 0;
     bool m_has_subtype = false;
 // #include <nlohmann/detail/conversions/from_json.hpp>
@@ -4667,16 +5977,26 @@ class byte_container_with_subtype : public BinaryType
 // #include <nlohmann/detail/exceptions.hpp>
 // #include <nlohmann/detail/hash.hpp>
-#include <cstddef> // size_t, uint8_t
+#include <cstddef> // size_t
 #include <functional> // hash
-// #include <nlohmann/detail/macro_scope.hpp>
+// #include <nlohmann/detail/value_t.hpp>
-namespace nlohmann
 namespace detail
@@ -4772,7 +6092,7 @@ std::size_t hash(const BasicJsonType& j)
             auto seed = combine(type, j.get_binary().size());
             const auto h = std::hash<bool> {}(j.get_binary().has_subtype());
             seed = combine(seed, h);
-            seed = combine(seed, j.get_binary().subtype());
+            seed = combine(seed, static_cast<std::size_t>(j.get_binary().subtype()));
             for (const auto byte : j.get_binary())
                 seed = combine(seed, std::hash<std::uint8_t> {}(byte));
@@ -4781,15 +6101,23 @@ std::size_t hash(const BasicJsonType& j)
-            JSON_ASSERT(false);    // LCOV_EXCL_LINE
+            JSON_ASSERT(false); // NOLINT(cert-dcl03-c,hicpp-static-assert,misc-static-assert) LCOV_EXCL_LINE
             return 0;              // LCOV_EXCL_LINE
 // #include <nlohmann/detail/input/binary_reader.hpp>
 #include <algorithm> // generate_n
@@ -4808,13 +6136,19 @@ std::size_t hash(const BasicJsonType& j)
 // #include <nlohmann/detail/input/input_adapters.hpp>
-#include <cstdio> //FILE *
-#include <istream> // istream
 #include <iterator> // begin, end, iterator_traits, random_access_iterator_tag, distance, next
 #include <memory> // shared_ptr, make_shared, addressof
 #include <numeric> // accumulate
@@ -4822,22 +6156,30 @@ std::size_t hash(const BasicJsonType& j)
 #include <type_traits> // enable_if, is_base_of, is_pointer, is_integral, remove_pointer
 #include <utility> // pair, declval
+#ifndef JSON_NO_IO
+    #include <cstdio>   // FILE *
+    #include <istream>  // istream
+#endif                  // JSON_NO_IO
 // #include <nlohmann/detail/iterators/iterator_traits.hpp>
-namespace nlohmann
 namespace detail
 /// the supported input formats
-enum class input_format_t { json, cbor, msgpack, ubjson, bson };
+enum class input_format_t { json, cbor, msgpack, ubjson, bson, bjdata };
 // input adapters //
+#ifndef JSON_NO_IO
 Input adapter for stdio file access. This adapter read only 1 byte and do not use any
  buffer. This adapter is a very low level adapter.
@@ -4850,13 +6192,16 @@ class file_input_adapter
     JSON_HEDLEY_NON_NULL(2)
     explicit file_input_adapter(std::FILE* f) noexcept
         : m_file(f)
+        JSON_ASSERT(m_file != nullptr);
     // make class move-only
     file_input_adapter(const file_input_adapter&) = delete;
-    file_input_adapter(file_input_adapter&&) = default;
+    file_input_adapter(file_input_adapter&&) noexcept = default;
     file_input_adapter& operator=(const file_input_adapter&) = delete;
     file_input_adapter& operator=(file_input_adapter&&) = delete;
+    ~file_input_adapter() = default;
     std::char_traits<char>::int_type get_character() noexcept
@@ -4868,7 +6213,6 @@ class file_input_adapter
     std::FILE* m_file;
 Input adapter for a (caching) istream. Ignores a UFT Byte Order Mark at
 beginning of input. Does not support changing the underlying std::streambuf
@@ -4900,9 +6244,10 @@ class input_stream_adapter
     // delete because of pointer members
     input_stream_adapter(const input_stream_adapter&) = delete;
     input_stream_adapter& operator=(input_stream_adapter&) = delete;
-    input_stream_adapter& operator=(input_stream_adapter&& rhs) = delete;
+    input_stream_adapter& operator=(input_stream_adapter&&) = delete;
-    input_stream_adapter(input_stream_adapter&& rhs) noexcept : is(rhs.is), sb(rhs.sb)
+    input_stream_adapter(input_stream_adapter&& rhs) noexcept
+        : is(rhs.is), sb(rhs.sb)
         rhs.is = nullptr;
         rhs.sb = nullptr;
@@ -4910,12 +6255,12 @@ class input_stream_adapter
     // std::istream/std::streambuf use std::char_traits<char>::to_int_type, to
     // ensure that std::char_traits<char>::eof() and the character 0xFF do not
-    // end up as the same value, eg. 0xFFFFFFFF.
+    // end up as the same value, e.g. 0xFFFFFFFF.
         auto res = sb->sbumpc();
         // set eof manually, as we don't use the istream interface.
-        if (JSON_HEDLEY_UNLIKELY(res == EOF))
+        if (JSON_HEDLEY_UNLIKELY(res == std::char_traits<char>::eof()))
             is->clear(is->rdstate() | std::ios::eofbit);
@@ -4927,6 +6272,7 @@ class input_stream_adapter
     std::istream* is = nullptr;
     std::streambuf* sb = nullptr;
 // General-purpose iterator-based adapter. It might not be as fast as
 // theoretically possible for some containers, but it is extremely versatile.
@@ -4937,20 +6283,19 @@ class iterator_input_adapter
     using char_type = typename std::iterator_traits<IteratorType>::value_type;
     iterator_input_adapter(IteratorType first, IteratorType last)
-        : current(std::move(first)), end(std::move(last)) {}
+        : current(std::move(first)), end(std::move(last))
-    typename std::char_traits<char_type>::int_type get_character()
+    typename char_traits<char_type>::int_type get_character()
         if (JSON_HEDLEY_LIKELY(current != end))
-            auto result = std::char_traits<char_type>::to_int_type(*current);
+            auto result = char_traits<char_type>::to_int_type(*current);
             std::advance(current, 1);
             return result;
-        else
-            return std::char_traits<char_type>::eof();
+        return char_traits<char_type>::eof();
   private:
@@ -4964,10 +6309,8 @@ class iterator_input_adapter
         return current == end;
 template<typename BaseInputAdapter, size_t T>
 struct wide_string_input_helper;
@@ -5136,7 +6479,6 @@ class wide_string_input_adapter
     std::size_t utf8_bytes_filled = 0;
 template<typename IteratorType, typename Enable = void>
 struct iterator_input_adapter_factory
@@ -5207,7 +6549,7 @@ struct container_input_adapter_factory< ContainerType,
+}  // namespace container_input_adapter_factory_impl
 template<typename ContainerType>
 typename container_input_adapter_factory_impl::container_input_adapter_factory<ContainerType>::adapter_type input_adapter(const ContainerType& container)
@@ -5215,6 +6557,7 @@ typename container_input_adapter_factory_impl::container_input_adapter_factory<C
     return container_input_adapter_factory_impl::container_input_adapter_factory<ContainerType>::create(container);
+#ifndef JSON_NO_IO
 // Special cases with fast paths
 inline file_input_adapter input_adapter(std::FILE* file)
@@ -5230,6 +6573,7 @@ inline input_stream_adapter input_adapter(std::istream&& stream)
     return input_stream_adapter(stream);
 using contiguous_bytes_input_adapter = decltype(input_adapter(std::declval<const char*>(), std::declval<const char*>()));
@@ -5249,13 +6593,13 @@ contiguous_bytes_input_adapter input_adapter(CharT b)
 template<typename T, std::size_t N>
-auto input_adapter(T (&array)[N]) -> decltype(input_adapter(array, array + N))
+auto input_adapter(T (&array)[N]) -> decltype(input_adapter(array, array + N)) // NOLINT(cppcoreguidelines-avoid-c-arrays,hicpp-avoid-c-arrays,modernize-avoid-c-arrays)
     return input_adapter(array, array + N);
 // This class only handles inputs of input_buffer_adapter type.
-// It's required so that expressions like {ptr, len} can be implicitly casted
+// It's required so that expressions like {ptr, len} can be implicitly cast
 // to the correct adapter.
 class span_input_adapter
@@ -5278,16 +6622,25 @@ class span_input_adapter
     contiguous_bytes_input_adapter&& get()
-        return std::move(ia);
+        return std::move(ia); // NOLINT(hicpp-move-const-arg,performance-move-const-arg)
   private:
     contiguous_bytes_input_adapter ia;
 // #include <nlohmann/detail/input/json_sax.hpp>
 #include <cstddef>
@@ -5299,9 +6652,10 @@ class span_input_adapter
-namespace nlohmann
 @brief SAX interface
@@ -5348,7 +6702,7 @@ struct json_sax
     virtual bool number_unsigned(number_unsigned_t val) = 0;
-    @brief an floating-point number was read
+    @brief a floating-point number was read
     @param[in] val  floating-point value
     @param[in] s    raw token value
     @return whether parsing should proceed
@@ -5356,18 +6710,18 @@ struct json_sax
     virtual bool number_float(number_float_t val, const string_t& s) = 0;
-    @brief a string was read
+    @brief a string value was read
     @param[in] val  string value
-    @note It is safe to move the passed string.
+    @note It is safe to move the passed string value.
     virtual bool string(string_t& val) = 0;
-    @brief a binary string was read
+    @brief a binary value was read
     @param[in] val  binary value
-    @note It is safe to move the passed binary.
+    @note It is safe to move the passed binary value.
     virtual bool binary(binary_t& val) = 0;
@@ -5418,10 +6772,14 @@ struct json_sax
                              const std::string& last_token,
                              const detail::exception& ex) = 0;
+    json_sax() = default;
+    json_sax(const json_sax&) = default;
+    json_sax(json_sax&&) noexcept = default;
+    json_sax& operator=(const json_sax&) = default;
+    json_sax& operator=(json_sax&&) noexcept = default;
     virtual ~json_sax() = default;
 namespace detail
@@ -5448,7 +6806,7 @@ class json_sax_dom_parser
     using binary_t = typename BasicJsonType::binary_t;
-    @param[in, out] r  reference to a JSON value that is manipulated while
+    @param[in,out] r  reference to a JSON value that is manipulated while
                        parsing
     @param[in] allow_exceptions_  whether parse errors yield exceptions
@@ -5458,9 +6816,9 @@ class json_sax_dom_parser
     json_sax_dom_parser(const json_sax_dom_parser&) = delete;
-    json_sax_dom_parser(json_sax_dom_parser&&) = default;
+    json_sax_dom_parser(json_sax_dom_parser&&) = default; // NOLINT(hicpp-noexcept-move,performance-noexcept-move-constructor)
     json_sax_dom_parser& operator=(const json_sax_dom_parser&) = delete;
-    json_sax_dom_parser& operator=(json_sax_dom_parser&&) = default;
+    json_sax_dom_parser& operator=(json_sax_dom_parser&&) = default; // NOLINT(hicpp-noexcept-move,performance-noexcept-move-constructor)
     ~json_sax_dom_parser() = default;
     bool null()
@@ -5509,10 +6867,9 @@ class json_sax_dom_parser
         ref_stack.push_back(handle_value(BasicJsonType::value_t::object));
-        if (JSON_HEDLEY_UNLIKELY(len != std::size_t(-1) && len > ref_stack.back()->max_size()))
+        if (JSON_HEDLEY_UNLIKELY(len != static_cast<std::size_t>(-1) && len > ref_stack.back()->max_size()))
-            JSON_THROW(out_of_range::create(408,
-                                            "excessive object size: " + std::to_string(len)));
+            JSON_THROW(out_of_range::create(408, concat("excessive object size: ", std::to_string(len)), ref_stack.back()));
         return true;
@@ -5520,13 +6877,20 @@ class json_sax_dom_parser
     bool key(string_t& val)
+        JSON_ASSERT(!ref_stack.empty());
+        JSON_ASSERT(ref_stack.back()->is_object());
         // add null at given key and store the reference for later
-        object_element = &(ref_stack.back()->m_value.object->operator[](val));
+        object_element = &(ref_stack.back()->m_data.m_value.object->operator[](val));
         return true;
     bool end_object()
+        ref_stack.back()->set_parents();
         ref_stack.pop_back();
         return true;
@@ -5535,10 +6899,9 @@ class json_sax_dom_parser
         ref_stack.push_back(handle_value(BasicJsonType::value_t::array));
-                                            "excessive array size: " + std::to_string(len)));
+            JSON_THROW(out_of_range::create(408, concat("excessive array size: ", std::to_string(len)), ref_stack.back()));
         return true;
@@ -5546,6 +6909,10 @@ class json_sax_dom_parser
     bool end_array()
+        JSON_ASSERT(ref_stack.back()->is_array());
         return true;
@@ -5589,8 +6956,8 @@ class json_sax_dom_parser
         if (ref_stack.back()->is_array())
-            ref_stack.back()->m_value.array->emplace_back(std::forward<Value>(v));
-            return &(ref_stack.back()->m_value.array->back());
+            ref_stack.back()->m_data.m_value.array->emplace_back(std::forward<Value>(v));
+            return &(ref_stack.back()->m_data.m_value.array->back());
@@ -5633,9 +7000,9 @@ class json_sax_dom_callback_parser
     json_sax_dom_callback_parser(const json_sax_dom_callback_parser&) = delete;
-    json_sax_dom_callback_parser(json_sax_dom_callback_parser&&) = default;
+    json_sax_dom_callback_parser(json_sax_dom_callback_parser&&) = default; // NOLINT(hicpp-noexcept-move,performance-noexcept-move-constructor)
     json_sax_dom_callback_parser& operator=(const json_sax_dom_callback_parser&) = delete;
-    json_sax_dom_callback_parser& operator=(json_sax_dom_callback_parser&&) = default;
+    json_sax_dom_callback_parser& operator=(json_sax_dom_callback_parser&&) = default; // NOLINT(hicpp-noexcept-move,performance-noexcept-move-constructor)
     ~json_sax_dom_callback_parser() = default;
     bool null()
@@ -5690,9 +7057,9 @@ class json_sax_dom_callback_parser
         ref_stack.push_back(val.second);
         // check object limit
-        if (ref_stack.back() && JSON_HEDLEY_UNLIKELY(len != std::size_t(-1) && len > ref_stack.back()->max_size()))
+        if (ref_stack.back() && JSON_HEDLEY_UNLIKELY(len != static_cast<std::size_t>(-1) && len > ref_stack.back()->max_size()))
-            JSON_THROW(out_of_range::create(408, "excessive object size: " + std::to_string(len)));
         return true;
@@ -5709,7 +7076,7 @@ class json_sax_dom_callback_parser
         // add discarded value at given key and store the reference for later
         if (keep && ref_stack.back())
-            object_element = &(ref_stack.back()->m_value.object->operator[](val) = discarded);
+            object_element = &(ref_stack.back()->m_data.m_value.object->operator[](val) = discarded);
         return true;
@@ -5717,10 +7084,17 @@ class json_sax_dom_callback_parser
     bool end_object()
-        if (ref_stack.back() && !callback(static_cast<int>(ref_stack.size()) - 1, parse_event_t::object_end, *ref_stack.back()))
+        if (ref_stack.back())
-            // discard object
-            *ref_stack.back() = discarded;
+            if (!callback(static_cast<int>(ref_stack.size()) - 1, parse_event_t::object_end, *ref_stack.back()))
+                // discard object
+                *ref_stack.back() = discarded;
+            else
@@ -5753,9 +7127,9 @@ class json_sax_dom_callback_parser
         // check array limit
-            JSON_THROW(out_of_range::create(408, "excessive array size: " + std::to_string(len)));
         return true;
@@ -5768,7 +7142,11 @@ class json_sax_dom_callback_parser
             keep = callback(static_cast<int>(ref_stack.size()) - 1, parse_event_t::array_end, *ref_stack.back());
-            if (!keep)
+            if (keep)
+            else
                 // discard array
@@ -5783,7 +7161,7 @@ class json_sax_dom_callback_parser
         // remove discarded value
         if (!keep && !ref_stack.empty() && ref_stack.back()->is_array())
-            ref_stack.back()->m_value.array->pop_back();
+            ref_stack.back()->m_data.m_value.array->pop_back();
         return true;
@@ -5850,7 +7228,7 @@ class json_sax_dom_callback_parser
         if (ref_stack.empty())
             root = std::move(value);
-            return {true, &root};
+            return {true, & root};
         // skip this value if we already decided to skip the parent
@@ -5866,8 +7244,8 @@ class json_sax_dom_callback_parser
         // array
-            ref_stack.back()->m_value.array->push_back(std::move(value));
-            return {true, &(ref_stack.back()->m_value.array->back())};
+            ref_stack.back()->m_data.m_value.array->emplace_back(std::move(value));
+            return {true, & (ref_stack.back()->m_data.m_value.array->back())};
         // object
@@ -5952,7 +7330,7 @@ class json_sax_acceptor
         return true;
-    bool start_object(std::size_t /*unused*/ = std::size_t(-1))
+    bool start_object(std::size_t /*unused*/ = static_cast<std::size_t>(-1))
         return true;
@@ -5967,7 +7345,7 @@ class json_sax_acceptor
         return true;
-    bool start_array(std::size_t /*unused*/ = std::size_t(-1))
+    bool start_array(std::size_t /*unused*/ = static_cast<std::size_t>(-1))
         return true;
@@ -5982,11 +7360,19 @@ class json_sax_acceptor
         return false;
+}  // namespace detail
+NLOHMANN_JSON_NAMESPACE_END
 // #include <nlohmann/detail/input/lexer.hpp>
@@ -6005,11 +7391,13 @@ class json_sax_acceptor
-namespace nlohmann
 namespace detail
 // lexer //
@@ -6099,12 +7487,12 @@ class lexer : public lexer_base<BasicJsonType>
     using number_float_t = typename BasicJsonType::number_float_t;
     using string_t = typename BasicJsonType::string_t;
     using char_type = typename InputAdapterType::char_type;
-    using char_int_type = typename std::char_traits<char_type>::int_type;
+    using char_int_type = typename char_traits<char_type>::int_type;
   public:
     using token_type = typename lexer_base<BasicJsonType>::token_type;
-    explicit lexer(InputAdapterType&& adapter, bool ignore_comments_ = false)
+    explicit lexer(InputAdapterType&& adapter, bool ignore_comments_ = false) noexcept
         : ia(std::move(adapter))
         , ignore_comments(ignore_comments_)
         , decimal_point_char(static_cast<char_int_type>(get_decimal_point()))
@@ -6112,9 +7500,9 @@ class lexer : public lexer_base<BasicJsonType>
     lexer(const lexer&) = delete;
-    lexer(lexer&&) = default;
+    lexer(lexer&&) = default; // NOLINT(hicpp-noexcept-move,performance-noexcept-move-constructor)
     lexer& operator=(lexer&) = delete;
-    lexer& operator=(lexer&&) = default;
+    lexer& operator=(lexer&&) = default; // NOLINT(hicpp-noexcept-move,performance-noexcept-move-constructor)
     ~lexer() = default;
   private:
@@ -6206,7 +7594,7 @@ class lexer : public lexer_base<BasicJsonType>
         for (auto range = ranges.begin(); range != ranges.end(); ++range)
             get();
-            if (JSON_HEDLEY_LIKELY(*range <= current && current <= *(++range)))
+            if (JSON_HEDLEY_LIKELY(*range <= current && current <= *(++range))) // NOLINT(bugprone-inc-dec-in-conditions)
                 add(current);
@@ -6223,7 +7611,7 @@ class lexer : public lexer_base<BasicJsonType>
     @brief scan a string literal
-    This function scans a string according to Sect. 7 of RFC 7159. While
+    This function scans a string according to Sect. 7 of RFC 8259. While
     scanning, bytes are escaped and copied into buffer token_buffer. Then the
     function returns successfully, token_buffer is *not* null-terminated (as it
     may contain \0 bytes), and token_buffer.size() is the number of bytes in the
@@ -6249,7 +7637,7 @@ class lexer : public lexer_base<BasicJsonType>
             switch (get())
                 // end of file while parsing string
-                case std::char_traits<char_type>::eof():
+                case char_traits<char_type>::eof():
                     error_message = "invalid string: missing closing quote";
                     return token_type::parse_error;
@@ -6335,7 +7723,7 @@ class lexer : public lexer_base<BasicJsonType>
                                                         // low surrogate occupies the least significant 15 bits
                                                         + static_cast<unsigned int>(codepoint2)
                                                         // there is still the 0xD800, 0xDC00 and 0x10000 noise
-                                                        // in the result so we have to subtract with:
+                                                        // in the result, so we have to subtract with:
                                                         // (0xD800 << 10) + DC00 - 0x10000 = 0x35FDC00
                                                         - 0x35FDC00u);
@@ -6838,7 +8226,7 @@ class lexer : public lexer_base<BasicJsonType>
                         case '\n':
                         case '\r':
                         case '\0':
                             return true;
@@ -6855,7 +8243,7 @@ class lexer : public lexer_base<BasicJsonType>
                     switch (get())
                         case '\0':
                             error_message = "invalid comment; missing closing '*/'";
@@ -6913,10 +8301,10 @@ class lexer : public lexer_base<BasicJsonType>
     @brief scan a number literal
-    This function scans a string according to Sect. 6 of RFC 7159.
+    This function scans a string according to Sect. 6 of RFC 8259.
     The function is realized with a deterministic finite state machine derived
-    from the grammar described in RFC 7159. Starting in state "init", the
+    from the grammar described in RFC 8259. Starting in state "init", the
     input is read and used to determined the next state. Only state "done"
     accepts the number. State "error" is a trap state to model errors. In the
     table below, "anything" means any character but the ones listed before.
@@ -6990,7 +8378,7 @@ class lexer : public lexer_base<BasicJsonType>
             // all other characters are rejected outside scan_number()
             default:            // LCOV_EXCL_LINE
 scan_number_minus:
@@ -7228,7 +8616,7 @@ scan_number_done:
         // we are done scanning a number)
         unget();
-        char* endptr = nullptr;
+        char* endptr = nullptr; // NOLINT(cppcoreguidelines-pro-type-vararg,hicpp-vararg)
         errno = 0;
         // try to parse integers first and fall back to floats
@@ -7284,10 +8672,10 @@ scan_number_done:
     token_type scan_literal(const char_type* literal_text, const std::size_t length,
                             token_type return_type)
-        JSON_ASSERT(std::char_traits<char_type>::to_char_type(current) == literal_text[0]);
+        JSON_ASSERT(char_traits<char_type>::to_char_type(current) == literal_text[0]);
         for (std::size_t i = 1; i < length; ++i)
-            if (JSON_HEDLEY_UNLIKELY(std::char_traits<char_type>::to_char_type(get()) != literal_text[i]))
+            if (JSON_HEDLEY_UNLIKELY(char_traits<char_type>::to_char_type(get()) != literal_text[i]))
                 error_message = "invalid literal";
@@ -7305,7 +8693,7 @@ scan_number_done:
         token_buffer.clear();
         token_string.clear();
-        token_string.push_back(std::char_traits<char_type>::to_char_type(current));
+        token_string.push_back(char_traits<char_type>::to_char_type(current));
@@ -7313,7 +8701,7 @@ scan_number_done:
     This function provides the interface to the used input adapter. It does
     not throw in case the input reached EOF, but returns a
-    `std::char_traits<char>::eof()` in that case.  Stores the scanned characters
+    `char_traits<char>::eof()` in that case.  Stores the scanned characters
     for use in error messages.
     @return character read from the input
@@ -7333,9 +8721,9 @@ scan_number_done:
             current = ia.get_character();
-        if (JSON_HEDLEY_LIKELY(current != std::char_traits<char_type>::eof()))
+        if (JSON_HEDLEY_LIKELY(current != char_traits<char_type>::eof()))
         if (current == '\n')
@@ -7374,7 +8762,7 @@ scan_number_done:
             --position.chars_read_current_line;
             JSON_ASSERT(!token_string.empty());
             token_string.pop_back();
@@ -7439,7 +8827,7 @@ scan_number_done:
                 // escape control characters
                 std::array<char, 9> cs{{}};
-                (std::snprintf)(cs.data(), cs.size(), "<U+%.4X>", static_cast<unsigned char>(c));
+                static_cast<void>((std::snprintf)(cs.data(), cs.size(), "<U+%.4X>", static_cast<unsigned char>(c))); // NOLINT(cppcoreguidelines-pro-type-vararg,hicpp-vararg)
                 result += cs.data();
             else
@@ -7533,17 +8921,17 @@ scan_number_done:
             // literals
             case 't':
-                std::array<char_type, 4> true_literal = {{char_type('t'), char_type('r'), char_type('u'), char_type('e')}};
+                std::array<char_type, 4> true_literal = {{static_cast<char_type>('t'), static_cast<char_type>('r'), static_cast<char_type>('u'), static_cast<char_type>('e')}};
                 return scan_literal(true_literal.data(), true_literal.size(), token_type::literal_true);
             case 'f':
-                std::array<char_type, 5> false_literal = {{char_type('f'), char_type('a'), char_type('l'), char_type('s'), char_type('e')}};
+                std::array<char_type, 5> false_literal = {{static_cast<char_type>('f'), static_cast<char_type>('a'), static_cast<char_type>('l'), static_cast<char_type>('s'), static_cast<char_type>('e')}};
                 return scan_literal(false_literal.data(), false_literal.size(), token_type::literal_false);
             case 'n':
-                std::array<char_type, 4> null_literal = {{char_type('n'), char_type('u'), char_type('l'), char_type('l')}};
+                std::array<char_type, 4> null_literal = {{static_cast<char_type>('n'), static_cast<char_type>('u'), static_cast<char_type>('l'), static_cast<char_type>('l')}};
                 return scan_literal(null_literal.data(), null_literal.size(), token_type::literal_null);
@@ -7568,7 +8956,7 @@ scan_number_done:
             // end of input (the null byte is needed when parsing from
             // string literals)
             case '\0':
                 return token_type::end_of_input;
             // error
@@ -7586,7 +8974,7 @@ scan_number_done:
     const bool ignore_comments = false;
     /// the current character
-    char_int_type current = std::char_traits<char_type>::eof();
+    char_int_type current = char_traits<char_type>::eof();
     /// whether the next get() call should just return current
     bool next_unget = false;
@@ -7611,27 +8999,38 @@ scan_number_done:
     /// the decimal point
     const char_int_type decimal_point_char = '.';
 // #include <nlohmann/detail/meta/is_sax.hpp>
 #include <cstdint> // size_t
 #include <utility> // declval
+// #include <nlohmann/detail/abi_macros.hpp>
 // #include <nlohmann/detail/meta/detected.hpp>
 // #include <nlohmann/detail/meta/type_traits.hpp>
-namespace nlohmann
 namespace detail
 template<typename T>
 using null_function_t = decltype(std::declval<T&>().null());
@@ -7766,22 +9165,27 @@ struct is_sax_static_asserts
         "Missing/invalid function: bool parse_error(std::size_t, const "
         "std::string&, const exception&)");
+// #include <nlohmann/detail/meta/type_traits.hpp>
+// #include <nlohmann/detail/string_concat.hpp>
-namespace nlohmann
 namespace detail
 /// how to treat CBOR tags
 enum class cbor_tag_handler_t
-    error,  ///< throw a parse_error exception in case of a tag
-    ignore   ///< ignore tags
+    error,   ///< throw a parse_error exception in case of a tag
+    ignore,  ///< ignore tags
+    store    ///< store tags as binary type
@@ -7791,12 +9195,11 @@ enum class cbor_tag_handler_t
 @note from https://stackoverflow.com/a/1001328/266378
-static inline bool little_endianess(int num = 1) noexcept
+static inline bool little_endianness(int num = 1) noexcept
     return *reinterpret_cast<char*>(&num) == 1;
 // binary reader //
@@ -7814,7 +9217,7 @@ class binary_reader
     using json_sax_t = SAX;
   public:
@@ -7822,16 +9225,16 @@ class binary_reader
     @param[in] adapter  input adapter to read from
-    explicit binary_reader(InputAdapterType&& adapter) : ia(std::move(adapter))
+    explicit binary_reader(InputAdapterType&& adapter, const input_format_t format = input_format_t::json) noexcept : ia(std::move(adapter)), input_format(format)
         (void)detail::is_sax_static_asserts<SAX, BasicJsonType> {};
     binary_reader(const binary_reader&) = delete;
-    binary_reader(binary_reader&&) = default;
+    binary_reader(binary_reader&&) = default; // NOLINT(hicpp-noexcept-move,performance-noexcept-move-constructor)
     binary_reader& operator=(const binary_reader&) = delete;
-    binary_reader& operator=(binary_reader&&) = default;
+    binary_reader& operator=(binary_reader&&) = default; // NOLINT(hicpp-noexcept-move,performance-noexcept-move-constructor)
     ~binary_reader() = default;
@@ -7840,7 +9243,7 @@ class binary_reader
     @param[in] strict  whether to expect the input to be consumed completed
     @param[in] tag_handler  how to treat CBOR tags
-    @return
+    @return whether parsing was successful
     JSON_HEDLEY_NON_NULL(3)
     bool sax_parse(const input_format_t format,
@@ -7866,17 +9269,19 @@ class binary_reader
                 break;
             case input_format_t::ubjson:
+            case input_format_t::bjdata:
                 result = parse_ubjson_internal();
                 break;
+            case input_format_t::json: // LCOV_EXCL_LINE
         // strict mode: next byte must be EOF
         if (result && strict)
-            if (format == input_format_t::ubjson)
+            if (input_format == input_format_t::ubjson || input_format == input_format_t::bjdata)
                 get_ignore_noop();
@@ -7885,10 +9290,10 @@ class binary_reader
                 get();
-            if (JSON_HEDLEY_UNLIKELY(current != std::char_traits<char_type>::eof()))
+            if (JSON_HEDLEY_UNLIKELY(current != char_traits<char_type>::eof()))
-                return sax->parse_error(chars_read, get_token_string(),
-                                        parse_error::create(110, chars_read, exception_message(format, "expected end of input; last byte: 0x" + get_token_string(), "value")));
+                return sax->parse_error(chars_read, get_token_string(), parse_error::create(110, chars_read,
+                                        exception_message(input_format, concat("expected end of input; last byte: 0x", get_token_string()), "value"), nullptr));
@@ -7909,7 +9314,7 @@ class binary_reader
         std::int32_t document_size{};
         get_number<std::int32_t, true>(input_format_t::bson, document_size);
-        if (JSON_HEDLEY_UNLIKELY(!sax->start_object(std::size_t(-1))))
+        if (JSON_HEDLEY_UNLIKELY(!sax->start_object(static_cast<std::size_t>(-1))))
             return false;
@@ -7924,7 +9329,7 @@ class binary_reader
     @brief Parses a C-style string from the BSON input.
-    @param[in, out] result  A reference to the string variable where the read
+    @param[in,out] result  A reference to the string variable where the read
                             string is to be stored.
     @return `true` if the \x00-byte indicating the end of the string was
              encountered before the EOF; false` indicates an unexpected EOF.
@@ -7952,7 +9357,7 @@ class binary_reader
            input.
     @param[in] len  The length (including the zero-byte at the end) of the
                     string to be read.
     @tparam NumberType The type of the length @a len
     @pre len >= 1
@@ -7964,16 +9369,17 @@ class binary_reader
         if (JSON_HEDLEY_UNLIKELY(len < 1))
             auto last_token = get_token_string();
-            return sax->parse_error(chars_read, last_token, parse_error::create(112, chars_read, exception_message(input_format_t::bson, "string length must be at least 1, is " + std::to_string(len), "string")));
+            return sax->parse_error(chars_read, last_token, parse_error::create(112, chars_read,
+                                    exception_message(input_format_t::bson, concat("string length must be at least 1, is ", std::to_string(len)), "string"), nullptr));
-        return get_string(input_format_t::bson, len - static_cast<NumberType>(1), result) && get() != std::char_traits<char_type>::eof();
+        return get_string(input_format_t::bson, len - static_cast<NumberType>(1), result) && get() != char_traits<char_type>::eof();
     @brief Parses a byte array input of length @a len from the BSON input.
     @param[in] len  The length of the byte array to be read.
-    @param[in, out] result  A reference to the binary variable where the read
+    @param[in,out] result  A reference to the binary variable where the read
                             array is to be stored.
     @pre len >= 0
@@ -7985,7 +9391,8 @@ class binary_reader
         if (JSON_HEDLEY_UNLIKELY(len < 0))
-            return sax->parse_error(chars_read, last_token, parse_error::create(112, chars_read, exception_message(input_format_t::bson, "byte array length cannot be negative, is " + std::to_string(len), "binary")));
+                                    exception_message(input_format_t::bson, concat("byte array length cannot be negative, is ", std::to_string(len)), "binary"), nullptr));
         // All BSON binary values have a subtype
@@ -8066,8 +9473,10 @@ class binary_reader
             default: // anything else not supported (yet)
                 std::array<char, 3> cr{{}};
-                (std::snprintf)(cr.data(), cr.size(), "%.2hhX", static_cast<unsigned char>(element_type));
-                return sax->parse_error(element_type_parse_position, std::string(cr.data()), parse_error::create(114, element_type_parse_position, "Unsupported BSON record type 0x" + std::string(cr.data())));
+                static_cast<void>((std::snprintf)(cr.data(), cr.size(), "%.2hhX", static_cast<unsigned char>(element_type))); // NOLINT(cppcoreguidelines-pro-type-vararg,hicpp-vararg)
+                const std::string cr_str{cr.data()};
+                return sax->parse_error(element_type_parse_position, cr_str,
+                                        parse_error::create(114, element_type_parse_position, concat("Unsupported BSON record type 0x", cr_str), nullptr));
@@ -8127,7 +9536,7 @@ class binary_reader
-        if (JSON_HEDLEY_UNLIKELY(!sax->start_array(std::size_t(-1))))
+        if (JSON_HEDLEY_UNLIKELY(!sax->start_array(static_cast<std::size_t>(-1))))
             return false;
@@ -8158,7 +9567,7 @@ class binary_reader
         switch (get_char ? get() : current)
             // EOF
                 return unexpect_eof(input_format_t::cbor, "value");
             // Integer 0x00..0x17 (0..23)
@@ -8359,7 +9768,8 @@ class binary_reader
             case 0x95:
             case 0x96:
             case 0x97:
-                return get_cbor_array(static_cast<std::size_t>(static_cast<unsigned int>(current) & 0x1Fu), tag_handler);
+                return get_cbor_array(
+                           conditional_static_cast<std::size_t>(static_cast<unsigned int>(current) & 0x1Fu), tag_handler);
             case 0x98: // array (one-byte uint8_t for n follows)
@@ -8376,17 +9786,17 @@ class binary_reader
             case 0x9A: // array (four-byte uint32_t for n follow)
                 std::uint32_t len{};
-                return get_number(input_format_t::cbor, len) && get_cbor_array(static_cast<std::size_t>(len), tag_handler);
+                return get_number(input_format_t::cbor, len) && get_cbor_array(conditional_static_cast<std::size_t>(len), tag_handler);
             case 0x9B: // array (eight-byte uint64_t for n follow)
                 std::uint64_t len{};
             case 0x9F: // array (indefinite length)
-                return get_cbor_array(std::size_t(-1), tag_handler);
+                return get_cbor_array(static_cast<std::size_t>(-1), tag_handler);
             // map (0x00..0x17 pairs of data items follow)
             case 0xA0:
@@ -8413,7 +9823,7 @@ class binary_reader
             case 0xB5:
             case 0xB6:
             case 0xB7:
-                return get_cbor_object(static_cast<std::size_t>(static_cast<unsigned int>(current) & 0x1Fu), tag_handler);
+                return get_cbor_object(conditional_static_cast<std::size_t>(static_cast<unsigned int>(current) & 0x1Fu), tag_handler);
             case 0xB8: // map (one-byte uint8_t for n follows)
@@ -8430,17 +9840,17 @@ class binary_reader
             case 0xBA: // map (four-byte uint32_t for n follow)
-                return get_number(input_format_t::cbor, len) && get_cbor_object(static_cast<std::size_t>(len), tag_handler);
+                return get_number(input_format_t::cbor, len) && get_cbor_object(conditional_static_cast<std::size_t>(len), tag_handler);
             case 0xBB: // map (eight-byte uint64_t for n follow)
             case 0xBF: // map (indefinite length)
-                return get_cbor_object(std::size_t(-1), tag_handler);
+                return get_cbor_object(static_cast<std::size_t>(-1), tag_handler);
             case 0xC6: // tagged item
             case 0xC7:
@@ -8467,35 +9877,37 @@ class binary_reader
                     case cbor_tag_handler_t::error:
-                        return sax->parse_error(chars_read, last_token, parse_error::create(112, chars_read, exception_message(input_format_t::cbor, "invalid byte: 0x" + last_token, "value")));
+                                                exception_message(input_format_t::cbor, concat("invalid byte: 0x", last_token), "value"), nullptr));
                     case cbor_tag_handler_t::ignore:
+                        // ignore binary subtype
                         switch (current)
                             case 0xD8:
-                                std::uint8_t len{};
-                                get_number(input_format_t::cbor, len);
+                                std::uint8_t subtype_to_ignore{};
+                                get_number(input_format_t::cbor, subtype_to_ignore);
                                 break;
                             case 0xD9:
-                                std::uint16_t len{};
+                                std::uint16_t subtype_to_ignore{};
                                 break;
                             case 0xDA:
-                                std::uint32_t len{};
+                                std::uint32_t subtype_to_ignore{};
                                 break;
                             case 0xDB:
-                                std::uint64_t len{};
+                                std::uint64_t subtype_to_ignore{};
                                 break;
                             default:
@@ -8504,8 +9916,49 @@ class binary_reader
                         return parse_cbor_internal(true, tag_handler);
+                    case cbor_tag_handler_t::store:
+                        binary_t b;
+                        // use binary subtype and store in binary container
+                        switch (current)
+                            case 0xD8:
+                                std::uint8_t subtype{};
+                                get_number(input_format_t::cbor, subtype);
+                                b.set_subtype(detail::conditional_static_cast<typename binary_t::subtype_type>(subtype));
+                                break;
+                            case 0xD9:
+                                std::uint16_t subtype{};
+                                break;
+                            case 0xDA:
+                                std::uint32_t subtype{};
+                                break;
+                            case 0xDB:
+                                std::uint64_t subtype{};
+                                break;
+                            default:
+                                return parse_cbor_internal(true, tag_handler);
+                        get();
+                        return get_cbor_binary(b) && sax->binary(b);
                         return false;        // LCOV_EXCL_LINE
@@ -8582,7 +10035,8 @@ class binary_reader
             default: // anything else (0xFF is handled inside the other types)
@@ -8677,7 +10131,8 @@ class binary_reader
             default:
-                return sax->parse_error(chars_read, last_token, parse_error::create(113, chars_read, exception_message(input_format_t::cbor, "expected length specification (0x60-0x7B) or indefinite string type (0x7F); last byte: 0x" + last_token, "string")));
+                return sax->parse_error(chars_read, last_token, parse_error::create(113, chars_read,
+                                        exception_message(input_format_t::cbor, concat("expected length specification (0x60-0x7B) or indefinite string type (0x7F); last byte: 0x", last_token), "string"), nullptr));
@@ -8776,13 +10231,14 @@ class binary_reader
             default:
-                return sax->parse_error(chars_read, last_token, parse_error::create(113, chars_read, exception_message(input_format_t::cbor, "expected length specification (0x40-0x5B) or indefinite binary array type (0x5F); last byte: 0x" + last_token, "binary")));
+                                        exception_message(input_format_t::cbor, concat("expected length specification (0x40-0x5B) or indefinite binary array type (0x5F); last byte: 0x", last_token), "binary"), nullptr));
-    @param[in] len  the length of the array or std::size_t(-1) for an
+    @param[in] len  the length of the array or static_cast<std::size_t>(-1) for an
                     array of indefinite size
     @param[in] tag_handler how CBOR tags should be treated
     @return whether array creation completed
@@ -8795,7 +10251,7 @@ class binary_reader
             return false;
-        if (len != std::size_t(-1))
+        if (len != static_cast<std::size_t>(-1))
             for (std::size_t i = 0; i < len; ++i)
@@ -8820,7 +10276,7 @@ class binary_reader
-    @param[in] len  the length of the object or std::size_t(-1) for an
+    @param[in] len  the length of the object or static_cast<std::size_t>(-1) for an
                     object of indefinite size
     @return whether object creation completed
@@ -8833,38 +10289,41 @@ class binary_reader
             return false;
-        string_t key;
+        if (len != 0)
-            for (std::size_t i = 0; i < len; ++i)
+            string_t key;
-                get();
-                if (JSON_HEDLEY_UNLIKELY(!get_cbor_string(key) || !sax->key(key)))
+                for (std::size_t i = 0; i < len; ++i)
-                    return false;
+                    get();
+                    if (JSON_HEDLEY_UNLIKELY(!get_cbor_string(key) || !sax->key(key)))
+                        return false;
-                if (JSON_HEDLEY_UNLIKELY(!parse_cbor_internal(true, tag_handler)))
-                    return false;
+                    if (JSON_HEDLEY_UNLIKELY(!parse_cbor_internal(true, tag_handler)))
+                        return false;
+                    key.clear();
-                key.clear();
-        else
-            while (get() != 0xFF)
+            else
+                while (get() != 0xFF)
-                    return false;
+                        return false;
-                    return false;
+                        return false;
+                    key.clear();
-                key.clear();
@@ -8883,7 +10342,7 @@ class binary_reader
         switch (get())
             // EOF
                 return unexpect_eof(input_format_t::msgpack, "value");
             // positive fixint
@@ -9034,7 +10493,7 @@ class binary_reader
             case 0x8D:
             case 0x8E:
             case 0x8F:
-                return get_msgpack_object(static_cast<std::size_t>(static_cast<unsigned int>(current) & 0x0Fu));
+                return get_msgpack_object(conditional_static_cast<std::size_t>(static_cast<unsigned int>(current) & 0x0Fu));
             // fixarray
             case 0x90:
@@ -9053,7 +10512,7 @@ class binary_reader
             case 0x9D:
             case 0x9E:
             case 0x9F:
-                return get_msgpack_array(static_cast<std::size_t>(static_cast<unsigned int>(current) & 0x0Fu));
+                return get_msgpack_array(conditional_static_cast<std::size_t>(static_cast<unsigned int>(current) & 0x0Fu));
             // fixstr
             case 0xA0:
@@ -9190,7 +10649,7 @@ class binary_reader
             case 0xDD: // array 32
-                return get_number(input_format_t::msgpack, len) && get_msgpack_array(static_cast<std::size_t>(len));
+                return get_number(input_format_t::msgpack, len) && get_msgpack_array(conditional_static_cast<std::size_t>(len));
             case 0xDE: // map 16
@@ -9202,7 +10661,7 @@ class binary_reader
             case 0xDF: // map 32
-                return get_number(input_format_t::msgpack, len) && get_msgpack_object(static_cast<std::size_t>(len));
+                return get_number(input_format_t::msgpack, len) && get_msgpack_object(conditional_static_cast<std::size_t>(len));
             // negative fixint
@@ -9243,7 +10702,8 @@ class binary_reader
-                return sax->parse_error(chars_read, last_token, parse_error::create(112, chars_read, exception_message(input_format_t::msgpack, "invalid byte: 0x" + last_token, "value")));
+                                        exception_message(input_format_t::msgpack, concat("invalid byte: 0x", last_token), "value"), nullptr));
@@ -9325,7 +10785,8 @@ class binary_reader
             default:
-                return sax->parse_error(chars_read, last_token, parse_error::create(113, chars_read, exception_message(input_format_t::msgpack, "expected length specification (0xA0-0xBF, 0xD9-0xDB); last byte: 0x" + last_token, "string")));
+                                        exception_message(input_format_t::msgpack, concat("expected length specification (0xA0-0xBF, 0xD9-0xDB); last byte: 0x", last_token), "string"), nullptr));
@@ -9536,7 +10997,7 @@ class binary_reader
             get();  // TODO(niels): may we ignore N here?
-        if (JSON_HEDLEY_UNLIKELY(!unexpect_eof(input_format_t::ubjson, "value")))
+        if (JSON_HEDLEY_UNLIKELY(!unexpect_eof(input_format, "value")))
             return false;
@@ -9546,51 +11007,162 @@ class binary_reader
             case 'U':
                 std::uint8_t len{};
-                return get_number(input_format_t::ubjson, len) && get_string(input_format_t::ubjson, len, result);
+                return get_number(input_format, len) && get_string(input_format, len, result);
             case 'i':
                 std::int8_t len{};
             case 'I':
                 std::int16_t len{};
             case 'l':
                 std::int32_t len{};
             case 'L':
                 std::int64_t len{};
+            case 'u':
+                if (input_format != input_format_t::bjdata)
+                    break;
+                std::uint16_t len{};
+            case 'm':
+                    break;
+                std::uint32_t len{};
+            case 'M':
+                    break;
+                std::uint64_t len{};
             default:
-                auto last_token = get_token_string();
-                return sax->parse_error(chars_read, last_token, parse_error::create(113, chars_read, exception_message(input_format_t::ubjson, "expected length type specification (U, i, I, l, L); last byte: 0x" + last_token, "string")));
+                break;
+        auto last_token = get_token_string();
+        std::string message;
+            message = "expected length type specification (U, i, I, l, L); last byte: 0x" + last_token;
+        else
+            message = "expected length type specification (U, i, u, I, m, l, M, L); last byte: 0x" + last_token;
+        return sax->parse_error(chars_read, last_token, parse_error::create(113, chars_read, exception_message(input_format, message, "string"), nullptr));
+    @param[out] dim  an integer vector storing the ND array dimensions
+    @return whether reading ND array size vector is successful
+    bool get_ubjson_ndarray_size(std::vector<size_t>& dim)
+        std::pair<std::size_t, char_int_type> size_and_type;
+        size_t dimlen = 0;
+        bool no_ndarray = true;
+        if (JSON_HEDLEY_UNLIKELY(!get_ubjson_size_type(size_and_type, no_ndarray)))
+            return false;
+        if (size_and_type.first != npos)
+            if (size_and_type.second != 0)
+                if (size_and_type.second != 'N')
+                    for (std::size_t i = 0; i < size_and_type.first; ++i)
+                        if (JSON_HEDLEY_UNLIKELY(!get_ubjson_size_value(dimlen, no_ndarray, size_and_type.second)))
+                            return false;
+                        dim.push_back(dimlen);
+            else
+                    if (JSON_HEDLEY_UNLIKELY(!get_ubjson_size_value(dimlen, no_ndarray)))
+                        return false;
+        else
+            while (current != ']')
+                if (JSON_HEDLEY_UNLIKELY(!get_ubjson_size_value(dimlen, no_ndarray, current)))
+                    return false;
+                get_ignore_noop();
+        return true;
     @param[out] result  determined size
+    @param[in,out] is_ndarray  for input, `true` means already inside an ndarray vector
+                               or ndarray dimension is not allowed; `false` means ndarray
+                               is allowed; for output, `true` means an ndarray is found;
+                               is_ndarray can only return `true` when its initial value
+                               is `false`
+    @param[in] prefix  type marker if already read, otherwise set to 0
     @return whether size determination completed
-    bool get_ubjson_size_value(std::size_t& result)
+    bool get_ubjson_size_value(std::size_t& result, bool& is_ndarray, char_int_type prefix = 0)
-        switch (get_ignore_noop())
+        if (prefix == 0)
+            prefix = get_ignore_noop();
+        switch (prefix)
             case 'U':
                 std::uint8_t number{};
-                if (JSON_HEDLEY_UNLIKELY(!get_number(input_format_t::ubjson, number)))
+                if (JSON_HEDLEY_UNLIKELY(!get_number(input_format, number)))
                     return false;
@@ -9601,21 +11173,31 @@ class binary_reader
             case 'i':
                 std::int8_t number{};
                     return false;
-                result = static_cast<std::size_t>(number);
+                if (number < 0)
+                    return sax->parse_error(chars_read, get_token_string(), parse_error::create(113, chars_read,
+                                            exception_message(input_format, "count in an optimized container must be positive", "size"), nullptr));
+                result = static_cast<std::size_t>(number); // NOLINT(bugprone-signed-char-misuse,cert-str34-c): number is not a char
                 return true;
             case 'I':
                 std::int16_t number{};
                     return false;
+                if (number < 0)
                 return true;
@@ -9623,10 +11205,15 @@ class binary_reader
             case 'l':
                 std::int32_t number{};
                     return false;
+                if (number < 0)
                 return true;
@@ -9634,7 +11221,32 @@ class binary_reader
             case 'L':
                 std::int64_t number{};
+                    return false;
+                if (number < 0)
+                if (!value_in_range_of<std::size_t>(number))
+                    return sax->parse_error(chars_read, get_token_string(), out_of_range::create(408,
+                                            exception_message(input_format, "integer value overflow", "size"), nullptr));
+                return true;
+            case 'u':
+                    break;
+                std::uint16_t number{};
                     return false;
@@ -9642,12 +11254,112 @@ class binary_reader
                 return true;
-            default:
+            case 'm':
-                return sax->parse_error(chars_read, last_token, parse_error::create(113, chars_read, exception_message(input_format_t::ubjson, "expected length type specification (U, i, I, l, L) after '#'; last byte: 0x" + last_token, "size")));
+                    break;
+                std::uint32_t number{};
+                    return false;
+                result = conditional_static_cast<std::size_t>(number);
+                return true;
+            case 'M':
+                    break;
+                std::uint64_t number{};
+                    return false;
+                result = detail::conditional_static_cast<std::size_t>(number);
+                return true;
+            case '[':
+                    break;
+                if (is_ndarray) // ndarray dimensional vector can only contain integers, and can not embed another array
+                    return sax->parse_error(chars_read, get_token_string(), parse_error::create(113, chars_read, exception_message(input_format, "ndarray dimensional vector is not allowed", "size"), nullptr));
+                std::vector<size_t> dim;
+                if (JSON_HEDLEY_UNLIKELY(!get_ubjson_ndarray_size(dim)))
+                    return false;
+                if (dim.size() == 1 || (dim.size() == 2 && dim.at(0) == 1)) // return normal array size if 1D row vector
+                    result = dim.at(dim.size() - 1);
+                    return true;
+                if (!dim.empty())  // if ndarray, convert to an object in JData annotated array format
+                    for (auto i : dim) // test if any dimension in an ndarray is 0, if so, return a 1D empty container
+                        if ( i == 0 )
+                            result = 0;
+                            return true;
+                    string_t key = "_ArraySize_";
+                    if (JSON_HEDLEY_UNLIKELY(!sax->start_object(3) || !sax->key(key) || !sax->start_array(dim.size())))
+                        return false;
+                    result = 1;
+                        result *= i;
+                        if (result == 0 || result == npos) // because dim elements shall not have zeros, result = 0 means overflow happened; it also can't be npos as it is used to initialize size in get_ubjson_size_type()
+                            return sax->parse_error(chars_read, get_token_string(), out_of_range::create(408, exception_message(input_format, "excessive ndarray size caused overflow", "size"), nullptr));
+                        if (JSON_HEDLEY_UNLIKELY(!sax->number_unsigned(static_cast<number_unsigned_t>(i))))
+                            return false;
+                    is_ndarray = true;
+                    return sax->end_array();
+                result = 0;
+                return true;
+            default:
+                break;
+            message = "expected length type specification (U, i, I, l, L) after '#'; last byte: 0x" + last_token;
+        else
+            message = "expected length type specification (U, i, u, I, m, l, M, L) after '#'; last byte: 0x" + last_token;
+        return sax->parse_error(chars_read, last_token, parse_error::create(113, chars_read, exception_message(input_format, message, "size"), nullptr));
@@ -9657,20 +11369,30 @@ class binary_reader
     for a more compact representation.
     @param[out] result  pair of the size and the type
+    @param[in] inside_ndarray  whether the parser is parsing an ND array dimensional vector
     @return whether pair creation completed
-    bool get_ubjson_size_type(std::pair<std::size_t, char_int_type>& result)
+    bool get_ubjson_size_type(std::pair<std::size_t, char_int_type>& result, bool inside_ndarray = false)
-        result.first = string_t::npos; // size
+        result.first = npos; // size
         result.second = 0; // type
+        bool is_ndarray = false;
         get_ignore_noop();
         if (current == '$')
             result.second = get();  // must not ignore 'N', because 'N' maybe the type
-            if (JSON_HEDLEY_UNLIKELY(!unexpect_eof(input_format_t::ubjson, "type")))
+            if (input_format == input_format_t::bjdata
+                    && JSON_HEDLEY_UNLIKELY(std::binary_search(bjd_optimized_type_markers.begin(), bjd_optimized_type_markers.end(), result.second)))
+                                        exception_message(input_format, concat("marker 0x", last_token, " is not a permitted optimized array type"), "type"), nullptr));
+            if (JSON_HEDLEY_UNLIKELY(!unexpect_eof(input_format, "type")))
                 return false;
@@ -9678,20 +11400,37 @@ class binary_reader
             get_ignore_noop();
             if (JSON_HEDLEY_UNLIKELY(current != '#'))
                     return false;
-                return sax->parse_error(chars_read, last_token, parse_error::create(112, chars_read, exception_message(input_format_t::ubjson, "expected '#' after type information; last byte: 0x" + last_token, "size")));
+                                        exception_message(input_format, concat("expected '#' after type information; last byte: 0x", last_token), "size"), nullptr));
-            return get_ubjson_size_value(result.first);
+            const bool is_error = get_ubjson_size_value(result.first, is_ndarray);
+            if (input_format == input_format_t::bjdata && is_ndarray)
+                if (inside_ndarray)
+                    return sax->parse_error(chars_read, get_token_string(), parse_error::create(112, chars_read,
+                                            exception_message(input_format, "ndarray can not be recursive", "size"), nullptr));
+                result.second |= (1 << 8); // use bit 8 to indicate ndarray, all UBJSON and BJData markers should be ASCII letters
+            return is_error;
         if (current == '#')
+                                        exception_message(input_format, "ndarray requires both type and size", "size"), nullptr));
+            return is_error;
         return true;
@@ -9705,8 +11444,8 @@ class binary_reader
         switch (prefix)
-            case std::char_traits<char_type>::eof():  // EOF
-                return unexpect_eof(input_format_t::ubjson, "value");
+            case char_traits<char_type>::eof():  // EOF
+                return unexpect_eof(input_format, "value");
             case 'T':  // true
                 return sax->boolean(true);
@@ -9719,43 +11458,125 @@ class binary_reader
             case 'U':
-                return get_number(input_format_t::ubjson, number) && sax->number_unsigned(number);
+                return get_number(input_format, number) && sax->number_unsigned(number);
             case 'i':
-                return get_number(input_format_t::ubjson, number) && sax->number_integer(number);
+                return get_number(input_format, number) && sax->number_integer(number);
             case 'I':
             case 'l':
             case 'L':
+            case 'u':
+                    break;
+            case 'm':
+                    break;
+            case 'M':
+                    break;
+            case 'h':
+                    break;
+                const auto byte1_raw = get();
+                if (JSON_HEDLEY_UNLIKELY(!unexpect_eof(input_format, "number")))
+                    return false;
+                const auto byte2_raw = get();
+                    return false;
+                const auto byte1 = static_cast<unsigned char>(byte1_raw);
+                const auto byte2 = static_cast<unsigned char>(byte2_raw);
+                // code from RFC 7049, Appendix D, Figure 3:
+                // As half-precision floating-point numbers were only added
+                // to IEEE 754 in 2008, today's programming platforms often
+                // still only have limited support for them. It is very
+                // easy to include at least decoding support for them even
+                // without such support. An example of a small decoder for
+                // half-precision floating-point numbers in the C language
+                // is shown in Fig. 3.
+                const auto half = static_cast<unsigned int>((byte2 << 8u) + byte1);
+                const double val = [&half]
+                    const int exp = (half >> 10u) & 0x1Fu;
+                    const unsigned int mant = half & 0x3FFu;
+                    JSON_ASSERT(0 <= exp&& exp <= 32);
+                    JSON_ASSERT(mant <= 1024);
+                    switch (exp)
+                        case 0:
+                            return std::ldexp(mant, -24);
+                        case 31:
+                            return (mant == 0)
+                            ? std::numeric_limits<double>::infinity()
+                            : std::numeric_limits<double>::quiet_NaN();
+                        default:
+                            return std::ldexp(mant + 1024, exp - 25);
+                return sax->number_float((half & 0x8000u) != 0
+                                         ? static_cast<number_float_t>(-val)
+                                         : static_cast<number_float_t>(val), "");
             case 'd':
                 float number{};
-                return get_number(input_format_t::ubjson, number) && sax->number_float(static_cast<number_float_t>(number), "");
+                return get_number(input_format, number) && sax->number_float(static_cast<number_float_t>(number), "");
             case 'D':
                 double number{};
             case 'H':
@@ -9766,14 +11587,15 @@ class binary_reader
             case 'C':  // char
                 get();
-                if (JSON_HEDLEY_UNLIKELY(!unexpect_eof(input_format_t::ubjson, "char")))
+                if (JSON_HEDLEY_UNLIKELY(!unexpect_eof(input_format, "char")))
                     return false;
                 if (JSON_HEDLEY_UNLIKELY(current > 127))
-                    return sax->parse_error(chars_read, last_token, parse_error::create(113, chars_read, exception_message(input_format_t::ubjson, "byte after 'C' must be in range 0x00..0x7F; last byte: 0x" + last_token, "char")));
+                                            exception_message(input_format, concat("byte after 'C' must be in range 0x00..0x7F; last byte: 0x", last_token), "char"), nullptr));
                 string_t s(1, static_cast<typename string_t::value_type>(current));
                 return sax->string(s);
@@ -9792,11 +11614,10 @@ class binary_reader
                 return get_ubjson_object();
-                return sax->parse_error(chars_read, last_token, parse_error::create(112, chars_read, exception_message(input_format_t::ubjson, "invalid byte: 0x" + last_token, "value")));
+                break;
+        return sax->parse_error(chars_read, last_token, parse_error::create(112, chars_read, exception_message(input_format, "invalid byte: 0x" + last_token, "value"), nullptr));
@@ -9810,7 +11631,53 @@ class binary_reader
             return false;
-        if (size_and_type.first != string_t::npos)
+        // if bit-8 of size_and_type.second is set to 1, encode bjdata ndarray as an object in JData annotated array format (https://github.com/NeuroJSON/jdata):
+        // {"_ArrayType_" : "typeid", "_ArraySize_" : [n1, n2, ...], "_ArrayData_" : [v1, v2, ...]}
+        if (input_format == input_format_t::bjdata && size_and_type.first != npos && (size_and_type.second & (1 << 8)) != 0)
+            size_and_type.second &= ~(static_cast<char_int_type>(1) << 8);  // use bit 8 to indicate ndarray, here we remove the bit to restore the type marker
+            auto it = std::lower_bound(bjd_types_map.begin(), bjd_types_map.end(), size_and_type.second, [](const bjd_type & p, char_int_type t)
+                return p.first < t;
+            string_t key = "_ArrayType_";
+            if (JSON_HEDLEY_UNLIKELY(it == bjd_types_map.end() || it->first != size_and_type.second))
+                                        exception_message(input_format, "invalid byte: 0x" + last_token, "type"), nullptr));
+            string_t type = it->second; // sax->string() takes a reference
+            if (JSON_HEDLEY_UNLIKELY(!sax->key(key) || !sax->string(type)))
+                return false;
+            if (size_and_type.second == 'C')
+                size_and_type.second = 'U';
+            key = "_ArrayData_";
+            if (JSON_HEDLEY_UNLIKELY(!sax->key(key) || !sax->start_array(size_and_type.first) ))
+                return false;
+                if (JSON_HEDLEY_UNLIKELY(!get_ubjson_value(size_and_type.second)))
+                    return false;
+            return (sax->end_array() && sax->end_object());
             if (JSON_HEDLEY_UNLIKELY(!sax->start_array(size_and_type.first)))
@@ -9843,7 +11710,7 @@ class binary_reader
         else
                 return false;
@@ -9872,8 +11739,16 @@ class binary_reader
             return false;
+        // do not accept ND-array size in objects in BJData
+                                    exception_message(input_format, "BJData object does not support ND-array size in optimized format", "object"), nullptr));
         string_t key;
             if (JSON_HEDLEY_UNLIKELY(!sax->start_object(size_and_type.first)))
@@ -9913,7 +11788,7 @@ class binary_reader
         else
                 return false;
@@ -9943,7 +11818,8 @@ class binary_reader
         // get size of following number string
         std::size_t size{};
-        auto res = get_ubjson_size_value(size);
+        auto res = get_ubjson_size_value(size, no_ndarray);
         if (JSON_HEDLEY_UNLIKELY(!res))
             return res;
@@ -9954,7 +11830,7 @@ class binary_reader
         for (std::size_t i = 0; i < size; ++i)
             get();
-            if (JSON_HEDLEY_UNLIKELY(!unexpect_eof(input_format_t::ubjson, "number")))
                 return false;
@@ -9962,8 +11838,8 @@ class binary_reader
         // parse number string
-        auto number_ia = detail::input_adapter(std::forward<decltype(number_vector)>(number_vector));
-        auto number_lexer = detail::lexer<BasicJsonType, decltype(number_ia)>(std::move(number_ia), false);
+        using ia_type = decltype(detail::input_adapter(number_vector));
+        auto number_lexer = detail::lexer<BasicJsonType, ia_type>(detail::input_adapter(number_vector), false);
         const auto result_number = number_lexer.scan();
         const auto number_string = number_lexer.get_token_string();
         const auto result_remainder = number_lexer.scan();
@@ -9972,7 +11848,8 @@ class binary_reader
         if (JSON_HEDLEY_UNLIKELY(result_remainder != token_type::end_of_input))
-            return sax->parse_error(chars_read, number_string, parse_error::create(115, chars_read, exception_message(input_format_t::ubjson, "invalid number text: " + number_lexer.get_token_string(), "high-precision number")));
+            return sax->parse_error(chars_read, number_string, parse_error::create(115, chars_read,
+                                    exception_message(input_format, concat("invalid number text: ", number_lexer.get_token_string()), "high-precision number"), nullptr));
         switch (result_number)
@@ -9983,8 +11860,23 @@ class binary_reader
                 return sax->number_unsigned(number_lexer.get_number_unsigned());
             case token_type::value_float:
                 return sax->number_float(number_lexer.get_number_float(), std::move(number_string));
+            case token_type::uninitialized:
+            case token_type::literal_true:
+            case token_type::literal_false:
+            case token_type::literal_null:
+            case token_type::value_string:
+            case token_type::begin_array:
+            case token_type::begin_object:
+            case token_type::end_array:
+            case token_type::end_object:
+            case token_type::name_separator:
+            case token_type::value_separator:
+            case token_type::parse_error:
+            case token_type::end_of_input:
+            case token_type::literal_or_value:
             default:
@@ -9997,7 +11889,7 @@ class binary_reader
     not throw in case the input reached EOF, but returns a -'ve valued
-    `std::char_traits<char_type>::eof()` in that case.
+    `char_traits<char_type>::eof()` in that case.
@@ -10033,12 +11925,14 @@ class binary_reader
     @note This function needs to respect the system's endianness, because
           bytes in CBOR, MessagePack, and UBJSON are stored in network order
           (big endian) and therefore need reordering on little endian systems.
+          On the other hand, BSON and BJData use little endian and should reorder
+          on big endian systems.
     template<typename NumberType, bool InputIsLittleEndian = false>
     bool get_number(const input_format_t format, NumberType& result)
         // step 1: read input into array with system's byte order
-        std::array<std::uint8_t, sizeof(NumberType)> vec;
+        std::array<std::uint8_t, sizeof(NumberType)> vec{};
         for (std::size_t i = 0; i < sizeof(NumberType); ++i)
             get();
@@ -10048,7 +11942,7 @@ class binary_reader
             // reverse byte order prior to conversion if necessary
-            if (is_little_endian != InputIsLittleEndian)
+            if (is_little_endian != (InputIsLittleEndian || format == input_format_t::bjdata))
                 vec[sizeof(NumberType) - i - 1] = static_cast<std::uint8_t>(current);
@@ -10137,10 +12031,10 @@ class binary_reader
     bool unexpect_eof(const input_format_t format, const char* context) const
-        if (JSON_HEDLEY_UNLIKELY(current == std::char_traits<char_type>::eof()))
+        if (JSON_HEDLEY_UNLIKELY(current == char_traits<char_type>::eof()))
             return sax->parse_error(chars_read, "<end of file>",
-                                    parse_error::create(110, chars_read, exception_message(format, "unexpected end of input", context)));
+                                    parse_error::create(110, chars_read, exception_message(format, "unexpected end of input", context), nullptr));
         return true;
@@ -10151,7 +12045,7 @@ class binary_reader
     std::string get_token_string() const
-        (std::snprintf)(cr.data(), cr.size(), "%.2hhX", static_cast<unsigned char>(current));
+        static_cast<void>((std::snprintf)(cr.data(), cr.size(), "%.2hhX", static_cast<unsigned char>(current))); // NOLINT(cppcoreguidelines-pro-type-vararg,hicpp-vararg)
         return std::string{cr.data()};
@@ -10185,37 +12079,93 @@ class binary_reader
                 error_msg += "BSON";
                 break;
+                error_msg += "BJData";
+                break;
-        return error_msg + " " + context + ": " + detail;
+        return concat(error_msg, ' ', context, ": ", detail);
   private:
+    static JSON_INLINE_VARIABLE constexpr std::size_t npos = static_cast<std::size_t>(-1);
     /// input adapter
     InputAdapterType ia;
     /// the number of characters read
     std::size_t chars_read = 0;
     /// whether we can assume little endianness
-    const bool is_little_endian = little_endianess();
+    const bool is_little_endian = little_endianness();
+    /// input format
+    const input_format_t input_format = input_format_t::json;
     /// the SAX parser
     json_sax_t* sax = nullptr;
+    // excluded markers in bjdata optimized type
+#define JSON_BINARY_READER_MAKE_BJD_OPTIMIZED_TYPE_MARKERS_ \
+    make_array<char_int_type>('F', 'H', 'N', 'S', 'T', 'Z', '[', '{')
+#define JSON_BINARY_READER_MAKE_BJD_TYPES_MAP_ \
+    make_array<bjd_type>(                      \
+    bjd_type{'C', "char"},                     \
+    bjd_type{'D', "double"},                   \
+    bjd_type{'I', "int16"},                    \
+    bjd_type{'L', "int64"},                    \
+    bjd_type{'M', "uint64"},                   \
+    bjd_type{'U', "uint8"},                    \
+    bjd_type{'d', "single"},                   \
+    bjd_type{'i', "int8"},                     \
+    bjd_type{'l', "int32"},                    \
+    bjd_type{'m', "uint32"},                   \
+    bjd_type{'u', "uint16"})
+  JSON_PRIVATE_UNLESS_TESTED:
+    // lookup tables
+    // NOLINTNEXTLINE(cppcoreguidelines-non-private-member-variables-in-classes)
+    const decltype(JSON_BINARY_READER_MAKE_BJD_OPTIMIZED_TYPE_MARKERS_) bjd_optimized_type_markers =
+        JSON_BINARY_READER_MAKE_BJD_OPTIMIZED_TYPE_MARKERS_;
+    using bjd_type = std::pair<char_int_type, string_t>;
+    const decltype(JSON_BINARY_READER_MAKE_BJD_TYPES_MAP_) bjd_types_map =
+        JSON_BINARY_READER_MAKE_BJD_TYPES_MAP_;
+#undef JSON_BINARY_READER_MAKE_BJD_OPTIMIZED_TYPE_MARKERS_
+#undef JSON_BINARY_READER_MAKE_BJD_TYPES_MAP_
+#ifndef JSON_HAS_CPP_17
+    template<typename BasicJsonType, typename InputAdapterType, typename SAX>
+    constexpr std::size_t binary_reader<BasicJsonType, InputAdapterType, SAX>::npos;
+#endif
-}  // namespace nlohmann
 // #include <nlohmann/detail/input/parser.hpp>
+//     __ _____ _____ _____
+//  __|  |   __|     |   | |  JSON for Modern C++
+// |  |  |__   |  |  | | | |  version 3.11.3
+// |_____|_____|_____|_|___|  https://github.com/nlohmann/json
+// SPDX-FileCopyrightText: 2013-2023 Niels Lohmann <https://nlohmann.me>
+// SPDX-License-Identifier: MIT
 #include <cmath> // isfinite
@@ -10237,18 +12187,19 @@ class binary_reader
-namespace nlohmann
+NLOHMANN_JSON_NAMESPACE_BEGIN
 namespace detail
 // parser //
-enum class parse_event_t : uint8_t
+enum class parse_event_t : std::uint8_t
     /// the parser read `{` and started to process a JSON object
     object_start,
@@ -10266,7 +12217,7 @@ enum class parse_event_t : uint8_t
 template<typename BasicJsonType>
 using parser_callback_t =
-    std::function<bool(int depth, parse_event_t event, BasicJsonType& parsed)>;
+    std::function<bool(int /*depth*/, parse_event_t /*event*/, BasicJsonType& /*parsed*/)>;
 @brief syntax analysis
@@ -10313,7 +12264,6 @@ class parser
             json_sax_dom_callback_parser<BasicJsonType> sdp(result, callback, allow_exceptions);
             sax_parse_internal(&sdp);
-            result.assert_invariant();
             // in strict mode, input must be completely read
             if (strict && (get_token() != token_type::end_of_input))
@@ -10321,7 +12271,7 @@ class parser
                 sdp.parse_error(m_lexer.get_position(),
                                 m_lexer.get_token_string(),
                                 parse_error::create(101, m_lexer.get_position(),
-                                                    exception_message(token_type::end_of_input, "value")));
+                                                    exception_message(token_type::end_of_input, "value"), nullptr));
             // in case of an error, return discarded value
@@ -10342,15 +12292,13 @@ class parser
             json_sax_dom_parser<BasicJsonType> sdp(result, allow_exceptions);
-                                parse_error::create(101, m_lexer.get_position(),
+                                parse_error::create(101, m_lexer.get_position(), exception_message(token_type::end_of_input, "value"), nullptr));
@@ -10360,6 +12308,8 @@ class parser
                 return;
+        result.assert_invariant();
@@ -10386,8 +12336,7 @@ class parser
             return sax->parse_error(m_lexer.get_position(),
         return result;
@@ -10413,7 +12362,7 @@ class parser
                             return false;
@@ -10433,8 +12382,7 @@ class parser
-                                                            exception_message(token_type::value_string, "object key")));
+                                                    parse_error::create(101, m_lexer.get_position(), exception_message(token_type::value_string, "object key"), nullptr));
                         if (JSON_HEDLEY_UNLIKELY(!sax->key(m_lexer.get_string())))
@@ -10446,8 +12394,7 @@ class parser
-                                                            exception_message(token_type::name_separator, "object separator")));
+                                                    parse_error::create(101, m_lexer.get_position(), exception_message(token_type::name_separator, "object separator"), nullptr));
                         // remember we are now inside an object
@@ -10460,7 +12407,7 @@ class parser
                             return false;
@@ -10490,7 +12437,7 @@ class parser
-                                                    out_of_range::create(406, "number overflow parsing '" + m_lexer.get_token_string() + "'"));
+                                                    out_of_range::create(406, concat("number overflow parsing '", m_lexer.get_token_string(), '\''), nullptr));
                         if (JSON_HEDLEY_UNLIKELY(!sax->number_float(res, m_lexer.get_string())))
@@ -10560,16 +12507,33 @@ class parser
                         // using "uninitialized" to avoid "expected" message
-                                                        exception_message(token_type::uninitialized, "value")));
+                                                parse_error::create(101, m_lexer.get_position(), exception_message(token_type::uninitialized, "value"), nullptr));
+                        if (JSON_HEDLEY_UNLIKELY(m_lexer.get_position().chars_read_total == 1))
+                            return sax->parse_error(m_lexer.get_position(),
+                                                    m_lexer.get_token_string(),
+                                                            "attempting to parse an empty input; check that your input string or stream contains the expected JSON", nullptr));
+                                                parse_error::create(101, m_lexer.get_position(), exception_message(token_type::literal_or_value, "value"), nullptr));
                     default: // the last token was unexpected
-                                                        exception_message(token_type::literal_or_value, "value")));
@@ -10615,65 +12579,61 @@ class parser
-                                                exception_message(token_type::end_array, "array")));
+                                        parse_error::create(101, m_lexer.get_position(), exception_message(token_type::end_array, "array"), nullptr));
-            else  // object
+            // states.back() is false -> object
+            // comma -> next value
+            if (get_token() == token_type::value_separator)
-                // comma -> next value
-                if (get_token() == token_type::value_separator)
+                // parse key
+                if (JSON_HEDLEY_UNLIKELY(get_token() != token_type::value_string))
-                    // parse key
-                    if (JSON_HEDLEY_UNLIKELY(get_token() != token_type::value_string))
-                        return sax->parse_error(m_lexer.get_position(),
-                                                m_lexer.get_token_string(),
-                    if (JSON_HEDLEY_UNLIKELY(!sax->key(m_lexer.get_string())))
-                        return false;
-                    // parse separator (:)
-                    if (JSON_HEDLEY_UNLIKELY(get_token() != token_type::name_separator))
-                    // parse values
-                    get_token();
-                    continue;
-                // closing }
-                if (JSON_HEDLEY_LIKELY(last_token == token_type::end_object))
+                if (JSON_HEDLEY_UNLIKELY(!sax->key(m_lexer.get_string())))
-                    if (JSON_HEDLEY_UNLIKELY(!sax->end_object()))
-                        return false;
-                    // We are done with this object. Before we can parse a
-                    // new value, we need to evaluate the new state first.
-                    // By setting skip_to_state_evaluation to false, we
-                    // are effectively jumping to the beginning of this if.
-                    JSON_ASSERT(!states.empty());
-                    states.pop_back();
-                    skip_to_state_evaluation = true;
-                    continue;
+                    return false;
-                                                exception_message(token_type::end_object, "object")));
+                // parse separator (:)
+                if (JSON_HEDLEY_UNLIKELY(get_token() != token_type::name_separator))
+                // parse values
+                get_token();
+                continue;
+            // closing }
+            if (JSON_HEDLEY_LIKELY(last_token == token_type::end_object))
+                if (JSON_HEDLEY_UNLIKELY(!sax->end_object()))
+                    return false;
+                // We are done with this object. Before we can parse a
+                // new value, we need to evaluate the new state first.
+                // By setting skip_to_state_evaluation to false, we
+                // are effectively jumping to the beginning of this if.
+                JSON_ASSERT(!states.empty());
+                states.pop_back();
+                skip_to_state_evaluation = true;
+                continue;
+                                    parse_error::create(101, m_lexer.get_position(), exception_message(token_type::end_object, "object"), nullptr));
@@ -10689,24 +12649,24 @@ class parser
         if (!context.empty())
-            error_msg += "while parsing " + context + " ";
+            error_msg += concat("while parsing ", context, ' ');
         error_msg += "- ";
         if (last_token == token_type::parse_error)
-            error_msg += std::string(m_lexer.get_error_message()) + "; last read: '" +
-                         m_lexer.get_token_string() + "'";
+            error_msg += concat(m_lexer.get_error_message(), "; last read: '",
+                                m_lexer.get_token_string(), '\'');
         else
-            error_msg += "unexpected " + std::string(lexer_t::token_type_name(last_token));
+            error_msg += concat("unexpected ", lexer_t::token_type_name(last_token));
         if (expected != token_type::uninitialized)
-            error_msg += "; expected " + std::string(lexer_t::token_type_name(expected));
+            error_msg += concat("; expected ", lexer_t::token_type_name(expected));
         return error_msg;
@@ -10722,13 +12682,32 @@ class parser
     /// whether to throw exceptions in case of errors
     const bool allow_exceptions = true;
 // #include <nlohmann/detail/iterators/internal_iterator.hpp>
 // #include <nlohmann/detail/iterators/primitive_iterator.hpp>
 #include <cstddef> // ptrdiff_t
@@ -10737,10 +12716,10 @@ class parser
 // #include <nlohmann/detail/macro_scope.hpp>
-namespace nlohmann
 namespace detail
 @brief an iterator for primitive JSON types
@@ -10819,7 +12798,7 @@ class primitive_iterator_t
         return *this;
-    primitive_iterator_t const operator++(int) noexcept
+    primitive_iterator_t operator++(int)& noexcept // NOLINT(cert-dcl21-cpp)
         auto result = *this;
         ++m_it;
@@ -10832,7 +12811,7 @@ class primitive_iterator_t
         return *this;
-    primitive_iterator_t const operator--(int) noexcept
+    primitive_iterator_t operator--(int)& noexcept // NOLINT(cert-dcl21-cpp)
         --m_it;
@@ -10851,14 +12830,15 @@ class primitive_iterator_t
         return *this;
-namespace nlohmann
 namespace detail
 @brief an iterator value
@@ -10874,10 +12854,19 @@ template<typename BasicJsonType> struct internal_iterator
     /// generic iterator for all other types
     primitive_iterator_t primitive_iterator {};
 // #include <nlohmann/detail/iterators/iter_impl.hpp>
 #include <iterator> // iterator, random_access_iterator_tag, bidirectional_iterator_tag, advance, next
@@ -10898,10 +12887,10 @@ template<typename BasicJsonType> struct internal_iterator
 // #include <nlohmann/detail/value_t.hpp>
-namespace nlohmann
 namespace detail
 // forward declare, to be able to friend it later on
 template<typename IteratorType> class iteration_proxy;
 template<typename IteratorType> class iteration_proxy_value;
@@ -10923,7 +12912,7 @@ This class implements a both iterators (iterator and const_iterator) for the
        iterators in version 3.0.0 (see https://github.com/nlohmann/json/issues/593)
-class iter_impl
+class iter_impl // NOLINT(cppcoreguidelines-special-member-functions,hicpp-special-member-functions)
     /// the iterator with BasicJsonType of different const-ness
     using other_iter_impl = iter_impl<typename std::conditional<std::is_const<BasicJsonType>::value, typename std::remove_const<BasicJsonType>::type, const BasicJsonType>::type>;
@@ -10938,9 +12927,12 @@ class iter_impl
     // make sure BasicJsonType is basic_json or const basic_json
     static_assert(is_basic_json<typename std::remove_const<BasicJsonType>::type>::value,
                   "iter_impl only accepts (const) basic_json");
+    // superficial check for the LegacyBidirectionalIterator named requirement
+    static_assert(std::is_base_of<std::bidirectional_iterator_tag, std::bidirectional_iterator_tag>::value
+                  &&  std::is_base_of<std::bidirectional_iterator_tag, typename std::iterator_traits<typename array_t::iterator>::iterator_category>::value,
+                  "basic_json iterator assumes array and object type iterators satisfy the LegacyBidirectionalIterator named requirement.");
   public:
     /// The std::iterator class template (used as a base class to provide typedefs) is deprecated in C++17.
     /// The C++ Standard has never required user-defined iterators to derive from std::iterator.
     /// A user-defined iterator should provide publicly accessible typedefs named
@@ -10962,8 +12954,10 @@ class iter_impl
         typename BasicJsonType::const_reference,
         typename BasicJsonType::reference>::type;
-    /// default constructor
     iter_impl() = default;
+    ~iter_impl() = default;
+    iter_impl(iter_impl&&) noexcept = default;
+    iter_impl& operator=(iter_impl&&) noexcept = default;
     @brief constructor for a given JSON instance
@@ -10975,7 +12969,7 @@ class iter_impl
         JSON_ASSERT(m_object != nullptr);
-        switch (m_object->m_type)
+        switch (m_object->m_data.m_type)
             case value_t::object:
@@ -10989,6 +12983,14 @@ class iter_impl
                 break;
+            case value_t::null:
+            case value_t::string:
+            case value_t::boolean:
+            case value_t::number_integer:
+            case value_t::number_unsigned:
+            case value_t::number_float:
+            case value_t::binary:
+            case value_t::discarded:
             default:
                 m_it.primitive_iterator = primitive_iterator_t();
@@ -11025,8 +13027,11 @@ class iter_impl
     iter_impl& operator=(const iter_impl<const BasicJsonType>& other) noexcept
-        m_object = other.m_object;
-        m_it = other.m_it;
+        if (&other != this)
+            m_object = other.m_object;
+            m_it = other.m_it;
         return *this;
@@ -11045,7 +13050,7 @@ class iter_impl
     @return const/non-const iterator
     @note It is not checked whether @a other is initialized.
-    iter_impl& operator=(const iter_impl<typename std::remove_const<BasicJsonType>::type>& other) noexcept
+    iter_impl& operator=(const iter_impl<typename std::remove_const<BasicJsonType>::type>& other) noexcept // NOLINT(cert-oop54-cpp)
         m_it = other.m_it;
@@ -11061,17 +13066,17 @@ class iter_impl
-                m_it.object_iterator = m_object->m_value.object->begin();
+                m_it.object_iterator = m_object->m_data.m_value.object->begin();
                 break;
             case value_t::array:
-                m_it.array_iterator = m_object->m_value.array->begin();
+                m_it.array_iterator = m_object->m_data.m_value.array->begin();
                 break;
@@ -11082,6 +13087,13 @@ class iter_impl
                 break;
             default:
                 m_it.primitive_iterator.set_begin();
@@ -11098,20 +13110,28 @@ class iter_impl
-                m_it.object_iterator = m_object->m_value.object->end();
+                m_it.object_iterator = m_object->m_data.m_value.object->end();
                 break;
-                m_it.array_iterator = m_object->m_value.array->end();
+                m_it.array_iterator = m_object->m_data.m_value.array->end();
                 break;
             default:
                 m_it.primitive_iterator.set_end();
@@ -11129,23 +13149,30 @@ class iter_impl
-                JSON_ASSERT(m_it.object_iterator != m_object->m_value.object->end());
+                JSON_ASSERT(m_it.object_iterator != m_object->m_data.m_value.object->end());
                 return m_it.object_iterator->second;
-                JSON_ASSERT(m_it.array_iterator != m_object->m_value.array->end());
+                JSON_ASSERT(m_it.array_iterator != m_object->m_data.m_value.array->end());
                 return *m_it.array_iterator;
             case value_t::null:
-                JSON_THROW(invalid_iterator::create(214, "cannot get value"));
+                JSON_THROW(invalid_iterator::create(214, "cannot get value", m_object));
             default:
                 if (JSON_HEDLEY_LIKELY(m_it.primitive_iterator.is_begin()))
@@ -11153,7 +13180,7 @@ class iter_impl
                     return *m_object;
@@ -11166,20 +13193,28 @@ class iter_impl
                 return &(m_it.object_iterator->second);
                 return &*m_it.array_iterator;
             default:
@@ -11187,7 +13222,7 @@ class iter_impl
                     return m_object;
@@ -11196,7 +13231,7 @@ class iter_impl
     @brief post-increment (it++)
     @pre The iterator is initialized; i.e. `m_object != nullptr`.
-    iter_impl const operator++(int)
+    iter_impl operator++(int)& // NOLINT(cert-dcl21-cpp)
         ++(*this);
@@ -11211,7 +13246,7 @@ class iter_impl
@@ -11225,6 +13260,14 @@ class iter_impl
                 break;
             default:
                 ++m_it.primitive_iterator;
@@ -11239,7 +13282,7 @@ class iter_impl
     @brief post-decrement (it--)
-    iter_impl const operator--(int)
+    iter_impl operator--(int)& // NOLINT(cert-dcl21-cpp)
         --(*this);
@@ -11254,7 +13297,7 @@ class iter_impl
@@ -11268,6 +13311,14 @@ class iter_impl
                 break;
             default:
                 --m_it.primitive_iterator;
@@ -11288,12 +13339,12 @@ class iter_impl
         // if objects are not the same, the comparison is undefined
         if (JSON_HEDLEY_UNLIKELY(m_object != other.m_object))
-            JSON_THROW(invalid_iterator::create(212, "cannot compare iterators of different containers"));
+            JSON_THROW(invalid_iterator::create(212, "cannot compare iterators of different containers", m_object));
                 return (m_it.object_iterator == other.m_it.object_iterator);
@@ -11301,6 +13352,14 @@ class iter_impl
                 return (m_it.array_iterator == other.m_it.array_iterator);
             default:
                 return (m_it.primitive_iterator == other.m_it.primitive_iterator);
@@ -11325,19 +13384,27 @@ class iter_impl
-                JSON_THROW(invalid_iterator::create(213, "cannot compare order of object iterators"));
+                JSON_THROW(invalid_iterator::create(213, "cannot compare order of object iterators", m_object));
                 return (m_it.array_iterator < other.m_it.array_iterator);
             default:
                 return (m_it.primitive_iterator < other.m_it.primitive_iterator);
@@ -11378,10 +13445,10 @@ class iter_impl
-                JSON_THROW(invalid_iterator::create(209, "cannot use offsets with object iterators"));
+                JSON_THROW(invalid_iterator::create(209, "cannot use offsets with object iterators", m_object));
@@ -11389,6 +13456,14 @@ class iter_impl
                 break;
             default:
                 m_it.primitive_iterator += i;
@@ -11449,14 +13524,22 @@ class iter_impl
                 return m_it.array_iterator - other.m_it.array_iterator;
             default:
                 return m_it.primitive_iterator - other.m_it.primitive_iterator;
@@ -11470,17 +13553,24 @@ class iter_impl
-                JSON_THROW(invalid_iterator::create(208, "cannot use operator[] for object iterators"));
+                JSON_THROW(invalid_iterator::create(208, "cannot use operator[] for object iterators", m_object));
                 return *std::next(m_it.array_iterator, n);
             case value_t::null:
             default:
                 if (JSON_HEDLEY_LIKELY(m_it.primitive_iterator.get_value() == -n))
@@ -11488,7 +13578,7 @@ class iter_impl
                     return *m_object;
@@ -11506,7 +13596,7 @@ class iter_impl
             return m_it.object_iterator->first;
-        JSON_THROW(invalid_iterator::create(207, "cannot use key() for non-object iterators"));
+        JSON_THROW(invalid_iterator::create(207, "cannot use key() for non-object iterators", m_object));
@@ -11524,22 +13614,34 @@ class iter_impl
     /// the actual iterator of the associated instance
     internal_iterator<typename std::remove_const<BasicJsonType>::type> m_it {};
-} // namespace detail
+}  // namespace detail
+NLOHMANN_JSON_NAMESPACE_END
 // #include <nlohmann/detail/iterators/iteration_proxy.hpp>
 // #include <nlohmann/detail/iterators/json_reverse_iterator.hpp>
 #include <iterator> // reverse_iterator
-namespace nlohmann
 namespace detail
 // reverse_iterator //
@@ -11580,7 +13682,7 @@ class json_reverse_iterator : public std::reverse_iterator<Base>
     explicit json_reverse_iterator(const base_iterator& it) noexcept : base_iterator(it) {}
     /// post-increment (it++)
-    json_reverse_iterator const operator++(int)
+    json_reverse_iterator operator++(int)& // NOLINT(cert-dcl21-cpp)
         return static_cast<json_reverse_iterator>(base_iterator::operator++(1));
@@ -11592,7 +13694,7 @@ class json_reverse_iterator : public std::reverse_iterator<Base>
     /// post-decrement (it--)
-    json_reverse_iterator const operator--(int)
+    json_reverse_iterator operator--(int)& // NOLINT(cert-dcl21-cpp)
         return static_cast<json_reverse_iterator>(base_iterator::operator--(1));
@@ -11647,16 +13749,72 @@ class json_reverse_iterator : public std::reverse_iterator<Base>
         return it.operator * ();
+// #include <nlohmann/detail/json_custom_base_class.hpp>
+#include <type_traits> // conditional, is_same
+namespace detail
+ at brief Default base class of the @ref basic_json class.
+So that the correct implementations of the copy / move ctors / assign operators
+of @ref basic_json do not require complex case distinctions
+(no base class / custom base class used as customization point),
+ at ref basic_json always has a base class.
+By default, this class is used because it is empty and thus has no effect
+on the behavior of @ref basic_json.
+struct json_default_base {};
+template<class T>
+using json_base_class = typename std::conditional <
+                        std::is_same<T, void>::value,
+                        json_default_base,
+                        T
+                        >::type;
 // #include <nlohmann/detail/json_pointer.hpp>
 #include <algorithm> // all_of
 #include <cctype> // isdigit
+#include <cerrno> // errno, ERANGE
+#include <cstdlib> // strtoull
+#ifndef JSON_NO_IO
+    #include <iosfwd> // ostream
+#endif  // JSON_NO_IO
 #include <limits> // max
 #include <numeric> // accumulate
 #include <string> // string
@@ -11667,90 +13825,81 @@ class json_reverse_iterator : public std::reverse_iterator<Base>
+// #include <nlohmann/detail/string_escape.hpp>
-namespace nlohmann
-template<typename BasicJsonType>
+/// @brief JSON Pointer defines a string syntax for identifying a specific value within a JSON document
+/// @sa https://json.nlohmann.me/api/json_pointer/
+template<typename RefStringType>
 class json_pointer
     // allow basic_json to access private members
     NLOHMANN_BASIC_JSON_TPL_DECLARATION
     friend class basic_json;
+    template<typename>
+    friend class json_pointer;
+    template<typename T>
+    struct string_t_helper
+        using type = T;
+    NLOHMANN_BASIC_JSON_TPL_DECLARATION
+    struct string_t_helper<NLOHMANN_BASIC_JSON_TPL>
+        using type = StringType;
   public:
-    @brief create JSON pointer
+    // for backwards compatibility accept BasicJsonType
+    using string_t = typename string_t_helper<RefStringType>::type;
-    Create a JSON pointer according to the syntax described in
-    [Section 3 of RFC6901](https://tools.ietf.org/html/rfc6901#section-3).
-    @param[in] s  string representing the JSON pointer; if omitted, the empty
-                  string is assumed which references the whole JSON value
-    @throw parse_error.107 if the given JSON pointer @a s is nonempty and does
-                           not begin with a slash (`/`); see example below
-    @throw parse_error.108 if a tilde (`~`) in the given JSON pointer @a s is
-    not followed by `0` (representing `~`) or `1` (representing `/`); see
-    example below
-    @liveexample{The example shows the construction several valid JSON pointers
-    as well as the exceptional behavior.,json_pointer}
-    @since version 2.0.0
-    explicit json_pointer(const std::string& s = "")
+    /// @brief create JSON pointer
+    /// @sa https://json.nlohmann.me/api/json_pointer/json_pointer/
+    explicit json_pointer(const string_t& s = "")
         : reference_tokens(split(s))
-    @brief return a string representation of the JSON pointer
-    @invariant For each JSON pointer `ptr`, it holds:
-    @code {.cpp}
-    ptr == json_pointer(ptr.to_string());
-    @endcode
-    @return a string representation of the JSON pointer
-    @liveexample{The example shows the result of `to_string`.,json_pointer__to_string}
-    std::string to_string() const
+    /// @brief return a string representation of the JSON pointer
+    /// @sa https://json.nlohmann.me/api/json_pointer/to_string/
+    string_t to_string() const
         return std::accumulate(reference_tokens.begin(), reference_tokens.end(),
-                               std::string{},
-                               [](const std::string & a, const std::string & b)
+                               string_t{},
+                               [](const string_t& a, const string_t& b)
-            return a + "/" + escape(b);
+            return detail::concat(a, '/', detail::escape(b));
-    /// @copydoc to_string()
-    operator std::string() const
+    /// @sa https://json.nlohmann.me/api/json_pointer/operator_string/
+    JSON_HEDLEY_DEPRECATED_FOR(3.11.0, to_string())
+    operator string_t() const
         return to_string();
-    @brief append another JSON pointer at the end of this JSON pointer
+#ifndef JSON_NO_IO
+    /// @brief write string representation of the JSON pointer to stream
+    /// @sa https://json.nlohmann.me/api/basic_json/operator_ltlt/
+    friend std::ostream& operator<<(std::ostream& o, const json_pointer& ptr)
+        o << ptr.to_string();
+        return o;
+#endif
-    @param[in] ptr  JSON pointer to append
-    @return JSON pointer with @a ptr appended
-    @liveexample{The example shows the usage of `operator/=`.,json_pointer__operator_add}
-    @complexity Linear in the length of @a ptr.
-    @sa @ref operator/=(std::string) to append a reference token
-    @sa @ref operator/=(std::size_t) to append an array index
-    @sa @ref operator/(const json_pointer&, const json_pointer&) for a binary operator
-    @since version 3.6.0
+    /// @brief append another JSON pointer at the end of this JSON pointer
+    /// @sa https://json.nlohmann.me/api/json_pointer/operator_slasheq/
     json_pointer& operator/=(const json_pointer& ptr)
         reference_tokens.insert(reference_tokens.end(),
@@ -11759,123 +13908,45 @@ class json_pointer
         return *this;
-    @brief append an unescaped reference token at the end of this JSON pointer
-    @param[in] token  reference token to append
-    @return JSON pointer with @a token appended without escaping @a token
-    @complexity Amortized constant.
-    @sa @ref operator/=(const json_pointer&) to append a JSON pointer
-    @sa @ref operator/(const json_pointer&, std::size_t) for a binary operator
-    json_pointer& operator/=(std::string token)
+    /// @brief append an unescaped reference token at the end of this JSON pointer
+    json_pointer& operator/=(string_t token)
         push_back(std::move(token));
         return *this;
-    @brief append an array index at the end of this JSON pointer
-    @param[in] array_idx  array index to append
-    @return JSON pointer with @a array_idx appended
-    @sa @ref operator/(const json_pointer&, std::string) for a binary operator
+    /// @brief append an array index at the end of this JSON pointer
     json_pointer& operator/=(std::size_t array_idx)
         return *this /= std::to_string(array_idx);
-    @brief create a new JSON pointer by appending the right JSON pointer at the end of the left JSON pointer
-    @param[in] lhs  JSON pointer
-    @param[in] rhs  JSON pointer
-    @return a new JSON pointer with @a rhs appended to @a lhs
-    @liveexample{The example shows the usage of `operator/`.,json_pointer__operator_add_binary}
-    @complexity Linear in the length of @a lhs and @a rhs.
+    /// @brief create a new JSON pointer by appending the right JSON pointer at the end of the left JSON pointer
+    /// @sa https://json.nlohmann.me/api/json_pointer/operator_slash/
     friend json_pointer operator/(const json_pointer& lhs,
                                   const json_pointer& rhs)
         return json_pointer(lhs) /= rhs;
-    @brief create a new JSON pointer by appending the unescaped token at the end of the JSON pointer
-    @return a new JSON pointer with unescaped @a token appended to @a ptr
-    friend json_pointer operator/(const json_pointer& ptr, std::string token)
+    /// @brief create a new JSON pointer by appending the unescaped token at the end of the JSON pointer
+    friend json_pointer operator/(const json_pointer& lhs, string_t token) // NOLINT(performance-unnecessary-value-param)
-        return json_pointer(ptr) /= std::move(token);
+        return json_pointer(lhs) /= std::move(token);
-    @brief create a new JSON pointer by appending the array-index-token at the end of the JSON pointer
-    @return a new JSON pointer with @a array_idx appended to @a ptr
-    friend json_pointer operator/(const json_pointer& ptr, std::size_t array_idx)
+    /// @brief create a new JSON pointer by appending the array-index-token at the end of the JSON pointer
+    friend json_pointer operator/(const json_pointer& lhs, std::size_t array_idx)
-        return json_pointer(ptr) /= array_idx;
+        return json_pointer(lhs) /= array_idx;
-    @brief returns the parent of this JSON pointer
-    @return parent of this JSON pointer; in case this JSON pointer is the root,
-            the root itself is returned
-    @complexity Linear in the length of the JSON pointer.
-    @liveexample{The example shows the result of `parent_pointer` for different
-    JSON Pointers.,json_pointer__parent_pointer}
+    /// @brief returns the parent of this JSON pointer
+    /// @sa https://json.nlohmann.me/api/json_pointer/parent_pointer/
     json_pointer parent_pointer() const
         if (empty())
@@ -11888,90 +13959,46 @@ class json_pointer
         return res;
-    @brief remove last reference token
-    @pre not `empty()`
-    @liveexample{The example shows the usage of `pop_back`.,json_pointer__pop_back}
-    @complexity Constant.
-    @throw out_of_range.405 if JSON pointer has no parent
+    /// @brief remove last reference token
+    /// @sa https://json.nlohmann.me/api/json_pointer/pop_back/
     void pop_back()
         if (JSON_HEDLEY_UNLIKELY(empty()))
-            JSON_THROW(detail::out_of_range::create(405, "JSON pointer has no parent"));
+            JSON_THROW(detail::out_of_range::create(405, "JSON pointer has no parent", nullptr));
         reference_tokens.pop_back();
-    @brief return last reference token
-    @return last reference token
-    @liveexample{The example shows the usage of `back`.,json_pointer__back}
-    const std::string& back() const
+    /// @brief return last reference token
+    /// @sa https://json.nlohmann.me/api/json_pointer/back/
+    const string_t& back() const
         return reference_tokens.back();
-    @brief append an unescaped token at the end of the reference pointer
-    @param[in] token  token to add
-    @liveexample{The example shows the result of `push_back` for different
-    JSON Pointers.,json_pointer__push_back}
-    void push_back(const std::string& token)
+    /// @brief append an unescaped token at the end of the reference pointer
+    /// @sa https://json.nlohmann.me/api/json_pointer/push_back/
+    void push_back(const string_t& token)
         reference_tokens.push_back(token);
-    /// @copydoc push_back(const std::string&)
-    void push_back(std::string&& token)
+    void push_back(string_t&& token)
         reference_tokens.push_back(std::move(token));
-    @brief return whether pointer points to the root document
-    @return true iff the JSON pointer points to the root document
-    @exceptionsafety No-throw guarantee: this function never throws exceptions.
-    @liveexample{The example shows the result of `empty` for different JSON
-    Pointers.,json_pointer__empty}
+    /// @brief return whether pointer points to the root document
+    /// @sa https://json.nlohmann.me/api/json_pointer/empty/
     bool empty() const noexcept
         return reference_tokens.empty();
@@ -11988,46 +14015,39 @@ class json_pointer
     @throw out_of_range.404 if string @a s could not be converted to an integer
     @throw out_of_range.410 if an array index exceeds size_type
-    static typename BasicJsonType::size_type array_index(const std::string& s)
+    template<typename BasicJsonType>
+    static typename BasicJsonType::size_type array_index(const string_t& s)
         using size_type = typename BasicJsonType::size_type;
         // error condition (cf. RFC 6901, Sect. 4)
         if (JSON_HEDLEY_UNLIKELY(s.size() > 1 && s[0] == '0'))
-            JSON_THROW(detail::parse_error::create(106, 0,
-                                                   "array index '" + s +
-                                                   "' must not begin with '0'"));
+            JSON_THROW(detail::parse_error::create(106, 0, detail::concat("array index '", s, "' must not begin with '0'"), nullptr));
         if (JSON_HEDLEY_UNLIKELY(s.size() > 1 && !(s[0] >= '1' && s[0] <= '9')))
-            JSON_THROW(detail::parse_error::create(109, 0, "array index '" + s + "' is not a number"));
+            JSON_THROW(detail::parse_error::create(109, 0, detail::concat("array index '", s, "' is not a number"), nullptr));
-        std::size_t processed_chars = 0;
-        unsigned long long res = 0;
-        JSON_TRY
+        const char* p = s.c_str();
+        char* p_end = nullptr;
+        errno = 0; // strtoull doesn't reset errno
+        const unsigned long long res = std::strtoull(p, &p_end, 10); // NOLINT(runtime/int)
+        if (p == p_end // invalid input or empty string
+                || errno == ERANGE // out of range
+                || JSON_HEDLEY_UNLIKELY(static_cast<std::size_t>(p_end - p) != s.size())) // incomplete read
-            res = std::stoull(s, &processed_chars);
-        JSON_CATCH(std::out_of_range&)
-            JSON_THROW(detail::out_of_range::create(404, "unresolved reference token '" + s + "'"));
-        // check if the string was completely read
-        if (JSON_HEDLEY_UNLIKELY(processed_chars != s.size()))
+            JSON_THROW(detail::out_of_range::create(404, detail::concat("unresolved reference token '", s, "'"), nullptr));
         // only triggered on special platforms (like 32bit), see also
         // https://github.com/nlohmann/json/pull/2203
-        if (res >= static_cast<unsigned long long>((std::numeric_limits<size_type>::max)()))
+        if (res >= static_cast<unsigned long long>((std::numeric_limits<size_type>::max)()))  // NOLINT(runtime/int)
-            JSON_THROW(detail::out_of_range::create(410, "array index " + s + " exceeds size_type")); // LCOV_EXCL_LINE
+            JSON_THROW(detail::out_of_range::create(410, detail::concat("array index ", s, " exceeds size_type"), nullptr));   // LCOV_EXCL_LINE
         return static_cast<size_type>(res);
@@ -12038,7 +14058,7 @@ class json_pointer
         json_pointer result = *this;
@@ -12055,9 +14075,10 @@ class json_pointer
     @throw parse_error.109 if array index is not a number
     @throw type_error.313 if value cannot be unflattened
     BasicJsonType& get_and_create(BasicJsonType& j) const
-        auto result = &j;
+        auto* result = &j;
         // in case no reference tokens exist, return a reference to the JSON value
         // j which will be overwritten by a primitive value
@@ -12090,7 +14111,7 @@ class json_pointer
                 case detail::value_t::array:
                     // create an entry in the array
-                    result = &result->operator[](array_index(reference_token));
+                    result = &result->operator[](array_index<BasicJsonType>(reference_token));
                     break;
@@ -12100,8 +14121,15 @@ class json_pointer
                 an error situation, because primitive values may only occur as
                 single value; that is, with an empty list of reference tokens.
+                case detail::value_t::string:
+                case detail::value_t::boolean:
+                case detail::value_t::number_integer:
+                case detail::value_t::number_unsigned:
+                case detail::value_t::number_float:
+                case detail::value_t::binary:
+                case detail::value_t::discarded:
                 default:
-                    JSON_THROW(detail::type_error::create(313, "invalid value to unflatten"));
+                    JSON_THROW(detail::type_error::create(313, "invalid value to unflatten", &j));
@@ -12127,6 +14155,7 @@ class json_pointer
     @throw parse_error.109   if an array index was not a number
     @throw out_of_range.404  if the JSON pointer can not be resolved
     BasicJsonType& get_unchecked(BasicJsonType* ptr) const
         for (const auto& reference_token : reference_tokens)
@@ -12162,18 +14191,26 @@ class json_pointer
                     if (reference_token == "-")
                         // explicitly treat "-" as index beyond the end
-                        ptr = &ptr->operator[](ptr->m_value.array->size());
+                        ptr = &ptr->operator[](ptr->m_data.m_value.array->size());
                     else
                         // convert array index to number; unchecked access
-                        ptr = &ptr->operator[](array_index(reference_token));
+                        ptr = &ptr->operator[](array_index<BasicJsonType>(reference_token));
                     break;
+                case detail::value_t::null:
                 default:
-                    JSON_THROW(detail::out_of_range::create(404, "unresolved reference token '" + reference_token + "'"));
+                    JSON_THROW(detail::out_of_range::create(404, detail::concat("unresolved reference token '", reference_token, "'"), ptr));
@@ -12186,6 +14223,7 @@ class json_pointer
     @throw out_of_range.402  if the array index '-' is used
     BasicJsonType& get_checked(BasicJsonType* ptr) const
@@ -12204,18 +14242,26 @@ class json_pointer
                     if (JSON_HEDLEY_UNLIKELY(reference_token == "-"))
                         // "-" always fails the range check
-                        JSON_THROW(detail::out_of_range::create(402,
-        "array index '-' (" + std::to_string(ptr->m_value.array->size()) +
-        ") is out of range"));
+                        JSON_THROW(detail::out_of_range::create(402, detail::concat(
+                                "array index '-' (", std::to_string(ptr->m_data.m_value.array->size()),
+                                ") is out of range"), ptr));
                     // note: at performs range check
-                    ptr = &ptr->at(array_index(reference_token));
+                    ptr = &ptr->at(array_index<BasicJsonType>(reference_token));
                     break;
                 default:
@@ -12235,6 +14281,7 @@ class json_pointer
     const BasicJsonType& get_unchecked(const BasicJsonType* ptr) const
@@ -12253,18 +14300,24 @@ class json_pointer
                         // "-" cannot be used for const access
+                        JSON_THROW(detail::out_of_range::create(402, detail::concat("array index '-' (", std::to_string(ptr->m_data.m_value.array->size()), ") is out of range"), ptr));
                     // use unchecked array access
                     break;
                 default:
@@ -12277,6 +14330,7 @@ class json_pointer
     const BasicJsonType& get_checked(const BasicJsonType* ptr) const
@@ -12295,18 +14349,26 @@ class json_pointer
                     break;
                 default:
@@ -12317,6 +14379,7 @@ class json_pointer
     @throw parse_error.106   if an array index begins with '0'
     bool contains(const BasicJsonType* ptr) const
@@ -12364,7 +14427,7 @@ class json_pointer
-                    const auto idx = array_index(reference_token);
+                    const auto idx = array_index<BasicJsonType>(reference_token);
                     if (idx >= ptr->size())
                         // index out of range
@@ -12375,6 +14438,14 @@ class json_pointer
                     break;
                 default:
                     // we do not expect primitive values if there is still a
@@ -12397,9 +14468,9 @@ class json_pointer
     @throw parse_error.107  if the pointer is not empty or begins with '/'
     @throw parse_error.108  if character '~' is not followed by '0' or '1'
-    static std::vector<std::string> split(const std::string& reference_string)
+    static std::vector<string_t> split(const string_t& reference_string)
-        std::vector<std::string> result;
+        std::vector<string_t> result;
         // special case: empty reference string -> no reference tokens
         if (reference_string.empty())
@@ -12410,9 +14481,7 @@ class json_pointer
         // check if nonempty reference string begins with slash
         if (JSON_HEDLEY_UNLIKELY(reference_string[0] != '/'))
-            JSON_THROW(detail::parse_error::create(107, 1,
-                                                   "JSON pointer must be empty or begin with '/' - was: '" +
-                                                   reference_string + "'"));
+            JSON_THROW(detail::parse_error::create(107, 1, detail::concat("JSON pointer must be empty or begin with '/' - was: '", reference_string, "'"), nullptr));
         // extract the reference tokens:
@@ -12423,11 +14492,11 @@ class json_pointer
             std::size_t slash = reference_string.find_first_of('/', 1),
             // set the beginning of the first reference token
             start = 1;
-            // we can stop if start == 0 (if slash == std::string::npos)
+            // we can stop if start == 0 (if slash == string_t::npos)
             start != 0;
             // set the beginning of the next reference token
-            // (will eventually be 0 if slash == std::string::npos)
-            start = (slash == std::string::npos) ? 0 : slash + 1,
+            // (will eventually be 0 if slash == string_t::npos)
+            start = (slash == string_t::npos) ? 0 : slash + 1,
             // find next slash
             slash = reference_string.find_first_of('/', start))
@@ -12437,7 +14506,7 @@ class json_pointer
             // check reference tokens are properly escaped
             for (std::size_t pos = reference_token.find_first_of('~');
-                    pos != std::string::npos;
+                    pos != string_t::npos;
                     pos = reference_token.find_first_of('~', pos + 1))
                 JSON_ASSERT(reference_token[pos] == '~');
@@ -12447,58 +14516,18 @@ class json_pointer
                                          (reference_token[pos + 1] != '0' &&
                                           reference_token[pos + 1] != '1')))
-                    JSON_THROW(detail::parse_error::create(108, 0, "escape character '~' must be followed with '0' or '1'"));
+                    JSON_THROW(detail::parse_error::create(108, 0, "escape character '~' must be followed with '0' or '1'", nullptr));
             // finally, store the reference token
-            unescape(reference_token);
+            detail::unescape(reference_token);
             result.push_back(reference_token);
         return result;
-    @brief replace all occurrences of a substring by another string
-    @param[in,out] s  the string to manipulate; changed so that all
-                   occurrences of @a f are replaced with @a t
-    @param[in]     f  the substring to replace with @a t
-    @param[in]     t  the string to replace @a f
-    @pre The search string @a f must not be empty. **This precondition is
-    enforced with an assertion.**
-    static void replace_substring(std::string& s, const std::string& f,
-                                  const std::string& t)
-        JSON_ASSERT(!f.empty());
-        for (auto pos = s.find(f);                // find first occurrence of f
-                pos != std::string::npos;         // make sure f was found
-                s.replace(pos, f.size(), t),      // replace with t, and
-                pos = s.find(f, pos + t.size()))  // find next occurrence of f
-  JSON_PRIVATE_UNLESS_TESTED:
-    /// escape "~" to "~0" and "/" to "~1"
-    static std::string escape(std::string s)
-        replace_substring(s, "~", "~0");
-        replace_substring(s, "/", "~1");
-        return s;
-    /// unescape "~1" to tilde and "~0" to slash (order is important!)
-    static void unescape(std::string& s)
-        replace_substring(s, "~1", "/");
-        replace_substring(s, "~0", "~");
   private:
     @param[in] reference_string  the reference string to the current value
@@ -12507,7 +14536,8 @@ class json_pointer
     @note Empty objects or arrays are flattened to `null`.
-    static void flatten(const std::string& reference_string,
+    static void flatten(const string_t& reference_string,
                         const BasicJsonType& value,
                         BasicJsonType& result)
@@ -12515,7 +14545,7 @@ class json_pointer
-                if (value.m_value.array->empty())
+                if (value.m_data.m_value.array->empty())
                     // flatten empty array as null
                     result[reference_string] = nullptr;
@@ -12523,10 +14553,10 @@ class json_pointer
                 else
                     // iterate array and use index as reference string
-                    for (std::size_t i = 0; i < value.m_value.array->size(); ++i)
+                    for (std::size_t i = 0; i < value.m_data.m_value.array->size(); ++i)
-                        flatten(reference_string + "/" + std::to_string(i),
-                                value.m_value.array->operator[](i), result);
+                        flatten(detail::concat(reference_string, '/', std::to_string(i)),
+                                value.m_data.m_value.array->operator[](i), result);
                 break;
@@ -12534,7 +14564,7 @@ class json_pointer
             case detail::value_t::object:
-                if (value.m_value.object->empty())
+                if (value.m_data.m_value.object->empty())
                     // flatten empty object as null
@@ -12542,14 +14572,22 @@ class json_pointer
                 else
                     // iterate object and use keys as reference string
-                    for (const auto& element : *value.m_value.object)
+                    for (const auto& element : *value.m_data.m_value.object)
-                        flatten(reference_string + "/" + escape(element.first), element.second, result);
+                        flatten(detail::concat(reference_string, '/', detail::escape(element.first)), element.second, result);
                 break;
             default:
                 // add primitive value with its reference string
@@ -12569,22 +14607,23 @@ class json_pointer
     @throw type_error.315  if object values are not primitive
     static BasicJsonType
     unflatten(const BasicJsonType& value)
         if (JSON_HEDLEY_UNLIKELY(!value.is_object()))
-            JSON_THROW(detail::type_error::create(314, "only objects can be unflattened"));
+            JSON_THROW(detail::type_error::create(314, "only objects can be unflattened", &value));
         BasicJsonType result;
         // iterate the JSON object values
             if (JSON_HEDLEY_UNLIKELY(!element.second.is_primitive()))
-                JSON_THROW(detail::type_error::create(315, "values in object must be primitive"));
+                JSON_THROW(detail::type_error::create(315, "values in object must be primitive", &element.second));
             // assign value to reference pointed to by JSON pointer; Note that if
@@ -12597,58 +14636,185 @@ class json_pointer
         return result;
-    @brief compares two JSON pointers for equality
-    @param[in] lhs  JSON pointer to compare
-    @param[in] rhs  JSON pointer to compare
-    @return whether @a lhs is equal to @a rhs
-    friend bool operator==(json_pointer const& lhs,
-                           json_pointer const& rhs) noexcept
+    // can't use conversion operator because of ambiguity
+    json_pointer<string_t> convert() const&
-        return lhs.reference_tokens == rhs.reference_tokens;
+        json_pointer<string_t> result;
+        result.reference_tokens = reference_tokens;
+        return result;
-    @brief compares two JSON pointers for inequality
-    @return whether @a lhs is not equal @a rhs
-    friend bool operator!=(json_pointer const& lhs,
+    json_pointer<string_t> convert()&&
-        return !(lhs == rhs);
+        result.reference_tokens = std::move(reference_tokens);
+        return result;
+  public:
+#if JSON_HAS_THREE_WAY_COMPARISON
+    /// @brief compares two JSON pointers for equality
+    /// @sa https://json.nlohmann.me/api/json_pointer/operator_eq/
+    template<typename RefStringTypeRhs>
+    bool operator==(const json_pointer<RefStringTypeRhs>& rhs) const noexcept
+        return reference_tokens == rhs.reference_tokens;
+    /// @brief compares JSON pointer and string for equality
+    JSON_HEDLEY_DEPRECATED_FOR(3.11.2, operator==(json_pointer))
+    bool operator==(const string_t& rhs) const
+        return *this == json_pointer(rhs);
+    /// @brief 3-way compares two JSON pointers
+    std::strong_ordering operator<=>(const json_pointer<RefStringTypeRhs>& rhs) const noexcept // *NOPAD*
+        return  reference_tokens <=> rhs.reference_tokens; // *NOPAD*
+#else
+    template<typename RefStringTypeLhs, typename RefStringTypeRhs>
+    // NOLINTNEXTLINE(readability-redundant-declaration)
+    friend bool operator==(const json_pointer<RefStringTypeLhs>& lhs,
+                           const json_pointer<RefStringTypeRhs>& rhs) noexcept;
+    template<typename RefStringTypeLhs, typename StringType>
+                           const StringType& rhs);
+    /// @brief compares string and JSON pointer for equality
+    template<typename RefStringTypeRhs, typename StringType>
+    friend bool operator==(const StringType& lhs,
+                           const json_pointer<RefStringTypeRhs>& rhs);
+    /// @brief compares two JSON pointers for inequality
+    /// @sa https://json.nlohmann.me/api/json_pointer/operator_ne/
+    friend bool operator!=(const json_pointer<RefStringTypeLhs>& lhs,
+    /// @brief compares JSON pointer and string for inequality
+    /// @brief compares string and JSON pointer for inequality
+    friend bool operator!=(const StringType& lhs,
+    /// @brief compares two JSON pointer for less-than
+    friend bool operator<(const json_pointer<RefStringTypeLhs>& lhs,
+#endif
+  private:
     /// the reference tokens
-    std::vector<std::string> reference_tokens;
+    std::vector<string_t> reference_tokens;
+#if !JSON_HAS_THREE_WAY_COMPARISON
+// functions cannot be defined inside class due to ODR violations
+template<typename RefStringTypeLhs, typename RefStringTypeRhs>
+inline bool operator==(const json_pointer<RefStringTypeLhs>& lhs,
+    return lhs.reference_tokens == rhs.reference_tokens;
+         typename StringType = typename json_pointer<RefStringTypeLhs>::string_t>
+JSON_HEDLEY_DEPRECATED_FOR(3.11.2, operator==(json_pointer, json_pointer))
+    return lhs == json_pointer<RefStringTypeLhs>(rhs);
+template<typename RefStringTypeRhs,
+         typename StringType = typename json_pointer<RefStringTypeRhs>::string_t>
+inline bool operator==(const StringType& lhs,
+    return json_pointer<RefStringTypeRhs>(lhs) == rhs;
+inline bool operator!=(const json_pointer<RefStringTypeLhs>& lhs,
+    return !(lhs == rhs);
+JSON_HEDLEY_DEPRECATED_FOR(3.11.2, operator!=(json_pointer, json_pointer))
+inline bool operator!=(const StringType& lhs,
+inline bool operator<(const json_pointer<RefStringTypeLhs>& lhs,
+    return lhs.reference_tokens < rhs.reference_tokens;
+#endif
 // #include <nlohmann/detail/json_ref.hpp>
 #include <initializer_list>
 #include <utility>
+// #include <nlohmann/detail/abi_macros.hpp>
 // #include <nlohmann/detail/meta/type_traits.hpp>
-namespace nlohmann
 namespace detail
 class json_ref
@@ -12675,7 +14841,7 @@ class json_ref
     // class should be movable only
-    json_ref(json_ref&&) = default;
+    json_ref(json_ref&&) noexcept = default;
     json_ref(const json_ref&) = delete;
     json_ref& operator=(const json_ref&) = delete;
     json_ref& operator=(json_ref&&) = delete;
@@ -12704,54 +14870,88 @@ class json_ref
     mutable value_type owned_value = nullptr;
     value_type const* value_ref = nullptr;
+// #include <nlohmann/detail/string_concat.hpp>
 // #include <nlohmann/detail/meta/cpp_future.hpp>
 // #include <nlohmann/detail/output/binary_writer.hpp>
 #include <algorithm> // reverse
 #include <array> // array
+#include <map> // map
+#include <cmath> // isnan, isinf
 #include <cstdint> // uint8_t, uint16_t, uint32_t, uint64_t
 #include <cstring> // memcpy
 #include <limits> // numeric_limits
-#include <cmath> // isnan, isinf
+#include <utility> // move
+#include <vector> // vector
 // #include <nlohmann/detail/input/binary_reader.hpp>
 // #include <nlohmann/detail/output/output_adapters.hpp>
 #include <algorithm> // copy
 #include <cstddef> // size_t
-#include <ios> // streamsize
 #include <iterator> // back_inserter
 #include <memory> // shared_ptr, make_shared
-#include <ostream> // basic_ostream
 #include <string> // basic_string
+#ifndef JSON_NO_IO
+    #include <ios>      // streamsize
+    #include <ostream>  // basic_ostream
-namespace nlohmann
 namespace detail
 /// abstract output adapter interface
 template<typename CharType> struct output_adapter_protocol
     virtual void write_character(CharType c) = 0;
     virtual void write_characters(const CharType* s, std::size_t length) = 0;
     virtual ~output_adapter_protocol() = default;
+    output_adapter_protocol() = default;
+    output_adapter_protocol(const output_adapter_protocol&) = default;
+    output_adapter_protocol(output_adapter_protocol&&) noexcept = default;
+    output_adapter_protocol& operator=(const output_adapter_protocol&) = default;
+    output_adapter_protocol& operator=(output_adapter_protocol&&) noexcept = default;
 /// a type to simplify interfaces
@@ -12759,11 +14959,11 @@ template<typename CharType>
 using output_adapter_t = std::shared_ptr<output_adapter_protocol<CharType>>;
 /// output adapter for byte vectors
-template<typename CharType>
+template<typename CharType, typename AllocatorType = std::allocator<CharType>>
 class output_vector_adapter : public output_adapter_protocol<CharType>
   public:
-    explicit output_vector_adapter(std::vector<CharType>& vec) noexcept
+    explicit output_vector_adapter(std::vector<CharType, AllocatorType>& vec) noexcept
         : v(vec)
@@ -12775,13 +14975,14 @@ class output_vector_adapter : public output_adapter_protocol<CharType>
     JSON_HEDLEY_NON_NULL(2)
     void write_characters(const CharType* s, std::size_t length) override
-        std::copy(s, s + length, std::back_inserter(v));
+        v.insert(v.end(), s, s + length);
   private:
-    std::vector<CharType>& v;
+    std::vector<CharType, AllocatorType>& v;
+#ifndef JSON_NO_IO
 /// output adapter for output streams
 class output_stream_adapter : public output_adapter_protocol<CharType>
@@ -12805,6 +15006,7 @@ class output_stream_adapter : public output_adapter_protocol<CharType>
   private:
     std::basic_ostream<CharType>& stream;
 /// output adapter for basic_string
 template<typename CharType, typename StringType = std::basic_string<CharType>>
@@ -12834,11 +15036,14 @@ template<typename CharType, typename StringType = std::basic_string<CharType>>
 class output_adapter
   public:
-    output_adapter(std::vector<CharType>& vec)
-        : oa(std::make_shared<output_vector_adapter<CharType>>(vec)) {}
+    template<typename AllocatorType = std::allocator<CharType>>
+    output_adapter(std::vector<CharType, AllocatorType>& vec)
+        : oa(std::make_shared<output_vector_adapter<CharType, AllocatorType>>(vec)) {}
+#ifndef JSON_NO_IO
     output_adapter(std::basic_ostream<CharType>& s)
         : oa(std::make_shared<output_stream_adapter<CharType>>(s)) {}
     output_adapter(StringType& s)
         : oa(std::make_shared<output_string_adapter<CharType, StringType>>(s)) {}
@@ -12851,14 +15056,17 @@ class output_adapter
   private:
     output_adapter_t<CharType> oa = nullptr;
-namespace nlohmann
 namespace detail
 // binary writer //
@@ -12879,7 +15087,7 @@ class binary_writer
     @param[in] adapter  output adapter to write to
-    explicit binary_writer(output_adapter_t<CharType> adapter) : oa(adapter)
+    explicit binary_writer(output_adapter_t<CharType> adapter) : oa(std::move(adapter))
         JSON_ASSERT(oa);
@@ -12894,13 +15102,22 @@ class binary_writer
-                write_bson_object(*j.m_value.object);
+                write_bson_object(*j.m_data.m_value.object);
                 break;
+            case value_t::array:
             default:
-                JSON_THROW(type_error::create(317, "to serialize to BSON, top-level type must be object, but is " + std::string(j.type_name())));
+                JSON_THROW(type_error::create(317, concat("to serialize to BSON, top-level type must be object, but is ", j.type_name()), &j));
@@ -12920,7 +15137,7 @@ class binary_writer
-                oa->write_character(j.m_value.boolean
+                oa->write_character(j.m_data.m_value.boolean
                                     ? to_char_type(0xF5)
                                     : to_char_type(0xF4));
                 break;
@@ -12928,42 +15145,42 @@ class binary_writer
-                if (j.m_value.number_integer >= 0)
+                if (j.m_data.m_value.number_integer >= 0)
                     // CBOR does not differentiate between positive signed
                     // integers and unsigned integers. Therefore, we used the
                     // code from the value_t::number_unsigned case here.
-                    if (j.m_value.number_integer <= 0x17)
+                    if (j.m_data.m_value.number_integer <= 0x17)
-                        write_number(static_cast<std::uint8_t>(j.m_value.number_integer));
+                        write_number(static_cast<std::uint8_t>(j.m_data.m_value.number_integer));
-                    else if (j.m_value.number_integer <= (std::numeric_limits<std::uint8_t>::max)())
+                    else if (j.m_data.m_value.number_integer <= (std::numeric_limits<std::uint8_t>::max)())
                         oa->write_character(to_char_type(0x18));
-                    else if (j.m_value.number_integer <= (std::numeric_limits<std::uint16_t>::max)())
+                    else if (j.m_data.m_value.number_integer <= (std::numeric_limits<std::uint16_t>::max)())
                         oa->write_character(to_char_type(0x19));
-                        write_number(static_cast<std::uint16_t>(j.m_value.number_integer));
+                        write_number(static_cast<std::uint16_t>(j.m_data.m_value.number_integer));
-                    else if (j.m_value.number_integer <= (std::numeric_limits<std::uint32_t>::max)())
+                    else if (j.m_data.m_value.number_integer <= (std::numeric_limits<std::uint32_t>::max)())
                         oa->write_character(to_char_type(0x1A));
-                        write_number(static_cast<std::uint32_t>(j.m_value.number_integer));
+                        write_number(static_cast<std::uint32_t>(j.m_data.m_value.number_integer));
                     else
                         oa->write_character(to_char_type(0x1B));
-                        write_number(static_cast<std::uint64_t>(j.m_value.number_integer));
+                        write_number(static_cast<std::uint64_t>(j.m_data.m_value.number_integer));
                 else
                     // The conversions below encode the sign in the first
                     // byte, and the value is converted to a positive number.
-                    const auto positive_number = -1 - j.m_value.number_integer;
-                    if (j.m_value.number_integer >= -24)
+                    const auto positive_number = -1 - j.m_data.m_value.number_integer;
+                    if (j.m_data.m_value.number_integer >= -24)
                         write_number(static_cast<std::uint8_t>(0x20 + positive_number));
@@ -12993,52 +15210,52 @@ class binary_writer
-                if (j.m_value.number_unsigned <= 0x17)
+                if (j.m_data.m_value.number_unsigned <= 0x17)
-                    write_number(static_cast<std::uint8_t>(j.m_value.number_unsigned));
+                    write_number(static_cast<std::uint8_t>(j.m_data.m_value.number_unsigned));
-                else if (j.m_value.number_unsigned <= (std::numeric_limits<std::uint8_t>::max)())
+                else if (j.m_data.m_value.number_unsigned <= (std::numeric_limits<std::uint8_t>::max)())
-                else if (j.m_value.number_unsigned <= (std::numeric_limits<std::uint16_t>::max)())
+                else if (j.m_data.m_value.number_unsigned <= (std::numeric_limits<std::uint16_t>::max)())
-                    write_number(static_cast<std::uint16_t>(j.m_value.number_unsigned));
+                    write_number(static_cast<std::uint16_t>(j.m_data.m_value.number_unsigned));
-                else if (j.m_value.number_unsigned <= (std::numeric_limits<std::uint32_t>::max)())
+                else if (j.m_data.m_value.number_unsigned <= (std::numeric_limits<std::uint32_t>::max)())
-                    write_number(static_cast<std::uint32_t>(j.m_value.number_unsigned));
+                    write_number(static_cast<std::uint32_t>(j.m_data.m_value.number_unsigned));
                 else
-                    write_number(static_cast<std::uint64_t>(j.m_value.number_unsigned));
+                    write_number(static_cast<std::uint64_t>(j.m_data.m_value.number_unsigned));
                 break;
-                if (std::isnan(j.m_value.number_float))
+                if (std::isnan(j.m_data.m_value.number_float))
                     // NaN is 0xf97e00 in CBOR
                     oa->write_character(to_char_type(0xF9));
                     oa->write_character(to_char_type(0x7E));
                     oa->write_character(to_char_type(0x00));
-                else if (std::isinf(j.m_value.number_float))
+                else if (std::isinf(j.m_data.m_value.number_float))
                     // Infinity is 0xf97c00, -Infinity is 0xf9fc00
                     oa->write_character(to_char_type(0xf9));
-                    oa->write_character(j.m_value.number_float > 0 ? to_char_type(0x7C) : to_char_type(0xFC));
+                    oa->write_character(j.m_data.m_value.number_float > 0 ? to_char_type(0x7C) : to_char_type(0xFC));
                 else
-                    write_compact_float(j.m_value.number_float, detail::input_format_t::cbor);
+                    write_compact_float(j.m_data.m_value.number_float, detail::input_format_t::cbor);
                 break;
@@ -13046,7 +15263,7 @@ class binary_writer
                 // step 1: write control byte and the string length
-                const auto N = j.m_value.string->size();
+                const auto N = j.m_data.m_value.string->size();
                 if (N <= 0x17)
                     write_number(static_cast<std::uint8_t>(0x60 + N));
@@ -13076,15 +15293,15 @@ class binary_writer
                 // step 2: write the string
                 oa->write_characters(
-                    reinterpret_cast<const CharType*>(j.m_value.string->c_str()),
-                    j.m_value.string->size());
+                    reinterpret_cast<const CharType*>(j.m_data.m_value.string->c_str()),
+                    j.m_data.m_value.string->size());
                 break;
                 // step 1: write control byte and the array size
-                const auto N = j.m_value.array->size();
+                const auto N = j.m_data.m_value.array->size();
                 if (N <= 0x17)
                     write_number(static_cast<std::uint8_t>(0x80 + N));
@@ -13113,7 +15330,7 @@ class binary_writer
                 // LCOV_EXCL_STOP
                 // step 2: write each element
-                for (const auto& el : *j.m_value.array)
+                for (const auto& el : *j.m_data.m_value.array)
                     write_cbor(el);
@@ -13122,14 +15339,32 @@ class binary_writer
-                if (j.m_value.binary->has_subtype())
+                if (j.m_data.m_value.binary->has_subtype())
-                    write_number(static_cast<std::uint8_t>(0xd8));
-                    write_number(j.m_value.binary->subtype());
+                    if (j.m_data.m_value.binary->subtype() <= (std::numeric_limits<std::uint8_t>::max)())
+                        write_number(static_cast<std::uint8_t>(0xd8));
+                        write_number(static_cast<std::uint8_t>(j.m_data.m_value.binary->subtype()));
+                    else if (j.m_data.m_value.binary->subtype() <= (std::numeric_limits<std::uint16_t>::max)())
+                        write_number(static_cast<std::uint8_t>(0xd9));
+                        write_number(static_cast<std::uint16_t>(j.m_data.m_value.binary->subtype()));
+                    else if (j.m_data.m_value.binary->subtype() <= (std::numeric_limits<std::uint32_t>::max)())
+                        write_number(static_cast<std::uint8_t>(0xda));
+                        write_number(static_cast<std::uint32_t>(j.m_data.m_value.binary->subtype()));
+                    else if (j.m_data.m_value.binary->subtype() <= (std::numeric_limits<std::uint64_t>::max)())
+                        write_number(static_cast<std::uint8_t>(0xdb));
+                        write_number(static_cast<std::uint64_t>(j.m_data.m_value.binary->subtype()));
                 // step 1: write control byte and the binary array size
-                const auto N = j.m_value.binary->size();
+                const auto N = j.m_data.m_value.binary->size();
                 if (N <= 0x17)
                     write_number(static_cast<std::uint8_t>(0x40 + N));
@@ -13159,7 +15394,7 @@ class binary_writer
-                    reinterpret_cast<const CharType*>(j.m_value.binary->data()),
+                    reinterpret_cast<const CharType*>(j.m_data.m_value.binary->data()),
                     N);
                 break;
@@ -13168,7 +15403,7 @@ class binary_writer
                 // step 1: write control byte and the object size
-                const auto N = j.m_value.object->size();
+                const auto N = j.m_data.m_value.object->size();
                 if (N <= 0x17)
                     write_number(static_cast<std::uint8_t>(0xA0 + N));
@@ -13197,7 +15432,7 @@ class binary_writer
                 // LCOV_EXCL_STOP
-                for (const auto& el : *j.m_value.object)
+                for (const auto& el : *j.m_data.m_value.object)
                     write_cbor(el.first);
                     write_cbor(el.second);
@@ -13205,6 +15440,7 @@ class binary_writer
                 break;
             default:
                 break;
@@ -13225,7 +15461,7 @@ class binary_writer
             case value_t::boolean: // true and false
                                     ? to_char_type(0xC3)
                                     : to_char_type(0xC2));
                 break;
@@ -13233,75 +15469,75 @@ class binary_writer
                     // MessagePack does not differentiate between positive
                     // signed integers and unsigned integers. Therefore, we used
                     // the code from the value_t::number_unsigned case here.
-                    if (j.m_value.number_unsigned < 128)
+                    if (j.m_data.m_value.number_unsigned < 128)
                         // positive fixnum
                         // uint 8
                         oa->write_character(to_char_type(0xCC));
                         // uint 16
                         oa->write_character(to_char_type(0xCD));
                         // uint 32
                         oa->write_character(to_char_type(0xCE));
-                    else if (j.m_value.number_unsigned <= (std::numeric_limits<std::uint64_t>::max)())
+                    else if (j.m_data.m_value.number_unsigned <= (std::numeric_limits<std::uint64_t>::max)())
                         // uint 64
                         oa->write_character(to_char_type(0xCF));
                 else
-                    if (j.m_value.number_integer >= -32)
+                    if (j.m_data.m_value.number_integer >= -32)
                         // negative fixnum
-                        write_number(static_cast<std::int8_t>(j.m_value.number_integer));
+                        write_number(static_cast<std::int8_t>(j.m_data.m_value.number_integer));
-                    else if (j.m_value.number_integer >= (std::numeric_limits<std::int8_t>::min)() &&
-                             j.m_value.number_integer <= (std::numeric_limits<std::int8_t>::max)())
+                    else if (j.m_data.m_value.number_integer >= (std::numeric_limits<std::int8_t>::min)() &&
+                             j.m_data.m_value.number_integer <= (std::numeric_limits<std::int8_t>::max)())
                         // int 8
                         oa->write_character(to_char_type(0xD0));
-                    else if (j.m_value.number_integer >= (std::numeric_limits<std::int16_t>::min)() &&
-                             j.m_value.number_integer <= (std::numeric_limits<std::int16_t>::max)())
+                    else if (j.m_data.m_value.number_integer >= (std::numeric_limits<std::int16_t>::min)() &&
+                             j.m_data.m_value.number_integer <= (std::numeric_limits<std::int16_t>::max)())
                         // int 16
                         oa->write_character(to_char_type(0xD1));
-                        write_number(static_cast<std::int16_t>(j.m_value.number_integer));
+                        write_number(static_cast<std::int16_t>(j.m_data.m_value.number_integer));
-                    else if (j.m_value.number_integer >= (std::numeric_limits<std::int32_t>::min)() &&
-                             j.m_value.number_integer <= (std::numeric_limits<std::int32_t>::max)())
+                    else if (j.m_data.m_value.number_integer >= (std::numeric_limits<std::int32_t>::min)() &&
+                             j.m_data.m_value.number_integer <= (std::numeric_limits<std::int32_t>::max)())
                         // int 32
                         oa->write_character(to_char_type(0xD2));
-                        write_number(static_cast<std::int32_t>(j.m_value.number_integer));
+                        write_number(static_cast<std::int32_t>(j.m_data.m_value.number_integer));
-                    else if (j.m_value.number_integer >= (std::numeric_limits<std::int64_t>::min)() &&
-                             j.m_value.number_integer <= (std::numeric_limits<std::int64_t>::max)())
+                    else if (j.m_data.m_value.number_integer >= (std::numeric_limits<std::int64_t>::min)() &&
+                             j.m_data.m_value.number_integer <= (std::numeric_limits<std::int64_t>::max)())
                         // int 64
                         oa->write_character(to_char_type(0xD3));
-                        write_number(static_cast<std::int64_t>(j.m_value.number_integer));
+                        write_number(static_cast<std::int64_t>(j.m_data.m_value.number_integer));
                 break;
@@ -13309,48 +15545,48 @@ class binary_writer
                     // positive fixnum
                     // uint 8
                     // uint 16
                     // uint 32
                     // uint 64
                 break;
-                write_compact_float(j.m_value.number_float, detail::input_format_t::msgpack);
+                write_compact_float(j.m_data.m_value.number_float, detail::input_format_t::msgpack);
                 break;
                 if (N <= 31)
                     // fixstr
@@ -13377,15 +15613,15 @@ class binary_writer
                 break;
                 if (N <= 15)
                     // fixarray
@@ -13405,7 +15641,7 @@ class binary_writer
                     write_msgpack(el);
@@ -13416,10 +15652,10 @@ class binary_writer
                 // step 0: determine if the binary type has a set subtype to
                 // determine whether or not to use the ext or fixext types
-                const bool use_ext = j.m_value.binary->has_subtype();
+                const bool use_ext = j.m_data.m_value.binary->has_subtype();
                 // step 1: write control byte and the byte string length
                 if (N <= (std::numeric_limits<std::uint8_t>::max)())
                     std::uint8_t output_type{};
@@ -13464,18 +15700,18 @@ class binary_writer
                 else if (N <= (std::numeric_limits<std::uint16_t>::max)())
-                    std::uint8_t output_type = use_ext
-                                               ? 0xC8 // ext 16
-                                               : 0xC5; // bin 16
+                    const std::uint8_t output_type = use_ext
+                                                     ? 0xC8 // ext 16
+                                                     : 0xC5; // bin 16
                     oa->write_character(to_char_type(output_type));
                     write_number(static_cast<std::uint16_t>(N));
                 else if (N <= (std::numeric_limits<std::uint32_t>::max)())
-                                               ? 0xC9 // ext 32
-                                               : 0xC6; // bin 32
+                                                     ? 0xC9 // ext 32
+                                                     : 0xC6; // bin 32
                     write_number(static_cast<std::uint32_t>(N));
@@ -13484,12 +15720,12 @@ class binary_writer
                 // step 1.5: if this is an ext type, write the subtype
                 if (use_ext)
-                    write_number(static_cast<std::int8_t>(j.m_value.binary->subtype()));
+                    write_number(static_cast<std::int8_t>(j.m_data.m_value.binary->subtype()));
                 // step 2: write the byte string
                     N);
                 break;
@@ -13498,7 +15734,7 @@ class binary_writer
                 if (N <= 15)
                     // fixmap
@@ -13518,7 +15754,7 @@ class binary_writer
                     write_msgpack(el.first);
                     write_msgpack(el.second);
@@ -13526,6 +15762,7 @@ class binary_writer
                 break;
             default:
                 break;
@@ -13536,9 +15773,11 @@ class binary_writer
     @param[in] use_count   whether to use '#' prefixes (optimized format)
     @param[in] use_type    whether to use '$' prefixes (optimized format)
     @param[in] add_prefix  whether prefixes need to be used for this value
+    @param[in] use_bjdata  whether write in BJData format, default is false
     void write_ubjson(const BasicJsonType& j, const bool use_count,
-                      const bool use_type, const bool add_prefix = true)
+                      const bool use_type, const bool add_prefix = true,
+                      const bool use_bjdata = false)
         switch (j.type())
@@ -13555,7 +15794,7 @@ class binary_writer
                 if (add_prefix)
                                         ? to_char_type('T')
                                         : to_char_type('F'));
@@ -13564,19 +15803,19 @@ class binary_writer
-                write_number_with_ubjson_prefix(j.m_value.number_integer, add_prefix);
+                write_number_with_ubjson_prefix(j.m_data.m_value.number_integer, add_prefix, use_bjdata);
                 break;
-                write_number_with_ubjson_prefix(j.m_value.number_unsigned, add_prefix);
+                write_number_with_ubjson_prefix(j.m_data.m_value.number_unsigned, add_prefix, use_bjdata);
                 break;
-                write_number_with_ubjson_prefix(j.m_value.number_float, add_prefix);
+                write_number_with_ubjson_prefix(j.m_data.m_value.number_float, add_prefix, use_bjdata);
                 break;
@@ -13586,10 +15825,10 @@ class binary_writer
                     oa->write_character(to_char_type('S'));
-                write_number_with_ubjson_prefix(j.m_value.string->size(), true);
+                write_number_with_ubjson_prefix(j.m_data.m_value.string->size(), true, use_bjdata);
                 break;
@@ -13601,17 +15840,19 @@ class binary_writer
                 bool prefix_required = true;
-                if (use_type && !j.m_value.array->empty())
+                if (use_type && !j.m_data.m_value.array->empty())
                     JSON_ASSERT(use_count);
-                    const CharType first_prefix = ubjson_prefix(j.front());
+                    const CharType first_prefix = ubjson_prefix(j.front(), use_bjdata);
                     const bool same_prefix = std::all_of(j.begin() + 1, j.end(),
-                                                         [this, first_prefix](const BasicJsonType & v)
+                                                         [this, first_prefix, use_bjdata](const BasicJsonType & v)
-                        return ubjson_prefix(v) == first_prefix;
+                        return ubjson_prefix(v, use_bjdata) == first_prefix;
-                    if (same_prefix)
+                    std::vector<CharType> bjdx = {'[', '{', 'S', 'H', 'T', 'F', 'N', 'Z'}; // excluded markers in bjdata optimized type
+                    if (same_prefix && !(use_bjdata && std::find(bjdx.begin(), bjdx.end(), first_prefix) != bjdx.end()))
                         prefix_required = false;
                         oa->write_character(to_char_type('$'));
@@ -13622,12 +15863,12 @@ class binary_writer
                 if (use_count)
                     oa->write_character(to_char_type('#'));
-                    write_number_with_ubjson_prefix(j.m_value.array->size(), true);
+                    write_number_with_ubjson_prefix(j.m_data.m_value.array->size(), true, use_bjdata);
-                    write_ubjson(el, use_count, use_type, prefix_required);
+                    write_ubjson(el, use_count, use_type, prefix_required, use_bjdata);
                 if (!use_count)
@@ -13645,7 +15886,7 @@ class binary_writer
                     oa->write_character(to_char_type('['));
-                if (use_type && !j.m_value.binary->empty())
+                if (use_type && !j.m_data.m_value.binary->empty())
@@ -13655,21 +15896,21 @@ class binary_writer
                 if (use_count)
-                    write_number_with_ubjson_prefix(j.m_value.binary->size(), true);
+                    write_number_with_ubjson_prefix(j.m_data.m_value.binary->size(), true, use_bjdata);
                 if (use_type)
-                        j.m_value.binary->size());
+                        j.m_data.m_value.binary->size());
                 else
-                    for (size_t i = 0; i < j.m_value.binary->size(); ++i)
+                    for (size_t i = 0; i < j.m_data.m_value.binary->size(); ++i)
                         oa->write_character(to_char_type('U'));
-                        oa->write_character(j.m_value.binary->data()[i]);
+                        oa->write_character(j.m_data.m_value.binary->data()[i]);
@@ -13683,23 +15924,33 @@ class binary_writer
+                if (use_bjdata && j.m_data.m_value.object->size() == 3 && j.m_data.m_value.object->find("_ArrayType_") != j.m_data.m_value.object->end() && j.m_data.m_value.object->find("_ArraySize_") != j.m_data.m_value.object->end() && j.m_data.m_value.object->find("_ArrayData_") != j.m_data.m_value.object->end())
+                    if (!write_bjdata_ndarray(*j.m_data.m_value.object, use_count, use_type))  // decode bjdata ndarray in the JData format (https://github.com/NeuroJSON/jdata)
+                        break;
                 if (add_prefix)
                     oa->write_character(to_char_type('{'));
-                if (use_type && !j.m_value.object->empty())
+                if (use_type && !j.m_data.m_value.object->empty())
                     const bool same_prefix = std::all_of(j.begin(), j.end(),
-                    if (same_prefix)
@@ -13710,16 +15961,16 @@ class binary_writer
                 if (use_count)
-                    write_number_with_ubjson_prefix(j.m_value.object->size(), true);
+                    write_number_with_ubjson_prefix(j.m_data.m_value.object->size(), true, use_bjdata);
-                    write_number_with_ubjson_prefix(el.first.size(), true);
+                    write_number_with_ubjson_prefix(el.first.size(), true, use_bjdata);
                         reinterpret_cast<const CharType*>(el.first.c_str()),
                         el.first.size());
-                    write_ubjson(el.second, use_count, use_type, prefix_required);
+                    write_ubjson(el.second, use_count, use_type, prefix_required, use_bjdata);
                 if (!use_count)
@@ -13730,6 +15981,7 @@ class binary_writer
                 break;
             default:
                 break;
@@ -13744,13 +15996,13 @@ class binary_writer
     @return The size of a BSON document entry header, including the id marker
             and the entry name size (and its null-terminator).
-    static std::size_t calc_bson_entry_header_size(const string_t& name)
+    static std::size_t calc_bson_entry_header_size(const string_t& name, const BasicJsonType& j)
         const auto it = name.find(static_cast<typename string_t::value_type>(0));
         if (JSON_HEDLEY_UNLIKELY(it != BasicJsonType::string_t::npos))
-            JSON_THROW(out_of_range::create(409,
-                                            "BSON key cannot contain code point U+0000 (at byte " + std::to_string(it) + ")"));
+            JSON_THROW(out_of_range::create(409, concat("BSON key cannot contain code point U+0000 (at byte ", std::to_string(it), ")"), &j));
+            static_cast<void>(j);
         return /*id*/ 1ul + name.size() + /*zero-terminator*/1u;
@@ -13785,7 +16037,7 @@ class binary_writer
                            const double value)
         write_bson_entry_header(name, 0x01);
-        write_number<double, true>(value);
+        write_number<double>(value, true);
@@ -13804,7 +16056,7 @@ class binary_writer
         write_bson_entry_header(name, 0x02);
-        write_number<std::int32_t, true>(static_cast<std::int32_t>(value.size() + 1ul));
+        write_number<std::int32_t>(static_cast<std::int32_t>(value.size() + 1ul), true);
             reinterpret_cast<const CharType*>(value.c_str()),
             value.size() + 1);
@@ -13837,12 +16089,12 @@ class binary_writer
         if ((std::numeric_limits<std::int32_t>::min)() <= value && value <= (std::numeric_limits<std::int32_t>::max)())
             write_bson_entry_header(name, 0x10); // int32
-            write_number<std::int32_t, true>(static_cast<std::int32_t>(value));
+            write_number<std::int32_t>(static_cast<std::int32_t>(value), true);
         else
             write_bson_entry_header(name, 0x12); // int64
-            write_number<std::int64_t, true>(static_cast<std::int64_t>(value));
+            write_number<std::int64_t>(static_cast<std::int64_t>(value), true);
@@ -13860,21 +16112,21 @@ class binary_writer
     @brief Writes a BSON element with key @a name and unsigned @a value
     void write_bson_unsigned(const string_t& name,
-                             const std::uint64_t value)
+                             const BasicJsonType& j)
-        if (value <= static_cast<std::uint64_t>((std::numeric_limits<std::int32_t>::max)()))
+        if (j.m_data.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::int32_t>::max)()))
             write_bson_entry_header(name, 0x10 /* int32 */);
+            write_number<std::int32_t>(static_cast<std::int32_t>(j.m_data.m_value.number_unsigned), true);
-        else if (value <= static_cast<std::uint64_t>((std::numeric_limits<std::int64_t>::max)()))
+        else if (j.m_data.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::int64_t>::max)()))
             write_bson_entry_header(name, 0x12 /* int64 */);
+            write_number<std::int64_t>(static_cast<std::int64_t>(j.m_data.m_value.number_unsigned), true);
         else
-            JSON_THROW(out_of_range::create(407, "integer number " + std::to_string(value) + " cannot be represented by BSON as it does not fit int64"));
+            JSON_THROW(out_of_range::create(407, concat("integer number ", std::to_string(j.m_data.m_value.number_unsigned), " cannot be represented by BSON as it does not fit int64"), &j));
@@ -13895,7 +16147,7 @@ class binary_writer
         std::size_t array_index = 0ul;
-        const std::size_t embedded_document_size = std::accumulate(std::begin(value), std::end(value), std::size_t(0), [&array_index](std::size_t result, const typename BasicJsonType::array_t::value_type & el)
+        const std::size_t embedded_document_size = std::accumulate(std::begin(value), std::end(value), static_cast<std::size_t>(0), [&array_index](std::size_t result, const typename BasicJsonType::array_t::value_type & el)
             return result + calc_bson_element_size(std::to_string(array_index++), el);
@@ -13918,7 +16170,7 @@ class binary_writer
                           const typename BasicJsonType::array_t& value)
         write_bson_entry_header(name, 0x04); // array
-        write_number<std::int32_t, true>(static_cast<std::int32_t>(calc_bson_array_size(value)));
+        write_number<std::int32_t>(static_cast<std::int32_t>(calc_bson_array_size(value)), true);
@@ -13938,8 +16190,8 @@ class binary_writer
         write_bson_entry_header(name, 0x05);
-        write_number<std::int32_t, true>(static_cast<std::int32_t>(value.size()));
-        write_number(value.has_subtype() ? value.subtype() : std::uint8_t(0x00));
+        write_number<std::int32_t>(static_cast<std::int32_t>(value.size()), true);
+        write_number(value.has_subtype() ? static_cast<std::uint8_t>(value.subtype()) : static_cast<std::uint8_t>(0x00));
         oa->write_characters(reinterpret_cast<const CharType*>(value.data()), value.size());
@@ -13951,17 +16203,17 @@ class binary_writer
     static std::size_t calc_bson_element_size(const string_t& name,
-        const auto header_size = calc_bson_entry_header_size(name);
+        const auto header_size = calc_bson_entry_header_size(name, j);
         switch (j.type())
             case value_t::object:
-                return header_size + calc_bson_object_size(*j.m_value.object);
+                return header_size + calc_bson_object_size(*j.m_data.m_value.object);
-                return header_size + calc_bson_array_size(*j.m_value.array);
+                return header_size + calc_bson_array_size(*j.m_data.m_value.array);
             case value_t::binary:
-                return header_size + calc_bson_binary_size(*j.m_value.binary);
+                return header_size + calc_bson_binary_size(*j.m_data.m_value.binary);
                 return header_size + 1ul;
@@ -13970,20 +16222,21 @@ class binary_writer
                 return header_size + 8ul;
             case value_t::number_integer:
-                return header_size + calc_bson_integer_size(j.m_value.number_integer);
+                return header_size + calc_bson_integer_size(j.m_data.m_value.number_integer);
             case value_t::number_unsigned:
-                return header_size + calc_bson_unsigned_size(j.m_value.number_unsigned);
+                return header_size + calc_bson_unsigned_size(j.m_data.m_value.number_unsigned);
             case value_t::string:
-                return header_size + calc_bson_string_size(*j.m_value.string);
+                return header_size + calc_bson_string_size(*j.m_data.m_value.string);
             case value_t::null:
                 return header_size + 0ul;
             // LCOV_EXCL_START
+            case value_t::discarded:
             default:
-                JSON_ASSERT(false);
+                JSON_ASSERT(false); // NOLINT(cert-dcl03-c,hicpp-static-assert,misc-static-assert)
                 return 0ul;
                 // LCOV_EXCL_STOP
@@ -13994,7 +16247,6 @@ class binary_writer
            key @a name.
     @param name The name to associate with the JSON entity @a j within the
                 current BSON document
-    @return The size of the BSON entry
     void write_bson_element(const string_t& name,
@@ -14002,35 +16254,36 @@ class binary_writer
         switch (j.type())
-                return write_bson_object_entry(name, *j.m_value.object);
+                return write_bson_object_entry(name, *j.m_data.m_value.object);
-                return write_bson_array(name, *j.m_value.array);
+                return write_bson_array(name, *j.m_data.m_value.array);
-                return write_bson_binary(name, *j.m_value.binary);
+                return write_bson_binary(name, *j.m_data.m_value.binary);
-                return write_bson_boolean(name, j.m_value.boolean);
+                return write_bson_boolean(name, j.m_data.m_value.boolean);
             case value_t::number_float:
-                return write_bson_double(name, j.m_value.number_float);
+                return write_bson_double(name, j.m_data.m_value.number_float);
-                return write_bson_integer(name, j.m_value.number_integer);
+                return write_bson_integer(name, j.m_data.m_value.number_integer);
-                return write_bson_unsigned(name, j.m_value.number_unsigned);
+                return write_bson_unsigned(name, j);
-                return write_bson_string(name, *j.m_value.string);
+                return write_bson_string(name, *j.m_data.m_value.string);
             case value_t::null:
                 return write_bson_null(name);
             // LCOV_EXCL_START
             default:
                 return;
                 // LCOV_EXCL_STOP
@@ -14039,13 +16292,13 @@ class binary_writer
     @brief Calculates the size of the BSON serialization of the given
            JSON-object @a j.
-    @param[in] j  JSON value to serialize
-    @pre       j.type() == value_t::object
+    @param[in] value  JSON value to serialize
+    @pre       value.type() == value_t::object
     static std::size_t calc_bson_object_size(const typename BasicJsonType::object_t& value)
-        std::size_t document_size = std::accumulate(value.begin(), value.end(), std::size_t(0),
-                                    [](size_t result, const typename BasicJsonType::object_t::value_type & el)
+        const std::size_t document_size = std::accumulate(value.begin(), value.end(), static_cast<std::size_t>(0),
+                                          [](size_t result, const typename BasicJsonType::object_t::value_type & el)
             return result += calc_bson_element_size(el.first, el.second);
@@ -14054,12 +16307,12 @@ class binary_writer
     void write_bson_object(const typename BasicJsonType::object_t& value)
-        write_number<std::int32_t, true>(static_cast<std::int32_t>(calc_bson_object_size(value)));
+        write_number<std::int32_t>(static_cast<std::int32_t>(calc_bson_object_size(value)), true);
         for (const auto& el : value)
@@ -14105,20 +16358,22 @@ class binary_writer
     template<typename NumberType, typename std::enable_if<
                  std::is_floating_point<NumberType>::value, int>::type = 0>
     void write_number_with_ubjson_prefix(const NumberType n,
-                                         const bool add_prefix)
+                                         const bool add_prefix,
+                                         const bool use_bjdata)
         if (add_prefix)
             oa->write_character(get_ubjson_float_prefix(n));
-        write_number(n);
+        write_number(n, use_bjdata);
     // UBJSON: write number (unsigned integer)
                  std::is_unsigned<NumberType>::value, int>::type = 0>
         if (n <= static_cast<std::uint64_t>((std::numeric_limits<std::int8_t>::max)()))
@@ -14126,7 +16381,7 @@ class binary_writer
                 oa->write_character(to_char_type('i'));  // int8
-            write_number(static_cast<std::uint8_t>(n));
+            write_number(static_cast<std::uint8_t>(n), use_bjdata);
         else if (n <= (std::numeric_limits<std::uint8_t>::max)())
@@ -14134,7 +16389,7 @@ class binary_writer
                 oa->write_character(to_char_type('U'));  // uint8
         else if (n <= static_cast<std::uint64_t>((std::numeric_limits<std::int16_t>::max)()))
@@ -14142,7 +16397,15 @@ class binary_writer
                 oa->write_character(to_char_type('I'));  // int16
-            write_number(static_cast<std::int16_t>(n));
+            write_number(static_cast<std::int16_t>(n), use_bjdata);
+        else if (use_bjdata && n <= static_cast<uint64_t>((std::numeric_limits<uint16_t>::max)()))
+            if (add_prefix)
+                oa->write_character(to_char_type('u'));  // uint16 - bjdata only
+            write_number(static_cast<std::uint16_t>(n), use_bjdata);
         else if (n <= static_cast<std::uint64_t>((std::numeric_limits<std::int32_t>::max)()))
@@ -14150,7 +16413,15 @@ class binary_writer
                 oa->write_character(to_char_type('l'));  // int32
-            write_number(static_cast<std::int32_t>(n));
+            write_number(static_cast<std::int32_t>(n), use_bjdata);
+        else if (use_bjdata && n <= static_cast<uint64_t>((std::numeric_limits<uint32_t>::max)()))
+            if (add_prefix)
+                oa->write_character(to_char_type('m'));  // uint32 - bjdata only
+            write_number(static_cast<std::uint32_t>(n), use_bjdata);
         else if (n <= static_cast<std::uint64_t>((std::numeric_limits<std::int64_t>::max)()))
@@ -14158,7 +16429,15 @@ class binary_writer
                 oa->write_character(to_char_type('L'));  // int64
-            write_number(static_cast<std::int64_t>(n));
+            write_number(static_cast<std::int64_t>(n), use_bjdata);
+        else if (use_bjdata && n <= (std::numeric_limits<uint64_t>::max)())
+            if (add_prefix)
+                oa->write_character(to_char_type('M'));  // uint64 - bjdata only
+            write_number(static_cast<std::uint64_t>(n), use_bjdata);
         else
@@ -14168,7 +16447,7 @@ class binary_writer
             const auto number = BasicJsonType(n).dump();
-            write_number_with_ubjson_prefix(number.size(), true);
+            write_number_with_ubjson_prefix(number.size(), true, use_bjdata);
             for (std::size_t i = 0; i < number.size(); ++i)
                 oa->write_character(to_char_type(static_cast<std::uint8_t>(number[i])));
@@ -14181,7 +16460,8 @@ class binary_writer
                    std::is_signed<NumberType>::value&&
                    !std::is_floating_point<NumberType>::value, int >::type = 0 >
         if ((std::numeric_limits<std::int8_t>::min)() <= n && n <= (std::numeric_limits<std::int8_t>::max)())
@@ -14189,7 +16469,7 @@ class binary_writer
-            write_number(static_cast<std::int8_t>(n));
+            write_number(static_cast<std::int8_t>(n), use_bjdata);
         else if (static_cast<std::int64_t>((std::numeric_limits<std::uint8_t>::min)()) <= n && n <= static_cast<std::int64_t>((std::numeric_limits<std::uint8_t>::max)()))
@@ -14197,7 +16477,7 @@ class binary_writer
         else if ((std::numeric_limits<std::int16_t>::min)() <= n && n <= (std::numeric_limits<std::int16_t>::max)())
@@ -14205,7 +16485,15 @@ class binary_writer
+        else if (use_bjdata && (static_cast<std::int64_t>((std::numeric_limits<std::uint16_t>::min)()) <= n && n <= static_cast<std::int64_t>((std::numeric_limits<std::uint16_t>::max)())))
+            if (add_prefix)
+            write_number(static_cast<uint16_t>(n), use_bjdata);
         else if ((std::numeric_limits<std::int32_t>::min)() <= n && n <= (std::numeric_limits<std::int32_t>::max)())
@@ -14213,7 +16501,15 @@ class binary_writer
+        else if (use_bjdata && (static_cast<std::int64_t>((std::numeric_limits<std::uint32_t>::min)()) <= n && n <= static_cast<std::int64_t>((std::numeric_limits<std::uint32_t>::max)())))
+            if (add_prefix)
+            write_number(static_cast<uint32_t>(n), use_bjdata);
         else if ((std::numeric_limits<std::int64_t>::min)() <= n && n <= (std::numeric_limits<std::int64_t>::max)())
@@ -14221,7 +16517,7 @@ class binary_writer
         // LCOV_EXCL_START
         else
@@ -14232,7 +16528,7 @@ class binary_writer
@@ -14244,7 +16540,7 @@ class binary_writer
     @brief determine the type prefix of container values
-    CharType ubjson_prefix(const BasicJsonType& j) const noexcept
+    CharType ubjson_prefix(const BasicJsonType& j, const bool use_bjdata) const noexcept
         switch (j.type())
@@ -14252,27 +16548,35 @@ class binary_writer
                 return 'Z';
-                return j.m_value.boolean ? 'T' : 'F';
+                return j.m_data.m_value.boolean ? 'T' : 'F';
-                if ((std::numeric_limits<std::int8_t>::min)() <= j.m_value.number_integer && j.m_value.number_integer <= (std::numeric_limits<std::int8_t>::max)())
+                if ((std::numeric_limits<std::int8_t>::min)() <= j.m_data.m_value.number_integer && j.m_data.m_value.number_integer <= (std::numeric_limits<std::int8_t>::max)())
                     return 'i';
-                if ((std::numeric_limits<std::uint8_t>::min)() <= j.m_value.number_integer && j.m_value.number_integer <= (std::numeric_limits<std::uint8_t>::max)())
+                if ((std::numeric_limits<std::uint8_t>::min)() <= j.m_data.m_value.number_integer && j.m_data.m_value.number_integer <= (std::numeric_limits<std::uint8_t>::max)())
                     return 'U';
-                if ((std::numeric_limits<std::int16_t>::min)() <= j.m_value.number_integer && j.m_value.number_integer <= (std::numeric_limits<std::int16_t>::max)())
+                if ((std::numeric_limits<std::int16_t>::min)() <= j.m_data.m_value.number_integer && j.m_data.m_value.number_integer <= (std::numeric_limits<std::int16_t>::max)())
                     return 'I';
-                if ((std::numeric_limits<std::int32_t>::min)() <= j.m_value.number_integer && j.m_value.number_integer <= (std::numeric_limits<std::int32_t>::max)())
+                if (use_bjdata && ((std::numeric_limits<std::uint16_t>::min)() <= j.m_data.m_value.number_integer && j.m_data.m_value.number_integer <= (std::numeric_limits<std::uint16_t>::max)()))
+                    return 'u';
+                if ((std::numeric_limits<std::int32_t>::min)() <= j.m_data.m_value.number_integer && j.m_data.m_value.number_integer <= (std::numeric_limits<std::int32_t>::max)())
                     return 'l';
-                if ((std::numeric_limits<std::int64_t>::min)() <= j.m_value.number_integer && j.m_value.number_integer <= (std::numeric_limits<std::int64_t>::max)())
+                if (use_bjdata && ((std::numeric_limits<std::uint32_t>::min)() <= j.m_data.m_value.number_integer && j.m_data.m_value.number_integer <= (std::numeric_limits<std::uint32_t>::max)()))
+                    return 'm';
+                if ((std::numeric_limits<std::int64_t>::min)() <= j.m_data.m_value.number_integer && j.m_data.m_value.number_integer <= (std::numeric_limits<std::int64_t>::max)())
                     return 'L';
@@ -14282,32 +16586,44 @@ class binary_writer
-                if (j.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::int8_t>::max)()))
+                if (j.m_data.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::int8_t>::max)()))
                     return 'i';
-                if (j.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::uint8_t>::max)()))
+                if (j.m_data.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::uint8_t>::max)()))
                     return 'U';
-                if (j.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::int16_t>::max)()))
+                if (j.m_data.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::int16_t>::max)()))
                     return 'I';
-                if (j.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::int32_t>::max)()))
+                if (use_bjdata && j.m_data.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::uint16_t>::max)()))
+                    return 'u';
                     return 'l';
-                if (j.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::int64_t>::max)()))
+                if (use_bjdata && j.m_data.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::uint32_t>::max)()))
+                    return 'm';
+                if (j.m_data.m_value.number_unsigned <= static_cast<std::uint64_t>((std::numeric_limits<std::int64_t>::max)()))
                     return 'L';
+                if (use_bjdata && j.m_data.m_value.number_unsigned <= (std::numeric_limits<std::uint64_t>::max)())
+                    return 'M';
                 // anything else is treated as high-precision number
                 return 'H'; // LCOV_EXCL_LINE
-                return get_ubjson_float_prefix(j.m_value.number_float);
+                return get_ubjson_float_prefix(j.m_data.m_value.number_float);
                 return 'S';
@@ -14319,6 +16635,7 @@ class binary_writer
                 return '{';
             default:  // discarded values
                 return 'N';
@@ -14334,6 +16651,118 @@ class binary_writer
         return 'D';  // float 64
+    @return false if the object is successfully converted to a bjdata ndarray, true if the type or size is invalid
+    bool write_bjdata_ndarray(const typename BasicJsonType::object_t& value, const bool use_count, const bool use_type)
+        std::map<string_t, CharType> bjdtype = {{"uint8", 'U'},  {"int8", 'i'},  {"uint16", 'u'}, {"int16", 'I'},
+            {"uint32", 'm'}, {"int32", 'l'}, {"uint64", 'M'}, {"int64", 'L'}, {"single", 'd'}, {"double", 'D'}, {"char", 'C'}
+        string_t key = "_ArrayType_";
+        auto it = bjdtype.find(static_cast<string_t>(value.at(key)));
+        if (it == bjdtype.end())
+            return true;
+        CharType dtype = it->second;
+        key = "_ArraySize_";
+        std::size_t len = (value.at(key).empty() ? 0 : 1);
+        for (const auto& el : value.at(key))
+            len *= static_cast<std::size_t>(el.m_data.m_value.number_unsigned);
+        key = "_ArrayData_";
+        if (value.at(key).size() != len)
+            return true;
+        oa->write_character('[');
+        oa->write_character('$');
+        oa->write_character(dtype);
+        oa->write_character('#');
+        write_ubjson(value.at(key), use_count, use_type, true,  true);
+        if (dtype == 'U' || dtype == 'C')
+                write_number(static_cast<std::uint8_t>(el.m_data.m_value.number_unsigned), true);
+        else if (dtype == 'i')
+                write_number(static_cast<std::int8_t>(el.m_data.m_value.number_integer), true);
+        else if (dtype == 'u')
+                write_number(static_cast<std::uint16_t>(el.m_data.m_value.number_unsigned), true);
+        else if (dtype == 'I')
+                write_number(static_cast<std::int16_t>(el.m_data.m_value.number_integer), true);
+        else if (dtype == 'm')
+                write_number(static_cast<std::uint32_t>(el.m_data.m_value.number_unsigned), true);
+        else if (dtype == 'l')
+                write_number(static_cast<std::int32_t>(el.m_data.m_value.number_integer), true);
+        else if (dtype == 'M')
+                write_number(static_cast<std::uint64_t>(el.m_data.m_value.number_unsigned), true);
+        else if (dtype == 'L')
+                write_number(static_cast<std::int64_t>(el.m_data.m_value.number_integer), true);
+        else if (dtype == 'd')
+                write_number(static_cast<float>(el.m_data.m_value.number_float), true);
+        else if (dtype == 'D')
+                write_number(static_cast<double>(el.m_data.m_value.number_float), true);
+        return false;
     // Utility functions //
@@ -14341,19 +16770,21 @@ class binary_writer
     @brief write a number to output input
     @param[in] n number of type @a NumberType
-    @tparam NumberType the type of the number
-    @tparam OutputIsLittleEndian Set to true if output data is
+    @param[in] OutputIsLittleEndian Set to true if output data is
                                  required to be little endian
+    @tparam NumberType the type of the number
     @note This function needs to respect the system's endianness, because bytes
           in CBOR, MessagePack, and UBJSON are stored in network order (big
           endian) and therefore need reordering on little endian systems.
+          On the other hand, BSON and BJData use little endian and should reorder
+          on big endian systems.
-    template<typename NumberType, bool OutputIsLittleEndian = false>
-    void write_number(const NumberType n)
+    template<typename NumberType>
+    void write_number(const NumberType n, const bool OutputIsLittleEndian = false)
         // step 1: write number to array of length NumberType
-        std::array<CharType, sizeof(NumberType)> vec;
+        std::array<CharType, sizeof(NumberType)> vec{};
         std::memcpy(vec.data(), &n, sizeof(NumberType));
         // step 2: write array to output (with possible reordering)
@@ -14368,6 +16799,10 @@ class binary_writer
     void write_compact_float(const number_float_t n, detail::input_format_t format)
+#ifdef __GNUC__
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Wfloat-equal"
+#endif
         if (static_cast<double>(n) >= static_cast<double>(std::numeric_limits<float>::lowest()) &&
                 static_cast<double>(n) <= static_cast<double>((std::numeric_limits<float>::max)()) &&
                 static_cast<double>(static_cast<float>(n)) == static_cast<double>(n))
@@ -14384,6 +16819,9 @@ class binary_writer
                                 : get_msgpack_float_prefix(n));
             write_number(n);
+#ifdef __GNUC__
+#pragma GCC diagnostic pop
+#endif
   public:
@@ -14429,17 +16867,27 @@ class binary_writer
   private:
     /// whether we can assume little endianness
-    const bool is_little_endian = little_endianess();
+    const bool is_little_endian = little_endianness();
     /// the output
 }  // namespace detail
-}  // namespace nlohmann
+NLOHMANN_JSON_NAMESPACE_END
 // #include <nlohmann/detail/output/serializer.hpp>
+//     __ _____ _____ _____
+//  __|  |   __|     |   | |  JSON for Modern C++
+// |  |  |__   |  |  | | | |  version 3.11.3
+// |_____|_____|_____|_|___|  https://github.com/nlohmann/json
+// SPDX-FileCopyrightText: 2008-2009 Björn Hoehrmann <bjoern at hoehrmann.de>
+// SPDX-FileCopyrightText: 2013-2023 Niels Lohmann <https://nlohmann.me>
+// SPDX-License-Identifier: MIT
 #include <algorithm> // reverse, remove, fill, find, none_of
@@ -14451,10 +16899,20 @@ class binary_writer
 #include <cstdio> // snprintf
 #include <string> // string, char_traits
+#include <iomanip> // setfill, setw
 #include <type_traits> // is_same
 // #include <nlohmann/detail/conversions/to_chars.hpp>
+// SPDX-FileCopyrightText: 2009 Florian Loitsch <https://florian.loitsch.com/>
@@ -14467,8 +16925,7 @@ class binary_writer
 // #include <nlohmann/detail/macro_scope.hpp>
-namespace nlohmann
+NLOHMANN_JSON_NAMESPACE_BEGIN
 namespace detail
@@ -14658,7 +17115,7 @@ boundaries compute_boundaries(FloatType value)
     using bits_type = typename std::conditional<kPrecision == 24, std::uint32_t, std::uint64_t >::type;
-    const std::uint64_t bits = reinterpret_bits<bits_type>(value);
+    const auto bits = static_cast<std::uint64_t>(reinterpret_bits<bits_type>(value));
     const std::uint64_t E = bits >> (kPrecision - 1);
     const std::uint64_t F = bits & (kHiddenBit - 1);
@@ -14948,51 +17405,49 @@ inline int find_largest_pow10(const std::uint32_t n, std::uint32_t& pow10)
         return 10;
     // LCOV_EXCL_STOP
-    else if (n >= 100000000)
+    if (n >= 100000000)
         pow10 = 100000000;
         return  9;
-    else if (n >= 10000000)
+    if (n >= 10000000)
         pow10 = 10000000;
         return  8;
-    else if (n >= 1000000)
+    if (n >= 1000000)
         pow10 = 1000000;
         return  7;
-    else if (n >= 100000)
+    if (n >= 100000)
         pow10 = 100000;
         return  6;
-    else if (n >= 10000)
+    if (n >= 10000)
         pow10 = 10000;
         return  5;
-    else if (n >= 1000)
+    if (n >= 1000)
         pow10 = 1000;
         return  4;
-    else if (n >= 100)
+    if (n >= 100)
         pow10 = 100;
         return  3;
-    else if (n >= 10)
+    if (n >= 10)
         pow10 = 10;
         return  2;
-    else
-        pow10 = 1;
-        return 1;
+    pow10 = 1;
+    return 1;
 inline void grisu2_round(char* buf, int len, std::uint64_t dist, std::uint64_t delta,
@@ -15078,7 +17533,7 @@ inline void grisu2_digit_gen(char* buffer, int& length, int& decimal_exponent,
     JSON_ASSERT(p1 > 0);
-    std::uint32_t pow10;
+    std::uint32_t pow10{};
     const int k = find_largest_pow10(p1, pow10);
     //      10^(k-1) <= p1 < 10^k, pow10 = 10^(k-1)
@@ -15351,7 +17806,7 @@ void grisu2(char* buf, int& len, int& decimal_exponent, FloatType value)
     // The documentation for 'std::to_chars' (https://en.cppreference.com/w/cpp/utility/to_chars)
     // says "value is converted to a string as if by std::sprintf in the default ("C") locale"
-    // and since sprintf promotes float's to double's, I think this is exactly what 'std::to_chars'
+    // and since sprintf promotes floats to doubles, I think this is exactly what 'std::to_chars'
     // does.
     // On the other hand, the documentation for 'std::to_chars' requires that "parsing the
     // representation using the corresponding std::from_chars function recovers value exactly". That
@@ -15361,7 +17816,7 @@ void grisu2(char* buf, int& len, int& decimal_exponent, FloatType value)
     // NB: If the neighbors are computed for single-precision numbers, there is a single float
     //     (7.0385307e-26f) which can't be recovered using strtod. The resulting double precision
     //     value is off by 1 ulp.
-#if 0
+#if 0 // NOLINT(readability-avoid-unconditional-preprocessor-if)
     const boundaries w = compute_boundaries(static_cast<double>(value));
 #else
     const boundaries w = compute_boundaries(value);
@@ -15499,7 +17954,7 @@ inline char* format_buffer(char* buf, int len, int decimal_exponent,
     return append_exponent(buf, n - 1);
-} // namespace dtoa_impl
+}  // namespace dtoa_impl
 @brief generates a decimal representation of the floating-point number value in [first, last).
@@ -15526,6 +17981,10 @@ char* to_chars(char* first, const char* last, FloatType value)
         *first++ = '-';
+#ifdef __GNUC__
+#endif
     if (value == 0) // +-0
         *first++ = '0';
@@ -15534,6 +17993,9 @@ char* to_chars(char* first, const char* last, FloatType value)
         *first++ = '0';
         return first;
+#ifdef __GNUC__
+#endif
     JSON_ASSERT(last - first >= std::numeric_limits<FloatType>::max_digits10);
@@ -15559,8 +18021,8 @@ char* to_chars(char* first, const char* last, FloatType value)
     return dtoa_impl::format_buffer(first, len, decimal_exponent, kMinExp, kMaxExp);
-} // namespace detail
+}  // namespace detail
 // #include <nlohmann/detail/exceptions.hpp>
@@ -15572,13 +18034,15 @@ char* to_chars(char* first, const char* last, FloatType value)
 // #include <nlohmann/detail/value_t.hpp>
-namespace nlohmann
 namespace detail
 // serialization //
@@ -15654,11 +18118,11 @@ class serializer
               const unsigned int indent_step,
               const unsigned int current_indent = 0)
-        switch (val.m_type)
+        switch (val.m_data.m_type)
-                if (val.m_value.object->empty())
+                if (val.m_data.m_value.object->empty())
                     o->write_characters("{}", 2);
                     return;
@@ -15676,8 +18140,8 @@ class serializer
                     // first n-1 elements
-                    auto i = val.m_value.object->cbegin();
-                    for (std::size_t cnt = 0; cnt < val.m_value.object->size() - 1; ++cnt, ++i)
+                    auto i = val.m_data.m_value.object->cbegin();
+                    for (std::size_t cnt = 0; cnt < val.m_data.m_value.object->size() - 1; ++cnt, ++i)
                         o->write_characters(indent_string.c_str(), new_indent);
                         o->write_character('\"');
@@ -15688,8 +18152,8 @@ class serializer
                     // last element
-                    JSON_ASSERT(i != val.m_value.object->cend());
-                    JSON_ASSERT(std::next(i) == val.m_value.object->cend());
+                    JSON_ASSERT(i != val.m_data.m_value.object->cend());
+                    JSON_ASSERT(std::next(i) == val.m_data.m_value.object->cend());
                     dump_escaped(i->first, ensure_ascii);
@@ -15705,8 +18169,8 @@ class serializer
                     o->write_character('{');
@@ -15716,8 +18180,8 @@ class serializer
                     // last element
                     o->write_characters("\":", 2);
@@ -15731,7 +18195,7 @@ class serializer
-                if (val.m_value.array->empty())
+                if (val.m_data.m_value.array->empty())
                     o->write_characters("[]", 2);
                     return;
@@ -15749,8 +18213,8 @@ class serializer
-                    for (auto i = val.m_value.array->cbegin();
-                            i != val.m_value.array->cend() - 1; ++i)
+                    for (auto i = val.m_data.m_value.array->cbegin();
+                            i != val.m_data.m_value.array->cend() - 1; ++i)
                         dump(*i, true, ensure_ascii, indent_step, new_indent);
@@ -15758,9 +18222,9 @@ class serializer
                     // last element
-                    JSON_ASSERT(!val.m_value.array->empty());
+                    JSON_ASSERT(!val.m_data.m_value.array->empty());
-                    dump(val.m_value.array->back(), true, ensure_ascii, indent_step, new_indent);
+                    dump(val.m_data.m_value.array->back(), true, ensure_ascii, indent_step, new_indent);
                     o->write_character('\n');
                     o->write_characters(indent_string.c_str(), current_indent);
@@ -15771,16 +18235,16 @@ class serializer
                     o->write_character('[');
                         dump(*i, false, ensure_ascii, indent_step, current_indent);
                         o->write_character(',');
                     // last element
-                    dump(val.m_value.array->back(), false, ensure_ascii, indent_step, current_indent);
+                    dump(val.m_data.m_value.array->back(), false, ensure_ascii, indent_step, current_indent);
                     o->write_character(']');
@@ -15791,7 +18255,7 @@ class serializer
-                dump_escaped(*val.m_value.string, ensure_ascii);
+                dump_escaped(*val.m_data.m_value.string, ensure_ascii);
                 return;
@@ -15813,24 +18277,24 @@ class serializer
                     o->write_characters("\"bytes\": [", 10);
-                    if (!val.m_value.binary->empty())
+                    if (!val.m_data.m_value.binary->empty())
-                        for (auto i = val.m_value.binary->cbegin();
-                                i != val.m_value.binary->cend() - 1; ++i)
+                        for (auto i = val.m_data.m_value.binary->cbegin();
+                                i != val.m_data.m_value.binary->cend() - 1; ++i)
                             dump_integer(*i);
                             o->write_characters(", ", 2);
-                        dump_integer(val.m_value.binary->back());
+                        dump_integer(val.m_data.m_value.binary->back());
                     o->write_characters("],\n", 3);
                     o->write_characters("\"subtype\": ", 11);
-                    if (val.m_value.binary->has_subtype())
+                    if (val.m_data.m_value.binary->has_subtype())
-                        dump_integer(val.m_value.binary->subtype());
+                        dump_integer(val.m_data.m_value.binary->subtype());
                     else
@@ -15844,21 +18308,21 @@ class serializer
                     o->write_characters("{\"bytes\":[", 10);
                             dump_integer(*i);
                     o->write_characters("],\"subtype\":", 12);
                         o->write_character('}');
                     else
@@ -15871,7 +18335,7 @@ class serializer
-                if (val.m_value.boolean)
+                if (val.m_data.m_value.boolean)
                     o->write_characters("true", 4);
@@ -15884,19 +18348,19 @@ class serializer
-                dump_integer(val.m_value.number_integer);
+                dump_integer(val.m_data.m_value.number_integer);
                 return;
-                dump_integer(val.m_value.number_unsigned);
+                dump_integer(val.m_data.m_value.number_unsigned);
                 return;
-                dump_float(val.m_value.number_float);
+                dump_float(val.m_data.m_value.number_float);
                 return;
@@ -15913,7 +18377,7 @@ class serializer
             default:            // LCOV_EXCL_LINE
-                JSON_ASSERT(false);  // LCOV_EXCL_LINE
+                JSON_ASSERT(false); // NOLINT(cert-dcl03-c,hicpp-static-assert,misc-static-assert) LCOV_EXCL_LINE
@@ -15934,7 +18398,7 @@ class serializer
     void dump_escaped(const string_t& s, const bool ensure_ascii)
-        std::uint32_t codepoint;
+        std::uint32_t codepoint{};
         std::uint8_t state = UTF8_ACCEPT;
         std::size_t bytes = 0;  // number of bytes written to string_buffer
@@ -15944,7 +18408,7 @@ class serializer
         for (std::size_t i = 0; i < s.size(); ++i)
-            const auto byte = static_cast<uint8_t>(s[i]);
+            const auto byte = static_cast<std::uint8_t>(s[i]);
             switch (decode(state, codepoint, byte))
@@ -16009,15 +18473,17 @@ class serializer
                                 if (codepoint <= 0xFFFF)
-                                    (std::snprintf)(string_buffer.data() + bytes, 7, "\\u%04x",
-                                                    static_cast<std::uint16_t>(codepoint));
+                                    // NOLINTNEXTLINE(cppcoreguidelines-pro-type-vararg,hicpp-vararg)
+                                    static_cast<void>((std::snprintf)(string_buffer.data() + bytes, 7, "\\u%04x",
+        static_cast<std::uint16_t>(codepoint)));
                                     bytes += 6;
                                 else
-                                    (std::snprintf)(string_buffer.data() + bytes, 13, "\\u%04x\\u%04x",
-                                                    static_cast<std::uint16_t>(0xD7C0u + (codepoint >> 10u)),
-                                                    static_cast<std::uint16_t>(0xDC00u + (codepoint & 0x3FFu)));
+                                    static_cast<void>((std::snprintf)(string_buffer.data() + bytes, 13, "\\u%04x\\u%04x",
+        static_cast<std::uint16_t>(0xD7C0u + (codepoint >> 10u)),
+        static_cast<std::uint16_t>(0xDC00u + (codepoint & 0x3FFu))));
                                     bytes += 12;
@@ -16052,9 +18518,7 @@ class serializer
                         case error_handler_t::strict:
-                            std::string sn(3, '\0');
-                            (std::snprintf)(&sn[0], sn.size(), "%.2X", byte);
-                            JSON_THROW(type_error::create(316, "invalid UTF-8 byte at index " + std::to_string(i) + ": 0x" + sn));
+                            JSON_THROW(type_error::create(316, concat("invalid UTF-8 byte at index ", std::to_string(i), ": 0x", hex_bytes(byte | 0)), nullptr));
                         case error_handler_t::ignore:
@@ -16112,7 +18576,7 @@ class serializer
                     break;
@@ -16146,9 +18610,7 @@ class serializer
-                    (std::snprintf)(&sn[0], sn.size(), "%.2X", static_cast<std::uint8_t>(s.back()));
-                    JSON_THROW(type_error::create(316, "incomplete UTF-8 string; last byte: 0x" + sn));
+                    JSON_THROW(type_error::create(316, concat("incomplete UTF-8 string; last byte: 0x", hex_bytes(static_cast<std::uint8_t>(s.back() | 0))), nullptr));
@@ -16175,7 +18637,7 @@ class serializer
@@ -16215,6 +18677,33 @@ class serializer
+     * @brief convert a byte to a uppercase hex representation
+     * @param[in] byte byte to represent
+     * @return representation ("00".."FF")
+    static std::string hex_bytes(std::uint8_t byte)
+        std::string result = "FF";
+        constexpr const char* nibble_to_hex = "0123456789ABCDEF";
+        result[0] = nibble_to_hex[byte / 16];
+        result[1] = nibble_to_hex[byte % 16];
+        return result;
+    // templates to avoid warnings about useless casts
+    template <typename NumberType, enable_if_t<std::is_signed<NumberType>::value, int> = 0>
+    bool is_negative_number(NumberType x)
+        return x < 0;
+    template < typename NumberType, enable_if_t <std::is_unsigned<NumberType>::value, int > = 0 >
+    bool is_negative_number(NumberType /*unused*/)
+        return false;
     @brief dump an integer
@@ -16225,6 +18714,7 @@ class serializer
     @tparam NumberType either @a number_integer_t or @a number_unsigned_t
     template < typename NumberType, detail::enable_if_t <
+                   std::is_integral<NumberType>::value ||
                    std::is_same<NumberType, number_unsigned_t>::value ||
                    std::is_same<NumberType, number_integer_t>::value ||
                    std::is_same<NumberType, binary_char_t>::value,
@@ -16255,14 +18745,13 @@ class serializer
         // use a pointer to fill the buffer
-        auto buffer_ptr = number_buffer.begin();
+        auto buffer_ptr = number_buffer.begin(); // NOLINT(llvm-qualified-auto,readability-qualified-auto,cppcoreguidelines-pro-type-vararg,hicpp-vararg)
-        const bool is_negative = std::is_same<NumberType, number_integer_t>::value && !(x >= 0); // see issue #755
         number_unsigned_t abs_value;
-        unsigned int n_chars;
+        unsigned int n_chars{};
-        if (is_negative)
+        if (is_negative_number(x))
             *buffer_ptr = '-';
             abs_value = remove_sign(static_cast<number_integer_t>(x));
@@ -16279,7 +18768,7 @@ class serializer
         // spare 1 byte for '\0'
         JSON_ASSERT(n_chars < number_buffer.size() - 1);
-        // jump to the end to generate the string from backward
+        // jump to the end to generate the string from backward,
         // so we later avoid reversing the result
         buffer_ptr += n_chars;
@@ -16338,8 +18827,8 @@ class serializer
     void dump_float(number_float_t x, std::true_type /*is_ieee_single_or_double*/)
-        char* begin = number_buffer.data();
-        char* end = ::nlohmann::detail::to_chars(begin, begin + number_buffer.size(), x);
+        auto* begin = number_buffer.data();
+        auto* end = ::nlohmann::detail::to_chars(begin, begin + number_buffer.size(), x);
         o->write_characters(begin, static_cast<size_t>(end - begin));
@@ -16350,6 +18839,7 @@ class serializer
         static constexpr auto d = std::numeric_limits<number_float_t>::max_digits10;
         // the actual conversion
         std::ptrdiff_t len = (std::snprintf)(number_buffer.data(), number_buffer.size(), "%.*g", d, x);
         // negative value indicates an error
@@ -16360,8 +18850,8 @@ class serializer
         // erase thousands separator
         if (thousands_sep != '\0')
-            const auto end = std::remove(number_buffer.begin(),
-                                         number_buffer.begin() + len, thousands_sep);
+            // NOLINTNEXTLINE(readability-qualified-auto,llvm-qualified-auto): std::remove returns an iterator, see https://github.com/nlohmann/json/issues/3081
+            const auto end = std::remove(number_buffer.begin(), number_buffer.begin() + len, thousands_sep);
             std::fill(end, number_buffer.end(), '\0');
             JSON_ASSERT((end - number_buffer.begin()) <= len);
             len = (end - number_buffer.begin());
@@ -16370,6 +18860,7 @@ class serializer
         // convert decimal point to '.'
         if (decimal_point != '\0' && decimal_point != '.')
+            // NOLINTNEXTLINE(readability-qualified-auto,llvm-qualified-auto): std::find returns an iterator, see https://github.com/nlohmann/json/issues/3081
             const auto dec_pos = std::find(number_buffer.begin(), number_buffer.end(), decimal_point);
             if (dec_pos != number_buffer.end())
@@ -16379,7 +18870,7 @@ class serializer
         o->write_characters(number_buffer.data(), static_cast<std::size_t>(len));
-        // determine if need to append ".0"
+        // determine if we need to append ".0"
         const bool value_is_int_like =
             std::none_of(number_buffer.begin(), number_buffer.begin() + len + 1,
                          [](char c)
@@ -16443,8 +18934,8 @@ class serializer
                 ? (byte & 0x3fu) | (codep << 6u)
                 : (0xFFu >> type) & (byte);
-        std::size_t index = 256u + static_cast<size_t>(state) * 16u + static_cast<size_t>(type);
-        JSON_ASSERT(index < 400);
+        const std::size_t index = 256u + static_cast<size_t>(state) * 16u + static_cast<size_t>(type);
+        JSON_ASSERT(index < utf8d.size());
         state = utf8d[index];
         return state;
@@ -16456,7 +18947,7 @@ class serializer
     number_unsigned_t remove_sign(number_unsigned_t x)
         return x; // LCOV_EXCL_LINE
@@ -16471,7 +18962,7 @@ class serializer
     inline number_unsigned_t remove_sign(number_integer_t x) noexcept
-        JSON_ASSERT(x < 0 && x < (std::numeric_limits<number_integer_t>::max)());
+        JSON_ASSERT(x < 0 && x < (std::numeric_limits<number_integer_t>::max)()); // NOLINT(misc-redundant-expression)
         return static_cast<number_unsigned_t>(-(x + 1)) + 1;
@@ -16500,26 +18991,40 @@ class serializer
     /// error_handler how to react on decoding errors
     const error_handler_t error_handler;
 // #include <nlohmann/json_fwd.hpp>
 // #include <nlohmann/ordered_map.hpp>
-#include <functional> // less
+#include <functional> // equal_to, less
+#include <initializer_list> // initializer_list
+#include <iterator> // input_iterator_tag, iterator_traits
 #include <memory> // allocator
+#include <stdexcept> // for out_of_range
+#include <type_traits> // enable_if, is_convertible
 #include <utility> // pair
+// #include <nlohmann/detail/meta/type_traits.hpp>
-namespace nlohmann
 /// ordered_map: a minimal map-like container that preserves insertion order
 /// for use within nlohmann::basic_json<ordered_map>
@@ -16530,48 +19035,83 @@ template <class Key, class T, class IgnoredLess = std::less<Key>,
     using key_type = Key;
     using mapped_type = T;
     using Container = std::vector<std::pair<const Key, T>, Allocator>;
-    using typename Container::iterator;
-    using typename Container::const_iterator;
-    using typename Container::size_type;
-    using typename Container::value_type;
+    using iterator = typename Container::iterator;
+    using const_iterator = typename Container::const_iterator;
+    using size_type = typename Container::size_type;
+    using value_type = typename Container::value_type;
+#ifdef JSON_HAS_CPP_14
+    using key_compare = std::equal_to<>;
+#else
+    using key_compare = std::equal_to<Key>;
+#endif
     // Explicit constructors instead of `using Container::Container`
     // otherwise older compilers choke on it (GCC <= 5.5, xcode <= 9.4)
-    ordered_map(const Allocator& alloc = Allocator()) : Container{alloc} {}
+    ordered_map() noexcept(noexcept(Container())) : Container{} {}
+    explicit ordered_map(const Allocator& alloc) noexcept(noexcept(Container(alloc))) : Container{alloc} {}
     template <class It>
     ordered_map(It first, It last, const Allocator& alloc = Allocator())
         : Container{first, last, alloc} {}
-    ordered_map(std::initializer_list<T> init, const Allocator& alloc = Allocator() )
+    ordered_map(std::initializer_list<value_type> init, const Allocator& alloc = Allocator() )
         : Container{init, alloc} {}
     std::pair<iterator, bool> emplace(const key_type& key, T&& t)
         for (auto it = this->begin(); it != this->end(); ++it)
-            if (it->first == key)
+            if (m_compare(it->first, key))
                 return {it, false};
-        Container::emplace_back(key, t);
-        return {--this->end(), true};
+        Container::emplace_back(key, std::forward<T>(t));
+        return {std::prev(this->end()), true};
-    T& operator[](const Key& key)
+    template<class KeyType, detail::enable_if_t<
+                 detail::is_usable_as_key_type<key_compare, key_type, KeyType>::value, int> = 0>
+    std::pair<iterator, bool> emplace(KeyType && key, T && t)
+        for (auto it = this->begin(); it != this->end(); ++it)
+                return {it, false};
+        Container::emplace_back(std::forward<KeyType>(key), std::forward<T>(t));
+    T& operator[](const key_type& key)
         return emplace(key, T{}).first->second;
-    const T& operator[](const Key& key) const
+    T & operator[](KeyType && key)
+        return emplace(std::forward<KeyType>(key), T{}).first->second;
+    const T& operator[](const key_type& key) const
         return at(key);
-    T& at(const Key& key)
+    const T & operator[](KeyType && key) const
+        return at(std::forward<KeyType>(key));
+    T& at(const key_type& key)
                 return it->second;
@@ -16580,11 +19120,13 @@ template <class Key, class T, class IgnoredLess = std::less<Key>,
         JSON_THROW(std::out_of_range("key not found"));
-    const T& at(const Key& key) const
+    T & at(KeyType && key) // NOLINT(cppcoreguidelines-missing-std-forward)
                 return it->second;
@@ -16593,11 +19135,60 @@ template <class Key, class T, class IgnoredLess = std::less<Key>,
-    size_type erase(const Key& key)
+    const T& at(const key_type& key) const
+                return it->second;
+        JSON_THROW(std::out_of_range("key not found"));
+    const T & at(KeyType && key) const // NOLINT(cppcoreguidelines-missing-std-forward)
+    size_type erase(const key_type& key)
+                // Since we cannot move const Keys, re-construct them in place
+                for (auto next = it; ++next != this->end(); ++it)
+                    it->~value_type(); // Destroy but keep allocation
+                    new (&*it) value_type{std::move(*next)};
+                Container::pop_back();
+                return 1;
+        return 0;
+    size_type erase(KeyType && key) // NOLINT(cppcoreguidelines-missing-std-forward)
@@ -16614,23 +19205,67 @@ template <class Key, class T, class IgnoredLess = std::less<Key>,
     iterator erase(iterator pos)
-        auto it = pos;
-        // Since we cannot move const Keys, re-construct them in place
-        for (auto next = it; ++next != this->end(); ++it)
-            it->~value_type(); // Destroy but keep allocation
-            new (&*it) value_type{std::move(*next)};
-        Container::pop_back();
-        return pos;
+        return erase(pos, std::next(pos));
-    size_type count(const Key& key) const
+    iterator erase(iterator first, iterator last)
+        if (first == last)
+            return first;
+        const auto elements_affected = std::distance(first, last);
+        const auto offset = std::distance(Container::begin(), first);
+        // This is the start situation. We need to delete elements_affected
+        // elements (3 in this example: e, f, g), and need to return an
+        // iterator past the last deleted element (h in this example).
+        // Note that offset is the distance from the start of the vector
+        // to first. We will need this later.
+        // [ a, b, c, d, e, f, g, h, i, j ]
+        //             first    last
+        // Since we cannot move const Keys, we re-construct them in place.
+        // We start at first and re-construct (viz. copy) the elements from
+        // the back of the vector. Example for first iteration:
+        //               v        |   destroy e and re-construct with h
+        //               it       it + elements_affected
+        for (auto it = first; std::next(it, elements_affected) != Container::end(); ++it)
+            it->~value_type(); // destroy but keep allocation
+            new (&*it) value_type{std::move(*std::next(it, elements_affected))}; // "move" next element to it
+        // [ a, b, c, d, h, i, j, h, i, j ]
+        //             first    last
+        // remove the unneeded elements at the end of the vector
+        Container::resize(this->size() - static_cast<size_type>(elements_affected));
+        // [ a, b, c, d, h, i, j ]
+        //             first    last
+        // first is now pointing past the last deleted element, but we cannot
+        // use this iterator, because it may have been invalidated by the
+        // resize call. Instead, we can return begin() + offset.
+        return Container::begin() + offset;
+    size_type count(const key_type& key) const
                 return 1;
@@ -16638,11 +19273,25 @@ template <class Key, class T, class IgnoredLess = std::less<Key>,
         return 0;
-    iterator find(const Key& key)
+    size_type count(KeyType && key) const // NOLINT(cppcoreguidelines-missing-std-forward)
+                return 1;
+        return 0;
+    iterator find(const key_type& key)
                 return it;
@@ -16650,11 +19299,25 @@ template <class Key, class T, class IgnoredLess = std::less<Key>,
         return Container::end();
-    const_iterator find(const Key& key) const
+    iterator find(KeyType && key) // NOLINT(cppcoreguidelines-missing-std-forward)
+                return it;
+        return Container::end();
+    const_iterator find(const key_type& key) const
                 return it;
@@ -16671,7 +19334,7 @@ template <class Key, class T, class IgnoredLess = std::less<Key>,
-            if (it->first == value.first)
+            if (m_compare(it->first, value.first))
                 return {it, false};
@@ -16692,12 +19355,18 @@ template <class Key, class T, class IgnoredLess = std::less<Key>,
             insert(*it);
+private:
+    JSON_NO_UNIQUE_ADDRESS key_compare m_compare = key_compare();
 #if defined(JSON_HAS_CPP_17)
+    #if JSON_HAS_STATIC_RTTI
+        #include <any>
+    #endif
     #include <string_view>
 #endif
@@ -16706,75 +19375,12 @@ template <class Key, class T, class IgnoredLess = std::less<Key>,
 @see https://github.com/nlohmann
 @since version 1.0.0
-namespace nlohmann
 @brief a class to store JSON values
- at tparam ObjectType type for JSON objects (`std::map` by default; will be used
-in @ref object_t)
- at tparam ArrayType type for JSON arrays (`std::vector` by default; will be used
-in @ref array_t)
- at tparam StringType type for JSON strings and object keys (`std::string` by
-default; will be used in @ref string_t)
- at tparam BooleanType type for JSON booleans (`bool` by default; will be used
-in @ref boolean_t)
- at tparam NumberIntegerType type for JSON integer numbers (`int64_t` by
-default; will be used in @ref number_integer_t)
- at tparam NumberUnsignedType type for JSON unsigned integer numbers (@c
-`uint64_t` by default; will be used in @ref number_unsigned_t)
- at tparam NumberFloatType type for JSON floating-point numbers (`double` by
-default; will be used in @ref number_float_t)
- at tparam BinaryType type for packed binary data for compatibility with binary
-serialization formats (`std::vector<std::uint8_t>` by default; will be used in
- at ref binary_t)
- at tparam AllocatorType type of the allocator to use (`std::allocator` by
-default)
- at tparam JSONSerializer the serializer to resolve internal calls to `to_json()`
-and `from_json()` (@ref adl_serializer by default)
- at requirement The class satisfies the following concept requirements:
-- Basic
- - [DefaultConstructible](https://en.cppreference.com/w/cpp/named_req/DefaultConstructible):
-   JSON values can be default constructed. The result will be a JSON null
-   value.
- - [MoveConstructible](https://en.cppreference.com/w/cpp/named_req/MoveConstructible):
-   A JSON value can be constructed from an rvalue argument.
- - [CopyConstructible](https://en.cppreference.com/w/cpp/named_req/CopyConstructible):
-   A JSON value can be copy-constructed from an lvalue expression.
- - [MoveAssignable](https://en.cppreference.com/w/cpp/named_req/MoveAssignable):
-   A JSON value van be assigned from an rvalue argument.
- - [CopyAssignable](https://en.cppreference.com/w/cpp/named_req/CopyAssignable):
-   A JSON value can be copy-assigned from an lvalue expression.
- - [Destructible](https://en.cppreference.com/w/cpp/named_req/Destructible):
-   JSON values can be destructed.
-- Layout
- - [StandardLayoutType](https://en.cppreference.com/w/cpp/named_req/StandardLayoutType):
-   JSON values have
-   [standard layout](https://en.cppreference.com/w/cpp/language/data_members#Standard_layout):
-   All non-static data members are private and standard layout types, the
-   class has no virtual functions or (virtual) base classes.
-- Library-wide
- - [EqualityComparable](https://en.cppreference.com/w/cpp/named_req/EqualityComparable):
-   JSON values can be compared with `==`, see @ref
-   operator==(const_reference,const_reference).
- - [LessThanComparable](https://en.cppreference.com/w/cpp/named_req/LessThanComparable):
-   JSON values can be compared with `<`, see @ref
-   operator<(const_reference,const_reference).
- - [Swappable](https://en.cppreference.com/w/cpp/named_req/Swappable):
-   Any JSON lvalue or rvalue of can be swapped with any lvalue or rvalue of
-   other compatible types, using unqualified function call @ref swap().
- - [NullablePointer](https://en.cppreference.com/w/cpp/named_req/NullablePointer):
-   JSON values can be compared against `std::nullptr_t` objects which are used
-   to model the `null` value.
-- Container
- - [Container](https://en.cppreference.com/w/cpp/named_req/Container):
-   JSON values can be used like STL containers and provide iterator access.
- - [ReversibleContainer](https://en.cppreference.com/w/cpp/named_req/ReversibleContainer);
-   JSON values can be used like STL containers and provide reverse iterator
-   access.
+ at internal
 @invariant The member variables @a m_value and @a m_type have the following
 relationship:
 - If `m_type == value_t::object`, then `m_value.object != nullptr`.
@@ -16782,23 +19388,24 @@ relationship:
 - If `m_type == value_t::string`, then `m_value.string != nullptr`.
 The invariants are checked by member function assert_invariant().
- at internal
 @note ObjectType trick from https://stackoverflow.com/a/9860911
 @endinternal
- at see [RFC 7159: The JavaScript Object Notation (JSON) Data Interchange
-Format](http://rfc7159.net/rfc7159)
 @nosubgrouping
 NLOHMANN_BASIC_JSON_TPL_DECLARATION
-class basic_json
+class basic_json // NOLINT(cppcoreguidelines-special-member-functions,hicpp-special-member-functions)
+    : public ::nlohmann::detail::json_base_class<CustomBaseClass>
   private:
     template<detail::value_t> friend struct detail::external_constructor;
-    friend ::nlohmann::json_pointer<basic_json>;
+    template<typename>
+    friend class ::nlohmann::json_pointer;
+    // can be restored when json_pointer backwards compatibility is removed
+    // friend ::nlohmann::json_pointer<StringType>;
     template<typename BasicJsonType, typename InputType>
     friend class ::nlohmann::detail::parser;
@@ -16813,9 +19420,11 @@ class basic_json
     friend class ::nlohmann::detail::json_sax_dom_parser;
     template<typename BasicJsonType>
     friend class ::nlohmann::detail::json_sax_dom_callback_parser;
+    friend class ::nlohmann::detail::exception;
     /// workaround type for MSVC
     using basic_json_t = NLOHMANN_BASIC_JSON_TPL;
+    using json_base_class_t = ::nlohmann::detail::json_base_class<CustomBaseClass>;
   JSON_PRIVATE_UNLESS_TESTED:
     // convenience aliases for types residing in namespace detail;
@@ -16856,7 +19465,7 @@ class basic_json
   public:
     using value_t = detail::value_t;
     /// JSON Pointer, see @ref nlohmann::json_pointer
-    using json_pointer = ::nlohmann::json_pointer<basic_json>;
+    using json_pointer = ::nlohmann::json_pointer<StringType>;
     template<typename T, typename SFINAE>
     using json_serializer = JSONSerializer<T, SFINAE>;
     /// how to treat decoding errors
@@ -16878,22 +19487,15 @@ class basic_json
     /// Classes to implement user-defined exceptions.
-    /// @copydoc detail::exception
     using exception = detail::exception;
-    /// @copydoc detail::parse_error
     using parse_error = detail::parse_error;
-    /// @copydoc detail::invalid_iterator
     using invalid_iterator = detail::invalid_iterator;
-    /// @copydoc detail::type_error
     using type_error = detail::type_error;
-    /// @copydoc detail::out_of_range
     using out_of_range = detail::out_of_range;
-    /// @copydoc detail::other_error
     using other_error = detail::other_error;
     // container types //
@@ -16935,53 +19537,27 @@ class basic_json
-    @brief returns the allocator associated with the container
+    /// @brief returns the allocator associated with the container
+    /// @sa https://json.nlohmann.me/api/basic_json/get_allocator/
     static allocator_type get_allocator()
         return allocator_type();
-    @brief returns version information on the library
-    This function returns a JSON object with information about the library,
-    including the version number and information on the platform and compiler.
-    @return JSON object holding version information
-    key         | description
-    `compiler`  | Information on the used compiler. It is an object with the following keys: `c++` (the used C++ standard), `family` (the compiler family; possible values are `clang`, `icc`, `gcc`, `ilecpp`, `msvc`, `pgcpp`, `sunpro`, and `unknown`), and `version` (the compiler version).
-    `copyright` | The copyright line for the library as string.
-    `name`      | The name of the library as string.
-    `platform`  | The used platform as string. Possible values are `win32`, `linux`, `apple`, `unix`, and `unknown`.
-    `url`       | The URL of the project as string.
-    `version`   | The version of the library. It is an object with the following keys: `major`, `minor`, and `patch` as defined by [Semantic Versioning](http://semver.org), and `string` (the version string).
-    @liveexample{The following code shows an example output of the `meta()`
-    function.,meta}
-    @exceptionsafety Strong guarantee: if an exception is thrown, there are no
-    changes to any JSON value.
-    @complexity Constant.
-    @since 2.1.0
+    /// @brief returns version information on the library
+    /// @sa https://json.nlohmann.me/api/basic_json/meta/
     JSON_HEDLEY_WARN_UNUSED_RESULT
     static basic_json meta()
         basic_json result;
-        result["copyright"] = "(C) 2013-2021 Niels Lohmann";
+        result["copyright"] = "(C) 2013-2023 Niels Lohmann";
         result["name"] = "JSON for Modern C++";
         result["url"] = "https://github.com/nlohmann/json";
         result["version"]["string"] =
-            std::to_string(NLOHMANN_JSON_VERSION_MAJOR) + "." +
-            std::to_string(NLOHMANN_JSON_VERSION_MINOR) + "." +
-            std::to_string(NLOHMANN_JSON_VERSION_PATCH);
+            detail::concat(std::to_string(NLOHMANN_JSON_VERSION_MAJOR), '.',
+                           std::to_string(NLOHMANN_JSON_VERSION_MINOR), '.',
+                           std::to_string(NLOHMANN_JSON_VERSION_PATCH));
         result["version"]["major"] = NLOHMANN_JSON_VERSION_MAJOR;
         result["version"]["minor"] = NLOHMANN_JSON_VERSION_MINOR;
         result["version"]["patch"] = NLOHMANN_JSON_VERSION_PATCH;
@@ -17003,7 +19579,12 @@ class basic_json
 #elif defined(__clang__)
         result["compiler"] = {{"family", "clang"}, {"version", __clang_version__}};
 #elif defined(__GNUC__) || defined(__GNUG__)
-        result["compiler"] = {{"family", "gcc"}, {"version", std::to_string(__GNUC__) + "." + std::to_string(__GNUC_MINOR__) + "." + std::to_string(__GNUC_PATCHLEVEL__)}};
+        result["compiler"] = {{"family", "gcc"}, {"version", detail::concat(
+                    std::to_string(__GNUC__), '.',
+                    std::to_string(__GNUC_MINOR__), '.',
+                    std::to_string(__GNUC_PATCHLEVEL__))
 #elif defined(__HP_cc) || defined(__HP_aCC)
         result["compiler"] = "hp"
 #elif defined(__IBMCPP__)
@@ -17018,7 +19599,9 @@ class basic_json
         result["compiler"] = {{"family", "unknown"}, {"version", "unknown"}};
 #endif
-#ifdef __cplusplus
+#if defined(_MSVC_LANG)
+        result["compiler"]["c++"] = std::to_string(_MSVC_LANG);
+#elif defined(__cplusplus)
         result["compiler"]["c++"] = std::to_string(__cplusplus);
 #else
         result["compiler"]["c++"] = "unknown";
@@ -17026,7 +19609,6 @@ class basic_json
         return result;
     // JSON value data types //
@@ -17036,509 +19618,58 @@ class basic_json
     /// the template arguments passed to class @ref basic_json.
+    /// @brief default object key comparator type
+    /// The actual object key comparator type (@ref object_comparator_t) may be
+    /// different.
+    /// @sa https://json.nlohmann.me/api/basic_json/default_object_comparator_t/
 #if defined(JSON_HAS_CPP_14)
-    // Use transparent comparator if possible, combined with perfect forwarding
-    // on find() and count() calls prevents unnecessary string construction.
-    using object_comparator_t = std::less<>;
+    // use of transparent comparator avoids unnecessary repeated construction of temporaries
+    // in functions involving lookup by key with types other than object_t::key_type (aka. StringType)
+    using default_object_comparator_t = std::less<>;
 #else
-    using object_comparator_t = std::less<StringType>;
+    using default_object_comparator_t = std::less<StringType>;
 #endif
-    @brief a type for an object
-    [RFC 7159](http://rfc7159.net/rfc7159) describes JSON objects as follows:
-    > An object is an unordered collection of zero or more name/value pairs,
-    > where a name is a string and a value is a string, number, boolean, null,
-    > object, or array.
-    To store objects in C++, a type is defined by the template parameters
-    described below.
-    @tparam ObjectType  the container to store objects (e.g., `std::map` or
-    `std::unordered_map`)
-    @tparam StringType the type of the keys or names (e.g., `std::string`).
-    The comparison function `std::less<StringType>` is used to order elements
-    inside the container.
-    @tparam AllocatorType the allocator to use for objects (e.g.,
-    `std::allocator`)
-    #### Default type
-    With the default values for @a ObjectType (`std::map`), @a StringType
-    (`std::string`), and @a AllocatorType (`std::allocator`), the default
-    value for @a object_t is:
-    @code {.cpp}
-    std::map<
-      std::string, // key_type
-      basic_json, // value_type
-      std::less<std::string>, // key_compare
-      std::allocator<std::pair<const std::string, basic_json>> // allocator_type
-    @endcode
-    #### Behavior
-    The choice of @a object_t influences the behavior of the JSON class. With
-    the default type, objects have the following behavior:
-    - When all names are unique, objects will be interoperable in the sense
-      that all software implementations receiving that object will agree on
-      the name-value mappings.
-    - When the names within an object are not unique, it is unspecified which
-      one of the values for a given key will be chosen. For instance,
-      `{"key": 2, "key": 1}` could be equal to either `{"key": 1}` or
-      `{"key": 2}`.
-    - Internally, name/value pairs are stored in lexicographical order of the
-      names. Objects will also be serialized (see @ref dump) in this order.
-      For instance, `{"b": 1, "a": 2}` and `{"a": 2, "b": 1}` will be stored
-      and serialized as `{"a": 2, "b": 1}`.
-    - When comparing objects, the order of the name/value pairs is irrelevant.
-      This makes objects interoperable in the sense that they will not be
-      affected by these differences. For instance, `{"b": 1, "a": 2}` and
-      `{"a": 2, "b": 1}` will be treated as equal.
-    #### Limits
-    [RFC 7159](http://rfc7159.net/rfc7159) specifies:
-    > An implementation may set limits on the maximum depth of nesting.
-    In this class, the object's limit of nesting is not explicitly constrained.
-    However, a maximum depth of nesting may be introduced by the compiler or
-    runtime environment. A theoretical limit can be queried by calling the
-    @ref max_size function of a JSON object.
-    #### Storage
-    Objects are stored as pointers in a @ref basic_json type. That is, for any
-    access to object values, a pointer of type `object_t*` must be
-    dereferenced.
-    @sa @ref array_t -- type for an array value
-    @since version 1.0.0
-    @note The order name/value pairs are added to the object is *not*
-    preserved by the library. Therefore, iterating an object may return
-    name/value pairs in a different order than they were originally stored. In
-    fact, keys will be traversed in alphabetical order as `std::map` with
-    `std::less` is used by default. Please note this behavior conforms to [RFC
-    7159](http://rfc7159.net/rfc7159), because any order implements the
-    specified "unordered" nature of JSON objects.
+    /// @brief a type for an object
+    /// @sa https://json.nlohmann.me/api/basic_json/object_t/
     using object_t = ObjectType<StringType,
           basic_json,
-          object_comparator_t,
+          default_object_comparator_t,
           AllocatorType<std::pair<const StringType,
           basic_json>>>;
-    @brief a type for an array
-    [RFC 7159](http://rfc7159.net/rfc7159) describes JSON arrays as follows:
-    > An array is an ordered sequence of zero or more values.
-    explained below.
-    @tparam ArrayType  container type to store arrays (e.g., `std::vector` or
-    `std::list`)
-    @tparam AllocatorType allocator to use for arrays (e.g., `std::allocator`)
-    #### Default type
-    With the default values for @a ArrayType (`std::vector`) and @a
-    AllocatorType (`std::allocator`), the default value for @a array_t is:
-    @code {.cpp}
-    std::vector<
-      std::allocator<basic_json> // allocator_type
-    @endcode
-    #### Limits
-    In this class, the array's limit of nesting is not explicitly constrained.
-    @ref max_size function of a JSON array.
-    #### Storage
-    Arrays are stored as pointers in a @ref basic_json type. That is, for any
-    access to array values, a pointer of type `array_t*` must be dereferenced.
-    @sa @ref object_t -- type for an object value
+    /// @brief a type for an array
+    /// @sa https://json.nlohmann.me/api/basic_json/array_t/
     using array_t = ArrayType<basic_json, AllocatorType<basic_json>>;
-    @brief a type for a string
-    [RFC 7159](http://rfc7159.net/rfc7159) describes JSON strings as follows:
-    > A string is a sequence of zero or more Unicode characters.
-    described below. Unicode values are split by the JSON class into
-    byte-sized characters during deserialization.
-    @tparam StringType  the container to store strings (e.g., `std::string`).
-    Note this container is used for keys/names in objects, see @ref object_t.
-    #### Default type
-    With the default values for @a StringType (`std::string`), the default
-    value for @a string_t is:
-    @code {.cpp}
-    std::string
-    @endcode
-    #### Encoding
-    Strings are stored in UTF-8 encoding. Therefore, functions like
-    `std::string::size()` or `std::string::length()` return the number of
-    bytes in the string rather than the number of characters or glyphs.
-    #### String comparison
-    [RFC 7159](http://rfc7159.net/rfc7159) states:
-    > Software implementations are typically required to test names of object
-    > members for equality. Implementations that transform the textual
-    > representation into sequences of Unicode code units and then perform the
-    > comparison numerically, code unit by code unit, are interoperable in the
-    > sense that implementations will agree in all cases on equality or
-    > inequality of two strings. For example, implementations that compare
-    > strings with escaped characters unconverted may incorrectly find that
-    > `"a\\b"` and `"a\u005Cb"` are not equal.
-    This implementation is interoperable as it does compare strings code unit
-    by code unit.
-    #### Storage
-    String values are stored as pointers in a @ref basic_json type. That is,
-    for any access to string values, a pointer of type `string_t*` must be
-    dereferenced.
+    /// @brief a type for a string
+    /// @sa https://json.nlohmann.me/api/basic_json/string_t/
     using string_t = StringType;
-    @brief a type for a boolean
-    [RFC 7159](http://rfc7159.net/rfc7159) implicitly describes a boolean as a
-    type which differentiates the two literals `true` and `false`.
-    To store objects in C++, a type is defined by the template parameter @a
-    BooleanType which chooses the type to use.
-    #### Default type
-    With the default values for @a BooleanType (`bool`), the default value for
-    @a boolean_t is:
-    @code {.cpp}
-    bool
-    @endcode
-    #### Storage
-    Boolean values are stored directly inside a @ref basic_json type.
+    /// @brief a type for a boolean
+    /// @sa https://json.nlohmann.me/api/basic_json/boolean_t/
     using boolean_t = BooleanType;
-    @brief a type for a number (integer)
-    [RFC 7159](http://rfc7159.net/rfc7159) describes numbers as follows:
-    > The representation of numbers is similar to that used in most
-    > programming languages. A number is represented in base 10 using decimal
-    > digits. It contains an integer component that may be prefixed with an
-    > optional minus sign, which may be followed by a fraction part and/or an
-    > exponent part. Leading zeros are not allowed. (...) Numeric values that
-    > cannot be represented in the grammar below (such as Infinity and NaN)
-    > are not permitted.
-    This description includes both integer and floating-point numbers.
-    However, C++ allows more precise storage if it is known whether the number
-    is a signed integer, an unsigned integer or a floating-point number.
-    Therefore, three different types, @ref number_integer_t, @ref
-    number_unsigned_t and @ref number_float_t are used.
-    To store integer numbers in C++, a type is defined by the template
-    parameter @a NumberIntegerType which chooses the type to use.
-    #### Default type
-    With the default values for @a NumberIntegerType (`int64_t`), the default
-    value for @a number_integer_t is:
-    @code {.cpp}
-    int64_t
-    @endcode
-    #### Default behavior
-    - The restrictions about leading zeros is not enforced in C++. Instead,
-      leading zeros in integer literals lead to an interpretation as octal
-      number. Internally, the value will be stored as decimal number. For
-      instance, the C++ integer literal `010` will be serialized to `8`.
-      During deserialization, leading zeros yield an error.
-    - Not-a-number (NaN) values will be serialized to `null`.
-    #### Limits
-    > An implementation may set limits on the range and precision of numbers.
-    When the default type is used, the maximal integer number that can be
-    stored is `9223372036854775807` (INT64_MAX) and the minimal integer number
-    that can be stored is `-9223372036854775808` (INT64_MIN). Integer numbers
-    that are out of range will yield over/underflow when used in a
-    constructor. During deserialization, too large or small integer numbers
-    will be automatically be stored as @ref number_unsigned_t or @ref
-    number_float_t.
-    [RFC 7159](http://rfc7159.net/rfc7159) further states:
-    > Note that when such software is used, numbers that are integers and are
-    > in the range \f$[-2^{53}+1, 2^{53}-1]\f$ are interoperable in the sense
-    > that implementations will agree exactly on their numeric values.
-    As this range is a subrange of the exactly supported range [INT64_MIN,
-    INT64_MAX], this class's integer type is interoperable.
-    #### Storage
-    Integer number values are stored directly inside a @ref basic_json type.
-    @sa @ref number_float_t -- type for number values (floating-point)
-    @sa @ref number_unsigned_t -- type for number values (unsigned integer)
+    /// @brief a type for a number (integer)
+    /// @sa https://json.nlohmann.me/api/basic_json/number_integer_t/
     using number_integer_t = NumberIntegerType;
-    @brief a type for a number (unsigned)
-    To store unsigned integer numbers in C++, a type is defined by the
-    template parameter @a NumberUnsignedType which chooses the type to use.
-    #### Default type
-    With the default values for @a NumberUnsignedType (`uint64_t`), the
-    default value for @a number_unsigned_t is:
-    @code {.cpp}
-    uint64_t
-    @endcode
-    #### Limits
-    stored is `18446744073709551615` (UINT64_MAX) and the minimal integer
-    number that can be stored is `0`. Integer numbers that are out of range
-    will yield over/underflow when used in a constructor. During
-    deserialization, too large or small integer numbers will be automatically
-    be stored as @ref number_integer_t or @ref number_float_t.
-    As this range is a subrange (when considered in conjunction with the
-    number_integer_t type) of the exactly supported range [0, UINT64_MAX],
-    this class's integer type is interoperable.
-    #### Storage
-    @sa @ref number_integer_t -- type for number values (integer)
-    @since version 2.0.0
+    /// @brief a type for a number (unsigned)
+    /// @sa https://json.nlohmann.me/api/basic_json/number_unsigned_t/
     using number_unsigned_t = NumberUnsignedType;
-    @brief a type for a number (floating-point)
-    To store floating-point numbers in C++, a type is defined by the template
-    parameter @a NumberFloatType which chooses the type to use.
-    #### Default type
-    With the default values for @a NumberFloatType (`double`), the default
-    value for @a number_float_t is:
-    @code {.cpp}
-    double
-    @endcode
-      leading zeros in floating-point literals will be ignored. Internally,
-      the value will be stored as decimal number. For instance, the C++
-      floating-point literal `01.2` will be serialized to `1.2`. During
-      deserialization, leading zeros yield an error.
-    #### Limits
-    > This specification allows implementations to set limits on the range and
-    > precision of numbers accepted. Since software that implements IEEE
-    > 754-2008 binary64 (double precision) numbers is generally available and
-    > widely used, good interoperability can be achieved by implementations
-    > that expect no more precision or range than these provide, in the sense
-    > that implementations will approximate JSON numbers within the expected
-    > precision.
-    This implementation does exactly follow this approach, as it uses double
-    precision floating-point numbers. Note values smaller than
-    `-1.79769313486232e+308` and values greater than `1.79769313486232e+308`
-    will be stored as NaN internally and be serialized to `null`.
-    #### Storage
-    Floating-point number values are stored directly inside a @ref basic_json
-    type.
+    /// @brief a type for a number (floating-point)
+    /// @sa https://json.nlohmann.me/api/basic_json/number_float_t/
     using number_float_t = NumberFloatType;
-    @brief a type for a packed binary type
-    This type is a type designed to carry binary data that appears in various
-    serialized formats, such as CBOR's Major Type 2, MessagePack's bin, and
-    BSON's generic binary subtype. This type is NOT a part of standard JSON and
-    exists solely for compatibility with these binary types. As such, it is
-    simply defined as an ordered sequence of zero or more byte values.
-    Additionally, as an implementation detail, the subtype of the binary data is
-    carried around as a `std::uint8_t`, which is compatible with both of the
-    binary data formats that use binary subtyping, (though the specific
-    numbering is incompatible with each other, and it is up to the user to
-    translate between them).
-    [CBOR's RFC 7049](https://tools.ietf.org/html/rfc7049) describes this type
-    as:
-    > Major type 2: a byte string. The string's length in bytes is represented
-    > following the rules for positive integers (major type 0).
-    [MessagePack's documentation on the bin type
-    family](https://github.com/msgpack/msgpack/blob/master/spec.md#bin-format-family)
-    describes this type as:
-    > Bin format family stores an byte array in 2, 3, or 5 bytes of extra bytes
-    > in addition to the size of the byte array.
-    [BSON's specifications](http://bsonspec.org/spec.html) describe several
-    binary types; however, this type is intended to represent the generic binary
-    type which has the description:
-    > Generic binary subtype - This is the most commonly used binary subtype and
-    > should be the 'default' for drivers and tools.
-    None of these impose any limitations on the internal representation other
-    than the basic unit of storage be some type of array whose parts are
-    decomposable into bytes.
-    The default representation of this binary format is a
-    `std::vector<std::uint8_t>`, which is a very common way to represent a byte
-    array in modern C++.
-    #### Default type
-    The default values for @a BinaryType is `std::vector<std::uint8_t>`
-    #### Storage
-    Binary Arrays are stored as pointers in a @ref basic_json type. That is,
-    for any access to array values, a pointer of the type `binary_t*` must be
-    dereferenced.
-    #### Notes on subtypes
-    - CBOR
-       - Binary values are represented as byte strings. No subtypes are
-         supported and will be ignored when CBOR is written.
-    - MessagePack
-       - If a subtype is given and the binary array contains exactly 1, 2, 4, 8,
-         or 16 elements, the fixext family (fixext1, fixext2, fixext4, fixext8)
-         is used. For other sizes, the ext family (ext8, ext16, ext32) is used.
-         The subtype is then added as signed 8-bit integer.
-       - If no subtype is given, the bin family (bin8, bin16, bin32) is used.
-    - BSON
-       - If a subtype is given, it is used and added as unsigned 8-bit integer.
-       - If no subtype is given, the generic binary subtype 0x00 is used.
-    @sa @ref binary -- create a binary array
-    @since version 3.8.0
+    /// @brief a type for a packed binary type
+    /// @sa https://json.nlohmann.me/api/basic_json/binary_t/
     using binary_t = nlohmann::byte_container_with_subtype<BinaryType>;
+    /// @brief object key comparator type
+    /// @sa https://json.nlohmann.me/api/basic_json/object_comparator_t/
+    using object_comparator_t = detail::actual_object_comparator_t<basic_json>;
   private:
@@ -17651,25 +19782,25 @@ class basic_json
                 case value_t::boolean:
-                    boolean = boolean_t(false);
+                    boolean = static_cast<boolean_t>(false);
                     break;
                 case value_t::number_integer:
-                    number_integer = number_integer_t(0);
+                    number_integer = static_cast<number_integer_t>(0);
                     break;
                 case value_t::number_unsigned:
-                    number_unsigned = number_unsigned_t(0);
+                    number_unsigned = static_cast<number_unsigned_t>(0);
                     break;
                 case value_t::number_float:
-                    number_float = number_float_t(0.0);
+                    number_float = static_cast<number_float_t>(0.0);
                     break;
@@ -17679,12 +19810,13 @@ class basic_json
                     break;
+                case value_t::discarded:
                 default:
                     object = nullptr;  // silence warning, see #821
                     if (JSON_HEDLEY_UNLIKELY(t == value_t::null))
-                        JSON_THROW(other_error::create(500, "961c151d2e87f2686a955a9be24d316f1362bf21 3.9.1")); // LCOV_EXCL_LINE
+                        JSON_THROW(other_error::create(500, "961c151d2e87f2686a955a9be24d316f1362bf21 3.11.3", nullptr)); // LCOV_EXCL_LINE
                     break;
@@ -17692,112 +19824,94 @@ class basic_json
         /// constructor for strings
-        json_value(const string_t& value)
-            string = create<string_t>(value);
+        json_value(const string_t& value) : string(create<string_t>(value)) {}
         /// constructor for rvalue strings
-        json_value(string_t&& value)
-            string = create<string_t>(std::move(value));
+        json_value(string_t&& value) : string(create<string_t>(std::move(value))) {}
         /// constructor for objects
-        json_value(const object_t& value)
-            object = create<object_t>(value);
+        json_value(const object_t& value) : object(create<object_t>(value)) {}
         /// constructor for rvalue objects
-        json_value(object_t&& value)
-            object = create<object_t>(std::move(value));
+        json_value(object_t&& value) : object(create<object_t>(std::move(value))) {}
         /// constructor for arrays
-        json_value(const array_t& value)
-            array = create<array_t>(value);
+        json_value(const array_t& value) : array(create<array_t>(value)) {}
         /// constructor for rvalue arrays
-        json_value(array_t&& value)
-            array = create<array_t>(std::move(value));
+        json_value(array_t&& value) : array(create<array_t>(std::move(value))) {}
         /// constructor for binary arrays
-        json_value(const typename binary_t::container_type& value)
-            binary = create<binary_t>(value);
+        json_value(const typename binary_t::container_type& value) : binary(create<binary_t>(value)) {}
         /// constructor for rvalue binary arrays
-        json_value(typename binary_t::container_type&& value)
-            binary = create<binary_t>(std::move(value));
+        json_value(typename binary_t::container_type&& value) : binary(create<binary_t>(std::move(value))) {}
         /// constructor for binary arrays (internal type)
-        json_value(const binary_t& value)
+        json_value(const binary_t& value) : binary(create<binary_t>(value)) {}
         /// constructor for rvalue binary arrays (internal type)
-        json_value(binary_t&& value)
+        json_value(binary_t&& value) : binary(create<binary_t>(std::move(value))) {}
+        void destroy(value_t t)
-        void destroy(value_t t) noexcept
-            // flatten the current json_value to a heap-allocated stack
-            std::vector<basic_json> stack;
-            // move the top-level items to stack
-            if (t == value_t::array)
+            if (
+                (t == value_t::object && object == nullptr) ||
+                (t == value_t::array && array == nullptr) ||
+                (t == value_t::string && string == nullptr) ||
+                (t == value_t::binary && binary == nullptr)
-                stack.reserve(array->size());
-                std::move(array->begin(), array->end(), std::back_inserter(stack));
+                //not initialized (e.g. due to exception in the ctor)
+                return;
-            else if (t == value_t::object)
+            if (t == value_t::array || t == value_t::object)
-                stack.reserve(object->size());
-                for (auto&& it : *object)
+                // flatten the current json_value to a heap-allocated stack
+                std::vector<basic_json> stack;
+                // move the top-level items to stack
+                if (t == value_t::array)
-                    stack.push_back(std::move(it.second));
+                    stack.reserve(array->size());
+                    std::move(array->begin(), array->end(), std::back_inserter(stack));
-            while (!stack.empty())
-                // move the last item to local variable to be processed
-                basic_json current_item(std::move(stack.back()));
-                stack.pop_back();
-                // if current_item is array/object, move
-                // its children to the stack to be processed later
-                if (current_item.is_array())
+                else
-                    std::move(current_item.m_value.array->begin(), current_item.m_value.array->end(),
-                              std::back_inserter(stack));
-                    current_item.m_value.array->clear();
-                else if (current_item.is_object())
-                    for (auto&& it : *current_item.m_value.object)
+                    stack.reserve(object->size());
+                    for (auto&& it : *object)
-                    current_item.m_value.object->clear();
-                // it's now safe that current_item get destructed
-                // since it doesn't have any children
+                while (!stack.empty())
+                    // move the last item to local variable to be processed
+                    basic_json current_item(std::move(stack.back()));
+                    stack.pop_back();
+                    // if current_item is array/object, move
+                    // its children to the stack to be processed later
+                    if (current_item.is_array())
+                        std::move(current_item.m_data.m_value.array->begin(), current_item.m_data.m_value.array->end(), std::back_inserter(stack));
+                        current_item.m_data.m_value.array->clear();
+                    else if (current_item.is_object())
+                        for (auto&& it : *current_item.m_data.m_value.object)
+                            stack.push_back(std::move(it.second));
+                        current_item.m_data.m_value.object->clear();
+                    // it's now safe that current_item get destructed
+                    // since it doesn't have any children
             switch (t)
@@ -17834,6 +19948,12 @@ class basic_json
                     break;
+                case value_t::null:
+                case value_t::boolean:
+                case value_t::number_integer:
+                case value_t::number_unsigned:
+                case value_t::number_float:
                 default:
                     break;
@@ -17851,13 +19971,123 @@ class basic_json
     invariant. Furthermore, it has to be called each time the type of a JSON
     value is changed, because the invariant expresses a relationship between
     @a m_type and @a m_value.
+    Furthermore, the parent relation is checked for arrays and objects: If
+    @a check_parents true and the value is an array or object, then the
+    container's elements must have the current value as parent.
+    @param[in] check_parents  whether the parent relation should be checked.
+               The value is true by default and should only be set to false
+               during destruction of objects when the invariant does not
+               need to hold.
-    void assert_invariant() const noexcept
+    void assert_invariant(bool check_parents = true) const noexcept
-        JSON_ASSERT(m_type != value_t::object || m_value.object != nullptr);
-        JSON_ASSERT(m_type != value_t::array || m_value.array != nullptr);
-        JSON_ASSERT(m_type != value_t::string || m_value.string != nullptr);
-        JSON_ASSERT(m_type != value_t::binary || m_value.binary != nullptr);
+        JSON_ASSERT(m_data.m_type != value_t::object || m_data.m_value.object != nullptr);
+        JSON_ASSERT(m_data.m_type != value_t::array || m_data.m_value.array != nullptr);
+        JSON_ASSERT(m_data.m_type != value_t::string || m_data.m_value.string != nullptr);
+        JSON_ASSERT(m_data.m_type != value_t::binary || m_data.m_value.binary != nullptr);
+#if JSON_DIAGNOSTICS
+        JSON_TRY
+            // cppcheck-suppress assertWithSideEffect
+            JSON_ASSERT(!check_parents || !is_structured() || std::all_of(begin(), end(), [this](const basic_json & j)
+                return j.m_parent == this;
+        JSON_CATCH(...) {} // LCOV_EXCL_LINE
+#endif
+        static_cast<void>(check_parents);
+    void set_parents()
+        switch (m_data.m_type)
+            case value_t::array:
+                for (auto& element : *m_data.m_value.array)
+                    element.m_parent = this;
+                break;
+            case value_t::object:
+                for (auto& element : *m_data.m_value.object)
+                    element.second.m_parent = this;
+                break;
+            case value_t::string:
+            case value_t::binary:
+            default:
+                break;
+#endif
+    iterator set_parents(iterator it, typename iterator::difference_type count_set_parents)
+        for (typename iterator::difference_type i = 0; i < count_set_parents; ++i)
+            (it + i)->m_parent = this;
+#else
+        static_cast<void>(count_set_parents);
+#endif
+        return it;
+    reference set_parent(reference j, std::size_t old_capacity = static_cast<std::size_t>(-1))
+        if (old_capacity != static_cast<std::size_t>(-1))
+            // see https://github.com/nlohmann/json/issues/2838
+            JSON_ASSERT(type() == value_t::array);
+            if (JSON_HEDLEY_UNLIKELY(m_data.m_value.array->capacity() != old_capacity))
+                // capacity has changed: update all parents
+                set_parents();
+                return j;
+        // ordered_json uses a vector internally, so pointers could have
+        // been invalidated; see https://github.com/nlohmann/json/issues/2962
+#ifdef JSON_HEDLEY_MSVC_VERSION
+#pragma warning(push )
+#pragma warning(disable : 4127) // ignore warning to replace if with if constexpr
+#endif
+        if (detail::is_ordered_map<object_t>::value)
+            set_parents();
+            return j;
+#pragma warning( pop )
+#endif
+        j.m_parent = this;
+#else
+        static_cast<void>(j);
+        static_cast<void>(old_capacity);
+#endif
+        return j;
   public:
@@ -17865,72 +20095,12 @@ class basic_json
     // JSON parser callback //
-    @brief parser event types
-    The parser callback distinguishes the following events:
-    - `object_start`: the parser read `{` and started to process a JSON object
-    - `key`: the parser read a key of a value in an object
-    - `object_end`: the parser read `}` and finished processing a JSON object
-    - `array_start`: the parser read `[` and started to process a JSON array
-    - `array_end`: the parser read `]` and finished processing a JSON array
-    - `value`: the parser finished reading a JSON value
-    @image html callback_events.png "Example when certain parse events are triggered"
-    @sa @ref parser_callback_t for more information and examples
+    /// @brief parser event types
+    /// @sa https://json.nlohmann.me/api/basic_json/parse_event_t/
     using parse_event_t = detail::parse_event_t;
-    @brief per-element parser callback type
-    With a parser callback function, the result of parsing a JSON text can be
-    influenced. When passed to @ref parse, it is called on certain events
-    (passed as @ref parse_event_t via parameter @a event) with a set recursion
-    depth @a depth and context JSON value @a parsed. The return value of the
-    callback function is a boolean indicating whether the element that emitted
-    the callback shall be kept or not.
-    We distinguish six scenarios (determined by the event type) in which the
-    callback function can be called. The following table describes the values
-    of the parameters @a depth, @a event, and @a parsed.
-    parameter @a event | description | parameter @a depth | parameter @a parsed
-    parse_event_t::object_start | the parser read `{` and started to process a JSON object | depth of the parent of the JSON object | a JSON value with type discarded
-    parse_event_t::key | the parser read a key of a value in an object | depth of the currently parsed JSON object | a JSON string containing the key
-    parse_event_t::object_end | the parser read `}` and finished processing a JSON object | depth of the parent of the JSON object | the parsed JSON object
-    parse_event_t::array_start | the parser read `[` and started to process a JSON array | depth of the parent of the JSON array | a JSON value with type discarded
-    parse_event_t::array_end | the parser read `]` and finished processing a JSON array | depth of the parent of the JSON array | the parsed JSON array
-    parse_event_t::value | the parser finished reading a JSON value | depth of the value | the parsed JSON value
-    Discarding a value (i.e., returning `false`) has different effects
-    depending on the context in which function was called:
-    - Discarded values in structured types are skipped. That is, the parser
-      will behave as if the discarded value was never read.
-    - In case a value outside a structured type is skipped, it is replaced
-      with `null`. This case happens if the top-level element is skipped.
-    @param[in] depth  the depth of the recursion during parsing
-    @param[in] event  an event of type parse_event_t indicating the context in
-    the callback function has been called
-    @param[in,out] parsed  the current intermediate parse result; note that
-    writing to this value has no effect for parse_event_t::key events
-    @return Whether the JSON value which called the function during parsing
-    should be kept (`true`) or not (`false`). In the latter case, it is either
-    skipped completely or replaced by an empty discarded object.
-    @sa @ref parse for examples
+    /// @brief per-element parser callback type
+    /// @sa https://json.nlohmann.me/api/basic_json/parser_callback_t/
     using parser_callback_t = detail::parser_callback_t<basic_json>;
@@ -17942,167 +20112,39 @@ class basic_json
     /// assignment, static functions creating objects, and the destructor.
-    @brief create an empty value with a given type
-    Create an empty JSON value with a given type. The value will be default
-    initialized with an empty value which depends on the type:
-    Value type  | initial value
-    null        | `null`
-    boolean     | `false`
-    string      | `""`
-    number      | `0`
-    object      | `{}`
-    array       | `[]`
-    binary      | empty array
-    @param[in] v  the type of the value to create
-    @liveexample{The following code shows the constructor for different @ref
-    value_t values,basic_json__value_t}
-    @sa @ref clear() -- restores the postcondition of this constructor
+    /// @brief create an empty value with a given type
+    /// @sa https://json.nlohmann.me/api/basic_json/basic_json/
     basic_json(const value_t v)
-        : m_type(v), m_value(v)
+        : m_data(v)
         assert_invariant();
-    @brief create a null object
-    Create a `null` JSON value. It either takes a null pointer as parameter
-    (explicitly creating `null`) or no parameter (implicitly creating `null`).
-    The passed null pointer itself is not read -- it is only used to choose
-    the right constructor.
-    @exceptionsafety No-throw guarantee: this constructor never throws
-    exceptions.
-    @liveexample{The following code shows the constructor with and without a
-    null pointer parameter.,basic_json__nullptr_t}
-    basic_json(std::nullptr_t = nullptr) noexcept
+    /// @brief create a null object
+    basic_json(std::nullptr_t = nullptr) noexcept // NOLINT(bugprone-exception-escape)
         : basic_json(value_t::null)
         assert_invariant();
-    @brief create a JSON value
-    This is a "catch all" constructor for all compatible JSON types; that is,
-    types for which a `to_json()` method exists. The constructor forwards the
-    parameter @a val to that method (to `json_serializer<U>::to_json` method
-    with `U = uncvref_t<CompatibleType>`, to be exact).
-    Template type @a CompatibleType includes, but is not limited to, the
-    following types:
-    - **arrays**: @ref array_t and all kinds of compatible containers such as
-      `std::vector`, `std::deque`, `std::list`, `std::forward_list`,
-      `std::array`, `std::valarray`, `std::set`, `std::unordered_set`,
-      `std::multiset`, and `std::unordered_multiset` with a `value_type` from
-      which a @ref basic_json value can be constructed.
-    - **objects**: @ref object_t and all kinds of compatible associative
-      containers such as `std::map`, `std::unordered_map`, `std::multimap`,
-      and `std::unordered_multimap` with a `key_type` compatible to
-      @ref string_t and a `value_type` from which a @ref basic_json value can
-      be constructed.
-    - **strings**: @ref string_t, string literals, and all compatible string
-      containers can be used.
-    - **numbers**: @ref number_integer_t, @ref number_unsigned_t,
-      @ref number_float_t, and all convertible number types such as `int`,
-      `size_t`, `int64_t`, `float` or `double` can be used.
-    - **boolean**: @ref boolean_t / `bool` can be used.
-    - **binary**: @ref binary_t / `std::vector<uint8_t>` may be used,
-      unfortunately because string literals cannot be distinguished from binary
-      character arrays by the C++ type system, all types compatible with `const
-      char*` will be directed to the string constructor instead.  This is both
-      for backwards compatibility, and due to the fact that a binary type is not
-      a standard JSON type.
-    See the examples below.
-    @tparam CompatibleType a type such that:
-    - @a CompatibleType is not derived from `std::istream`,
-    - @a CompatibleType is not @ref basic_json (to avoid hijacking copy/move
-         constructors),
-    - @a CompatibleType is not a different @ref basic_json type (i.e. with different template arguments)
-    - @a CompatibleType is not a @ref basic_json nested type (e.g.,
-         @ref json_pointer, @ref iterator, etc ...)
-    - @ref @ref json_serializer<U> has a
-         `to_json(basic_json_t&, CompatibleType&&)` method
-    @tparam U = `uncvref_t<CompatibleType>`
-    @param[in] val the value to be forwarded to the respective constructor
-    @complexity Usually linear in the size of the passed @a val, also
-                depending on the implementation of the called `to_json()`
-                method.
-    @exceptionsafety Depends on the called constructor. For types directly
-    supported by the library (i.e., all types for which no `to_json()` function
-    was provided), strong guarantee holds: if an exception is thrown, there are
-    no changes to any JSON value.
-    @liveexample{The following code shows the constructor with several
-    compatible types.,basic_json__CompatibleType}
-    @since version 2.1.0
+    /// @brief create a JSON value from compatible types
     template < typename CompatibleType,
                typename U = detail::uncvref_t<CompatibleType>,
                    !detail::is_basic_json<U>::value && detail::is_compatible_type<basic_json_t, U>::value, int > = 0 >
-    basic_json(CompatibleType && val) noexcept(noexcept(
+    basic_json(CompatibleType && val) noexcept(noexcept( // NOLINT(bugprone-forwarding-reference-overload,bugprone-exception-escape)
                 JSONSerializer<U>::to_json(std::declval<basic_json_t&>(),
                                            std::forward<CompatibleType>(val))))
         JSONSerializer<U>::to_json(*this, std::forward<CompatibleType>(val));
+        set_parents();
         assert_invariant();
-    @brief create a JSON value from an existing one
-    This is a constructor for existing @ref basic_json types.
-    It does not hijack copy/move constructors, since the parameter has different
-    template arguments than the current ones.
-    The constructor tries to convert the internal @ref m_value of the parameter.
-    @tparam BasicJsonType a type such that:
-    - @a BasicJsonType is a @ref basic_json type.
-    - @a BasicJsonType has different template arguments than @ref basic_json_t.
-    @param[in] val the @ref basic_json value to be converted.
-                method.
-    @since version 3.2.0
+    /// @brief create a JSON value from an existing one
     template < typename BasicJsonType,
                    detail::is_basic_json<BasicJsonType>::value&& !std::is_same<basic_json, BasicJsonType>::value, int > = 0 >
@@ -18147,88 +20189,18 @@ class basic_json
                 *this = nullptr;
                 break;
-                m_type = value_t::discarded;
+                m_data.m_type = value_t::discarded;
                 break;
             default:            // LCOV_EXCL_LINE
-                JSON_ASSERT(false);  // LCOV_EXCL_LINE
+                JSON_ASSERT(false); // NOLINT(cert-dcl03-c,hicpp-static-assert,misc-static-assert) LCOV_EXCL_LINE
+        JSON_ASSERT(m_data.m_type == val.type());
+        set_parents();
         assert_invariant();
-    @brief create a container (array or object) from an initializer list
-    Creates a JSON value of type array or object from the passed initializer
-    list @a init. In case @a type_deduction is `true` (default), the type of
-    the JSON value to be created is deducted from the initializer list @a init
-    according to the following rules:
-    1. If the list is empty, an empty JSON object value `{}` is created.
-    2. If the list consists of pairs whose first element is a string, a JSON
-       object value is created where the first elements of the pairs are
-       treated as keys and the second elements are as values.
-    3. In all other cases, an array is created.
-    The rules aim to create the best fit between a C++ initializer list and
-    JSON values. The rationale is as follows:
-    1. The empty initializer list is written as `{}` which is exactly an empty
-       JSON object.
-    2. C++ has no way of describing mapped types other than to list a list of
-       pairs. As JSON requires that keys must be of type string, rule 2 is the
-       weakest constraint one can pose on initializer lists to interpret them
-       as an object.
-    3. In all other cases, the initializer list could not be interpreted as
-       JSON object type, so interpreting it as JSON array type is safe.
-    With the rules described above, the following JSON values cannot be
-    expressed by an initializer list:
-    - the empty array (`[]`): use @ref array(initializer_list_t)
-      with an empty initializer list in this case
-    - arrays whose elements satisfy rule 2: use @ref
-      array(initializer_list_t) with the same initializer list
-      in this case
-    @note When used without parentheses around an empty initializer list, @ref
-    basic_json() is called instead of this function, yielding the JSON null
-    value.
-    @param[in] init  initializer list with JSON values
-    @param[in] type_deduction internal parameter; when set to `true`, the type
-    of the JSON value is deducted from the initializer list @a init; when set
-    to `false`, the type provided via @a manual_type is forced. This mode is
-    used by the functions @ref array(initializer_list_t) and
-    @ref object(initializer_list_t).
-    @param[in] manual_type internal parameter; when @a type_deduction is set
-    to `false`, the created JSON value will use the provided type (only @ref
-    value_t::array and @ref value_t::object are valid); when @a type_deduction
-    is set to `true`, this parameter has no effect
-    @throw type_error.301 if @a type_deduction is `false`, @a manual_type is
-    `value_t::object`, but @a init contains an element which is not a pair
-    whose first element is a string. In this case, the constructor could not
-    create an object. If @a type_deduction would have be `true`, an array
-    would have been created. See @ref object(initializer_list_t)
-    for an example.
-    @complexity Linear in the size of the initializer list @a init.
-    @liveexample{The example below shows how JSON values are created from
-    initializer lists.,basic_json__list_init_t}
-    @sa @ref array(initializer_list_t) -- create a JSON array
-    value from an initializer list
-    @sa @ref object(initializer_list_t) -- create a JSON object
+    /// @brief create a container (array or object) from an initializer list
     basic_json(initializer_list_t init,
                bool type_deduction = true,
                value_t manual_type = value_t::array)
@@ -18238,7 +20210,10 @@ class basic_json
         bool is_an_object = std::all_of(init.begin(), init.end(),
                                         [](const detail::json_ref<basic_json>& element_ref)
-            return element_ref->is_array() && element_ref->size() == 2 && (*element_ref)[0].is_string();
+            // The cast is to ensure op[size_type] is called, bearing in mind size_type may not be int;
+            // (many string types can be constructed from 0 via its null-pointer guise, so we get a
+            // broken call to op[key_type], the wrong semantics and a 4804 warning on Windows)
+            return element_ref->is_array() && element_ref->size() == 2 && (*element_ref)[static_cast<size_type>(0)].is_string();
         // adjust type if type deduction is not wanted
@@ -18253,298 +20228,106 @@ class basic_json
             // if object is wanted but impossible, throw an exception
             if (JSON_HEDLEY_UNLIKELY(manual_type == value_t::object && !is_an_object))
-                JSON_THROW(type_error::create(301, "cannot create object from initializer list"));
+                JSON_THROW(type_error::create(301, "cannot create object from initializer list", nullptr));
         if (is_an_object)
             // the initializer list is a list of pairs -> create object
-            m_type = value_t::object;
-            m_value = value_t::object;
+            m_data.m_type = value_t::object;
+            m_data.m_value = value_t::object;
-            std::for_each(init.begin(), init.end(), [this](const detail::json_ref<basic_json>& element_ref)
+            for (auto& element_ref : init)
                 auto element = element_ref.moved_or_copied();
-                m_value.object->emplace(
-                    std::move(*((*element.m_value.array)[0].m_value.string)),
-                    std::move((*element.m_value.array)[1]));
+                m_data.m_value.object->emplace(
+                    std::move(*((*element.m_data.m_value.array)[0].m_data.m_value.string)),
+                    std::move((*element.m_data.m_value.array)[1]));
         else
             // the initializer list describes an array -> create array
-            m_type = value_t::array;
-            m_value.array = create<array_t>(init.begin(), init.end());
+            m_data.m_type = value_t::array;
+            m_data.m_value.array = create<array_t>(init.begin(), init.end());
+        set_parents();
         assert_invariant();
-    @brief explicitly create a binary array (without subtype)
-    Creates a JSON binary array value from a given binary container. Binary
-    values are part of various binary formats, such as CBOR, MessagePack, and
-    BSON. This constructor is used to create a value for serialization to those
-    formats.
-    @note Note, this function exists because of the difficulty in correctly
-    specifying the correct template overload in the standard value ctor, as both
-    JSON arrays and JSON binary arrays are backed with some form of a
-    `std::vector`. Because JSON binary arrays are a non-standard extension it
-    was decided that it would be best to prevent automatic initialization of a
-    binary array type, for backwards compatibility and so it does not happen on
-    accident.
-    @param[in] init container containing bytes to use as binary type
-    @return JSON binary array value
-    @complexity Linear in the size of @a init.
+    /// @brief explicitly create a binary array (without subtype)
+    /// @sa https://json.nlohmann.me/api/basic_json/binary/
     static basic_json binary(const typename binary_t::container_type& init)
         auto res = basic_json();
-        res.m_type = value_t::binary;
-        res.m_value = init;
+        res.m_data.m_type = value_t::binary;
+        res.m_data.m_value = init;
         return res;
-    @brief explicitly create a binary array (with subtype)
-    formats.
-    accident.
-    @param[in] subtype subtype to use in MessagePack and BSON
+    /// @brief explicitly create a binary array (with subtype)
-    static basic_json binary(const typename binary_t::container_type& init, std::uint8_t subtype)
+    static basic_json binary(const typename binary_t::container_type& init, typename binary_t::subtype_type subtype)
-        res.m_value = binary_t(init, subtype);
+        res.m_data.m_value = binary_t(init, subtype);
         return res;
-    /// @copydoc binary(const typename binary_t::container_type&)
     static basic_json binary(typename binary_t::container_type&& init)
-        res.m_value = std::move(init);
+        res.m_data.m_value = std::move(init);
         return res;
-    /// @copydoc binary(const typename binary_t::container_type&, std::uint8_t)
-    static basic_json binary(typename binary_t::container_type&& init, std::uint8_t subtype)
+    static basic_json binary(typename binary_t::container_type&& init, typename binary_t::subtype_type subtype)
-        res.m_value = binary_t(std::move(init), subtype);
+        res.m_data.m_value = binary_t(std::move(init), subtype);
         return res;
-    @brief explicitly create an array from an initializer list
-    Creates a JSON array value from a given initializer list. That is, given a
-    list of values `a, b, c`, creates the JSON value `[a, b, c]`. If the
-    initializer list is empty, the empty array `[]` is created.
-    @note This function is only needed to express two edge cases that cannot
-    be realized with the initializer list constructor (@ref
-    basic_json(initializer_list_t, bool, value_t)). These cases
-    are:
-    1. creating an array whose elements are all pairs whose first element is a
-    string -- in this case, the initializer list constructor would create an
-    object, taking the first elements as keys
-    2. creating an empty array -- passing the empty initializer list to the
-    initializer list constructor yields an empty object
-    @param[in] init  initializer list with JSON values to create an array from
-    (optional)
-    @return JSON array value
-    @liveexample{The following code shows an example for the `array`
-    function.,array}
-    @sa @ref basic_json(initializer_list_t, bool, value_t) --
-    create a JSON value from an initializer list
+    /// @brief explicitly create an array from an initializer list
+    /// @sa https://json.nlohmann.me/api/basic_json/array/
     static basic_json array(initializer_list_t init = {})
         return basic_json(init, false, value_t::array);
-    @brief explicitly create an object from an initializer list
-    Creates a JSON object value from a given initializer list. The initializer
-    lists elements must be pairs, and their first elements must be strings. If
-    the initializer list is empty, the empty object `{}` is created.
-    @note This function is only added for symmetry reasons. In contrast to the
-    related function @ref array(initializer_list_t), there are
-    no cases which can only be expressed by this function. That is, any
-    initializer list @a init can also be passed to the initializer list
-    constructor @ref basic_json(initializer_list_t, bool, value_t).
-    @param[in] init  initializer list to create an object from (optional)
-    @return JSON object value
-    @throw type_error.301 if @a init is not a list of pairs whose first
-    elements are strings. In this case, no object can be created. When such a
-    value is passed to @ref basic_json(initializer_list_t, bool, value_t),
-    an array would have been created from the passed initializer list @a init.
-    See example below.
-    @liveexample{The following code shows an example for the `object`
-    function.,object}
+    /// @brief explicitly create an object from an initializer list
+    /// @sa https://json.nlohmann.me/api/basic_json/object/
     static basic_json object(initializer_list_t init = {})
         return basic_json(init, false, value_t::object);
-    @brief construct an array with count copies of given value
-    Constructs a JSON array value by creating @a cnt copies of a passed value.
-    In case @a cnt is `0`, an empty array is created.
-    @param[in] cnt  the number of JSON copies of @a val to create
-    @param[in] val  the JSON value to copy
-    @post `std::distance(begin(),end()) == cnt` holds.
-    @complexity Linear in @a cnt.
-    @liveexample{The following code shows examples for the @ref
-    basic_json(size_type\, const basic_json&)
-    constructor.,basic_json__size_type_basic_json}
-    basic_json(size_type cnt, const basic_json& val)
-        : m_type(value_t::array)
+    /// @brief construct an array with count copies of given value
+    basic_json(size_type cnt, const basic_json& val):
+        m_data{cnt, val}
-        m_value.array = create<array_t>(cnt, val);
+        set_parents();
         assert_invariant();
-    @brief construct a JSON container given an iterator range
-    Constructs the JSON value with the contents of the range `[first, last)`.
-    The semantics depends on the different types a JSON value can have:
-    - In case of a null type, invalid_iterator.206 is thrown.
-    - In case of other primitive types (number, boolean, or string), @a first
-      must be `begin()` and @a last must be `end()`. In this case, the value is
-      copied. Otherwise, invalid_iterator.204 is thrown.
-    - In case of structured types (array, object), the constructor behaves as
-      similar versions for `std::vector` or `std::map`; that is, a JSON array
-      or object is constructed from the values in the range.
-    @tparam InputIT an input iterator type (@ref iterator or @ref
-    const_iterator)
-    @param[in] first begin of the range to copy from (included)
-    @param[in] last end of the range to copy from (excluded)
-    @pre Iterators @a first and @a last must be initialized. **This
-         precondition is enforced with an assertion (see warning).** If
-         assertions are switched off, a violation of this precondition yields
-         undefined behavior.
-    @pre Range `[first, last)` is valid. Usually, this precondition cannot be
-         checked efficiently. Only certain edge cases are detected; see the
-         description of the exceptions below. A violation of this precondition
-         yields undefined behavior.
-    @warning A precondition is enforced with a runtime assertion that will
-             result in calling `std::abort` if this precondition is not met.
-             Assertions can be disabled by defining `NDEBUG` at compile time.
-             See https://en.cppreference.com/w/cpp/error/assert for more
-             information.
-    @throw invalid_iterator.201 if iterators @a first and @a last are not
-    compatible (i.e., do not belong to the same JSON value). In this case,
-    the range `[first, last)` is undefined.
-    @throw invalid_iterator.204 if iterators @a first and @a last belong to a
-    primitive type (number, boolean, or string), but @a first does not point
-    to the first element any more. In this case, the range `[first, last)` is
-    undefined. See example code below.
-    @throw invalid_iterator.206 if iterators @a first and @a last belong to a
-    null value. In this case, the range `[first, last)` is undefined.
-    @complexity Linear in distance between @a first and @a last.
-    @liveexample{The example below shows several ways to create JSON values by
-    specifying a subrange with iterators.,basic_json__InputIt_InputIt}
+    /// @brief construct a JSON container given an iterator range
     template < class InputIT, typename std::enable_if <
                    std::is_same<InputIT, typename basic_json_t::iterator>::value ||
                    std::is_same<InputIT, typename basic_json_t::const_iterator>::value, int >::type = 0 >
@@ -18556,14 +20339,14 @@ class basic_json
         // make sure iterator fits the current value
         if (JSON_HEDLEY_UNLIKELY(first.m_object != last.m_object))
-            JSON_THROW(invalid_iterator::create(201, "iterators are not compatible"));
+            JSON_THROW(invalid_iterator::create(201, "iterators are not compatible", nullptr));
         // copy type from first iterator
-        m_type = first.m_object->m_type;
+        m_data.m_type = first.m_object->m_data.m_type;
         // check if iterator range is complete for primitive values
-        switch (m_type)
@@ -18574,76 +20357,82 @@ class basic_json
                 if (JSON_HEDLEY_UNLIKELY(!first.m_it.primitive_iterator.is_begin()
                                          || !last.m_it.primitive_iterator.is_end()))
-                    JSON_THROW(invalid_iterator::create(204, "iterators out of range"));
+                    JSON_THROW(invalid_iterator::create(204, "iterators out of range", first.m_object));
                 break;
             default:
                 break;
-        switch (m_type)
-                m_value.number_integer = first.m_object->m_value.number_integer;
+                m_data.m_value.number_integer = first.m_object->m_data.m_value.number_integer;
                 break;
-                m_value.number_unsigned = first.m_object->m_value.number_unsigned;
+                m_data.m_value.number_unsigned = first.m_object->m_data.m_value.number_unsigned;
                 break;
-                m_value.number_float = first.m_object->m_value.number_float;
+                m_data.m_value.number_float = first.m_object->m_data.m_value.number_float;
                 break;
-                m_value.boolean = first.m_object->m_value.boolean;
+                m_data.m_value.boolean = first.m_object->m_data.m_value.boolean;
                 break;
-                m_value = *first.m_object->m_value.string;
+                m_data.m_value = *first.m_object->m_data.m_value.string;
                 break;
-                m_value.object = create<object_t>(first.m_it.object_iterator,
-                                                  last.m_it.object_iterator);
+                m_data.m_value.object = create<object_t>(first.m_it.object_iterator,
+                                        last.m_it.object_iterator);
                 break;
-                m_value.array = create<array_t>(first.m_it.array_iterator,
-                                                last.m_it.array_iterator);
+                m_data.m_value.array = create<array_t>(first.m_it.array_iterator,
+                                                       last.m_it.array_iterator);
                 break;
-                m_value = *first.m_object->m_value.binary;
+                m_data.m_value = *first.m_object->m_data.m_value.binary;
                 break;
             default:
-                JSON_THROW(invalid_iterator::create(206, "cannot construct with iterators from " +
-                                                    std::string(first.m_object->type_name())));
+                JSON_THROW(invalid_iterator::create(206, detail::concat("cannot construct with iterators from ", first.m_object->type_name()), first.m_object));
+        set_parents();
         assert_invariant();
     // other constructors and destructor //
@@ -18653,194 +20442,120 @@ class basic_json
                                  std::is_same<typename JsonRef::value_type, basic_json>>::value, int> = 0 >
     basic_json(const JsonRef& ref) : basic_json(ref.moved_or_copied()) {}
-    @brief copy constructor
-    Creates a copy of a given JSON value.
-    @param[in] other  the JSON value to copy
-    @post `*this == other`
-    @complexity Linear in the size of @a other.
-    @requirement This function helps `basic_json` satisfying the
-    requirements:
-    - The complexity is linear.
-    - As postcondition, it holds: `other == basic_json(other)`.
-    @liveexample{The following code shows an example for the copy
-    constructor.,basic_json__basic_json}
+    /// @brief copy constructor
     basic_json(const basic_json& other)
-        : m_type(other.m_type)
+        : json_base_class_t(other)
+        m_data.m_type = other.m_data.m_type;
         // check of passed value is valid
         other.assert_invariant();
-        switch (m_type)
-                m_value = *other.m_value.object;
+                m_data.m_value = *other.m_data.m_value.object;
                 break;
-                m_value = *other.m_value.array;
+                m_data.m_value = *other.m_data.m_value.array;
                 break;
-                m_value = *other.m_value.string;
+                m_data.m_value = *other.m_data.m_value.string;
                 break;
-                m_value = other.m_value.boolean;
+                m_data.m_value = other.m_data.m_value.boolean;
                 break;
-                m_value = other.m_value.number_integer;
+                m_data.m_value = other.m_data.m_value.number_integer;
                 break;
-                m_value = other.m_value.number_unsigned;
+                m_data.m_value = other.m_data.m_value.number_unsigned;
                 break;
-                m_value = other.m_value.number_float;
+                m_data.m_value = other.m_data.m_value.number_float;
                 break;
-                m_value = *other.m_value.binary;
+                m_data.m_value = *other.m_data.m_value.binary;
                 break;
             default:
                 break;
+        set_parents();
         assert_invariant();
-    @brief move constructor
-    Move constructor. Constructs a JSON value with the contents of the given
-    value @a other using move semantics. It "steals" the resources from @a
-    other and leaves it as JSON null value.
-    @param[in,out] other  value to move to this object
-    @post `*this` has the same value as @a other before the call.
-    @post @a other is a JSON null value.
-    exceptions.
-    [MoveConstructible](https://en.cppreference.com/w/cpp/named_req/MoveConstructible)
-    requirements.
-    @liveexample{The code below shows the move constructor explicitly called
-    via std::move.,basic_json__moveconstructor}
+    /// @brief move constructor
     basic_json(basic_json&& other) noexcept
-        : m_type(std::move(other.m_type)),
-          m_value(std::move(other.m_value))
+        : json_base_class_t(std::forward<json_base_class_t>(other)),
+          m_data(std::move(other.m_data))
         // check that passed value is valid
-        other.assert_invariant();
+        other.assert_invariant(false);
         // invalidate payload
-        other.m_type = value_t::null;
-        other.m_value = {};
+        other.m_data.m_type = value_t::null;
+        other.m_data.m_value = {};
+        set_parents();
         assert_invariant();
-    @brief copy assignment
-    Copy assignment operator. Copies a JSON value via the "copy and swap"
-    strategy: It is expressed in terms of the copy constructor, destructor,
-    and the `swap()` member function.
-    @param[in] other  value to copy from
-    @complexity Linear.
-    [Container](https://en.cppreference.com/w/cpp/named_req/Container)
-    requirements:
-    @liveexample{The code below shows and example for the copy assignment. It
-    creates a copy of value `a` which is then swapped with `b`. Finally\, the
-    copy of `a` (which is the null value after the swap) is
-    destroyed.,basic_json__copyassignment}
+    /// @brief copy assignment
+    /// @sa https://json.nlohmann.me/api/basic_json/operator=/
     basic_json& operator=(basic_json other) noexcept (
         std::is_nothrow_move_constructible<value_t>::value&&
         std::is_nothrow_move_assignable<value_t>::value&&
         std::is_nothrow_move_constructible<json_value>::value&&
-        std::is_nothrow_move_assignable<json_value>::value
+        std::is_nothrow_move_assignable<json_value>::value&&
+        std::is_nothrow_move_assignable<json_base_class_t>::value
         using std::swap;
-        swap(m_type, other.m_type);
-        swap(m_value, other.m_value);
+        swap(m_data.m_type, other.m_data.m_type);
+        swap(m_data.m_value, other.m_data.m_value);
+        json_base_class_t::operator=(std::move(other));
+        set_parents();
         assert_invariant();
         return *this;
-    @brief destructor
-    Destroys the JSON value and frees all allocated memory.
-    requirements:
-    - All stored elements are destroyed and all memory is freed.
+    /// @brief destructor
+    /// @sa https://json.nlohmann.me/api/basic_json/~basic_json/
     ~basic_json() noexcept
-        assert_invariant();
-        m_value.destroy(m_type);
+        assert_invariant(false);
@@ -18854,53 +20569,8 @@ class basic_json
     /// Functions to inspect the type of a JSON value.
-    @brief serialization
-    Serialization function for JSON values. The function tries to mimic
-    Python's `json.dumps()` function, and currently supports its @a indent
-    and @a ensure_ascii parameters.
-    @param[in] indent If indent is nonnegative, then array elements and object
-    members will be pretty-printed with that indent level. An indent level of
-    `0` will only insert newlines. `-1` (the default) selects the most compact
-    representation.
-    @param[in] indent_char The character to use for indentation if @a indent is
-    greater than `0`. The default is ` ` (space).
-    @param[in] ensure_ascii If @a ensure_ascii is true, all non-ASCII characters
-    in the output are escaped with `\uXXXX` sequences, and the result consists
-    of ASCII characters only.
-    @param[in] error_handler  how to react on decoding errors; there are three
-    possible values: `strict` (throws and exception in case a decoding error
-    occurs; default), `replace` (replace invalid UTF-8 sequences with U+FFFD),
-    and `ignore` (ignore invalid UTF-8 sequences during serialization; all
-    bytes are copied to the output unchanged).
-    @return string containing the serialization of the JSON value
-    @throw type_error.316 if a string stored inside the JSON value is not
-                          UTF-8 encoded and @a error_handler is set to strict
-    @note Binary values are serialized as object containing two keys:
-      - "bytes": an array of bytes as integers
-      - "subtype": the subtype as integer or "null" if the binary has no subtype
-    @exceptionsafety Strong guarantee: if an exception is thrown, there are no
-    changes in the JSON value.
-    @liveexample{The following example shows the effect of different @a indent\,
-    @a indent_char\, and @a ensure_ascii parameters to the result of the
-    serialization.,dump}
-    @see https://docs.python.org/2/library/json.html#json.dump
-    @since version 1.0.0; indentation character @a indent_char, option
-           @a ensure_ascii and exceptions added in version 3.0.0; error
-           handlers added in version 3.4.0; serialization of binary values added
-           in version 3.8.0.
+    /// @brief serialization
+    /// @sa https://json.nlohmann.me/api/basic_json/dump/
     string_t dump(const int indent = -1,
                   const char indent_char = ' ',
                   const bool ensure_ascii = false,
@@ -18921,400 +20591,109 @@ class basic_json
         return result;
-    @brief return the type of the JSON value (explicit)
-    Return the type of the JSON value as a value from the @ref value_t
-    enumeration.
-    @return the type of the JSON value
-            Value type                | return value
-            null                      | value_t::null
-            boolean                   | value_t::boolean
-            string                    | value_t::string
-            number (integer)          | value_t::number_integer
-            number (unsigned integer) | value_t::number_unsigned
-            number (floating-point)   | value_t::number_float
-            object                    | value_t::object
-            array                     | value_t::array
-            binary                    | value_t::binary
-            discarded                 | value_t::discarded
-    @complexity Constant.
-    @exceptionsafety No-throw guarantee: this member function never throws
-    exceptions.
-    @liveexample{The following code exemplifies `type()` for all JSON
-    types.,type}
-    @sa @ref operator value_t() -- return the type of the JSON value (implicit)
-    @sa @ref type_name() -- return the type as string
+    /// @brief return the type of the JSON value (explicit)
+    /// @sa https://json.nlohmann.me/api/basic_json/type/
     constexpr value_t type() const noexcept
-        return m_type;
+        return m_data.m_type;
-    @brief return whether type is primitive
-    This function returns true if and only if the JSON type is primitive
-    (string, number, boolean, or null).
-    @return `true` if type is primitive (string, number, boolean, or null),
-    `false` otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_primitive()` for all JSON
-    types.,is_primitive}
-    @sa @ref is_structured() -- returns whether JSON value is structured
-    @sa @ref is_null() -- returns whether JSON value is `null`
-    @sa @ref is_string() -- returns whether JSON value is a string
-    @sa @ref is_boolean() -- returns whether JSON value is a boolean
-    @sa @ref is_number() -- returns whether JSON value is a number
-    @sa @ref is_binary() -- returns whether JSON value is a binary array
+    /// @brief return whether type is primitive
+    /// @sa https://json.nlohmann.me/api/basic_json/is_primitive/
     constexpr bool is_primitive() const noexcept
         return is_null() || is_string() || is_boolean() || is_number() || is_binary();
-    @brief return whether type is structured
-    This function returns true if and only if the JSON type is structured
-    (array or object).
-    @return `true` if type is structured (array or object), `false` otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_structured()` for all JSON
-    types.,is_structured}
-    @sa @ref is_primitive() -- returns whether value is primitive
-    @sa @ref is_array() -- returns whether value is an array
-    @sa @ref is_object() -- returns whether value is an object
+    /// @brief return whether type is structured
+    /// @sa https://json.nlohmann.me/api/basic_json/is_structured/
     constexpr bool is_structured() const noexcept
         return is_array() || is_object();
-    @brief return whether value is null
-    This function returns true if and only if the JSON value is null.
-    @return `true` if type is null, `false` otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_null()` for all JSON
-    types.,is_null}
+    /// @brief return whether value is null
+    /// @sa https://json.nlohmann.me/api/basic_json/is_null/
     constexpr bool is_null() const noexcept
-        return m_type == value_t::null;
+        return m_data.m_type == value_t::null;
-    @brief return whether value is a boolean
-    This function returns true if and only if the JSON value is a boolean.
-    @return `true` if type is boolean, `false` otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_boolean()` for all JSON
-    types.,is_boolean}
+    /// @brief return whether value is a boolean
+    /// @sa https://json.nlohmann.me/api/basic_json/is_boolean/
     constexpr bool is_boolean() const noexcept
-        return m_type == value_t::boolean;
+        return m_data.m_type == value_t::boolean;
-    @brief return whether value is a number
-    This function returns true if and only if the JSON value is a number. This
-    includes both integer (signed and unsigned) and floating-point values.
-    @return `true` if type is number (regardless whether integer, unsigned
-    integer or floating-type), `false` otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_number()` for all JSON
-    types.,is_number}
-    @sa @ref is_number_integer() -- check if value is an integer or unsigned
-    integer number
-    @sa @ref is_number_unsigned() -- check if value is an unsigned integer
-    number
-    @sa @ref is_number_float() -- check if value is a floating-point number
+    /// @brief return whether value is a number
+    /// @sa https://json.nlohmann.me/api/basic_json/is_number/
     constexpr bool is_number() const noexcept
         return is_number_integer() || is_number_float();
-    @brief return whether value is an integer number
-    This function returns true if and only if the JSON value is a signed or
-    unsigned integer number. This excludes floating-point values.
-    @return `true` if type is an integer or unsigned integer number, `false`
-    otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_number_integer()` for all
-    JSON types.,is_number_integer}
-    @sa @ref is_number() -- check if value is a number
-    number
+    /// @brief return whether value is an integer number
+    /// @sa https://json.nlohmann.me/api/basic_json/is_number_integer/
     constexpr bool is_number_integer() const noexcept
-        return m_type == value_t::number_integer || m_type == value_t::number_unsigned;
+        return m_data.m_type == value_t::number_integer || m_data.m_type == value_t::number_unsigned;
-    @brief return whether value is an unsigned integer number
-    This function returns true if and only if the JSON value is an unsigned
-    integer number. This excludes floating-point and signed integer values.
-    @return `true` if type is an unsigned integer number, `false` otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_number_unsigned()` for all
-    JSON types.,is_number_unsigned}
-    integer number
+    /// @brief return whether value is an unsigned integer number
+    /// @sa https://json.nlohmann.me/api/basic_json/is_number_unsigned/
     constexpr bool is_number_unsigned() const noexcept
-        return m_type == value_t::number_unsigned;
+        return m_data.m_type == value_t::number_unsigned;
-    @brief return whether value is a floating-point number
-    floating-point number. This excludes signed and unsigned integer values.
-    @return `true` if type is a floating-point number, `false` otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_number_float()` for all
-    JSON types.,is_number_float}
-    @sa @ref is_number() -- check if value is number
-    @sa @ref is_number_integer() -- check if value is an integer number
-    number
+    /// @brief return whether value is a floating-point number
+    /// @sa https://json.nlohmann.me/api/basic_json/is_number_float/
     constexpr bool is_number_float() const noexcept
-        return m_type == value_t::number_float;
+        return m_data.m_type == value_t::number_float;
-    @brief return whether value is an object
-    This function returns true if and only if the JSON value is an object.
-    @return `true` if type is object, `false` otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_object()` for all JSON
-    types.,is_object}
+    /// @brief return whether value is an object
+    /// @sa https://json.nlohmann.me/api/basic_json/is_object/
     constexpr bool is_object() const noexcept
-        return m_type == value_t::object;
+        return m_data.m_type == value_t::object;
-    @brief return whether value is an array
-    This function returns true if and only if the JSON value is an array.
-    @return `true` if type is array, `false` otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_array()` for all JSON
-    types.,is_array}
+    /// @brief return whether value is an array
+    /// @sa https://json.nlohmann.me/api/basic_json/is_array/
     constexpr bool is_array() const noexcept
-        return m_type == value_t::array;
+        return m_data.m_type == value_t::array;
-    @brief return whether value is a string
-    This function returns true if and only if the JSON value is a string.
-    @return `true` if type is string, `false` otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_string()` for all JSON
-    types.,is_string}
+    /// @brief return whether value is a string
+    /// @sa https://json.nlohmann.me/api/basic_json/is_string/
     constexpr bool is_string() const noexcept
-        return m_type == value_t::string;
+        return m_data.m_type == value_t::string;
-    @brief return whether value is a binary array
-    This function returns true if and only if the JSON value is a binary array.
-    @return `true` if type is binary array, `false` otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_binary()` for all JSON
-    types.,is_binary}
+    /// @brief return whether value is a binary array
+    /// @sa https://json.nlohmann.me/api/basic_json/is_binary/
     constexpr bool is_binary() const noexcept
-        return m_type == value_t::binary;
+        return m_data.m_type == value_t::binary;
-    @brief return whether value is discarded
-    This function returns true if and only if the JSON value was discarded
-    during parsing with a callback function (see @ref parser_callback_t).
-    @note This function will always be `false` for JSON values after parsing.
-    That is, discarded values can only occur during parsing, but will be
-    removed when inside a structured value or replaced by null in other cases.
-    @return `true` if type is discarded, `false` otherwise.
-    exceptions.
-    @liveexample{The following code exemplifies `is_discarded()` for all JSON
-    types.,is_discarded}
+    /// @brief return whether value is discarded
+    /// @sa https://json.nlohmann.me/api/basic_json/is_discarded/
     constexpr bool is_discarded() const noexcept
-        return m_type == value_t::discarded;
+        return m_data.m_type == value_t::discarded;
-    @brief return the type of the JSON value (implicit)
-    Implicitly return the type of the JSON value as a value from the @ref
-    value_t enumeration.
-    exceptions.
-    @liveexample{The following code exemplifies the @ref value_t operator for
-    all JSON types.,operator__value_t}
-    @sa @ref type() -- return the type of the JSON value (explicit)
+    /// @brief return the type of the JSON value (implicit)
+    /// @sa https://json.nlohmann.me/api/basic_json/operator_value_t/
     constexpr operator value_t() const noexcept
-        return m_type;
@@ -19329,106 +20708,106 @@ class basic_json
         if (JSON_HEDLEY_LIKELY(is_boolean()))
-            return m_value.boolean;
+            return m_data.m_value.boolean;
-        JSON_THROW(type_error::create(302, "type must be boolean, but is " + std::string(type_name())));
+        JSON_THROW(type_error::create(302, detail::concat("type must be boolean, but is ", type_name()), this));
     /// get a pointer to the value (object)
     object_t* get_impl_ptr(object_t* /*unused*/) noexcept
-        return is_object() ? m_value.object : nullptr;
+        return is_object() ? m_data.m_value.object : nullptr;
     constexpr const object_t* get_impl_ptr(const object_t* /*unused*/) const noexcept
     /// get a pointer to the value (array)
     array_t* get_impl_ptr(array_t* /*unused*/) noexcept
-        return is_array() ? m_value.array : nullptr;
+        return is_array() ? m_data.m_value.array : nullptr;
     constexpr const array_t* get_impl_ptr(const array_t* /*unused*/) const noexcept
     /// get a pointer to the value (string)
     string_t* get_impl_ptr(string_t* /*unused*/) noexcept
-        return is_string() ? m_value.string : nullptr;
+        return is_string() ? m_data.m_value.string : nullptr;
     constexpr const string_t* get_impl_ptr(const string_t* /*unused*/) const noexcept
     /// get a pointer to the value (boolean)
     boolean_t* get_impl_ptr(boolean_t* /*unused*/) noexcept
-        return is_boolean() ? &m_value.boolean : nullptr;
+        return is_boolean() ? &m_data.m_value.boolean : nullptr;
     constexpr const boolean_t* get_impl_ptr(const boolean_t* /*unused*/) const noexcept
     /// get a pointer to the value (integer number)
     number_integer_t* get_impl_ptr(number_integer_t* /*unused*/) noexcept
-        return is_number_integer() ? &m_value.number_integer : nullptr;
+        return is_number_integer() ? &m_data.m_value.number_integer : nullptr;
     constexpr const number_integer_t* get_impl_ptr(const number_integer_t* /*unused*/) const noexcept
     /// get a pointer to the value (unsigned number)
     number_unsigned_t* get_impl_ptr(number_unsigned_t* /*unused*/) noexcept
-        return is_number_unsigned() ? &m_value.number_unsigned : nullptr;
+        return is_number_unsigned() ? &m_data.m_value.number_unsigned : nullptr;
     constexpr const number_unsigned_t* get_impl_ptr(const number_unsigned_t* /*unused*/) const noexcept
     /// get a pointer to the value (floating-point number)
     number_float_t* get_impl_ptr(number_float_t* /*unused*/) noexcept
-        return is_number_float() ? &m_value.number_float : nullptr;
+        return is_number_float() ? &m_data.m_value.number_float : nullptr;
     constexpr const number_float_t* get_impl_ptr(const number_float_t* /*unused*/) const noexcept
     /// get a pointer to the value (binary)
     binary_t* get_impl_ptr(binary_t* /*unused*/) noexcept
-        return is_binary() ? m_value.binary : nullptr;
+        return is_binary() ? m_data.m_value.binary : nullptr;
     constexpr const binary_t* get_impl_ptr(const binary_t* /*unused*/) const noexcept
@@ -19446,14 +20825,14 @@ class basic_json
     static ReferenceType get_ref_impl(ThisType& obj)
         // delegate the call to get_ptr<>()
-        auto ptr = obj.template get_ptr<typename std::add_pointer<ReferenceType>::type>();
+        auto* ptr = obj.template get_ptr<typename std::add_pointer<ReferenceType>::type>();
         if (JSON_HEDLEY_LIKELY(ptr != nullptr))
             return *ptr;
-        JSON_THROW(type_error::create(303, "incompatible ReferenceType for get_ref, actual type is " + std::string(obj.type_name())));
+        JSON_THROW(type_error::create(303, detail::concat("incompatible ReferenceType for get_ref, actual type is ", obj.type_name()), &obj));
   public:
@@ -19461,51 +20840,28 @@ class basic_json
     /// Direct access to the stored value of a JSON value.
-    @brief get special-case overload
-    This overloads avoids a lot of template boilerplate, it can be seen as the
-    identity method
-    @tparam BasicJsonType == @ref basic_json
-    @return a copy of *this
-    template<typename BasicJsonType, detail::enable_if_t<
-                 std::is_same<typename std::remove_const<BasicJsonType>::type, basic_json_t>::value,
-                 int> = 0>
-    basic_json get() const
+    /// @brief get a pointer value (implicit)
+    /// @sa https://json.nlohmann.me/api/basic_json/get_ptr/
+    template<typename PointerType, typename std::enable_if<
+                 std::is_pointer<PointerType>::value, int>::type = 0>
+    auto get_ptr() noexcept -> decltype(std::declval<basic_json_t&>().get_impl_ptr(std::declval<PointerType>()))
-        return *this;
+        // delegate the call to get_impl_ptr<>()
+        return get_impl_ptr(static_cast<PointerType>(nullptr));
-    This overloads converts the current @ref basic_json in a different
-    @ref basic_json type
-    @return a copy of *this, converted into @tparam BasicJsonType
-    @complexity Depending on the implementation of the called `from_json()`
-                method.
-    template < typename BasicJsonType, detail::enable_if_t <
-                   !std::is_same<BasicJsonType, basic_json>::value&&
-                   detail::is_basic_json<BasicJsonType>::value, int > = 0 >
-    BasicJsonType get() const
+    template < typename PointerType, typename std::enable_if <
+                   std::is_pointer<PointerType>::value&&
+                   std::is_const<typename std::remove_pointer<PointerType>::type>::value, int >::type = 0 >
+    constexpr auto get_ptr() const noexcept -> decltype(std::declval<const basic_json_t&>().get_impl_ptr(std::declval<PointerType>()))
-        return *this;
+        // delegate the call to get_impl_ptr<>() const
+  private:
     @brief get a value (explicit)
@@ -19529,7 +20885,6 @@ class basic_json
     - @ref json_serializer<ValueType> does not have a `from_json()` method of
       the form `ValueType from_json(const basic_json&)`
-    @tparam ValueTypeCV the provided value type
     @tparam ValueType the returned value type
     @return copy of the JSON value, converted to @a ValueType
@@ -19545,24 +20900,15 @@ class basic_json
-    template < typename ValueTypeCV, typename ValueType = detail::uncvref_t<ValueTypeCV>,
+    template < typename ValueType,
-                   !detail::is_basic_json<ValueType>::value &&
-                   detail::has_from_json<basic_json_t, ValueType>::value &&
-                   !detail::has_non_default_from_json<basic_json_t, ValueType>::value,
+                   detail::is_default_constructible<ValueType>::value&&
+                   detail::has_from_json<basic_json_t, ValueType>::value,
                    int > = 0 >
-    ValueType get() const noexcept(noexcept(
-                                       JSONSerializer<ValueType>::from_json(std::declval<const basic_json_t&>(), std::declval<ValueType&>())))
+    ValueType get_impl(detail::priority_tag<0> /*unused*/) const noexcept(noexcept(
+                JSONSerializer<ValueType>::from_json(std::declval<const basic_json_t&>(), std::declval<ValueType&>())))
-        // we cannot static_assert on ValueTypeCV being non-const, because
-        // there is support for get<const basic_json_t>(), which is why we
-        // still need the uncvref
-        static_assert(!std::is_reference<ValueTypeCV>::value,
-                      "get() cannot be used with reference types, you might want to use get_ref()");
-        static_assert(std::is_default_constructible<ValueType>::value,
-                      "types must be DefaultConstructible when used with get()");
-        ValueType ret;
+        auto ret = ValueType();
         JSONSerializer<ValueType>::from_json(*this, ret);
         return ret;
@@ -19578,7 +20924,7 @@ class basic_json
     The function is equivalent to executing
     @code {.cpp}
-    return JSONSerializer<ValueTypeCV>::from_json(*this);
+    return JSONSerializer<ValueType>::from_json(*this);
     @endcode
     This overloads is chosen if:
@@ -19589,7 +20935,6 @@ class basic_json
     @note If @ref json_serializer<ValueType> has both overloads of
     `from_json()`, this one is chosen.
@@ -19598,134 +20943,116 @@ class basic_json
-               detail::enable_if_t < !std::is_same<basic_json_t, ValueType>::value &&
-                                     detail::has_non_default_from_json<basic_json_t, ValueType>::value,
-                                     int > = 0 >
-                                       JSONSerializer<ValueType>::from_json(std::declval<const basic_json_t&>())))
+               detail::enable_if_t <
+                   detail::has_non_default_from_json<basic_json_t, ValueType>::value,
+                   int > = 0 >
+    ValueType get_impl(detail::priority_tag<1> /*unused*/) const noexcept(noexcept(
+                JSONSerializer<ValueType>::from_json(std::declval<const basic_json_t&>())))
-    @brief get a value (explicit)
+    @brief get special-case overload
-    Explicit type conversion between the JSON value and a compatible value.
-    The value is filled into the input parameter by calling the @ref json_serializer<ValueType>
-    `from_json()` method.
+    This overloads converts the current @ref basic_json in a different
+    @ref basic_json type
-    The function is equivalent to executing
-    @code {.cpp}
-    ValueType v;
-    JSONSerializer<ValueType>::from_json(*this, v);
-    @endcode
+    @tparam BasicJsonType == @ref basic_json
-    This overloads is chosen if:
-    - @a ValueType is not @ref basic_json,
-    - @ref json_serializer<ValueType> has a `from_json()` method of the form
-      `void from_json(const basic_json&, ValueType&)`, and
+    @return a copy of *this, converted into @a BasicJsonType
-    @tparam ValueType the input parameter type.
+    @complexity Depending on the implementation of the called `from_json()`
+                method.
-    @return the input parameter, allowing chaining calls.
-    @throw what @ref json_serializer<ValueType> `from_json()` method throws
-    @liveexample{The example below shows several conversions from JSON values
-    to other types. There a few things to note: (1) Floating-point numbers can
-    be converted to integers\, (2) A JSON array can be converted to a standard
-    `std::vector<short>`\, (3) A JSON object can be converted to C++
-    associative containers such as `std::unordered_map<std::string\,
-    json>`.,get_to}
-    @since version 3.3.0
+    @since version 3.2.0
-    template < typename ValueType,
+    template < typename BasicJsonType,
-                   !detail::is_basic_json<ValueType>::value&&
-                   detail::has_from_json<basic_json_t, ValueType>::value,
+                   detail::is_basic_json<BasicJsonType>::value,
                    int > = 0 >
-    ValueType & get_to(ValueType& v) const noexcept(noexcept(
-                JSONSerializer<ValueType>::from_json(std::declval<const basic_json_t&>(), v)))
+    BasicJsonType get_impl(detail::priority_tag<2> /*unused*/) const
-        return v;
+        return *this;
-    // specialization to allow to call get_to with a basic_json value
-    // see https://github.com/nlohmann/json/issues/2175
-    template<typename ValueType,
-                 detail::is_basic_json<ValueType>::value,
-                 int> = 0>
-        v = *this;
-        return v;
-    template <
-        typename T, std::size_t N,
-        typename Array = T (&)[N],
-            detail::has_from_json<basic_json_t, Array>::value, int > = 0 >
-    Array get_to(T (&v)[N]) const
-    noexcept(noexcept(JSONSerializer<Array>::from_json(
-                          std::declval<const basic_json_t&>(), v)))
-        JSONSerializer<Array>::from_json(*this, v);
-        return v;
-    @brief get a pointer value (implicit)
-    Implicit pointer access to the internally stored JSON value. No copies are
-    made.
+    This overloads avoids a lot of template boilerplate, it can be seen as the
+    identity method
-    @warning Writing data to the pointee of the result yields an undefined
-    state.
-    @tparam PointerType pointer type; must be a pointer to @ref array_t, @ref
-    object_t, @ref string_t, @ref boolean_t, @ref number_integer_t,
-    @ref number_unsigned_t, or @ref number_float_t. Enforced by a static
-    assertion.
-    @return pointer to the internally stored JSON value if the requested
-    pointer type @a PointerType fits to the JSON value; `nullptr` otherwise
-    @liveexample{The example below shows how pointers to internal values of a
-    JSON value can be requested. Note that no type conversions are made and a
-    `nullptr` is returned if the value and the requested pointer type does not
-    match.,get_ptr}
+    @since version 2.1.0
-    template<typename PointerType, typename std::enable_if<
-                 std::is_pointer<PointerType>::value, int>::type = 0>
-    auto get_ptr() noexcept -> decltype(std::declval<basic_json_t&>().get_impl_ptr(std::declval<PointerType>()))
+    template<typename BasicJsonType,
+             detail::enable_if_t<
+                 std::is_same<BasicJsonType, basic_json_t>::value,
+                 int> = 0>
+    basic_json get_impl(detail::priority_tag<3> /*unused*/) const
-        // delegate the call to get_impl_ptr<>()
-        return get_impl_ptr(static_cast<PointerType>(nullptr));
+        return *this;
-    @copydoc get_ptr()
+    @brief get a pointer value (explicit)
+    @copydoc get()
-    template < typename PointerType, typename std::enable_if <
-                   std::is_pointer<PointerType>::value&&
-                   std::is_const<typename std::remove_pointer<PointerType>::type>::value, int >::type = 0 >
-    constexpr auto get_ptr() const noexcept -> decltype(std::declval<const basic_json_t&>().get_impl_ptr(std::declval<PointerType>()))
+                 int> = 0>
+    constexpr auto get_impl(detail::priority_tag<4> /*unused*/) const noexcept
+    -> decltype(std::declval<const basic_json_t&>().template get_ptr<PointerType>())
-        // delegate the call to get_impl_ptr<>() const
+        // delegate the call to get_ptr
+        return get_ptr<PointerType>();
+  public:
+    @brief get a (pointer) value (explicit)
+    Performs explicit type conversion between the JSON value and a compatible value if required.
+    - If the requested type is a pointer to the internally stored JSON value that pointer is returned.
+    No copies are made.
+    - If the requested type is the current @ref basic_json, or a different @ref basic_json convertible
+    from the current @ref basic_json.
+    - Otherwise the value is converted by calling the @ref json_serializer<ValueType> `from_json()`
+    method.
+    @tparam ValueTypeCV the provided value type
+    @tparam ValueType the returned value type
+    @return copy of the JSON value, converted to @tparam ValueType if necessary
+    @throw what @ref json_serializer<ValueType> `from_json()` method throws if conversion is required
+    template < typename ValueTypeCV, typename ValueType = detail::uncvref_t<ValueTypeCV>>
+#if defined(JSON_HAS_CPP_14)
+    constexpr
+#endif
+    auto get() const noexcept(
+    noexcept(std::declval<const basic_json_t&>().template get_impl<ValueType>(detail::priority_tag<4> {})))
+    -> decltype(std::declval<const basic_json_t&>().template get_impl<ValueType>(detail::priority_tag<4> {}))
+        // we cannot static_assert on ValueTypeCV being non-const, because
+        // there is support for get<const basic_json_t>(), which is why we
+        // still need the uncvref
+        static_assert(!std::is_reference<ValueTypeCV>::value,
+                      "get() cannot be used with reference types, you might want to use get_ref()");
+        return get_impl<ValueType>(detail::priority_tag<4> {});
@@ -19751,7 +21078,7 @@ class basic_json
     match.,get__PointerType}
-    @sa @ref get_ptr() for explicit pointer-member access
+    @sa see @ref get_ptr() for explicit pointer-member access
@@ -19763,44 +21090,47 @@ class basic_json
-    @brief get a pointer value (explicit)
-    @copydoc get()
-    constexpr auto get() const noexcept -> decltype(std::declval<const basic_json_t&>().template get_ptr<PointerType>())
+    /// @brief get a value (explicit)
+    /// @sa https://json.nlohmann.me/api/basic_json/get_to/
+                   !detail::is_basic_json<ValueType>::value&&
+                   int > = 0 >
+    ValueType & get_to(ValueType& v) const noexcept(noexcept(
+                JSONSerializer<ValueType>::from_json(std::declval<const basic_json_t&>(), v)))
-        // delegate the call to get_ptr
-        return get_ptr<PointerType>();
+        JSONSerializer<ValueType>::from_json(*this, v);
+        return v;
-    @brief get a reference value (implicit)
+    // specialization to allow calling get_to with a basic_json value
+    // see https://github.com/nlohmann/json/issues/2175
+    template<typename ValueType,
+                 detail::is_basic_json<ValueType>::value,
+                 int> = 0>
+        v = *this;
+        return v;
-    Implicit reference access to the internally stored JSON value. No copies
-    are made.
+    template <
+        typename T, std::size_t N,
+        typename Array = T (&)[N], // NOLINT(cppcoreguidelines-avoid-c-arrays,hicpp-avoid-c-arrays,modernize-avoid-c-arrays)
+            detail::has_from_json<basic_json_t, Array>::value, int > = 0 >
+    Array get_to(T (&v)[N]) const // NOLINT(cppcoreguidelines-avoid-c-arrays,hicpp-avoid-c-arrays,modernize-avoid-c-arrays)
+    noexcept(noexcept(JSONSerializer<Array>::from_json(
+                          std::declval<const basic_json_t&>(), v)))
+        JSONSerializer<Array>::from_json(*this, v);
+        return v;
-    @warning Writing data to the referee of the result yields an undefined
-    state.
-    @tparam ReferenceType reference type; must be a reference to @ref array_t,
-    @ref object_t, @ref string_t, @ref boolean_t, @ref number_integer_t, or
-    @ref number_float_t. Enforced by static assertion.
-    @return reference to the internally stored JSON value if the requested
-    reference type @a ReferenceType fits to the JSON value; throws
-    type_error.303 otherwise
-    @throw type_error.303 in case passed type @a ReferenceType is incompatible
-    with the stored JSON value; see example below
-    @liveexample{The example shows several calls to `get_ref()`.,get_ref}
-    @since version 1.1.0
+    /// @brief get a reference value (implicit)
+    /// @sa https://json.nlohmann.me/api/basic_json/get_ref/
     template<typename ReferenceType, typename std::enable_if<
                  std::is_reference<ReferenceType>::value, int>::type = 0>
     ReferenceType get_ref()
@@ -19809,10 +21139,8 @@ class basic_json
         return get_ref_impl<ReferenceType>(*this);
-    @copydoc get_ref()
     template < typename ReferenceType, typename std::enable_if <
                    std::is_reference<ReferenceType>::value&&
                    std::is_const<typename std::remove_reference<ReferenceType>::type>::value, int >::type = 0 >
@@ -19852,47 +21180,46 @@ class basic_json
     template < typename ValueType, typename std::enable_if <
-                   !std::is_pointer<ValueType>::value&&
-                   !std::is_same<ValueType, detail::json_ref<basic_json>>::value&&
-                   !std::is_same<ValueType, typename string_t::value_type>::value&&
-                   && !std::is_same<ValueType, std::initializer_list<typename string_t::value_type>>::value
+                   detail::conjunction <
+                       detail::negation<std::is_pointer<ValueType>>,
+                       detail::negation<std::is_same<ValueType, std::nullptr_t>>,
+                       detail::negation<std::is_same<ValueType, detail::json_ref<basic_json>>>,
+                                        detail::negation<std::is_same<ValueType, typename string_t::value_type>>,
+                                        detail::negation<detail::is_basic_json<ValueType>>,
+                                        detail::negation<std::is_same<ValueType, std::initializer_list<typename string_t::value_type>>>,
 #if defined(JSON_HAS_CPP_17) && (defined(__GNUC__) || (defined(_MSC_VER) && _MSC_VER >= 1910 && _MSC_VER <= 1914))
-                   && !std::is_same<ValueType, typename std::string_view>::value
+                                                detail::negation<std::is_same<ValueType, std::string_view>>,
 #endif
-                   && detail::is_detected<detail::get_template_function, const basic_json_t&, ValueType>::value
-                   , int >::type = 0 >
-    JSON_EXPLICIT operator ValueType() const
+#if defined(JSON_HAS_CPP_17) && JSON_HAS_STATIC_RTTI
+                                                detail::negation<std::is_same<ValueType, std::any>>,
+#endif
+                                                detail::is_detected_lazy<detail::get_template_function, const basic_json_t&, ValueType>
+                                                >::value, int >::type = 0 >
+                                        JSON_EXPLICIT operator ValueType() const
         // delegate the call to get<>() const
         return get<ValueType>();
-    @return reference to the binary value
-    @throw type_error.302 if the value is not binary
-    @sa @ref is_binary() to check if the value is binary
-    @since version 3.8.0
+    /// @brief get a binary value
+    /// @sa https://json.nlohmann.me/api/basic_json/get_binary/
     binary_t& get_binary()
         if (!is_binary())
-            JSON_THROW(type_error::create(302, "type must be binary, but is " + std::string(type_name())));
+            JSON_THROW(type_error::create(302, detail::concat("type must be binary, but is ", type_name()), this));
         return *get_ptr<binary_t*>();
-    /// @copydoc get_binary()
     const binary_t& get_binary() const
         if (!is_binary())
         return *get_ptr<const binary_t*>();
@@ -19900,7 +21227,6 @@ class basic_json
     // element access //
@@ -19909,32 +21235,8 @@ class basic_json
     /// Access to the JSON value.
-    @brief access specified array element with bounds checking
-    Returns a reference to the element at specified location @a idx, with
-    bounds checking.
-    @param[in] idx  index of the element to access
-    @return reference to the element at index @a idx
-    @throw type_error.304 if the JSON value is not an array; in this case,
-    calling `at` with an index makes no sense. See example below.
-    @throw out_of_range.401 if the index @a idx is out of range of the array;
-    that is, `idx >= size()`. See example below.
-    @liveexample{The example below shows how array elements can be read and
-    written using `at()`. It also demonstrates the different exceptions that
-    can be thrown.,at__size_type}
+    /// @brief access specified array element with bounds checking
+    /// @sa https://json.nlohmann.me/api/basic_json/at/
     reference at(size_type idx)
         // at only works for arrays
@@ -19942,46 +21244,22 @@ class basic_json
             JSON_TRY
-                return m_value.array->at(idx);
+                return set_parent(m_data.m_value.array->at(idx));
             JSON_CATCH (std::out_of_range&)
                 // create better exception explanation
-                JSON_THROW(out_of_range::create(401, "array index " + std::to_string(idx) + " is out of range"));
+                JSON_THROW(out_of_range::create(401, detail::concat("array index ", std::to_string(idx), " is out of range"), this));
         else
-            JSON_THROW(type_error::create(304, "cannot use at() with " + std::string(type_name())));
+            JSON_THROW(type_error::create(304, detail::concat("cannot use at() with ", type_name()), this));
-    Returns a const reference to the element at specified location @a idx,
-    with bounds checking.
-    @return const reference to the element at index @a idx
-    @liveexample{The example below shows how array elements can be read using
-    `at()`. It also demonstrates the different exceptions that can be thrown.,
-    at__size_type_const}
     const_reference at(size_type idx) const
@@ -19989,154 +21267,105 @@ class basic_json
             JSON_TRY
+                return m_data.m_value.array->at(idx);
         else
-    @brief access specified object element with bounds checking
-    Returns a reference to the element at with specified key @a key, with
-    bounds checking.
-    @param[in] key  key of the element to access
-    @return reference to the element at key @a key
-    @throw type_error.304 if the JSON value is not an object; in this case,
-    calling `at` with a key makes no sense. See example below.
-    @throw out_of_range.403 if the key @a key is is not stored in the object;
-    that is, `find(key) == end()`. See example below.
-    @complexity Logarithmic in the size of the container.
-    @sa @ref operator[](const typename object_t::key_type&) for unchecked
-    access by reference
-    @sa @ref value() for access by value with a default value
-    @liveexample{The example below shows how object elements can be read and
-    can be thrown.,at__object_t_key_type}
+    /// @brief access specified object element with bounds checking
     reference at(const typename object_t::key_type& key)
         // at only works for objects
-        if (JSON_HEDLEY_LIKELY(is_object()))
+        if (JSON_HEDLEY_UNLIKELY(!is_object()))
-            JSON_TRY
-                return m_value.object->at(key);
-            JSON_CATCH (std::out_of_range&)
-                // create better exception explanation
-                JSON_THROW(out_of_range::create(403, "key '" + key + "' not found"));
-        else
+        auto it = m_data.m_value.object->find(key);
+        if (it == m_data.m_value.object->end())
+            JSON_THROW(out_of_range::create(403, detail::concat("key '", key, "' not found"), this));
+        return set_parent(it->second);
+    template<class KeyType, detail::enable_if_t<
+                 detail::is_usable_as_basic_json_key_type<basic_json_t, KeyType>::value, int> = 0>
+    reference at(KeyType && key)
+        // at only works for objects
-    Returns a const reference to the element at with specified key @a key,
+        auto it = m_data.m_value.object->find(std::forward<KeyType>(key));
+            JSON_THROW(out_of_range::create(403, detail::concat("key '", string_t(std::forward<KeyType>(key)), "' not found"), this));
-    @return const reference to the element at key @a key
-    @liveexample{The example below shows how object elements can be read using
-    at__object_t_key_type_const}
     const_reference at(const typename object_t::key_type& key) const
-            JSON_TRY
-        else
+        return it->second;
+    const_reference at(KeyType && key) const
-    Returns a reference to the element at specified location @a idx.
-    @note If @a idx is beyond the range of the array (i.e., `idx >= size()`),
-    then the array is silently filled up with `null` values to make `idx` a
-    valid reference to the last stored element.
-    @throw type_error.305 if the JSON value is not an array or null; in that
-    cases, using the [] operator with an index makes no sense.
-    @complexity Constant if @a idx is in the range of the array. Otherwise
-    linear in `idx - size()`.
-    written using `[]` operator. Note the addition of `null`
-    values.,operatorarray__size_type}
+    /// @sa https://json.nlohmann.me/api/basic_json/operator%5B%5D/
     reference operator[](size_type idx)
         // implicitly convert null value to an empty array
         if (is_null())
-            m_value.array = create<array_t>();
+            m_data.m_value.array = create<array_t>();
             assert_invariant();
@@ -20144,286 +21373,161 @@ class basic_json
         if (JSON_HEDLEY_LIKELY(is_array()))
             // fill up array with null values if given idx is outside range
-            if (idx >= m_value.array->size())
+            if (idx >= m_data.m_value.array->size())
-                m_value.array->insert(m_value.array->end(),
-                                      idx - m_value.array->size() + 1,
-                                      basic_json());
+#if JSON_DIAGNOSTICS
+                // remember array size & capacity before resizing
+                const auto old_size = m_data.m_value.array->size();
+                const auto old_capacity = m_data.m_value.array->capacity();
+#endif
+                m_data.m_value.array->resize(idx + 1);
+                if (JSON_HEDLEY_UNLIKELY(m_data.m_value.array->capacity() != old_capacity))
+                    // capacity has changed: update all parents
+                    set_parents();
+                else
+                    // set parent for values added above
+                    set_parents(begin() + static_cast<typename iterator::difference_type>(old_size), static_cast<typename iterator::difference_type>(idx + 1 - old_size));
+#endif
+                assert_invariant();
-            return m_value.array->operator[](idx);
+            return m_data.m_value.array->operator[](idx);
-        JSON_THROW(type_error::create(305, "cannot use operator[] with a numeric argument with " + std::string(type_name())));
+        JSON_THROW(type_error::create(305, detail::concat("cannot use operator[] with a numeric argument with ", type_name()), this));
-    Returns a const reference to the element at specified location @a idx.
-    @throw type_error.305 if the JSON value is not an array; in that case,
-    using the [] operator with an index makes no sense.
-    the `[]` operator.,operatorarray__size_type_const}
     const_reference operator[](size_type idx) const
         // const operator[] only works for arrays
-    Returns a reference to the element at with specified key @a key.
-    @note If @a key is not found in the object, then it is silently added to
-    the object and filled with a `null` value to make `key` a valid reference.
-    In case the value was `null` before, it is converted to an object.
-    @throw type_error.305 if the JSON value is not an object or null; in that
-    cases, using the [] operator with a key makes no sense.
-    written using the `[]` operator.,operatorarray__key_type}
-    @sa @ref at(const typename object_t::key_type&) for access by reference
-    with range checking
-    reference operator[](const typename object_t::key_type& key)
+    reference operator[](typename object_t::key_type key)
         // implicitly convert null value to an empty object
         if (is_null())
-            m_value.object = create<object_t>();
+            m_data.m_value.object = create<object_t>();
             assert_invariant();
         // operator[] only works for objects
-            return m_value.object->operator[](key);
+            auto result = m_data.m_value.object->emplace(std::move(key), nullptr);
+            return set_parent(result.first->second);
-        JSON_THROW(type_error::create(305, "cannot use operator[] with a string argument with " + std::string(type_name())));
+        JSON_THROW(type_error::create(305, detail::concat("cannot use operator[] with a string argument with ", type_name()), this));
-    @brief read-only access specified object element
-    Returns a const reference to the element at with specified key @a key. No
-    bounds checking is performed.
-    @warning If the element with key @a key does not exist, the behavior is
-    undefined.
-    @pre The element with key @a key must exist. **This precondition is
-         enforced with an assertion.**
-    @throw type_error.305 if the JSON value is not an object; in that case,
-    using the [] operator with a key makes no sense.
-    the `[]` operator.,operatorarray__key_type_const}
     const_reference operator[](const typename object_t::key_type& key) const
         // const operator[] only works for objects
-            JSON_ASSERT(m_value.object->find(key) != m_value.object->end());
-            return m_value.object->find(key)->second;
+            JSON_ASSERT(it != m_data.m_value.object->end());
+    // these two functions resolve a (const) char * ambiguity affecting Clang and MSVC
+    // (they seemingly cannot be constrained to resolve the ambiguity)
     template<typename T>
-    JSON_HEDLEY_NON_NULL(2)
     reference operator[](T* key)
-        // implicitly convert null to object
+        return operator[](typename object_t::key_type(key));
+    template<typename T>
+    const_reference operator[](T* key) const
+                 detail::is_usable_as_basic_json_key_type<basic_json_t, KeyType>::value, int > = 0 >
+    reference operator[](KeyType && key)
+        // implicitly convert null value to an empty object
         if (is_null())
             assert_invariant();
-        // at only works for objects
+        // operator[] only works for objects
+            auto result = m_data.m_value.object->emplace(std::forward<KeyType>(key), nullptr);
-    undefined.
-    template<typename T>
-    const_reference operator[](T* key) const
+    const_reference operator[](KeyType && key) const
+        // const operator[] only works for objects
-    @brief access specified object element with default value
+  private:
+    template<typename KeyType>
+    using is_comparable_with_object_key = detail::is_comparable <
+        object_comparator_t, const typename object_t::key_type&, KeyType >;
-    Returns either a copy of an object's element at the specified key @a key
-    or a given default value if no element with key @a key exists.
+    template<typename ValueType>
+    using value_return_type = std::conditional <
+        detail::is_c_string_uncvref<ValueType>::value,
+        string_t, typename std::decay<ValueType>::type >;
-    The function is basically equivalent to executing
-    @code {.cpp}
-    try {
-        return at(key);
-    } catch(out_of_range) {
-        return default_value;
-    @endcode
-    @note Unlike @ref at(const typename object_t::key_type&), this function
-    does not throw if the given key @a key was not found.
-    @note Unlike @ref operator[](const typename object_t::key_type& key), this
-    function does not implicitly add an element to the position defined by @a
-    key. This function is furthermore also applicable to const objects.
-    @param[in] default_value  the value to return if @a key is not found
-    @tparam ValueType type compatible to JSON values, for instance `int` for
-    JSON integer numbers, `bool` for JSON booleans, or `std::vector` types for
-    JSON arrays. Note the type of the expected value at @a key and the default
-    value @a default_value must be compatible.
-    @return copy of the element at key @a key or @a default_value if @a key
-    is not found
-    @throw type_error.302 if @a default_value does not match the type of the
-    value at @a key
-    @throw type_error.306 if the JSON value is not an object; in that case,
-    using `value()` with a key makes no sense.
-    @liveexample{The example below shows how object elements can be queried
-    with a default value.,basic_json__value}
-    // using std::is_convertible in a std::enable_if will fail when using explicit conversions
-    template < class ValueType, typename std::enable_if <
-                   detail::is_getable<basic_json_t, ValueType>::value
-                   && !std::is_same<value_t, ValueType>::value, int >::type = 0 >
+  public:
+    /// @brief access specified object element with default value
+    /// @sa https://json.nlohmann.me/api/basic_json/value/
+    template < class ValueType, detail::enable_if_t <
+                   !detail::is_transparent<object_comparator_t>::value
+                   && detail::is_getable<basic_json_t, ValueType>::value
+                   && !std::is_same<value_t, detail::uncvref_t<ValueType>>::value, int > = 0 >
     ValueType value(const typename object_t::key_type& key, const ValueType& default_value) const
+        // value only works for objects
             // if key is found, return value and given default value otherwise
@@ -20436,66 +21540,95 @@ class basic_json
-        JSON_THROW(type_error::create(306, "cannot use value() with " + std::string(type_name())));
+        JSON_THROW(type_error::create(306, detail::concat("cannot use value() with ", type_name()), this));
-    @brief overload for a default value of type const char*
-    @copydoc basic_json::value(const typename object_t::key_type&, const ValueType&) const
-    string_t value(const typename object_t::key_type& key, const char* default_value) const
+    template < class ValueType, class ReturnType = typename value_return_type<ValueType>::type,
+                   && detail::is_getable<basic_json_t, ReturnType>::value
+    ReturnType value(const typename object_t::key_type& key, ValueType && default_value) const
-        return value(key, string_t(default_value));
+        if (JSON_HEDLEY_LIKELY(is_object()))
+            // if key is found, return value and given default value otherwise
+            const auto it = find(key);
+            if (it != end())
+                return it->template get<ReturnType>();
+            return std::forward<ValueType>(default_value);
-    @brief access specified object element via JSON Pointer with default value
+    template < class ValueType, class KeyType, detail::enable_if_t <
+                   detail::is_transparent<object_comparator_t>::value
+                   && !detail::is_json_pointer<KeyType>::value
+                   && is_comparable_with_object_key<KeyType>::value
+    ValueType value(KeyType && key, const ValueType& default_value) const
+            const auto it = find(std::forward<KeyType>(key));
+            if (it != end())
+                return it->template get<ValueType>();
+            return default_value;
-    @code {.cpp}
-    try {
-        return at(ptr);
-    @endcode
-    @note Unlike @ref at(const json_pointer&), this function does not throw
-    if the given key @a key was not found.
+    /// @brief access specified object element via JSON Pointer with default value
+    template < class ValueType, class KeyType, class ReturnType = typename value_return_type<ValueType>::type,
+    ReturnType value(KeyType && key, ValueType && default_value) const
+            if (it != end())
-    @param[in] ptr  a JSON pointer to the element to access
-    @param[in] default_value  the value to return if @a ptr found no value
-    is not found
-    value at @a ptr
-    with a default value.,basic_json__value_ptr}
-    @sa @ref operator[](const json_pointer&) for unchecked access by reference
-    @since version 2.0.2
-    template<class ValueType, typename std::enable_if<
-                 detail::is_getable<basic_json_t, ValueType>::value, int>::type = 0>
+                   detail::is_getable<basic_json_t, ValueType>::value
     ValueType value(const json_pointer& ptr, const ValueType& default_value) const
             // if pointer resolves a value, return it or use default value
@@ -20509,88 +21642,71 @@ class basic_json
-    @copydoc basic_json::value(const json_pointer&, ValueType) const
-    JSON_HEDLEY_NON_NULL(3)
-    string_t value(const json_pointer& ptr, const char* default_value) const
+                   detail::is_getable<basic_json_t, ReturnType>::value
+    ReturnType value(const json_pointer& ptr, ValueType && default_value) const
-        return value(ptr, string_t(default_value));
+            // if pointer resolves a value, return it or use default value
+            JSON_TRY
+                return ptr.get_checked(this).template get<ReturnType>();
+            JSON_INTERNAL_CATCH (out_of_range&)
-    @brief access the first element
+    template < class ValueType, class BasicJsonType, detail::enable_if_t <
+    JSON_HEDLEY_DEPRECATED_FOR(3.11.0, basic_json::json_pointer or nlohmann::json_pointer<basic_json::string_t>) // NOLINT(readability/alt_tokens)
+    ValueType value(const ::nlohmann::json_pointer<BasicJsonType>& ptr, const ValueType& default_value) const
+        return value(ptr.convert(), default_value);
-    Returns a reference to the first element in the container. For a JSON
-    container `c`, the expression `c.front()` is equivalent to `*c.begin()`.
+    template < class ValueType, class BasicJsonType, class ReturnType = typename value_return_type<ValueType>::type,
+    ReturnType value(const ::nlohmann::json_pointer<BasicJsonType>& ptr, ValueType && default_value) const
+        return value(ptr.convert(), std::forward<ValueType>(default_value));
-    @return In case of a structured type (array or object), a reference to the
-    first element is returned. In case of number, string, boolean, or binary
-    values, a reference to the value is returned.
-    @pre The JSON value must not be `null` (would throw `std::out_of_range`)
-    or an empty array or object (undefined behavior, **guarded by
-    assertions**).
-    @post The JSON value remains unchanged.
-    @throw invalid_iterator.214 when called on `null` value
-    @liveexample{The following code shows an example for `front()`.,front}
-    @sa @ref back() -- access the last element
+    /// @brief access the first element
+    /// @sa https://json.nlohmann.me/api/basic_json/front/
     reference front()
         return *begin();
-    @copydoc basic_json::front()
     const_reference front() const
         return *cbegin();
-    @brief access the last element
-    Returns a reference to the last element in the container. For a JSON
-    container `c`, the expression `c.back()` is equivalent to
-    @code {.cpp}
-    auto tmp = c.end();
-    --tmp;
-    return *tmp;
-    @endcode
-    last element is returned. In case of number, string, boolean, or binary
-    assertions**).
-    @throw invalid_iterator.214 when called on a `null` value. See example
-    below.
-    @liveexample{The following code shows an example for `back()`.,back}
-    @sa @ref front() -- access the first element
+    /// @brief access the last element
+    /// @sa https://json.nlohmann.me/api/basic_json/back/
     reference back()
         auto tmp = end();
@@ -20598,9 +21714,8 @@ class basic_json
         return *tmp;
-    @copydoc basic_json::back()
     const_reference back() const
         auto tmp = cend();
@@ -20608,67 +21723,22 @@ class basic_json
         return *tmp;
-    @brief remove element given an iterator
-    Removes the element specified by iterator @a pos. The iterator @a pos must
-    be valid and dereferenceable. Thus the `end()` iterator (which is valid,
-    but is not dereferenceable) cannot be used as a value for @a pos.
-    If called on a primitive type other than `null`, the resulting JSON value
-    will be `null`.
-    @param[in] pos iterator to the element to remove
-    @return Iterator following the last removed element. If the iterator @a
-    pos refers to the last element, the `end()` iterator is returned.
-    @tparam IteratorType an @ref iterator or @ref const_iterator
-    @post Invalidates iterators and references at or after the point of the
-    erase, including the `end()` iterator.
-    @throw type_error.307 if called on a `null` value; example: `"cannot use
-    erase() with null"`
-    @throw invalid_iterator.202 if called on an iterator which does not belong
-    to the current JSON value; example: `"iterator does not fit current
-    value"`
-    @throw invalid_iterator.205 if called on a primitive type with invalid
-    iterator (i.e., any iterator which is not `begin()`); example: `"iterator
-    out of range"`
-    @complexity The complexity depends on the type:
-    - objects: amortized constant
-    - arrays: linear in distance between @a pos and the end of the container
-    - strings and binary: linear in the length of the member
-    - other types: constant
-    @liveexample{The example shows the result of `erase()` for different JSON
-    types.,erase__IteratorType}
-    @sa @ref erase(IteratorType, IteratorType) -- removes the elements in
-    the given range
-    @sa @ref erase(const typename object_t::key_type&) -- removes the element
-    from an object at the given key
-    @sa @ref erase(const size_type) -- removes the element from an array at
-    the given index
-    template < class IteratorType, typename std::enable_if <
+    /// @brief remove element given an iterator
+    /// @sa https://json.nlohmann.me/api/basic_json/erase/
+    template < class IteratorType, detail::enable_if_t <
                    std::is_same<IteratorType, typename basic_json_t::iterator>::value ||
-                   std::is_same<IteratorType, typename basic_json_t::const_iterator>::value, int >::type
-               = 0 >
+                   std::is_same<IteratorType, typename basic_json_t::const_iterator>::value, int > = 0 >
     IteratorType erase(IteratorType pos)
         if (JSON_HEDLEY_UNLIKELY(this != pos.m_object))
-            JSON_THROW(invalid_iterator::create(202, "iterator does not fit current value"));
+            JSON_THROW(invalid_iterator::create(202, "iterator does not fit current value", this));
         IteratorType result = end();
-        switch (m_type)
+        switch (m_data.m_type)
             case value_t::boolean:
             case value_t::number_float:
@@ -20679,109 +21749,66 @@ class basic_json
                 if (JSON_HEDLEY_UNLIKELY(!pos.m_it.primitive_iterator.is_begin()))
-                    JSON_THROW(invalid_iterator::create(205, "iterator out of range"));
+                    JSON_THROW(invalid_iterator::create(205, "iterator out of range", this));
                 if (is_string())
                     AllocatorType<string_t> alloc;
-                    std::allocator_traits<decltype(alloc)>::destroy(alloc, m_value.string);
-                    std::allocator_traits<decltype(alloc)>::deallocate(alloc, m_value.string, 1);
-                    m_value.string = nullptr;
+                    std::allocator_traits<decltype(alloc)>::destroy(alloc, m_data.m_value.string);
+                    std::allocator_traits<decltype(alloc)>::deallocate(alloc, m_data.m_value.string, 1);
+                    m_data.m_value.string = nullptr;
                 else if (is_binary())
                     AllocatorType<binary_t> alloc;
-                    std::allocator_traits<decltype(alloc)>::destroy(alloc, m_value.binary);
-                    std::allocator_traits<decltype(alloc)>::deallocate(alloc, m_value.binary, 1);
-                    m_value.binary = nullptr;
+                    std::allocator_traits<decltype(alloc)>::destroy(alloc, m_data.m_value.binary);
+                    std::allocator_traits<decltype(alloc)>::deallocate(alloc, m_data.m_value.binary, 1);
+                    m_data.m_value.binary = nullptr;
-                m_type = value_t::null;
+                m_data.m_type = value_t::null;
                 assert_invariant();
                 break;
             case value_t::object:
-                result.m_it.object_iterator = m_value.object->erase(pos.m_it.object_iterator);
+                result.m_it.object_iterator = m_data.m_value.object->erase(pos.m_it.object_iterator);
                 break;
             case value_t::array:
-                result.m_it.array_iterator = m_value.array->erase(pos.m_it.array_iterator);
+                result.m_it.array_iterator = m_data.m_value.array->erase(pos.m_it.array_iterator);
                 break;
+            case value_t::null:
+            case value_t::discarded:
             default:
-                JSON_THROW(type_error::create(307, "cannot use erase() with " + std::string(type_name())));
+                JSON_THROW(type_error::create(307, detail::concat("cannot use erase() with ", type_name()), this));
         return result;
-    @brief remove elements given an iterator range
-    Removes the element specified by the range `[first; last)`. The iterator
-    @a first does not need to be dereferenceable if `first == last`: erasing
-    an empty range is a no-op.
-    will be `null`.
-    @param[in] first iterator to the beginning of the range to remove
-    @param[in] last iterator past the end of the range to remove
-    second refers to the last element, the `end()` iterator is returned.
-    @throw invalid_iterator.203 if called on iterators which does not belong
-    to the current JSON value; example: `"iterators do not fit current value"`
-    @throw invalid_iterator.204 if called on a primitive type with invalid
-    iterators (i.e., if `first != begin()` and `last != end()`); example:
-    `"iterators out of range"`
-    - objects: `log(size()) + std::distance(first, last)`
-    - arrays: linear in the distance between @a first and @a last, plus linear
-      in the distance between @a last and end of the container
-    types.,erase__IteratorType_IteratorType}
-    @sa @ref erase(IteratorType) -- removes the element at a given position
-    the given index
+    /// @brief remove elements given an iterator range
-               = 0 >
     IteratorType erase(IteratorType first, IteratorType last)
         // make sure iterator fits the current value
         if (JSON_HEDLEY_UNLIKELY(this != first.m_object || this != last.m_object))
-            JSON_THROW(invalid_iterator::create(203, "iterators do not fit current value"));
+            JSON_THROW(invalid_iterator::create(203, "iterators do not fit current value", this));
-        switch (m_type)
@@ -20793,114 +21820,107 @@ class basic_json
                 if (JSON_HEDLEY_LIKELY(!first.m_it.primitive_iterator.is_begin()
                                        || !last.m_it.primitive_iterator.is_end()))
-                    JSON_THROW(invalid_iterator::create(204, "iterators out of range"));
+                    JSON_THROW(invalid_iterator::create(204, "iterators out of range", this));
                 if (is_string())
                 assert_invariant();
                 break;
-                result.m_it.object_iterator = m_value.object->erase(first.m_it.object_iterator,
+                result.m_it.object_iterator = m_data.m_value.object->erase(first.m_it.object_iterator,
                                               last.m_it.object_iterator);
                 break;
-                result.m_it.array_iterator = m_value.array->erase(first.m_it.array_iterator,
+                result.m_it.array_iterator = m_data.m_value.array->erase(first.m_it.array_iterator,
                                              last.m_it.array_iterator);
                 break;
             default:
         return result;
-    @brief remove element from a JSON object given a key
-    Removes elements from a JSON object with the key value @a key.
-    @param[in] key value of the elements to remove
-    @return Number of elements removed. If @a ObjectType is the default
-    `std::map` type, the return value will always be `0` (@a key was not
-    found) or `1` (@a key was found).
-    @post References and iterators to the erased elements are invalidated.
-    Other references and iterators are not affected.
-    @throw type_error.307 when called on a type other than JSON object;
-    example: `"cannot use erase() with null"`
-    @complexity `log(size()) + count(key)`
-    @liveexample{The example shows the effect of `erase()`.,erase__key_type}
-    the given range
-    the given index
-    size_type erase(const typename object_t::key_type& key)
+  private:
+    template < typename KeyType, detail::enable_if_t <
+                   detail::has_erase_with_key_type<basic_json_t, KeyType>::value, int > = 0 >
+    size_type erase_internal(KeyType && key)
         // this erase only works for objects
-            return m_value.object->erase(key);
+        return m_data.m_value.object->erase(std::forward<KeyType>(key));
-    @brief remove element from a JSON array given an index
+                   !detail::has_erase_with_key_type<basic_json_t, KeyType>::value, int > = 0 >
+        // this erase only works for objects
-    Removes element from a JSON array at the index @a idx.
+        const auto it = m_data.m_value.object->find(std::forward<KeyType>(key));
+        if (it != m_data.m_value.object->end())
+            m_data.m_value.object->erase(it);
+            return 1;
+        return 0;
-    @param[in] idx index of the element to remove
+  public:
-    @throw out_of_range.401 when `idx >= size()`; example: `"array index 17
-    is out of range"`
+    /// @brief remove element from a JSON object given a key
+    size_type erase(const typename object_t::key_type& key)
+        // the indirection via erase_internal() is added to avoid making this
+        // function a template and thus de-rank it during overload resolution
+        return erase_internal(key);
-    @complexity Linear in distance between @a idx and the end of the container.
+    size_type erase(KeyType && key)
+        return erase_internal(std::forward<KeyType>(key));
-    @liveexample{The example shows the effect of `erase()`.,erase__size_type}
-    the given range
+    /// @brief remove element from a JSON array given an index
     void erase(const size_type idx)
         // this erase only works for arrays
@@ -20908,20 +21928,19 @@ class basic_json
             if (JSON_HEDLEY_UNLIKELY(idx >= size()))
-            m_value.array->erase(m_value.array->begin() + static_cast<difference_type>(idx));
+            m_data.m_value.array->erase(m_data.m_value.array->begin() + static_cast<difference_type>(idx));
         else
     // lookup //
@@ -20929,153 +21948,115 @@ class basic_json
     /// @name lookup
-    @brief find an element in a JSON object
-    Finds an element in a JSON object with key equivalent to @a key. If the
-    element is not found or the JSON value is not an object, end() is
-    returned.
-    @note This method always returns @ref end() when executed on a JSON type
-          that is not an object.
-    @param[in] key key value of the element to search for.
-    @return Iterator to an element with key equivalent to @a key. If no such
-    element is found or the JSON value is not an object, past-the-end (see
-    @ref end()) iterator is returned.
-    @complexity Logarithmic in the size of the JSON object.
-    @liveexample{The example shows how `find()` is used.,find__key_type}
-    @sa @ref contains(KeyT&&) const -- checks whether a key exists
-    template<typename KeyT>
-    iterator find(KeyT&& key)
+    /// @brief find an element in a JSON object
+    /// @sa https://json.nlohmann.me/api/basic_json/find/
+    iterator find(const typename object_t::key_type& key)
         auto result = end();
         if (is_object())
-            result.m_it.object_iterator = m_value.object->find(std::forward<KeyT>(key));
+            result.m_it.object_iterator = m_data.m_value.object->find(key);
         return result;
-    @copydoc find(KeyT&&)
-    const_iterator find(KeyT&& key) const
+    const_iterator find(const typename object_t::key_type& key) const
         auto result = cend();
         if (is_object())
         return result;
-    @brief returns the number of occurrences of a key in a JSON object
+    iterator find(KeyType && key)
+        auto result = end();
-    Returns the number of elements with key @a key. If ObjectType is the
-    default `std::map` type, the return value will always be `0` (@a key was
-    not found) or `1` (@a key was found).
+        if (is_object())
+            result.m_it.object_iterator = m_data.m_value.object->find(std::forward<KeyType>(key));
-    @note This method always returns `0` when executed on a JSON type that is
-          not an object.
+        return result;
-    @param[in] key key value of the element to count
+    const_iterator find(KeyType && key) const
+        auto result = cend();
-    @return Number of elements with key @a key. If the JSON value is not an
-    object, the return value will be `0`.
+        if (is_object())
+        return result;
-    @liveexample{The example shows how `count()` is used.,count}
-    size_type count(KeyT&& key) const
+    /// @brief returns the number of occurrences of a key in a JSON object
+    /// @sa https://json.nlohmann.me/api/basic_json/count/
+    size_type count(const typename object_t::key_type& key) const
         // return 0 for all nonobject types
-        return is_object() ? m_value.object->count(std::forward<KeyT>(key)) : 0;
+        return is_object() ? m_data.m_value.object->count(key) : 0;
-    @brief check the existence of an element in a JSON object
-    Check whether an element exists in a JSON object with key equivalent to
-    @a key. If the element is not found or the JSON value is not an object,
-    false is returned.
-    @note This method always returns false when executed on a JSON type
-    @param[in] key key value to check its existence.
-    @return true if an element with specified @a key exists. If no such
-    element with such key is found or the JSON value is not an object,
-    @liveexample{The following code shows an example for `contains()`.,contains}
-    @sa @ref find(KeyT&&) -- returns an iterator to an object element
-    @sa @ref contains(const json_pointer&) const -- checks the existence for a JSON pointer
-    @since version 3.6.0
-    template < typename KeyT, typename std::enable_if <
-                   !std::is_same<typename std::decay<KeyT>::type, json_pointer>::value, int >::type = 0 >
-    bool contains(KeyT && key) const
+    size_type count(KeyType && key) const
-        return is_object() && m_value.object->find(std::forward<KeyT>(key)) != m_value.object->end();
+        // return 0 for all nonobject types
+        return is_object() ? m_data.m_value.object->count(std::forward<KeyType>(key)) : 0;
-    @brief check the existence of an element in a JSON object given a JSON pointer
+    /// @brief check the existence of an element in a JSON object
+    /// @sa https://json.nlohmann.me/api/basic_json/contains/
+    bool contains(const typename object_t::key_type& key) const
+        return is_object() && m_data.m_value.object->find(key) != m_data.m_value.object->end();
-    Check whether the given JSON pointer @a ptr can be resolved in the current
-    JSON value.
+    bool contains(KeyType && key) const
+        return is_object() && m_data.m_value.object->find(std::forward<KeyType>(key)) != m_data.m_value.object->end();
-    @note This method can be executed on any JSON value type.
-    @param[in] ptr JSON pointer to check its existence.
-    @return true if the JSON pointer can be resolved to a stored value, false
-    otherwise.
-    @post If `j.contains(ptr)` returns true, it is safe to call `j[ptr]`.
-    @throw parse_error.106   if an array index begins with '0'
-    @throw parse_error.109   if an array index was not a number
-    @liveexample{The following code shows an example for `contains()`.,contains_json_pointer}
-    @sa @ref contains(KeyT &&) const -- checks the existence of a key
-    @since version 3.7.0
+    /// @brief check the existence of an element in a JSON object given a JSON pointer
     bool contains(const json_pointer& ptr) const
         return ptr.contains(this);
+    template<typename BasicJsonType, detail::enable_if_t<detail::is_basic_json<BasicJsonType>::value, int> = 0>
+    bool contains(const typename ::nlohmann::json_pointer<BasicJsonType>& ptr) const
+        return ptr.contains(this);
     // iterators //
@@ -21084,30 +22065,8 @@ class basic_json
     /// @name iterators
-    @brief returns an iterator to the first element
-    Returns an iterator to the first element.
-    @image html range-begin-end.svg "Illustration from cppreference.com"
-    @return iterator to the first element
-    @complexity Constant.
-    @requirement This function helps `basic_json` satisfying the
-    [Container](https://en.cppreference.com/w/cpp/named_req/Container)
-    requirements:
-    - The complexity is constant.
-    @liveexample{The following code shows an example for `begin()`.,begin}
-    @sa @ref cbegin() -- returns a const iterator to the beginning
-    @sa @ref end() -- returns an iterator to the end
-    @sa @ref cend() -- returns a const iterator to the end
-    @since version 1.0.0
+    /// @brief returns an iterator to the first element
+    /// @sa https://json.nlohmann.me/api/basic_json/begin/
     iterator begin() noexcept
         iterator result(this);
@@ -21115,39 +22074,15 @@ class basic_json
         return result;
-    @copydoc basic_json::cbegin()
     const_iterator begin() const noexcept
         return cbegin();
-    @brief returns a const iterator to the first element
-    Returns a const iterator to the first element.
-    @return const iterator to the first element
-    requirements:
-    - Has the semantics of `const_cast<const basic_json&>(*this).begin()`.
-    @liveexample{The following code shows an example for `cbegin()`.,cbegin}
-    @sa @ref begin() -- returns an iterator to the beginning
+    /// @brief returns a const iterator to the first element
+    /// @sa https://json.nlohmann.me/api/basic_json/cbegin/
     const_iterator cbegin() const noexcept
         const_iterator result(this);
@@ -21155,30 +22090,8 @@ class basic_json
         return result;
-    @brief returns an iterator to one past the last element
-    Returns an iterator to one past the last element.
-    @return iterator one past the last element
-    requirements:
-    @liveexample{The following code shows an example for `end()`.,end}
+    /// @brief returns an iterator to one past the last element
+    /// @sa https://json.nlohmann.me/api/basic_json/end/
     iterator end() noexcept
@@ -21186,39 +22099,15 @@ class basic_json
         return result;
-    @copydoc basic_json::cend()
     const_iterator end() const noexcept
         return cend();
-    @brief returns a const iterator to one past the last element
-    Returns a const iterator to one past the last element.
-    @return const iterator one past the last element
-    requirements:
-    - Has the semantics of `const_cast<const basic_json&>(*this).end()`.
-    @liveexample{The following code shows an example for `cend()`.,cend}
+    /// @sa https://json.nlohmann.me/api/basic_json/cend/
     const_iterator cend() const noexcept
@@ -21226,286 +22115,80 @@ class basic_json
         return result;
-    @brief returns an iterator to the reverse-beginning
-    Returns an iterator to the reverse-beginning; that is, the last element.
-    @image html range-rbegin-rend.svg "Illustration from cppreference.com"
-    [ReversibleContainer](https://en.cppreference.com/w/cpp/named_req/ReversibleContainer)
-    requirements:
-    - Has the semantics of `reverse_iterator(end())`.
-    @liveexample{The following code shows an example for `rbegin()`.,rbegin}
-    @sa @ref crbegin() -- returns a const reverse iterator to the beginning
-    @sa @ref rend() -- returns a reverse iterator to the end
-    @sa @ref crend() -- returns a const reverse iterator to the end
+    /// @brief returns an iterator to the reverse-beginning
+    /// @sa https://json.nlohmann.me/api/basic_json/rbegin/
     reverse_iterator rbegin() noexcept
         return reverse_iterator(end());
-    @copydoc basic_json::crbegin()
     const_reverse_iterator rbegin() const noexcept
         return crbegin();
-    @brief returns an iterator to the reverse-end
-    Returns an iterator to the reverse-end; that is, one before the first
-    element.
-    requirements:
-    - Has the semantics of `reverse_iterator(begin())`.
-    @liveexample{The following code shows an example for `rend()`.,rend}
-    @sa @ref rbegin() -- returns a reverse iterator to the beginning
+    /// @brief returns an iterator to the reverse-end
+    /// @sa https://json.nlohmann.me/api/basic_json/rend/
     reverse_iterator rend() noexcept
         return reverse_iterator(begin());
-    @copydoc basic_json::crend()
     const_reverse_iterator rend() const noexcept
         return crend();
-    @brief returns a const reverse iterator to the last element
-    Returns a const iterator to the reverse-beginning; that is, the last
-    element.
-    requirements:
-    - Has the semantics of `const_cast<const basic_json&>(*this).rbegin()`.
-    @liveexample{The following code shows an example for `crbegin()`.,crbegin}
+    /// @brief returns a const reverse iterator to the last element
+    /// @sa https://json.nlohmann.me/api/basic_json/crbegin/
     const_reverse_iterator crbegin() const noexcept
         return const_reverse_iterator(cend());
-    @brief returns a const reverse iterator to one before the first
-    Returns a const reverse iterator to the reverse-end; that is, one before
-    the first element.
-    requirements:
-    - Has the semantics of `const_cast<const basic_json&>(*this).rend()`.
-    @liveexample{The following code shows an example for `crend()`.,crend}
+    /// @brief returns a const reverse iterator to one before the first
+    /// @sa https://json.nlohmann.me/api/basic_json/crend/
     const_reverse_iterator crend() const noexcept
         return const_reverse_iterator(cbegin());
   public:
-    @brief wrapper to access iterator member functions in range-based for
-    This function allows to access @ref iterator::key() and @ref
-    iterator::value() during range-based for loops. In these loops, a
-    reference to the JSON values is returned, so there is no access to the
-    underlying iterator.
-    For loop without iterator_wrapper:
-    @code{cpp}
-    for (auto it = j_object.begin(); it != j_object.end(); ++it)
-        std::cout << "key: " << it.key() << ", value:" << it.value() << '\n';
-    @endcode
-    Range-based for loop without iterator proxy:
-    @code{cpp}
-    for (auto it : j_object)
-        // "it" is of type json::reference and has no key() member
-        std::cout << "value: " << it << '\n';
-    @endcode
-    Range-based for loop with iterator proxy:
-    @code{cpp}
-    for (auto it : json::iterator_wrapper(j_object))
-    @endcode
-    @note When iterating over an array, `key()` will return the index of the
-          element as string (see example).
-    @param[in] ref  reference to a JSON value
-    @return iteration proxy object wrapping @a ref with an interface to use in
-            range-based for loops
-    @liveexample{The following code shows how the wrapper is used,iterator_wrapper}
-    @exceptionsafety Strong guarantee: if an exception is thrown, there are no
-    changes in the JSON value.
-    @note The name of this function is not yet final and may change in the
-    future.
-    @deprecated This stream operator is deprecated and will be removed in
-                future 4.0.0 of the library. Please use @ref items() instead;
-                that is, replace `json::iterator_wrapper(j)` with `j.items()`.
+    /// @brief wrapper to access iterator member functions in range-based for
+    /// @sa https://json.nlohmann.me/api/basic_json/items/
+    /// @deprecated This function is deprecated since 3.1.0 and will be removed in
+    ///             version 4.0.0 of the library. Please use @ref items() instead;
+    ///             that is, replace `json::iterator_wrapper(j)` with `j.items()`.
     JSON_HEDLEY_DEPRECATED_FOR(3.1.0, items())
     static iteration_proxy<iterator> iterator_wrapper(reference ref) noexcept
         return ref.items();
-    @copydoc iterator_wrapper(reference)
     static iteration_proxy<const_iterator> iterator_wrapper(const_reference ref) noexcept
         return ref.items();
-    @brief helper to access iterator member functions in range-based for
-    For loop without `items()` function:
-    @code{cpp}
-    @endcode
-    Range-based for loop without `items()` function:
-    @code{cpp}
-    @endcode
-    Range-based for loop with `items()` function:
-    @code{cpp}
-    for (auto& el : j_object.items())
-        std::cout << "key: " << el.key() << ", value:" << el.value() << '\n';
-    @endcode
-    The `items()` function also allows to use
-    [structured bindings](https://en.cppreference.com/w/cpp/language/structured_binding)
-    (C++17):
-    @code{cpp}
-    for (auto& [key, val] : j_object.items())
-        std::cout << "key: " << key << ", value:" << val << '\n';
-    @endcode
-          element as string (see example). For primitive types (e.g., numbers),
-          `key()` returns an empty string.
-    @warning Using `items()` on temporary objects is dangerous. Make sure the
-             object's lifetime exceeds the iteration. See
-             <https://github.com/nlohmann/json/issues/2040> for more
-             information.
-    @liveexample{The following code shows how the function is used.,items}
-    @since version 3.1.0, structured bindings support since 3.5.0.
+    /// @brief helper to access iterator member functions in range-based for
     iteration_proxy<iterator> items() noexcept
         return iteration_proxy<iterator>(*this);
-    @copydoc items()
     iteration_proxy<const_iterator> items() const noexcept
         return iteration_proxy<const_iterator>(*this);
@@ -21513,7 +22196,6 @@ class basic_json
     // capacity //
@@ -21521,51 +22203,11 @@ class basic_json
     /// @name capacity
-    @brief checks whether the container is empty.
-    Checks if a JSON value has no elements (i.e. whether its @ref size is `0`).
-    @return The return value depends on the different types and is
-            defined as follows:
-            Value type  | return value
-            null        | `true`
-            boolean     | `false`
-            string      | `false`
-            number      | `false`
-            binary      | `false`
-            object      | result of function `object_t::empty()`
-            array       | result of function `array_t::empty()`
-    @liveexample{The following code uses `empty()` to check if a JSON
-    object contains any elements.,empty}
-    @complexity Constant, as long as @ref array_t and @ref object_t satisfy
-    the Container concept; that is, their `empty()` functions have constant
-    complexity.
-    @iterators No changes.
-    @exceptionsafety No-throw guarantee: this function never throws exceptions.
-    @note This function does not return whether a string stored as JSON value
-    is empty - it returns whether the JSON container itself is empty which is
-    false in the case of a string.
-    requirements:
-    - Has the semantics of `begin() == end()`.
-    @sa @ref size() -- returns the number of elements
+    /// @brief checks whether the container is empty.
+    /// @sa https://json.nlohmann.me/api/basic_json/empty/
     bool empty() const noexcept
-        switch (m_type)
             case value_t::null:
@@ -21576,15 +22218,22 @@ class basic_json
                 // delegate call to array_t::empty()
-                return m_value.array->empty();
+                return m_data.m_value.array->empty();
                 // delegate call to object_t::empty()
-                return m_value.object->empty();
+                return m_data.m_value.object->empty();
+            case value_t::string:
+            case value_t::boolean:
+            case value_t::number_integer:
+            case value_t::number_unsigned:
+            case value_t::number_float:
+            case value_t::binary:
             default:
                 // all other types are nonempty
@@ -21593,52 +22242,11 @@ class basic_json
-    @brief returns the number of elements
-    Returns the number of elements in a JSON value.
-            null        | `0`
-            boolean     | `1`
-            string      | `1`
-            number      | `1`
-            binary      | `1`
-            object      | result of function object_t::size()
-            array       | result of function array_t::size()
-    @liveexample{The following code calls `size()` on the different value
-    types.,size}
-    the Container concept; that is, their size() functions have constant
-    complexity.
-    @note This function does not return the length of a string stored as JSON
-    value - it returns the number of elements in the JSON value which is 1 in
-    the case of a string.
-    requirements:
-    - Has the semantics of `std::distance(begin(), end())`.
-    @sa @ref empty() -- checks whether the container is empty
-    @sa @ref max_size() -- returns the maximal number of elements
+    /// @brief returns the number of elements
+    /// @sa https://json.nlohmann.me/api/basic_json/size/
     size_type size() const noexcept
-        switch (m_type)
             case value_t::null:
@@ -21649,15 +22257,22 @@ class basic_json
                 // delegate call to array_t::size()
-                return m_value.array->size();
+                return m_data.m_value.array->size();
                 // delegate call to object_t::size()
-                return m_value.object->size();
+                return m_data.m_value.object->size();
             default:
                 // all other types have size 1
@@ -21666,63 +22281,32 @@ class basic_json
-    @brief returns the maximum possible number of elements
-    Returns the maximum number of elements a JSON value is able to hold due to
-    system or library implementation limitations, i.e. `std::distance(begin(),
-    end())` for the JSON value.
-            null        | `0` (same as `size()`)
-            boolean     | `1` (same as `size()`)
-            string      | `1` (same as `size()`)
-            number      | `1` (same as `size()`)
-            binary      | `1` (same as `size()`)
-            object      | result of function `object_t::max_size()`
-            array       | result of function `array_t::max_size()`
-    @liveexample{The following code calls `max_size()` on the different value
-    types. Note the output is implementation specific.,max_size}
-    the Container concept; that is, their `max_size()` functions have constant
-    complexity.
-    requirements:
-    - Has the semantics of returning `b.size()` where `b` is the largest
-      possible JSON value.
+    /// @brief returns the maximum possible number of elements
+    /// @sa https://json.nlohmann.me/api/basic_json/max_size/
     size_type max_size() const noexcept
-        switch (m_type)
                 // delegate call to array_t::max_size()
-                return m_value.array->max_size();
+                return m_data.m_value.array->max_size();
                 // delegate call to object_t::max_size()
-                return m_value.object->max_size();
+                return m_data.m_value.object->max_size();
             default:
                 // all other types have max_size() == size()
@@ -21733,7 +22317,6 @@ class basic_json
     // modifiers //
@@ -21741,260 +22324,165 @@ class basic_json
     /// @name modifiers
-    @brief clears the contents
-    Clears the content of a JSON value and resets it to the default value as
-    if @ref basic_json(value_t) would have been called with the current value
-    type from @ref type():
-    Value type  | initial value
-    null        | `null`
-    boolean     | `false`
-    string      | `""`
-    number      | `0`
-    binary      | An empty byte vector
-    object      | `{}`
-    array       | `[]`
-    @post Has the same effect as calling
-    @code {.cpp}
-    *this = basic_json(type());
-    @endcode
-    @liveexample{The example below shows the effect of `clear()` to different
-    JSON types.,clear}
-    @complexity Linear in the size of the JSON value.
-    @iterators All iterators, pointers and references related to this container
-               are invalidated.
-    @sa @ref basic_json(value_t) -- constructor that creates an object with the
-        same value than calling `clear()`
+    /// @brief clears the contents
+    /// @sa https://json.nlohmann.me/api/basic_json/clear/
     void clear() noexcept
-        switch (m_type)
-                m_value.number_integer = 0;
+                m_data.m_value.number_integer = 0;
                 break;
-                m_value.number_unsigned = 0;
+                m_data.m_value.number_unsigned = 0;
                 break;
-                m_value.number_float = 0.0;
+                m_data.m_value.number_float = 0.0;
                 break;
-                m_value.boolean = false;
+                m_data.m_value.boolean = false;
                 break;
-                m_value.string->clear();
+                m_data.m_value.string->clear();
                 break;
-                m_value.binary->clear();
+                m_data.m_value.binary->clear();
                 break;
-                m_value.array->clear();
+                m_data.m_value.array->clear();
                 break;
-                m_value.object->clear();
+                m_data.m_value.object->clear();
                 break;
             default:
                 break;
-    @brief add an object to an array
-    Appends the given element @a val to the end of the JSON value. If the
-    function is called on a JSON null value, an empty array is created before
-    appending @a val.
-    @param[in] val the value to add to the JSON array
-    @throw type_error.308 when called on a type other than JSON array or
-    null; example: `"cannot use push_back() with number"`
-    @complexity Amortized constant.
-    @liveexample{The example shows how `push_back()` and `+=` can be used to
-    add elements to a JSON array. Note how the `null` value was silently
-    converted to a JSON array.,push_back}
+    /// @brief add an object to an array
+    /// @sa https://json.nlohmann.me/api/basic_json/push_back/
     void push_back(basic_json&& val)
         // push_back only works for null objects or arrays
         if (JSON_HEDLEY_UNLIKELY(!(is_null() || is_array())))
-            JSON_THROW(type_error::create(308, "cannot use push_back() with " + std::string(type_name())));
+            JSON_THROW(type_error::create(308, detail::concat("cannot use push_back() with ", type_name()), this));
         // transform null object into an array
         if (is_null())
-            m_type = value_t::array;
-            m_value = value_t::array;
+            m_data.m_type = value_t::array;
+            m_data.m_value = value_t::array;
             assert_invariant();
         // add element to array (move semantics)
-        m_value.array->push_back(std::move(val));
-        // if val is moved from, basic_json move constructor marks it null so we do not call the destructor
+        m_data.m_value.array->push_back(std::move(val));
+        set_parent(m_data.m_value.array->back(), old_capacity);
+        // if val is moved from, basic_json move constructor marks it null, so we do not call the destructor
-    @copydoc push_back(basic_json&&)
+    /// @sa https://json.nlohmann.me/api/basic_json/operator+=/
     reference operator+=(basic_json&& val)
         return *this;
     void push_back(const basic_json& val)
         if (is_null())
             assert_invariant();
-        m_value.array->push_back(val);
+        m_data.m_value.array->push_back(val);
     reference operator+=(const basic_json& val)
         push_back(val);
         return *this;
-    @brief add an object to an object
-    Inserts the given element @a val to the JSON object. If the function is
-    called on a JSON null value, an empty object is created before inserting
-    @a val.
-    @param[in] val the value to add to the JSON object
-    @throw type_error.308 when called on a type other than JSON object or
-    @complexity Logarithmic in the size of the container, O(log(`size()`)).
-    add elements to a JSON object. Note how the `null` value was silently
-    converted to a JSON object.,push_back__object_t__value}
+    /// @brief add an object to an object
     void push_back(const typename object_t::value_type& val)
         // push_back only works for null objects or objects
         if (JSON_HEDLEY_UNLIKELY(!(is_null() || is_object())))
         // transform null object into an object
         if (is_null())
-            m_type = value_t::object;
-            m_value = value_t::object;
+            m_data.m_type = value_t::object;
+            m_data.m_value = value_t::object;
             assert_invariant();
-        // add element to array
-        m_value.object->insert(val);
+        // add element to object
+        auto res = m_data.m_value.object->insert(val);
+        set_parent(res.first->second);
-    @copydoc push_back(const typename object_t::value_type&)
     reference operator+=(const typename object_t::value_type& val)
         push_back(val);
         return *this;
-    This function allows to use `push_back` with an initializer list. In case
-    1. the current value is an object,
-    2. the initializer list @a init contains only two elements, and
-    3. the first element of @a init is a string,
-    @a init is converted into an object element and added using
-    @ref push_back(const typename object_t::value_type&). Otherwise, @a init
-    is converted to a JSON value and added using @ref push_back(basic_json&&).
-    @param[in] init  an initializer list
-    @complexity Linear in the size of the initializer list @a init.
-    @note This function is required to resolve an ambiguous overload error,
-          because pairs like `{"key", "value"}` can be both interpreted as
-          `object_t::value_type` or `std::initializer_list<basic_json>`, see
-          https://github.com/nlohmann/json/issues/235 for more information.
-    @liveexample{The example shows how initializer lists are treated as
-    objects when possible.,push_back__initializer_list}
     void push_back(initializer_list_t init)
         if (is_object() && init.size() == 2 && (*init.begin())->is_string())
@@ -22009,111 +22497,62 @@ class basic_json
-    @copydoc push_back(initializer_list_t)
     reference operator+=(initializer_list_t init)
         push_back(init);
         return *this;
-    Creates a JSON value from the passed parameters @a args to the end of the
-    JSON value. If the function is called on a JSON null value, an empty array
-    is created before appending the value created from @a args.
-    @param[in] args arguments to forward to a constructor of @ref basic_json
-    @tparam Args compatible types to create a @ref basic_json object
-    @return reference to the inserted element
-    @throw type_error.311 when called on a type other than JSON array or
-    null; example: `"cannot use emplace_back() with number"`
-    @liveexample{The example shows how `push_back()` can be used to add
-    elements to a JSON array. Note how the `null` value was silently converted
-    to a JSON array.,emplace_back}
-    @since version 2.0.8, returns reference since 3.7.0
+    /// @sa https://json.nlohmann.me/api/basic_json/emplace_back/
     template<class... Args>
     reference emplace_back(Args&& ... args)
         // emplace_back only works for null objects or arrays
-            JSON_THROW(type_error::create(311, "cannot use emplace_back() with " + std::string(type_name())));
+            JSON_THROW(type_error::create(311, detail::concat("cannot use emplace_back() with ", type_name()), this));
         if (is_null())
             assert_invariant();
         // add element to array (perfect forwarding)
-#ifdef JSON_HAS_CPP_17
-        return m_value.array->emplace_back(std::forward<Args>(args)...);
-#else
-        m_value.array->emplace_back(std::forward<Args>(args)...);
-        return m_value.array->back();
-#endif
+        m_data.m_value.array->emplace_back(std::forward<Args>(args)...);
+        return set_parent(m_data.m_value.array->back(), old_capacity);
-    @brief add an object to an object if key does not exist
-    Inserts a new element into a JSON object constructed in-place with the
-    given @a args if there is no element with the key in the container. If the
-    function is called on a JSON null value, an empty object is created before
-    appending the value created from @a args.
-    @return a pair consisting of an iterator to the inserted element, or the
-            already-existing element if no insertion happened, and a bool
-            denoting whether the insertion took place.
-    @throw type_error.311 when called on a type other than JSON object or
-    null; example: `"cannot use emplace() with number"`
-    @liveexample{The example shows how `emplace()` can be used to add elements
-    to a JSON object. Note how the `null` value was silently converted to a
-    JSON object. Further note how no value is added if there was already one
-    value stored with the same key.,emplace}
+    /// @brief add an object to an object if key does not exist
+    /// @sa https://json.nlohmann.me/api/basic_json/emplace/
     std::pair<iterator, bool> emplace(Args&& ... args)
         // emplace only works for null objects or arrays
-            JSON_THROW(type_error::create(311, "cannot use emplace() with " + std::string(type_name())));
+            JSON_THROW(type_error::create(311, detail::concat("cannot use emplace() with ", type_name()), this));
         if (is_null())
             assert_invariant();
-        auto res = m_value.object->emplace(std::forward<Args>(args)...);
+        auto res = m_data.m_value.object->emplace(std::forward<Args>(args)...);
         // create result iterator and set iterator to the result of emplace
         auto it = begin();
         it.m_it.object_iterator = res.first;
@@ -22129,41 +22568,22 @@ class basic_json
     iterator insert_iterator(const_iterator pos, Args&& ... args)
-        JSON_ASSERT(m_value.array != nullptr);
+        JSON_ASSERT(m_data.m_value.array != nullptr);
-        auto insert_pos = std::distance(m_value.array->begin(), pos.m_it.array_iterator);
-        m_value.array->insert(pos.m_it.array_iterator, std::forward<Args>(args)...);
-        result.m_it.array_iterator = m_value.array->begin() + insert_pos;
+        auto insert_pos = std::distance(m_data.m_value.array->begin(), pos.m_it.array_iterator);
+        m_data.m_value.array->insert(pos.m_it.array_iterator, std::forward<Args>(args)...);
+        result.m_it.array_iterator = m_data.m_value.array->begin() + insert_pos;
         // This could have been written as:
-        // result.m_it.array_iterator = m_value.array->insert(pos.m_it.array_iterator, cnt, val);
+        // result.m_it.array_iterator = m_data.m_value.array->insert(pos.m_it.array_iterator, cnt, val);
         // but the return value of insert is missing in GCC 4.8, so it is written this way instead.
+        set_parents();
         return result;
-    @brief inserts element
-    Inserts element @a val before iterator @a pos.
-    @param[in] pos iterator before which the content will be inserted; may be
-    the end() iterator
-    @param[in] val element to insert
-    @return iterator pointing to the inserted @a val.
-    @throw type_error.309 if called on JSON values other than arrays;
-    example: `"cannot use insert() with string"`
-    @throw invalid_iterator.202 if @a pos is not an iterator of *this;
-    example: `"iterator does not fit current value"`
-    @complexity Constant plus linear in the distance between @a pos and end of
-    the container.
-    @liveexample{The example shows how `insert()` is used.,insert}
+    /// @brief inserts element into array
+    /// @sa https://json.nlohmann.me/api/basic_json/insert/
     iterator insert(const_iterator pos, const basic_json& val)
         // insert only works for arrays
@@ -22172,49 +22592,25 @@ class basic_json
             // check if iterator pos fits to this JSON value
             if (JSON_HEDLEY_UNLIKELY(pos.m_object != this))
             // insert to array and return iterator
             return insert_iterator(pos, val);
-        JSON_THROW(type_error::create(309, "cannot use insert() with " + std::string(type_name())));
+        JSON_THROW(type_error::create(309, detail::concat("cannot use insert() with ", type_name()), this));
-    @copydoc insert(const_iterator, const basic_json&)
     iterator insert(const_iterator pos, basic_json&& val)
         return insert(pos, val);
-    @brief inserts elements
-    Inserts @a cnt copies of @a val before iterator @a pos.
-    @param[in] cnt number of copies of @a val to insert
-    @return iterator pointing to the first element inserted, or @a pos if
-    `cnt==0`
-    @throw type_error.309 if called on JSON values other than arrays; example:
-    `"cannot use insert() with string"`
-    @complexity Linear in @a cnt plus linear in the distance between @a pos
-    and end of the container.
-    @liveexample{The example shows how `insert()` is used.,insert__count}
+    /// @brief inserts copies of element into array
     iterator insert(const_iterator pos, size_type cnt, const basic_json& val)
@@ -22223,473 +22619,257 @@ class basic_json
             return insert_iterator(pos, cnt, val);
-    Inserts elements from range `[first, last)` before iterator @a pos.
-    @param[in] first begin of the range of elements to insert
-    @param[in] last end of the range of elements to insert
-    @throw invalid_iterator.210 if @a first and @a last do not belong to the
-    same JSON value; example: `"iterators do not fit"`
-    @throw invalid_iterator.211 if @a first or @a last are iterators into
-    container for which insert is called; example: `"passed iterators may not
-    belong to container"`
-    `first==last`
-    @complexity Linear in `std::distance(first, last)` plus linear in the
-    distance between @a pos and end of the container.
-    @liveexample{The example shows how `insert()` is used.,insert__range}
+    /// @brief inserts range of elements into array
     iterator insert(const_iterator pos, const_iterator first, const_iterator last)
         if (JSON_HEDLEY_UNLIKELY(!is_array()))
         // check if range iterators belong to the same JSON object
         if (JSON_HEDLEY_UNLIKELY(first.m_object != last.m_object))
-            JSON_THROW(invalid_iterator::create(210, "iterators do not fit"));
+            JSON_THROW(invalid_iterator::create(210, "iterators do not fit", this));
         if (JSON_HEDLEY_UNLIKELY(first.m_object == this))
-            JSON_THROW(invalid_iterator::create(211, "passed iterators may not belong to container"));
+            JSON_THROW(invalid_iterator::create(211, "passed iterators may not belong to container", this));
         return insert_iterator(pos, first.m_it.array_iterator, last.m_it.array_iterator);
-    Inserts elements from initializer list @a ilist before iterator @a pos.
-    @param[in] ilist initializer list to insert the values from
-    `ilist` is empty
-    @complexity Linear in `ilist.size()` plus linear in the distance between
-    @a pos and end of the container.
-    @liveexample{The example shows how `insert()` is used.,insert__ilist}
+    /// @brief inserts elements from initializer list into array
     iterator insert(const_iterator pos, initializer_list_t ilist)
         return insert_iterator(pos, ilist.begin(), ilist.end());
-    Inserts elements from range `[first, last)`.
-    @throw type_error.309 if called on JSON values other than objects; example:
-    @throw invalid_iterator.202 if iterator @a first or @a last does does not
-    point to an object; example: `"iterators first and last must point to
-    objects"`
-    @complexity Logarithmic: `O(N*log(size() + N))`, where `N` is the number
-    of elements to insert.
-    @liveexample{The example shows how `insert()` is used.,insert__range_object}
-    @since version 3.0.0
+    /// @brief inserts range of elements into object
     void insert(const_iterator first, const_iterator last)
         // insert only works for objects
         // passed iterators must belong to objects
         if (JSON_HEDLEY_UNLIKELY(!first.m_object->is_object()))
-            JSON_THROW(invalid_iterator::create(202, "iterators first and last must point to objects"));
+            JSON_THROW(invalid_iterator::create(202, "iterators first and last must point to objects", this));
-        m_value.object->insert(first.m_it.object_iterator, last.m_it.object_iterator);
+        m_data.m_value.object->insert(first.m_it.object_iterator, last.m_it.object_iterator);
-    @brief updates a JSON object from another object, overwriting existing keys
+    /// @brief updates a JSON object from another object, overwriting existing keys
+    /// @sa https://json.nlohmann.me/api/basic_json/update/
+    void update(const_reference j, bool merge_objects = false)
+        update(j.begin(), j.end(), merge_objects);
-    Inserts all values from JSON object @a j and overwrites existing keys.
-    @param[in] j  JSON object to read values from
-    @throw type_error.312 if called on JSON values other than objects; example:
-    `"cannot use update() with string"`
-    @complexity O(N*log(size() + N)), where N is the number of elements to
-                insert.
-    @liveexample{The example shows how `update()` is used.,update}
-    @sa https://docs.python.org/3.6/library/stdtypes.html#dict.update
-    void update(const_reference j)
+    void update(const_iterator first, const_iterator last, bool merge_objects = false)
         if (is_null())
             assert_invariant();
-            JSON_THROW(type_error::create(312, "cannot use update() with " + std::string(type_name())));
-        if (JSON_HEDLEY_UNLIKELY(!j.is_object()))
-            JSON_THROW(type_error::create(312, "cannot use update() with " + std::string(j.type_name())));
-        for (auto it = j.cbegin(); it != j.cend(); ++it)
-            m_value.object->operator[](it.key()) = it.value();
-    Inserts all values from from range `[first, last)` and overwrites existing
-    keys.
-    objects"`
-                insert.
-    @liveexample{The example shows how `update()` is used__range.,update}
-    void update(const_iterator first, const_iterator last)
-        // implicitly convert null value to an empty object
-        if (is_null())
-            assert_invariant();
-        if (JSON_HEDLEY_UNLIKELY(!is_object()))
+            JSON_THROW(type_error::create(312, detail::concat("cannot use update() with ", type_name()), this));
-        if (JSON_HEDLEY_UNLIKELY(!first.m_object->is_object()
-                                 || !last.m_object->is_object()))
+        if (JSON_HEDLEY_UNLIKELY(!first.m_object->is_object()))
+            JSON_THROW(type_error::create(312, detail::concat("cannot use update() with ", first.m_object->type_name()), first.m_object));
         for (auto it = first; it != last; ++it)
+            if (merge_objects && it.value().is_object())
+                auto it2 = m_data.m_value.object->find(it.key());
+                if (it2 != m_data.m_value.object->end())
+                    it2->second.update(it.value(), true);
+                    continue;
+            m_data.m_value.object->operator[](it.key()) = it.value();
+            m_data.m_value.object->operator[](it.key()).m_parent = this;
+#endif
-    @brief exchanges the values
-    Exchanges the contents of the JSON value with those of @a other. Does not
-    invoke any move, copy, or swap operations on individual elements. All
-    iterators and references remain valid. The past-the-end iterator is
-    invalidated.
-    @param[in,out] other JSON value to exchange the contents with
-    @liveexample{The example below shows how JSON values can be swapped with
-    `swap()`.,swap__reference}
+    /// @brief exchanges the values
+    /// @sa https://json.nlohmann.me/api/basic_json/swap/
     void swap(reference other) noexcept (
         std::is_nothrow_move_constructible<value_t>::value&&
         std::is_nothrow_move_assignable<value_t>::value&&
-        std::is_nothrow_move_constructible<json_value>::value&&
+        std::is_nothrow_move_constructible<json_value>::value&& // NOLINT(cppcoreguidelines-noexcept-swap,performance-noexcept-swap)
         std::is_nothrow_move_assignable<json_value>::value
-        std::swap(m_type, other.m_type);
-        std::swap(m_value, other.m_value);
+        std::swap(m_data.m_type, other.m_data.m_type);
+        std::swap(m_data.m_value, other.m_data.m_value);
+        set_parents();
+        other.set_parents();
         assert_invariant();
-    Exchanges the contents of the JSON value from @a left with those of @a right. Does not
-    invalidated. implemented as a friend function callable via ADL.
-    @param[in,out] left JSON value to exchange the contents with
-    @param[in,out] right JSON value to exchange the contents with
     friend void swap(reference left, reference right) noexcept (
         left.swap(right);
-    Exchanges the contents of a JSON array with those of @a other. Does not
-    invalidated.
-    @param[in,out] other array to exchange the contents with
-    @throw type_error.310 when JSON value is not an array; example: `"cannot
-    use swap() with string"`
-    @liveexample{The example below shows how arrays can be swapped with
-    `swap()`.,swap__array_t}
-    void swap(array_t& other)
+    void swap(array_t& other) // NOLINT(bugprone-exception-escape,cppcoreguidelines-noexcept-swap,performance-noexcept-swap)
         // swap only works for arrays
         if (JSON_HEDLEY_LIKELY(is_array()))
-            std::swap(*(m_value.array), other);
+            using std::swap;
+            swap(*(m_data.m_value.array), other);
         else
-            JSON_THROW(type_error::create(310, "cannot use swap() with " + std::string(type_name())));
+            JSON_THROW(type_error::create(310, detail::concat("cannot use swap(array_t&) with ", type_name()), this));
-    Exchanges the contents of a JSON object with those of @a other. Does not
-    invalidated.
-    @param[in,out] other object to exchange the contents with
-    @throw type_error.310 when JSON value is not an object; example:
-    `"cannot use swap() with string"`
-    @liveexample{The example below shows how objects can be swapped with
-    `swap()`.,swap__object_t}
-    void swap(object_t& other)
+    void swap(object_t& other) // NOLINT(bugprone-exception-escape,cppcoreguidelines-noexcept-swap,performance-noexcept-swap)
         // swap only works for objects
-            std::swap(*(m_value.object), other);
+            using std::swap;
+            swap(*(m_data.m_value.object), other);
         else
+            JSON_THROW(type_error::create(310, detail::concat("cannot use swap(object_t&) with ", type_name()), this));
-    Exchanges the contents of a JSON string with those of @a other. Does not
-    invalidated.
-    @param[in,out] other string to exchange the contents with
-    @throw type_error.310 when JSON value is not a string; example: `"cannot
-    use swap() with boolean"`
-    @liveexample{The example below shows how strings can be swapped with
-    `swap()`.,swap__string_t}
-    void swap(string_t& other)
+    void swap(string_t& other) // NOLINT(bugprone-exception-escape,cppcoreguidelines-noexcept-swap,performance-noexcept-swap)
         // swap only works for strings
         if (JSON_HEDLEY_LIKELY(is_string()))
-            std::swap(*(m_value.string), other);
+            using std::swap;
+            swap(*(m_data.m_value.string), other);
         else
+            JSON_THROW(type_error::create(310, detail::concat("cannot use swap(string_t&) with ", type_name()), this));
-    invalidated.
-    @param[in,out] other binary to exchange the contents with
-    `swap()`.,swap__binary_t}
-    @since version 3.8.0
-    void swap(binary_t& other)
+    void swap(binary_t& other) // NOLINT(bugprone-exception-escape,cppcoreguidelines-noexcept-swap,performance-noexcept-swap)
         if (JSON_HEDLEY_LIKELY(is_binary()))
-            std::swap(*(m_value.binary), other);
+            using std::swap;
+            swap(*(m_data.m_value.binary), other);
         else
+            JSON_THROW(type_error::create(310, detail::concat("cannot use swap(binary_t&) with ", type_name()), this));
-    /// @copydoc swap(binary_t)
-    void swap(typename binary_t::container_type& other)
+    void swap(typename binary_t::container_type& other) // NOLINT(bugprone-exception-escape)
+            using std::swap;
         else
+            JSON_THROW(type_error::create(310, detail::concat("cannot use swap(binary_t::container_type&) with ", type_name()), this));
-  public:
     // lexicographical comparison operators //
@@ -22697,454 +22877,391 @@ class basic_json
     /// @name lexicographical comparison operators
-    @brief comparison: equal
+    // note parentheses around operands are necessary; see
+    // https://github.com/nlohmann/json/issues/1530
+#define JSON_IMPLEMENT_OPERATOR(op, null_result, unordered_result, default_result)                       \
+    const auto lhs_type = lhs.type();        \
+    const auto rhs_type = rhs.type();        \
+    if (lhs_type == rhs_type) /* NOLINT(readability/braces) */                                           \
+        switch (lhs_type)        \
+            case value_t::array:        \
+                return (*lhs.m_data.m_value.array) op (*rhs.m_data.m_value.array);                                     \
+            case value_t::object:        \
+                return (*lhs.m_data.m_value.object) op (*rhs.m_data.m_value.object);                                   \
+            case value_t::null:        \
+                return (null_result);        \
+            case value_t::string:        \
+                return (*lhs.m_data.m_value.string) op (*rhs.m_data.m_value.string);                                   \
+            case value_t::boolean:        \
+                return (lhs.m_data.m_value.boolean) op (rhs.m_data.m_value.boolean);                                   \
+            case value_t::number_integer:        \
+                return (lhs.m_data.m_value.number_integer) op (rhs.m_data.m_value.number_integer);                     \
+            case value_t::number_unsigned:                                                               \
+                return (lhs.m_data.m_value.number_unsigned) op (rhs.m_data.m_value.number_unsigned);                   \
+            case value_t::number_float:        \
+                return (lhs.m_data.m_value.number_float) op (rhs.m_data.m_value.number_float);                         \
+            case value_t::binary:        \
+                return (*lhs.m_data.m_value.binary) op (*rhs.m_data.m_value.binary);                                   \
+            case value_t::discarded:        \
+            default:        \
+                return (unordered_result);                                                               \
+    else if (lhs_type == value_t::number_integer && rhs_type == value_t::number_float)                   \
+        return static_cast<number_float_t>(lhs.m_data.m_value.number_integer) op rhs.m_data.m_value.number_float;      \
+    else if (lhs_type == value_t::number_float && rhs_type == value_t::number_integer)                   \
+        return lhs.m_data.m_value.number_float op static_cast<number_float_t>(rhs.m_data.m_value.number_integer);      \
+    else if (lhs_type == value_t::number_unsigned && rhs_type == value_t::number_float)                  \
+        return static_cast<number_float_t>(lhs.m_data.m_value.number_unsigned) op rhs.m_data.m_value.number_float;     \
+    else if (lhs_type == value_t::number_float && rhs_type == value_t::number_unsigned)                  \
+        return lhs.m_data.m_value.number_float op static_cast<number_float_t>(rhs.m_data.m_value.number_unsigned);     \
+    else if (lhs_type == value_t::number_unsigned && rhs_type == value_t::number_integer)                \
+        return static_cast<number_integer_t>(lhs.m_data.m_value.number_unsigned) op rhs.m_data.m_value.number_integer; \
+    else if (lhs_type == value_t::number_integer && rhs_type == value_t::number_unsigned)                \
+        return lhs.m_data.m_value.number_integer op static_cast<number_integer_t>(rhs.m_data.m_value.number_unsigned); \
+    else if(compares_unordered(lhs, rhs))\
+        return (unordered_result);\
+    return (default_result);
-    Compares two JSON values for equality according to the following rules:
-    - Two JSON values are equal if (1) they are from the same type and (2)
-      their stored values are the same according to their respective
-      `operator==`.
-    - Integer and floating-point numbers are automatically converted before
-      comparison. Note that two NaN values are always treated as unequal.
-    - Two JSON null values are equal.
-    @note Floating-point inside JSON values numbers are compared with
-    `json::number_float_t::operator==` which is `double::operator==` by
-    default. To compare floating-point while respecting an epsilon, an alternative
-    [comparison function](https://github.com/mariokonrad/marnav/blob/master/include/marnav/math/floatingpoint.hpp#L34-#L39)
-    could be used, for instance
-    @code {.cpp}
-    template<typename T, typename = typename std::enable_if<std::is_floating_point<T>::value, T>::type>
-    inline bool is_same(T a, T b, T epsilon = std::numeric_limits<T>::epsilon()) noexcept
+  JSON_PRIVATE_UNLESS_TESTED:
+    // returns true if:
+    // - any operand is NaN and the other operand is of number type
+    // - any operand is discarded
+    // in legacy mode, discarded values are considered ordered if
+    // an operation is computed as an odd number of inverses of others
+    static bool compares_unordered(const_reference lhs, const_reference rhs, bool inverse = false) noexcept
-        return std::abs(a - b) <= epsilon;
+        if ((lhs.is_number_float() && std::isnan(lhs.m_data.m_value.number_float) && rhs.is_number())
+                || (rhs.is_number_float() && std::isnan(rhs.m_data.m_value.number_float) && lhs.is_number()))
+            return true;
+#if JSON_USE_LEGACY_DISCARDED_VALUE_COMPARISON
+        return (lhs.is_discarded() || rhs.is_discarded()) && !inverse;
+#else
+        static_cast<void>(inverse);
+        return lhs.is_discarded() || rhs.is_discarded();
+#endif
-    @endcode
-    Or you can self-defined operator equal function like this:
-    @code {.cpp}
-    bool my_equal(const_reference lhs, const_reference rhs) {
-    const auto lhs_type lhs.type();
-    const auto rhs_type rhs.type();
-    if (lhs_type == rhs_type) {
-        switch(lhs_type)
-            // self_defined case
-            case value_t::number_float:
-                return std::abs(lhs - rhs) <= std::numeric_limits<float>::epsilon();
-            // other cases remain the same with the original
+  private:
+    bool compares_unordered(const_reference rhs, bool inverse = false) const noexcept
+        return compares_unordered(*this, rhs, inverse);
+  public:
+#if JSON_HAS_THREE_WAY_COMPARISON
+    /// @brief comparison: equal
+    /// @sa https://json.nlohmann.me/api/basic_json/operator_eq/
+    bool operator==(const_reference rhs) const noexcept
+#ifdef __GNUC__
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Wfloat-equal"
+#endif
+        const_reference lhs = *this;
+        JSON_IMPLEMENT_OPERATOR( ==, true, false, false)
+#ifdef __GNUC__
+#pragma GCC diagnostic pop
+#endif
-    @endcode
-    @note NaN values never compare equal to themselves or to other NaN values.
+    template<typename ScalarType>
+    requires std::is_scalar_v<ScalarType>
+    bool operator==(ScalarType rhs) const noexcept
+        return *this == basic_json(rhs);
-    @param[in] lhs  first JSON value to consider
-    @param[in] rhs  second JSON value to consider
-    @return whether the values @a lhs and @a rhs are equal
+    /// @brief comparison: not equal
+    /// @sa https://json.nlohmann.me/api/basic_json/operator_ne/
+    bool operator!=(const_reference rhs) const noexcept
+        if (compares_unordered(rhs, true))
+            return false;
+        return !operator==(rhs);
+    /// @brief comparison: 3-way
+    /// @sa https://json.nlohmann.me/api/basic_json/operator_spaceship/
+    std::partial_ordering operator<=>(const_reference rhs) const noexcept // *NOPAD*
+        // default_result is used if we cannot compare values. In that case,
+        // we compare types.
+        JSON_IMPLEMENT_OPERATOR(<=>, // *NOPAD*
+                                std::partial_ordering::equivalent,
+                                std::partial_ordering::unordered,
+                                lhs_type <=> rhs_type) // *NOPAD*
-    @complexity Linear.
+    std::partial_ordering operator<=>(ScalarType rhs) const noexcept // *NOPAD*
+        return *this <=> basic_json(rhs); // *NOPAD*
-    @liveexample{The example demonstrates comparing several JSON
-    types.,operator__equal}
+    // all operators that are computed as an odd number of inverses of others
+    // need to be overloaded to emulate the legacy comparison behavior
+    /// @brief comparison: less than or equal
+    /// @sa https://json.nlohmann.me/api/basic_json/operator_le/
+    JSON_HEDLEY_DEPRECATED_FOR(3.11.0, undef JSON_USE_LEGACY_DISCARDED_VALUE_COMPARISON)
+    bool operator<=(const_reference rhs) const noexcept
+            return false;
+        return !(rhs < *this);
+    bool operator<=(ScalarType rhs) const noexcept
+        return *this <= basic_json(rhs);
+    /// @brief comparison: greater than or equal
+    /// @sa https://json.nlohmann.me/api/basic_json/operator_ge/
+    bool operator>=(const_reference rhs) const noexcept
+            return false;
+        return !(*this < rhs);
+    bool operator>=(ScalarType rhs) const noexcept
+        return *this >= basic_json(rhs);
+#endif
+#else
     friend bool operator==(const_reference lhs, const_reference rhs) noexcept
-        const auto lhs_type = lhs.type();
-        const auto rhs_type = rhs.type();
-            switch (lhs_type)
-                case value_t::array:
-                    return *lhs.m_value.array == *rhs.m_value.array;
-                case value_t::object:
-                    return *lhs.m_value.object == *rhs.m_value.object;
-                case value_t::null:
-                    return true;
-                case value_t::string:
-                    return *lhs.m_value.string == *rhs.m_value.string;
-                case value_t::boolean:
-                    return lhs.m_value.boolean == rhs.m_value.boolean;
-                case value_t::number_integer:
-                    return lhs.m_value.number_integer == rhs.m_value.number_integer;
-                case value_t::number_unsigned:
-                    return lhs.m_value.number_unsigned == rhs.m_value.number_unsigned;
-                    return lhs.m_value.number_float == rhs.m_value.number_float;
-                case value_t::binary:
-                    return *lhs.m_value.binary == *rhs.m_value.binary;
-                default:
-                    return false;
-        else if (lhs_type == value_t::number_integer && rhs_type == value_t::number_float)
-            return static_cast<number_float_t>(lhs.m_value.number_integer) == rhs.m_value.number_float;
-        else if (lhs_type == value_t::number_float && rhs_type == value_t::number_integer)
-            return lhs.m_value.number_float == static_cast<number_float_t>(rhs.m_value.number_integer);
-        else if (lhs_type == value_t::number_unsigned && rhs_type == value_t::number_float)
-            return static_cast<number_float_t>(lhs.m_value.number_unsigned) == rhs.m_value.number_float;
-        else if (lhs_type == value_t::number_float && rhs_type == value_t::number_unsigned)
-            return lhs.m_value.number_float == static_cast<number_float_t>(rhs.m_value.number_unsigned);
-        else if (lhs_type == value_t::number_unsigned && rhs_type == value_t::number_integer)
-            return static_cast<number_integer_t>(lhs.m_value.number_unsigned) == rhs.m_value.number_integer;
-        else if (lhs_type == value_t::number_integer && rhs_type == value_t::number_unsigned)
-            return lhs.m_value.number_integer == static_cast<number_integer_t>(rhs.m_value.number_unsigned);
-        return false;
+#ifdef __GNUC__
+#endif
+#ifdef __GNUC__
+#endif
-    @copydoc operator==(const_reference, const_reference)
     template<typename ScalarType, typename std::enable_if<
                  std::is_scalar<ScalarType>::value, int>::type = 0>
-    friend bool operator==(const_reference lhs, const ScalarType rhs) noexcept
+    friend bool operator==(const_reference lhs, ScalarType rhs) noexcept
         return lhs == basic_json(rhs);
-    friend bool operator==(const ScalarType lhs, const_reference rhs) noexcept
+    friend bool operator==(ScalarType lhs, const_reference rhs) noexcept
         return basic_json(lhs) == rhs;
-    @brief comparison: not equal
-    Compares two JSON values for inequality by calculating `not (lhs == rhs)`.
-    @return whether the values @a lhs and @a rhs are not equal
-    types.,operator__notequal}
     friend bool operator!=(const_reference lhs, const_reference rhs) noexcept
+        if (compares_unordered(lhs, rhs, true))
+            return false;
         return !(lhs == rhs);
-    @copydoc operator!=(const_reference, const_reference)
-    friend bool operator!=(const_reference lhs, const ScalarType rhs) noexcept
+    friend bool operator!=(const_reference lhs, ScalarType rhs) noexcept
         return lhs != basic_json(rhs);
-    friend bool operator!=(const ScalarType lhs, const_reference rhs) noexcept
+    friend bool operator!=(ScalarType lhs, const_reference rhs) noexcept
         return basic_json(lhs) != rhs;
-    @brief comparison: less than
-    Compares whether one JSON value @a lhs is less than another JSON value @a
-    rhs according to the following rules:
-    - If @a lhs and @a rhs have the same type, the values are compared using
-      the default `<` operator.
-      comparison
-    - In case @a lhs and @a rhs have different types, the values are ignored
-      and the order of the types is considered, see
-      @ref operator<(const value_t, const value_t).
-    @return whether @a lhs is less than @a rhs
-    types.,operator__less}
+    /// @sa https://json.nlohmann.me/api/basic_json/operator_lt/
     friend bool operator<(const_reference lhs, const_reference rhs) noexcept
-            switch (lhs_type)
-                    // note parentheses are necessary, see
-                    // https://github.com/nlohmann/json/issues/1530
-                    return (*lhs.m_value.array) < (*rhs.m_value.array);
-                    return (*lhs.m_value.object) < (*rhs.m_value.object);
-                    return false;
-                    return (*lhs.m_value.string) < (*rhs.m_value.string);
-                    return (lhs.m_value.boolean) < (rhs.m_value.boolean);
-                    return (lhs.m_value.number_integer) < (rhs.m_value.number_integer);
-                    return (lhs.m_value.number_unsigned) < (rhs.m_value.number_unsigned);
-                    return (lhs.m_value.number_float) < (rhs.m_value.number_float);
-                    return (*lhs.m_value.binary) < (*rhs.m_value.binary);
-                default:
-                    return false;
-            return static_cast<number_float_t>(lhs.m_value.number_integer) < rhs.m_value.number_float;
-            return lhs.m_value.number_float < static_cast<number_float_t>(rhs.m_value.number_integer);
-            return static_cast<number_float_t>(lhs.m_value.number_unsigned) < rhs.m_value.number_float;
-            return lhs.m_value.number_float < static_cast<number_float_t>(rhs.m_value.number_unsigned);
-            return lhs.m_value.number_integer < static_cast<number_integer_t>(rhs.m_value.number_unsigned);
-            return static_cast<number_integer_t>(lhs.m_value.number_unsigned) < rhs.m_value.number_integer;
-        // We only reach this line if we cannot compare values. In that case,
         // we compare types. Note we have to call the operator explicitly,
         // because MSVC has problems otherwise.
-        return operator<(lhs_type, rhs_type);
+        JSON_IMPLEMENT_OPERATOR( <, false, false, operator<(lhs_type, rhs_type))
-    @copydoc operator<(const_reference, const_reference)
-    friend bool operator<(const_reference lhs, const ScalarType rhs) noexcept
+    friend bool operator<(const_reference lhs, ScalarType rhs) noexcept
         return lhs < basic_json(rhs);
-    friend bool operator<(const ScalarType lhs, const_reference rhs) noexcept
+    friend bool operator<(ScalarType lhs, const_reference rhs) noexcept
         return basic_json(lhs) < rhs;
-    @brief comparison: less than or equal
-    Compares whether one JSON value @a lhs is less than or equal to another
-    JSON value by calculating `not (rhs < lhs)`.
-    @return whether @a lhs is less than or equal to @a rhs
-    types.,operator__greater}
     friend bool operator<=(const_reference lhs, const_reference rhs) noexcept
+            return false;
         return !(rhs < lhs);
-    @copydoc operator<=(const_reference, const_reference)
-    friend bool operator<=(const_reference lhs, const ScalarType rhs) noexcept
+    friend bool operator<=(const_reference lhs, ScalarType rhs) noexcept
         return lhs <= basic_json(rhs);
-    friend bool operator<=(const ScalarType lhs, const_reference rhs) noexcept
+    friend bool operator<=(ScalarType lhs, const_reference rhs) noexcept
         return basic_json(lhs) <= rhs;
-    @brief comparison: greater than
-    Compares whether one JSON value @a lhs is greater than another
-    JSON value by calculating `not (lhs <= rhs)`.
-    @return whether @a lhs is greater than to @a rhs
-    types.,operator__lessequal}
+    /// @sa https://json.nlohmann.me/api/basic_json/operator_gt/
     friend bool operator>(const_reference lhs, const_reference rhs) noexcept
+        // double inverse
+        if (compares_unordered(lhs, rhs))
+            return false;
         return !(lhs <= rhs);
-    @copydoc operator>(const_reference, const_reference)
-    friend bool operator>(const_reference lhs, const ScalarType rhs) noexcept
+    friend bool operator>(const_reference lhs, ScalarType rhs) noexcept
         return lhs > basic_json(rhs);
-    friend bool operator>(const ScalarType lhs, const_reference rhs) noexcept
+    friend bool operator>(ScalarType lhs, const_reference rhs) noexcept
         return basic_json(lhs) > rhs;
-    @brief comparison: greater than or equal
-    Compares whether one JSON value @a lhs is greater than or equal to another
-    JSON value by calculating `not (lhs < rhs)`.
-    @return whether @a lhs is greater than or equal to @a rhs
-    types.,operator__greaterequal}
     friend bool operator>=(const_reference lhs, const_reference rhs) noexcept
+            return false;
         return !(lhs < rhs);
-    @copydoc operator>=(const_reference, const_reference)
-    friend bool operator>=(const_reference lhs, const ScalarType rhs) noexcept
+    friend bool operator>=(const_reference lhs, ScalarType rhs) noexcept
         return lhs >= basic_json(rhs);
-    friend bool operator>=(const ScalarType lhs, const_reference rhs) noexcept
+    friend bool operator>=(ScalarType lhs, const_reference rhs) noexcept
         return basic_json(lhs) >= rhs;
+#endif
+#undef JSON_IMPLEMENT_OPERATOR
@@ -23154,38 +23271,9 @@ class basic_json
     /// @name serialization
-    @brief serialize to stream
-    Serialize the given JSON value @a j to the output stream @a o. The JSON
-    value will be serialized using the @ref dump member function.
-    - The indentation of the output can be controlled with the member variable
-      `width` of the output stream @a o. For instance, using the manipulator
-      `std::setw(4)` on @a o sets the indentation level to `4` and the
-      serialization result is the same as calling `dump(4)`.
-    - The indentation character can be controlled with the member variable
-      `fill` of the output stream @a o. For instance, the manipulator
-      `std::setfill('\\t')` sets indentation to use a tab character rather than
-      the default space character.
-    @param[in,out] o  stream to serialize to
-    @param[in] j  JSON value to serialize
-    @return the stream @a o
-    @throw type_error.316 if a string stored inside the JSON value is not
-                          UTF-8 encoded
-    @liveexample{The example below shows the serialization with different
-    parameters to `width` to adjust the indentation level.,operator_serialize}
-    @since version 1.0.0; indentation character added in version 3.0.0
+#ifndef JSON_NO_IO
+    /// @brief serialize to stream
+    /// @sa https://json.nlohmann.me/api/basic_json/operator_ltlt/
     friend std::ostream& operator<<(std::ostream& o, const basic_json& j)
         // read width member and use it as indentation parameter if nonzero
@@ -23201,23 +23289,20 @@ class basic_json
         return o;
-                @ref operator<<(std::ostream&, const basic_json&)
-                instead; that is, replace calls like `j >> o;` with `o << j;`.
-    @since version 1.0.0; deprecated since version 3.0.0
+    /// @deprecated This function is deprecated since 3.0.0 and will be removed in
+    ///             operator<<(std::ostream&, const basic_json&) instead; that is,
+    ///             replace calls like `j >> o;` with `o << j;`.
     JSON_HEDLEY_DEPRECATED_FOR(3.0.0, operator<<(std::ostream&, const basic_json&))
     friend std::ostream& operator>>(const basic_json& j, std::ostream& o)
         return o << j;
+#endif  // JSON_NO_IO
     // deserialization //
@@ -23225,57 +23310,8 @@ class basic_json
     /// @name deserialization
-    @brief deserialize from a compatible input
-    @tparam InputType A compatible input, for instance
-    - an std::istream object
-    - a FILE pointer
-    - a C-style array of characters
-    - a pointer to a null-terminated string of single byte characters
-    - an object obj for which begin(obj) and end(obj) produces a valid pair of
-      iterators.
-    @param[in] i  input to read from
-    @param[in] cb  a parser callback function of type @ref parser_callback_t
-    which is used to control the deserialization by filtering unwanted values
-    (optional)
-    @param[in] allow_exceptions  whether to throw exceptions in case of a
-    parse error (optional, true by default)
-    @param[in] ignore_comments  whether comments should be ignored and treated
-    like whitespace (true) or yield a parse error (true); (optional, false by
-    default)
-    @return deserialized JSON value; in case of a parse error and
-            @a allow_exceptions set to `false`, the return value will be
-            value_t::discarded.
-    @throw parse_error.101 if a parse error occurs; example: `""unexpected end
-    of input; expected string literal""`
-    @throw parse_error.102 if to_unicode fails or surrogate error
-    @throw parse_error.103 if to_unicode fails
-    @complexity Linear in the length of the input. The parser is a predictive
-    LL(1) parser. The complexity can be higher if the parser callback function
-    @a cb or reading from the input @a i has a super-linear complexity.
-    @note A UTF-8 byte order mark is silently ignored.
-    @liveexample{The example below demonstrates the `parse()` function reading
-    from an array.,parse__array__parser_callback_t}
-    @liveexample{The example below demonstrates the `parse()` function with
-    and without callback function.,parse__string__parser_callback_t}
-    and without callback function.,parse__istream__parser_callback_t}
-    from a contiguous container.,parse__contiguouscontainer__parser_callback_t}
-    @since version 2.0.3 (contiguous containers); version 3.9.0 allowed to
-    ignore comments.
+    /// @brief deserialize from a compatible input
+    /// @sa https://json.nlohmann.me/api/basic_json/parse/
     template<typename InputType>
     JSON_HEDLEY_WARN_UNUSED_RESULT
     static basic_json parse(InputType&& i,
@@ -23288,32 +23324,8 @@ class basic_json
         return result;
-    @brief deserialize from a pair of character iterators
-    The value_type of the iterator must be a integral type with size of 1, 2 or
-    4 bytes, which will be interpreted respectively as UTF-8, UTF-16 and UTF-32.
-    @param[in] first iterator to start of character range
-    @param[in] last  iterator to end of character range
-    (optional)
-    default)
+    /// @brief deserialize from a pair of character iterators
     template<typename IteratorType>
     static basic_json parse(IteratorType first,
@@ -23339,36 +23351,8 @@ class basic_json
         return result;
-    @brief check if the input is valid JSON
-    Unlike the @ref parse(InputType&&, const parser_callback_t,const bool)
-    function, this function neither throws an exception in case of invalid JSON
-    input (i.e., a parse error) nor creates diagnostic information.
-    - a FILE pointer
-      iterators.
-    default)
-    @return Whether the input read from @a i is valid JSON.
-    LL(1) parser.
-    @liveexample{The example below demonstrates the `accept()` function reading
-    from a string.,accept__string}
+    /// @brief check if the input is valid JSON
+    /// @sa https://json.nlohmann.me/api/basic_json/accept/
     static bool accept(InputType&& i,
                        const bool ignore_comments = false)
@@ -23376,6 +23360,8 @@ class basic_json
         return parser(detail::input_adapter(std::forward<InputType>(i)), nullptr, false, ignore_comments).accept(true);
     static bool accept(IteratorType first, IteratorType last,
@@ -23391,46 +23377,8 @@ class basic_json
         return parser(i.get(), nullptr, false, ignore_comments).accept(true);
-    @brief generate SAX events
-    The SAX event lister must follow the interface of @ref json_sax.
-    This function reads from a compatible input. Examples are:
-    - a FILE pointer
-      iterators.
-    @param[in,out] sax  SAX event listener
-    @param[in] format  the format to parse (JSON, CBOR, MessagePack, or UBJSON)
-    @param[in] strict  whether the input has to be consumed completely
-    default); only applies to the JSON file format.
-    @return return value of the last processed SAX event
-    LL(1) parser. The complexity can be higher if the SAX consumer @a sax has
-    a super-linear complexity.
-    @liveexample{The example below demonstrates the `sax_parse()` function
-    reading from string and processing the events with a user-defined SAX
-    event consumer.,sax_parse}
-    @since version 3.2.0
+    /// @brief generate SAX events
+    /// @sa https://json.nlohmann.me/api/basic_json/sax_parse/
     template <typename InputType, typename SAX>
     JSON_HEDLEY_NON_NULL(2)
     static bool sax_parse(InputType&& i, SAX* sax,
@@ -23441,9 +23389,11 @@ class basic_json
         auto ia = detail::input_adapter(std::forward<InputType>(i));
         return format == input_format_t::json
                ? parser(std::move(ia), nullptr, true, ignore_comments).sax_parse(sax, strict)
-               : detail::binary_reader<basic_json, decltype(ia), SAX>(std::move(ia)).sax_parse(format, sax, strict);
+               : detail::binary_reader<basic_json, decltype(ia), SAX>(std::move(ia), format).sax_parse(format, sax, strict);
     template<class IteratorType, class SAX>
     JSON_HEDLEY_NON_NULL(3)
     static bool sax_parse(IteratorType first, IteratorType last, SAX* sax,
@@ -23454,9 +23404,14 @@ class basic_json
         auto ia = detail::input_adapter(std::move(first), std::move(last));
+    /// @deprecated This function is deprecated since 3.8.0 and will be removed in
+    ///             sax_parse(ptr, ptr + len) instead.
     template <typename SAX>
     JSON_HEDLEY_DEPRECATED_FOR(3.8.0, sax_parse(ptr, ptr + len, ...))
@@ -23467,129 +23422,109 @@ class basic_json
         auto ia = i.get();
+               // NOLINTNEXTLINE(hicpp-move-const-arg,performance-move-const-arg)
-    @brief deserialize from stream
-                version 4.0.0 of the library. Please use
-                @ref operator>>(std::istream&, basic_json&)
-                instead; that is, replace calls like `j << i;` with `i >> j;`.
+#ifndef JSON_NO_IO
+    /// @brief deserialize from stream
+    /// @sa https://json.nlohmann.me/api/basic_json/operator_gtgt/
+    /// @deprecated This stream operator is deprecated since 3.0.0 and will be removed in
+    ///             operator>>(std::istream&, basic_json&) instead; that is,
+    ///             replace calls like `j << i;` with `i >> j;`.
     JSON_HEDLEY_DEPRECATED_FOR(3.0.0, operator>>(std::istream&, basic_json&))
     friend std::istream& operator<<(basic_json& j, std::istream& i)
         return operator>>(i, j);
-    Deserializes an input stream to a JSON value.
-    @param[in,out] i  input stream to read a serialized JSON value from
-    @param[in,out] j  JSON value to write the deserialized input to
-    @throw parse_error.101 in case of an unexpected token
-    LL(1) parser.
-    @liveexample{The example below shows how a JSON value is constructed by
-    reading a serialization from a stream.,operator_deserialize}
-    @sa parse(std::istream&, const parser_callback_t) for a variant with a
-    parser callback function to filter values while parsing
     friend std::istream& operator>>(std::istream& i, basic_json& j)
         parser(detail::input_adapter(i)).parse(false, j);
         return i;
     // convenience functions //
-    @brief return the type as string
-    Returns the type name as string to be used in error messages - usually to
-    indicate that a function was called on a wrong JSON type.
-    @return a string representation of a the @a m_type member:
-            null        | `"null"`
-            boolean     | `"boolean"`
-            string      | `"string"`
-            number      | `"number"` (for all number types)
-            object      | `"object"`
-            array       | `"array"`
-            binary      | `"binary"`
-            discarded   | `"discarded"`
-    @complexity Constant.
-    @liveexample{The following code exemplifies `type_name()` for all JSON
-    types.,type_name}
-    @sa @ref type() -- return the type of the JSON value
-    @sa @ref operator value_t() -- return the type of the JSON value (implicit)
-    @since version 1.0.0, public since 2.1.0, `const char*` and `noexcept`
-    since 3.0.0
+    /// @brief return the type as string
+    /// @sa https://json.nlohmann.me/api/basic_json/type_name/
     JSON_HEDLEY_RETURNS_NON_NULL
     const char* type_name() const noexcept
+        switch (m_data.m_type)
-            switch (m_type)
-                    return "null";
-                    return "object";
-                    return "array";
-                    return "string";
-                    return "boolean";
-                    return "binary";
-                case value_t::discarded:
-                    return "discarded";
-                default:
-                    return "number";
+                return "null";
+                return "object";
+                return "array";
+                return "string";
+                return "boolean";
+                return "binary";
+                return "discarded";
+            default:
+                return "number";
     // member variables //
-    /// the type of the current element
-    value_t m_type = value_t::null;
+    struct data
+        /// the type of the current element
+        value_t m_type = value_t::null;
-    /// the value of the current element
-    json_value m_value = {};
+        /// the value of the current element
+        json_value m_value = {};
+        data(const value_t v)
+            : m_type(v), m_value(v)
+        data(size_type cnt, const basic_json& val)
+            : m_type(value_t::array)
+            m_value.array = create<array_t>(cnt, val);
+        data() noexcept = default;
+        data(data&&) noexcept = default;
+        data(const data&) noexcept = delete;
+        data& operator=(data&&) noexcept = delete;
+        data& operator=(const data&) noexcept = delete;
+        ~data() noexcept
+            m_value.destroy(m_type);
+    data m_data = {};
+#if JSON_DIAGNOSTICS
+    /// a pointer to a parent value (for debugging purposes)
+    basic_json* m_parent = nullptr;
+#endif
     // binary serialization/deserialization //
@@ -23599,507 +23534,131 @@ class basic_json
   public:
-    @brief create a CBOR serialization of a given JSON value
-    Serializes a given JSON value @a j to a byte vector using the CBOR (Concise
-    Binary Object Representation) serialization format. CBOR is a binary
-    serialization format which aims to be more compact than JSON itself, yet
-    more efficient to parse.
-    The library uses the following mapping from JSON values types to
-    CBOR types according to the CBOR specification (RFC 7049):
-    JSON value type | value/range                                | CBOR type                          | first byte
-    null            | `null`                                     | Null                               | 0xF6
-    boolean         | `true`                                     | True                               | 0xF5
-    boolean         | `false`                                    | False                              | 0xF4
-    number_integer  | -9223372036854775808..-2147483649          | Negative integer (8 bytes follow)  | 0x3B
-    number_integer  | -2147483648..-32769                        | Negative integer (4 bytes follow)  | 0x3A
-    number_integer  | -32768..-129                               | Negative integer (2 bytes follow)  | 0x39
-    number_integer  | -128..-25                                  | Negative integer (1 byte follow)   | 0x38
-    number_integer  | -24..-1                                    | Negative integer                   | 0x20..0x37
-    number_integer  | 0..23                                      | Integer                            | 0x00..0x17
-    number_integer  | 24..255                                    | Unsigned integer (1 byte follow)   | 0x18
-    number_integer  | 256..65535                                 | Unsigned integer (2 bytes follow)  | 0x19
-    number_integer  | 65536..4294967295                          | Unsigned integer (4 bytes follow)  | 0x1A
-    number_integer  | 4294967296..18446744073709551615           | Unsigned integer (8 bytes follow)  | 0x1B
-    number_unsigned | 0..23                                      | Integer                            | 0x00..0x17
-    number_unsigned | 24..255                                    | Unsigned integer (1 byte follow)   | 0x18
-    number_unsigned | 256..65535                                 | Unsigned integer (2 bytes follow)  | 0x19
-    number_unsigned | 65536..4294967295                          | Unsigned integer (4 bytes follow)  | 0x1A
-    number_unsigned | 4294967296..18446744073709551615           | Unsigned integer (8 bytes follow)  | 0x1B
-    number_float    | *any value representable by a float*       | Single-Precision Float             | 0xFA
-    number_float    | *any value NOT representable by a float*   | Double-Precision Float             | 0xFB
-    string          | *length*: 0..23                            | UTF-8 string                       | 0x60..0x77
-    string          | *length*: 23..255                          | UTF-8 string (1 byte follow)       | 0x78
-    string          | *length*: 256..65535                       | UTF-8 string (2 bytes follow)      | 0x79
-    string          | *length*: 65536..4294967295                | UTF-8 string (4 bytes follow)      | 0x7A
-    string          | *length*: 4294967296..18446744073709551615 | UTF-8 string (8 bytes follow)      | 0x7B
-    array           | *size*: 0..23                              | array                              | 0x80..0x97
-    array           | *size*: 23..255                            | array (1 byte follow)              | 0x98
-    array           | *size*: 256..65535                         | array (2 bytes follow)             | 0x99
-    array           | *size*: 65536..4294967295                  | array (4 bytes follow)             | 0x9A
-    array           | *size*: 4294967296..18446744073709551615   | array (8 bytes follow)             | 0x9B
-    object          | *size*: 0..23                              | map                                | 0xA0..0xB7
-    object          | *size*: 23..255                            | map (1 byte follow)                | 0xB8
-    object          | *size*: 256..65535                         | map (2 bytes follow)               | 0xB9
-    object          | *size*: 65536..4294967295                  | map (4 bytes follow)               | 0xBA
-    object          | *size*: 4294967296..18446744073709551615   | map (8 bytes follow)               | 0xBB
-    binary          | *size*: 0..23                              | byte string                        | 0x40..0x57
-    binary          | *size*: 23..255                            | byte string (1 byte follow)        | 0x58
-    binary          | *size*: 256..65535                         | byte string (2 bytes follow)       | 0x59
-    binary          | *size*: 65536..4294967295                  | byte string (4 bytes follow)       | 0x5A
-    binary          | *size*: 4294967296..18446744073709551615   | byte string (8 bytes follow)       | 0x5B
-    @note The mapping is **complete** in the sense that any JSON value type
-          can be converted to a CBOR value.
-    @note If NaN or Infinity are stored inside a JSON number, they are
-          serialized properly. This behavior differs from the @ref dump()
-          function which serializes NaN or Infinity to `null`.
-    @note The following CBOR types are not used in the conversion:
-          - UTF-8 strings terminated by "break" (0x7F)
-          - arrays terminated by "break" (0x9F)
-          - maps terminated by "break" (0xBF)
-          - byte strings terminated by "break" (0x5F)
-          - date/time (0xC0..0xC1)
-          - bignum (0xC2..0xC3)
-          - decimal fraction (0xC4)
-          - bigfloat (0xC5)
-          - expected conversions (0xD5..0xD7)
-          - simple values (0xE0..0xF3, 0xF8)
-          - undefined (0xF7)
-          - half-precision floats (0xF9)
-          - break (0xFF)
-    @return CBOR serialization as byte vector
-    @complexity Linear in the size of the JSON value @a j.
-    @liveexample{The example shows the serialization of a JSON value to a byte
-    vector in CBOR format.,to_cbor}
-    @sa http://cbor.io
-    @sa @ref from_cbor(detail::input_adapter&&, const bool, const bool, const cbor_tag_handler_t) for the
-        analogous deserialization
-    @sa @ref to_msgpack(const basic_json&) for the related MessagePack format
-    @sa @ref to_ubjson(const basic_json&, const bool, const bool) for the
-             related UBJSON format
-    @since version 2.0.9; compact representation of floating-point numbers
-           since version 3.8.0
-    static std::vector<uint8_t> to_cbor(const basic_json& j)
+    /// @brief create a CBOR serialization of a given JSON value
+    /// @sa https://json.nlohmann.me/api/basic_json/to_cbor/
+    static std::vector<std::uint8_t> to_cbor(const basic_json& j)
-        std::vector<uint8_t> result;
+        std::vector<std::uint8_t> result;
         to_cbor(j, result);
         return result;
-    static void to_cbor(const basic_json& j, detail::output_adapter<uint8_t> o)
+    static void to_cbor(const basic_json& j, detail::output_adapter<std::uint8_t> o)
-        binary_writer<uint8_t>(o).write_cbor(j);
+        binary_writer<std::uint8_t>(o).write_cbor(j);
     static void to_cbor(const basic_json& j, detail::output_adapter<char> o)
         binary_writer<char>(o).write_cbor(j);
-    @brief create a MessagePack serialization of a given JSON value
-    Serializes a given JSON value @a j to a byte vector using the MessagePack
-    serialization format. MessagePack is a binary serialization format which
-    aims to be more compact than JSON itself, yet more efficient to parse.
-    MessagePack types according to the MessagePack specification:
-    JSON value type | value/range                       | MessagePack type | first byte
-    null            | `null`                            | nil              | 0xC0
-    boolean         | `true`                            | true             | 0xC3
-    boolean         | `false`                           | false            | 0xC2
-    number_integer  | -9223372036854775808..-2147483649 | int64            | 0xD3
-    number_integer  | -2147483648..-32769               | int32            | 0xD2
-    number_integer  | -32768..-129                      | int16            | 0xD1
-    number_integer  | -128..-33                         | int8             | 0xD0
-    number_integer  | -32..-1                           | negative fixint  | 0xE0..0xFF
-    number_integer  | 0..127                            | positive fixint  | 0x00..0x7F
-    number_integer  | 128..255                          | uint 8           | 0xCC
-    number_integer  | 256..65535                        | uint 16          | 0xCD
-    number_integer  | 65536..4294967295                 | uint 32          | 0xCE
-    number_integer  | 4294967296..18446744073709551615  | uint 64          | 0xCF
-    number_unsigned | 0..127                            | positive fixint  | 0x00..0x7F
-    number_unsigned | 128..255                          | uint 8           | 0xCC
-    number_unsigned | 256..65535                        | uint 16          | 0xCD
-    number_unsigned | 65536..4294967295                 | uint 32          | 0xCE
-    number_unsigned | 4294967296..18446744073709551615  | uint 64          | 0xCF
-    number_float    | *any value representable by a float*     | float 32 | 0xCA
-    number_float    | *any value NOT representable by a float* | float 64 | 0xCB
-    string          | *length*: 0..31                   | fixstr           | 0xA0..0xBF
-    string          | *length*: 32..255                 | str 8            | 0xD9
-    string          | *length*: 256..65535              | str 16           | 0xDA
-    string          | *length*: 65536..4294967295       | str 32           | 0xDB
-    array           | *size*: 0..15                     | fixarray         | 0x90..0x9F
-    array           | *size*: 16..65535                 | array 16         | 0xDC
-    array           | *size*: 65536..4294967295         | array 32         | 0xDD
-    object          | *size*: 0..15                     | fix map          | 0x80..0x8F
-    object          | *size*: 16..65535                 | map 16           | 0xDE
-    object          | *size*: 65536..4294967295         | map 32           | 0xDF
-    binary          | *size*: 0..255                    | bin 8            | 0xC4
-    binary          | *size*: 256..65535                | bin 16           | 0xC5
-    binary          | *size*: 65536..4294967295         | bin 32           | 0xC6
-          can be converted to a MessagePack value.
-    @note The following values can **not** be converted to a MessagePack value:
-          - strings with more than 4294967295 bytes
-          - byte strings with more than 4294967295 bytes
-          - arrays with more than 4294967295 elements
-          - objects with more than 4294967295 elements
-    @note Any MessagePack output created @ref to_msgpack can be successfully
-          parsed by @ref from_msgpack.
-    @return MessagePack serialization as byte vector
-    vector in MessagePack format.,to_msgpack}
-    @sa http://msgpack.org
-    @sa @ref from_msgpack for the analogous deserialization
-    @sa @ref to_cbor(const basic_json& for the related CBOR format
-    static std::vector<uint8_t> to_msgpack(const basic_json& j)
+    /// @brief create a MessagePack serialization of a given JSON value
+    /// @sa https://json.nlohmann.me/api/basic_json/to_msgpack/
+    static std::vector<std::uint8_t> to_msgpack(const basic_json& j)
         to_msgpack(j, result);
         return result;
-    static void to_msgpack(const basic_json& j, detail::output_adapter<uint8_t> o)
+    static void to_msgpack(const basic_json& j, detail::output_adapter<std::uint8_t> o)
-        binary_writer<uint8_t>(o).write_msgpack(j);
+        binary_writer<std::uint8_t>(o).write_msgpack(j);
     static void to_msgpack(const basic_json& j, detail::output_adapter<char> o)
         binary_writer<char>(o).write_msgpack(j);
-    @brief create a UBJSON serialization of a given JSON value
-    Serializes a given JSON value @a j to a byte vector using the UBJSON
-    (Universal Binary JSON) serialization format. UBJSON aims to be more compact
-    than JSON itself, yet more efficient to parse.
-    UBJSON types according to the UBJSON specification:
-    JSON value type | value/range                       | UBJSON type | marker
-    null            | `null`                            | null        | `Z`
-    boolean         | `true`                            | true        | `T`
-    boolean         | `false`                           | false       | `F`
-    number_integer  | -9223372036854775808..-2147483649 | int64       | `L`
-    number_integer  | -2147483648..-32769               | int32       | `l`
-    number_integer  | -32768..-129                      | int16       | `I`
-    number_integer  | -128..127                         | int8        | `i`
-    number_integer  | 128..255                          | uint8       | `U`
-    number_integer  | 256..32767                        | int16       | `I`
-    number_integer  | 32768..2147483647                 | int32       | `l`
-    number_integer  | 2147483648..9223372036854775807   | int64       | `L`
-    number_unsigned | 0..127                            | int8        | `i`
-    number_unsigned | 128..255                          | uint8       | `U`
-    number_unsigned | 256..32767                        | int16       | `I`
-    number_unsigned | 32768..2147483647                 | int32       | `l`
-    number_unsigned | 2147483648..9223372036854775807   | int64       | `L`
-    number_unsigned | 2147483649..18446744073709551615  | high-precision | `H`
-    number_float    | *any value*                       | float64     | `D`
-    string          | *with shortest length indicator*  | string      | `S`
-    array           | *see notes on optimized format*   | array       | `[`
-    object          | *see notes on optimized format*   | map         | `{`
-          can be converted to a UBJSON value.
-    @note The following values can **not** be converted to a UBJSON value:
-          - strings with more than 9223372036854775807 bytes (theoretical)
-    @note The following markers are not used in the conversion:
-          - `Z`: no-op values are not created.
-          - `C`: single-byte strings are serialized with `S` markers.
-    @note Any UBJSON output created @ref to_ubjson can be successfully parsed
-          by @ref from_ubjson.
-    @note The optimized formats for containers are supported: Parameter
-          @a use_size adds size information to the beginning of a container and
-          removes the closing marker. Parameter @a use_type further checks
-          whether all elements of a container have the same type and adds the
-          type marker to the beginning of the container. The @a use_type
-          parameter must only be used together with @a use_size = true. Note
-          that @a use_size = true alone may result in larger representations -
-          the benefit of this parameter is that the receiving side is
-          immediately informed on the number of elements of the container.
-    @note If the JSON data contains the binary type, the value stored is a list
-          of integers, as suggested by the UBJSON documentation.  In particular,
-          this means that serialization and the deserialization of a JSON
-          containing binary values into UBJSON and back will result in a
-          different JSON object.
-    @param[in] use_size  whether to add size annotations to container types
-    @param[in] use_type  whether to add type annotations to container types
-                         (must be combined with @a use_size = true)
-    @return UBJSON serialization as byte vector
-    vector in UBJSON format.,to_ubjson}
-    @sa http://ubjson.org
-    @sa @ref from_ubjson(detail::input_adapter&&, const bool, const bool) for the
-    @since version 3.1.0
-    static std::vector<uint8_t> to_ubjson(const basic_json& j,
-                                          const bool use_size = false,
-                                          const bool use_type = false)
+    /// @brief create a UBJSON serialization of a given JSON value
+    /// @sa https://json.nlohmann.me/api/basic_json/to_ubjson/
+    static std::vector<std::uint8_t> to_ubjson(const basic_json& j,
+            const bool use_size = false,
+            const bool use_type = false)
         to_ubjson(j, result, use_size, use_type);
         return result;
-    static void to_ubjson(const basic_json& j, detail::output_adapter<uint8_t> o,
+    static void to_ubjson(const basic_json& j, detail::output_adapter<std::uint8_t> o,
                           const bool use_size = false, const bool use_type = false)
-        binary_writer<uint8_t>(o).write_ubjson(j, use_size, use_type);
+        binary_writer<std::uint8_t>(o).write_ubjson(j, use_size, use_type);
     static void to_ubjson(const basic_json& j, detail::output_adapter<char> o,
         binary_writer<char>(o).write_ubjson(j, use_size, use_type);
-    @brief Serializes the given JSON object `j` to BSON and returns a vector
-           containing the corresponding BSON-representation.
-    BSON (Binary JSON) is a binary format in which zero or more ordered key/value pairs are
-    stored as a single entity (a so-called document).
-    The library uses the following mapping from JSON values types to BSON types:
-    JSON value type | value/range                       | BSON type   | marker
-    null            | `null`                            | null        | 0x0A
-    boolean         | `true`, `false`                   | boolean     | 0x08
-    number_integer  | -9223372036854775808..-2147483649 | int64       | 0x12
-    number_integer  | -2147483648..2147483647           | int32       | 0x10
-    number_integer  | 2147483648..9223372036854775807   | int64       | 0x12
-    number_unsigned | 0..2147483647                     | int32       | 0x10
-    number_unsigned | 2147483648..9223372036854775807   | int64       | 0x12
-    number_unsigned | 9223372036854775808..18446744073709551615| --   | --
-    number_float    | *any value*                       | double      | 0x01
-    string          | *any value*                       | string      | 0x02
-    array           | *any value*                       | document    | 0x04
-    object          | *any value*                       | document    | 0x03
-    binary          | *any value*                       | binary      | 0x05
-    @warning The mapping is **incomplete**, since only JSON-objects (and things
-    contained therein) can be serialized to BSON.
-    Also, integers larger than 9223372036854775807 cannot be serialized to BSON,
-    and the keys may not contain U+0000, since they are serialized a
-    zero-terminated c-strings.
-    @throw out_of_range.407  if `j.is_number_unsigned() && j.get<std::uint64_t>() > 9223372036854775807`
-    @throw out_of_range.409  if a key in `j` contains a NULL (U+0000)
-    @throw type_error.317    if `!j.is_object()`
-    @pre The input `j` is required to be an object: `j.is_object() == true`.
-    @note Any BSON output created via @ref to_bson can be successfully parsed
-          by @ref from_bson.
-    @return BSON serialization as byte vector
-    vector in BSON format.,to_bson}
-    @sa http://bsonspec.org/spec.html
-    @sa @ref from_bson(detail::input_adapter&&, const bool strict) for the
-    @sa @ref to_cbor(const basic_json&) for the related CBOR format
-    static std::vector<uint8_t> to_bson(const basic_json& j)
+    /// @brief create a BJData serialization of a given JSON value
+    /// @sa https://json.nlohmann.me/api/basic_json/to_bjdata/
+    static std::vector<std::uint8_t> to_bjdata(const basic_json& j,
+        to_bjdata(j, result, use_size, use_type);
+        return result;
+    static void to_bjdata(const basic_json& j, detail::output_adapter<std::uint8_t> o,
+                          const bool use_size = false, const bool use_type = false)
+        binary_writer<std::uint8_t>(o).write_ubjson(j, use_size, use_type, true, true);
+    static void to_bjdata(const basic_json& j, detail::output_adapter<char> o,
+        binary_writer<char>(o).write_ubjson(j, use_size, use_type, true, true);
+    /// @brief create a BSON serialization of a given JSON value
+    /// @sa https://json.nlohmann.me/api/basic_json/to_bson/
+    static std::vector<std::uint8_t> to_bson(const basic_json& j)
         to_bson(j, result);
         return result;
-    @brief Serializes the given JSON object `j` to BSON and forwards the
-           corresponding BSON-representation to the given output_adapter `o`.
-    @param j The JSON object to convert to BSON.
-    @param o The output adapter that receives the binary BSON representation.
-    @pre The input `j` shall be an object: `j.is_object() == true`
-    @sa @ref to_bson(const basic_json&)
-    static void to_bson(const basic_json& j, detail::output_adapter<uint8_t> o)
+    static void to_bson(const basic_json& j, detail::output_adapter<std::uint8_t> o)
-        binary_writer<uint8_t>(o).write_bson(j);
+        binary_writer<std::uint8_t>(o).write_bson(j);
-    @copydoc to_bson(const basic_json&, detail::output_adapter<uint8_t>)
     static void to_bson(const basic_json& j, detail::output_adapter<char> o)
         binary_writer<char>(o).write_bson(j);
-    @brief create a JSON value from an input in CBOR format
-    Deserializes a given input @a i to a JSON value using the CBOR (Concise
-    The library maps CBOR types to JSON value types as follows:
-    CBOR type              | JSON value type | first byte
-    Integer                | number_unsigned | 0x00..0x17
-    Unsigned integer       | number_unsigned | 0x18
-    Unsigned integer       | number_unsigned | 0x19
-    Unsigned integer       | number_unsigned | 0x1A
-    Unsigned integer       | number_unsigned | 0x1B
-    Negative integer       | number_integer  | 0x20..0x37
-    Negative integer       | number_integer  | 0x38
-    Negative integer       | number_integer  | 0x39
-    Negative integer       | number_integer  | 0x3A
-    Negative integer       | number_integer  | 0x3B
-    Byte string            | binary          | 0x40..0x57
-    Byte string            | binary          | 0x58
-    Byte string            | binary          | 0x59
-    Byte string            | binary          | 0x5A
-    Byte string            | binary          | 0x5B
-    UTF-8 string           | string          | 0x60..0x77
-    UTF-8 string           | string          | 0x78
-    UTF-8 string           | string          | 0x79
-    UTF-8 string           | string          | 0x7A
-    UTF-8 string           | string          | 0x7B
-    UTF-8 string           | string          | 0x7F
-    array                  | array           | 0x80..0x97
-    array                  | array           | 0x98
-    array                  | array           | 0x99
-    array                  | array           | 0x9A
-    array                  | array           | 0x9B
-    array                  | array           | 0x9F
-    map                    | object          | 0xA0..0xB7
-    map                    | object          | 0xB8
-    map                    | object          | 0xB9
-    map                    | object          | 0xBA
-    map                    | object          | 0xBB
-    map                    | object          | 0xBF
-    False                  | `false`         | 0xF4
-    True                   | `true`          | 0xF5
-    Null                   | `null`          | 0xF6
-    Half-Precision Float   | number_float    | 0xF9
-    Single-Precision Float | number_float    | 0xFA
-    Double-Precision Float | number_float    | 0xFB
-    @warning The mapping is **incomplete** in the sense that not all CBOR
-             types can be converted to a JSON value. The following CBOR types
-             are not supported and will yield parse errors (parse_error.112):
-             - bigfloat (0xC5)
-    @warning CBOR allows map keys of any type, whereas JSON only allows
-             strings as keys in object values. Therefore, CBOR maps with keys
-             other than UTF-8 strings are rejected (parse_error.113).
-    @note Any CBOR output created @ref to_cbor can be successfully parsed by
-          @ref from_cbor.
-    @param[in] i  an input in CBOR format convertible to an input adapter
-    @param[in] strict  whether to expect the input to be consumed until EOF
-                       (true by default)
-    @param[in] tag_handler how to treat CBOR tags (optional, error by default)
-    @throw parse_error.110 if the given input ends prematurely or the end of
-    file was not reached when @a strict was set to true
-    @throw parse_error.112 if unsupported features from CBOR were
-    used in the given input @a v or if the input is not valid CBOR
-    @throw parse_error.113 if a string was expected as map key, but not found
-    @complexity Linear in the size of the input @a i.
-    @liveexample{The example shows the deserialization of a byte vector in CBOR
-    format to a JSON value.,from_cbor}
-    @sa @ref to_cbor(const basic_json&) for the analogous serialization
-    @sa @ref from_msgpack(detail::input_adapter&&, const bool, const bool) for the
-        related MessagePack format
-    @since version 2.0.9; parameter @a start_index since 2.1.1; changed to
-           consume input adapters, removed start_index parameter, and added
-           @a strict parameter since 3.0.0; added @a allow_exceptions parameter
-           since 3.2.0; added @a tag_handler parameter since 3.9.0.
+    /// @brief create a JSON value from an input in CBOR format
+    /// @sa https://json.nlohmann.me/api/basic_json/from_cbor/
     static basic_json from_cbor(InputType&& i,
@@ -24110,13 +23669,12 @@ class basic_json
         basic_json result;
         detail::json_sax_dom_parser<basic_json> sdp(result, allow_exceptions);
-        const bool res = binary_reader<decltype(ia)>(std::move(ia)).sax_parse(input_format_t::cbor, &sdp, strict, tag_handler);
+        const bool res = binary_reader<decltype(ia)>(std::move(ia), input_format_t::cbor).sax_parse(input_format_t::cbor, &sdp, strict, tag_handler);
         return res ? result : basic_json(value_t::discarded);
-    @copydoc from_cbor(detail::input_adapter&&, const bool, const bool, const cbor_tag_handler_t)
     static basic_json from_cbor(IteratorType first, IteratorType last,
@@ -24127,7 +23685,7 @@ class basic_json
         basic_json result;
@@ -24142,7 +23700,6 @@ class basic_json
         return from_cbor(ptr, ptr + len, strict, allow_exceptions, tag_handler);
     JSON_HEDLEY_DEPRECATED_FOR(3.8.0, from_cbor(ptr, ptr + len))
     static basic_json from_cbor(detail::span_input_adapter&& i,
@@ -24153,96 +23710,13 @@ class basic_json
         basic_json result;
         auto ia = i.get();
-    @brief create a JSON value from an input in MessagePack format
-    Deserializes a given input @a i to a JSON value using the MessagePack
-    The library maps MessagePack types to JSON value types as follows:
-    MessagePack type | JSON value type | first byte
-    positive fixint  | number_unsigned | 0x00..0x7F
-    fixmap           | object          | 0x80..0x8F
-    fixarray         | array           | 0x90..0x9F
-    fixstr           | string          | 0xA0..0xBF
-    nil              | `null`          | 0xC0
-    false            | `false`         | 0xC2
-    true             | `true`          | 0xC3
-    float 32         | number_float    | 0xCA
-    float 64         | number_float    | 0xCB
-    uint 8           | number_unsigned | 0xCC
-    uint 16          | number_unsigned | 0xCD
-    uint 32          | number_unsigned | 0xCE
-    uint 64          | number_unsigned | 0xCF
-    int 8            | number_integer  | 0xD0
-    int 16           | number_integer  | 0xD1
-    int 32           | number_integer  | 0xD2
-    int 64           | number_integer  | 0xD3
-    str 8            | string          | 0xD9
-    str 16           | string          | 0xDA
-    str 32           | string          | 0xDB
-    array 16         | array           | 0xDC
-    array 32         | array           | 0xDD
-    map 16           | object          | 0xDE
-    map 32           | object          | 0xDF
-    bin 8            | binary          | 0xC4
-    bin 16           | binary          | 0xC5
-    bin 32           | binary          | 0xC6
-    ext 8            | binary          | 0xC7
-    ext 16           | binary          | 0xC8
-    ext 32           | binary          | 0xC9
-    fixext 1         | binary          | 0xD4
-    fixext 2         | binary          | 0xD5
-    fixext 4         | binary          | 0xD6
-    fixext 8         | binary          | 0xD7
-    fixext 16        | binary          | 0xD8
-    negative fixint  | number_integer  | 0xE0-0xFF
-    @param[in] i  an input in MessagePack format convertible to an input
-                  adapter
-                       (true by default)
-    @throw parse_error.112 if unsupported features from MessagePack were
-    used in the given input @a i or if the input is not valid MessagePack
-    MessagePack format to a JSON value.,from_msgpack}
-    @sa @ref to_msgpack(const basic_json&) for the analogous serialization
-        related CBOR format
-        the related UBJSON format
-    @sa @ref from_bson(detail::input_adapter&&, const bool, const bool) for
-        the related BSON format
-           since 3.2.0
+    /// @brief create a JSON value from an input in MessagePack format
+    /// @sa https://json.nlohmann.me/api/basic_json/from_msgpack/
     static basic_json from_msgpack(InputType&& i,
@@ -24252,13 +23726,12 @@ class basic_json
         basic_json result;
-        const bool res = binary_reader<decltype(ia)>(std::move(ia)).sax_parse(input_format_t::msgpack, &sdp, strict);
+        const bool res = binary_reader<decltype(ia)>(std::move(ia), input_format_t::msgpack).sax_parse(input_format_t::msgpack, &sdp, strict);
-    @copydoc from_msgpack(detail::input_adapter&&, const bool, const bool)
     static basic_json from_msgpack(IteratorType first, IteratorType last,
@@ -24268,11 +23741,10 @@ class basic_json
         basic_json result;
     template<typename T>
     JSON_HEDLEY_DEPRECATED_FOR(3.8.0, from_msgpack(ptr, ptr + len))
@@ -24292,73 +23764,13 @@ class basic_json
         basic_json result;
         auto ia = i.get();
-    @brief create a JSON value from an input in UBJSON format
-    Deserializes a given input @a i to a JSON value using the UBJSON (Universal
-    Binary JSON) serialization format.
-    The library maps UBJSON types to JSON value types as follows:
-    UBJSON type | JSON value type                         | marker
-    no-op       | *no value, next value is read*          | `N`
-    null        | `null`                                  | `Z`
-    false       | `false`                                 | `F`
-    true        | `true`                                  | `T`
-    float32     | number_float                            | `d`
-    float64     | number_float                            | `D`
-    uint8       | number_unsigned                         | `U`
-    int8        | number_integer                          | `i`
-    int16       | number_integer                          | `I`
-    int32       | number_integer                          | `l`
-    int64       | number_integer                          | `L`
-    high-precision number | number_integer, number_unsigned, or number_float - depends on number string | 'H'
-    string      | string                                  | `S`
-    char        | string                                  | `C`
-    array       | array (optimized values are supported)  | `[`
-    object      | object (optimized values are supported) | `{`
-    @note The mapping is **complete** in the sense that any UBJSON value can
-          be converted to a JSON value.
-    @param[in] i  an input in UBJSON format convertible to an input adapter
-                       (true by default)
-    @throw parse_error.112 if a parse error occurs
-    @throw parse_error.113 if a string could not be parsed successfully
-    UBJSON format to a JSON value.,from_ubjson}
-             analogous serialization
-        the related MessagePack format
-    @since version 3.1.0; added @a allow_exceptions parameter since 3.2.0
+    /// @brief create a JSON value from an input in UBJSON format
+    /// @sa https://json.nlohmann.me/api/basic_json/from_ubjson/
     static basic_json from_ubjson(InputType&& i,
@@ -24368,13 +23780,12 @@ class basic_json
         basic_json result;
-        const bool res = binary_reader<decltype(ia)>(std::move(ia)).sax_parse(input_format_t::ubjson, &sdp, strict);
+        const bool res = binary_reader<decltype(ia)>(std::move(ia), input_format_t::ubjson).sax_parse(input_format_t::ubjson, &sdp, strict);
-    @copydoc from_ubjson(detail::input_adapter&&, const bool, const bool)
     static basic_json from_ubjson(IteratorType first, IteratorType last,
@@ -24384,7 +23795,7 @@ class basic_json
         basic_json result;
@@ -24407,71 +23818,43 @@ class basic_json
         basic_json result;
         auto ia = i.get();
+    /// @brief create a JSON value from an input in BJData format
+    /// @sa https://json.nlohmann.me/api/basic_json/from_bjdata/
+    template<typename InputType>
+    JSON_HEDLEY_WARN_UNUSED_RESULT
+    static basic_json from_bjdata(InputType&& i,
+                                  const bool strict = true,
+                                  const bool allow_exceptions = true)
+        basic_json result;
+        detail::json_sax_dom_parser<basic_json> sdp(result, allow_exceptions);
+        auto ia = detail::input_adapter(std::forward<InputType>(i));
+        const bool res = binary_reader<decltype(ia)>(std::move(ia), input_format_t::bjdata).sax_parse(input_format_t::bjdata, &sdp, strict);
+        return res ? result : basic_json(value_t::discarded);
-    @brief Create a JSON value from an input in BSON format
+    template<typename IteratorType>
+    static basic_json from_bjdata(IteratorType first, IteratorType last,
+        auto ia = detail::input_adapter(std::move(first), std::move(last));
-    Deserializes a given input @a i to a JSON value using the BSON (Binary JSON)
-    The library maps BSON record types to JSON value types as follows:
-    BSON type       | BSON marker byte | JSON value type
-    double          | 0x01             | number_float
-    string          | 0x02             | string
-    document        | 0x03             | object
-    array           | 0x04             | array
-    binary          | 0x05             | binary
-    undefined       | 0x06             | still unsupported
-    ObjectId        | 0x07             | still unsupported
-    boolean         | 0x08             | boolean
-    UTC Date-Time   | 0x09             | still unsupported
-    null            | 0x0A             | null
-    Regular Expr.   | 0x0B             | still unsupported
-    DB Pointer      | 0x0C             | still unsupported
-    JavaScript Code | 0x0D             | still unsupported
-    Symbol          | 0x0E             | still unsupported
-    JavaScript Code | 0x0F             | still unsupported
-    int32           | 0x10             | number_integer
-    Timestamp       | 0x11             | still unsupported
-    128-bit decimal float | 0x13       | still unsupported
-    Max Key         | 0x7F             | still unsupported
-    Min Key         | 0xFF             | still unsupported
-    @warning The mapping is **incomplete**. The unsupported mappings
-             are indicated in the table above.
-    @param[in] i  an input in BSON format convertible to an input adapter
-                       (true by default)
-    @throw parse_error.114 if an unsupported BSON record type is encountered
-    BSON format to a JSON value.,from_bson}
-    @sa @ref to_bson(const basic_json&) for the analogous serialization
+    /// @brief create a JSON value from an input in BSON format
+    /// @sa https://json.nlohmann.me/api/basic_json/from_bson/
     static basic_json from_bson(InputType&& i,
@@ -24481,13 +23864,12 @@ class basic_json
         basic_json result;
-        const bool res = binary_reader<decltype(ia)>(std::move(ia)).sax_parse(input_format_t::bson, &sdp, strict);
+        const bool res = binary_reader<decltype(ia)>(std::move(ia), input_format_t::bson).sax_parse(input_format_t::bson, &sdp, strict);
-    @copydoc from_bson(detail::input_adapter&&, const bool, const bool)
     static basic_json from_bson(IteratorType first, IteratorType last,
@@ -24497,7 +23879,7 @@ class basic_json
         basic_json result;
@@ -24520,7 +23902,8 @@ class basic_json
         basic_json result;
         auto ia = i.get();
@@ -24532,180 +23915,64 @@ class basic_json
     /// @name JSON Pointer functions
-    @brief access specified element via JSON Pointer
-    Uses a JSON pointer to retrieve a reference to the respective JSON value.
-    No bound checking is performed. Similar to @ref operator[](const typename
-    object_t::key_type&), `null` values are created in arrays and objects if
-    necessary.
-    In particular:
-    - If the JSON pointer points to an object key that does not exist, it
-      is created an filled with a `null` value before a reference to it
-      is returned.
-    - If the JSON pointer points to an array index that does not exist, it
-      is returned. All indices between the current maximum and the given
-      index are also filled with `null`.
-    - The special value `-` is treated as a synonym for the index past the
-      end.
-    @param[in] ptr  a JSON pointer
-    @return reference to the element pointed to by @a ptr
-    @throw parse_error.106   if an array index begins with '0'
-    @throw parse_error.109   if an array index was not a number
-    @throw out_of_range.404  if the JSON pointer can not be resolved
-    @liveexample{The behavior is shown in the example.,operatorjson_pointer}
-    @since version 2.0.0
+    /// @brief access specified element via JSON Pointer
+    /// @sa https://json.nlohmann.me/api/basic_json/operator%5B%5D/
     reference operator[](const json_pointer& ptr)
         return ptr.get_unchecked(this);
+    template<typename BasicJsonType, detail::enable_if_t<detail::is_basic_json<BasicJsonType>::value, int> = 0>
+    JSON_HEDLEY_DEPRECATED_FOR(3.11.0, basic_json::json_pointer or nlohmann::json_pointer<basic_json::string_t>) // NOLINT(readability/alt_tokens)
+    reference operator[](const ::nlohmann::json_pointer<BasicJsonType>& ptr)
+        return ptr.get_unchecked(this);
-    No bound checking is performed. The function does not change the JSON
-    value; no `null` values are created. In particular, the special value
-    `-` yields an exception.
-    @param[in] ptr  JSON pointer to the desired element
-    @return const reference to the element pointed to by @a ptr
-    @throw out_of_range.402  if the array index '-' is used
-    @liveexample{The behavior is shown in the example.,operatorjson_pointer_const}
     const_reference operator[](const json_pointer& ptr) const
+    const_reference operator[](const ::nlohmann::json_pointer<BasicJsonType>& ptr) const
-    Returns a reference to the element at with specified JSON pointer @a ptr,
-    with bounds checking.
-    @throw parse_error.106 if an array index in the passed JSON pointer @a ptr
-    begins with '0'. See example below.
-    @throw parse_error.109 if an array index in the passed JSON pointer @a ptr
-    is not a number. See example below.
-    @throw out_of_range.401 if an array index in the passed JSON pointer @a ptr
-    is out of range. See example below.
-    @throw out_of_range.402 if the array index '-' is used in the passed JSON
-    pointer @a ptr. As `at` provides checked access (and no elements are
-    implicitly inserted), the index '-' is always invalid. See example below.
-    @throw out_of_range.403 if the JSON pointer describes a key of an object
-    which cannot be found. See example below.
-    @throw out_of_range.404 if the JSON pointer @a ptr can not be resolved.
-    See example below.
-    @exceptionsafety Strong guarantee: if an exception is thrown, there are no
-    changes in the JSON value.
-    @liveexample{The behavior is shown in the example.,at_json_pointer}
+    /// @sa https://json.nlohmann.me/api/basic_json/at/
     reference at(const json_pointer& ptr)
         return ptr.get_checked(this);
+    reference at(const ::nlohmann::json_pointer<BasicJsonType>& ptr)
+        return ptr.get_checked(this);
-    Returns a const reference to the element at with specified JSON pointer @a
-    ptr, with bounds checking.
-    @liveexample{The behavior is shown in the example.,at_json_pointer_const}
     const_reference at(const json_pointer& ptr) const
-    @brief return flattened JSON value
+    const_reference at(const ::nlohmann::json_pointer<BasicJsonType>& ptr) const
-    The function creates a JSON object whose keys are JSON pointers (see [RFC
-    6901](https://tools.ietf.org/html/rfc6901)) and whose values are all
-    primitive. The original JSON value can be restored using the @ref
-    unflatten() function.
-    @return an object that maps JSON pointers to primitive values
-    @note Empty objects and arrays are flattened to `null` and will not be
-          reconstructed correctly by the @ref unflatten() function.
-    @complexity Linear in the size the JSON value.
-    @liveexample{The following code shows how a JSON object is flattened to an
-    object whose keys consist of JSON pointers.,flatten}
-    @sa @ref unflatten() for the reverse function
+    /// @brief return flattened JSON value
+    /// @sa https://json.nlohmann.me/api/basic_json/flatten/
     basic_json flatten() const
         basic_json result(value_t::object);
@@ -24713,36 +23980,8 @@ class basic_json
         return result;
-    @brief unflatten a previously flattened JSON value
-    The function restores the arbitrary nesting of a JSON value that has been
-    flattened before using the @ref flatten() function. The JSON value must
-    meet certain constraints:
-    1. The value must be an object.
-    2. The keys must be JSON pointers (see
-       [RFC 6901](https://tools.ietf.org/html/rfc6901))
-    3. The mapped values must be primitive JSON types.
-    @return the original JSON from a flattened version
-    @note Empty objects and arrays are flattened by @ref flatten() to `null`
-          values and can not unflattened to their original type. Apart from
-          this example, for a JSON value `j`, the following is always true:
-          `j == j.flatten().unflatten()`.
-    @throw type_error.314  if value is not an object
-    @throw type_error.315  if object values are not primitive
-    @liveexample{The following code shows how a flattened JSON object is
-    unflattened into the original nested JSON object.,unflatten}
-    @sa @ref flatten() for the reverse function
+    /// @brief unflatten a previously flattened JSON value
+    /// @sa https://json.nlohmann.me/api/basic_json/unflatten/
     basic_json unflatten() const
         return json_pointer::unflatten(*this);
@@ -24757,58 +23996,11 @@ class basic_json
     /// @name JSON Patch functions
-    @brief applies a JSON patch
-    [JSON Patch](http://jsonpatch.com) defines a JSON document structure for
-    expressing a sequence of operations to apply to a JSON) document. With
-    this function, a JSON Patch is applied to the current JSON value by
-    executing all operations from the patch.
-    @param[in] json_patch  JSON patch document
-    @return patched document
-    @note The application of a patch is atomic: Either all operations succeed
-          and the patched document is returned or an exception is thrown. In
-          any case, the original value is not changed: the patch is applied
-          to a copy of the value.
-    @throw parse_error.104 if the JSON patch does not consist of an array of
-    objects
-    @throw parse_error.105 if the JSON patch is malformed (e.g., mandatory
-    attributes are missing); example: `"operation add must have member path"`
-    @throw out_of_range.401 if an array index is out of range.
-    @throw out_of_range.403 if a JSON pointer inside the patch could not be
-    resolved successfully in the current JSON value; example: `"key baz not
-    found"`
-    @throw out_of_range.405 if JSON pointer has no parent ("add", "remove",
-    "move")
-    @throw other_error.501 if "test" operation was unsuccessful
-    @complexity Linear in the size of the JSON value and the length of the
-    JSON patch. As usually only a fraction of the JSON value is affected by
-    the patch, the complexity can usually be neglected.
-    @liveexample{The following code shows how a JSON patch is applied to a
-    value.,patch}
-    @sa @ref diff -- create a JSON patch by comparing two JSON values
-    @sa [RFC 6902 (JSON Patch)](https://tools.ietf.org/html/rfc6902)
-    @sa [RFC 6901 (JSON Pointer)](https://tools.ietf.org/html/rfc6901)
-    basic_json patch(const basic_json& json_patch) const
+    /// @brief applies a JSON patch in-place without copying the object
+    /// @sa https://json.nlohmann.me/api/basic_json/patch/
+    void patch_inplace(const basic_json& json_patch)
-        // make a working copy to apply the patch to
-        basic_json result = *this;
+        basic_json& result = *this;
         // the valid JSON Patch operations
         enum class patch_operations {add, remove, replace, move, copy, test, invalid};
@@ -24853,7 +24045,7 @@ class basic_json
             // make sure the top element of the pointer exists
-            json_pointer top_pointer = ptr.top();
+            json_pointer const top_pointer = ptr.top();
             if (top_pointer != ptr)
                 result.at(top_pointer);
@@ -24862,9 +24054,10 @@ class basic_json
             // get reference to parent of JSON pointer ptr
             const auto last_path = ptr.back();
             ptr.pop_back();
-            basic_json& parent = result[ptr];
+            // parent must exist when performing patch add per RFC6902 specs
+            basic_json& parent = result.at(ptr);
-            switch (parent.m_type)
+            switch (parent.m_data.m_type)
                 case value_t::null:
@@ -24883,11 +24076,11 @@ class basic_json
                     else
-                        const auto idx = json_pointer::array_index(last_path);
+                        const auto idx = json_pointer::template array_index<basic_json_t>(last_path);
                         if (JSON_HEDLEY_UNLIKELY(idx > parent.size()))
                             // avoid undefined behavior
-                            JSON_THROW(out_of_range::create(401, "array index " + std::to_string(idx) + " is out of range"));
+                            JSON_THROW(out_of_range::create(401, detail::concat("array index ", std::to_string(idx), " is out of range"), &parent));
                         // default case: insert add offset
@@ -24897,13 +24090,20 @@ class basic_json
                 // if there exists a parent it cannot be primitive
+                case value_t::string: // LCOV_EXCL_LINE
+                case value_t::boolean: // LCOV_EXCL_LINE
+                case value_t::number_integer: // LCOV_EXCL_LINE
+                case value_t::number_unsigned: // LCOV_EXCL_LINE
+                case value_t::number_float: // LCOV_EXCL_LINE
+                case value_t::binary: // LCOV_EXCL_LINE
+                case value_t::discarded: // LCOV_EXCL_LINE
                 default:            // LCOV_EXCL_LINE
-                    JSON_ASSERT(false);  // LCOV_EXCL_LINE
+                    JSON_ASSERT(false); // NOLINT(cert-dcl03-c,hicpp-static-assert,misc-static-assert) LCOV_EXCL_LINE
         // wrapper for "remove" operation; remove value at ptr
-        const auto operation_remove = [&result](json_pointer & ptr)
+        const auto operation_remove = [this, & result](json_pointer & ptr)
@@ -24921,20 +24121,20 @@ class basic_json
                 else
-                    JSON_THROW(out_of_range::create(403, "key '" + last_path + "' not found"));
+                    JSON_THROW(out_of_range::create(403, detail::concat("key '", last_path, "' not found"), this));
             else if (parent.is_array())
                 // note erase performs range check
-                parent.erase(json_pointer::array_index(last_path));
+                parent.erase(json_pointer::template array_index<basic_json_t>(last_path));
         // type check: top level value must be an array
         if (JSON_HEDLEY_UNLIKELY(!json_patch.is_array()))
-            JSON_THROW(parse_error::create(104, 0, "JSON patch must be an array of objects"));
+            JSON_THROW(parse_error::create(104, 0, "JSON patch must be an array of objects", &json_patch));
         // iterate and apply the operations
@@ -24946,21 +24146,23 @@ class basic_json
                                           bool string_type) -> basic_json &
                 // find value
-                auto it = val.m_value.object->find(member);
+                auto it = val.m_data.m_value.object->find(member);
                 // context-sensitive error message
-                const auto error_msg = (op == "op") ? "operation" : "operation '" + op + "'";
+                const auto error_msg = (op == "op") ? "operation" : detail::concat("operation '", op, '\'');
                 // check if desired value is present
-                if (JSON_HEDLEY_UNLIKELY(it == val.m_value.object->end()))
+                if (JSON_HEDLEY_UNLIKELY(it == val.m_data.m_value.object->end()))
-                    JSON_THROW(parse_error::create(105, 0, error_msg + " must have member '" + member + "'"));
+                    // NOLINTNEXTLINE(performance-inefficient-string-concatenation)
+                    JSON_THROW(parse_error::create(105, 0, detail::concat(error_msg, " must have member '", member, "'"), &val));
                 // check if result is of type string
                 if (JSON_HEDLEY_UNLIKELY(string_type && !it->second.is_string()))
-                    JSON_THROW(parse_error::create(105, 0, error_msg + " must have string member '" + member + "'"));
+                    JSON_THROW(parse_error::create(105, 0, detail::concat(error_msg, " must have string member '", member, "'"), &val));
                 // no error: return value
@@ -24970,7 +24172,7 @@ class basic_json
             // type check: every element of the array must be an object
             if (JSON_HEDLEY_UNLIKELY(!val.is_object()))
+                JSON_THROW(parse_error::create(104, 0, "JSON patch must be an array of objects", &val));
             // collect mandatory members
@@ -25005,7 +24207,7 @@ class basic_json
                     json_pointer from_ptr(from_path);
                     // the "from" location must exist - use at()
-                    basic_json v = result.at(from_ptr);
+                    basic_json const v = result.at(from_ptr);
                     // The move operation is functionally identical to a
                     // "remove" operation on the "from" location, followed
@@ -25022,7 +24224,7 @@ class basic_json
                     const json_pointer from_ptr(from_path);
                     // The copy is functionally identical to an "add"
                     // operation at the target location using the value
@@ -25048,57 +24250,34 @@ class basic_json
                     // throw an exception if test fails
                     if (JSON_HEDLEY_UNLIKELY(!success))
-                        JSON_THROW(other_error::create(501, "unsuccessful: " + val.dump()));
+                        JSON_THROW(other_error::create(501, detail::concat("unsuccessful: ", val.dump()), &val));
                     break;
+                case patch_operations::invalid:
                 default:
                     // op must be "add", "remove", "replace", "move", "copy", or
                     // "test"
-                    JSON_THROW(parse_error::create(105, 0, "operation value '" + op + "' is invalid"));
+                    JSON_THROW(parse_error::create(105, 0, detail::concat("operation value '", op, "' is invalid"), &val));
+    /// @brief applies a JSON patch to a copy of the current object
+    basic_json patch(const basic_json& json_patch) const
+        basic_json result = *this;
+        result.patch_inplace(json_patch);
         return result;
-    @brief creates a diff as a JSON patch
-    Creates a [JSON Patch](http://jsonpatch.com) so that value @a source can
-    be changed into the value @a target by calling @ref patch function.
-    @invariant For two JSON values @a source and @a target, the following code
-    yields always `true`:
-    @code {.cpp}
-    source.patch(diff(source, target)) == target;
-    @endcode
-    @note Currently, only `remove`, `add`, and `replace` operations are
-          generated.
-    @param[in] source  JSON value to compare from
-    @param[in] target  JSON value to compare against
-    @param[in] path    helper value to create JSON pointers
-    @return a JSON patch to convert the @a source to @a target
-    @complexity Linear in the lengths of @a source and @a target.
-    @liveexample{The following code shows how a JSON patch is created as a
-    diff for two JSON values.,diff}
-    @sa @ref patch -- apply a JSON patch
-    @sa @ref merge_patch -- apply a JSON Merge Patch
+    /// @brief creates a diff as a JSON patch
+    /// @sa https://json.nlohmann.me/api/basic_json/diff/
     static basic_json diff(const basic_json& source, const basic_json& target,
                            const std::string& path = "")
@@ -25131,12 +24310,12 @@ class basic_json
                 while (i < source.size() && i < target.size())
                     // recursive call to compare array values at index i
-                    auto temp_diff = diff(source[i], target[i], path + "/" + std::to_string(i));
+                    auto temp_diff = diff(source[i], target[i], detail::concat(path, '/', std::to_string(i)));
                     result.insert(result.end(), temp_diff.begin(), temp_diff.end());
                     ++i;
-                // i now reached the end of at least one array
+                // We now reached the end of at least one array
                 // in a second pass, traverse the remaining elements
                 // remove my remaining elements
@@ -25148,7 +24327,7 @@ class basic_json
                     result.insert(result.begin() + end_index, object(
                         {"op", "remove"},
-                        {"path", path + "/" + std::to_string(i)}
+                        {"path", detail::concat(path, '/', std::to_string(i))}
                     ++i;
@@ -25159,7 +24338,7 @@ class basic_json
                     result.push_back(
                         {"op", "add"},
-                        {"path", path + "/-"},
+                        {"path", detail::concat(path, "/-")},
                         {"value", target[i]}
                     ++i;
@@ -25174,12 +24353,12 @@ class basic_json
                 for (auto it = source.cbegin(); it != source.cend(); ++it)
                     // escape the key name to be used in a JSON patch
-                    const auto key = json_pointer::escape(it.key());
+                    const auto path_key = detail::concat(path, '/', detail::escape(it.key()));
                     if (target.find(it.key()) != target.end())
                         // recursive call to compare object values at key it
-                        auto temp_diff = diff(it.value(), target[it.key()], path + "/" + key);
+                        auto temp_diff = diff(it.value(), target[it.key()], path_key);
                     else
@@ -25187,7 +24366,7 @@ class basic_json
                         // found a key that is not in o -> remove it
                         result.push_back(object(
-                            {"op", "remove"}, {"path", path + "/" + key}
+                            {"op", "remove"}, {"path", path_key}
@@ -25198,10 +24377,10 @@ class basic_json
                     if (source.find(it.key()) == source.end())
                         // found a key that is not in this -> add it
                         result.push_back(
-                            {"op", "add"}, {"path", path + "/" + key},
+                            {"op", "add"}, {"path", path_key},
                             {"value", it.value()}
@@ -25210,6 +24389,14 @@ class basic_json
                 break;
+            case value_t::null:
             default:
                 // both primitive type: replace value
@@ -25223,7 +24410,6 @@ class basic_json
         return result;
@@ -25233,48 +24419,8 @@ class basic_json
     /// @name JSON Merge Patch functions
-    @brief applies a JSON Merge Patch
-    The merge patch format is primarily intended for use with the HTTP PATCH
-    method as a means of describing a set of modifications to a target
-    resource's content. This function applies a merge patch to the current
-    JSON value.
-    The function implements the following algorithm from Section 2 of
-    [RFC 7396 (JSON Merge Patch)](https://tools.ietf.org/html/rfc7396):
-    define MergePatch(Target, Patch):
-      if Patch is an Object:
-        if Target is not an Object:
-          Target = {} // Ignore the contents and set it to an empty Object
-        for each Name/Value pair in Patch:
-          if Value is null:
-            if Name exists in Target:
-              remove the Name/Value pair from Target
-          else:
-            Target[Name] = MergePatch(Target[Name], Value)
-        return Target
-      else:
-        return Patch
-    Thereby, `Target` is the current object; that is, the patch is applied to
-    the current value.
-    @param[in] apply_patch  the patch to apply
-    @complexity Linear in the lengths of @a patch.
-    @liveexample{The following code shows how a JSON Merge Patch is applied to
-    a JSON document.,merge_patch}
-    @sa [RFC 7396 (JSON Merge Patch)](https://tools.ietf.org/html/rfc7396)
-    @since version 3.0.0
+    /// @brief applies a JSON Merge Patch
+    /// @sa https://json.nlohmann.me/api/basic_json/merge_patch/
     void merge_patch(const basic_json& apply_patch)
         if (apply_patch.is_object())
@@ -25304,146 +24450,165 @@ class basic_json
- at brief user-defined to_string function for JSON values
-This function implements a user-defined to_string  for JSON objects.
- at param[in] j  a JSON object
- at return a std::string object
+/// @brief user-defined to_string function for JSON values
+/// @sa https://json.nlohmann.me/api/basic_json/to_string/
 NLOHMANN_BASIC_JSON_TPL_DECLARATION
 std::string to_string(const NLOHMANN_BASIC_JSON_TPL& j)
     return j.dump();
-} // namespace nlohmann
+inline namespace literals
+inline namespace json_literals
+/// @brief user-defined string literal for JSON values
+/// @sa https://json.nlohmann.me/api/basic_json/operator_literal_json/
+JSON_HEDLEY_NON_NULL(1)
+#if !defined(JSON_HEDLEY_GCC_VERSION) || JSON_HEDLEY_GCC_VERSION_CHECK(4,9,0)
+    inline nlohmann::json operator ""_json(const char* s, std::size_t n)
+#else
+    inline nlohmann::json operator "" _json(const char* s, std::size_t n)
+#endif
+    return nlohmann::json::parse(s, s + n);
+/// @brief user-defined string literal for JSON pointer
+/// @sa https://json.nlohmann.me/api/basic_json/operator_literal_json_pointer/
+    inline nlohmann::json::json_pointer operator ""_json_pointer(const char* s, std::size_t n)
+#else
+    inline nlohmann::json::json_pointer operator "" _json_pointer(const char* s, std::size_t n)
+#endif
+    return nlohmann::json::json_pointer(std::string(s, n));
+}  // namespace json_literals
+}  // namespace literals
+NLOHMANN_JSON_NAMESPACE_END
 // nonmember support //
-// specialization of std::swap, and std::hash
-namespace std
+namespace std // NOLINT(cert-dcl58-cpp)
-/// hash value for JSON objects
-template<>
-struct hash<nlohmann::json>
+/// @brief hash value for JSON objects
+/// @sa https://json.nlohmann.me/api/basic_json/std_hash/
+NLOHMANN_BASIC_JSON_TPL_DECLARATION
+struct hash<nlohmann::NLOHMANN_BASIC_JSON_TPL> // NOLINT(cert-dcl58-cpp)
-    @brief return a hash value for a JSON object
-    std::size_t operator()(const nlohmann::json& j) const
+    std::size_t operator()(const nlohmann::NLOHMANN_BASIC_JSON_TPL& j) const
         return nlohmann::detail::hash(j);
-/// specialization for std::less<value_t>
-/// @note: do not remove the space after '<',
-///        see https://github.com/nlohmann/json/pull/679
+// specialization for std::less<value_t>
 template<>
-struct less<::nlohmann::detail::value_t>
+struct less< ::nlohmann::detail::value_t> // do not remove the space after '<', see https://github.com/nlohmann/json/pull/679
     @brief compare two value_t enum values
-    bool operator()(nlohmann::detail::value_t lhs,
-                    nlohmann::detail::value_t rhs) const noexcept
+    bool operator()(::nlohmann::detail::value_t lhs,
+                    ::nlohmann::detail::value_t rhs) const noexcept
-        return nlohmann::detail::operator<(lhs, rhs);
+#if JSON_HAS_THREE_WAY_COMPARISON
+        return std::is_lt(lhs <=> rhs); // *NOPAD*
+#else
+        return ::nlohmann::detail::operator<(lhs, rhs);
+#endif
 // C++20 prohibit function specialization in the std namespace.
 #ifndef JSON_HAS_CPP_20
- at brief exchanges the values of two JSON objects
- at since version 1.0.0
-template<>
-inline void swap<nlohmann::json>(nlohmann::json& j1, nlohmann::json& j2) noexcept(
-    is_nothrow_move_constructible<nlohmann::json>::value&&
-    is_nothrow_move_assignable<nlohmann::json>::value
+/// @brief exchanges the values of two JSON objects
+/// @sa https://json.nlohmann.me/api/basic_json/std_swap/
+inline void swap(nlohmann::NLOHMANN_BASIC_JSON_TPL& j1, nlohmann::NLOHMANN_BASIC_JSON_TPL& j2) noexcept(  // NOLINT(readability-inconsistent-declaration-parameter-name, cert-dcl58-cpp)
+    is_nothrow_move_constructible<nlohmann::NLOHMANN_BASIC_JSON_TPL>::value&&                          // NOLINT(misc-redundant-expression,cppcoreguidelines-noexcept-swap,performance-noexcept-swap)
+    is_nothrow_move_assignable<nlohmann::NLOHMANN_BASIC_JSON_TPL>::value)
     j1.swap(j2);
 #endif
-} // namespace std
+}  // namespace std
- at brief user-defined string literal for JSON values
-This operator implements a user-defined string literal for JSON objects. It
-can be used by adding `"_json"` to a string literal and returns a JSON object
-if no parse error occurred.
- at param[in] s  a string representation of a JSON object
- at param[in] n  the length of string @a s
- at return a JSON object
-JSON_HEDLEY_NON_NULL(1)
-inline nlohmann::json operator "" _json(const char* s, std::size_t n)
-    return nlohmann::json::parse(s, s + n);
- at brief user-defined string literal for JSON pointer
-This operator implements a user-defined string literal for JSON Pointers. It
-can be used by adding `"_json_pointer"` to a string literal and returns a JSON pointer
-object if no parse error occurred.
- at param[in] s  a string representation of a JSON Pointer
- at return a JSON pointer object
- at since version 2.0.0
-inline nlohmann::json::json_pointer operator "" _json_pointer(const char* s, std::size_t n)
-    return nlohmann::json::json_pointer(std::string(s, n));
+#if JSON_USE_GLOBAL_UDLS
+    #if !defined(JSON_HEDLEY_GCC_VERSION) || JSON_HEDLEY_GCC_VERSION_CHECK(4,9,0)
+        using nlohmann::literals::json_literals::operator ""_json; // NOLINT(misc-unused-using-decls,google-global-names-in-headers)
+        using nlohmann::literals::json_literals::operator ""_json_pointer; //NOLINT(misc-unused-using-decls,google-global-names-in-headers)
+    #else
+        using nlohmann::literals::json_literals::operator "" _json; // NOLINT(misc-unused-using-decls,google-global-names-in-headers)
+        using nlohmann::literals::json_literals::operator "" _json_pointer; //NOLINT(misc-unused-using-decls,google-global-names-in-headers)
+    #endif
+#endif
 // #include <nlohmann/detail/macro_unscope.hpp>
+//     __ _____ _____ _____
+//  __|  |   __|     |   | |  JSON for Modern C++
+// |  |  |__   |  |  | | | |  version 3.11.3
+// |_____|_____|_____|_|___|  https://github.com/nlohmann/json
+// SPDX-FileCopyrightText: 2013-2023 Niels Lohmann <https://nlohmann.me>
+// SPDX-License-Identifier: MIT
-// restore GCC/clang diagnostic settings
-#if defined(__clang__) || defined(__GNUC__) || defined(__GNUG__)
-    #pragma GCC diagnostic pop
-#endif
+// restore clang diagnostic settings
+    #pragma clang diagnostic pop
 #endif
 // clean up
 #undef JSON_ASSERT
 #undef JSON_INTERNAL_CATCH
-#undef JSON_CATCH
 #undef JSON_THROW
-#undef JSON_TRY
 #undef JSON_PRIVATE_UNLESS_TESTED
-#undef JSON_HAS_CPP_14
-#undef JSON_HAS_CPP_17
 #undef NLOHMANN_BASIC_JSON_TPL_DECLARATION
 #undef JSON_EXPLICIT
+#undef NLOHMANN_CAN_CALL_STD_FUNC_IMPL
+#undef JSON_INLINE_VARIABLE
+#undef JSON_NO_UNIQUE_ADDRESS
+#undef JSON_DISABLE_ENUM_SERIALIZATION
+#undef JSON_USE_GLOBAL_UDLS
+#ifndef JSON_TEST_KEEP_MACROS
+    #undef JSON_CATCH
+    #undef JSON_TRY
+    #undef JSON_HAS_CPP_11
+    #undef JSON_HAS_CPP_14
+    #undef JSON_HAS_CPP_17
+    #undef JSON_HAS_CPP_20
+    #undef JSON_HAS_FILESYSTEM
+    #undef JSON_HAS_EXPERIMENTAL_FILESYSTEM
+    #undef JSON_HAS_THREE_WAY_COMPARISON
+    #undef JSON_HAS_RANGES
+    #undef JSON_HAS_STATIC_RTTI
+    #undef JSON_USE_LEGACY_DISCARDED_VALUE_COMPARISON
+#endif
 // #include <nlohmann/thirdparty/hedley/hedley_undef.hpp>
 #undef JSON_HEDLEY_ALWAYS_INLINE
@@ -25479,6 +24644,7 @@ inline nlohmann::json::json_pointer operator "" _json_pointer(const char* s, std
 #undef JSON_HEDLEY_DIAGNOSTIC_DISABLE_DEPRECATED
 #undef JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNKNOWN_CPP_ATTRIBUTES
 #undef JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNKNOWN_PRAGMAS
+#undef JSON_HEDLEY_DIAGNOSTIC_DISABLE_UNUSED_FUNCTION
 #undef JSON_HEDLEY_DIAGNOSTIC_POP
 #undef JSON_HEDLEY_DIAGNOSTIC_PUSH
 #undef JSON_HEDLEY_DMC_VERSION
@@ -25530,6 +24696,8 @@ inline nlohmann::json::json_pointer operator "" _json_pointer(const char* s, std
 #undef JSON_HEDLEY_IS_CONSTEXPR_
 #undef JSON_HEDLEY_LIKELY
 #undef JSON_HEDLEY_MALLOC
+#undef JSON_HEDLEY_MCST_LCC_VERSION
+#undef JSON_HEDLEY_MCST_LCC_VERSION_CHECK
 #undef JSON_HEDLEY_MESSAGE
 #undef JSON_HEDLEY_MSVC_VERSION
 #undef JSON_HEDLEY_MSVC_VERSION_CHECK
hooks/post-receive
More information about the geos-commits mailing list
