[geos-commits] [SCM] GEOS branch main updated. 1e4d0b01fe307b347fb629793baf8488146d041b
Tue Mar 18 13:02:24 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  1e4d0b01fe307b347fb629793baf8488146d041b (commit)
      from  969b0019dbadf2095e21fa2a868cbf1e6e3b5ff8 (commit)
revisions in full, below.
commit 1e4d0b01fe307b347fb629793baf8488146d041b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Mar 18 13:01:55 2025 -0700
    Use shorter class names where possible in CAPI
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index ace450b49..d7545469d 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -194,6 +194,8 @@ using geos::geom::PrecisionModel;
 using geos::geom::SimpleCurve;
 using geos::geom::Surface;
+using geos::geom::prep::PreparedGeometry;
 using geos::io::WKTReader;
 using geos::io::WKTWriter;
 using geos::io::WKBReader;
@@ -2069,8 +2071,6 @@ extern "C" {
     int
     GEOSGeomGetM_r(GEOSContextHandle_t extHandle, const Geometry* g1, double* m)
-        using geos::geom::Point;
         return execute(extHandle, 0, [&]() {
             const Point* po = dynamic_cast<const Point*>(g1);
             if(!po) {
@@ -3252,8 +3252,6 @@ extern "C" {
     GEOSGeom_setPrecision_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g,
                             double gridSize, int flags)
-        using namespace geos::geom;
         return execute(extHandle, [&]() {
             PrecisionModel newpm;
             if(gridSize != 0) {
@@ -3286,8 +3284,6 @@ extern "C" {
     double
     GEOSGeom_getPrecision_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g)
         return execute(extHandle, -1.0, [&]() {
             const PrecisionModel* pm = g->getPrecisionModel();
             double cursize = pm->isFloating() ? 0 : 1.0 / pm->getScale();
@@ -3382,10 +3378,8 @@ extern "C" {
     Geometry*
     GEOSSimplify_r(GEOSContextHandle_t extHandle, const Geometry* g1, double tolerance)
-        using namespace geos::simplify;
-            Geometry::Ptr g3(DouglasPeuckerSimplifier::simplify(g1, tolerance));
+            Geometry::Ptr g3(geos::simplify::DouglasPeuckerSimplifier::simplify(g1, tolerance));
             g3->setSRID(g1->getSRID());
             return g3.release();
@@ -3394,10 +3388,8 @@ extern "C" {
     Geometry*
     GEOSTopologyPreserveSimplify_r(GEOSContextHandle_t extHandle, const Geometry* g1, double tolerance)
-            Geometry::Ptr g3(TopologyPreservingSimplifier::simplify(g1, tolerance));
+            Geometry::Ptr g3(geos::simplify::TopologyPreservingSimplifier::simplify(g1, tolerance));
@@ -3752,7 +3744,7 @@ extern "C" {
 // Prepared Geometry
-    const geos::geom::prep::PreparedGeometry*
+    const PreparedGeometry*
     GEOSPrepare_r(GEOSContextHandle_t extHandle, const Geometry* g)
@@ -3761,7 +3753,7 @@ extern "C" {
     void
-    GEOSPreparedGeom_destroy_r(GEOSContextHandle_t extHandle, const geos::geom::prep::PreparedGeometry* a)
+    GEOSPreparedGeom_destroy_r(GEOSContextHandle_t extHandle, const PreparedGeometry* a)
             delete a;
@@ -3770,7 +3762,7 @@ extern "C" {
     char
     GEOSPreparedContains_r(GEOSContextHandle_t extHandle,
-                           const geos::geom::prep::PreparedGeometry* pg, const Geometry* g)
+                           const PreparedGeometry* pg, const Geometry* g)
         return execute(extHandle, 2, [&]() {
             return pg->contains(g);
@@ -3779,7 +3771,7 @@ extern "C" {
     char
     GEOSPreparedContainsXY_r(GEOSContextHandle_t extHandle,
-                           const geos::geom::prep::PreparedGeometry* pg, double x, double y)
+                           const PreparedGeometry* pg, double x, double y)
         extHandle->point2d->setXY(x, y);
@@ -3788,7 +3780,7 @@ extern "C" {
     char
     GEOSPreparedContainsProperly_r(GEOSContextHandle_t extHandle,
             return pg->containsProperly(g);
@@ -3797,7 +3789,7 @@ extern "C" {
     char
     GEOSPreparedCoveredBy_r(GEOSContextHandle_t extHandle,
             return pg->coveredBy(g);
@@ -3806,7 +3798,7 @@ extern "C" {
     char
     GEOSPreparedCovers_r(GEOSContextHandle_t extHandle,
             return pg->covers(g);
@@ -3815,7 +3807,7 @@ extern "C" {
     char
     GEOSPreparedCrosses_r(GEOSContextHandle_t extHandle,
             return pg->crosses(g);
@@ -3824,7 +3816,7 @@ extern "C" {
     char
     GEOSPreparedDisjoint_r(GEOSContextHandle_t extHandle,
             return pg->disjoint(g);
@@ -3833,7 +3825,7 @@ extern "C" {
     char
     GEOSPreparedIntersects_r(GEOSContextHandle_t extHandle,
             return pg->intersects(g);
@@ -3842,7 +3834,7 @@ extern "C" {
     char
     GEOSPreparedIntersectsXY_r(GEOSContextHandle_t extHandle,
@@ -3851,7 +3843,7 @@ extern "C" {
     char
     GEOSPreparedOverlaps_r(GEOSContextHandle_t extHandle,
             return pg->overlaps(g);
@@ -3860,7 +3852,7 @@ extern "C" {
     char
     GEOSPreparedTouches_r(GEOSContextHandle_t extHandle,
             return pg->touches(g);
@@ -3869,7 +3861,7 @@ extern "C" {
     char
     GEOSPreparedWithin_r(GEOSContextHandle_t extHandle,
             return pg->within(g);
@@ -3878,7 +3870,7 @@ extern "C" {
     char *
     GEOSPreparedRelate_r(GEOSContextHandle_t extHandle,
         return execute(extHandle, [&]() -> char * {
             return gstrdup(pg->relate(g)->toString());
@@ -3887,7 +3879,7 @@ extern "C" {
     char
     GEOSPreparedRelatePattern_r(GEOSContextHandle_t extHandle,
-                         const geos::geom::prep::PreparedGeometry* pg, const Geometry* g, const char* imPattern)
+                         const PreparedGeometry* pg, const Geometry* g, const char* imPattern)
             return pg->relate(g, std::string(imPattern));
@@ -3896,18 +3888,16 @@ extern "C" {
     CoordinateSequence*
     GEOSPreparedNearestPoints_r(GEOSContextHandle_t extHandle,
-        return execute(extHandle, [&]() -> CoordinateSequence* {
+        return execute(extHandle, [&]() -> geos::geom::CoordinateSequence* {
             return pg->nearestPoints(g).release();
     int
     GEOSPreparedDistance_r(GEOSContextHandle_t extHandle,
                          const Geometry* g, double* dist)
@@ -3918,7 +3908,7 @@ extern "C" {
     char
     GEOSPreparedDistanceWithin_r(GEOSContextHandle_t extHandle,
                          const Geometry* g, double dist)
@@ -3952,7 +3942,7 @@ extern "C" {
     void
     GEOSSTRtree_insert_r(GEOSContextHandle_t extHandle,
                          GEOSSTRtree* tree,
-                         const geos::geom::Geometry* g,
+                         const Geometry* g,
                          void* item)
@@ -3963,7 +3953,7 @@ extern "C" {
     void
     GEOSSTRtree_query_r(GEOSContextHandle_t extHandle,
                         GEOSSTRtree* tree,
                         GEOSQueryCallback callback,
                         void* userdata)
@@ -3976,7 +3966,7 @@ extern "C" {
     const GEOSGeometry*
     GEOSSTRtree_nearest_r(GEOSContextHandle_t extHandle,
                           GEOSSTRtree* tree,
-                          const geos::geom::Geometry* geom)
+                          const Geometry* geom)
         return (const GEOSGeometry*) GEOSSTRtree_nearest_generic_r(extHandle, tree, geom, geom, nullptr, nullptr);
@@ -3985,12 +3975,10 @@ extern "C" {
     GEOSSTRtree_nearest_generic_r(GEOSContextHandle_t extHandle,
                                   GEOSSTRtree* tree,
                                   const void* item,
-                                  const geos::geom::Geometry* itemEnvelope,
+                                  const Geometry* itemEnvelope,
                                   GEOSDistanceCallback distancefn,
                                   void* userdata)
-        using namespace geos::index::strtree;
         struct CustomItemDistance {
             CustomItemDistance(GEOSDistanceCallback p_distancefn, void* p_userdata)
                 : m_distancefn(p_distancefn), m_userdata(p_userdata) {}
@@ -4042,7 +4030,7 @@ extern "C" {
     char
     GEOSSTRtree_remove_r(GEOSContextHandle_t extHandle,
                          GEOSSTRtree* tree,
                          void* item) {
             return tree->remove(g->getEnvelopeInternal(), item);
@@ -4064,7 +4052,7 @@ extern "C" {
                   const Geometry* p)
-            const geos::geom::Point* point = dynamic_cast<const geos::geom::Point*>(p);
+            const Point* point = dynamic_cast<const Point*>(p);
             if(!point) {
                 throw std::runtime_error("third argument of GEOSProject_r must be Point");
@@ -4130,13 +4118,10 @@ extern "C" {
     GEOSGeom_extractUniquePoints_r(GEOSContextHandle_t extHandle,
-        using namespace geos::util;
             /* 1: extract points */
             std::vector<const Coordinate*> coords;
-            UniqueCoordinateArrayFilter filter(coords);
+            geos::util::UniqueCoordinateArrayFilter filter(coords);
             g->apply_ro(&filter);
             /* 2: for each point, create a geometry and put into a vector */
@@ -4161,20 +4146,18 @@ extern "C" {
     int GEOSOrientationIndex_r(GEOSContextHandle_t extHandle,
                                double Ax, double Ay, double Bx, double By, double Px, double Py)
-        using geos::algorithm::Orientation;
             Coordinate A(Ax, Ay);
             Coordinate B(Bx, By);
             Coordinate P(Px, Py);
-            return Orientation::index(A, B, P);
+            return geos::algorithm::Orientation::index(A, B, P);
     GEOSGeometry*
     GEOSSharedPaths_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g1, const GEOSGeometry* g2)
-        using namespace geos::operation::sharedpaths;
+        using geos::operation::sharedpaths::SharedPathsOp;
         if(nullptr == extHandle) {
             return nullptr;
@@ -4245,10 +4228,8 @@ extern "C" {
     GEOSSnap_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g1,
                const GEOSGeometry* g2, double tolerance)
-        using namespace geos::operation::overlay::snap;
-            GeometrySnapper snapper(*g1);
+            geos::operation::overlay::snap::GeometrySnapper snapper(*g1);
             std::unique_ptr<Geometry> ret = snapper.snapTo(*g2, tolerance);
             ret->setSRID(g1->getSRID());
             return ret.release();
Summary of changes:
 capi/geos_ts_c.cpp | 87 +++++++++++++++++++++---------------------------------
 1 file changed, 34 insertions(+), 53 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
