[geos-commits] [SCM] GEOS branch main updated. 4ae3f0536735923dc93d6ea8a1e0dadafc791af1
    git at osgeo.org
    git at osgeo.org
    Fri May  2 10:02:43 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  4ae3f0536735923dc93d6ea8a1e0dadafc791af1 (commit)
      from  06f74885cb1fd6790bd9286ee2cd8433a349b890 (commit)
revisions in full, below.
commit 4ae3f0536735923dc93d6ea8a1e0dadafc791af1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri May 2 10:01:48 2025 -0700
    Add MaximumInscribedCircle fast exact calculation for simple shapes, port of https://github.com/locationtech/jts/pull/1123
diff --git a/include/geos/algorithm/Angle.h b/include/geos/algorithm/Angle.h
index a2ea53a48..164c89844 100644
--- a/include/geos/algorithm/Angle.h
+++ b/include/geos/algorithm/Angle.h
@@ -147,6 +147,19 @@ public:
                                        const geom::CoordinateXY& tail,
                                        const geom::CoordinateXY& tip2);
+    /// Computes the angle of the unoriented bisector
+    /// of the smallest angle between two vectors.
+    /// The computed angle will be in the range (-Pi, Pi].
+    /// @param tip1 the tip of v1
+    /// @param tail the tail of each vector
+    /// @param tip2 the tip of v2
+    /// @return the angle of the bisector between v1 and v2
+    static double bisector(const geom::CoordinateXY& tip1,
+                           const geom::CoordinateXY& tail,
+                           const geom::CoordinateXY& tip2);
     /// Computes the interior angle between two segments of a ring.
     /// The ring is assumed to be oriented in a clockwise direction.
@@ -230,7 +243,6 @@ public:
     /// @param rCos the result of cos(ang)
     static inline void sinCosSnap(const double ang, double& rSin, double& rCos) {
-        // calculate both; may be optimized with FSINCOS instruction
         rSin = std::sin(ang);
         rCos = std::cos(ang);
         // snap near-zero values
@@ -238,6 +250,16 @@ public:
         if (std::fabs(rCos) < 5e-16) rCos = 0.0;
+    /// Projects a point by a given angle and distance.
+    /// @param p the point to project
+    /// @param angle the angle at which to project
+    /// @param dist the distance to project
+    /// @return the projected point
+    static geom::CoordinateXY project(const geom::CoordinateXY& p,
+        double angle, double dist);
diff --git a/include/geos/algorithm/construct/ExactMaxInscribedCircle.h b/include/geos/algorithm/construct/ExactMaxInscribedCircle.h
new file mode 100644
index 000000000..d41866ef6
--- /dev/null
+++ b/include/geos/algorithm/construct/ExactMaxInscribedCircle.h
@@ -0,0 +1,122 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (c) 2020 Martin Davis
+ * Copyright (C) 2020 Paul Ramsey <pramsey at cleverelephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: algorithm/construct/ExactMaxInscribedCircle.java
+ * https://github.com/locationtech/jts/commit/8d5ced1b784d232e1eecf5df4b71873e8822336a
+#pragma once
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/LineSegment.h>
+#include <array>
+// #include <queue>
+namespace geos {
+namespace geom {
+class CoordinateSequence;
+class Geometry;
+class Polygon;
+namespace geos {
+namespace algorithm { // geos::algorithm
+namespace construct { // geos::algorithm::construct
+ * Computes the Maximum Inscribed Circle for some kinds of convex polygons.
+ * It determines the circle center point by computing Voronoi node points
+ * and testing them for distance to generating edges.
+ * This is more precise than iterated approximation,
+ * and faster for small polygons (such as triangles and convex quadrilaterals).
+ * @author Martin Davis
+class GEOS_DLL ExactMaxInscribedCircle {
+    using CoordinateSequence = geos::geom::CoordinateSequence;
+    using CoordinateXY = geos::geom::CoordinateXY;
+    using LineSegment = geos::geom::LineSegment;
+    using Polygon = geos::geom::Polygon;
+public:
+    ExactMaxInscribedCircle();
+     * Tests whether a given geometry is supported by this class.
+     * Currently only triangles and convex quadrilaterals are supported.
+     * @param geom an areal geometry
+     * @return true if the geometry shape can be evaluated
+    static bool isSupported(const geom::Geometry* geom);
+    static std::pair<CoordinateXY, CoordinateXY> computeRadius(const Polygon* polygon);
+private:
+    static bool isTriangle(const Polygon* polygon);
+    static bool isQuadrilateral(const Polygon* polygon);
+    static std::pair<CoordinateXY, CoordinateXY> computeTriangle(const CoordinateSequence* ring);
+     * The Voronoi nodes of a convex polygon occur at the intersection point
+     * of two bisectors of each triplet of edges.
+     * The Maximum Inscribed Circle center is the node
+     * is the farthest distance from the generating edges.
+     * For a quadrilateral there are 4 distinct edge triplets,
+     * at each edge with its adjacent edges.
+     * @param ring the polygon ring
+     * @return an array containing the incircle center and radius points
+    static std::pair<CoordinateXY, CoordinateXY> computeConvexQuadrilateral(const CoordinateSequence* ring);
+    static std::array<LineSegment, 4> computeBisectors(const CoordinateSequence* ptsCW,
+                                                       double diameter);
+    static CoordinateXY nearestEdgePt(const CoordinateSequence* ring,
+                                      const CoordinateXY& pt);
+    static LineSegment computeConvexBisector(const CoordinateSequence* pts,
+                                             std::size_t index, double len);
+    static bool isConvex(const Polygon* polygon);
+    static bool isConvex(const CoordinateSequence* ring);
+    static bool isConvex(const CoordinateXY& p0,
+                         const CoordinateXY& p1,
+                         const CoordinateXY& p2);
+    static bool isPointInConvexRing(const CoordinateSequence* ringCW,
+                                const CoordinateXY& p);
+} // geos::algorithm::construct
+} // geos
diff --git a/include/geos/algorithm/construct/MaximumInscribedCircle.h b/include/geos/algorithm/construct/MaximumInscribedCircle.h
index af4260c49..17d2a88a3 100644
--- a/include/geos/algorithm/construct/MaximumInscribedCircle.h
+++ b/include/geos/algorithm/construct/MaximumInscribedCircle.h
@@ -139,6 +139,8 @@ private:
     double distanceToBoundary(const geom::Point& pt);
     double distanceToBoundary(double x, double y);
     void compute();
+    void computeApproximation();
+    void createResult(const geom::CoordinateXY& c, const geom::CoordinateXY& r);
     /* private class */
     class Cell {
diff --git a/include/geos/geom/Triangle.h b/include/geos/geom/Triangle.h
index 663f50ec5..0f54cb9ee 100644
--- a/include/geos/geom/Triangle.h
+++ b/include/geos/geom/Triangle.h
@@ -45,6 +45,11 @@ public:
     void inCentre(CoordinateXY& resultPoint);
+    static CoordinateXY inCentre(
+        const CoordinateXY& p0,
     /** \brief
      * Computes the circumcentre of a triangle.
diff --git a/src/algorithm/Angle.cpp b/src/algorithm/Angle.cpp
index 7069607f5..f9e176768 100644
--- a/src/algorithm/Angle.cpp
+++ b/src/algorithm/Angle.cpp
@@ -118,6 +118,19 @@ Angle::angleBetweenOriented(const geom::CoordinateXY& tip1,
     return angDel;
+/* public static */
+double
+Angle::bisector(const geom::CoordinateXY& tip1,
+    double angDel = angleBetweenOriented(tip1, tail, tip2);
+    double angBi = angle(tail, tip1) + angDel / 2;
+    return normalize(angBi);
 /* public static */
 double
 Angle::interiorAngle(const geom::CoordinateXY& p0, const geom::CoordinateXY& p1,
@@ -187,20 +200,32 @@ Angle::diff(double ang1, double ang2)
     double delAngle;
-    if(ang1 < ang2) {
+    if (ang1 < ang2) {
         delAngle = ang2 - ang1;
     else {
         delAngle = ang1 - ang2;
-    if(delAngle > MATH_PI) {
+    if (delAngle > MATH_PI) {
         delAngle = PI_TIMES_2 - delAngle;
     return delAngle;
+geom::CoordinateXY
+Angle::project(const geom::CoordinateXY& p, double angle, double dist)
+    double cosSnap, sinSnap;
+    sinCosSnap(angle, sinSnap, cosSnap);
+    double x = p.x + dist * cosSnap;
+    double y = p.y + dist * sinSnap;
+    return geom::CoordinateXY(x, y);
 } // namespace geos.algorithm
 } //namespace geos
diff --git a/src/algorithm/construct/ExactMaxInscribedCircle.cpp b/src/algorithm/construct/ExactMaxInscribedCircle.cpp
index 000000000..561133af4
--- /dev/null
+++ b/src/algorithm/construct/ExactMaxInscribedCircle.cpp
@@ -0,0 +1,267 @@
+#include <geos/algorithm/construct/ExactMaxInscribedCircle.h>
+#include <geos/algorithm/Angle.h>
+#include <geos/algorithm/Orientation.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/LinearRing.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/Triangle.h>
+#include <geos/util/IllegalArgumentException.h>
+#include <typeinfo> // for dynamic_cast
+using namespace geos::geom;
+namespace geos {
+namespace algorithm { // geos.algorithm
+namespace construct { // geos.algorithm.construct
+bool
+ExactMaxInscribedCircle::isSupported(const Geometry* geom)
+    /* isSimplePolygon() */
+    /* TODO replace with geometryid test */
+    const Polygon* polygon = dynamic_cast<const Polygon*>(geom);
+    if (polygon == nullptr)
+        return false;
+    if (polygon->getNumInteriorRing() > 0)
+        return false;
+    if (isTriangle(polygon))
+        return true;
+    if (isQuadrilateral(polygon) && isConvex(polygon))
+        return true;
+    return false;
+/* private static */
+bool
+ExactMaxInscribedCircle::isTriangle(const Polygon* polygon)
+    return polygon->getNumPoints() == 4;
+bool
+ExactMaxInscribedCircle::isQuadrilateral(const Polygon* polygon)
+    return polygon->getNumPoints() == 5;
+std::pair<CoordinateXY, CoordinateXY>
+ExactMaxInscribedCircle::computeRadius(const Polygon* polygon)
+    const LinearRing* exRing = polygon->getExteriorRing();
+    const CoordinateSequence* ring = exRing->getCoordinatesRO();
+    if (exRing->getNumPoints() == 4)
+        return computeTriangle(ring);
+    else if (exRing->getNumPoints() == 5)
+        return computeConvexQuadrilateral(ring);
+    throw util::IllegalArgumentException("Input must be a triangle or convex quadrilateral");
+ExactMaxInscribedCircle::computeTriangle(const CoordinateSequence* ring)
+    CoordinateXY center = Triangle::inCentre(
+        ring->getAt(0), ring->getAt(1), ring->getAt(2));
+    LineSegment seg(ring->getAt(0), ring->getAt(1));
+    CoordinateXY radius = seg.project(center);
+    std::pair<CoordinateXY, CoordinateXY> result;
+    result.first = center;
+    result.second = radius;
+    return result;
+ExactMaxInscribedCircle::computeConvexQuadrilateral(const CoordinateSequence* ring)
+    /* Ensure ring is clockwise */
+    const CoordinateSequence* ringCW = ring;
+    std::unique_ptr<CoordinateSequence> ringPtr; // storage if we have to reverse
+    if (Orientation::isCCW(ring)) {
+        ringPtr = ring->clone();
+        ringPtr->reverse();
+        ringCW = ringPtr.get();
+    double diameter = ringCW->getEnvelope().getDiameter();
+    //-- compute corner bisectors
+    std::array<LineSegment, 4> bisector = computeBisectors(ringCW, diameter);
+    //-- compute nodes and find interior one farthest from sides
+    double maxDist = -1;
+    CoordinateXY center;
+    CoordinateXY radius;
+    for (std::size_t i = 0; i < 4; i++) {
+        LineSegment& b1 = bisector[i];
+        std::size_t i2 = (i + 1) % 4;
+        LineSegment& b2 = bisector[i2];
+        CoordinateXY nodePt = b1.intersection(b2);
+        //-- only interior nodes are considered
+        if (! isPointInConvexRing(ringCW, nodePt)) {
+            continue;
+        //-- check if node is further than current max center
+        CoordinateXY r = nearestEdgePt(ringCW, nodePt);
+        double dist = nodePt.distance(r);
+        if (maxDist < 0 || dist > maxDist) {
+            center = nodePt;
+            radius = r;
+            maxDist = dist;
+    return result;
+std::array<LineSegment, 4>
+ExactMaxInscribedCircle::computeBisectors(
+    const CoordinateSequence* ptsCW, double diameter)
+    std::array<LineSegment, 4> bisector;
+        bisector[i] = computeConvexBisector(ptsCW, i, diameter);
+    return bisector;
+CoordinateXY
+ExactMaxInscribedCircle::nearestEdgePt(const CoordinateSequence* ring,
+    CoordinateXY nearestPt;
+    CoordinateXY r;
+    double minDist = -1;
+    for (std::size_t i = 0; i < ring->size() - 1; i++) {
+        LineSegment edge(ring->getAt(i), ring->getAt(i + 1));
+        edge.closestPoint(pt, r);
+        double dist = pt.distance(r);
+        if (minDist < 0 || dist < minDist) {
+            minDist = dist;
+            nearestPt = r;
+    return nearestPt;
+LineSegment
+ExactMaxInscribedCircle::computeConvexBisector(
+    const CoordinateSequence* pts, std::size_t index, double len)
+    const CoordinateXY& basePt = pts->getAt(index);
+    std::size_t iPrev = index == 0 ? pts->size() - 2 : index - 1;
+    std::size_t iNext = index >= pts->size() ? 0 : index + 1;
+    const CoordinateXY& pPrev = pts->getAt(iPrev);
+    const CoordinateXY& pNext = pts->getAt(iNext);
+    if (! isConvex(pPrev, basePt, pNext))
+        throw util::IllegalArgumentException("Input is not convex");
+    double bisectAng = Angle::bisector(pPrev, basePt, pNext);
+    CoordinateXY endPt = Angle::project(basePt, bisectAng, len);
+    return LineSegment(basePt.x, basePt.y, endPt.x, endPt.y);
+bool
+ExactMaxInscribedCircle::isConvex(const Polygon* polygon)
+    const LinearRing* shell = polygon->getExteriorRing();
+    return isConvex(shell->getCoordinatesRO());
+bool
+ExactMaxInscribedCircle::isConvex(const CoordinateSequence* ring)
+     * A ring cannot be all concave, so if it has a consistent
+     * orientation it must be convex.
+    std::size_t n = ring->size();
+    if (n < 4)
+        return false;
+    int ringOrient = 0;
+    for (std::size_t i = 0; i < n - 1; i++) {
+        std::size_t i1 = i + 1;
+        std::size_t i2 = (i1 >= n - 1) ? 1 : i1 + 1;
+        int orient = Orientation::index(
+            ring->getAt(i),
+            ring->getAt(i1),
+            ring->getAt(i2));
+        if (orient == Orientation::COLLINEAR)
+            continue;
+        if (ringOrient == 0) {
+            ringOrient = orient;
+        else if (orient != ringOrient) {
+            return false;
+    return true;
+bool
+ExactMaxInscribedCircle::isConvex(const CoordinateXY& p0,
+    return Orientation::CLOCKWISE == Orientation::index(p0, p1, p2);
+bool
+ExactMaxInscribedCircle::isPointInConvexRing(const CoordinateSequence* ringCW,
+    for (std::size_t i = 0; i < ringCW->size() - 1; i++) {
+        const CoordinateXY& p0 = ringCW->getAt(i);
+        const CoordinateXY& p1 = ringCW->getAt(i + 1);
+        int orient = Orientation::index(p0, p1, p);
+        if (orient == Orientation::COUNTERCLOCKWISE)
+            return false;
+    return true;
+} // namespace geos.algorithm.construct
diff --git a/src/algorithm/construct/MaximumInscribedCircle.cpp b/src/algorithm/construct/MaximumInscribedCircle.cpp
index a8f83d1be..686b9aa30 100644
--- a/src/algorithm/construct/MaximumInscribedCircle.cpp
+++ b/src/algorithm/construct/MaximumInscribedCircle.cpp
@@ -18,6 +18,7 @@
 #include <geos/algorithm/construct/MaximumInscribedCircle.h>
 #include <geos/geom/Envelope.h>
@@ -174,10 +175,45 @@ MaximumInscribedCircle::createInteriorPointCell(const Geometry* geom)
 void
 MaximumInscribedCircle::compute()
     // check if already computed
     if (done) return;
+     * Handle empty or flat geometries.
+    if (inputGeom->getArea() == 0.0) {
+        const CoordinateXY* c = inputGeom->getCoordinate();
+        createResult(*c, *c);
+        return;
+     * Optimization for small simple convex polygons
+    if (ExactMaxInscribedCircle::isSupported(inputGeom)) {
+        auto polygonal = static_cast<const Polygon*>(inputGeom);
+        std::pair<CoordinateXY, CoordinateXY> centreRadius = ExactMaxInscribedCircle::computeRadius(polygonal);
+        createResult(centreRadius.first, centreRadius.second);
+        return;
+    computeApproximation();
+/* private */
+void MaximumInscribedCircle::createResult(
+    const CoordinateXY& c, const CoordinateXY& r)
+    centerPt = c;
+    radiusPt = r;
+/* private */
+void
+MaximumInscribedCircle::computeApproximation()
     // Priority queue of cells, ordered by maximum distance from boundary
     Cell::CellQueue cellQueue;
diff --git a/src/geom/Triangle.cpp b/src/geom/Triangle.cpp
index 90dad34cd..61241b127 100644
--- a/src/geom/Triangle.cpp
+++ b/src/geom/Triangle.cpp
@@ -51,6 +51,19 @@ Triangle::inCentre(CoordinateXY& result)
     result = CoordinateXY(inCentreX, inCentreY);
+CoordinateXY
+Triangle::inCentre(const CoordinateXY& p0,
+    Triangle tri(p0, p1, p2);
+    CoordinateXY result;
+    tri.inCentre(result);
+    return result;
 void
 Triangle::circumcentre(CoordinateXY& result)
diff --git a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
index dcab53cc8..4f10b0c29 100644
--- a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
+++ b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
@@ -119,8 +119,7 @@ group test_mic_group("geos::algorithm::construct::MaximumInscribedCircle");
 template<>
 template<>
-void object::test<1>
+void object::test<1> ()
     checkCircle("POLYGON ((100 200, 200 200, 200 100, 100 100, 100 200))",
                 0.001, 150, 150, 50);
@@ -131,8 +130,7 @@ void object::test<1>
 template<>
 template<>
-void object::test<2>
+void object::test<2> ()
     checkCircle("POLYGON ((150 250, 50 150, 150 50, 250 150, 150 250))",
                 0.001, 150, 150, 70.71 );
@@ -143,8 +141,7 @@ void object::test<2>
 template<>
 template<>
-void object::test<3>
+void object::test<3> ()
     std::unique_ptr<Geometry> geom(reader_.read("POINT (100 100)"));
     std::unique_ptr<Geometry> circle(geom->buffer(100, 20));
@@ -157,8 +154,7 @@ void object::test<3>
 template<>
 template<>
-void object::test<4>
+void object::test<4> ()
     checkCircle("MULTIPOLYGON (((150 200, 100 150, 150 100, 250 150, 150 200)), ((400 250, 300 150, 400 50, 560 150, 400 250)))",
        0.001, 411.38877, 149.9996185, 78.7634662 );
@@ -169,8 +165,7 @@ void object::test<4>
 template<>
 template<>
-void object::test<5>
+void object::test<5> ()
     checkCircle("POLYGON ((100 100, 200 200, 100 100, 100 100))",
        0.01, 100, 100, 0 );
@@ -182,8 +177,7 @@ void object::test<5>
 template<>
 template<>
-void object::test<6>
+void object::test<6> ()
      checkCircle("POLYGON ((100 100, 100 100, 100 100, 100 100))",
@@ -194,8 +188,7 @@ void object::test<6>
 template<>
 template<>
-void object::test<7>
+void object::test<7> ()
      checkCircle("POLYGON((1 2, 1 2, 1 2, 1 2, 3 2, 1 2))",
        0.01, 1, 2, 0 );
@@ -204,8 +197,7 @@ void object::test<7>
 // Exception thrown to avoid infinite loop with infinite envelope
 template<>
 template<>
-void object::test<8>
+void object::test<8> ()
     auto g1 = reader_.read("POLYGON ((0 0, 1 0, 1 1, 0 Inf, 0 0))");
     try {
@@ -232,8 +224,7 @@ void object::test<8>
 // testNearlyFlat
 template<>
 template<>
-void object::test<9>
+void object::test<9> ()
     checkCircle("POLYGON ((59.3 100.00000000000001, 99.7 100.00000000000001, 99.7 100, 59.3 100, 59.3 100.00000000000001))",
        0.01 );
@@ -242,8 +233,7 @@ void object::test<9>
 // testVeryThin
 template<>
 template<>
-void object::test<10>
+void object::test<10> ()
     checkCircle("POLYGON ((100 100, 200 300, 300 100, 450 250, 300 99.999999, 200 299.99999, 100 100))",
        0.01 );
@@ -254,12 +244,57 @@ void object::test<10>
 template<>
 template<>
-void object::test<11>
+void object::test<11> ()
     checkCircle("POLYGON((0 -10,-7.07107 -7.07107,-10 0,-7.07107 7.07107,0 10,7.07107 7.07107,10 0,7.07107 -7.07107,0 -10))",
         0.1, 0, 0, 9.2387);
+/* testTriangleRight() */
+template<>
+template<>
+void object::test<12> ()
+    checkCircle("POLYGON ((1 1, 1 9, 9 1, 1 1))",
+        0.001, 3.343, 3.343, 2.343 );
+/* testTriangleObtuse */
+template<>
+template<>
+void object::test<13> ()
+    checkCircle("POLYGON ((1 1, 1 9, 2 2, 1 1))",
+        0.01, 1.485, 2.173, 0.485 );
+/* testThinQuad */
+template<>
+template<>
+void object::test<14> ()
+    checkCircle("POLYGON ((1 2, 9 3, 9 1, 1 1, 1 2))",
+        0.001, 8.0623, 1.9377, 0.93774 );
+/* testChevron */
+template<>
+template<>
+void object::test<15> ()
+    checkCircle("POLYGON ((1 1, 6 9, 3.7 2.5, 9 1, 1 1))",
+        0.001, 2.82, 2.008, 1.008 );
+/* testChevronFat */
+template<>
+template<>
+void object::test<16> ()
+    checkCircle("POLYGON ((1 1, 6 9, 5.9 5, 9 1, 1 1))",
+        0.001, 4.7545, 3.0809, 2.081 );
 } // namespace tut
Summary of changes:
 include/geos/algorithm/Angle.h                     |  24 +-
 .../algorithm/construct/ExactMaxInscribedCircle.h  | 122 ++++++++++
 .../algorithm/construct/MaximumInscribedCircle.h   |   2 +
 include/geos/geom/Triangle.h                       |   5 +
 src/algorithm/Angle.cpp                            |  29 ++-
 .../construct/ExactMaxInscribedCircle.cpp          | 267 +++++++++++++++++++++
 src/algorithm/construct/MaximumInscribedCircle.cpp |  38 ++-
 src/geom/Triangle.cpp                              |  13 +
 .../construct/MaximumInscribedCircleTest.cpp       |  79 ++++--
 9 files changed, 553 insertions(+), 26 deletions(-)
 create mode 100644 include/geos/algorithm/construct/ExactMaxInscribedCircle.h
 create mode 100644 src/algorithm/construct/ExactMaxInscribedCircle.cpp
hooks/post-receive
More information about the geos-commits
