[geos-commits] [SCM] GEOS branch main updated. c11ff3c9917f2387bfbb34331db0021c2b59b3a3
Mon May 5 10:37:48 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  c11ff3c9917f2387bfbb34331db0021c2b59b3a3 (commit)
      from  553d99b24f474aec191d4d5c83e7a346dd7ee91f (commit)
revisions in full, below.
commit c11ff3c9917f2387bfbb34331db0021c2b59b3a3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon May 5 10:37:24 2025 -0700
    Confirm behaviour change against PostGIS test for MaximumInscribedCircle
diff --git a/src/algorithm/construct/ExactMaxInscribedCircle.cpp b/src/algorithm/construct/ExactMaxInscribedCircle.cpp
index 46ce08794..e4a030f41 100644
--- a/src/algorithm/construct/ExactMaxInscribedCircle.cpp
+++ b/src/algorithm/construct/ExactMaxInscribedCircle.cpp
@@ -47,10 +47,9 @@ bool
 ExactMaxInscribedCircle::isSupported(const Geometry* geom)
     /* isSimplePolygon() */
-    /* TODO replace with geometryid test */
-    const Polygon* polygon = dynamic_cast<const Polygon*>(geom);
-    if (polygon == nullptr)
+    if (geom->getGeometryTypeId() != GEOS_POLYGON)
         return false;
+    const Polygon* polygon = static_cast<const Polygon*>(geom);
     if (polygon->getNumInteriorRing() > 0)
         return false;
@@ -226,8 +225,8 @@ ExactMaxInscribedCircle::isConvex(const CoordinateSequence* ring)
         return false;
     int ringOrient = 0;
     for (std::size_t i = 0; i < n - 1; i++) {
-        std::size_t i1 = i + 1;
-        std::size_t i2 = (i1 >= n - 1) ? 1 : i1 + 1;
+        std::size_t i1 = (i + 1) % (n - 1);
+        std::size_t i2 = (i + 2) % (n - 1);
         int orient = Orientation::index(
             ring->getAt(i),
             ring->getAt(i1),
diff --git a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
index 7261e3374..b08561e32 100644
--- a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
+++ b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
@@ -304,6 +304,18 @@ void object::test<17> ()
         0.001, 5.0, 3.3431,  1.65685 );
+/* postgis mic-box test */
+template<>
+template<>
+void object::test<18> ()
+    checkCircle("Polygon((0 0, 100 0, 99 98, 0 100, 0 0))",
+        0.1, 49.5117, 49.5117, 49.47799 );
+//-mic-box|POINT(49.5117 49.5117)|POINT(50.5111 98.9796)|49.4779
+//+mic-box|POINT(49.495 49.495)|POINT(50.4947 98.9799)|49.4950
 } // namespace tut
Summary of changes:
 src/algorithm/construct/ExactMaxInscribedCircle.cpp          |  9 ++++-----
 .../unit/algorithm/construct/MaximumInscribedCircleTest.cpp  | 12 ++++++++++++
 2 files changed, 16 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
