[geos-commits] [SCM] GEOS branch 3.11 updated. 3eb40b554c9f9fa8f86c11064d10eb6deba4c463
    git at osgeo.org
    git at osgeo.org
    Mon May 26 14:10:08 PDT 2025
the project "GEOS".
The branch, 3.11 has been updated
       via  3eb40b554c9f9fa8f86c11064d10eb6deba4c463 (commit)
       via  8a03ecc783cf79c0a4dea3bba883b49b4dd4579a (commit)
      from  1a93fbe4f262fd196cdb153782366e8436fb630a (commit)
revisions in full, below.
commit 3eb40b554c9f9fa8f86c11064d10eb6deba4c463
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon May 26 14:09:46 2025 -0700
    Update NEWS
diff --git a/NEWS.md b/NEWS.md
index 1505d33d0..e545f4296 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -2,7 +2,7 @@
 2025-xx-xx
 - Fixes/Improvements:
+  - Fix DepthSegment comparison logic (really this time) (GH-1266, Martin Davis)
 ## Changes in 3.11.5
 2025-03-03
commit 8a03ecc783cf79c0a4dea3bba883b49b4dd4579a
Date:   Mon May 26 14:09:17 2025 -0700
diff --git a/src/operation/buffer/SubgraphDepthLocater.cpp b/src/operation/buffer/SubgraphDepthLocater.cpp
index 44d06c5ec..2ce65d368 100644
--- a/src/operation/buffer/SubgraphDepthLocater.cpp
+++ b/src/operation/buffer/SubgraphDepthLocater.cpp
@@ -70,8 +70,35 @@ public:
-     * Defines a comparision operation on DepthSegments
-     * which orders them left to right
+     * Compares a point to a segment for left/right position,
+     * as long as the point lies within the segment Y extent.
+     * Otherwise the point is not comparable.
+     * If the point is not comparable or it lies on the segment
+     * returns 0.
+    int
+    comparePointInYExtent(const Coordinate& p, const LineSegment& seg) const
+        //-- if point is comparable to segment
+        if (p.y >= seg.minY() && p.y <= seg.maxY()) {
+          //-- flip sign, since orientation and order relation are opposite
+          int orient = seg.orientationIndex(p);
+          switch (orient) {
+          case Orientation::LEFT: return -1;
+          case Orientation::RIGHT: return 1;
+          //-- collinear, so indeterminate
+        //-- not computable
+        return 0;
+     * A comparison operation which orders segments left to right
+     * along some horizontal line.
+     * If segments don't touch the same line,
+     * or touch at the same point,
+     * they are compared in their Y extent.
      * <pre>
      * DS1 < DS2   if   DS1.seg is left of DS2.seg
@@ -85,45 +112,60 @@ public:
     compareTo(const DepthSegment& other) const
-         * If segment envelopes do not overlap, then
-         * can use standard segment lexicographic ordering.
+         * If segments are disjoint in X, X values provides ordering.
+         * This is the most common case.
-        if (upwardSeg.minX() >= other.upwardSeg.maxX()
-            || upwardSeg.maxX() <= other.upwardSeg.minX()
-            || upwardSeg.minY() >= other.upwardSeg.maxY()
-            || upwardSeg.maxY() <= other.upwardSeg.minY()) {
-            return upwardSeg.compareTo(other.upwardSeg);
+        if (upwardSeg.minX() > other.upwardSeg.maxX())
+            return 1;
+        if (upwardSeg.maxX() < other.upwardSeg.minX())
+            return -1;
-         * Otherwise if envelopes overlap, use relative segment orientation.
-         * Collinear segments should be evaluated by previous logic
+         * The segments Y ranges should intersect since they lie on same stabbing line.
+         * But check for this and provide a result based on Y ordering
-        int orientIndex = upwardSeg.orientationIndex(&(other.upwardSeg));
-         * If comparison between this and other is indeterminate,
-         * try the opposite call order.
-         * orientationIndex value is 1 if this is left of other,
-         * so have to flip sign to get proper comparison value of
-         * -1 if this is leftmost
-        if(orientIndex == 0) {
-            orientIndex = -1 * other.upwardSeg.orientationIndex(&upwardSeg);
-        // if orientation is determinate, return it
-        if(orientIndex != 0) {
-            return orientIndex;
+        if (upwardSeg.minY() > other.upwardSeg.maxY())
+            return 1;
+        if (upwardSeg.maxY() < other.upwardSeg.minY())
+            return -1;
-         * If segment envelopes overlap and they are collinear,
-         * since segments do not cross they must be equal.
+         * Check if some segment point is left or right
+         * of the other segment in its Y extent.
+        int comp00 = comparePointInYExtent(upwardSeg.p0, other.upwardSeg);
+        if (comp00 != 0) return comp00;
+        int comp01 = comparePointInYExtent(upwardSeg.p1, other.upwardSeg);
+        if (comp01 != 0) return comp01;
+        //-- negate orientation for other/this checks
+        int comp10 = -comparePointInYExtent(other.upwardSeg.p0, upwardSeg);
+        if (comp10 != 0) return comp10;
+        int comp11 = -comparePointInYExtent(other.upwardSeg.p1, upwardSeg);
+        if (comp11 != 0) return comp11;
+         * If point checks in Y range are indeterminate,
+         * segments touch at a point
+         * and lie above and below that point, or are horizontal.
+         * Order according to their Y values.
+         * (The ordering in this case doesn't matter, it just has to be consistent)
+        if (upwardSeg.maxY() > other.upwardSeg.maxY())
+            return 1;
+        if (upwardSeg.maxY() < other.upwardSeg.maxY())
+            return -1;
+         * If both are horizontal order by X
+        if (upwardSeg.isHorizontal() && other.upwardSeg.isHorizontal()) {
+            if (upwardSeg.minX() < other.upwardSeg.minX())
+                return -1;
+            if (upwardSeg.minX() > other.upwardSeg.minX())
+                return 1;
         // assert: segments are equal
-        return 0;
+        return 0;
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index dff461b16..1103a0b46 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -660,4 +660,17 @@ void object::test<26>
         "POLYGON ((0.73 0.05, 0.67 -0.13, 0.58 -0.31, 0.46 -0.46, 0.31 -0.58, 0.13 -0.67, -0.05 -0.73, -0.25 -0.75, -0.75 -0.75, -0.95 -0.73, -1.13 -0.67, -1.31 -0.58, -1.46 -0.46, -1.58 -0.31, -1.67 -0.13, -1.73 0.05, -1.75 0.25, -1.75 0.75, -1.73 0.95, -1.67 1.13, -1.58 1.31, -1.46 1.46, -1.31 1.58, -1.13 1.67, -0.95 1.73, -0.75 1.75, -0.25 1.75, -0.05 1.73, 0.13 1.67, 0.31 1.58, 0.46 1.46, 0.58 1.31, 0.67 1.13, 0.73 0.95, 0.75 0.75, 0.75 0.25, 0.73 0.05))");
+// testBufferByZeroKeepsAllElements
+// Test a buffer-by-zero case which revealed a bug in the DeptSegment comparator.
+// See https://github.com/locationtech/jts/issues/1131
+template<>
+template<>
+void object::test<28>
+    std::string wkt = "MULTIPOLYGON (((24 95.239, 24 96, 24 99, 24.816 99, 24 95.239)), ((3 90, 3 93, 3 96, 3 99, 21 99, 21 96, 21 93, 21 90, 3 90)))";
+    checkBuffer(wkt, 0, 0.01,
+"MULTIPOLYGON (((24 95.239, 24 96, 24 99, 24.816 99, 24 95.239)), ((3 90, 3 93, 3 96, 3 99, 21 99, 21 96, 21 93, 21 90, 3 90)))");
 } // namespace tut
Summary of changes:
 NEWS.md                                       |   2 +-
 src/operation/buffer/SubgraphDepthLocater.cpp | 110 ++++++++++++++++++--------
 tests/unit/operation/buffer/BufferOpTest.cpp  |  13 +++
 3 files changed, 90 insertions(+), 35 deletions(-)
hooks/post-receive
More information about the geos-commits
