[geos-commits] [SCM] GEOS branch main updated. 93472ce0f6a02dd5dfcbf8e41eca4e75e714209f
Mon Nov 10 09:52:51 PST 2025
the project "GEOS".
The branch, main has been updated
       via  93472ce0f6a02dd5dfcbf8e41eca4e75e714209f (commit)
      from  b5960c3a08c3ccaffee019529f847dc02371a790 (commit)
revisions in full, below.
commit 93472ce0f6a02dd5dfcbf8e41eca4e75e714209f
Author: Daniel Baston <dbaston at gmail.com>
Date:   Mon Nov 10 12:52:28 2025 -0500
    Buffer: Ensure buffer of single-part returns single-part (#1323)
    * Buffer: Ensure buffer of single-part returns single-part
    * Buffer: Move location of fix for #1321
    * BufferOp: Add a test case
diff --git a/src/operation/buffer/BufferBuilder.cpp b/src/operation/buffer/BufferBuilder.cpp
index a5d423e9e..5cc5685d2 100644
--- a/src/operation/buffer/BufferBuilder.cpp
+++ b/src/operation/buffer/BufferBuilder.cpp
@@ -363,6 +363,25 @@ BufferBuilder::bufferLineSingleSided(const Geometry* g, double distance,
+static void
+keepLargestArea(std::vector<std::unique_ptr<Geometry>> & polyList) {
+    size_t maxAreaGeom = 0;
+    double maxArea = polyList[0]->getArea();
+    for (size_t i = 1; i < polyList.size(); i++) {
+        if (polyList[i]->getArea() > maxArea) {
+            maxArea = polyList[i]->getArea();
+            maxAreaGeom = i;
+    if (maxAreaGeom > 0) {
+        polyList[0] = std::move(polyList[maxAreaGeom]);
+    polyList.resize(1);
 /*public*/
 BufferBuilder::buffer(const Geometry* g, double distance)
@@ -485,9 +504,18 @@ BufferBuilder::buffer(const Geometry* g, double distance)
             return createEmptyResultGeometry();
+        //  Heuristic to remove artifacts caused by topology robustness problems
+        //  or buffer curve generation anomalies.
+        //  Uses fact that for distance > 0 single-element inputs must create single element buffers.
+        //  This does not hold if distance <= 0;
+        //  distance = 0 can create multipolygon results due to topology collapse,
+        //  and distance < 0 may erode polygons so they are disconnected.
+        if (distance > 0 && g->getNumGeometries() == 1 && resultPolyList.size() > 1) {
+            keepLargestArea(resultPolyList);
         // resultPolyList ownership transferred here
         resultGeom = geomFact->buildGeometry(std::move(resultPolyList));
     catch(const util::GEOSException& /* exc */) {
diff --git a/src/operation/buffer/BufferOp.cpp b/src/operation/buffer/BufferOp.cpp
index 379ca1d4d..0bdbbfdb7 100644
--- a/src/operation/buffer/BufferOp.cpp
+++ b/src/operation/buffer/BufferOp.cpp
@@ -116,6 +116,7 @@ BufferOp::getResultGeometry(double nDistance)
     distance = nDistance;
     computeGeometry();
     return std::unique_ptr<Geometry>(resultGeometry.release());
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index b51914ca8..7ac585ccc 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -598,7 +598,7 @@ void object::test<26>
 // testElementErodedEx
-// Checks that a skinny element polygon is eroded with no internal predicision reduction due to topo exes
+// Checks that a skinny element polygon is eroded with no internal precision reduction due to topo exes
 // see https://github.com/libgeos/geos/issues/1182
 template<>
 template<>
@@ -623,4 +623,43 @@ void object::test<28>
 "MULTIPOLYGON (((24 95.239, 24 96, 24 99, 24.816 99, 24 95.239)), ((3 90, 3 93, 3 96, 3 99, 21 99, 21 96, 21 93, 21 90, 3 90)))");
+template<>
+template<>
+void object::test<29>
+    set_test_name("GH-1321");
+    // Ensure positive buffer of LineString produces a single-part Polygon
+    // See https://github.com/libgeos/geos/issues/1321
+    std::string wkt = "LINESTRING(640770.332537465 216785.425146015,640770.356311913 216785.560172686,640770.475488952 216786.226162019,640770.647396495 216787.800152365,640770.658978918 216789.268376902,640770.447752096 216792.399898366,640769.98018796 216795.624688816,640769.110287021 216798.527305023,640767.648768098 216801.891389348,640766.02448565 216804.805892778,640764.74005588 216807.134569434,640763.337363474 216809.560477487,640761.650901703 216812.246990061,640759.955600712 216815.327305019,640758.482499366 216817.868732504,640757.383693167 216819.548488661,640756.238862077 216821.226720821,640754.01503683 216824.434442434,640751.366929134 216828.435255234,640749.204368809 216832.450088865,640747.25516891 216836.227787618,640746.014020829 216838.801219168,640745.393751588 216840.360274284,640744.315976633 216842.854457673,640743.400050801 216844.65704848,640742.582575565 216846.277673322,640741.52491745 216848.478638524,640740.503835408 216850.705816576,640739.787553975 2
 16852.270967708,640739.053289307 216853.851968469,640738.173025147 216855.546355058,640737.55488951 216856.568961104,640736.817272035 216857.822910812,640735.910795021 216859.35697228,640734.77510795 216861.236982439,640733.832969266 216862.938074642,640732.814325629 216865.039674844,640731.225095251 216869.012141189,640729.979984761 216871.879095724,640729.445974092 216873.02148841,640729.002794006 216873.679857725,640728.952197105 216873.745389857,640728.676962154 216874.089814544)";
+    auto bufGeom = wktreader.read(wkt)->buffer(100);
+    ensure_equals(bufGeom->getGeometryTypeId(), geos::geom::GEOS_POLYGON);
+    ensure(bufGeom->getArea() > 51000);
+template<>
+template<>
+void object::test<30>
+    set_test_name("sf-2552");
+    // See https://github.com/r-spatial/sf/issues/2552
+    std::string wkt = "LINESTRING (245184.6 6045650, 245193.3 6045649, 245201.7 6045651, 245204.3 6045653)";
+    auto geom = wktreader.read(wkt);
+    BufferOp bop(geom.get());
+    bop.setEndCapStyle(BufferParameters::CAP_SQUARE);
+    auto bufGeom = bop.getResultGeometry(50);
+    ensure(bufGeom->getArea() > 12000);
 } // namespace tut
diff --git a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
index 73a8a3dd1..83f3e9e45 100644
--- a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
+++ b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
@@ -45,7 +45,7 @@ struct test_dpsimp_data {
         ensure("Simplified geometry is invalid!", simplified->isValid());
         GeomPtr exp(wktreader.read(wkt_expected));
-        ensure_equals_geometry(exp.get(), simplified.get());
+        ensure_equals_geometry(simplified.get(), exp.get());
     void
Summary of changes:
 src/operation/buffer/BufferBuilder.cpp             | 30 +++++++++++++++-
 src/operation/buffer/BufferOp.cpp                  |  1 +
 tests/unit/operation/buffer/BufferOpTest.cpp       | 41 +++++++++++++++++++++-
 .../unit/simplify/DouglasPeuckerSimplifierTest.cpp |  2 +-
 4 files changed, 71 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
