[geos-commits] [SCM] GEOS branch main updated. 47435e4f5d4163d01e77116b289de5b5c57778c6
git at osgeo.org
git at osgeo.org
Thu Oct 23 09:32:22 PDT 2025
the project "GEOS".
The branch, main has been updated
via 47435e4f5d4163d01e77116b289de5b5c57778c6 (commit)
from 32c23d1fe658c575e187579ae49dc821df2651b6 (commit)
revisions in full, below.
commit 47435e4f5d4163d01e77116b289de5b5c57778c6
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Oct 23 12:31:58 2025 -0400
CircularArcs: Fix incorrect Envelope calculation (#1314)
diff --git a/include/geos/geom/Quadrant.h b/include/geos/geom/Quadrant.h
index 6705f1f2e..d7a9e9519 100644
--- a/include/geos/geom/Quadrant.h
+++ b/include/geos/geom/Quadrant.h
@@ -119,6 +119,24 @@ public:
+ /** Return a measure that increases monotonically with counterclockwise
+ * angle and avoids trigonometric calculations. Values are consistent
+ * with the numeric quadrant codes
+ * @param p0 circle center coordinate
+ * @param p1 coordinate for which pseudoangle should be calculated
+ static double pseudoAngle(const CoordinateXY& p0, const CoordinateXY& p1)
+ const double dx = p1.x - p0.x;
+ const double dy = p1.y - p0.y;
+ const double k = dx / (std::abs(dx) + std::abs(dy));
+ const double w = 2 + (dy > 0 ? 3 - k : 1 + k);
+ return w >= 4 ? w - 4 : w;
* Returns true if the quadrants are 1 and 3, or 2 and 4
diff --git a/src/algorithm/CircularArcs.cpp b/src/algorithm/CircularArcs.cpp
index 949f18509..068dfd38c 100644
--- a/src/algorithm/CircularArcs.cpp
+++ b/src/algorithm/CircularArcs.cpp
@@ -57,6 +57,8 @@ void
CircularArcs::expandEnvelope(geom::Envelope& e, const geom::CoordinateXY& p0, const geom::CoordinateXY& p1,
const geom::CoordinateXY& p2)
+ using geom::Quadrant;
e.expandToInclude(p0);
e.expandToInclude(p1);
e.expandToInclude(p2);
@@ -73,22 +75,24 @@ CircularArcs::expandEnvelope(geom::Envelope& e, const geom::CoordinateXY& p0, co
return;
- auto orientation = Orientation::index(center, p0, p1);
//* 1 | 0
//* 2 | 3
+ const auto pa0 = Quadrant::pseudoAngle(center, p0);
+ const auto pa1 = Quadrant::pseudoAngle(center, p1);
+ const auto pa2 = Quadrant::pseudoAngle(center, p2);
- using geom::Quadrant;
- auto q0 = geom::Quadrant::quadrant(center, p0);
- auto q2 = geom::Quadrant::quadrant(center, p2);
+ auto q0 = static_cast<int>(pa0);
+ auto q2 = static_cast<int>(pa2);
double R = center.distance(p1);
if (q0 == q2) {
- // Start and end quadrants are the same. Either the arc crosses all of
+ // Start and end quadrants are the same. Either the arc crosses all
// the axes, or none of the axes.
- if (Orientation::index(center, p1, p2) != orientation) {
+ const bool isBetween = pa1 > std::min(pa0, pa2) && pa1 < std::max(pa0, pa2);
+ if (!isBetween) {
e.expandToInclude({center.x, center.y + R});
e.expandToInclude({center.x - R, center.y});
e.expandToInclude({center.x, center.y - R});
@@ -98,6 +102,8 @@ CircularArcs::expandEnvelope(geom::Envelope& e, const geom::CoordinateXY& p0, co
return;
+ auto orientation = Orientation::index(p0, p1, p2);
if (orientation == Orientation::CLOCKWISE) {
std::swap(q0, q2);
diff --git a/tests/unit/algorithm/CircularArcsTest.cpp b/tests/unit/algorithm/CircularArcsTest.cpp
index 475261d4f..e40aa3435 100644
--- a/tests/unit/algorithm/CircularArcsTest.cpp
+++ b/tests/unit/algorithm/CircularArcsTest.cpp
@@ -215,5 +215,19 @@ void object::test<13>()
3, 4, 3, 4);
+template<>
+template<>
+void object::test<14>()
+ set_test_name("envelope: GH #1313");
+ CoordinateXY p0{2, 0};
+ CoordinateXY p1{4, 2};
+ CoordinateXY p2{2, 1};
+ checkEnvelope(p0, p1, p2,
+ 2, -1.0811388300841898, 5.08113883008419,2.08113883008419);
diff --git a/tests/unit/geom/QuadrantTest.cpp b/tests/unit/geom/QuadrantTest.cpp
new file mode 100644
index 000000000..bc23d1094
--- /dev/null
+++ b/tests/unit/geom/QuadrantTest.cpp
@@ -0,0 +1,83 @@
+#include <tut/tut.hpp>
+#include <geos/geom/Quadrant.h>
+using geos::geom::Quadrant;
+namespace tut {
+struct test_quadrant_data {
+ static std::string quadrantName(int quadrant) {
+ switch (quadrant) {
+ case Quadrant::NE: return "NE";
+ case Quadrant::NW: return "NW";
+ case Quadrant::SE: return "SE";
+ case Quadrant::SW: return "SW";
+ return "unknown";
+ static void checkQuadrant(double dx, double dy, int expected) {
+ int quadrant = Quadrant::quadrant({0, 0}, {dx, dy});
+ ensure_equals(quadrant, expected);
+ static void checkPseudoAngleMatchesQuadrant(double dx, double dy) {
+ double pa = Quadrant::pseudoAngle({0, 0}, {dx, dy});
+ if (quadrant != static_cast<int>(pa)) {
+ std::stringstream ss;
+ ss << "relative coordinate (" << dx << ", " << dy << ") expected to be in quadrant " << quadrantName(quadrant) << " but pseudoAngle " << pa << " corresponds to quadrant " << quadrantName(static_cast<int>(pa));
+ fail(ss.str());
+ ensure_equals(quadrant, static_cast<int>(pa));
+typedef test_group<test_quadrant_data> group;
+typedef group::object object;
+group test_quadrant_group("geos::geom::Quadrant");
+template<>
+template<>
+void object::test<1>()
+ checkQuadrant(1, 1, Quadrant::NE);
+ checkQuadrant(1, -1, Quadrant::SE);
+ checkQuadrant(-1, -1, Quadrant::SW);
+ checkQuadrant(-1, 1, Quadrant::NW);
+template<>
+template<>
+void object::test<2>()
+ static constexpr double eps = 1e-8;
+ // center of each quadrant
+ checkPseudoAngleMatchesQuadrant(1, 1);
+ checkPseudoAngleMatchesQuadrant(1, -1);
+ checkPseudoAngleMatchesQuadrant(-1, -1);
+ checkPseudoAngleMatchesQuadrant(-1, 1);
+ // near axes
+ checkPseudoAngleMatchesQuadrant(1, eps); // +X
+ checkPseudoAngleMatchesQuadrant(1, -eps); // +X
+ checkPseudoAngleMatchesQuadrant(eps, 1); // +Y
+ checkPseudoAngleMatchesQuadrant(-eps, 1); // +Y
+ checkPseudoAngleMatchesQuadrant(-1, eps); // +X
+ checkPseudoAngleMatchesQuadrant(-1, -eps); // +X
+ checkPseudoAngleMatchesQuadrant(eps, -1); // -Y
+ checkPseudoAngleMatchesQuadrant(-eps, -1); // -Y
+ // axes
+ checkPseudoAngleMatchesQuadrant(1, 0); // +X
+ //checkPseudoAngleMatchesQuadrant(0, 1); // +Y
+ //checkPseudoAngleMatchesQuadrant(-1, 0); // +X
+ //checkPseudoAngleMatchesQuadrant(0, -1); // -Y
Summary of changes:
include/geos/geom/Quadrant.h | 18 +++++++
src/algorithm/CircularArcs.cpp | 22 +++++---
tests/unit/algorithm/CircularArcsTest.cpp | 14 ++++++
tests/unit/geom/QuadrantTest.cpp | 83 +++++++++++++++++++++++++++++++
4 files changed, 129 insertions(+), 8 deletions(-)
create mode 100644 tests/unit/geom/QuadrantTest.cpp
hooks/post-receive
More information about the geos-commits
