[geos-commits] [SCM] GEOS branch main updated. c0d97ffcdfd2f5f175053ff1aa9b44df6baf49be
git at osgeo.org
git at osgeo.org
Thu Oct 23 10:27:05 PDT 2025
the project "GEOS".
The branch, main has been updated
via c0d97ffcdfd2f5f175053ff1aa9b44df6baf49be (commit)
from 47435e4f5d4163d01e77116b289de5b5c57778c6 (commit)
revisions in full, below.
commit c0d97ffcdfd2f5f175053ff1aa9b44df6baf49be
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Oct 23 13:26:44 2025 -0400
FAQ: Remove outdated content about M ordinates (#1318)
diff --git a/web/content/usage/faq/index.md b/web/content/usage/faq/index.md
index 5481744af..5ecc2fcd4 100644
--- a/web/content/usage/faq/index.md
+++ b/web/content/usage/faq/index.md
@@ -37,11 +37,6 @@ One way to perform geodetic computations is to project data to an appropriate pl
using a transformation library such as [PROJ](https://proj.org/).
The desired geometric operations can be computed in planar space, and reprojected back to geodetic.
-### Does GEOS support coordinates with measures (M)?
-No, the GEOS coordinate model only supports X,Y and Z ordinates.
-We hope to add support for M, and also a more efficient XY coordinate storage representation.
## Robustness
### Why does `GEOSIntersects(GEOSIntersection(A, B), A) == false`?
@@ -50,7 +45,7 @@ GEOS represents geometry coordinates using IEEE-754 double-precision floating po
This is a finite representation, whereas the implicit lines between vertices have infinite precision. In general it is highly unlikely that a coordinate computed via an arithmetic operation
(such as a line intersection) is reported by an `intersects` test as lying exactly on the (theoretical) lines.
-For example, the diagram below shows how the computed intersection point of two lines in general does not lie exactly on either line (scale exaggerrated for clarity):
+For example, the diagram below shows how the computed intersection point of two lines in general does not lie exactly on either line (scale exaggerated for clarity):
@@ -61,6 +56,6 @@ As explained in the previous question, GEOS uses finite-precision floating point
because in the general case it is not possible to represent points along a line exactly using finite-precision numbers.
The diagram below shows how points interpolated along a line rarely lie exactly on the line
-(scale exaggerrated for clarity):
+(scale exaggerated for clarity):
Summary of changes:
web/content/usage/faq/index.md | 9 ++-------
1 file changed, 2 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
