[geos-commits] [SCM] GEOS branch main updated. b5960c3a08c3ccaffee019529f847dc02371a790
Tue Oct 28 05:56:22 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  b5960c3a08c3ccaffee019529f847dc02371a790 (commit)
      from  eedd2c3059aa5445c72e8c74e6247e9013564bed (commit)
revisions in full, below.
commit b5960c3a08c3ccaffee019529f847dc02371a790
Author: Daniel Baston <dbaston at gmail.com>
Date:   Tue Oct 28 08:55:59 2025 -0400
    Add CircularArcIntersector (#1171)
    * Add CircularArcIntersector
    * CircularArcIntersector: Add tests with nearly-degenerate arcs
    * Angle: Fix impl of isWithinCCW and add tests
    * CircularArc: Add some tests
    * CircularArcIntersector: Add some tests from ILI validator project
    * CircularArcIntersector: Pull circle-segment intersection into own method
    * Arcs: Make CircularArc store its coordinates so we can construct it from a known radius and centerpoint
    * CircularArcs: fix orientation in createArc
    * CircularArc: Add splitAtPoint()
    * Add CircularArc::getSagitta
    * CircularArcIntersector: Add (but do not use) alternate formulation for intersection test
    * CircularArcIntersector: Relax assertions on expected points, disable 3 failing tests
diff --git a/include/geos/algorithm/Angle.h b/include/geos/algorithm/Angle.h
index 6f86f3d33..192891022 100644
--- a/include/geos/algorithm/Angle.h
+++ b/include/geos/algorithm/Angle.h
@@ -218,6 +218,15 @@ public:
     static double normalizePositive(double angle);
+    /// Returns true if angle x is within the counterclockwise
+    /// arc from angle a to angle b
+    /// @param angle angle to test
+    /// @param from starting angle of arc
+    /// @param to ending angle of arc
+    /// @return true if `angle` is within [from, to]
+    static bool isWithinCCW(double angle, double from, double to);
     /// Computes the unoriented smallest difference between two angles.
diff --git a/include/geos/algorithm/CircularArcIntersector.h b/include/geos/algorithm/CircularArcIntersector.h
new file mode 100644
index 000000000..dad551906
--- /dev/null
+++ b/include/geos/algorithm/CircularArcIntersector.h
@@ -0,0 +1,97 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2024 ISciences, LLC
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <array>
+#include <cstdint>
+#include <geos/export.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CircularArc.h>
+#include <geos/geom/LineSegment.h>
+namespace geos::algorithm {
+class GEOS_DLL CircularArcIntersector {
+public:
+    using CoordinateXY = geom::CoordinateXY;
+    using CircularArc = geom::CircularArc;
+    using Envelope = geom::Envelope;
+    enum intersection_type : uint8_t {
+        NO_INTERSECTION = 0,
+        ONE_POINT_INTERSECTION = 1,
+        TWO_POINT_INTERSECTION = 2,
+        COCIRCULAR_INTERSECTION = 3,
+    intersection_type getResult() const
+        return result;
+    const CoordinateXY& getPoint(std::uint8_t i) const
+        return intPt[i];
+    const CircularArc& getArc(std::uint8_t i) const
+        return intArc[i];
+    std::uint8_t getNumPoints() const
+        return nPt;
+    std::uint8_t getNumArcs() const
+        return nArc;
+    /// Determines whether and where a circular arc intersects a line segment.
+    /// Sets the appropriate value of intersection_type and stores the intersection
+    /// points, if any.
+    void intersects(const CircularArc& arc, const CoordinateXY& p0, const CoordinateXY& p1);
+    void intersects(const CircularArc& arc, const geom::LineSegment& seg)
+        intersects(arc, seg.p0, seg.p1);
+    /// Determines whether and where two circular arcs intersect.
+    /// points and/or arcs, if any.
+    void intersects(const CircularArc& arc1, const CircularArc& arc2);
+    static int
+    circleIntersects(const CoordinateXY& center, double r, const CoordinateXY& p0, const CoordinateXY& p1, CoordinateXY& isect0, CoordinateXY& isect1);
+private:
+    void intersects(const CoordinateXY& p0, const CoordinateXY& p1, const CoordinateXY& q0, const CoordinateXY& q1);
+    std::array<CoordinateXY, 2> intPt;
+    std::array<CircularArc, 2> intArc;
+    intersection_type result = NO_INTERSECTION;
+    std::uint8_t nPt = 0;
+    std::uint8_t nArc = 0;
diff --git a/include/geos/algorithm/CircularArcs.h b/include/geos/algorithm/CircularArcs.h
index 54f0a9b7d..60876b97e 100644
--- a/include/geos/algorithm/CircularArcs.h
+++ b/include/geos/algorithm/CircularArcs.h
@@ -14,6 +14,8 @@
 #pragma once
+#include <array>
 #include <geos/geom/Envelope.h>
@@ -28,9 +30,19 @@ public:
     static geom::CoordinateXY getCenter(const geom::CoordinateXY& p0, const geom::CoordinateXY& p1,
                                         const geom::CoordinateXY& p2);
+    static double getAngle(const geom::CoordinateXY& pt, const geom::CoordinateXY& center);
+    static double getMidpointAngle(double theta0, double theta2, bool isCCW);
+    static geom::CoordinateXY getMidpoint(const geom::CoordinateXY& p0, const geom::CoordinateXY& p2, const geom::CoordinateXY& center, double radius, bool isCCW);
     /// Expand an envelope to include an arc defined by three points
     static void expandEnvelope(geom::Envelope& e, const geom::CoordinateXY& p0, const geom::CoordinateXY& p1,
+    /// Return the point defined by a circle center, radius, and angle
+    static geom::CoordinateXY createPoint(const geom::CoordinateXY& center, double radius, double theta);
diff --git a/include/geos/geom/CircularArc.h b/include/geos/geom/CircularArc.h
index 283eaf3b0..621ab3ec1 100644
--- a/include/geos/geom/CircularArc.h
+++ b/include/geos/geom/CircularArc.h
@@ -16,6 +16,7 @@
 #include <geos/geom/Quadrant.h>
 #include <geos/algorithm/CircularArcs.h>
 #include <geos/algorithm/Orientation.h>
@@ -31,6 +32,8 @@ public:
+    CircularArc() : CircularArc({0, 0}, {0, 0}, {0, 0}) {}
     CircularArc(const CoordinateXY& q0, const CoordinateXY& q1, const CoordinateXY& q2)
         : p0(q0)
         , p1(q1)
@@ -40,15 +43,39 @@ public:
         , m_orientation_known(false)
-    const CoordinateXY& p0;
-    const CoordinateXY& p1;
-    const CoordinateXY& p2;
+    CircularArc(double theta0, double theta2, const CoordinateXY& center, double radius, int orientation)
+        : p0(algorithm::CircularArcs::createPoint(center, radius, theta0)),
+          p1(algorithm::CircularArcs::createPoint(center, radius, algorithm::CircularArcs::getMidpointAngle(theta0, theta2, orientation==algorithm::Orientation::COUNTERCLOCKWISE))),
+          p2(algorithm::CircularArcs::createPoint(center, radius, theta2)),
+          m_center(center),
+          m_radius(radius),
+          m_orientation(orientation),
+          m_center_known(true),
+          m_radius_known(true),
+          m_orientation_known(true)
+    CircularArc(const CoordinateXY& q0, const CoordinateXY& q2, const CoordinateXY& center, double radius, int orientation)
+        : p0(q0),
+          p1(algorithm::CircularArcs::getMidpoint(q0, q2, center, radius, orientation==algorithm::Orientation::COUNTERCLOCKWISE)),
+          p2(q2),
+          m_center(center),
+          m_radius(radius),
+    CoordinateXY p0;
+    CoordinateXY p1;
+    CoordinateXY p2;
     /// Return the orientation of the arc as one of:
     /// - algorithm::Orientation::CLOCKWISE,
     /// - algorithm::Orientation::COUNTERCLOCKWISE
     /// - algorithm::Orientation::COLLINEAR
-    int orientation() const {
+    int getOrientation() const {
         if (!m_orientation_known) {
             m_orientation = algorithm::Orientation::index(p0, p1, p2);
             m_orientation_known = true;
@@ -56,6 +83,10 @@ public:
         return m_orientation;
+    bool isCCW() const {
+        return getOrientation() == algorithm::Orientation::COUNTERCLOCKWISE;
     /// Return the center point of the circle associated with this arc
     const CoordinateXY& getCenter() const {
         if (!m_center_known) {
@@ -83,7 +114,7 @@ public:
     /// Returns whether this arc forms a straight line (p0, p1, and p2 are collinear)
     bool isLinear() const {
-        return std::isnan(getRadius());
+        return !std::isfinite(getRadius());
     /// Return the inner angle of the sector associated with this arc
@@ -100,7 +131,7 @@ public:
         auto t0 = theta0();
         auto t2 = theta2();
-        if (orientation() == algorithm::Orientation::COUNTERCLOCKWISE) {
+        if (getOrientation() == algorithm::Orientation::COUNTERCLOCKWISE) {
             std::swap(t0, t2);
@@ -133,14 +164,20 @@ public:
         return R*R/2*(theta - std::sin(theta));
+    /// Return the distance from the centerpoint of the arc to the line segment formed by the end points of the arc.
+    double getSagitta() const {
+        CoordinateXY midpoint = algorithm::CircularArcs::getMidpoint(p0, p2, getCenter(), getRadius(), isCCW());
+        return algorithm::Distance::pointToSegment(midpoint, p0, p2);
     /// Return the angle of p0
     double theta0() const {
-        return std::atan2(p0.y - getCenter().y, p0.x - getCenter().x);
+        return algorithm::CircularArcs::getAngle(p0, getCenter());
     /// Return the angle of p2
     double theta2() const {
-        return std::atan2(p2.y - getCenter().y, p2.x - getCenter().x);
+        return algorithm::CircularArcs::getAngle(p2, getCenter());
     /// Check to see if a coordinate lies on the arc
@@ -153,18 +190,18 @@ public:
     /// Check to see if a coordinate lies on the arc, after testing whether
     /// it lies on the circle.
-    bool containsPoint(const CoordinateXY& q) {
+    bool containsPoint(const CoordinateXY& q) const {
         if (q == p0 || q == p1 || q == p2) {
             return true;
-        auto dist = std::abs(q.distance(getCenter()) - getRadius());
+        //auto dist = std::abs(q.distance(getCenter()) - getRadius());
-        if (dist > 1e-8) {
-            return false;
+        //if (dist > 1e-8) {
+        //    return false;
-        if (triangulate::quadedge::TrianglePredicate::isInCircleNormalized(p0, p1, p2, q) != geom::Location::BOUNDARY) {
+        if (triangulate::quadedge::TrianglePredicate::isInCircleRobust(p0, p1, p2, q) != geom::Location::BOUNDARY) {
             return false;
@@ -180,7 +217,7 @@ public:
             return true;
             std::swap(t0, t2);
@@ -204,7 +241,7 @@ public:
         auto quad = geom::Quadrant::quadrant(getCenter(), q);
         bool isUpward;
-        if (orientation() == algorithm::Orientation::CLOCKWISE) {
+        if (getOrientation() == algorithm::Orientation::CLOCKWISE) {
             isUpward = (quad == geom::Quadrant::SW || quad == geom::Quadrant::NW);
         } else {
             isUpward = (quad == geom::Quadrant::SE || quad == geom::Quadrant::NE);
@@ -213,6 +250,15 @@ public:
         return isUpward;
+    // Split an arc at a specified point.
+    // The point is assumed to be o the arc.
+    std::pair<CircularArc, CircularArc> splitAtPoint(const CoordinateXY& q) const {
+        return {
+            CircularArc(p0, q, getCenter(), getRadius(), getOrientation()),
+            CircularArc(q, p2, getCenter(), getRadius(), getOrientation())
     class Iterator {
     public:
         using iterator_category = std::forward_iterator_tag;
diff --git a/include/geos/math/DD.h b/include/geos/math/DD.h
index 61e3a08a7..7be00a6f7 100644
--- a/include/geos/math/DD.h
+++ b/include/geos/math/DD.h
@@ -158,6 +158,7 @@ class GEOS_DLL DD {
         friend GEOS_DLL DD operator* (const DD &lhs, double rhs);
         friend GEOS_DLL DD operator/ (const DD &lhs, const DD &rhs);
         friend GEOS_DLL DD operator/ (const DD &lhs, double rhs);
+        friend GEOS_DLL DD operator- (const DD& x);
         static DD determinant(const DD &x1, const DD &y1, const DD &x2, const DD &y2);
         static DD determinant(double x1, double y1, double x2, double y2);
diff --git a/include/geos/triangulate/quadedge/TrianglePredicate.h b/include/geos/triangulate/quadedge/TrianglePredicate.h
index c356928ce..22273ad9f 100644
--- a/include/geos/triangulate/quadedge/TrianglePredicate.h
+++ b/include/geos/triangulate/quadedge/TrianglePredicate.h
@@ -70,7 +70,7 @@ public:
      * Tests if a point is inside the circle defined by
      * the triangle with vertices a, b, c (oriented counter-clockwise).
      * This test uses simple
-     * double-precision arithmetic, and thus is not 10% robust.
+     * double-precision arithmetic, and thus is not 100% robust.
      * However, by using normalization to the origin
      * it provides improved robustness and increased performance.
      * <p>
diff --git a/src/algorithm/Angle.cpp b/src/algorithm/Angle.cpp
index f9e176768..b63dc4db8 100644
--- a/src/algorithm/Angle.cpp
+++ b/src/algorithm/Angle.cpp
@@ -194,6 +194,15 @@ Angle::normalizePositive(double angle)
     return angle;
+bool
+Angle::isWithinCCW(double x, double a, double b) {
+    if (b > a) {
+        return x >= a && x <= b;
+    } else {
+        return x >= a || x <= b;
 /* public static */
 double
 Angle::diff(double ang1, double ang2)
diff --git a/src/algorithm/CircularArcIntersector.cpp b/src/algorithm/CircularArcIntersector.cpp
index 000000000..5ed2a44b7
--- /dev/null
+++ b/src/algorithm/CircularArcIntersector.cpp
@@ -0,0 +1,328 @@
+#include <geos/algorithm/Angle.h>
+#include <geos/algorithm/CircularArcIntersector.h>
+#include <geos/algorithm/LineIntersector.h>
+static double
+nextAngleCCW(double from, double a, double b)
+    if (Angle::normalizePositive(a - from) < Angle::normalizePositive(b - from)) {
+        return a;
+    else {
+        return b;
+int
+CircularArcIntersector::circleIntersects(const CoordinateXY& center, double r, const CoordinateXY& p0, const CoordinateXY& p1, CoordinateXY& ret0, CoordinateXY& ret1)
+    const double& x0 = center.x;
+    const double& y0 = center.y;
+    Envelope segEnv(p0, p1);
+    CoordinateXY isect0, isect1;
+    int n = 0;
+    if (p1.x == p0.x) {
+        // vertical line
+        double x = p1.x;
+        double A = 1;
+        double B = 2*y0;
+        double C = x*x - 2*x*x0 + x0*x0 + y0*y0 - r*r;
+        double d = std::sqrt(B*B - 4*A*C);
+        double Y1 = (-B + d)/(2*A);
+        double Y2 = (-B - d)/(2*A);
+        isect0 = {x, Y1};
+        isect1 = {x, Y2};
+    else {
+        double m = (p1.y - p0.y) / (p1.x - p0.x);
+        double b = p1.y - p1.x*m;
+        // Ax^2 + Bx + C = 0
+        double A = 1 + m*m;
+        double B = -2*x0 + 2*m*b - 2*m*y0;
+        double C = x0*x0 + b*b - 2*b*y0 + y0*y0 - r*r;
+        double X1 = (-B + d)/(2*A);
+        double X2 = (-B - d)/(2*A);
+        // TODO use robust quadratic solver such as https://github.com/archermarx/quadratic ?
+        // auto [X1, X2] = quadratic::solve(A, B, C);
+        isect0 = {X1, m* X1 + b};
+        isect1 = {X2, m* X2 + b};
+    if (segEnv.intersects(isect0)) {
+        ret0 = isect0;
+        if (segEnv.intersects(isect1) && !isect1.equals2D(isect0)) {
+            ret1 = isect1;
+            n = 2;
+        } else {
+            n = 1;
+    } else if (segEnv.intersects(isect1)) {
+        ret0 = isect1;
+        n = 1;
+    return n;
+void
+CircularArcIntersector::intersects(const CircularArc& arc, const CoordinateXY& p0, const CoordinateXY& p1)
+    if (arc.isLinear()) {
+        intersects(arc.p0, arc.p2, p0, p1);
+        return;
+    // TODO: envelope check?
+    const CoordinateXY& c = arc.getCenter();
+    const double r = arc.getRadius();
+    auto n = circleIntersects(c, r, p0, p1, isect0, isect1);
+    if (n > 0 && arc.containsPointOnCircle(isect0)) {
+        intPt[nPt++] = isect0;
+    if (n > 1  && arc.containsPointOnCircle(isect1)) {
+        intPt[nPt++] = isect1;
+    switch (nPt) {
+    case 2:
+        result = TWO_POINT_INTERSECTION;
+        break;
+    case 1:
+        result = ONE_POINT_INTERSECTION;
+        break;
+    default:
+        result = NO_INTERSECTION;
+void
+CircularArcIntersector::intersects(const CoordinateXY& p0, const CoordinateXY& p1,
+                                   const CoordinateXY& q0, const CoordinateXY& q1)
+    algorithm::LineIntersector li;
+    li.computeIntersection(p0, p1, q0, q1);
+    if (li.getIntersectionNum() == 2) {
+        // FIXME this means a collinear intersection, so we should report as cocircular?
+        intPt[0] = li.getIntersection(0);
+        intPt[1] = li.getIntersection(1);
+    } else if (li.getIntersectionNum() == 1) {
+        nPt = 1;
+    } else {
+void
+CircularArcIntersector::intersects(const CircularArc& arc1, const CircularArc& arc2)
+    // Handle cases where one or both arcs are degenerate
+    if (arc1.isLinear()) {
+        if (arc2.isLinear()) {
+            intersects(arc1.p0, arc1.p2, arc2.p0, arc2.p2);
+            return;
+        } else {
+            intersects(arc2, arc1.p0, arc1.p2);
+            return;
+    } else if (arc2.isLinear()) {
+        intersects(arc1, arc2.p0, arc2.p2);
+        return;
+    const auto& c1 = arc1.getCenter();
+    const auto& c2 = arc2.getCenter();
+    const auto r1 = arc1.getRadius();
+    const auto r2 = arc2.getRadius();
+    auto d = c1.distance(c2);
+    if (d > r1 + r2) {
+        // Circles are disjoint
+        return;
+    if (d < std::abs(r1-r2)) {
+        // One circle contained within the other; arcs cannot intersect
+        return;
+    // a: the distance from c1 to the "radical line", which connects the two intersection points
+    // The following expression was rewritten by
+    double a = (d*d + r1*r1 - r2*r2) / (2*d);
+    // Expression rewritten by Herbie, https://herbie.uwplse.org/demo/
+    // double a = std::fma(r1-r2, (r1 + r2) / (d+d), d*0.5);
+    // TODO because the circle center calculation is inexact we need some kind of tolerance here.
+    // Take a PrecisionModel like LineIntersector?
+    if (a == 0 || (d == 0 && r1 == r2)) {
+        // COCIRCULAR
+        double ap0 = arc1.theta0();
+        double ap1 = arc1.theta2();
+        double bp0 = arc2.theta0();
+        double bp1 = arc2.theta2();
+        bool resultArcIsCCW = true;
+        if (arc1.getOrientation() != Orientation::COUNTERCLOCKWISE) {
+            std::swap(ap0, ap1);
+            resultArcIsCCW = false;
+        if (arc2.getOrientation() != Orientation::COUNTERCLOCKWISE) {
+            std::swap(bp0, bp1);
+        ap0 = Angle::normalizePositive(ap0);
+        ap1 = Angle::normalizePositive(ap1);
+        bp0 = Angle::normalizePositive(bp0);
+        bp1 = Angle::normalizePositive(bp1);
+        bool checkBp1inA = true;
+        // check start of B within A?
+        if (Angle::isWithinCCW(bp0, ap0, ap1)) {
+            double start = bp0;
+            double end = nextAngleCCW(start, bp1, ap1);
+            if (end == bp1) {
+                checkBp1inA = false;
+            if (start == end) {
+                intPt[nPt++] = CircularArcs::createPoint(c1, r1, start);
+            else {
+                if (resultArcIsCCW) {
+                    intArc[nArc++] = CircularArc(start, end, c1, r1, Orientation::COUNTERCLOCKWISE);
+                else {
+                    intArc[nArc++] = CircularArc(end, start, c1, r1, Orientation::CLOCKWISE);
+        if (checkBp1inA && Angle::isWithinCCW(bp1, ap0, ap1)) {
+            // end of B within A?
+            double start = ap0;
+            double end = bp1;
+            else {
+                else {
+    } else {
+        // NOT COCIRCULAR
+        double dx = c2.x-c1.x;
+        double dy = c2.y-c1.y;
+#if 1
+        // point where a line between the two circle center points intersects
+        // the radical line
+        CoordinateXY p{c1.x + a* dx/d, c1.y+a* dy/d};
+        // distance from p to the intersection points
+        double h = std::sqrt(r1*r1 - a*a);
+        CoordinateXY isect0{p.x + h* dy/d, p.y - h* dx/d };
+        CoordinateXY isect1{p.x - h* dy/d, p.y + h* dx/d };
+        if (arc1.containsPointOnCircle(isect0) && arc2.containsPointOnCircle(isect0)) {
+        if (!isect1.equals2D(isect0) && arc1.containsPointOnCircle(isect1) && arc2.containsPointOnCircle(isect1)) {
+#else
+        // Alternate formulation.
+        // Instead of calculating the intersection points and determining if they fall on the arc,
+        // calculate the angles of the intersection points. If they fall on the arc, create intersection points
+        // at those angles.
+        double centerPointAngle = std::atan2(dy, dx);
+        double arc1IntPtAngleDeviation = std::acos(a / r1);
+        double a11 = Angle::normalize(centerPointAngle - arc1IntPtAngleDeviation);
+        double a12 = Angle::normalize(centerPointAngle + arc1IntPtAngleDeviation);
+        double b = d - a;
+        double arc2IntPtAngleDeviation = std::acos(b / r2);
+        double a21 = Angle::normalize(centerPointAngle + MATH_PI + arc2IntPtAngleDeviation);
+        double a22 = Angle::normalize(centerPointAngle + MATH_PI - arc2IntPtAngleDeviation);
+        if (arc1.containsAngle(a11) && arc2.containsAngle(a21)) {
+            intPt[nPt++] = CircularArcs::createPoint(arc1.getCenter(), arc1.getRadius(), a11);
+        if (arc1.containsAngle(a12) && arc2.containsAngle(a22)) {
+            intPt[nPt++] = CircularArcs::createPoint(arc1.getCenter(), arc1.getRadius(), a12);
+            if (nPt == 2 && intPt[0].equals(intPt[1])) {
+                nPt = 1;
+#endif
+    if (nArc) {
+        result = COCIRCULAR_INTERSECTION;
+    else {
+        switch (nPt) {
+        case 2:
+            break;
+        case 1:
+            break;
+        case 0:
+            break;
diff --git a/src/algorithm/CircularArcs.cpp b/src/algorithm/CircularArcs.cpp
index 068dfd38c..99ddb04ff 100644
--- a/src/algorithm/CircularArcs.cpp
+++ b/src/algorithm/CircularArcs.cpp
@@ -12,16 +12,95 @@
+#include <geos/math/DD.h>
 using geos::geom::CoordinateXY;
 namespace geos {
 namespace algorithm {
+CoordinateXY
+CircularArcs::getMidpoint(const CoordinateXY& p0, const CoordinateXY& p2, const CoordinateXY& center, double radius, bool isCCW)
+    double start = getAngle(p0, center);
+    double stop = getAngle(p2, center);
+    double mid = getMidpointAngle(start, stop, isCCW);
+    return createPoint(center, radius, mid);
+double
+CircularArcs::getAngle(const CoordinateXY& p, const CoordinateXY& center)
+    return std::atan2(p.y - center.y, p.x - center.x);
+double
+CircularArcs::getMidpointAngle(double theta0, double theta2, bool isCCW)
+    if (!isCCW) {
+        return getMidpointAngle(theta2, theta0, true);
+    double mid = (theta0 + theta2) / 2;
+    if (!Angle::isWithinCCW(mid, theta0, theta2)) {
+        mid += MATH_PI;
+    return mid;
+CoordinateXY
+CircularArcs::createPoint(const CoordinateXY& center, double radius, double theta)
+    return { center.x + radius* std::cos(theta), center.y + radius* std::sin(theta) };
+template<typename T>
+CoordinateXY getCenterImpl(const CoordinateXY& p0, const CoordinateXY& p1, const CoordinateXY& p2)
+    // Circumcenter formulas from Graphics Gems III
+    T p0x{p0.x};
+    T p0y{p0.y};
+    T p1x{p1.x};
+    T p1y{p1.y};
+    T p2x{p2.x};
+    T p2y{p2.y};
+    T ax = p1x - p2x;
+    T ay = p1y - p2y;
+    T bx = p2x - p0x;
+    T by = p2y - p0y;
+    T cx = p0x - p1x;
+    T cy = p0y - p1y;
+    T d1 = -(bx*cx + by*cy);
+    T d2 = -(cx*ax + cy*ay);
+    T d3 = -(ax*bx + ay*by);
+    T e1 = d2*d3;
+    T e2 = d3*d1;
+    T e3 = d1*d2;
+    T e = e1 + e2 + e3;
+    T G3x = p0.x + p1.x + p2.x;
+    T G3y = p0.y + p1.y + p2.y;
+    T Hx = (e1*p0.x + e2*p1.x + e3*p2.x) / e;
+    T Hy = (e1*p0.y + e2*p1.y + e3*p2.y) / e;
+    T rx = 0.5*(G3x - Hx);
+    T ry = 0.5*(G3y - Hy);
+    if constexpr (std::is_same_v<T, math::DD>) {
+        return {rx.doubleValue(), ry.doubleValue()};
+    } else {
+        return {rx, ry};
 CoordinateXY
 CircularArcs::getCenter(const CoordinateXY& p0, const CoordinateXY& p1, const CoordinateXY& p2)
@@ -31,26 +110,7 @@ CircularArcs::getCenter(const CoordinateXY& p0, const CoordinateXY& p1, const Co
         return { 0.5*(p0.x + p1.x), 0.5*(p0.y + p1.y) };
-    // Circumcenter formulas from Graphics Gems III
-    CoordinateXY a{p1.x - p2.x, p1.y - p2.y};
-    CoordinateXY b{p2.x - p0.x, p2.y - p0.y};
-    CoordinateXY c{p0.x - p1.x, p0.y - p1.y};
-    double d1 = -(b.x*c.x + b.y*c.y);
-    double d2 = -(c.x*a.x + c.y*a.y);
-    double d3 = -(a.x*b.x + a.y*b.y);
-    double e1 = d2*d3;
-    double e2 = d3*d1;
-    double e3 = d1*d2;
-    double e = e1 + e2 + e3;
-    CoordinateXY G3{p0.x + p1.x + p2.x, p0.y + p1.y + p2.y};
-    CoordinateXY H {(e1*p0.x + e2*p1.x + e3*p2.x) / e, (e1*p0.y + e2*p1.y + e3*p2.y) / e};
-    CoordinateXY center = {0.5*(G3.x - H.x), 0.5*(G3.y - H.y)};
-    return center;
+    return getCenterImpl<double>(p0, p1, p2);
 void
diff --git a/src/math/DD.cpp b/src/math/DD.cpp
index c620c1b62..662f1f1d3 100644
--- a/src/math/DD.cpp
+++ b/src/math/DD.cpp
@@ -236,6 +236,11 @@ DD operator/(const DD &lhs, double rhs)
     return rv;
+DD operator- (const DD& x)
+    return x.negate();
 /* public */
 DD DD::negate() const
diff --git a/tests/unit/algorithm/AngleTest.cpp b/tests/unit/algorithm/AngleTest.cpp
index 4d3767182..f44d3ee42 100644
--- a/tests/unit/algorithm/AngleTest.cpp
+++ b/tests/unit/algorithm/AngleTest.cpp
@@ -25,7 +25,7 @@ struct test_angle_data {
     test_angle_data()
         TOL(1e-5),
-        PI(3.14159265358979323846)
+        PI(geos::MATH_PI)
@@ -196,7 +196,40 @@ void object::test<6>
         ensure_equals(std::to_string(angrad), rCos, std::cos(angrad));
+template<>
+template<>
+void object::test<7>()
+    set_test_name("isWithinCCW");
+    // interval from 0 to pi
+        double from = 0, to = PI;
+        ensure("pi/2 in [0, pi]", Angle::isWithinCCW(Angle::PI_OVER_2, from, to));
+        ensure("0 in [0, pi]", Angle::isWithinCCW(0, from, to));
+        ensure("pi in [0, pi]", Angle::isWithinCCW(PI, from, to));
+        ensure("-pi/2 not in [0, pi]", !Angle::isWithinCCW(Angle::normalizePositive(-Angle::PI_OVER_2), from, to));
+    // interval from pi to 0
+        double from = PI, to = 0;
+        ensure("pi/2 not in [pi, 0]", !Angle::isWithinCCW(Angle::PI_OVER_2, from, to));
+        ensure("0 in [pi, 0]", Angle::isWithinCCW(0, from, to));
+        ensure("pi in [pi, 0]", Angle::isWithinCCW(PI, from, to));
+        ensure("-pi/2 in [pi, 0]", Angle::isWithinCCW(Angle::normalizePositive(-Angle::PI_OVER_2), from, to));
+    // interval from -pi/2 to pi/2
+        double from = Angle::normalizePositive(-Angle::PI_OVER_2), to = Angle::PI_OVER_2;
+        ensure("0 in [-pi/2, pi/2]", Angle::isWithinCCW(0, from, to));
+        ensure("pi/2 in [-pi/2, pi/2]", Angle::isWithinCCW(Angle::PI_OVER_2, from, to));
+        ensure("-pi/2 in [-pi/2, pi/2]", Angle::isWithinCCW(Angle::normalizePositive(-Angle::PI_OVER_2), from, to));
+        ensure("pi not in [-pi/2, pi/2]", !Angle::isWithinCCW(PI, from, to));
diff --git a/tests/unit/algorithm/CircularArcIntersectorTest.cpp b/tests/unit/algorithm/CircularArcIntersectorTest.cpp
index 000000000..2f9e51bdc
--- /dev/null
+++ b/tests/unit/algorithm/CircularArcIntersectorTest.cpp
@@ -0,0 +1,884 @@
+#include <tut/tut.hpp>
+#include <geos/constants.h>
+#include <variant>
+using geos::algorithm::CircularArcIntersector;
+using geos::algorithm::Orientation;
+using geos::geom::CoordinateXY;
+using geos::geom::CircularArc;
+using geos::MATH_PI;
+namespace tut {
+struct test_circulararcintersector_data {
+    using ArcOrPoint = std::variant<CoordinateXY, CircularArc>;
+    static std::string to_string(CircularArcIntersector::intersection_type t)
+        switch (t) {
+        case geos::algorithm::CircularArcIntersector::NO_INTERSECTION:
+            return "no intersection";
+        case geos::algorithm::CircularArcIntersector::ONE_POINT_INTERSECTION:
+            return "one-point intersection";
+        case geos::algorithm::CircularArcIntersector::TWO_POINT_INTERSECTION:
+            return "two-point intersection";
+        case geos::algorithm::CircularArcIntersector::COCIRCULAR_INTERSECTION:
+            return "cocircular intersection";
+            break;
+        return "";
+    static std::string toWKT(const CoordinateXY& pt)
+        return "POINT (" + pt.toString() + ")";
+    static std::string toWKT(const CircularArc& arc)
+        return "CIRCULARSTRING (" + arc.p0.toString() + ", " + arc.p1.toString() + ", " + arc.p2.toString() + ")";
+    static std::string toWKT(const geos::geom::LineSegment& seg)
+        return "LINESTRING (" + seg.p0.toString() + ", " + seg.p1.toString() + ")";
+    static void checkIntersection(CoordinateXY p0, CoordinateXY p1, CoordinateXY p2,
+                                  CoordinateXY q0, CoordinateXY q1, CoordinateXY q2,
+                                  CircularArcIntersector::intersection_type result,
+                                  ArcOrPoint i0 = CoordinateXY::getNull(),
+                                  ArcOrPoint i1 = CoordinateXY::getNull())
+        CircularArc a0(p0, p1, p2);
+        CircularArc a1(q0, q1, q2);
+        checkIntersection(a0, a1, result, i0, i1);
+                                  CoordinateXY i0 = CoordinateXY::getNull(),
+                                  CoordinateXY i1 = CoordinateXY::getNull())
+        CircularArc a(p0, p1, p2);
+        geos::geom::LineSegment s(geos::geom::Coordinate{q0}, geos::geom::Coordinate{q1});
+        checkIntersection(a, s, result, i0, i1);
+    static bool pointWithinTolerance(const CoordinateXY& actual, const CoordinateXY& expected, double tol)
+        if (actual.distance(expected) < tol) {
+            return true;
+        return std::abs(actual.x - expected.x) < tol * std::abs(actual.x) &&
+            std::abs(actual.y - expected.y) < tol * std::abs(actual.y);
+    template<typename CircularArcOrLineSegment>
+    static void checkIntersection(const CircularArc& a0,
+                                  const CircularArcOrLineSegment& a1,
+                                  ArcOrPoint p0 = CoordinateXY::getNull(),
+                                  ArcOrPoint p1 = CoordinateXY::getNull())
+        CircularArcIntersector cai;
+        cai.intersects(a0, a1);
+        ensure_equals("incorrect intersection type between " + toWKT(a0) + " and " + toWKT(a1), to_string(cai.getResult()), to_string(result));
+        std::vector<CoordinateXY> expectedPoints;
+        std::vector<CircularArc> expectedArcs;
+        for (const auto& intersection : { p0, p1 }) {
+            if (std::holds_alternative<CoordinateXY>(intersection)) {
+                const CoordinateXY& pt = std::get<CoordinateXY>(intersection);
+                if (!pt.isNull()) {
+                    expectedPoints.push_back(pt);
+            else {
+                expectedArcs.push_back(std::get<CircularArc>(intersection));
+        std::vector<CoordinateXY> actualPoints;
+        std::vector<CircularArc> actualArcs;
+        for (std::uint8_t i = 0; i < cai.getNumPoints(); i++) {
+            actualPoints.push_back(cai.getPoint(i));
+        for (std::uint8_t i = 0; i < cai.getNumArcs(); i++) {
+            actualArcs.push_back(cai.getArc(i));
+        auto compareArcs = [](const CircularArc& a, const CircularArc& b) {
+            int cmp;
+            cmp = a.p0.compareTo(b.p0);
+            if (cmp != 0) {
+                return cmp == -1;
+            cmp = a.p2.compareTo(b.p2);
+            if (cmp != 0) {
+                return cmp == -1;
+            cmp = a.getCenter().compareTo(b.getCenter());
+            if (cmp != 0) {
+                return cmp == -1;
+            return a.getOrientation() < b.getOrientation();
+        std::sort(actualPoints.begin(), actualPoints.end());
+        std::sort(actualArcs.begin(), actualArcs.end(), compareArcs);
+        std::sort(expectedPoints.begin(), expectedPoints.end());
+        std::sort(expectedArcs.begin(), expectedArcs.end(), compareArcs);
+        bool equal = true;
+        if (actualPoints.size() != expectedPoints.size()) {
+            equal = false;
+        if (actualArcs.size() != expectedArcs.size()) {
+            equal = false;
+        constexpr double eps = 1e-8;
+        if (equal) {
+            for (std::size_t i = 0; i < actualPoints.size(); i++) {
+                if (!pointWithinTolerance(actualPoints[i], expectedPoints[i], eps)) {
+                    equal = false;
+            for (std::size_t i = 0; i < actualArcs.size(); i++) {
+                if (actualArcs[i].getOrientation() != expectedArcs[i].getOrientation()) {
+                    equal = false;
+                if (std::abs(actualArcs[i].getRadius() - expectedArcs[i].getRadius()) > eps) {
+                    equal = false;
+                if (!pointWithinTolerance(actualArcs[i].getCenter(), expectedArcs[i].getCenter(), eps)) {
+                    equal = false;
+                if (!pointWithinTolerance(actualArcs[i].p0, expectedArcs[i].p0, eps)) {
+                    equal = false;
+                if (!pointWithinTolerance(actualArcs[i].p2, expectedArcs[i].p2, eps)) {
+                    equal = false;
+        if (equal) {
+            return;
+        std::string actual;
+        for (const auto& pt : actualPoints) {
+            if (!actual.empty()) {
+                actual += ", ";
+            actual += toWKT(pt);
+        for (const auto& arc : actualArcs) {
+                actual += ", ";
+            actual += toWKT(arc);
+        std::string expected;
+        for (const auto& pt : expectedPoints) {
+            if (!expected.empty()) {
+                expected += ", ";
+            expected += toWKT(pt);
+        for (const auto& arc : expectedArcs) {
+                expected += ", ";
+            expected += toWKT(arc);
+        ensure_equals(actual, expected);
+    const CoordinateXY _NW = { -std::sqrt(2)/2, std::sqrt(2)/2 };
+    const CoordinateXY _N =  { 0, 1};
+    const CoordinateXY _NE = {  std::sqrt(2)/2, std::sqrt(2)/2 };
+    const CoordinateXY _E =  { 1, 0};
+    const CoordinateXY _SE = {  std::sqrt(2)/2, -std::sqrt(2)/2 };
+    const CoordinateXY _S =  { 0, -1};
+    const CoordinateXY _SW = { -std::sqrt(2)/2, -std::sqrt(2)/2 };
+    const CoordinateXY _W =  { -1, 0};
+using group = test_group<test_circulararcintersector_data>;
+using object = group::object;
+group test_circulararcintersector_group("geos::algorithm::CircularArcIntersector");
+template<>
+template<>
+void object::test<1>()
+    set_test_name("interior/interior intersection (one point)");
+    checkIntersection({0, 0}, {1, std::sqrt(3)}, {2, 2},
+    {0, 2}, {1, std::sqrt(3)}, {2, 0},
+    CircularArcIntersector::ONE_POINT_INTERSECTION,
+    CoordinateXY{1, std::sqrt(3)});
+template<>
+template<>
+void object::test<2>()
+    set_test_name("interior/interior intersection (two points)");
+    // result from CGAL 5.4
+    checkIntersection({0, 0}, {2, 2}, {4, 0},
+    {0, 1}, {2, -1}, {4, 1},
+    CircularArcIntersector::TWO_POINT_INTERSECTION,
+    CoordinateXY{0.0635083268962914893, 0.5},
+    CoordinateXY{3.93649167310370851, 0.5});
+template<>
+template<>
+void object::test<3>()
+    set_test_name("single endpoint-endpoint intersection");
+    checkIntersection({0, 0}, {1, 1}, {2, 0},
+    {2, 0}, {3, -1}, {4, 0},
+    CoordinateXY{2, 0});
+template<>
+template<>
+void object::test<4>()
+    set_test_name("single interior-interior intersection at point of tangency");
+    {0, 2}, {1, 1}, {2, 2},
+    CoordinateXY{1, 1});
+template<>
+template<>
+void object::test<5>()
+    set_test_name("supporting circles intersect but arcs do not");
+    {1, 1}, {0, -1}, {-1, 1},
+    CircularArcIntersector::NO_INTERSECTION);
+template<>
+template<>
+void object::test<6>()
+    set_test_name("one circle contained within other");
+    checkIntersection({0, 0}, {4, 4}, {8, 0},
+    {2, 0}, {4, 2}, {6, 0},
+template<>
+template<>
+    set_test_name("cocircular with double endpoint intersection");
+    {0, 0}, {1, -1}, {2, 0},
+    CoordinateXY{0, 0}, CoordinateXY{2, 0});
+template<>
+template<>
+void object::test<8>()
+    set_test_name("cocircular with single endpoint intersection");
+    checkIntersection({-2, 0}, {0, 2}, {2, 0},
+    {0, -2}, {std::sqrt(2), -std::sqrt(2)}, {2, 0},
+template<>
+template<>
+void object::test<9>()
+    set_test_name("cocircular disjoint");
+    checkIntersection(_NW, _N, _NE,
+                      _SW, _S, _SE,
+template<>
+template<>
+void object::test<10>()
+    set_test_name("cocircular with single arc intersection (clockwise)");
+    checkIntersection({-5, 0}, {0, 5}, {5, 0}, // CW
+    {-4, 3}, {0, 5}, {4, 3}, // CW
+    CircularArcIntersector::COCIRCULAR_INTERSECTION,
+    CircularArc{{-4, 3}, {0, 5}, {4, 3}}); // CW
+template<>
+template<>
+void object::test<11>()
+    set_test_name("cocircular with single arc intersection (counter-clockwise)");
+    checkIntersection({5, 0},  {0, 5}, {-5, 0}, // CCW
+    CircularArc{{4, 3}, {0, 5}, {-4, 3}}); // CCW
+template<>
+template<>
+void object::test<12>()
+    set_test_name("cocircular with arc and point intersections");
+    {5, 0}, {0, -5}, {0, 5},
+    CircularArc{{-5, 0}, {-5*std::sqrt(2)/2, 5*std::sqrt(2)/2}, {0, 5}},
+    CoordinateXY{5, 0});
+template<>
+template<>
+void object::test<13>()
+    set_test_name("cocircular with two arc intersections");
+    {3, 4}, {0, -5}, {-3, 4},
+    CircularArc{{3, 4}, {4.4721359549995796, 2.2360679774997898}, {5, 0}},
+    CircularArc{{-5, 0}, {-4.4721359549995796, 2.2360679774997907}, {-3, 4}});
+template<>
+template<>
+void object::test<20>()
+    set_test_name("arc - degenerate arc with single interior intersection");
+    checkIntersection({0, 0}, {2, 2}, {4, 0}, // CW arc
+                      {-1, -4}, {1, 0}, {3, 4}, // degenerate arc
+                      CoordinateXY{2, 2});
+    checkIntersection({-1, -4}, {1, 0}, {3, 4}, // degenerate arc
+                      {0, 0}, {2, 2}, {4, 0}, // CW arc
+template<>
+template<>
+void object::test<21>()
+    set_test_name("two degenerate arcs with single interior intersection");
+    checkIntersection({0, 0}, {4, 4}, {10, 10},
+                      {10, 0}, {1, 9}, {0, 10},
+                      CoordinateXY{5, 5});
+template<>
+template<>
+void object::test<30>()
+    set_test_name("arc-segment with single interior intersection");
+    {1, 0}, {3, 4},
+    {2, 2});
+template<>
+template<>
+void object::test<31>()
+    set_test_name("arc-vertical segment with single interior intersection");
+    {0, 0}, {0, 4},
+    {0, 2});
+template<>
+template<>
+void object::test<32>()
+    set_test_name("arc-segment with two interior intersections");
+    checkIntersection(_W, _E, _SW,
+    {-10, 10}, {10, -10},
+    _NW, _SE);
+template<>
+template<>
+void object::test<33>()
+    set_test_name("arc-vertical segment with two interior intersections");
+    {0, -2}, {0, 2},
+    _S, _N);
+template<>
+template<>
+void object::test<34>()
+    set_test_name("arc-segment disjoint with bbox containment");
+    checkIntersection(_W, _N, _E,
+    {0, 0}, {0.2, 0.2},
+template<>
+template<>
+void object::test<35>()
+    set_test_name("degenerate arc-segment with interior intersection");
+    checkIntersection({-5, -5}, {0, 0}, {5, 5},
+                      {-5, 5},  {5, -5},
+                      {0, 0});
+template<>
+template<>
+void object::test<36>()
+    set_test_name("intersection between a segment and a degenerate arc (radius = Infinity)");
+    checkIntersection({-5, -5}, {0, 0}, {5, 5 + 1e-14},
+                      {-5, 5}, {5, -5},
+                      CoordinateXY{0, 0});
+template<>
+template<>
+void object::test<37>()
+    set_test_name("intersection between a segment and a nearly-degenerate arc (radius ~= 1e5)");
+    checkIntersection({-5, -5}, {0, 0}, {5, 5 + 1e-4},
+                      {-5, 5}, {5, -5},
+template<>
+template<>
+void object::test<38>()
+    set_test_name("arc-segment tests from ILI validator");
+    // https://github.com/claeis/iox-ili/blob/master/jtsext/src/test/java/ch/interlis/iom_j/itf/impl/hrg/ISCILRTest.java
+    // test_1a
+    checkIntersection({0, 5}, {5, 0}, {0, -5},
+                      {20, 5}, {20, -5},
+                      CircularArcIntersector::NO_INTERSECTION),
+    // test_2a
+                      {5, 5}, {5, 0},
+                      {5, 0});
+    // test_2b
+                      {5, 5}, {5, -5},
+                      {5, 0});
+    // test_2c
+    checkIntersection({0, 5}, {4, 3}, {0, -5},
+                      {5, 5}, {5, 0},
+                      {5, 0});
+    // test_2d
+                      {5, 5}, {5, -5},
+                      {5, 0});
+    // test_3a
+                      {4, 5}, {4, -5},
+                      {4, 3}, {4, -3});
+    // test_3b
+                      {-4, 5}, {-4, -5},
+    // test_3c
+                      {4, 10}, {4, 5},
+    // test_3d
+    checkIntersection({0, 5}, {3, 4}, {5, 0},
+                      {4, 5}, {4, -5},
+                      {4, 3});
+    // test_3e
+                      {4, 5}, {4, 0},
+                      {4, 3});
+template<>
+template<>
+void object::test<39>()
+    set_test_name("arc-arc tests from ILI validator");
+    // https://github.com/claeis/iox-ili/blob/master/jtsext/src/test/java/ch/interlis/iom_j/itf/impl/hrg/ISCICRTest.java
+    // test_1: circles do not overlap
+                      {20, 5}, {15, 0}, {20, -5},
+    // test_2a: arcs overlap at a point
+                      {10, 5}, {5, 0}, {10, -5},
+    // test_2b: arcs overlap at a point that is not a definition point of either arc
+                      {10, 5}, {6, 3}, {10, -5},
+    // test_3a: circles overlap at two points that are within both arcs
+                      {8, 5}, {3, 0}, {8, -5},
+                      CoordinateXY{4, 3}, CoordinateXY{4, -3});
+    // test_3b: circles overlap at two points but neither is on the first arc
+    checkIntersection({0, 5}, {-5, 0}, {0, -5},
+    // test_3c: circles overlap at two points but neither is on the first or second arc
+                      {8, 5}, {13, 0}, {8, -5},
+    // test_3d: circles overlap at two points but one is not on the first arc
+    checkIntersection({5, 0}, {3, -4}, {0, -5},
+                      CoordinateXY{4, -3});
+    // test_3e: circles overlap at two points but one is not on the second arc
+                      {3, 0}, {5, -4}, {8, -5},
+    // test_4a: cocircular
+                      {4, 3}, {5, 0}, {4, -3},
+                      CircularArc{{4, 3}, {5, 0}, {4, -3}});
+#if 0
+// failed assertion: Values are not equal: expected `POINT (0 0)` actual `POINT (-5.4568517953157425e-06 5.4568517953157425e-06)`
+template<>
+template<>
+void object::test<40>()
+    set_test_name("intersection between a segment and a nearly-degenerate arc (radius ~= 2e6)");
+    checkIntersection({-5, -5}, {0, 0}, {5, 5 + 1e-9},
+                      {-5, 5}, {5, -5},
+#endif
+template<>
+template<>
+void object::test<41>()
+    set_test_name("IOX-ILI: testFastGerade");
+    checkIntersection({611770.424, 234251.322}, {611770.171, 234250.059}, {611769.918, 234248.796},
+    {611613.84, 233467.819},
+    {611610.392, 233468.995},
+#if 0
+template<>
+template<>
+void object::test<42>()
+    set_test_name("IOX-ILI: testCircleCircleEndptTolerance");
+    // two nearly-linear arcs touching at a single endpoint
+    // Potential fix is to use tolerance for checking if computed points are within arc.
+    checkIntersection({645175.553, 248745.374}, { 645092.332, 248711.677}, { 645009.11, 248677.98},
+                      {645009.11, 248677.98}, {644926.69, 248644.616}, { 644844.269, 248611.253},
+                      CoordinateXY{645009.110, 248677.980});
+#endif
+template<>
+template<>
+void object::test<43>()
+    set_test_name("IOX-ILI: overlayTwoARCS_SameEndPoints_SameDirection");
+    // two arcs with same arcPoint and radius.
+    // startPoints and endPoints are same. lines are in same direction
+    {100.0, 100.0},{120,150.0},{100.0,200.0},
+    CircularArc{{100.0, 100.0}, {120, 150}, {100, 200}});
+template<>
+template<>
+void object::test<44>()
+    set_test_name("IOX-ILI: overlayTwoARCS_DifferentArcPointOnSameArcLine_SameDirection");
+	// two arcs with different arcPoint (on same arcLine) and same radius length.
+	// startPoints and endPoints are same. lines are in same direction.
+    {0.0, 10.0},{4.0,8.0},{0.0,0.0},
+    {0.0, 10.0},{4.0,2.0},{0.0,0.0},
+    CircularArc{{0, 10}, {5, 5}, {0, 0}});
+template<>
+template<>
+void object::test<45>()
+    set_test_name("IOX-ILI: overlayTwoARCS_SameArcPointOnSameArcLine_OneArcLineIsLonger");
+    // two arcs with same arcPoint (on same arcLine) and same radius length.
+    // one arc line is longer than the other arc line.
+    // startPoints is same, endPoints are different. lines are in same direction.
+    {0.0, 10.0},{4.0,8.0},{4.0,2.0},
+    CircularArc{{0, 10}, {4, 2}, {0, 5}, 5, Orientation::CLOCKWISE});
+template<>
+template<>
+void object::test<46>()
+    set_test_name("IOX-ILI: overlayTwoARCS_SameEndPoints_OtherDirection");
+    // startPoint1 is equal to endPoint2, startPoint2 is equal to endPoint1.
+        CircularArc({100.0, 100.0}, {80.0, 150.0}, {100.0, 200.0}),
+        CircularArc({100.0, 200.0}, {80.0, 150.0}, {100.0, 100.0}),
+        CircularArc({100.0, 100.0}, {80.0, 150.0}, {100.0, 200.0}));
+template<>
+template<>
+void object::test<47>()
+    set_test_name("IOX-ILI: overlayTwoARCS_DifferentStartPoints_SameDirection_DifferentLength");
+    // two arcs. ArcPoint is equal. different angle.
+    // startPoints are different. endPoints are same.
+    CircularArc a({70.0, 60.0}, {50.0, 100.0}, {60.0, 130.0});
+    CircularArc b({60.0, 70.0}, {50.0, 100.0}, {60.0, 130.0});
+    checkIntersection(a, b,
+        CircularArc({60, 70}, {60, 130}, a.getCenter(), a.getRadius(), a.getOrientation()));
+template<>
+template<>
+void object::test<48>()
+    set_test_name("IOX-ILI: overlayTwoARCS_DifferentStartEndPoints_OtherDirection_DifferentLength");
+    // Two cocircular arcs with opposite orientation.
+    // ArcPoint is equal.
+    // startPoints are different. endPoints are different.
+    CircularArc a({70.0,  60.0}, {50.0, 100.0}, {70.0, 140.0});
+    CircularArc b({60.0, 130.0}, {50.0, 100.0}, {60.0,  70.0});
+template<>
+template<>
+void object::test<49>()
+    set_test_name("IOX-ILI: overlayTwoARCS_DifferentEndPoints_SameDirection_DifferentLength");
+    // Two arcs with same orientation.
+    // startPoints are same, endpoints are different
+    CircularArc b({70.0, 60.0}, {50.0, 100.0}, {60.0, 130.0});
+        CircularArcIntersector::COCIRCULAR_INTERSECTION, b);
+template<>
+template<>
+void object::test<50>()
+    set_test_name("IOX-ILI: overlayTwoARCS_DifferentEndPoints_OtherDirection_DifferentLength");
+    // Two arcs with opposite orientation.
+    // One endpoint is the same, one is different.
+    CircularArc b({60.0, 130.0}, {50.0, 100.0}, {70.0,  60.0});
+        CircularArc({70, 60}, {60, 130}, a.getCenter(), a.getRadius(), a.getOrientation()));
+template<>
+template<>
+void object::test<51>()
+    set_test_name("IOX-ILI: twoARCS_SameRadiusAndCenter_DontOverlay");
+    // two arcs with same center and radius that don't touch each other.
+    CircularArc b({140.0, 70.0}, {150.0, 100.0}, {140.0, 130.0});
+    checkIntersection(a, b, CircularArcIntersector::NO_INTERSECTION);
+template<>
+template<>
+void object::test<52>()
+    set_test_name("IOX-ILI: twoARCS_SameRadiusAndCenter_Touch_DontOverlay");
+    // Two arcs with same radius and center that touch at the endpoints
+    CircularArc a({50.0,  100.0}, {100.0, 150.0}, {150.0, 100.0});
+    CircularArc b({150.0, 100.0}, {100.0, 50.0},  {50.0,  100.0});
+    checkIntersection(a, b, CircularArcIntersector::TWO_POINT_INTERSECTION, a.p0, a.p2);
+#if 0
+template<>
+template<>
+void object::test<53>()
+    set_test_name("IOX-ILI: twoARCS_SameRadiusAndCenter_Touch_DontOverlay_real");
+    // arcs touch at endpoints
+    CircularArc a({2654828.912, 1223354.671}, {2654829.982, 1223353.601}, {2654831.052, 1223354.671});
+    CircularArc b({2654831.052, 1223354.671}, {2654829.982, 1223355.741}, {2654828.912, 1223354.671});
+#endif
+template<>
+template<>
+void object::test<54>()
+    set_test_name("IOX-ILI: twoARCS_intersect0");
+    // https://github.com/claeis/ilivalidator/issues/186
+    CircularArc a({2658317.225, 1250832.586}, {2658262.543, 1250774.465}, {2658210.528, 1250713.944});
+    CircularArc b({2658211.456, 1250715.072}, {2658161.386, 1250651.279}, {2658114.283, 1250585.266});
+    // An intersection is visually apparent in QGIS, but CGAL 5.6 reports no intersections...
+template<>
+template<>
+void object::test<55>()
+    set_test_name("IOX-ILI: twoARCS_issue308");
+    // https://github.com/claeis/ili2db/issues/308
+    CircularArc a({2653134.354, 1227788.188}, {2653137.455, 1227797.289}, {2653140.555, 1227806.391});
+    CircularArc b({2653135.557, 1227789.0},   {2653134.819, 1227788.796}, {2653134.354, 1227788.188});
+    // expected result calculated with CGAL 5.6
+        CoordinateXY{2653134.35399999982, 1227788.18800000008});
\ No newline at end of file
diff --git a/tests/unit/algorithm/CircularArcsTest.cpp b/tests/unit/algorithm/CircularArcsTest.cpp
index e40aa3435..96082078b 100644
--- a/tests/unit/algorithm/CircularArcsTest.cpp
+++ b/tests/unit/algorithm/CircularArcsTest.cpp
@@ -2,10 +2,13 @@
 using geos::algorithm::CircularArcs;
 using geos::geom::Envelope;
 namespace tut {
@@ -35,6 +38,25 @@ struct test_circulararcs_data {
             ensure_equals("p2-p1-p0 ymax", e.getMaxY(), ymax, eps);
+    static std::string toWKT(const CoordinateXY& p0, const CoordinateXY& p1, const CoordinateXY& p2)
+        std::stringstream ss;
+        ss << "CIRCULARSTRING (" << p0 << ", " << p1 << ", " << p2 << ")";
+        return ss.str();
+    void checkArc(std::string message,
+                  const CoordinateXY& center, double radius, bool ccw, double from, double to,
+                  const CoordinateXY& p0, const CoordinateXY& p1, const CoordinateXY& p2) const
+        CircularArc arc(from, to, center, radius, ccw);
+        if (arc.p0.distance(p0) > eps || arc.p1.distance(p1) > eps || arc.p2.distance(p2) > eps) {
+            ensure_equals(message, toWKT(arc.p0, arc.p1, arc.p2), toWKT(p0, p1, p2));
 using group = test_group<test_circulararcs_data>;
@@ -188,11 +210,11 @@ void object::test<11>()
                   -1, -1, 2, 2);
-// collinear
 template<>
 template<>
+    set_test_name("envelope: arc defined by three collinear points");
     CoordinateXY p0{1, 2};
     CoordinateXY p1{2, 3};
@@ -202,11 +224,12 @@ void object::test<12>()
                   1, 2, 3, 4);
-// repeated
 template<>
 template<>
+    set_test_name("envelope: arc defined by three repeated points");
     CoordinateXY p0{3, 4};
     CoordinateXY p1{3, 4};
     CoordinateXY p2{3, 4};
@@ -217,9 +240,7 @@ void object::test<13>()
 template<>
 template<>
-void object::test<14>()
-    set_test_name("envelope: GH #1313");
+void object::test<14>() {
     CoordinateXY p0{2, 0};
     CoordinateXY p1{4, 2};
@@ -229,5 +250,60 @@ void object::test<14>()
     2, -1.0811388300841898, 5.08113883008419,2.08113883008419);
+template<>
+template<>
+void object::test<15>()
+    set_test_name("createArc");
+    constexpr bool CCW = true;
+    constexpr bool CW = false;
+    checkArc("CCW: upper half-circle", {0, 0}, 1, CCW, 0, MATH_PI, {1, 0}, {0, 1}, {-1, 0});
+    checkArc("CCW: lower half-circle", {0, 0}, 1, CCW, MATH_PI, 0, {-1, 0}, {0, -1}, {1, 0});
+    checkArc("CCW: left half-circle", {0, 0}, 1, CCW, MATH_PI/2, -MATH_PI/2, {0, 1}, {-1, 0}, {0, -1});
+    checkArc("CCW: right half-circle", {0, 0}, 1, CCW, -MATH_PI/2, MATH_PI/2, {0, -1}, {1, 0}, {0, 1});
+    checkArc("CW: upper half-circle", {0, 0}, 1, CW, MATH_PI, 0, {-1, 0}, {0, 1}, {1, 0});
+    checkArc("CW: lower half-circle", {0, 0}, 1, CW, 0, MATH_PI, {1, 0}, {0, -1}, {-1, 0});
+    checkArc("CW: left half-circle", {0, 0}, 1, CW, -MATH_PI/2, MATH_PI/2, {0, -1}, {-1, 0}, {0, 1});
+    checkArc("CW: right half-circle", {0, 0}, 1, CW, MATH_PI/2, -MATH_PI/2, {0, 1}, {1, 0}, {0, -1});
+template<>
+template<>
+void object::test<16>()
+    set_test_name("splitAtPoint");
+    CircularArc cwArc({-1, 0}, {0, 1}, {1, 0});
+    auto [arc1, arc2] = cwArc.splitAtPoint({std::sqrt(2)/2, std::sqrt(2)/2});
+    ensure_equals(arc1.p0, CoordinateXY{-1, 0});
+    ensure_equals(arc1.p2, CoordinateXY{std::sqrt(2)/2, std::sqrt(2)/2});
+    ensure_equals(arc1.getCenter(), cwArc.getCenter());
+    ensure_equals(arc1.getRadius(), cwArc.getRadius());
+    ensure_equals(arc2.p0, CoordinateXY{std::sqrt(2)/2, std::sqrt(2)/2});
+    ensure_equals(arc2.p2, CoordinateXY{1, 0});
+    ensure_equals(arc2.getCenter(), cwArc.getCenter());
+    ensure_equals(arc2.getRadius(), cwArc.getRadius());
+    ensure_equals(cwArc.getLength(), arc1.getLength() + arc2.getLength());
+template<>
+template<>
+void object::test<17>() {
+    set_test_name("getSagitta");
+    CircularArc halfCircle({-1, 0}, {0, 1}, {1, 0});
+    ensure_equals(halfCircle.getSagitta(), 1);
+    CircularArc quarterCircle({0, 1}, {std::sqrt(2)/2, std::sqrt(2)/2}, {1, 0});
+    ensure_equals(quarterCircle.getSagitta(),
+        CoordinateXY{std::sqrt(2)/2, std::sqrt(2)/2}.distance(CoordinateXY{0.5, 0.5}));
diff --git a/tests/unit/geom/CircularArcTest.cpp b/tests/unit/geom/CircularArcTest.cpp
index a1f730091..024820bb6 100644
--- a/tests/unit/geom/CircularArcTest.cpp
+++ b/tests/unit/geom/CircularArcTest.cpp
@@ -14,7 +14,8 @@ struct test_circulararc_data {
     const double eps = 1e-8;
-    void checkAngle(const CoordinateXY& p0, const CoordinateXY& p1, const CoordinateXY& p2, double expected) {
+    void checkAngle(const CoordinateXY& p0, const CoordinateXY& p1, const CoordinateXY& p2, double expected)
         CircularArc arc(p0, p1, p2);
         ensure_equals(p0.toString() + " / " + p1.toString() + " / " + p2.toString(), arc.getAngle(), expected, eps);
@@ -22,7 +23,8 @@ struct test_circulararc_data {
         ensure_equals(p2.toString() + " / " + p1.toString() + " / " + p0.toString(), rev.getAngle(), expected, eps);
-    void checkLength(const CoordinateXY& p0, const CoordinateXY& p1, const CoordinateXY& p2, double expected) {
+    void checkLength(const CoordinateXY& p0, const CoordinateXY& p1, const CoordinateXY& p2, double expected)
         ensure_equals(p0.toString() + " / " + p1.toString() + " / " + p2.toString(), arc.getLength(), expected, eps);
@@ -36,11 +38,12 @@ using object = group::object;
 group test_circulararc_group("geos::geom::CircularArc");
-// test angle() on unit circle
 template<>
 template<>
+    set_test_name("CircularArc::getAngle() on a unit circle");
     auto x = std::sqrt(2.0)/2;
     // full circle
@@ -65,27 +68,57 @@ void object::test<1>()
     checkAngle({x, -x}, {-1, 0}, {x, x}, 1.5*MATH_PI); // mouth right
-// test length()
 template<>
 template<>
+    set_test_name("CircularArc::getLength()");
     checkLength({1.6, 0.4}, {1.6, 0.5}, {1.7, 1}, 0.6122445326877711);
-// test getArea()
 template<>
 template<>
+    set_test_name("CircularArc::getArea()");
     ensure_equals("half circle, R=2", CircularArc({-2, 0}, {0, 2}, {2, 0}).getArea(), MATH_PI*2);
     ensure_equals("full circle, R=3", CircularArc({-3, 0}, {3, 0}, {-3, 0}).getArea(), MATH_PI*3*3);
-    ensure_equals("3/4, mouth up, R=2", CircularArc({-std::sqrt(2), std::sqrt(2)}, {0, -2}, {std::sqrt(2), std::sqrt(2)}).getArea(), MATH_PI*4 - 2*(MATH_PI/2-1), 1e-8);
+    ensure_equals("3/4, mouth up, R=2", CircularArc({-std::sqrt(2), std::sqrt(2)}, {0, -2}, {std::sqrt(2), std::sqrt(2)}).getArea(),
+                  MATH_PI*4 - 2*(MATH_PI/2-1), 1e-8);
-    ensure_equals("1/4, pointing up, R=2", CircularArc({-std::sqrt(2), std::sqrt(2)}, {0, 2}, {std::sqrt(2), std::sqrt(2)}).getArea(), 2*(MATH_PI/2-1), 1e-8);
+    ensure_equals("1/4, pointing up, R=2", CircularArc({-std::sqrt(2), std::sqrt(2)}, {0, 2}, {std::sqrt(2), std::sqrt(2)}).getArea(),
+                  2*(MATH_PI/2-1), 1e-8);
+template<>
+template<>
+    set_test_name("CircularArc::isLinear()");
+    ensure_equals("not linear", CircularArc({-1, 0}, {0, 1}, {1, 0}).isLinear(), false);
+    ensure_equals("linear", CircularArc({0, 0}, {1, 1}, {2, 2}).isLinear(), true);
+template<>
+template<>
+    set_test_name("CircularArc::containsPointOnCircle");
+    // complete circle
+    CircularArc({5, 0}, {-5, 0}, {5, 0}).containsPointOnCircle({5, 0});
+    CircularArc({5, 0}, {-5, 0}, {5, 0}).containsPointOnCircle({4, 3});
+    // lower semi-circle
+    CircularArc({-5, 0}, {0, -5}, {5, 0}).containsPointOnCircle({5, 0});
+    // upper semi-circle
+    CircularArc({-5, 0}, {0, 5}, {5, 0}).containsPointOnCircle({5, 0});
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index a4ddbe6a8..5d3993d10 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -113,16 +113,16 @@ instanceOf(InstanceType const* instance)
 inline void
-ensure_equals_xy(geos::geom::Coordinate const& actual,
-                  geos::geom::Coordinate const& expected)
+ensure_equals_xy(geos::geom::CoordinateXY const& actual,
+                  geos::geom::CoordinateXY const& expected)
     ensure_equals("Coordinate X", actual.x, expected.x );
     ensure_equals("Coordinate Y", actual.y, expected.y );
 inline void
-                  geos::geom::Coordinate const& expected,
+                  geos::geom::CoordinateXY const& expected,
                   double tol)
     ensure_equals("Coordinate X", actual.x, expected.x, tol );
Summary of changes:
 include/geos/algorithm/Angle.h                     |   9 +
 include/geos/algorithm/CircularArcIntersector.h    |  97 +++
 include/geos/algorithm/CircularArcs.h              |  12 +
 include/geos/geom/CircularArc.h                    |  78 +-
 include/geos/math/DD.h                             |   1 +
 .../geos/triangulate/quadedge/TrianglePredicate.h  |   2 +-
 src/algorithm/Angle.cpp                            |   9 +
 src/algorithm/CircularArcIntersector.cpp           | 328 ++++++++
 src/algorithm/CircularArcs.cpp                     | 100 ++-
 src/math/DD.cpp                                    |   5 +
 tests/unit/algorithm/AngleTest.cpp                 |  35 +-
 .../unit/algorithm/CircularArcIntersectorTest.cpp  | 884 +++++++++++++++++++++
 tests/unit/algorithm/CircularArcsTest.cpp          |  86 +-
 tests/unit/geom/CircularArcTest.cpp                |  49 +-
 tests/unit/utility.h                               |   8 +-
 15 files changed, 1648 insertions(+), 55 deletions(-)
 create mode 100644 include/geos/algorithm/CircularArcIntersector.h
 create mode 100644 src/algorithm/CircularArcIntersector.cpp
 create mode 100644 tests/unit/algorithm/CircularArcIntersectorTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
