[geos-commits] [SCM] GEOS branch 3.14 updated. 8f3c8a399e83179d69c43423763fd1df5beadca3
git at osgeo.org
git at osgeo.org
Wed Sep 17 16:16:29 PDT 2025
the project "GEOS".
The branch, 3.14 has been updated
via 8f3c8a399e83179d69c43423763fd1df5beadca3 (commit)
from 69b60f3ec4d94321862074c09d046107698eda97 (commit)
revisions in full, below.
commit 8f3c8a399e83179d69c43423763fd1df5beadca3
Author: Mike Taves <mwtoews at gmail.com>
Date: Thu Sep 18 11:09:26 2025 +1200
Add CMake check for std::filesystem availability (#1303)
diff --git a/tests/unit/CMakeLists.txt b/tests/unit/CMakeLists.txt
index 3c172f1bc..063c408ff 100644
--- a/tests/unit/CMakeLists.txt
+++ b/tests/unit/CMakeLists.txt
@@ -14,6 +14,35 @@ file(GLOB_RECURSE _sources ${CMAKE_CURRENT_LIST_DIR}/*.cpp CONFIGURE_DEPEND)
add_executable(test_geos_unit ${_sources})
unset(_sources)
+# test that std::filesystem header actually is there and works
+if(NOT CMAKE_REQUIRED_QUIET)
+ # CMake 3.17+ use CHECK_START/CHECK_PASS/CHECK_FAIL
+ message(STATUS "Checking if compiler supports std::filesystem")
+endif()
+set(_filename "${CMAKE_CURRENT_BINARY_DIR}/has_filesystem.cpp")
+write_file(${_filename} "\
+#include <filesystem>
+int main() {
+ std::filesystem::path pth {\"../\"};
+ return 0;
+try_compile(HAVE_STD_FILESYSTEM "${CMAKE_BINARY_DIR}/temp" "${_filename}")
+file(REMOVE "${_filename}")
+unset(_filename)
+if(HAVE_STD_FILESYSTEM)
+ if(NOT CMAKE_REQUIRED_QUIET)
+ message(STATUS "Checking if compiler supports std::filesystem - yes")
+ endif()
+ target_compile_definitions(test_geos_unit PRIVATE HAVE_STD_FILESYSTEM)
+else()
+ message(STATUS "Checking if compiler supports std::filesystem - no")
+ endif()
+ target_compile_definitions(test_geos_unit PRIVATE HAVE_STD_FILESYSTEM=0)
+endif()
find_package(Threads)
target_link_libraries(test_geos_unit PRIVATE geos geos_c Threads::Threads)
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index 575b4a928..a4ddbe6a8 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -33,11 +33,13 @@
#include <fstream>
#include <sstream>
+#ifndef HAVE_STD_FILESYSTEM
#if defined(__GNUC__) && !defined(__clang__)
#define HAVE_STD_FILESYSTEM (__GNUC__ > 8)
#else
#define HAVE_STD_FILESYSTEM 1
#endif
+#endif /* ifndef HAVE_STD_FILESYSTEM */
#if HAVE_STD_FILESYSTEM
#endif
Summary of changes:
tests/unit/CMakeLists.txt | 29 +++++++++++++++++++++++++++++
tests/unit/utility.h | 2 ++
2 files changed, 31 insertions(+)
hooks/post-receive
More information about the geos-commits
