[geos-commits] [SCM] GEOS branch main updated. ee89eae8faa1e8bf82c98d30ce35a3328e3d57ae
Wed Apr 1 08:53:42 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  ee89eae8faa1e8bf82c98d30ce35a3328e3d57ae (commit)
      from  1a8eb16b2c90598d71fd6e469c79ec0ce6bba33e (commit)
revisions in full, below.
commit ee89eae8faa1e8bf82c98d30ce35a3328e3d57ae
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Apr 1 11:53:19 2026 -0400
    GeometryFactory: add createSurface method (#1416)
diff --git a/include/geos/geom/GeometryFactory.h b/include/geos/geom/GeometryFactory.h
index 4b5dba01f..d58b4dfe7 100644
--- a/include/geos/geom/GeometryFactory.h
+++ b/include/geos/geom/GeometryFactory.h
@@ -308,6 +308,15 @@ public:
     std::unique_ptr<CurvePolygon> createCurvePolygon(std::unique_ptr<Curve>&& shell,
                                                      std::vector<std::unique_ptr<Curve>> && holes) const;
+    /// Construct a Surface, taking ownership of given arguments
+    /// If arguments are LinearRings, a Polygon will be returned.
+    /// Otherwise, a CurvePolygon will be returned.
+    std::unique_ptr<Surface> createSurface(std::unique_ptr<Curve>&& shell) const;
+    std::unique_ptr<Surface> createSurface(std::unique_ptr<Curve>&& shell,
+                                           std::vector<std::unique_ptr<Curve>> && holes) const;
     /// Construct an EMPTY LineString
     std::unique_ptr<LineString> createLineString(std::size_t coordinateDimension = 2) const;
     std::unique_ptr<LineString> createLineString(bool hasZ, bool hasM) const;
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index 152dd39a2..93dc39f61 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -635,6 +635,42 @@ const
     return std::unique_ptr<CurvePolygon>(new CurvePolygon(std::move(shell), std::move(holes), *this));
+/* public */
+std::unique_ptr<Surface>
+GeometryFactory::createSurface(std::unique_ptr<Curve> && shell)
+const
+    if (shell->getGeometryTypeId() == GEOS_LINEARRING) {
+        std::unique_ptr<LinearRing> shellLR(detail::down_cast<LinearRing*>(shell.release()));
+        return createPolygon(std::move(shellLR));
+    return createCurvePolygon(std::move(shell));
+/* public */
+GeometryFactory::createSurface(std::unique_ptr<Curve> && shell, std::vector<std::unique_ptr<Curve>> && holes)
+const
+    const bool returnPolygon = shell->getGeometryTypeId() == GEOS_LINEARRING && std::all_of(holes.begin(), holes.end(), [](const auto& hole) {
+        return hole->getGeometryTypeId() == GEOS_LINEARRING;
+    if (returnPolygon) {
+        std::vector<std::unique_ptr<LinearRing>> holesLR(holes.size());
+        for (std::size_t i = 0; i < holes.size(); i++) {
+            holesLR[i].reset(detail::down_cast<LinearRing*>(holes[i].release()));
+        return createPolygon(std::move(shellLR), std::move(holesLR));
+    return createCurvePolygon(std::move(shell), std::move(holes));
 /*public*/
 GeometryFactory::createLineString(std::size_t coordinateDimension) const
diff --git a/tests/unit/geom/GeometryFactoryTest.cpp b/tests/unit/geom/GeometryFactoryTest.cpp
index a0773b21b..7e80d6703 100644
--- a/tests/unit/geom/GeometryFactoryTest.cpp
+++ b/tests/unit/geom/GeometryFactoryTest.cpp
@@ -1455,5 +1455,63 @@ void object::test<41>
+template<>
+template<>
+void object::test<42>
+    set_test_name("createSurface");
+    using geos::geom::GEOS_POLYGON;
+    using geos::geom::GEOS_CURVEPOLYGON;
+    using geos::geom::Curve;
+    // LinearRing
+        auto shell = reader_.read<Curve>("LINEARRING (0 0, 1 0, 1 1, 0 0)");
+        ensure_equals(factory_->createSurface(std::move(shell))->getGeometryTypeId(), GEOS_POLYGON);
+    // LineString
+        auto shell = reader_.read<Curve>("LINESTRING (0 0, 1 0, 1 1, 0 0)");
+        ensure_equals(factory_->createSurface(std::move(shell))->getGeometryTypeId(), GEOS_CURVEPOLYGON);
+    // CompoundCurve, linear
+        auto shell = reader_.read<Curve>("COMPOUNDCURVE ((0 0, 1 0, 1 1, 0 0))");
+    // CircularString
+        auto shell = reader_.read<Curve>("CIRCULARSTRING (-1 0, 0 1, 1 0, 0 -1, -1 0)");
+    // CompoundCurve, curved
+        auto shell = reader_.read<Curve>("COMPOUNDCURVE (CIRCULARSTRING (0 0, 1 1, 2 0), (2 0, 0 0))");
+    // LinearRing shell, LinearRing hole
+        auto shell = reader_.read<Curve>("LINEARRING (0 0, 10 0, 10 10, 0 10, 0 0)");
+        auto hole = reader_.read<Curve>("LINEARRING (5 5, 7 5, 7 7, 5 7, 5 5)");
+        std::vector<std::unique_ptr<Curve>> holes;
+        holes.push_back(std::move(hole));
+        ensure_equals(factory_->createSurface(std::move(shell), std::move(holes))->getGeometryTypeId(), GEOS_POLYGON);
+    // LinearRing shell, CompoundCurve hole
+        auto hole = reader_.read<Curve>("COMPOUNDCURVE ((5 5, 7 5, 7 7, 5 7, 5 5))");
+        ensure_equals(factory_->createSurface(std::move(shell), std::move(holes))->getGeometryTypeId(), GEOS_CURVEPOLYGON);
 } // namespace tut
Summary of changes:
 include/geos/geom/GeometryFactory.h     |  9 +++++
 src/geom/GeometryFactory.cpp            | 36 ++++++++++++++++++++
 tests/unit/geom/GeometryFactoryTest.cpp | 58 +++++++++++++++++++++++++++++++++
 3 files changed, 103 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
