[geos-commits] [SCM] GEOS branch main updated. f92148794f989e64940eba0074c4cec9083b54c7
git at osgeo.org
git at osgeo.org
Thu Apr 2 05:36:44 PDT 2026
the project "GEOS".
The branch, main has been updated
via f92148794f989e64940eba0074c4cec9083b54c7 (commit)
via f9657108f95a58051ddd38d2f64e9a2af9d39bce (commit)
from 4a24df60ce8b4b36ded1b06d4507a1578cb4da77 (commit)
revisions in full, below.
commit f92148794f989e64940eba0074c4cec9083b54c7
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Mar 31 09:24:47 2026 -0400
ArcIntersectionAdder: Avoid processing some trivial intersections
diff --git a/include/geos/noding/ArcIntersectionAdder.h b/include/geos/noding/ArcIntersectionAdder.h
index e71822df4..0d606a60f 100644
--- a/include/geos/noding/ArcIntersectionAdder.h
+++ b/include/geos/noding/ArcIntersectionAdder.h
@@ -33,6 +33,11 @@ public:
void processIntersections(SegmentString& e0, std::size_t segIndex0, SegmentString& e1, std::size_t segIndex1) override;
private:
+ static bool isAdjacentSegments(std::size_t i1, std::size_t i2);
+ bool isTrivialIntersection(const PathString* e0, std::size_t segIndex0,
+ const PathString* e1, std::size_t segIndex1) const;
algorithm::CircularArcIntersector& m_intersector;
diff --git a/src/noding/ArcIntersectionAdder.cpp b/src/noding/ArcIntersectionAdder.cpp
index 61b9adae1..0232e2ae3 100644
--- a/src/noding/ArcIntersectionAdder.cpp
+++ b/src/noding/ArcIntersectionAdder.cpp
@@ -35,6 +35,10 @@ ArcIntersectionAdder::processIntersections(ArcString& e0, std::size_t segIndex0,
return;
+ if (isTrivialIntersection(&e0, segIndex0, &e1, segIndex1)) {
+ return;
for (std::uint8_t i = 0; i < m_intersector.getNumPoints(); i++) {
detail::down_cast<NodableArcString*>(&e0)->addIntersection(m_intersector.getPoint(i), segIndex0);
detail::down_cast<NodableArcString*>(&e1)->addIntersection(m_intersector.getPoint(i), segIndex1);
@@ -73,6 +77,33 @@ ArcIntersectionAdder::processIntersections(ArcString& e0, std::size_t segIndex0,
+bool
+ArcIntersectionAdder::isAdjacentSegments(std::size_t i1, std::size_t i2)
+ return (i1 > i2 ? i1 - i2 : i2 - i1) == 1;
+bool
+ArcIntersectionAdder::isTrivialIntersection(const PathString *e0, std::size_t segIndex0,
+ const PathString *e1, std::size_t segIndex1) const
+ if (e0 != e1) {
+ return false;
+ // TODO: If two ArcStrings form a circle they may have a trivial intersection with
+ // two points.
+ if (m_intersector.getNumPoints() != 1) {
+ return false;
+ if (isAdjacentSegments(segIndex0, segIndex1)) {
+ return true;
+ return false;
void
ArcIntersectionAdder::processIntersections(SegmentString& e0, std::size_t segIndex0, SegmentString& e1, std::size_t segIndex1)
@@ -90,11 +121,13 @@ ArcIntersectionAdder::processIntersections(SegmentString& e0, std::size_t segInd
return;
- // todo collinear?
+ return;
+ // TODO: Handle collinear segments
static_cast<NodedSegmentString&>(e0).addIntersection(m_intersector.getPoint(0), segIndex0);
\ No newline at end of file
commit f9657108f95a58051ddd38d2f64e9a2af9d39bce
Date: Wed Mar 25 08:30:24 2026 -0400
NodableArcString: Split output ArcStrings at node points
diff --git a/include/geos/noding/NodableArcString.h b/include/geos/noding/NodableArcString.h
index b7e438f8f..505cbbba6 100644
--- a/include/geos/noding/NodableArcString.h
+++ b/include/geos/noding/NodableArcString.h
@@ -33,7 +33,7 @@ public:
m_adds[segmentIndex].push_back(intPt);
- std::unique_ptr<ArcString> getNoded();
+ void getNoded(std::vector<std::unique_ptr<ArcString>>& splitArcs);
private:
std::map<size_t, std::vector<geom::CoordinateXYZM>> m_adds;
diff --git a/src/noding/GeometryNoder.cpp b/src/noding/GeometryNoder.cpp
index 7580b6e07..208f5885f 100644
--- a/src/noding/GeometryNoder.cpp
+++ b/src/noding/GeometryNoder.cpp
@@ -127,10 +127,14 @@ GeometryNoder::toGeometry(std::vector<std::unique_ptr<PathString>>& nodedEdges)
for(auto& path : nodedEdges) {
const auto& coords = path->getCoordinates();
+ bool isLinear = dynamic_cast<SegmentString*>(path.get());
+ // TODO: Make OrientedCoordinateArray not require strict equality of arc control points
OrientedCoordinateArray oca1(*coords);
// Check if an equivalent edge is known
if(ocas.insert(oca1).second) {
- if (dynamic_cast<SegmentString*>(path.get())) {
+ if (isLinear) {
lines.push_back(geomFact->createLineString(coords));
} else {
resultArcs = true;
diff --git a/src/noding/NodableArcString.cpp b/src/noding/NodableArcString.cpp
index 35969cac5..bbecddf99 100644
--- a/src/noding/NodableArcString.cpp
+++ b/src/noding/NodableArcString.cpp
@@ -3,7 +3,7 @@
* GEOS - Geometry Engine Open Source
* http://geos.osgeo.org
- * Copyright (C) 2025 ISciences, LLC
+ * Copyright (C) 2025-2026 ISciences, LLC
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
@@ -13,8 +13,10 @@
#include <geos/noding/NodableArcString.h>
+#include <geos/algorithm/Angle.h>
-#define DEBUG_NODABLE_ARC_STRING 0
+using geos::geom::CoordinateXYZM;
+using geos::geom::CircularArc;
namespace geos::noding {
@@ -36,96 +38,165 @@ NodableArcString::NodableArcString(std::vector<geom::CircularArc> arcs, const st
-std::unique_ptr<ArcString>
-NodableArcString::getNoded() {
+static
+std::vector<CoordinateXYZM> prepareArcPoints(const CircularArc& arc, std::vector<CoordinateXYZM> splitPoints)
+ const bool isCCW = arc.getOrientation() == algorithm::Orientation::COUNTERCLOCKWISE;
+ const geom::CoordinateXY& center = arc.getCenter();
+ const double paStart = geom::Quadrant::pseudoAngle(center, arc.p0());
+ std::vector<CoordinateXYZM> retained;
+ // Add starting point of input arc
+ CoordinateXYZM p0;
+ arc.getCoordinateSequence()->getAt(arc.getCoordinatePosition(), p0);
+ retained.push_back(p0);
+ std::sort(splitPoints.begin(), splitPoints.end(), [¢er, paStart, isCCW](const auto& p0, const auto& p1) {
+ double pa0 = geom::Quadrant::pseudoAngle(center, p0);
+ double pa1 = geom::Quadrant::pseudoAngle(center, p1);
+ if (isCCW) {
+ return pseudoAngleDiffCCW(paStart, pa0) < pseudoAngleDiffCCW(paStart, pa1);
+ } else {
+ return pseudoAngleDiffCCW(paStart, pa0) > pseudoAngleDiffCCW(paStart, pa1);
+ // Add ending point of input arc
+ CoordinateXYZM p2;
+ arc.getCoordinateSequence()->getAt(arc.getCoordinatePosition() + 2, p2);
+ splitPoints.push_back(p2);
+ for (const auto& p2 : splitPoints) {
+ auto& p0 = retained.back();
+ if (p2.equals2D(p0)) {
+ if (std::isnan(p0.z) && !std::isnan(p2.z)) {
+ p0.z = p2.z;
+ if (std::isnan(p0.m) && !std::isnan(p2.m)) {
+ p0.m = p2.m;
+ continue;
+ if (!arc.containsPointOnCircle(p2)) {
+ continue;
+ const auto p1 = algorithm::CircularArcs::getMidpoint(p0, p2, center, arc.getRadius(), isCCW);
+ if (p1.equals2D(p0) || p1.equals2D(p2)) {
+ continue;
+ // Reject split point where sub-arc midpoint doesn't fall inside arc
+ if (!arc.containsPointOnCircle(p1)) {
+ continue;
+ // Reject split point where computed doesn't fall between endpoints
+ const double t0 = algorithm::Angle::normalizePositive(arc.theta0());
+ const double t1 = algorithm::Angle::normalizePositive(algorithm::CircularArcs::getAngle(p1, center));
+ const double t2 = algorithm::Angle::normalizePositive(algorithm::CircularArcs::getAngle(p2, center));
+ if (algorithm::Angle::isWithinCCW(t1, t0, t2) != isCCW) {
+ continue;
+ retained.push_back(p2);
+ // Make sure that endpoint of split arc is unchanged
+ CoordinateXYZM& back = retained.back();
+ if (!back.equals2D(p2)) {
+ back.x = p2.x;
+ back.y = p2.y;
+ if (std::isnan(back.z) && !std::isnan(p2.z)) {
+ back.z = p2.z;
+ if (std::isnan(back.m) && !std::isnan(p2.m)) {
+ back.m = p2.m;
+ return retained;
+void
+NodableArcString::getNoded(std::vector<std::unique_ptr<ArcString>>& splitArcs) {
auto dstSeq = std::make_unique<geom::CoordinateSequence>(0, m_constructZ, m_constructM);
+ std::vector<geom::CircularArc> arcs;
- std::vector<geom::CircularArc> arcs;
- for (size_t i = 0; i < m_arcs.size(); i++) {
- if (const auto it = m_adds.find(i); it == m_adds.end()) {
- // No nodes added, just copy the coordinates into the sequence.
- const geom::CoordinateSequence* srcSeq = m_arcs[i].getCoordinateSequence();
- std::size_t srcPos = m_arcs[i].getCoordinatePosition();
- std::size_t dstPos = dstSeq->getSize();
- dstSeq->add(*srcSeq, srcPos, srcPos + 2, false);
- arcs.emplace_back(*dstSeq, dstPos);
- } else {
- std::vector<geom::CoordinateXYZM>& splitPoints = it->second;
+ for (size_t arcIndex = 0; arcIndex < m_arcs.size(); arcIndex++) {
+ const CircularArc& toSplit = m_arcs[arcIndex];
+ const geom::CoordinateXY& center = toSplit.getCenter();
+ const double radius = toSplit.getRadius();
+ const int orientation = toSplit.getOrientation();
- // TODO check split point actually inside arc?
+ bool arcIsSplit = true;
+ std::vector<CoordinateXYZM> arcPoints;
+ const auto it = m_adds.find(arcIndex);
+ if (it == m_adds.end()) {
+ arcIsSplit = false;
+ } else {
+ arcPoints = prepareArcPoints(toSplit, it->second);
- const geom::CircularArc& toSplit = m_arcs[i];
- const geom::CoordinateXY& center = toSplit.getCenter();
- const double radius = toSplit.getRadius();
- const int orientation = toSplit.getOrientation();
- const bool isCCW = orientation == algorithm::Orientation::COUNTERCLOCKWISE;
- const double paStart = geom::Quadrant::pseudoAngle(center, toSplit.p0());
- std::sort(splitPoints.begin(), splitPoints.end(), [¢er, paStart, isCCW](const auto& p0, const auto& p1) {
- double pa0 = geom::Quadrant::pseudoAngle(center, p0);
- double pa1 = geom::Quadrant::pseudoAngle(center, p1);
- if (isCCW) {
- return pseudoAngleDiffCCW(paStart, pa0) < pseudoAngleDiffCCW(paStart, pa1);
- } else {
- return pseudoAngleDiffCCW(paStart, pa0) > pseudoAngleDiffCCW(paStart, pa1);
-#if DEBUG_NODABLE_ARC_STRING
- std::cout << "Splitting " << toSplit.toString() << " " << (isCCW ? "CCW" : "CW") << " paStart " << paStart << " paStop " << geom::Quadrant::pseudoAngle(center, toSplit.p2()) << std::endl;
- for (const auto& splitPt : splitPoints)
- const double pa = geom::Quadrant::pseudoAngle(center, splitPt);
- std::cout << " " << splitPt.toString() << " (pa " << pa << " diff " << pseudoAngleDiffCCW(paStart, pa) << ")" << std::endl;
-#endif
- // Add first point of split arc
- dstSeq->add(*toSplit.getCoordinateSequence(), toSplit.getCoordinatePosition(), toSplit.getCoordinatePosition());
- geom::CoordinateXYZM p0, p2;
- dstSeq->getAt(dstPos, p0);
- // Add intermediate points of split arc
- for (const auto& splitPoint : splitPoints) {
- if (arcs.empty()) {
- if (splitPoint.equals2D(p0)) {
- continue;
- } else if (splitPoint.equals2D(arcs.back().p2())) {
- continue;
- geom::CoordinateXYZM midpoint(algorithm::CircularArcs::getMidpoint(p0, splitPoint, center, radius, isCCW));
- midpoint.z = (p0.z + splitPoint.z) / 2;
- midpoint.m = (p0.m + splitPoint.m) / 2;
- dstSeq->add(midpoint);
- dstSeq->add(splitPoint);
- p0 = splitPoint;
- arcs.emplace_back(*dstSeq, dstPos, center, radius, orientation);
- dstPos = dstSeq->getSize() - 1;
- // Add last point of split arc
- toSplit.getCoordinateSequence()->getAt(toSplit.getCoordinatePosition() + 2, p2);
- if (arcs.empty() || !arcs.back().p2().equals2D(p2)) {
- geom::CoordinateXYZM midpoint(algorithm::CircularArcs::getMidpoint(p0, p2, center, radius, isCCW));
- midpoint.z = (p0.z + p2.z) / 2;
- midpoint.m = (p0.m + p2.m) / 2;
- dstSeq->add(p2);
+ if (arcPoints.size() == 2) {
+ // All added nodes collapsed
- return std::make_unique<NodableArcString>(std::move(arcs), std::move(dstSeq), m_constructZ, m_constructM, nullptr);
+ if (!arcIsSplit) {
+ // No nodes added, just copy the coordinates into the sequence.
+ const geom::CoordinateSequence* srcSeq = m_arcs[arcIndex].getCoordinateSequence();
+ std::size_t srcPos = m_arcs[arcIndex].getCoordinatePosition();
+ dstSeq->add(*srcSeq, srcPos, srcPos + 2, false);
+ std::size_t dstPos = dstSeq->getSize() - 3;
+ arcs.emplace_back(*dstSeq, dstPos, center, radius, orientation);
+ continue;
+ const bool isCCW = orientation == algorithm::Orientation::COUNTERCLOCKWISE;
+ for (std::size_t i = 1; i < arcPoints.size(); i++) {
+ const CoordinateXYZM& p0 = arcPoints[i - 1];
+ const CoordinateXYZM& p2 = arcPoints[i];
+ CoordinateXYZM p1(algorithm::CircularArcs::getMidpoint(p0, p2, center, radius, isCCW));
+ p1.z = (p0.z + p2.z) / 2;
+ p1.m = (p0.m + p2.m) / 2;
+ if (dstSeq->isEmpty()) {
+ dstSeq->add(p0);
+ dstSeq->add(p1);
+ dstSeq->add(p2);
+ const std::size_t dstPos = dstSeq->getSize() - 3;
+ // Finish the ArcString, start a new one.
+ splitArcs.push_back(std::make_unique<NodableArcString>(std::move(arcs), std::move(dstSeq), m_constructZ, m_constructM, nullptr));
+ dstSeq = std::make_unique<geom::CoordinateSequence>(0, m_constructZ, m_constructM);
+ arcs.clear();
+ if (!arcs.empty()) {
diff --git a/src/noding/SimpleNoder.cpp b/src/noding/SimpleNoder.cpp
index 496de6070..a35c0ee83 100644
--- a/src/noding/SimpleNoder.cpp
+++ b/src/noding/SimpleNoder.cpp
@@ -85,8 +85,12 @@ SimpleNoder::getNodedPaths()
nodedPaths.push_back(std::move(segString));
} else {
+ std::vector<std::unique_ptr<ArcString>> tmp;
auto* nas = detail::down_cast<NodableArcString*>(ps);
- nodedPaths.push_back(nas->getNoded());
+ nas->getNoded(tmp);
+ for (auto& arcString : tmp) {
+ nodedPaths.push_back(std::move(arcString));
diff --git a/tests/unit/capi/GEOSNodeTest.cpp b/tests/unit/capi/GEOSNodeTest.cpp
index e1356e44e..8feb5df96 100644
--- a/tests/unit/capi/GEOSNodeTest.cpp
+++ b/tests/unit/capi/GEOSNodeTest.cpp
@@ -212,8 +212,12 @@ void object::test<9>()
ensure(result_ != nullptr);
expected_ = fromWKT("MULTICURVE ("
- "CIRCULARSTRING (0 0, 0.0340741737 0.2588190451, 0.1339745962 0.5, 1 1, 1.8660254038 0.5, 1.9659258263 0.2588190451, 2 0),"
- "CIRCULARSTRING (0 1, 0.0340741737 0.7411809549, 0.1339745962 0.5, 1 0, 1.8660254038 0.5, 1.9659258263 0.7411809549, 2 1))");
+ "CIRCULARSTRING (0 0, 0.0340741737 0.2588190451, 0.1339745962 0.5),"
+ "CIRCULARSTRING (0.1339745962 0.5, 1 1, 1.8660254038 0.5),"
+ "CIRCULARSTRING (1.8660254038 0.5, 1.9659258263 0.2588190451, 2 0),"
+ "CIRCULARSTRING (0 1, 0.0340741737 0.7411809549, 0.1339745962 0.5),"
+ "CIRCULARSTRING (0.1339745962 0.5, 1 0, 1.8660254038 0.5),"
+ "CIRCULARSTRING (1.8660254038 0.5, 1.9659258263 0.7411809549, 2 1))");
ensure_geometry_equals_exact(result_, expected_, 1e-8);
@@ -222,7 +226,7 @@ template<>
template<>
void object::test<10>()
- set_test_name("CIRCULARSTRING ZM intersecting CIRCULARSTRING M");
+ set_test_name("CIRCULARSTRING ZM intersecting CIRCULARSTRING M at endpoint and interior");
input_ = fromWKT("MULTICURVE (CIRCULARSTRING ZM (-1 0 3 4, 0 1 2 5, 1 0 4 7), CIRCULARSTRING M (-1 2 9, 0 1 13, -1 0 17))");
ensure(input_);
@@ -231,12 +235,12 @@ void object::test<10>()
expected_ = fromWKT("MULTICURVE ZM ("
- "CIRCULARSTRING ZM (-1 0 3 4, -0.7071067812 0.7071067812 2.5 6.5, -5.5511151231e-17 1 2 9, 0.7071067812 0.7071067812 3 8, 1 0 4 7),"
- "CIRCULARSTRING ZM (-1 2 NaN 9, -0.2928932188 1.7071067812 NaN 9, -5.5511151231e-17 1 2 9, -0.2928932188 0.2928932188 2.5 6.5, -1 0 3 4))");
+ "CIRCULARSTRING ZM (-1 0 3 4, -0.7071067812 0.7071067812 2.5 6.5, -5.5511151231e-17 1 2 9),"
+ "CIRCULARSTRING ZM (-5.5511151231e-17 1 2 9, 0.7071067812 0.7071067812 3 8, 1 0 4 7),"
+ "CIRCULARSTRING ZM (-1 2 NaN 9, -0.2928932188 1.7071067812 NaN 9, -5.5511151231e-17 1 2 9),"
+ "CIRCULARSTRING ZM (-5.5511151231e-17 1 2 9, -0.2928932188 0.2928932188 2.5 6.5, -1 0 3 4))");
- ensure_equals(GEOSGetNumGeometries(result_), 2);
- ensure_equals("Noded arc 1 should have 5 points", GEOSGeomGetNumPoints(GEOSGetGeometryN(result_, 0)), 5);
- ensure_equals("Noded arc 2 should have 5 points", GEOSGeomGetNumPoints(GEOSGetGeometryN(result_, 1)), 5);
+ ensure_equals(GEOSGetNumGeometries(result_), 4);
ensure_equals_exact_geometry_xyzm(reinterpret_cast<Geometry*>(result_),
reinterpret_cast<Geometry*>(expected_), 1e-8);
@@ -255,7 +259,8 @@ void object::test<11>()
- "CIRCULARSTRING ZM (-5 0 3 4, -3.5355 3.5355 3 6, 0 5 3 8, 2.2361 4.4721 3.5 7.5, 4 3 4 7),"
+ "CIRCULARSTRING ZM (-5 0 3 4, -3.5355 3.5355 3 6, 0 5 3 8),"
+ "CIRCULARSTRING ZM (0 5 3 8, 2.2361 4.4721 3.5 7.5, 4 3 4 7),"
"LINESTRING ZM (0 0 NaN 7, 0 5 3 8),"
"LINESTRING ZM (0 5 3 8, 0 10 NaN 13))");
@@ -274,13 +279,17 @@ void object::test<12>()
"CIRCULARSTRING (-4 3, 0 5, 4 3))");
result_ = GEOSNode(input_);
+ ensure(result_);
- "CIRCULARSTRING (-5.0000000000000000 0.0000000000000000, -4.7434164902525691 1.5811388300841900, -4.0000000000000000 3.0000000000000000, 0.0000000000000003 5.0000000000000000, 4.0000000000000000 3.0000000000000000, 4.7434164902525691 1.5811388300841898, 5.0000000000000000 0.0000000000000000),"
- "CIRCULARSTRING (-4.0000000000000000 3.0000000000000000, 0.0000000000000003 5.0000000000000000, 4.0000000000000000 3.0000000000000000))");
+ "CIRCULARSTRING (-5 0, -4.7434164902525691 1.5811388300841900, -4 3),"
+ "CIRCULARSTRING (-4 3, 0 5, 4 3),"
+ "CIRCULARSTRING (-4 3, 0 5, 4 3)," // FIXME this component is not removed by OrientedCoordinateArray because
+ // its control point differs slightly from the previous one
+ "CIRCULARSTRING (4 3, 4.7434164902525691 1.5811388300841898, 5 0))");
- ensure_equals_exact_geometry_xyzm(reinterpret_cast<Geometry*>(result_),
- reinterpret_cast<Geometry*>(expected_), 1e-4);
+ ensure_equals_geometry_xyzm(reinterpret_cast<Geometry*>(result_),
+ reinterpret_cast<Geometry*>(expected_), 1e-4);
template<>
@@ -349,7 +358,7 @@ void object::test<16>()
- expected_ = fromWKT("MULTICURVE Z (CIRCULARSTRING Z (-5 0 3, -1.5811388301 4.7434164903 4.5, 4 3 6), (0 0 NaN, 4 3 6))");
+ expected_ = fromWKT("MULTICURVE Z (CIRCULARSTRING Z (-5 0 3, -4 3 5, 4 3 6), (0 0 NaN, 4 3 6))");
@@ -367,5 +376,27 @@ void object::test<17>()
ensure(result_);
+template<>
+template<>
+void object::test<18>()
+ set_test_name("Multi-section CircularStrings with single interior intersection");
+ input_ = fromWKT("MULTICURVE ("
+ "CIRCULARSTRING (-5 0, -4 3, 0 5, 3 4, 4 3),"
+ "CIRCULARSTRING (3 5, 4 4, 2 3))"
+ result_ = GEOSNode(input_);
+ ensure(result_);
+ expected_ = fromWKT("MULTICURVE (CIRCULARSTRING (-5 0, -4 3, 0 5, 2.1154124423 4.5304558489, 3.8335130689 3.2100120795), CIRCULARSTRING (3.8335130689 3.2100120795, 3.918163858 3.1061216946, 4 3), CIRCULARSTRING (3 5, 3.9016950794 4.3308190803, 3.8335130689 3.2100120795), CIRCULARSTRING (3.8335130689 3.2100120795, 2.9674441042 2.6624775822, 2 3))");
+ ensure_equals_exact_geometry_xyzm(reinterpret_cast<Geometry*>(result_),
} // namespace tut
diff --git a/tests/unit/noding/NodableArcStringTest.cpp b/tests/unit/noding/NodableArcStringTest.cpp
index 7c90e3831..4bdedad95 100644
--- a/tests/unit/noding/NodableArcStringTest.cpp
+++ b/tests/unit/noding/NodableArcStringTest.cpp
@@ -8,6 +8,7 @@ using geos::geom::CircularArc;
using geos::geom::Ordinate;
using geos::geom::CoordinateXY;
+using geos::noding::ArcString;
using geos::noding::NodableArcString;
namespace tut {
@@ -20,7 +21,7 @@ struct test_nodablearcstring_data {
using XYZM = CoordinateXYZM;
static void test_add_points(const CircularArc& arc, const std::vector<CoordinateXY>& coords,
- const std::vector<CircularArc>& expected, bool reversed=false) {
+ const std::vector<std::vector<CircularArc>>& expected, bool reversed=false) {
std::vector<CircularArc> arcs;
arcs.push_back(arc);
NodableArcString nas(arcs, nullptr, false, false, nullptr);
@@ -29,20 +30,27 @@ struct test_nodablearcstring_data {
nas.addIntersection(coord, 0);
- auto noded = nas.getNoded();
+ std::vector<std::unique_ptr<ArcString>> noded;
+ nas.getNoded(noded);
- ensure_equals(noded->getSize(), expected.size());
+ ensure_equals(noded.size(), expected.size());
- for (std::size_t i = 0; i < expected.size(); i++) {
- ensure_arc_equals(noded->getArc(i), expected[i], 1e-8);
+ for (std::size_t i = 0; i < noded.size(); i++) {
+ for (std::size_t j = 0; j < noded[i]->getSize(); j++) {
+ ensure_arc_equals(noded[i]->getArc(j), expected[i][j], 1e-8);
if (!reversed) {
const auto revArc = arc.reverse();
- std::vector<CircularArc> revExpected;
+ std::vector<std::vector<CircularArc>> revExpected;
for (const auto& x : expected) {
- revExpected.push_back(x.reverse());
+ revExpected.push_back(x);
+ std::reverse(revExpected.back().begin(), revExpected.back().end());
+ for (auto& y : revExpected.back()) {
+ y = y.reverse();
std::reverse(revExpected.begin(), revExpected.end());
@@ -74,12 +82,12 @@ void object::test<1>()
coords.emplace_back(-3, 4);
coords.emplace_back(-4, 3);
- std::vector<CircularArc> expected;
- expected.push_back(CircularArc::create(XY{-5, 0}, {-4, 3}, {0, 0}, 5, Orientation::CLOCKWISE));
- expected.push_back(CircularArc::create(XY{-4, 3}, {-3, 4}, {0, 0}, 5, Orientation::CLOCKWISE));
- expected.push_back(CircularArc::create(XY{-3, 4}, {3, 4}, {0, 0}, 5, Orientation::CLOCKWISE));
- expected.push_back(CircularArc::create(XY{3, 4}, {4, 3}, {0, 0}, 5, Orientation::CLOCKWISE));
- expected.push_back(CircularArc::create(XY{4, 3}, {5, 0}, {0, 0}, 5, Orientation::CLOCKWISE));
+ std::vector<std::vector<CircularArc>> expected;
+ expected.push_back({CircularArc::create(XY{-5, 0}, {-4, 3}, {0, 0}, 5, Orientation::CLOCKWISE)});
+ expected.push_back({CircularArc::create(XY{-4, 3}, {-3, 4}, {0, 0}, 5, Orientation::CLOCKWISE)});
+ expected.push_back({CircularArc::create(XY{-3, 4}, {3, 4}, {0, 0}, 5, Orientation::CLOCKWISE)});
+ expected.push_back({CircularArc::create(XY{3, 4}, {4, 3}, {0, 0}, 5, Orientation::CLOCKWISE)});
+ expected.push_back({CircularArc::create(XY{4, 3}, {5, 0}, {0, 0}, 5, Orientation::CLOCKWISE)});
test_add_points(in, coords, expected);
@@ -99,13 +107,13 @@ void object::test<2>()
coords.emplace_back(3, 4);
coords.emplace_back(5, 0);
- expected.push_back(CircularArc::create(XY{0, 5}, {3, 4}, {0, 0}, 5, Orientation::CLOCKWISE));
- expected.push_back(CircularArc::create(XY{5, 0}, {4, -3}, {0, 0}, 5, Orientation::CLOCKWISE));
- expected.push_back(CircularArc::create(XY{4, -3}, {3, -4}, {0, 0}, 5, Orientation::CLOCKWISE));
- expected.push_back(CircularArc::create(XY{3, -4}, {0, -5}, {0, 0}, 5, Orientation::CLOCKWISE));
+ expected.push_back({CircularArc::create(XY{0, 5}, {3, 4}, {0, 0}, 5, Orientation::CLOCKWISE)});
+ expected.push_back({CircularArc::create(XY{5, 0}, {4, -3}, {0, 0}, 5, Orientation::CLOCKWISE)});
+ expected.push_back({CircularArc::create(XY{4, -3}, {3, -4}, {0, 0}, 5, Orientation::CLOCKWISE)});
+ expected.push_back({CircularArc::create(XY{3, -4}, {0, -5}, {0, 0}, 5, Orientation::CLOCKWISE)});
@@ -118,8 +126,8 @@ void object::test<3>()
CircularArc in = CircularArc::create(CoordinateXY{-1, 0}, CoordinateXY{0, 1}, CoordinateXY{1, 0});
std::vector<CoordinateXY> coords;
- expected.push_back(in);
+ expected.push_back({in});
@@ -147,15 +155,16 @@ void object::test<4>()
nas.addIntersection( intPt, 0);
- ensure_equals(noded->getSize(), 2u);
- const CircularArc& arc0 = noded->getArc(0);
+ ensure_equals(noded.size(), 2u);
+ const CircularArc& arc0 = noded[0]->getArc(0);
ensure_arc_equals(arc0, CircularArc::create(p0, intPt, arc.getCenter(), arc.getRadius(), arc.getOrientation()), 1e-8);
ensure_equals(arc0.p1<CoordinateXYZM>().z, (p0.z + intPt.z) / 2);
ensure_equals(arc0.p1<CoordinateXYZM>().m, (p0.m + intPt.m) / 2);
- const CircularArc& arc1 = noded->getArc(1);
+ const CircularArc& arc1 = noded[1]->getArc(0);
ensure_arc_equals(arc1, CircularArc::create(intPt, p2, arc.getCenter(), arc.getRadius(), arc.getOrientation()), 1e-8);
ensure_equals(arc1.p1<CoordinateXYZM>().z, (intPt.z + p2.z) / 2);
ensure_equals(arc1.p1<CoordinateXYZM>().m, (intPt.m + p2.m) / 2);
Summary of changes:
include/geos/noding/ArcIntersectionAdder.h | 5 +
include/geos/noding/NodableArcString.h | 2 +-
src/noding/ArcIntersectionAdder.cpp | 39 ++++-
src/noding/GeometryNoder.cpp | 6 +-
src/noding/NodableArcString.cpp | 243 +++++++++++++++++++----------
src/noding/SimpleNoder.cpp | 6 +-
tests/unit/capi/GEOSNodeTest.cpp | 61 ++++++--
tests/unit/noding/NodableArcStringTest.cpp | 61 +++++---
8 files changed, 290 insertions(+), 133 deletions(-)
hooks/post-receive
More information about the geos-commits
