[geos-commits] [SCM] GEOS branch main updated. 3cee790e4d6f87feb09864b1941cce6b3fb7fbaf
Tue Apr 7 07:41:07 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  3cee790e4d6f87feb09864b1941cce6b3fb7fbaf (commit)
      from  52dc9337bc485361adfa0e3e0f0c135ceb4ccbdd (commit)
revisions in full, below.
commit 3cee790e4d6f87feb09864b1941cce6b3fb7fbaf
Author: Daniel Baston <dbaston at gmail.com>
Date:   Tue Apr 7 10:40:47 2026 -0400
    OverlayEdge: Avoid unintended ring rotation (#1412)
diff --git a/src/operation/overlayng/OverlayEdge.cpp b/src/operation/overlayng/OverlayEdge.cpp
index 8716e1503..31992b881 100644
--- a/src/operation/overlayng/OverlayEdge.cpp
+++ b/src/operation/overlayng/OverlayEdge.cpp
@@ -55,7 +55,7 @@ OverlayEdge::getCoordinatesOriented() const
 void
 OverlayEdge::addCoordinates(CoordinateSequence* coords) const
-    bool isFirstEdge = coords->size() > 0;
+    const bool isFirstEdge = coords->isEmpty();
     if (direction) {
         std::size_t startIndex = 1;
         if (isFirstEdge) {
diff --git a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
index 4c604a183..2c70f84d3 100644
--- a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
@@ -333,12 +333,10 @@ void object::test<24>()
     // https://github.com/libgeos/geos/issues/1365{
     set_test_name("M value retained on last point");
-    input_ = fromWKT("POLYGON ZM ((0 0 0 0, 0 1 1 1, 1 1 2 3, 1 0 4 5, 0 0 6 7))");
-    expected_ = fromWKT("POLYGON ZM ((0 1 1 1, 1 1 2 3, 1 0 4 5, 0 0 6 7, 0 1 1 1))");
+    input_ = fromWKT("POLYGON ZM ((0 0 6 7, 0 1 1 1, 1 1 2 3, 1 0 4 5, 0 0 6 7))");
     result_ = GEOSGeom_setPrecision(input_, 0.1, 0);
-    ensure(GEOSEqualsIdentical(result_, expected_));
+    ensure_geometry_equals_identical(result_, input_);
 } // namespace tut
diff --git a/tests/unit/capi/GEOSMakeValidTest.cpp b/tests/unit/capi/GEOSMakeValidTest.cpp
index 0cad2e552..44ec52c84 100644
--- a/tests/unit/capi/GEOSMakeValidTest.cpp
+++ b/tests/unit/capi/GEOSMakeValidTest.cpp
@@ -125,7 +125,8 @@ void object::test<7>()
     ensure(input_);
     result_ = GEOSMakeValid(input_);
-    expected_ = fromWKT("MULTIPOLYGON ZM (((0 0 1 2, 0.5 0.5 2.5 3.5, 1 0 2 3, 0 0 1 2)), ((1 1 4 5, 0.5 0.5 2.5 3.5, 0 1 3 4, 1 1 4 5)))");
+    expected_ = fromWKT("MULTIPOLYGON ZM (((0.5 0.5 2.5 3.5, 1 0 2 3, 0 0 1 2, 0.5 0.5 2.5 3.5)), ((0.5 0.5 2.5 3.5, 0 1 3 4, 1 1 4 5, 0.5 0.5 2.5 3.5)))");
     ensure_geometry_equals_identical(result_, expected_);
diff --git a/tests/unit/capi/GEOSSubdivideByGridTest.cpp b/tests/unit/capi/GEOSSubdivideByGridTest.cpp
index d734c5bca..fc4398fb6 100644
--- a/tests/unit/capi/GEOSSubdivideByGridTest.cpp
+++ b/tests/unit/capi/GEOSSubdivideByGridTest.cpp
@@ -50,7 +50,7 @@ void object::test<2>()
     result_ = GEOSSubdivideByGrid(input_, 1, 0, 5, 3, 4, 3, true);
-    ensure_geometry_equals_identical(expected_, result_);
+    ensure_geometry_equals(expected_, result_);
\ No newline at end of file
Summary of changes:
 src/operation/overlayng/OverlayEdge.cpp       | 2 +-
 tests/unit/capi/GEOSGeom_setPrecisionTest.cpp | 6 ++----
 tests/unit/capi/GEOSMakeValidTest.cpp         | 3 ++-
 tests/unit/capi/GEOSSubdivideByGridTest.cpp   | 2 +-
 4 files changed, 6 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
