[geos-commits] [SCM] GEOS branch main updated. 6e7863754410956b182ff8b687251e7f429ed67d
git at osgeo.org
git at osgeo.org
Sun Aug 2 14:26:11 PDT 2026
the project "GEOS".
The branch, main has been updated
via 6e7863754410956b182ff8b687251e7f429ed67d (commit)
from a03789b339d5adfe3930ee7e972cb156030398f4 (commit)
revisions in full, below.
commit 6e7863754410956b182ff8b687251e7f429ed67d
Author: dependabot[bot] <49699333+dependabot[bot]@users.noreply.github.com>
Date: Mon Aug 3 09:25:38 2026 +1200
Bump the all-actions group with 4 updates (#1496)
Bumps the all-actions group with 4 updates:
- Updates `actions/checkout` from 7.0.0 to 7.0.1
- Updates `vmactions/freebsd-vm` from 1.5.0 to 1.5.2
- Updates `github/codeql-action` from 4.36.2 to 4.37.3
- Updates `docker/login-action` from 4 to 4.5.1
Signed-off-by: dependabot[bot] <support at github.com>
Co-authored-by: dependabot[bot] <49699333+dependabot[bot]@users.noreply.github.com>
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 6df0cef55..8058675e1 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -197,7 +197,7 @@ jobs:
python3 -m pip install --disable-pip-version-check --user cmake==${{ matrix.ci.cmake }}
echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
- - uses: actions/checkout at v7.0.0
+ - uses: actions/checkout at v7.0.1
- name: Retrieve build cache
uses: actions/cache/restore at v6.1.0
@@ -281,7 +281,7 @@ jobs:
build_type: ['Debug', 'Release']
steps:
- name: 'Setup'
uses: msys2/setup-msys2 at v2
@@ -337,7 +337,7 @@ jobs:
arch: arm64
steps:
# ccache not supported for this generator and/or Debug
@@ -378,7 +378,7 @@ jobs:
runs-on: ${{ matrix.ci.os }}
steps:
@@ -459,7 +459,7 @@ jobs:
which clang++
clang++ --version
@@ -495,7 +495,7 @@ jobs:
runs-on: ubuntu-latest
steps:
@@ -506,7 +506,7 @@ jobs:
restore-keys: freebsd
- name: Build and test
- uses: vmactions/freebsd-vm at v1.5.0
+ uses: vmactions/freebsd-vm at v1.5.2
with:
release: "15.0"
envs: CCACHE_COMPRESS CCACHE_COMPRESSLEVEL CCACHE_MAXSIZE
@@ -540,7 +540,7 @@ jobs:
sudo -E apt-get autopurge -y needrestart
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make cmake emscripten ccache
@@ -582,7 +582,7 @@ jobs:
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
python3 -m pip install --disable-pip-version-check --user codespell
- name: 'cppcheck'
run: ./tools/cppcheck.sh
@@ -605,7 +605,7 @@ jobs:
python3 -m pip install --disable-pip-version-check --user cmake==3.15.*
with:
path: geos
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index 3b2190fcf..a42d66e77 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -36,11 +36,11 @@ jobs:
# Learn more about CodeQL language support at https://aka.ms/codeql-docs/language-support
steps:
# Initializes the CodeQL tools for scanning.
- name: Initialize CodeQL
- uses: github/codeql-action/init at v4.36.2
+ uses: github/codeql-action/init at v4.37.3
with:
languages: ${{ matrix.language }}
# If you wish to specify custom queries, you can do so here or in a config file.
@@ -63,6 +63,6 @@ jobs:
make -j$(nproc)
- name: Perform CodeQL Analysis
- uses: github/codeql-action/analyze at v4.36.2
+ uses: github/codeql-action/analyze at v4.37.3
with:
category: "/language:${{matrix.language}}"
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 8689d26ad..649c23048 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -24,7 +24,7 @@ jobs:
steps:
- name: Docker meta
@@ -40,7 +40,7 @@ jobs:
type=sha,prefix=
- name: Login to GitHub Container Registry
- uses: docker/login-action at v4
+ uses: docker/login-action at v4.5.1
with:
registry: ghcr.io
username: ${{ github.repository_owner }}
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
index 309573c6b..60dcffee5 100644
--- a/.github/workflows/release.yml
+++ b/.github/workflows/release.yml
@@ -32,7 +32,7 @@ jobs:
uname -a
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
- name: Get tag
diff --git a/.github/workflows/web.yml b/.github/workflows/web.yml
index 152377359..851d6f820 100644
--- a/.github/workflows/web.yml
+++ b/.github/workflows/web.yml
@@ -27,7 +27,7 @@ jobs:
- name: 'Check Out 📗'
+ uses: actions/checkout at v7.0.1
- name: 'Hugo Build 🛠'
# ...or replace 'master' with a full version tag, such as: v0.64.1
Summary of changes:
.github/workflows/ci.yml | 20 ++++++++++----------
.github/workflows/codeql.yml | 6 +++---
.github/workflows/container.yml | 4 ++--
.github/workflows/release.yml | 2 +-
.github/workflows/web.yml | 2 +-
5 files changed, 17 insertions(+), 17 deletions(-)
hooks/post-receive
More information about the geos-commits
