[geos-commits] [SCM] GEOS branch main updated. 14fd2d70311aae9646e5d2e5364921822074de2b
Sun Aug 9 05:33:51 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  14fd2d70311aae9646e5d2e5364921822074de2b (commit)
       via  59a36b35cfe4c51019ba0f673473e1c1155b5d8e (commit)
      from  5b62cd06ceeee053f2c7a4bf96138fc1c98675bc (commit)
revisions in full, below.
commit 14fd2d70311aae9646e5d2e5364921822074de2b
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Aug 5 14:17:14 2026 -0400
    GeometryNoder: Replace OrientedCoordinateArray with arc-specific logic
    Resolves https://github.com/libgeos/geos/issues/1497
diff --git a/include/geos/noding/DirectionIndependentArcString.h b/include/geos/noding/DirectionIndependentArcString.h
new file mode 100644
index 000000000..b7b0d8f10
--- /dev/null
+++ b/include/geos/noding/DirectionIndependentArcString.h
@@ -0,0 +1,52 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2026 ISciences, LLC
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <memory>
+#include <geos/export.h>
+namespace geos::noding {
+class ArcString;
+/// The DirectionIndependentArcString is a thin wrapper over an ArcString that provides specialized
+/// equality-testing and hashing functions. DirectionIndependentArcStrings are considered equal
+/// if they cover the same path, regardless of direction. The control points of arcs are not required
+/// to be identical, but must describe the same arc.
+class GEOS_DLL DirectionIndependentArcString {
+public:
+    explicit DirectionIndependentArcString(const ArcString& as) : m_as(as) {}
+    const ArcString& getArcString() const
+        return m_as;
+    bool operator==(const DirectionIndependentArcString& other) const;
+private:
+    const ArcString& m_as;
+template<>
+struct GEOS_DLL std::hash<geos::noding::DirectionIndependentArcString> {
+    std::size_t operator()(const geos::noding::DirectionIndependentArcString& as) const noexcept;
diff --git a/src/noding/DirectionIndependentArcString.cpp b/src/noding/DirectionIndependentArcString.cpp
index 000000000..0628384b2
--- /dev/null
+++ b/src/noding/DirectionIndependentArcString.cpp
@@ -0,0 +1,93 @@
+#include <geos/noding/DirectionIndependentArcString.h>
+#include <geos/noding/ArcString.h>
+#include <cstddef>
+static bool
+arcStringsSame(const ArcString& as1, const ArcString& as2, bool reverse)
+    using geom::CircularArc;
+    const auto nArcs = as1.getSize();
+    if (as2.getSize() != nArcs) {
+        return false;
+    for (std::size_t i = 0; i < nArcs; i++) {
+        const CircularArc& arc1 = as1.getArc(i);
+        const CircularArc& arc2 = as2.getArc(reverse ? nArcs - i - 1: i);
+        if (reverse) {
+            if (arc1.p0() != arc2.p2() || arc1.p2() != arc2.p0()) {
+                return false;
+            const bool arc1Linear = arc1.getOrientation() == algorithm::Orientation::COLLINEAR;
+            const bool arc2Linear = arc2.getOrientation() == algorithm::Orientation::COLLINEAR;
+            if (arc1Linear != arc2Linear) {
+                return false;
+            if (!arc1Linear && arc1.getOrientation() == arc2.getOrientation()) {
+                return false;
+        else {
+            if (arc1.p0() != arc2.p0() || arc1.p2() != arc2.p2()) {
+                return false;
+            if (arc1.getOrientation() != arc2.getOrientation()) {
+                return false;
+        if (!arc1.isLinear() && arc1.getCenter() != arc2.getCenter()) {
+            return false;
+    return true;
+bool
+DirectionIndependentArcString::operator==(const DirectionIndependentArcString& other) const
+    return arcStringsSame(m_as, other.m_as, false) || arcStringsSame(m_as, other.m_as, true);
+std::size_t
+std::hash<geos::noding::DirectionIndependentArcString>::operator()(const geos::noding::DirectionIndependentArcString&
+        as) const noexcept
+    const auto* c1 = &as.getArcString().getArc(0).p0();
+    const auto* c2 = &as.getArcString().getArc(as.getArcString().getSize() - 1).p2();
+    if (c2->compareTo(*c1) < 0) {
+        std::swap(c1, c2);
+    size_t h = std::hash<double> {}(c1->x);
+    h ^= std::hash<double> {}(c1->y) << 1;
+    h ^= std::hash<double> {}(c2->x) << 1;
+    h ^= std::hash<double> {}(c2->y) << 1;
+    return h;
diff --git a/src/noding/GeometryNoder.cpp b/src/noding/GeometryNoder.cpp
index 5296e729c..5de3b56b8 100644
--- a/src/noding/GeometryNoder.cpp
+++ b/src/noding/GeometryNoder.cpp
@@ -29,6 +29,7 @@
 #include <geos/noding/ArcIntersectionAdder.h>
 #include <geos/noding/GeometryNoder.h>
 #include <geos/noding/IteratedNoder.h>
 #include <geos/noding/MCIndexNoder.h>
 #include <geos/noding/NodableArcString.h>
@@ -41,6 +42,8 @@
 #include <geos/util/Assert.h>
 #include <memory> // for unique_ptr
+#include <set>
+#include <unordered_set>
 using geos::geom::CoordinateXY;
 using geos::geom::SimpleCurve;
@@ -317,22 +320,28 @@ GeometryNoder::toGeometry(std::vector<std::unique_ptr<PathString>>& nodedEdges)
     const geom::GeometryFactory* geomFact = argGeom1->getFactory();
     std::set< OrientedCoordinateArray > ocas;
+    std::unordered_set<DirectionIndependentArcString> arcStrings;
     std::vector<PathString*> pathsToKeep;
     for(auto& path : nodedEdges) {
         if (!isInResult(*path)) {
             continue;
-        const auto& coords = path->getCoordinates();
-        OrientedCoordinateArray oca1(*coords);
+        if (const auto* as = dynamic_cast<const ArcString*>(path.get())) {
+            // Check if an equivalent arc is known
+            if (arcStrings.emplace(*as).second) {
+                pathsToKeep.push_back(path.get());
+        } else {
+            const auto& coords = path->getCoordinates();
+            OrientedCoordinateArray oca1(*coords);
-        // Check if an equivalent edge is known
-        if(ocas.insert(oca1).second) {
-            pathsToKeep.push_back(path.get());
+            // Check if an equivalent edge is known
+            if(ocas.insert(oca1).second) {
diff --git a/tests/unit/capi/GEOSNodeTest.cpp b/tests/unit/capi/GEOSNodeTest.cpp
index 63d893a55..10166adbc 100644
--- a/tests/unit/capi/GEOSNodeTest.cpp
+++ b/tests/unit/capi/GEOSNodeTest.cpp
@@ -284,8 +284,6 @@ void object::test<12>()
     expected_ = fromWKT("MULTICURVE ("
                         "CIRCULARSTRING (-5 0, -4.7434164902525691 1.5811388300841900, -4 3),"
                         "CIRCULARSTRING (-4 3, 0 5, 4 3),"
-                        "CIRCULARSTRING (-4 3, 0 5, 4 3)," // FIXME this component is not removed by OrientedCoordinateArray because
-                                                           // its control point differs slightly from the previous one
                         "CIRCULARSTRING (4 3, 4.7434164902525691 1.5811388300841898, 5 0))");
     ensure_equals_geometry_xyzm(reinterpret_cast<Geometry*>(result_),
@@ -398,5 +396,23 @@ void object::test<18>()
+template<>
+template<>
+void object::test<19>()
+    set_test_name("two collinear CircularStrings");
+    input_ = fromWKT("MULTICURVE (CIRCULARSTRING (0 0, 1 1, 2 2), CIRCULARSTRING (2 2, 1 1, 0 0))");
+    result_ = GEOSNode(input_);
+    ensure(result_);
+    ensure_equals(GEOSGetNumGeometries(result_), 1);
+    expected_ = fromWKT("MULTICURVE(CIRCULARSTRING (0 0, 1 1, 2 2))");
+    ensure_equals_exact_geometry_xyzm(reinterpret_cast<Geometry*>(result_),
+                                      reinterpret_cast<Geometry*>(expected_), 1e-4);
 } // namespace tut
diff --git a/tests/unit/noding/DirectionIndependentArcStringTest.cpp b/tests/unit/noding/DirectionIndependentArcStringTest.cpp
index 000000000..55c71053f
--- /dev/null
+++ b/tests/unit/noding/DirectionIndependentArcStringTest.cpp
@@ -0,0 +1,108 @@
+#include <tut/tut.hpp>
+#include <geos/geom/CircularString.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/io/WKTReader.h>
+using namespace geos::geom;
+using namespace geos::noding;
+namespace tut {
+struct test_directionindependentarcstring_data {
+    geos::io::WKTReader reader_;
+    static bool isSame(const ArcString& as0, const ArcString& as1) {
+        std::unordered_set<DirectionIndependentArcString> map;
+        map.emplace(as0);
+        return !map.emplace(as1).second;
+    static bool isSame(const CircularString& cs0, const CircularString& cs1) {
+        ArcString as0(cs0.getArcs(), cs0.getSharedCoordinates(), nullptr);
+        ArcString as1(cs1.getArcs(), cs1.getSharedCoordinates(), nullptr);
+        return isSame(as0, as1);
+    bool isSame(const std::string& wkt0, const std::string& wkt1) {
+        auto cs0 = reader_.read<CircularString>(wkt0);
+        auto cs1 = reader_.read<CircularString>(wkt1);
+        return isSame(*cs0, *cs1);
+using group = test_group<test_directionindependentarcstring_data>;
+using object = group::object;
+group test_directionindependentarcstring_data("geos::noding::DirectionIndependentArcString");
+template<>
+template<>
+void object::test<1>()
+    set_test_name("equivalent: single-section arcs with different control points and opposite directions");
+    ensure(isSame("CIRCULARSTRING (-5 0, -4 3, 5 0)", "CIRCULARSTRING (5 0, 4 3, -5 0)"));
+template<>
+template<>
+void object::test<2>()
+    set_test_name("equivalent: multi-section arcs with different control points and opposite directions");
+    ensure(isSame("CIRCULARSTRING (-5 0, -4 3, 5 0, 6 1, 7 0)", "CIRCULARSTRING (7 0, 6 1, 5 0, 4 3, -5 0)"));
+template<>
+template<>
+void object::test<3>()
+    set_test_name("different: single-section arcs with same endpoints, covering different halves of circle");
+    ensure(!isSame("CIRCULARSTRING (-5 0, -4 3, 5 0)", "CIRCULARSTRING (-5 0, -4 -3, 5 0)"));
+template<>
+template<>
+void object::test<4>()
+    set_test_name("equivalent: two degenerate (linear) arcs having different control points and opposite directions");
+    ensure(isSame("CIRCULARSTRING (0 0, 4 4, 10 10)", "CIRCULARSTRING (10 10, 8 8, 0 0)"));
+template<>
+template<>
+void object::test<5>()
+    set_test_name("different: arc and degenerate arc having same endpoints");
+    ensure(!isSame("CIRCULARSTRING (-1 0, 0 1, 1 0)", "CIRCULARSTRING (-1 0, 0 0, 1 0)"));
+template<>
+template<>
+void object::test<6>()
+    set_test_name("different: two arcs having same endpoints and different control points");
+    ensure(!isSame("CIRCULARSTRING (-1 0, 0 1, 1 0)", "CIRCULARSTRING (-1 0, 0 0.9, 1 0)"));
+template<>
+template<>
+void object::test<7>()
+    set_test_name("different: two arcs sharing same path that later diverge");
+    ensure(!isSame("CIRCULARSTRING (-1 0, 0 1, 1 0, 2 -1, 3 0)", "CIRCULARSTRING (-1 0, 0 1, 1 0, 2 -1, 3 0.1)"));
diff --git a/tests/unit/operation/split/GeometrySplitterTest.cpp b/tests/unit/operation/split/GeometrySplitterTest.cpp
index 95c730693..d4700ec47 100644
--- a/tests/unit/operation/split/GeometrySplitterTest.cpp
+++ b/tests/unit/operation/split/GeometrySplitterTest.cpp
@@ -906,11 +906,10 @@ void object::test<75>()
     set_test_name("GH-1497");
-    auto geom = reader_.read("CURVEPOLYGON (COMPOUNDCURVE((5 0, 0 0, 0 5, 5 5), CIRCULARSTRING(5 5, 7 1, 5 0)))");
-    auto edge = reader_.read("CURVEPOLYGON (COMPOUNDCURVE((5 0, 0 0, 5 5), CIRCULARSTRING(5 5, 7 4, 5 0)))");
-    // This case is not currently handled correctly by the GeometrySplitter. Throw an error instead of returning an incorrect result.
-    ensure_THROW(GeometrySplitter::split(*geom, *edge), geos::util::GEOSException);
+    testSplit(
+    "CURVEPOLYGON (COMPOUNDCURVE((5 0, 0 0, 0 5, 5 5), CIRCULARSTRING(5 5, 7 1, 5 0)))",
+    "CURVEPOLYGON (COMPOUNDCURVE((5 0, 0 0, 5 5), CIRCULARSTRING(5 5, 7 4, 5 0)))",
+        "GEOMETRYCOLLECTION (CURVEPOLYGON (COMPOUNDCURVE ((5 0, 0 0, 5 5), CIRCULARSTRING (5 5, 7 1, 5 0))), POLYGON ((0 0, 0 5, 5 5, 0 0)))");
\ No newline at end of file
commit 59a36b35cfe4c51019ba0f673473e1c1155b5d8e
Date:   Wed Aug 5 13:32:31 2026 -0400
    GeometrySplitter: add check for result area
    References https://github.com/libgeos/geos/issues/1497
diff --git a/src/operation/split/GeometrySplitter.cpp b/src/operation/split/GeometrySplitter.cpp
index 10e766ec5..b669b14ea 100644
--- a/src/operation/split/GeometrySplitter.cpp
+++ b/src/operation/split/GeometrySplitter.cpp
@@ -373,7 +373,16 @@ GeometrySplitter::splitPolygonalWithEdge(const Geometry &geom, const Geometry &e
         return geom.getFactory()->createEmptyGeometry(geom::GEOS_GEOMETRYCOLLECTION, geom.hasZ(), geom.hasM());
-    return geom.getFactory()->createGeometryCollection(std::move(keep));
+    auto result =  geom.getFactory()->createGeometryCollection(std::move(keep));
+    const double inputArea = geom.getArea();
+    const double resultArea = result->getArea();
+    if (inputArea > 0 && std::abs(inputArea - resultArea) / inputArea > 1e-6) {
+        throw util::GEOSException("Splitting polygonal geometry failed to preserve area");
+    return result;
index 7019ea3fe..95c730693 100644
@@ -900,5 +900,17 @@ void object::test<74>()
+template<>
+template<>
+void object::test<75>()
+    set_test_name("GH-1497");
+    auto geom = reader_.read("CURVEPOLYGON (COMPOUNDCURVE((5 0, 0 0, 0 5, 5 5), CIRCULARSTRING(5 5, 7 1, 5 0)))");
+    auto edge = reader_.read("CURVEPOLYGON (COMPOUNDCURVE((5 0, 0 0, 5 5), CIRCULARSTRING(5 5, 7 4, 5 0)))");
+    // This case is not currently handled correctly by the GeometrySplitter. Throw an error instead of returning an incorrect result.
+    ensure_THROW(GeometrySplitter::split(*geom, *edge), geos::util::GEOSException);
Summary of changes:
 .../geos/noding/DirectionIndependentArcString.h    |  52 ++++++++++
 src/noding/DirectionIndependentArcString.cpp       |  93 ++++++++++++++++++
 src/noding/GeometryNoder.cpp                       |  23 +++--
 src/operation/split/GeometrySplitter.cpp           |  11 ++-
 tests/unit/capi/GEOSNodeTest.cpp                   |  20 +++-
 .../noding/DirectionIndependentArcStringTest.cpp   | 108 +++++++++++++++++++++
 .../unit/operation/split/GeometrySplitterTest.cpp  |  11 +++
 7 files changed, 308 insertions(+), 10 deletions(-)
 create mode 100644 include/geos/noding/DirectionIndependentArcString.h
 create mode 100644 src/noding/DirectionIndependentArcString.cpp
 create mode 100644 tests/unit/noding/DirectionIndependentArcStringTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
