[geos-commits] [SCM] GEOS branch main updated. 737737dbb924f348da99cfe39c2a00f9e393f414
Wed Aug 12 13:03:23 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  737737dbb924f348da99cfe39c2a00f9e393f414 (commit)
      from  da4de475f9b62990912f28a110aaadcf2de87dc3 (commit)
revisions in full, below.
commit 737737dbb924f348da99cfe39c2a00f9e393f414
Author: Petr Bělohlávek <petrbel at users.noreply.github.com>
Date:   Wed Aug 12 22:03:05 2026 +0200
    OverlayNG: Fix intersection computation of slightly overlapping polygons (#1499)
    Signed-off-by: Petr Belohlavek <me at petrbel.cz>
diff --git a/src/edgegraph/HalfEdge.cpp b/src/edgegraph/HalfEdge.cpp
index 54b5658e0..cdafbd734 100644
--- a/src/edgegraph/HalfEdge.cpp
+++ b/src/edgegraph/HalfEdge.cpp
@@ -179,17 +179,14 @@ HalfEdge::findLowest() const
 int
 HalfEdge::compareAngularDirection(const HalfEdge* e) const
-    double dx = directionX();
-    double dy = directionY();
-    double dx2 = e->directionX();
-    double dy2 = e->directionY();
+    assert(orig().equals2D(e->orig()));
     // same vector
-    if (dx == dx2 && dy == dy2)
+    if (directionPt().equals2D(e->directionPt()))
         return 0;
-    int quadrant = geom::Quadrant::quadrant(dx, dy);
-    int quadrant2 = geom::Quadrant::quadrant(dx2, dy2);
+    int quadrant = geom::Quadrant::quadrant(directionX(), directionY());
+    int quadrant2 = geom::Quadrant::quadrant(e->directionX(), e->directionY());
     * If the direction vectors are in different quadrants,
@@ -272,5 +269,3 @@ HalfEdge::toStringNode(const HalfEdge* he, std::ostream& os)
 } // namespace geos.edgegraph
 } // namespace geos
diff --git a/src/geomgraph/EdgeEnd.cpp b/src/geomgraph/EdgeEnd.cpp
index 18f9a9988..d9c094bea 100644
--- a/src/geomgraph/EdgeEnd.cpp
+++ b/src/geomgraph/EdgeEnd.cpp
@@ -160,7 +160,9 @@ int
 EdgeEnd::compareDirection(const EdgeEnd* e) const
     assert(e);
-    if(dx == e->dx && dy == e->dy) {
+    assert(p0.equals2D(e->p0));
+    if(p1.equals2D(e->p1)) {
         return 0;
@@ -215,4 +217,3 @@ operator<< (std::ostream& os, const EdgeEnd& ee)
 } // namespace geos.geomgraph
 } // namespace geos
diff --git a/tests/unit/edgegraph/EdgeGraphTest.cpp b/tests/unit/edgegraph/EdgeGraphTest.cpp
index 9d96139e3..a14d443a1 100644
--- a/tests/unit/edgegraph/EdgeGraphTest.cpp
+++ b/tests/unit/edgegraph/EdgeGraphTest.cpp
@@ -170,6 +170,25 @@ void object::test<5> ()
     checkNextPrev(*graph);
+// testSimilarEdgesDirection
+template<>
+template<>
+void object::test<6> ()
+    EdgeGraph graph;
+    HalfEdge* e1 = addEdge(graph, 1, 1, 0, 0.5);
+    addEdge(graph, 1, 1, 0, 0.49999999999999994);
+    addEdge(graph, 1, 1, 0, 1);
+    HalfEdge* eUpper = findEdge(graph, 1, 1, 0, 0.5);
+    HalfEdge* eLower = findEdge(graph, 1, 1, 0, 0.49999999999999994);
+    ensure("edges with distinct direction points must not compare equal", eUpper->compareTo(eLower) != 0);
+    ensure("edge comparison must be antisymmetric", eUpper->compareTo(eLower) == -eLower->compareTo(eUpper));
+    checkNodeValid(e1);
+    checkNextPrev(graph);
 } // namespace tut
diff --git a/tests/unit/operation/overlayng/OverlayNGRobustTest.cpp b/tests/unit/operation/overlayng/OverlayNGRobustTest.cpp
index d48518cf9..5a27cdeb7 100644
--- a/tests/unit/operation/overlayng/OverlayNGRobustTest.cpp
+++ b/tests/unit/operation/overlayng/OverlayNGRobustTest.cpp
@@ -61,6 +61,17 @@ struct test_overlayngrobust_data {
         ensure_NO_THROW( OverlayNGRobust::Overlay(geom_a.get(), geom_b.get(), opCode) );
+    void
+    checkOverlaySymmetricArea(const std::string& a, const std::string& b, int opCode, double expectedArea)
+        std::unique_ptr<Geometry> geom_a = r.read(a);
+        std::unique_ptr<Geometry> geom_b = r.read(b);
+        double areaAB = OverlayNGRobust::Overlay(geom_a.get(), geom_b.get(), opCode)->getArea();
+        double areaBA = OverlayNGRobust::Overlay(geom_b.get(), geom_a.get(), opCode)->getArea();
+        ensure_equals("overlay is not commutative", areaAB, areaBA, 1e-12);
+        ensure_equals("unexpected overlay area", areaAB, expectedArea, 1e-12);
     double2geom(const std::vector<double>& x, const std::vector<double>& y)
@@ -109,7 +120,26 @@ void object::test<2> ()
     checkOverlaySuccess(a, b, OverlayNG::INTERSECTION);
+// 2026-08-05 Intersection of polygons isn't commutative (https://github.com/libgeos/geos/issues/1405)
+template<>
+template<>
+void object::test<3> ()
+    set_test_name("Intersection of triangles with an extremely similar edge");
+    const std::string a = "POLYGON ((1 1, 0 0.5, 0 0, 1 1))";
+    const std::string b = "POLYGON ((1 1, 0 0.49999999999999994, 0 1, 1 1))";
+    checkOverlaySymmetricArea(a, b, OverlayNG::INTERSECTION, 0.0);
+template<>
+template<>
+void object::test<4> ()
+    set_test_name("Union of triangles with an extremely similar edge");
+    checkOverlaySymmetricArea(a, b, OverlayNG::UNION, 0.5);
 #if 0
Summary of changes:
 src/edgegraph/HalfEdge.cpp                         | 13 +++-------
 src/geomgraph/EdgeEnd.cpp                          |  5 ++--
 tests/unit/edgegraph/EdgeGraphTest.cpp             | 19 ++++++++++++++
 .../operation/overlayng/OverlayNGRobustTest.cpp    | 30 ++++++++++++++++++++++
 4 files changed, 56 insertions(+), 11 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
