[geos-commits] [SCM] GEOS branch main updated. 9bc6ca8716552f8d35e90cd22be433123c06b175
Fri Feb 6 12:52:59 PST 2026
the project "GEOS".
The branch, main has been updated
       via  9bc6ca8716552f8d35e90cd22be433123c06b175 (commit)
      from  8ef887079e3d8f18fef4bb7f7e9ab52866b437fa (commit)
revisions in full, below.
commit 9bc6ca8716552f8d35e90cd22be433123c06b175
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Feb 6 11:47:36 2026 -0800
    Fix: Preserve dimension and type for empty geometries during snap/simplify
    Closes https://github.com/libgeos/geos/issues/1356
    When performing operations like Snap on empty geometries (e.g., POINT EMPTY, LINESTRING EMPTY, POLYGON EMPTY), the GEOS library was incorrectly modifying their coordinate dimension (e.g., adding a Z dimension) and sometimes changing their type (e.g., POLYGON EMPTY becoming a LinearRing or GeometryCollection).
    This fix modifies GeometryTransformer to short-circuit the transformation process if the input geometry is already empty. Instead of transforming it, it now returns a direct clone of the empty input geometry. This ensures that the original type and coordinate dimension (e.g., 2D) are preserved, aligning with the expected behavior for empty geometries.
diff --git a/src/geom/util/GeometryTransformer.cpp b/src/geom/util/GeometryTransformer.cpp
index acec018bf..afa01ce32 100644
--- a/src/geom/util/GeometryTransformer.cpp
+++ b/src/geom/util/GeometryTransformer.cpp
@@ -79,6 +79,11 @@ GeometryTransformer::transform(const Geometry* nInputGeom)
     inputGeom = nInputGeom;
     factory = inputGeom->getFactory();
+    // If the input geometry is empty, return a clone of it to preserve its type and dimension
+    if (inputGeom->isEmpty()) {
+        return inputGeom->clone();
     if(const Point* p = dynamic_cast<const Point*>(inputGeom)) {
         return transformPoint(p, nullptr);
diff --git a/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp b/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
index ef82353e3..9e5245436 100644
--- a/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
+++ b/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
@@ -76,5 +76,56 @@ void object::test<3> ()
     ensure_equals_geometry(expected.get(), result.get());
+// Test snapping of empty geometries -- POINT EMPTY
+template<>
+template<>
+void object::test<4> ()
+    std::string wkt = "POINT EMPTY";
+    auto src = reader.read(wkt);
+    GeometrySnapper snapper(*src);
+    auto snap = reader.read(wkt); // Snap against itself
+    auto result = snapper.snapTo(*snap, 1);
+    auto expected = reader.read(wkt);
+    ensure_equals_geometry(expected.get(), result.get());
+    ensure_equals(result->getCoordinateDimension(), 2);
+    ensure_equals(result->getGeometryType(), "Point");
+// Test snapping of empty geometries -- LINESTRING EMPTY
+template<>
+template<>
+void object::test<5> ()
+    std::string wkt = "LINESTRING EMPTY";
+    ensure_equals(result->getGeometryType(), "LineString");
+// Test snapping of empty geometries -- POLYGON EMPTY
+template<>
+template<>
+void object::test<6> ()
+    std::string wkt = "POLYGON EMPTY";
+    ensure_equals(result->getGeometryType(), "Polygon");
 } // namespace tut
Summary of changes:
 src/geom/util/GeometryTransformer.cpp              |  5 +++
 .../operation/overlay/snap/GeometrySnapperTest.cpp | 51 ++++++++++++++++++++++
 2 files changed, 56 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
