[geos-commits] [SCM] GEOS branch main updated. 3f3a3e911f259b6fe76e18e05abe03c062d89aeb
Mon Jan 12 07:31:34 PST 2026
the project "GEOS".
The branch, main has been updated
       via  3f3a3e911f259b6fe76e18e05abe03c062d89aeb (commit)
      from  eb6121ae303477279d4a571c54ae9f0435e120bb (commit)
revisions in full, below.
commit 3f3a3e911f259b6fe76e18e05abe03c062d89aeb
Author: Daniel Baston <dbaston at gmail.com>
Date:   Mon Jan 12 10:31:09 2026 -0500
    Simplify: Preserve dimensions of empty geometries (#1357)
    * DouglasPeuckerSimplifier: Preserve dimension of empty geometries
    * TopologyPreservingSimplifier: Add test for preservation of empty geometry dims
diff --git a/include/geos/simplify/DouglasPeuckerSimplifier.h b/include/geos/simplify/DouglasPeuckerSimplifier.h
index 97fa32ca4..57fe5404e 100644
--- a/include/geos/simplify/DouglasPeuckerSimplifier.h
+++ b/include/geos/simplify/DouglasPeuckerSimplifier.h
@@ -68,7 +68,7 @@ public:
     void setDistanceTolerance(double tolerance);
-    std::unique_ptr<geom::Geometry> getResultGeometry();
+    std::unique_ptr<geom::Geometry> getResultGeometry() const;
 private:
diff --git a/src/simplify/DouglasPeuckerSimplifier.cpp b/src/simplify/DouglasPeuckerSimplifier.cpp
index 893d785a2..05b32b588 100644
--- a/src/simplify/DouglasPeuckerSimplifier.cpp
+++ b/src/simplify/DouglasPeuckerSimplifier.cpp
@@ -201,8 +201,12 @@ DouglasPeuckerSimplifier::setDistanceTolerance(double tol)
 Geometry::Ptr
-DouglasPeuckerSimplifier::getResultGeometry()
+DouglasPeuckerSimplifier::getResultGeometry() const
+    if (inputGeom->isEmpty()) {
+        return inputGeom->clone();
     DPTransformer t(distanceTolerance);
     return t.transform(inputGeom);
diff --git a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
index ee3257a90..50c0bf308 100644
--- a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
+++ b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
@@ -37,7 +37,7 @@ struct test_dpsimp_data {
     void
-    checkDP(const std::string& wkt, double tolerance, const std::string& wkt_expected)
+    checkDP(const std::string& wkt, double tolerance, const std::string& wkt_expected) const
         GeomPtr g(wktreader.read(wkt));
         GeomPtr simplified = DouglasPeuckerSimplifier::simplify(g.get(), tolerance);
@@ -49,7 +49,7 @@ struct test_dpsimp_data {
     void
-    checkDPNoChange(const std::string& wkt, double tolerance)
+    checkDPNoChange(const std::string& wkt, double tolerance) const
         checkDP(wkt, tolerance, wkt);
@@ -382,4 +382,24 @@ void object::test<23>()
         "POLYGON ZM ((2 0 10 9, 2 2 15 11, 0 2 20 13, 0 0 25 15, 2 0 10 9))");
+template<>
+template<>
+void object::test<24>()
+    set_test_name("simplification preserves dimensions of empty geometries");
+    const std::vector<std::string> geomTypes{"POINT", "LINESTRING", "POLYGON"};
+    const std::vector<std::string> dimensions{"", "Z", "M", "ZM"};
+    const std::vector<std::string> mods{"", "MULTI"};
+    for (const auto& geomType : geomTypes) {
+        for (const auto& dimension: dimensions) {
+            for (const auto& mod: mods) {
+                std::string wkt = mod + geomType + " " + dimension + " EMPTY";
+                checkDP(wkt, 0, wkt);
 } // namespace tut
diff --git a/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp b/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
index d8ab8d615..651627b05 100644
--- a/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
+++ b/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
@@ -34,17 +34,17 @@ struct test_tpsimp_data {
     void
-    checkTPS(const std::string& wkt, double tolerance, const std::string& wkt_expected)
+    checkTPS(const std::string& wkt, double tolerance, const std::string& wkt_expected) const
         GeomPtr simplified = TopologyPreservingSimplifier::simplify(g.get(), tolerance);
         GeomPtr exp(wktreader.read(wkt_expected));
-        ensure_equals_geometry(exp.get(), simplified.get(),0.00001);
+        ensure_equals_geometry_xyzm(exp.get(), simplified.get(),0.00001);
         ensure("Simplified geometry is invalid!", simplified->isValid());
     void
-    checkTPSNoChange(const std::string& wkt, double tolerance)
+    checkTPSNoChange(const std::string& wkt, double tolerance) const
         checkTPS(wkt, tolerance, wkt);
@@ -453,4 +453,24 @@ void object::test<35>()
         "MULTIPOLYGON (((689.300102 5733.615673, 689.46186 5733.617409, 689.458981 5733.646089, 689.300102 5733.615673)), ((689.488158 5733.746304, 689.23796 5733.680098, 689.253227 5733.613915, 689.467162 5733.67151, 689.679568 5733.588383, 689.488158 5733.746304)))");
+template<>
+template<>
+void object::test<36>()
+                checkTPSNoChange(wkt, 0);
 } // namespace tut
Summary of changes:
 include/geos/simplify/DouglasPeuckerSimplifier.h   |  2 +-
 src/simplify/DouglasPeuckerSimplifier.cpp          |  6 ++++-
 .../unit/simplify/DouglasPeuckerSimplifierTest.cpp | 24 ++++++++++++++++++--
 .../simplify/TopologyPreservingSimplifierTest.cpp  | 26 +++++++++++++++++++---
 4 files changed, 51 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
