[geos-commits] [SCM] GEOS branch main updated. 8f2364fc2c3eecc915e224f5d0e8399bb96d4e4c
Fri Jan 23 17:13:34 PST 2026
the project "GEOS".
The branch, main has been updated
       via  8f2364fc2c3eecc915e224f5d0e8399bb96d4e4c (commit)
      from  a02e30f462676831a6241630c87c98ab6c1c2d12 (commit)
revisions in full, below.
commit 8f2364fc2c3eecc915e224f5d0e8399bb96d4e4c
Author: Even Rouault <even.rouault at spatialys.com>
Date:   Sat Jan 24 02:12:48 2026 +0100
    DistanceOp::distance(): make it return +inf instead of 0 if one of the geometry is empty (#1345)
    * DistanceOp::distance(): make it return NaN instead of 0 if one of the geometry is empty
    Fixes https://github.com/OSGeo/gdal/issues/12978
    * DistanceOp::distance(): make it return inf instead of 0 if one of the geometry is empty
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 44bb6d3ed..b31a4290a 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -3405,7 +3405,7 @@ extern char GEOS_DLL GEOSisSimple(const GEOSGeometry* g);
 * In one step, calculate and return whether a geometry is simple
 * and one more more points at which the geometry self-intersects
 * at interior points.
-* Caller has the responsibility to destroy 'location' with
+* Caller has the responsibility to destroy 'location' with
 * GEOSGeom_destroy()
 * \param g The geometry to test
@@ -3649,7 +3649,8 @@ extern int GEOS_DLL GEOSGeomGetLength(
 * Calculate the distance between two geometries.
 * \param[in] g1 Input geometry
 * \param[in] g2 Input geometry
-* \param[out] dist Pointer to be filled in with distance result
+* \param[out] dist Pointer to be filled in with distance result. Positive
+*                  infinity is returned if one of the geometry is empty.
 * \return 1 on success, 0 on exception.
 * \since 2.2
@@ -5531,7 +5532,7 @@ extern char GEOS_DLL GEOSIntersects(const GEOSGeometry* g1, const GEOSGeometry*
 extern char GEOS_DLL GEOSCrosses(const GEOSGeometry* g1, const GEOSGeometry* g2);
-* Tests if geometry g1 is completely within g2,
+* Tests if geometry g1 is completely within g2,
 * but not wholly contained in the boundary of g2.
 * \param g1 Input geometry
 * \param g2 Input geometry
diff --git a/src/operation/distance/DistanceOp.cpp b/src/operation/distance/DistanceOp.cpp
index c6da7508f..2eb82eaac 100644
--- a/src/operation/distance/DistanceOp.cpp
+++ b/src/operation/distance/DistanceOp.cpp
@@ -36,6 +36,7 @@
 #include <geos/util/IllegalArgumentException.h>
 #include <geos/util.h>
+#include <limits>
 #include <vector>
 #include <iostream>
@@ -97,7 +98,7 @@ DistanceOp::DistanceOp(const Geometry& g0, const Geometry& g1, double tdist)
  * Report the distance between the closest points on the input geometries.
- * @return the distance between the geometries
+ * @return the distance between the geometries, or positive infinity if one of them is empty.
 double
@@ -111,7 +112,7 @@ DistanceOp::distance()
         throw IllegalArgumentException("null geometries are not supported");
     if(geom[0]->isEmpty() || geom[1]->isEmpty()) {
-        return 0.0;
+        return std::numeric_limits<double>::infinity();
     if(geom[0]->getGeometryTypeId() == GEOS_POINT && geom[1]->getGeometryTypeId() == GEOS_POINT) {
         return static_cast<const Point*>(geom[0])->getCoordinate()->distance(*static_cast<const Point*>(geom[1])->getCoordinate());
diff --git a/tests/unit/operation/distance/DistanceOpTest.cpp b/tests/unit/operation/distance/DistanceOpTest.cpp
index 32eee5bbf..bbb5e0850 100644
--- a/tests/unit/operation/distance/DistanceOpTest.cpp
+++ b/tests/unit/operation/distance/DistanceOpTest.cpp
@@ -228,7 +228,7 @@ void object::test<8>
     DistanceOp dist(g0.get(), g1.get());
-    ensure_equals(dist.distance(), 0);
+    ensure(std::isinf(dist.distance()));
     ensure(dist.nearestPoints() == nullptr);
@@ -416,7 +416,7 @@ void object::test<16>
@@ -497,7 +497,7 @@ void object::test<19>
     ensure(g1->isValid());
     ensure(g2->isValid());
-    ensure_equals(g1->distance(g2.get()), 0);
+    ensure(std::isinf(g1->distance(g2.get())));
 // Test case reported in Shapely
@@ -580,7 +580,6 @@ void object::test<22>()
     ensure_equals(g2->distance(g1.get()), 1);
-// Empty is same as empty so zero...?
 template<>
 template<>
 void object::test<23>()
@@ -589,8 +588,8 @@ void object::test<23>()
     auto g2 = wktreader.read("LINESTRING EMPTY");
     ensure(g1 != nullptr && g2 != nullptr);
-    ensure_equals(g2->distance(g1.get()), 0);
+    ensure(std::isinf(g2->distance(g1.get())));
 template<>
@@ -601,8 +600,8 @@ void object::test<24>()
 // But ignore empty if there's a real distance?
@@ -638,8 +637,8 @@ void object::test<27>()
     auto g2 = wktreader.read("GEOMETRYCOLLECTION(POINT(1 0))");
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index c3b33b939..be5445813 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -894,8 +894,12 @@ Test::checkResult( bool result )
 void
 Test::checkResult( double result)
-    char* rest;
-    double expectedRes = std::strtod(opResult.c_str(), &rest);
+    char* rest = nullptr;
+    const double expectedRes = (opResult == "NaN" || opResult == "nan") ?
+        std::numeric_limits<double>::quiet_NaN() :
+        (opResult == "Inf" || opResult == "inf") ?
+        std::numeric_limits<double>::infinity() :
+        std::strtod(opResult.c_str(), &rest);
     if(rest == opResult.c_str()) {
         throw std::runtime_error("malformed testcase: missing expected double value");
@@ -904,6 +908,12 @@ Test::checkResult( double result)
             isSuccess = true;
+    else if (std::isnan(expectedRes)) {
+        isSuccess = std::isnan(result);
+    else if( expectedRes == result ) {
+        isSuccess = true;
     else {
         if (std::abs(expectedRes - result) / expectedRes < 1e-3) {
             isSuccess = true;
diff --git a/tests/xmltester/tests/general/TestDistance.xml b/tests/xmltester/tests/general/TestDistance.xml
index e6444ddac..36ddb40c9 100644
--- a/tests/xmltester/tests/general/TestDistance.xml
+++ b/tests/xmltester/tests/general/TestDistance.xml
@@ -4,8 +4,8 @@
   <desc>PeP - point to an empty point</desc>
   <a>    POINT(10 10)  </a>
   <b>    POINT EMPTY  </b>
-<test><op name="distance" arg1="A" arg2="B">    0.0   </op></test>
-<test><op name="distance" arg1="B" arg2="A">    0.0   </op></test>
+<test><op name="distance" arg1="A" arg2="B">    inf   </op></test>
+<test><op name="distance" arg1="B" arg2="A">    inf   </op></test>
 </case>
 <case>
@@ -36,8 +36,8 @@
   <desc>LL - line to empty line</desc>
   <a>    LINESTRING (0 0, 0 10)  </a>
   <b>    LINESTRING EMPTY  </b>
 </case>
 <case>
@@ -68,8 +68,8 @@
   <desc>PA - point to empty polygon</desc>
   <a>    POINT (240 160)  </a>
   <b>    POLYGON EMPTY  </b>
-<test><op name="distance" arg1="A" arg2="B" >    0.0   </op></test>
-<test><op name="distance" arg1="B" arg2="A" >    0.0   </op></test>
+<test><op name="distance" arg1="A" arg2="B" >    inf   </op></test>
+<test><op name="distance" arg1="B" arg2="A" >    inf   </op></test>
 </case>
 <case>
Summary of changes:
 capi/geos_c.h.in                                 |  7 ++++---
 src/operation/distance/DistanceOp.cpp            |  5 +++--
 tests/unit/operation/distance/DistanceOpTest.cpp | 19 +++++++++----------
 tests/xmltester/XMLTester.cpp                    | 14 ++++++++++++--
 tests/xmltester/tests/general/TestDistance.xml   | 12 ++++++------
 5 files changed, 34 insertions(+), 23 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
