[geos-commits] [SCM] GEOS branch dependabot/github_actions/all-actions-75c878a17d created. 75a7aee174a6fcdefaf38f03e7f051e4fbc249c6
Wed Jul 1 08:51:31 PDT 2026
the project "GEOS".
The branch, dependabot/github_actions/all-actions-75c878a17d has been created
        at  75a7aee174a6fcdefaf38f03e7f051e4fbc249c6 (commit)
commit 75a7aee174a6fcdefaf38f03e7f051e4fbc249c6
Author: dependabot[bot] <49699333+dependabot[bot]@users.noreply.github.com>
Date:   Wed Jul 1 15:51:08 2026 +0000
    Bump the all-actions group with 6 updates
    Bumps the all-actions group with 6 updates:
    | Package | From | To |
    | [actions/checkout](https://github.com/actions/checkout) | `6.0.2` | `7.0.0` |
    | [actions/cache](https://github.com/actions/cache) | `5` | `6.1.0` |
    | [codecov/codecov-action](https://github.com/codecov/codecov-action) | `6` | `7` |
    | [vmactions/freebsd-vm](https://github.com/vmactions/freebsd-vm) | `1.4.5` | `1.4.8` |
    | [github/codeql-action](https://github.com/github/codeql-action) | `4.36.0` | `4.36.2` |
    | [docker/build-push-action](https://github.com/docker/build-push-action) | `7` | `7.2.0` |
    Updates `actions/checkout` from 6.0.2 to 7.0.0
    - [Release notes](https://github.com/actions/checkout/releases)
    - [Changelog](https://github.com/actions/checkout/blob/main/CHANGELOG.md)
    - [Commits](https://github.com/actions/checkout/compare/v6.0.2...v7.0.0)
    Updates `actions/cache` from 5 to 6.1.0
    - [Release notes](https://github.com/actions/cache/releases)
    - [Changelog](https://github.com/actions/cache/blob/main/RELEASES.md)
    - [Commits](https://github.com/actions/cache/compare/v5...v6.1.0)
    Updates `codecov/codecov-action` from 6 to 7
    - [Release notes](https://github.com/codecov/codecov-action/releases)
    - [Changelog](https://github.com/codecov/codecov-action/blob/main/CHANGELOG.md)
    - [Commits](https://github.com/codecov/codecov-action/compare/v6...v7)
    Updates `vmactions/freebsd-vm` from 1.4.5 to 1.4.8
    - [Release notes](https://github.com/vmactions/freebsd-vm/releases)
    - [Commits](https://github.com/vmactions/freebsd-vm/compare/v1.4.5...v1.4.8)
    Updates `github/codeql-action` from 4.36.0 to 4.36.2
    - [Release notes](https://github.com/github/codeql-action/releases)
    - [Changelog](https://github.com/github/codeql-action/blob/main/CHANGELOG.md)
    - [Commits](https://github.com/github/codeql-action/compare/v4.36.0...v4.36.2)
    Updates `docker/build-push-action` from 7 to 7.2.0
    - [Release notes](https://github.com/docker/build-push-action/releases)
    - [Commits](https://github.com/docker/build-push-action/compare/v7...v7.2.0)
    updated-dependencies:
    - dependency-name: actions/checkout
      dependency-version: 7.0.0
      dependency-type: direct:production
      update-type: version-update:semver-major
      dependency-group: all-actions
    - dependency-name: actions/cache
      dependency-version: 6.1.0
    - dependency-name: codecov/codecov-action
      dependency-version: '7'
    - dependency-name: vmactions/freebsd-vm
      dependency-version: 1.4.8
      update-type: version-update:semver-patch
    - dependency-name: github/codeql-action
      dependency-version: 4.36.2
    - dependency-name: docker/build-push-action
      dependency-version: 7.2.0
      update-type: version-update:semver-minor
    Signed-off-by: dependabot[bot] <support at github.com>
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 5f7a5e237..c493e6f3b 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -197,10 +197,10 @@ jobs:
         python3 -m pip install --disable-pip-version-check --user cmake==${{ matrix.ci.cmake }}
         echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
-    - uses: actions/checkout at v6.0.2
+    - uses: actions/checkout at v7.0.0
     - name: Retrieve build cache
-      uses: actions/cache/restore at v5
+      uses: actions/cache/restore at v6.1.0
       with:
         path: .ccache
@@ -227,7 +227,7 @@ jobs:
         ccache --show-stats
     - name: Save build cache
-      uses: actions/cache/save at v5
+      uses: actions/cache/save at v6.1.0
       with:
         path: .ccache
         key: ${{ steps.restore-cache.outputs.cache-primary-key }}
@@ -263,7 +263,7 @@ jobs:
     - name: Upload Coverage to Codecov
       if: ${{ matrix.ci.build_type == 'Coverage' && !cancelled() }}
-      uses: codecov/codecov-action at v6
+      uses: codecov/codecov-action at v7
       with:
         fail_ci_if_error: false
         files: build/coverage.info
@@ -281,7 +281,7 @@ jobs:
         build_type: ['Debug', 'Release']
     steps:
     - name: 'Setup'
       uses: msys2/setup-msys2 at v2
@@ -295,7 +295,7 @@ jobs:
           mingw-w64-x86_64-gcc
       with:
         path: .ccache
@@ -316,7 +316,7 @@ jobs:
         ccache --show-stats --verbose
       with:
         path: .ccache
@@ -337,7 +337,7 @@ jobs:
             arch: arm64
     steps:
     # ccache not supported for this generator and/or Debug
@@ -378,10 +378,10 @@ jobs:
     runs-on: ${{ matrix.ci.os }}
     steps:
       with:
         path: .ccache
@@ -415,7 +415,7 @@ jobs:
       with:
         path: .ccache
@@ -459,10 +459,10 @@ jobs:
         which clang++
         clang++ --version
       with:
         path: .ccache
@@ -482,7 +482,7 @@ jobs:
         ccache --show-stats
       with:
         path: .ccache
@@ -495,10 +495,10 @@ jobs:
     runs-on: ubuntu-latest
     steps:
       with:
         path: .ccache
@@ -506,7 +506,7 @@ jobs:
         restore-keys: freebsd
     - name: Build and test
-      uses: vmactions/freebsd-vm at v1.4.5
+      uses: vmactions/freebsd-vm at v1.4.8
       with:
         release: "15.0"
         envs: CCACHE_COMPRESS CCACHE_COMPRESSLEVEL CCACHE_MAXSIZE
@@ -524,7 +524,7 @@ jobs:
           rm -rf build
       with:
         path: .ccache
@@ -540,10 +540,10 @@ jobs:
         sudo -E apt-get autopurge -y needrestart
         sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make cmake emscripten ccache
       with:
         path: .ccache
@@ -562,7 +562,7 @@ jobs:
         ccache --show-stats
       with:
         path: .ccache
@@ -582,7 +582,7 @@ jobs:
         sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
         python3 -m pip install --disable-pip-version-check --user codespell
     - name: 'cppcheck'
       run: ./tools/cppcheck.sh
@@ -605,7 +605,7 @@ jobs:
         python3 -m pip install --disable-pip-version-check --user cmake==3.15.*
       with:
         path: geos
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index 39126ac0d..3b2190fcf 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -36,11 +36,11 @@ jobs:
         # Learn more about CodeQL language support at https://aka.ms/codeql-docs/language-support
     steps:
     # Initializes the CodeQL tools for scanning.
     - name: Initialize CodeQL
-      uses: github/codeql-action/init at v4.36.0
+      uses: github/codeql-action/init at v4.36.2
       with:
         languages: ${{ matrix.language }}
         # If you wish to specify custom queries, you can do so here or in a config file.
@@ -63,6 +63,6 @@ jobs:
           make -j$(nproc)
     - name: Perform CodeQL Analysis
-      uses: github/codeql-action/analyze at v4.36.0
+      uses: github/codeql-action/analyze at v4.36.2
       with:
         category: "/language:${{matrix.language}}"
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index d9168c715..af7b5e652 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -24,7 +24,7 @@ jobs:
     steps:
     - name: Docker meta
@@ -54,7 +54,7 @@ jobs:
         cp tools/ci/geosop/Dockerfile .
     - name: Build and Push
-      uses: docker/build-push-action at v7
+      uses: docker/build-push-action at v7.2.0
       with:
         context: .
         push: true
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
index 2920c83ae..2931ed4ae 100644
--- a/.github/workflows/release.yml
+++ b/.github/workflows/release.yml
@@ -32,7 +32,7 @@ jobs:
         uname -a
         sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
     - name: Get tag
diff --git a/.github/workflows/web.yml b/.github/workflows/web.yml
index cdd46c346..152377359 100644
--- a/.github/workflows/web.yml
+++ b/.github/workflows/web.yml
@@ -27,7 +27,7 @@ jobs:
     - name: 'Check Out 📗'
+      uses: actions/checkout at v7.0.0
     - name: 'Hugo Build 🛠'
       # ...or replace 'master' with a full version tag, such as: v0.64.1
hooks/post-receive
More information about the geos-commits mailing list
