[geos-commits] [SCM] GEOS branch main updated. 8385781ea869e09719a92f0d7240c4ba800501e8
Wed Jul 1 16:43:43 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  8385781ea869e09719a92f0d7240c4ba800501e8 (commit)
      from  5ffc04e4be506fe32ef237851ccc60ff400449de (commit)
revisions in full, below.
commit 8385781ea869e09719a92f0d7240c4ba800501e8
Author: dependabot[bot] <49699333+dependabot[bot]@users.noreply.github.com>
Date:   Thu Jul 2 11:43:13 2026 +1200
    Bump the all-actions group with 6 updates (#1463)
    * Bump the all-actions group with 6 updates
    - Updates `actions/checkout` from 6.0.2 to 7.0.0
    - Updates `actions/cache` from 5 to 6.1.0
    - Updates `codecov/codecov-action` from 6 to 7
    - Updates `vmactions/freebsd-vm` from 1.4.5 to 1.4.8
    - Updates `github/codeql-action` from 4.36.0 to 4.36.2
    - Updates `docker/build-push-action` from 7 to 7.3.0
    * Updates `lammy/msvc-dev-cmd` from 1 to 1.13.0
    * Updates `vmactions/freebsd-vm` from 1.4.8 to 1.5.0
    * Switch GHA from ilammy/msvc-dev-cmd to TheMrMilchmann/setup-msvc-dev
    Signed-off-by: dependabot[bot] <support at github.com>
    Co-authored-by: dependabot[bot] <49699333+dependabot[bot]@users.noreply.github.com>
    Co-authored-by: Mike Taves <mwtoews at gmail.com>
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 5f7a5e237..6df0cef55 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -197,10 +197,10 @@ jobs:
         python3 -m pip install --disable-pip-version-check --user cmake==${{ matrix.ci.cmake }}
         echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
-    - uses: actions/checkout at v6.0.2
+    - uses: actions/checkout at v7.0.0
     - name: Retrieve build cache
-      uses: actions/cache/restore at v5
+      uses: actions/cache/restore at v6.1.0
       with:
         path: .ccache
@@ -227,7 +227,7 @@ jobs:
         ccache --show-stats
     - name: Save build cache
-      uses: actions/cache/save at v5
+      uses: actions/cache/save at v6.1.0
       with:
         path: .ccache
         key: ${{ steps.restore-cache.outputs.cache-primary-key }}
@@ -263,7 +263,7 @@ jobs:
     - name: Upload Coverage to Codecov
       if: ${{ matrix.ci.build_type == 'Coverage' && !cancelled() }}
-      uses: codecov/codecov-action at v6
+      uses: codecov/codecov-action at v7
       with:
         fail_ci_if_error: false
         files: build/coverage.info
@@ -281,7 +281,7 @@ jobs:
         build_type: ['Debug', 'Release']
     steps:
     - name: 'Setup'
       uses: msys2/setup-msys2 at v2
@@ -295,7 +295,7 @@ jobs:
           mingw-w64-x86_64-gcc
       with:
         path: .ccache
@@ -316,7 +316,7 @@ jobs:
         ccache --show-stats --verbose
       with:
         path: .ccache
@@ -337,7 +337,7 @@ jobs:
             arch: arm64
     steps:
     # ccache not supported for this generator and/or Debug
@@ -378,10 +378,10 @@ jobs:
     runs-on: ${{ matrix.ci.os }}
     steps:
       with:
         path: .ccache
@@ -392,7 +392,7 @@ jobs:
       run: choco install ccache ninja
     - name: Activate MSVC
-      uses: ilammy/msvc-dev-cmd at v1
+      uses: TheMrMilchmann/setup-msvc-dev at v4
       with:
         arch: ${{ matrix.ci.arch }}
@@ -415,7 +415,7 @@ jobs:
       with:
         path: .ccache
@@ -459,10 +459,10 @@ jobs:
         which clang++
         clang++ --version
       with:
         path: .ccache
@@ -482,7 +482,7 @@ jobs:
         ccache --show-stats
       with:
         path: .ccache
@@ -495,10 +495,10 @@ jobs:
     runs-on: ubuntu-latest
     steps:
       with:
         path: .ccache
@@ -506,7 +506,7 @@ jobs:
         restore-keys: freebsd
     - name: Build and test
-      uses: vmactions/freebsd-vm at v1.4.5
+      uses: vmactions/freebsd-vm at v1.5.0
       with:
         release: "15.0"
         envs: CCACHE_COMPRESS CCACHE_COMPRESSLEVEL CCACHE_MAXSIZE
@@ -524,7 +524,7 @@ jobs:
           rm -rf build
       with:
         path: .ccache
@@ -540,10 +540,10 @@ jobs:
         sudo -E apt-get autopurge -y needrestart
         sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make cmake emscripten ccache
       with:
         path: .ccache
@@ -562,7 +562,7 @@ jobs:
         ccache --show-stats
       with:
         path: .ccache
@@ -582,7 +582,7 @@ jobs:
         sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
         python3 -m pip install --disable-pip-version-check --user codespell
     - name: 'cppcheck'
       run: ./tools/cppcheck.sh
@@ -605,7 +605,7 @@ jobs:
         python3 -m pip install --disable-pip-version-check --user cmake==3.15.*
       with:
         path: geos
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index 39126ac0d..3b2190fcf 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -36,11 +36,11 @@ jobs:
         # Learn more about CodeQL language support at https://aka.ms/codeql-docs/language-support
     steps:
     # Initializes the CodeQL tools for scanning.
     - name: Initialize CodeQL
-      uses: github/codeql-action/init at v4.36.0
+      uses: github/codeql-action/init at v4.36.2
       with:
         languages: ${{ matrix.language }}
         # If you wish to specify custom queries, you can do so here or in a config file.
@@ -63,6 +63,6 @@ jobs:
           make -j$(nproc)
     - name: Perform CodeQL Analysis
-      uses: github/codeql-action/analyze at v4.36.0
+      uses: github/codeql-action/analyze at v4.36.2
       with:
         category: "/language:${{matrix.language}}"
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index d9168c715..8689d26ad 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -24,7 +24,7 @@ jobs:
     steps:
     - name: Docker meta
@@ -54,7 +54,7 @@ jobs:
         cp tools/ci/geosop/Dockerfile .
     - name: Build and Push
-      uses: docker/build-push-action at v7
+      uses: docker/build-push-action at v7.3.0
       with:
         context: .
         push: true
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
index 2920c83ae..2931ed4ae 100644
--- a/.github/workflows/release.yml
+++ b/.github/workflows/release.yml
@@ -32,7 +32,7 @@ jobs:
         uname -a
         sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
     - name: Get tag
diff --git a/.github/workflows/web.yml b/.github/workflows/web.yml
index cdd46c346..152377359 100644
--- a/.github/workflows/web.yml
+++ b/.github/workflows/web.yml
@@ -27,7 +27,7 @@ jobs:
     - name: 'Check Out 📗'
+      uses: actions/checkout at v7.0.0
     - name: 'Hugo Build 🛠'
       # ...or replace 'master' with a full version tag, such as: v0.64.1
Summary of changes:
 .github/workflows/ci.yml        | 48 ++++++++++++++++++++---------------------
 .github/workflows/codeql.yml    |  6 +++---
 .github/workflows/container.yml |  4 ++--
 .github/workflows/release.yml   |  2 +-
 .github/workflows/web.yml       |  2 +-
 5 files changed, 31 insertions(+), 31 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
