[geos-commits] [SCM] GEOS branch main updated. 40b2404209e65edd044386b11c4989d8226aeecb
git at osgeo.org
git at osgeo.org
Tue Jul 7 08:33:59 PDT 2026
the project "GEOS".
The branch, main has been updated
via 40b2404209e65edd044386b11c4989d8226aeecb (commit)
from 28726481ede802eee10a9585f9df781873242a71 (commit)
revisions in full, below.
commit 40b2404209e65edd044386b11c4989d8226aeecb
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Jul 7 11:33:37 2026 -0400
Add progress reporting mechanism (#1466)
Co-authored-by: Even Rouault <even.rouault at spatialys.com>
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index a421eabc0..568f1c0b4 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -2194,5 +2194,4 @@ extern "C" {
return GEOSCoverageSimplifyVW_r(handle, input, tolerance, preserveBoundary);
} /* extern "C" */
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 8f706e543..cb91502fd 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -117,6 +117,21 @@ typedef void (*GEOSMessageHandler)(GEOS_PRINTF_FORMAT const char *fmt, ...)
typedef void (*GEOSMessageHandler_r)(const char *message, void *userdata);
+ * A GEOS progress callback function.
+ * Such function takes a progress ratio (0 to 1), and an optional message.
+ * \param progressRatio Progression ratio (between 0 and 1)
+ * \param message Information message (can be NULL)
+ * \param userdata the user data pointer that was passed to GEOS together with
+ * this callback.
+typedef void (GEOSProgressCallback)(double progressRatio,
+ const char* message, void* userdata);
* When we're included by geos_c.cpp, these types are #defined to the
* C++ definitions via preprocessor. We don't touch them to allow the
@@ -426,6 +441,23 @@ extern void GEOS_DLL GEOS_interruptRequest(void);
extern void GEOS_DLL GEOS_interruptCancel(void);
+/* ========== Progress monitoring ========== */
+* Register a function to be called with progress updates
+* \param extHandle the context returned by \ref GEOS_init_r.
+* \param cb Callback function to invoke
+* \param userData optional data to be pe provided as argument to callback
+* \return the previously registered callback, or NULL
+* \see GEOSProgressCallback
+* \since 3.15
+extern GEOSProgressCallback GEOS_DLL *GEOSContext_setProgressCallback_r(
+ GEOSContextHandle_t extHandle,
+ GEOSProgressCallback* cb,
+ void* userData);
/* ========== Initialization and Cleanup ========== */
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 7b06105cf..32254f9e3 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -84,6 +84,7 @@
#include <geos/operation/cluster/GeometryIntersectsClusterFinder.h>
#include <geos/operation/distance/DistanceOp.h>
#include <geos/operation/distance/IndexedFacetDistance.h>
+#include <geos/operation/union/UnaryUnionOp.h>
#include <geos/operation/grid/Grid.h>
#include <geos/operation/grid/GridIntersection.h>
#include <geos/operation/linemerge/LineMerger.h>
@@ -122,6 +123,7 @@
#include <geos/util/Interrupt.h>
#include <geos/util/UniqueCoordinateArrayFilter.h>
#include <geos/util/Machine.h>
+#include <geos/util/Progress.h>
#include <geos/version.h>
// This should go away
@@ -255,6 +257,8 @@ typedef struct GEOSContextHandle_HS {
GEOSMessageHandler_r errorMessageNew;
GEOSContextInterruptCallback* interrupt_cb;
void* interrupt_cb_data;
+ GEOSProgressCallback* progress_cb;
+ void* progress_cb_data;
void* errorData;
uint8_t WKBOutputDims;
int WKBByteOrder;
@@ -262,6 +266,7 @@ typedef struct GEOSContextHandle_HS {
std::unique_ptr<Point> point2d;
std::optional<GEOSLineToCurveParams> lineToCurveParams;
std::optional<GEOSCurveToLineParams> curveToLineParams;
+ geos::util::ProgressFunction progressFunction;
GEOSContextHandle_HS()
@@ -273,6 +278,8 @@ typedef struct GEOSContextHandle_HS {
errorMessageNew(nullptr),
interrupt_cb(nullptr),
interrupt_cb_data(nullptr),
+ progress_cb(nullptr),
+ progress_cb_data(nullptr),
errorData(nullptr),
point2d(nullptr)
@@ -284,6 +291,13 @@ typedef struct GEOSContextHandle_HS {
setNoticeHandler(nullptr);
setErrorHandler(nullptr);
initialized = 1;
+ progressFunction = [this](double progress, const char* message)
+ if (progress_cb) {
+ (*progress_cb)(progress, message, progress_cb_data);
GEOSMessageHandler
@@ -339,6 +353,15 @@ typedef struct GEOSContextHandle_HS {
return old;
+ setProgressCallback(GEOSProgressCallback* cb, void* userData)
+ auto old = progress_cb;
+ progress_cb = cb;
+ progress_cb_data = userData;
+ return old;
void
NOTICE_MESSAGE(GEOS_PRINTF_FORMAT const char *fmt, ...) GEOS_PRINTF_FORMAT_ATTR(2, 3)
@@ -548,17 +571,49 @@ struct InterruptManager {
struct NotInterruptible {
- NotInterruptible(GEOSContextHandle_t handle) {
+ explicit NotInterruptible(GEOSContextHandle_t handle) {
(void) handle;
+using Interruptible = InterruptManager;
+// RAII construct that ensures a progress callback is called at completion of an operation,
+// even if that operation does not support progress reporting.
+struct DefaultProgress {
+ explicit DefaultProgress(GEOSContextHandle_t handle)
+ : cb(handle->progress_cb)
+ , cb_data(handle->progress_cb_data)
+ ~DefaultProgress() {
+ if (cb) {
+ (*cb)(1.0, "", cb_data);
+ GEOSProgressCallback* cb;
+ void* cb_data;
+// Construct that avoids automatic progress reporting.
+// Used for functions that have progress reporting implemented.
+struct ReportsProgress {
+ explicit ReportsProgress(GEOSContextHandle_t handle) {
+ (void) handle;
+// Construct for trivial functions that avoids automatic progress
+// reporting.
+using NoProgress = ReportsProgress;
} // namespace anonymous
// Execute a lambda, using the given context handle to process errors.
// Return errval on error.
// Errval should be of the type returned by f, unless f returns a bool in which case we promote to char.
-template<typename InterruptManagerType=InterruptManager, typename F>
+template<typename InterruptManagerType=InterruptManager, typename ProgressManagerType=DefaultProgress, typename F>
inline auto execute(
typename std::conditional<std::is_same<decltype(std::declval<F>()()),bool>::value,
@@ -575,6 +630,7 @@ inline auto execute(
InterruptManagerType ic(handle);
+ ProgressManagerType pc(handle);
try {
return f();
@@ -589,7 +645,7 @@ inline auto execute(
// Return nullptr on error.
-template<typename InterruptManagerType=InterruptManager, typename F, typename std::enable_if<!std::is_void<decltype(std::declval<F>()())>::value, std::nullptr_t>::type = nullptr>
+template<typename InterruptManagerType=InterruptManager, typename ProgressManagerType=DefaultProgress, typename F, typename std::enable_if<!std::is_void<decltype(std::declval<F>()())>::value, std::nullptr_t>::type = nullptr>
inline auto execute(GEOSContextHandle_t extHandle, F&& f) -> decltype(f()) {
if (extHandle == nullptr) {
throw std::runtime_error("context handle is uninitialized, call initGEOS");
@@ -601,6 +657,7 @@ inline auto execute(GEOSContextHandle_t extHandle, F&& f) -> decltype(f()) {
try {
return f();
@@ -615,7 +672,7 @@ inline auto execute(GEOSContextHandle_t extHandle, F&& f) -> decltype(f()) {
// No return value.
-template<typename InterruptManagerType=InterruptManager, typename F, typename std::enable_if<std::is_void<decltype(std::declval<F>()())>::value, std::nullptr_t>::type = nullptr>
+template<typename InterruptManagerType=InterruptManager, typename ProgressManagerType=DefaultProgress, typename F, typename std::enable_if<std::is_void<decltype(std::declval<F>()())>::value, std::nullptr_t>::type = nullptr>
inline void execute(GEOSContextHandle_t extHandle, F&& f) {
GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
@@ -653,10 +710,10 @@ Geometry* convertCurvesAndExecute(GEOSContextHandle_t extHandle, const Geometry*
-template<typename F>
Geometry* convertCurvesAndExecute(GEOSContextHandle_t extHandle, const Geometry* g1, F&& f)
- return execute(extHandle, [&]() {
+ return execute<InterruptManagerType, ProgressManagerType>(extHandle, [&]() {
const auto geom1 = convertToLineIfNeeded(extHandle, g1);
auto g3 = f(geom1.get());
@@ -750,6 +807,16 @@ extern "C" {
return handle->setInterruptHandler(cb, userData);
+ GEOSContext_setProgressCallback_r(GEOSContextHandle_t extHandle, GEOSProgressCallback* cb, void* userData)
+ if(0 == extHandle->initialized) {
+ return nullptr;
+ return extHandle->setProgressCallback(cb, userData);
void GEOSContext_setCurveToLineParams_r(GEOSContextHandle_t extHandle, const GEOSCurveToLineParams* params)
if (params) {
@@ -1241,7 +1308,7 @@ extern "C" {
int
GEOSArea_r(GEOSContextHandle_t extHandle, const Geometry* g, double* area)
- return execute<NotInterruptible>(extHandle, 0, [&]() {
+ return execute<NotInterruptible, NoProgress>(extHandle, 0, [&]() {
*area = g->getArea();
return 1;
@@ -1250,7 +1317,7 @@ extern "C" {
int
GEOSLength_r(GEOSContextHandle_t extHandle, const Geometry* g, double* length)
*length = g->getLength();
return 1;
@@ -2006,7 +2073,8 @@ extern "C" {
Geometry*
GEOSUnaryUnion_r(GEOSContextHandle_t extHandle, const Geometry* g)
- return convertCurvesAndExecute(extHandle, g, [&](const Geometry* input1) {
+ return convertCurvesAndExecute<Interruptible, ReportsProgress>(extHandle, g, [&](const Geometry* input1) {
+ return geos::operation::geounion::UnaryUnionOp::Union(*input1, &extHandle->progressFunction);
return input1->Union();
@@ -2014,7 +2082,7 @@ extern "C" {
Geometry*
GEOSUnaryUnionPrec_r(GEOSContextHandle_t extHandle, const Geometry* g1, double gridSize)
+ return execute<Interruptible, DefaultProgress>(extHandle, [&]() {
std::unique_ptr<PrecisionModel> pm;
if(gridSize != 0) {
@@ -2276,7 +2344,7 @@ extern "C" {
int
GEOSGetNumInteriorRings_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- return execute<NotInterruptible>(extHandle, -1, [&]() {
+ return execute<NotInterruptible, NoProgress>(extHandle, -1, [&]() {
const Surface* p = dynamic_cast<const Surface*>(g1);
if(!p) {
throw IllegalArgumentException("Argument is not a Surface");
@@ -2290,7 +2358,7 @@ extern "C" {
int
GEOSGetNumGeometries_r(GEOSContextHandle_t extHandle, const Geometry* g1)
return static_cast<int>(g1->getNumGeometries());
@@ -2303,7 +2371,7 @@ extern "C" {
const Geometry*
GEOSGetGeometryN_r(GEOSContextHandle_t extHandle, const Geometry* g1, int n)
- return execute<NotInterruptible>(extHandle, [&]() {
+ return execute<NotInterruptible, NoProgress>(extHandle, [&]() {
if(n < 0) {
throw IllegalArgumentException("Index must be non-negative.");
@@ -2314,7 +2382,7 @@ extern "C" {
int
GEOSGetNumCurves_r(GEOSContextHandle_t extHandle, const Geometry* g1)
const Curve* curve = dynamic_cast<const Curve*>(g1);
if (curve) {
return static_cast<int>(curve->getNumCurves());
@@ -2327,7 +2395,7 @@ extern "C" {
const GEOSGeometry*
GEOSGetCurveN_r(GEOSContextHandle_t extHandle, const Geometry* g, int n)
- return execute<NotInterruptible>(extHandle, [&]() -> const Geometry* {
+ return execute<NotInterruptible, NoProgress>(extHandle, [&]() -> const Geometry* {
if(n < 0) {
@@ -2528,7 +2596,7 @@ extern "C" {
const Geometry*
GEOSGetExteriorRing_r(GEOSContextHandle_t extHandle, const Geometry* g1)
if(!p) {
throw IllegalArgumentException("Invalid argument (must be a Surface)");
@@ -2544,7 +2612,7 @@ extern "C" {
const Geometry*
GEOSGetInteriorRingN_r(GEOSContextHandle_t extHandle, const Geometry* g1, int n)
if(!p) {
@@ -3374,7 +3442,7 @@ extern "C" {
GEOSCoordSeq_setOrdinate_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs,
unsigned int idx, unsigned int dim, double val)
cs->setOrdinate(idx, dim, val);
return 1;
@@ -3407,7 +3475,7 @@ extern "C" {
int
GEOSCoordSeq_setXY_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs, unsigned int idx, double x, double y)
cs->setAt(CoordinateXY{x, y}, idx);
return 1;
@@ -3416,7 +3484,7 @@ extern "C" {
int
GEOSCoordSeq_setXYZ_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs, unsigned int idx, double x, double y, double z)
cs->setAt(Coordinate{x, y, z}, idx);
return 1;
@@ -3434,7 +3502,7 @@ extern "C" {
GEOSCoordSeq_getOrdinate_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs,
unsigned int idx, unsigned int dim, double* val)
*val = cs->getOrdinate(idx, dim);
return 1;
@@ -3467,7 +3535,7 @@ extern "C" {
int
GEOSCoordSeq_getXY_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int idx, double* x, double* y)
auto& c = cs->getAt<CoordinateXY>(idx);
*x = c.x;
*y = c.y;
@@ -3478,7 +3546,7 @@ extern "C" {
int
GEOSCoordSeq_getXYZ_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int idx, double* x, double* y, double* z)
auto& c = cs->getAt(idx);
*x = c.x;
*y = c.y;
@@ -3490,7 +3558,7 @@ extern "C" {
int
GEOSCoordSeq_getSize_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int* size)
const std::size_t sz = cs->getSize();
*size = static_cast<unsigned int>(sz);
return 1;
@@ -3500,7 +3568,7 @@ extern "C" {
int
GEOSCoordSeq_getDimensions_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int* dims)
const std::size_t dim = cs->getDimension();
*dims = static_cast<unsigned int>(dim);
@@ -5100,11 +5168,11 @@ extern "C" {
GEOSCoverageSimplifyVW_r(GEOSContextHandle_t extHandle,
const Geometry* input,
double tolerance,
- int preserveBoundary)
+ int preserveBoundary) {
using geos::coverage::CoverageSimplifier;
- return convertCurvesAndExecute(extHandle, input, [&](const Geometry* linearized) -> std::unique_ptr<Geometry> {
+ return convertCurvesAndExecute<Interruptible, ReportsProgress>(extHandle, input, [&](const Geometry* linearized) -> std::unique_ptr<Geometry> {
const GeometryCollection* col = dynamic_cast<const GeometryCollection*>(linearized);
if (!col)
return nullptr;
@@ -5116,10 +5184,10 @@ extern "C" {
CoverageSimplifier cov(coverage);
std::vector<std::unique_ptr<Geometry>> simple;
if (preserveBoundary == 1) {
- simple = cov.simplifyInner(tolerance);
+ simple = cov.simplifyInner(tolerance, &extHandle->progressFunction);
else if (preserveBoundary == 0) {
- simple = cov.simplify(tolerance);
+ simple = cov.simplify(tolerance, &extHandle->progressFunction);
else return nullptr;
diff --git a/include/geos/coverage/CoverageSimplifier.h b/include/geos/coverage/CoverageSimplifier.h
index 74df234dd..4c87e12eb 100644
--- a/include/geos/coverage/CoverageSimplifier.h
+++ b/include/geos/coverage/CoverageSimplifier.h
@@ -19,6 +19,7 @@
#include <vector>
#include <memory>
#include <geos/export.h>
namespace geos {
@@ -87,15 +88,18 @@ public:
* @param coverage a set of polygonal geometries forming a coverage
* @param tolerance the simplification tolerance
+ * @param progressFunction Progress function, or nullptr.
* @return the simplified polygons
static std::vector<std::unique_ptr<Geometry>> simplify(
std::vector<const Geometry*>& coverage,
- double tolerance);
+ double tolerance,
+ geos::util::ProgressFunction* progressFunction = nullptr);
const std::vector<std::unique_ptr<Geometry>>& coverage,
+ double tolerance,
* Simplifies the inner boundaries of a set of polygonal geometries forming a coverage,
@@ -104,24 +108,28 @@ public:
static std::vector<std::unique_ptr<Geometry>> simplifyInner(
+ double tolerance,
+ geos::util::ProgressFunction* progressFunction);
+ double tolerance,
* Computes the simplified coverage, preserving the coverage topology.
+ double tolerance, geos::util::ProgressFunction* progressFunction);
* Computes the inner-boundary simplified coverage,
@@ -129,10 +137,11 @@ public:
* and leaving outer boundary edges unchanged.
private:
@@ -145,7 +154,8 @@ private:
void simplifyEdges(
std::vector<CoverageEdge*> edges,
const MultiLineString* constraints,
+ double tolerance,
void setCoordinates(
std::vector<CoverageEdge*>& edges,
diff --git a/include/geos/coverage/TPVWSimplifier.h b/include/geos/coverage/TPVWSimplifier.h
index 0b904c8a8..ec2bce993 100644
--- a/include/geos/coverage/TPVWSimplifier.h
+++ b/include/geos/coverage/TPVWSimplifier.h
@@ -21,6 +21,7 @@
#include <geos/simplify/LinkedLine.h>
#include <geos/coverage/Corner.h>
namespace geos {
@@ -164,11 +165,13 @@ public:
* @param lines the lines to simplify
* @param distanceTolerance the simplification tolerance
* @return the simplified lines
static std::unique_ptr<MultiLineString> simplify(
const MultiLineString* lines,
- double distanceTolerance);
+ double distanceTolerance,
* Simplifies a set of lines, preserving the topology of the lines between
@@ -181,13 +184,15 @@ public:
* @param freeRings flags indicating which ring edges do not have node endpoints
* @param constraintLines the linear constraints
std::vector<bool>& freeRings,
const MultiLineString* constraintLines,
// Constructor
TPVWSimplifier(const MultiLineString* lines,
@@ -209,11 +214,12 @@ private:
void setConstraints(const MultiLineString* constraints);
- std::unique_ptr<MultiLineString> simplify();
+ std::unique_ptr<MultiLineString> simplify(geos::util::ProgressFunction* progressFunction);
std::vector<Edge> createEdges(
- std::vector<bool>& freeRing);
+ std::vector<bool>& freeRing,
}; // TPVWSimplifier
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 8fb442832..5a4a4fa24 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -35,6 +35,7 @@
#include <geos/geom/Dimension.h> // for Dimension::DimensionType
#include <geos/geom/GeometryComponentFilter.h> // for inheritance
#include <geos/geom/CoordinateSequence.h> // to materialize CoordinateSequence
#include <algorithm>
#include <string>
@@ -748,9 +749,15 @@ public:
* @see UnaryUnionOp
- Ptr Union() const;
+ Ptr Union(geos::util::ProgressFunction* progressFunction) const;
// throw(IllegalArgumentException *, TopologyException *);
+ Ptr Union() const
+ geos::util::ProgressFunction* progressFunction = nullptr;
+ return Union(progressFunction);
* \brief
* Returns a Geometry representing the points making up this
diff --git a/include/geos/operation/union/CascadedPolygonUnion.h b/include/geos/operation/union/CascadedPolygonUnion.h
index 2b1e29267..fcc5ba9a7 100644
--- a/include/geos/operation/union/CascadedPolygonUnion.h
+++ b/include/geos/operation/union/CascadedPolygonUnion.h
@@ -25,6 +25,7 @@
#include <geos/operation/union/UnionStrategy.h>
// Forward declarations
namespace geos {
@@ -140,7 +141,7 @@ public:
* ownership of elements *and* vector are left to caller.
static std::unique_ptr<geom::Geometry> Union(std::vector<geom::Polygon*>* polys);
- static std::unique_ptr<geom::Geometry> Union(std::vector<geom::Polygon*>* polys, UnionStrategy* unionFun);
+ static std::unique_ptr<geom::Geometry> Union(std::vector<geom::Polygon*>* polys, UnionStrategy* unionFun, geos::util::ProgressFunction* progressFunction);
/** \brief
* Computes the union of a set of polygonal [Geometrys](@ref geom::Geometry).
@@ -149,17 +150,18 @@ public:
* @param start start iterator
* @param end end iterator
* @param unionStrategy strategy to apply
+ * @param progressFunction progress function
template <class T>
- Union(T start, T end, UnionStrategy *unionStrategy)
+ Union(T start, T end, UnionStrategy *unionStrategy, geos::util::ProgressFunction* progressFunction)
std::vector<geom::Polygon*> polys;
for(T i = start; i != end; ++i) {
const geom::Polygon* p = dynamic_cast<const geom::Polygon*>(*i);
polys.push_back(const_cast<geom::Polygon*>(p));
- return Union(&polys, unionStrategy);
+ return Union(&polys, unionStrategy, progressFunction);
/** \brief
@@ -167,8 +169,9 @@ public:
* @param polys a collection of polygonal [Geometrys](@ref geom::Geometry).
* Ownership of elements *and* vector are left to caller.
- static std::unique_ptr<geom::Geometry> Union(const geom::MultiPolygon* polys);
+ static std::unique_ptr<geom::Geometry> Union(const geom::MultiPolygon* polys, geos::util::ProgressFunction* progressFunction);
/** \brief
* Creates a new instance to union the given collection of
@@ -192,10 +195,11 @@ public:
/** \brief
* Computes the union of the input geometries.
* @return the union of the input geometries
* @return `null` if no input geometries were provided
- std::unique_ptr<geom::Geometry> Union();
+ std::unique_ptr<geom::Geometry> Union(geos::util::ProgressFunction* progressFunction);
private:
@@ -211,7 +215,11 @@ private:
* @param end the index after the end of the section
* @return the union of the list section
- std::unique_ptr<geom::Geometry> binaryUnion(const std::vector<const geom::Geometry*> & geoms, std::size_t start, std::size_t end);
+ std::unique_ptr<geom::Geometry> binaryUnion(
+ const std::vector<const geom::Geometry*> & geoms,
+ std::size_t start,
+ std::size_t end,
+ std::function<void()>* unitProgress);
* Computes the union of two geometries,
diff --git a/include/geos/operation/union/UnaryUnionOp.h b/include/geos/operation/union/UnaryUnionOp.h
index 3fed7e32b..98b6a9e70 100644
--- a/include/geos/operation/union/UnaryUnionOp.h
+++ b/include/geos/operation/union/UnaryUnionOp.h
@@ -28,6 +28,7 @@
#include <geos/geom/Polygon.h>
#include <geos/geom/util/GeometryExtracter.h>
#include <geos/operation/union/CascadedPolygonUnion.h>
#include <geos/util.h>
@@ -93,7 +94,8 @@ public:
Union(const T& geoms)
UnaryUnionOp op(geoms);
- return op.Union();
+ return op.Union(progressFunction);
template <class T>
@@ -102,14 +104,15 @@ public:
geom::GeometryFactory& geomFact)
UnaryUnionOp op(geoms, geomFact);
- Union(const geom::Geometry& geom)
+ Union(const geom::Geometry& geom, geos::util::ProgressFunction* progressFunction)
UnaryUnionOp op(geom);
template <class T>
@@ -150,7 +153,7 @@ public:
* @return an empty GEOMETRYCOLLECTION if no geometries were provided
* in the input
private:
diff --git a/include/geos/util/Progress.h b/include/geos/util/Progress.h
new file mode 100644
index 000000000..c581c60ac
--- /dev/null
+++ b/include/geos/util/Progress.h
@@ -0,0 +1,84 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2025 Even Rouault <even.rouault at spatialys.com>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <functional>
+#include <geos/export.h>
+namespace geos {
+namespace util { // geos::util
+/** Signature of a progression function.
+ * Such function takes a progression ratio (between 0 and 1), and an optional
+ * message.
+typedef std::function<void(double, const char*)> ProgressFunction;
+/** Do progress function related processing for an iteration loop of iterCount iterations.
+ * This function will invoke (*progressFunction) every notificationInterval
+ *iteration.
+ * This function will return, or throw a geos::util::InterruptedException.
+ * A typical use is:
+ * \code
+ * const size_t notificationInterval = std::max<size_t>(1, iterCount / 100);
+ * for (size_t i = 0, iNotify = 0; i < iterCount; ++i) {
+ * // do something useful
+ * if (progressFunction) {
+ * geos::util::ProgressFunctionIteration(*progressFunction, i, iterCount, iNotify, notificationInterval);
+ * (*progressFunction)(1.0, nullptr);
+ * \endcode
+ * @param i Current index of loop iteration.
+ * @param iterCount Total number of loop iteration.
+ * @param iNotify Notification counter, updated by this function. Must be set by the caller (before the loop) to 0.
+ * @param notificationInterval Notification interval (e.g. iterCount / 100).
+void ProgressFunctionIteration(ProgressFunction& progressFunction, size_t i, size_t iterCount, size_t& iNotify, size_t notificationInterval);
+/** Create a scaled progress function.
+ * Sometimes when an operation wants to report progress, it actually
+ * invokes several subprocesses which also take a ProgressFunction,
+ * and it is desirable to map the progress of each sub operation into
+ * a portion of 0.0 to 1.0 progress of the overall process. The scaled
+ * progress function can be used for this.
+ * For each subsection a scaled progress function is created and
+ * instead of passing the overall progress func down to the sub functions,
+ * the scale progress function is passed instead.
+ * @param ratioMin the value to which 0.0 in the sub operation is mapped.
+ * @param ratioMax the value to which 1.0 is the sub operation is mapped.
+ * @param progressFunction the overall progress function.
+ * @return scaled progress function.
+ProgressFunction CreateScaledProgressFunction(double ratioMin, double ratioMax,
+ ProgressFunction& progressFunction);
+} // namespace geos::util
diff --git a/src/coverage/CoverageSimplifier.cpp b/src/coverage/CoverageSimplifier.cpp
index 0623cedce..fd52f0e84 100644
--- a/src/coverage/CoverageSimplifier.cpp
+++ b/src/coverage/CoverageSimplifier.cpp
@@ -26,7 +26,7 @@
using geos::geom::Geometry;
using geos::geom::GeometryFactory;
using geos::geom::MultiLineString;
+using geos::util::ProgressFunction;
namespace geos { // geos
namespace coverage { // geos.coverage
@@ -35,23 +35,25 @@ namespace coverage { // geos.coverage
CoverageSimplifier::simplify(
- double tolerance)
+ double tolerance,
+ ProgressFunction* progressFunction)
CoverageSimplifier simplifier(coverage);
- return simplifier.simplify(tolerance);
+ return simplifier.simplify(tolerance, progressFunction);
/* public static */
- double tolerance)
+ double tolerance,
std::vector<const Geometry*> geoms;
for (auto& geom : coverage) {
geoms.push_back(geom.get());
- return simplify(geoms, tolerance);
+ return simplify(geoms, tolerance, progressFunction);
@@ -59,10 +61,11 @@ CoverageSimplifier::simplify(
CoverageSimplifier::simplifyInner(
- double tolerance)
+ double tolerance,
- return simplifier.simplifyInner(tolerance);
+ return simplifier.simplifyInner(tolerance, progressFunction);
@@ -70,13 +73,14 @@ CoverageSimplifier::simplifyInner(
- double tolerance)
+ double tolerance,
- return simplifyInner(geoms, tolerance);
+ return simplifyInner(geoms, tolerance, progressFunction);
@@ -94,23 +98,25 @@ CoverageSimplifier::CoverageSimplifier(const std::vector<const Geometry*>& cover
/* public */
-CoverageSimplifier::simplify(double tolerance)
+CoverageSimplifier::simplify(double tolerance,
CoverageRingEdges cov(m_input);
- simplifyEdges(cov.getEdges(), nullptr, tolerance);
+ simplifyEdges(cov.getEdges(), nullptr, tolerance, progressFunction);
return cov.buildCoverage();
/* public */
-CoverageSimplifier::simplifyInner(double tolerance)
+CoverageSimplifier::simplifyInner(double tolerance,
std::vector<CoverageEdge*> innerEdges = cov.selectEdges(2);
std::vector<CoverageEdge*> outerEdges = cov.selectEdges(1);
std::unique_ptr<MultiLineString> constraintEdges = CoverageEdge::createLines(outerEdges, m_geomFactory);
- simplifyEdges(innerEdges, constraintEdges.get(), tolerance);
+ simplifyEdges(innerEdges, constraintEdges.get(), tolerance, progressFunction);
@@ -119,11 +125,12 @@ void
CoverageSimplifier::simplifyEdges(
- double tolerance)
+ double tolerance,
std::unique_ptr<MultiLineString> lines = CoverageEdge::createLines(edges, m_geomFactory);
std::vector<bool> freeRings = getFreeRings(edges);
- std::unique_ptr<MultiLineString> linesSimp = TPVWSimplifier::simplify(lines.get(), freeRings, constraints, tolerance);
+ std::unique_ptr<MultiLineString> linesSimp = TPVWSimplifier::simplify(lines.get(), freeRings, constraints, tolerance, progressFunction);
//Assert: mlsSimp.getNumGeometries = edges.length
setCoordinates(edges, linesSimp.get());
diff --git a/src/coverage/TPVWSimplifier.cpp b/src/coverage/TPVWSimplifier.cpp
index 0bf36ac30..d31169774 100644
--- a/src/coverage/TPVWSimplifier.cpp
+++ b/src/coverage/TPVWSimplifier.cpp
@@ -47,10 +47,11 @@ typedef TPVWSimplifier::EdgeIndex EdgeIndex;
TPVWSimplifier simp(lines, distanceTolerance);
- std::unique_ptr<MultiLineString> result = simp.simplify();
+ std::unique_ptr<MultiLineString> result = simp.simplify(progressFunction);
return result;
@@ -61,12 +62,13 @@ TPVWSimplifier::simplify(
const MultiLineString* p_lines,
std::vector<bool>& p_freeRings,
const MultiLineString* p_constraintLines,
TPVWSimplifier simp(p_lines, distanceTolerance);
simp.setFreeRingIndices(p_freeRings);
simp.setConstraints(p_constraintLines);
return result;
@@ -99,21 +101,60 @@ TPVWSimplifier::setFreeRingIndices(std::vector<bool>& freeRing)
/* private */
-TPVWSimplifier::simplify()
+TPVWSimplifier::simplify(geos::util::ProgressFunction* progressFunction)
std::vector<bool> emptyList;
- std::vector<Edge> edges = createEdges(inputLines, isFreeRing);
- std::vector<Edge> constraintEdges = createEdges(constraintLines, emptyList);
+ geos::util::ProgressFunction subProgress;
+ constexpr double RATIO_FIRST_PASS = 0.4;
+ const double ratioInputLinesOverInputAndConstraint =
+ RATIO_FIRST_PASS *
+ static_cast<double>(inputLines ? inputLines->getNumGeometries() : 0) /
+ static_cast<double>(std::max<size_t>(1,
+ (inputLines ? inputLines->getNumGeometries() : 0) +
+ (constraintLines ? constraintLines->getNumGeometries() : 0)));
+ if (progressFunction)
+ subProgress = geos::util::CreateScaledProgressFunction(
+ 0, ratioInputLinesOverInputAndConstraint, *progressFunction);
+ std::vector<Edge> edges = createEdges(inputLines, isFreeRing,
+ progressFunction ? &subProgress : nullptr);
+ ratioInputLinesOverInputAndConstraint, RATIO_FIRST_PASS, *progressFunction);
+ std::vector<Edge> constraintEdges = createEdges(
+ constraintLines, emptyList,
EdgeIndex edgeIndex;
edgeIndex.add(edges);
edgeIndex.add(constraintEdges);
std::vector<std::unique_ptr<LineString>> result;
- for (auto& edge : edges) {
+ const size_t iterCount = edges.size();
+ const size_t notificationInterval = std::max<size_t>(1, iterCount / 100);
+ RATIO_FIRST_PASS, 1.0, *progressFunction);
+ for (size_t i = 0, iNotify = 0; i < iterCount; ++i) {
+ auto& edge = edges[i];
std::unique_ptr<CoordinateSequence> ptsSimp = edge.simplify(edgeIndex);
auto ls = geomFactory->createLineString(std::move(ptsSimp));
result.emplace_back(ls.release());
+ if (progressFunction) {
+ geos::util::ProgressFunctionIteration(subProgress, i, iterCount, iNotify, notificationInterval);
+ (*progressFunction)(1.0, nullptr);
return geomFactory->createMultiLineString(std::move(result));
@@ -122,17 +163,25 @@ TPVWSimplifier::simplify()
std::vector<Edge>
TPVWSimplifier::createEdges(
std::vector<Edge> edges;
if (lines == nullptr)
return edges;
- for (std::size_t i = 0; i < lines->getNumGeometries(); i++) {
+ const size_t iterCount = lines->getNumGeometries();
const LineString* line = lines->getGeometryN(i);
bool isFree = freeRing.empty() ? false : freeRing[i];
edges.emplace_back(line, isFree, areaTolerance);
+ geos::util::ProgressFunctionIteration(*progressFunction, i, iterCount, iNotify, notificationInterval);
return edges;
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index a34c7bf35..b833a0499 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -624,10 +624,10 @@ Geometry::Union(const Geometry* other) const
/* public */
Geometry::Ptr
-Geometry::Union() const
+Geometry::Union(geos::util::ProgressFunction* progressFunction) const
using geos::operation::geounion::UnaryUnionOp;
- return UnaryUnionOp::Union(*this);
+ return UnaryUnionOp::Union(*this, progressFunction);
diff --git a/src/geom/util/GeometryFixer.cpp b/src/geom/util/GeometryFixer.cpp
index 6d73ecbc9..7523978f4 100644
--- a/src/geom/util/GeometryFixer.cpp
+++ b/src/geom/util/GeometryFixer.cpp
@@ -341,7 +341,8 @@ GeometryFixer::unionGeometry(std::vector<const Geometry*>& polys) const
UnaryUnionOp op(polys);
// return OverlayNGRobust::Union(polys);
diff --git a/src/operation/overlayng/OverlayNGRobust.cpp b/src/operation/overlayng/OverlayNGRobust.cpp
index 258a7ecda..3e8da6f9d 100644
--- a/src/operation/overlayng/OverlayNGRobust.cpp
+++ b/src/operation/overlayng/OverlayNGRobust.cpp
@@ -76,7 +76,8 @@ OverlayNGRobust::Union(const Geometry* a)
geounion::UnaryUnionOp op(*a);
SRUnionStrategy unionSRFun;
op.setUnionFunction(&unionSRFun);
/*public static*/
diff --git a/src/operation/overlayng/UnaryUnionNG.cpp b/src/operation/overlayng/UnaryUnionNG.cpp
index f09b987b9..609fa93ee 100644
--- a/src/operation/overlayng/UnaryUnionNG.cpp
+++ b/src/operation/overlayng/UnaryUnionNG.cpp
@@ -37,7 +37,8 @@ UnaryUnionNG::Union(const Geometry* geom, const PrecisionModel& pm)
NGUnionStrategy ngUnionStrat(pm);
geounion::UnaryUnionOp op(*geom);
op.setUnionFunction(&ngUnionStrat);
/*public static*/
diff --git a/src/operation/polygonize/BuildArea.cpp b/src/operation/polygonize/BuildArea.cpp
index 37ccd371e..9f16ac647 100644
--- a/src/operation/polygonize/BuildArea.cpp
+++ b/src/operation/polygonize/BuildArea.cpp
@@ -270,7 +270,7 @@ std::unique_ptr<geom::Geometry> BuildArea::build(const geom::Geometry* geom) {
/* Run a single overlay operation to dissolve shared edges */
auto shp = std::unique_ptr<geom::Geometry>(
- geos::operation::geounion::CascadedPolygonUnion::CascadedPolygonUnion::Union(tmp.get()));
+ geos::operation::geounion::CascadedPolygonUnion::CascadedPolygonUnion::Union(tmp.get(), nullptr));
if( shp ) {
shp->setSRID(geom->getSRID());
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 35a93b0e9..aac120c80 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -47,18 +47,19 @@ std::unique_ptr<geom::Geometry>
CascadedPolygonUnion::Union(std::vector<geom::Polygon*>* polys)
CascadedPolygonUnion op(polys);
-CascadedPolygonUnion::Union(std::vector<geom::Polygon*>* polys, UnionStrategy* unionFun)
+CascadedPolygonUnion::Union(std::vector<geom::Polygon*>* polys, UnionStrategy* unionFun, geos::util::ProgressFunction* progressFunction)
CascadedPolygonUnion op(polys, unionFun);
-CascadedPolygonUnion::Union(const geom::MultiPolygon* multipoly)
+CascadedPolygonUnion::Union(const geom::MultiPolygon* multipoly, geos::util::ProgressFunction* progressFunction)
@@ -67,11 +68,11 @@ CascadedPolygonUnion::Union(const geom::MultiPolygon* multipoly)
CascadedPolygonUnion op(&polys);
-CascadedPolygonUnion::Union()
+CascadedPolygonUnion::Union(geos::util::ProgressFunction* progressFunction)
if(inputPolys->empty()) {
return nullptr;
@@ -94,28 +95,43 @@ CascadedPolygonUnion::Union()
// TODO avoid creating this vector and run binaryUnion off the iterators directly
std::vector<const geom::Geometry*> geoms(index.items().begin(), index.items().end());
- return binaryUnion(geoms, 0, geoms.size());
+ size_t inc = 0;
+ std::function<void()> UnitProgress = [progressFunction, &inc, &geoms]()
+ ++inc;
+ (*progressFunction)(static_cast<double>(inc)/static_cast<double>(geoms.size()), "");
+ return binaryUnion(geoms, 0, geoms.size(), progressFunction ? &UnitProgress : nullptr);
CascadedPolygonUnion::binaryUnion(const std::vector<const geom::Geometry*> & geoms,
- std::size_t start, std::size_t end)
+ std::size_t start, std::size_t end,
if(end - start == 0) {
return nullptr;
else if(end - start == 1) {
+ if( unitProgress )
+ (*unitProgress)();
return unionSafe(geoms[start], nullptr);
else if(end - start == 2) {
return unionSafe(geoms[start], geoms[start + 1]);
else {
// recurse on both halves of the list
std::size_t mid = (end + start) / 2;
- std::unique_ptr<geom::Geometry> g0(binaryUnion(geoms, start, mid));
- std::unique_ptr<geom::Geometry> g1(binaryUnion(geoms, mid, end));
+ std::unique_ptr<geom::Geometry> g0(binaryUnion(geoms, start, mid, unitProgress));
+ std::unique_ptr<geom::Geometry> g1(binaryUnion(geoms, mid, end, unitProgress));
return unionSafe(std::move(g0), std::move(g1));
diff --git a/src/operation/union/UnaryUnionOp.cpp b/src/operation/union/UnaryUnionOp.cpp
index 09073f59a..7b6601c14 100644
--- a/src/operation/union/UnaryUnionOp.cpp
+++ b/src/operation/union/UnaryUnionOp.cpp
@@ -64,7 +64,7 @@ UnaryUnionOp::unionWithNull(std::unique_ptr<geom::Geometry> g0,
/*public*/
-UnaryUnionOp::Union()
+UnaryUnionOp::Union(geos::util::ProgressFunction* progressFunction)
typedef std::unique_ptr<geom::Geometry> GeomPtr;
@@ -95,7 +95,7 @@ UnaryUnionOp::Union()
GeomPtr unionPolygons;
if(!polygons.empty()) {
- unionPolygons = CascadedPolygonUnion::Union(polygons.begin(), polygons.end(), unionFunction);
+ unionPolygons = CascadedPolygonUnion::Union(polygons.begin(), polygons.end(), unionFunction, progressFunction);
@@ -122,6 +122,10 @@ UnaryUnionOp::Union()
ret = geomFact->createGeometryCollection();
+ if (polygons.empty() && progressFunction) {
+ (*progressFunction)(1.0, "");
return ret;
diff --git a/src/util/Progress.cpp b/src/util/Progress.cpp
index 000000000..ab4041e68
--- /dev/null
+++ b/src/util/Progress.cpp
@@ -0,0 +1,43 @@
+namespace geos {
+ size_t iterCount, size_t& iNotify,
+ size_t notificationInterval) {
+ if (iNotify + 1 == notificationInterval) {
+ progressFunction(static_cast<double>(i + 1)/static_cast<double>(iterCount), nullptr);
+ iNotify = 0;
+ else {
+ ++iNotify;
+ return [ratioMin, ratioMax, &progressFunction](double ratio, const char* msg)
+ progressFunction(ratioMin + (ratioMax - ratioMin) * ratio, msg);
diff --git a/tests/unit/capi/GEOSCoverageSimplifyTest.cpp b/tests/unit/capi/GEOSCoverageSimplifyTest.cpp
index d22ae9b79..ea4ff4353 100644
--- a/tests/unit/capi/GEOSCoverageSimplifyTest.cpp
+++ b/tests/unit/capi/GEOSCoverageSimplifyTest.cpp
@@ -84,10 +84,27 @@ template<> void object::test<3>
const char* inputWKT = "GEOMETRYCOLLECTION(POLYGON(( 0 0,10 0,10.1 5,10 10,0 10,0 0)),POLYGON((10 0,20 0,20 10,10 10,10.1 5,10 0)))";
input_ = fromWKT(inputWKT);
- result_ = GEOSCoverageSimplifyVW(input_, 1.0, 0);
+ struct Cbk
+ double lastRatio = 0;
+ static void Func(double progressRatio, const char* /* msg */, void* userdata)
+ Cbk* self = static_cast<Cbk*>(userdata);
+ self->lastRatio = progressRatio;
+ Cbk cbk;
+ auto context = initGEOS_r(nullptr, nullptr);
+ GEOSContext_setProgressCallback_r(context, &Cbk::Func, &cbk);
+ result_ = GEOSCoverageSimplifyVW_r(context, input_, 1.0, 0);
+ finishGEOS_r(context);
+ ensure_equals("cbk.lastRatio == 1.0", cbk.lastRatio, 1.0);
ensure( result_ != nullptr );
- ensure( GEOSGeomTypeId(result_) == GEOS_GEOMETRYCOLLECTION );
+ ensure_equals( GEOSGeomTypeId(result_), GEOS_GEOMETRYCOLLECTION );
const char* expectedWKT = "GEOMETRYCOLLECTION(POLYGON((0 0,10 0,10 10,0 10,0 0)),POLYGON((10 0,20 0,20 10,10 10,10 0)))";
diff --git a/tests/unit/capi/GEOSDifferenceTest.cpp b/tests/unit/capi/GEOSDifferenceTest.cpp
index ee1e8c823..d38f28c1d 100644
--- a/tests/unit/capi/GEOSDifferenceTest.cpp
+++ b/tests/unit/capi/GEOSDifferenceTest.cpp
@@ -78,5 +78,31 @@ void object::test<3>()
ensure_geometry_equals(result_, expected_, 1e-8);
+template<>
+template<>
+void object::test<4>()
+ set_test_name("progress reporting");
+ // GEOSDifference does not actually implement progress reporting, but our callback will automatically be
+ // called at 100% by the C API "DefaultProgress" handler.
+ useContext();
+ geom1_ = fromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))");
+ geom2_ = fromWKT("POLYGON ((5 5, 5 7, 7 7, 7 5, 5 5))");
+ std::vector<double> fracs;
+ auto progress = [](double f, const char*, void* userData) {
+ static_cast<std::vector<double>*>(userData)->push_back(f);
+ GEOSContext_setProgressCallback_r(ctxt_, progress, &fracs);
+ result_ = GEOSDifference_r(ctxt_, geom1_, geom2_);
+ ensure_equals(fracs.size(), 1u);
+ ensure_equals(fracs[0], 1.0);
} // namespace tut
diff --git a/tests/unit/capi/GEOSUnaryUnionTest.cpp b/tests/unit/capi/GEOSUnaryUnionTest.cpp
index dea0c8941..24f99fcb9 100644
--- a/tests/unit/capi/GEOSUnaryUnionTest.cpp
+++ b/tests/unit/capi/GEOSUnaryUnionTest.cpp
@@ -5,6 +5,7 @@
// geos
#include <geos_c.h>
// std
+#include <algorithm>
#include <cstring>
#include "capi_test_utils.h"
@@ -252,6 +253,60 @@ void object::test<12>()
ensure_equals("length does not match", result_length, input_length, 1e-5);
+template<>
+template<>
+void object::test<13>()
+ set_test_name("progress callback invoked (cascaded union)");
+ useContext();
+ std::vector<GEOSGeometry*> geoms;
+ for (int i = 0; i < 10; i++) {
+ GEOSGeometry* pt = GEOSGeom_createPointFromXY_r(ctxt_, static_cast<double>(i), static_cast<double>(i));
+ GEOSGeometry* circle = GEOSBuffer_r(ctxt_, pt, 3, 8);
+ geoms.push_back(circle);
+ GEOSGeom_destroy_r(ctxt_, pt);
+ input_ = GEOSGeom_createCollection_r(ctxt_, GEOS_GEOMETRYCOLLECTION, geoms.data(), static_cast<unsigned>(geoms.size()));
+ result_ = GEOSUnaryUnion_r(ctxt_, input_);
+ ensure(fracs.size() > 3); // arbitrary
+ // progress reported in-order
+ ensure(std::is_sorted(fracs.begin(), fracs.end()));
+ // no duplicate progress values
+ ensure(std::adjacent_find(fracs.begin(), fracs.end()) == fracs.end());
+template<>
+template<>
+void object::test<14>() {
+ set_test_name("progress callback invoked (input already unioned)");
+ useContext();
+ input_ = fromWKT("POINT (1 1)");
} // namespace tut
diff --git a/tests/unit/coverage/CoverageSimplifierTest.cpp b/tests/unit/coverage/CoverageSimplifierTest.cpp
index be8b1938c..926436409 100644
--- a/tests/unit/coverage/CoverageSimplifierTest.cpp
+++ b/tests/unit/coverage/CoverageSimplifierTest.cpp
@@ -31,7 +31,7 @@ struct test_coveragesimplifier_data {
void checkNoop(
const std::vector<std::unique_ptr<Geometry>>& input)
- std::vector<std::unique_ptr<Geometry>> actual = CoverageSimplifier::simplify(input, 0);
+ std::vector<std::unique_ptr<Geometry>> actual = CoverageSimplifier::simplify(input, 0, nullptr);
// std::cout << w.write(*input[0]) << std::endl;
// std::cout << w.write(*input[1]) << std::endl;
@@ -47,8 +47,16 @@ struct test_coveragesimplifier_data {
double tolerance,
const std::vector<std::unique_ptr<Geometry>>& expected)
- std::vector<std::unique_ptr<Geometry>> actual = CoverageSimplifier::simplify(input, tolerance);
+ double lastRatio = 0.0;
+ geos::util::ProgressFunction myProgress = [&lastRatio](double ratio, const char*)
+ ensure("ratio >= lastRatio", ratio >= lastRatio);
+ lastRatio = ratio;
+ return true;
+ std::vector<std::unique_ptr<Geometry>> actual = CoverageSimplifier::simplify(input, tolerance, &myProgress);
checkArrayEqual(expected, actual);
+ ensure("lastRatio == 1.0", lastRatio == 1.0);
void checkResultInner(
@@ -56,7 +64,7 @@ struct test_coveragesimplifier_data {
double tolerance,
- std::vector<std::unique_ptr<Geometry>> actual = CoverageSimplifier::simplifyInner(input, tolerance);
+ std::vector<std::unique_ptr<Geometry>> actual = CoverageSimplifier::simplifyInner(input, tolerance, nullptr);
@@ -477,7 +485,7 @@ void object::test<30> ()
try {
std::vector<std::unique_ptr<Geometry>> result =
- CoverageSimplifier::simplify(input, 10);
+ CoverageSimplifier::simplify(input, 10, nullptr);
catch (geos::util::IllegalArgumentException&) {
ensure("caught IllegalArgumentException", true);
@@ -497,7 +505,7 @@ void object::test<31> ()
try {
diff --git a/tests/unit/coverage/TPVWSimplifierTest.cpp b/tests/unit/coverage/TPVWSimplifierTest.cpp
index ce55c9965..e8762ce42 100644
--- a/tests/unit/coverage/TPVWSimplifierTest.cpp
+++ b/tests/unit/coverage/TPVWSimplifierTest.cpp
@@ -31,7 +31,7 @@ struct test_tpvwsimplifier_data {
std::unique_ptr<Geometry> geom = r.read(wkt);
const MultiLineString* mls = static_cast<const MultiLineString*>(geom.get());
- std::unique_ptr<Geometry> actual = TPVWSimplifier::simplify(mls, tolerance);
+ std::unique_ptr<Geometry> actual = TPVWSimplifier::simplify(mls, tolerance, nullptr);
ensure_equals_geometry(actual.get(), geom.get());
@@ -42,7 +42,7 @@ struct test_tpvwsimplifier_data {
const std::string& wktExpected)
auto mls = r.read<MultiLineString>(wkt);
- std::unique_ptr<Geometry> actual = TPVWSimplifier::simplify(mls.get(), tolerance);
+ std::unique_ptr<Geometry> actual = TPVWSimplifier::simplify(mls.get(), tolerance, nullptr);
std::unique_ptr<Geometry> expected = r.read(wktExpected);
ensure_equals_geometry(actual.get(), expected.get());
@@ -76,7 +76,7 @@ struct test_tpvwsimplifier_data {
constraints = r.read<MultiLineString>(wktConstraints);
- std::unique_ptr<Geometry> actual = TPVWSimplifier::simplify(lines.get(), freeRings, constraints.get(), tolerance);
+ std::unique_ptr<Geometry> actual = TPVWSimplifier::simplify(lines.get(), freeRings, constraints.get(), tolerance, nullptr);
// std::cout << "-- actual" << std::endl;
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index f10e22e84..7ef4c4613 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -1009,7 +1009,7 @@ std::vector<GeometryOpCreator> opRegistry {
[](const Geometry& geom, double d) {
std::vector<const Geometry*> coverage = toList(geom);
- = geos::coverage::CoverageSimplifier::simplify(coverage, d);
+ = geos::coverage::CoverageSimplifier::simplify(coverage, d, nullptr);
//-- convert list type (be nice to avoid this)
std::vector<std::unique_ptr<const Geometry>> resultList;
for (std::size_t i = 0; i < result.size(); i++) {
Summary of changes:
capi/geos_c.cpp | 1 -
capi/geos_c.h.in | 32 ++++++
capi/geos_ts_c.cpp | 128 ++++++++++++++++-----
include/geos/coverage/CoverageSimplifier.h | 24 ++--
include/geos/coverage/TPVWSimplifier.h | 14 ++-
include/geos/geom/Geometry.h | 9 +-
.../geos/operation/union/CascadedPolygonUnion.h | 20 +++-
include/geos/operation/union/UnaryUnionOp.h | 13 ++-
include/geos/util/Progress.h | 84 ++++++++++++++
src/coverage/CoverageSimplifier.cpp | 37 +++---
src/coverage/TPVWSimplifier.cpp | 71 ++++++++++--
src/geom/Geometry.cpp | 4 +-
src/geom/util/GeometryFixer.cpp | 3 +-
src/operation/overlayng/OverlayNGRobust.cpp | 3 +-
src/operation/overlayng/UnaryUnionNG.cpp | 3 +-
src/operation/polygonize/BuildArea.cpp | 2 +-
src/operation/union/CascadedPolygonUnion.cpp | 36 ++++--
src/operation/union/UnaryUnionOp.cpp | 8 +-
src/util/Progress.cpp | 43 +++++++
tests/unit/capi/GEOSCoverageSimplifyTest.cpp | 21 +++-
tests/unit/capi/GEOSDifferenceTest.cpp | 26 +++++
tests/unit/capi/GEOSUnaryUnionTest.cpp | 55 +++++++++
tests/unit/coverage/CoverageSimplifierTest.cpp | 18 ++-
tests/unit/coverage/TPVWSimplifierTest.cpp | 6 +-
util/geosop/GeometryOp.cpp | 2 +-
25 files changed, 554 insertions(+), 109 deletions(-)
create mode 100644 include/geos/util/Progress.h
create mode 100644 src/util/Progress.cpp
hooks/post-receive
More information about the geos-commits
